SlagOMatic Posted March 19, 2023 Share Posted March 19, 2023 Forgive me, I'm old and the process of re-learning everything I'd forgotten decades ago is rough. 🙂  Back in the days of 300bps software downloading from (semi-)local BBSs, some of the stuff I downloaded were simple application files (COM or OBJ) but others were disk images. I'd download the (comparatively large) file to my RAM disk, sign off the BBS, soft reboot back into SpartaDOS, then run a program. The program would ask me for the disk image I'd downloaded and prompt me to insert a blank disk into the drive, at which point it would basically restore the data back to the disk. Sort of like an ISO for floppy disks. I also believe it had a function to create disk images from disks in much the same way.  I want to say that the files I downloaded were ATR images but that just might be the result of more modern exposure to emulators and things like SIO2PC.  Does anyone remember what program I may have used back then? Quote Link to comment Share on other sites More sharing options...
BillC Posted March 19, 2023 Share Posted March 19, 2023 (edited) 14 minutes ago, SlagOMatic said: Forgive me, I'm old and the process of re-learning everything I'd forgotten decades ago is rough. 🙂  Back in the days of 300bps software downloading from (semi-)local BBSs, some of the stuff I downloaded were simple application files (COM or OBJ) but others were disk images. I'd download the (comparatively large) file to my RAM disk, sign off the BBS, soft reboot back into SpartaDOS, then run a program. The program would ask me for the disk image I'd downloaded and prompt me to insert a blank disk into the drive, at which point it would basically restore the data back to the disk. Sort of like an ISO for floppy disks. I also believe it had a function to create disk images from disks in much the same way.  I want to say that the files I downloaded were ATR images but that just might be the result of more modern exposure to emulators and things like SIO2PC.  Does anyone remember what program I may have used back then? There were 2 programs that converted a floppy to an image file back in the day: 1) SCOPY.COM - included with SpartaDOS, all sectors with no compression, used .SCP extension. 2) Disk Communicator - compression/archiving program for full boot disks from CSS, compression   reduces file size for transmission via modem, used .DCM extension. Edited March 19, 2023 by BillC 1 Quote Link to comment Share on other sites More sharing options...
SlagOMatic Posted March 19, 2023 Author Share Posted March 19, 2023 1 minute ago, BillC said: There were 2 programs that converted a floppy to an image file back in the day: 1) SCOPY.COM - included with SpartaDOS, all sectors with no compression, used .SCP extension. 2) Disk Communicator - compression/archiving program for full boot disks from CSS, compression   reduces file size for transmission via modem, used .DCM extension. Disk Communicator! That was it. Thanks!! Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted March 19, 2023 Share Posted March 19, 2023 That was some kind of Disk to File / File to Disk program, like: Â - Diskcommunicator by Bob Puff (creates DCM images, uses compression) - Bootlegger (compatible to either Masher, Scrunch or Shrink) - Masher-XL / Masher-XE (works with 90k/180k disks only) - Scrunch/Unscrunch (works with 90k/180k disks only) - UUencode/UUDecode - YauEncode/YauDecode - Shrink-XL / Shrink-XE (uses compression, 90k/180k disks only) - Superboot (compatible to either Masher, Scrunch or Shrink) - Scopy from SpartaDOS Â Â EDIT: My reply was too slow... PACKER4.zip 4 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted March 19, 2023 Share Posted March 19, 2023 3 minutes ago, BillC said: SCOPY.COM - included with SpartaDOS, all sectors with no compression Well, there was some compression with SCOPY in the form of zero-filled sectors would not be stored in the SCP file, but I guess sectors with any non-zero data would have no further compression. Quote Link to comment Share on other sites More sharing options...
+Larry Posted March 19, 2023 Share Posted March 19, 2023 Scrunch/UnScrunch was the first one that I remember using, but when Puff released Disk Communicator, it pretty much made the others obsolete. I knew of several local hackers that spent a lot of time trying to figure out how to use such a program to send protected disk images. I don't remember a lot, but they were "Archiver" guys, so the Archiver would have been part of the process. 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted March 20, 2023 Share Posted March 20, 2023 15 hours ago, Larry said: Scrunch/UnScrunch was the first one that I remember using, but when Puff released Disk Communicator, it pretty much made the others obsolete. I knew of several local hackers that spent a lot of time trying to figure out how to use such a program to send protected disk images. I don't remember a lot, but they were "Archiver" guys, so the Archiver would have been part of the process. I probably need to get out my old floppies. I know I have Scrunch / Unscrunch and 'The Masher' and there might be one or two more. 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted March 20, 2023 Share Posted March 20, 2023  1 hour ago, bf2k+ said: I probably need to get out my old floppies. I know I have Scrunch / Unscrunch and 'The Masher' and there might be one or two more.  Here are some compacting tools I've collected (720K image)... Utilities 2.3-Compacting Utilities.atr Quote Link to comment Share on other sites More sharing options...
+Larry Posted March 20, 2023 Share Posted March 20, 2023 19 hours ago, BillC said: There were 2 programs that converted a floppy to an image file back in the day: 1) SCOPY.COM - included with SpartaDOS, all sectors with no compression, used .SCP extension. 2) Disk Communicator - compression/archiving program for full boot disks from CSS, compression   reduces file size for transmission via modem, used .DCM extension.  Will SCOPY run under other dos versions, or just Sparta? Quote Link to comment Share on other sites More sharing options...
BillC Posted March 20, 2023 Share Posted March 20, 2023 3 hours ago, Larry said: Â Will SCOPY run under other dos versions, or just Sparta? I don't know, didn't use it much and never tried it with another DOS. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted March 23, 2023 Share Posted March 23, 2023 AFAIK Scopy needs command line parameters, so only Sparta-Dos/BeWe-Dos or compatible. 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted March 23, 2023 Share Posted March 23, 2023 Thanks! I saw an example of the command + parameters when I booted up 3.2g. It's interesting that SCOPY is on several 3.2 disks, but there is nothing in the manual about it.  Does anyone know what the structure of a SCOPY image looks like? I am curious, but can't find anything here or on the web about the file structure. Since it does a mild form of compressing empty sectors, it sounds similar to Disk Communicator. (?) Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted March 25, 2023 Share Posted March 25, 2023 I used SCOPY quite a lot back in the 80's before DiskComm came out but honestly I don't remember much about it other than it required command line parameters. Quote Link to comment Share on other sites More sharing options...
BillC Posted March 27, 2023 Share Posted March 27, 2023 (edited) On 3/23/2023 at 8:21 AM, Larry said: Thanks! I saw an example of the command + parameters when I booted up 3.2g. It's interesting that SCOPY is on several 3.2 disks, but there is nothing in the manual about it. SCOPY wasn't released until after the SDCS manual was already printed, rather than modifying this manual information about SCOPY was included in the R-Time 8/SDCS Supplement.  https://archive.org/details/R-Time-8_SDCS_Supplement_1985_ICD/mode/2up?view=theater Edited March 27, 2023 by BillC 1 Quote Link to comment Share on other sites More sharing options...
Doctorx Posted March 31, 2023 Share Posted March 31, 2023 Probably getting this wrong - but i thought that part of the header of one of the archivers always showed ‘3hrunk’ which leads me to believe the archiver was called shrink? If im wrong, i would be curious as to what im thinking.. i do recall quite vividly disk communicator as well.   Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted March 31, 2023 Share Posted March 31, 2023 There definitely was one called Shrink and ShrinkXE. Quote Link to comment Share on other sites More sharing options...
