DrVideo Posted March 19, 2023 Share Posted March 19, 2023 What is the best replacement power supply for the Jaguar? Is using this one ok? https://www.ebay.com/itm/153991341903 I don't want to risk damaging the Jaguar. Quote Link to comment Share on other sites More sharing options...
+LS650 Posted March 20, 2023 Share Posted March 20, 2023 When I bought a replacement power supply, I went with an OEM from Best. You can find them here: Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 20, 2023 Share Posted March 20, 2023 You can also use a PSU from a sega Genesis/Megadrive. They have the same polarity and specs. I've been using a Genesis model 1 PSU with my Jag for over 20 years now and never had an issue. I do have an OEM PSU connected to my JagCD but again, same specs. Quote Link to comment Share on other sites More sharing options...
RollOut Posted March 20, 2023 Share Posted March 20, 2023 I am also using a genesis model 1 PSU. I tried ordering an after market PSU that said it was jaguar compatible off ebay a while back. Turns out they had the polarity backwards (I double checked before plugging in). I was lucky I didn't fry my Jag. After that I just stuck with the model 1 Genesis PSU, and no issues. Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted March 20, 2023 Share Posted March 20, 2023 Make sure it is made for the Genesis 1, not the Genesis 2. The polarity for the latter is the opposite. 1 Quote Link to comment Share on other sites More sharing options...
+madman Posted March 20, 2023 Share Posted March 20, 2023 Assuming the adapter in the auction is center negative, you're good. 1 Quote Link to comment Share on other sites More sharing options...
+cubanismo Posted March 20, 2023 Share Posted March 20, 2023 There's a sticky thread on this I think... The OEM power supplies, like many old power supplies, are pretty inefficient. They're not going to put you out of a home or ruin the planet, but if you like efficiency for efficiency's sake, get a modern switching power supply with equivalent specs instead. Links to known working ones in the sticky thread. 1 Quote Link to comment Share on other sites More sharing options...
Madwindoman Posted March 22, 2023 Share Posted March 22, 2023 Here’s what I’m using. I got it from digikey a couple years ago. Pretty sure I got the recommendation from the pinned thread about the Jaguar power supply Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 22, 2023 Share Posted March 22, 2023 On 3/20/2023 at 10:50 AM, Zerosquare said: Make sure it is made for the Genesis 1, not the Genesis 2. The polarity for the latter is the opposite. The genesis model 2 PSU has a smaller diameter center opening. It won't even fit in the Jaguar's power port. 1 Quote Link to comment Share on other sites More sharing options...
