+KayBee Posted March 31, 2023 Share Posted March 31, 2023 Hello All, in terms of Apple I am new here but have some II+/IIe experience from my youth. I now have a IIe with no floppy drives but with an SD Disk ][ Plus storage solution. I have put many .DSK on the SD and they all work. Sadly except my favorite Apple game as a little kid that I want to show my son, Old Ironsides. I have tried 5 different versions, from Asov, TOSEC, and elsewhere but none work. Black screen with square bracket, no cursor. I am able to play it on the Mac via emulation in Virtual II. The manual for the game says "Old Ironsides will work on any Apple* or Apple II Plus* with 48K and a disk drive with DOS 3.3 (16 sector)" but I am very rusty on my IIe abilities so I don't know if one of those specifications is the root of my issue. So I have a couple of questions, does anyone else have similar hardware (SD storage) and is able to play the game? Or is it somehow not compatible? Many thanks. KB Quote Link to comment Share on other sites More sharing options...
Iamgroot Posted March 31, 2023 Share Posted March 31, 2023 The most common problem with these cards is to make sure they are set up correctly for slot 6. Go into the cards menu and see if anything can be changed to make an image locked in to slot 6 Quote Link to comment Share on other sites More sharing options...
nick3092 Posted March 31, 2023 Share Posted March 31, 2023 (edited) I can't speak to whatever SD device you are using. But I confirm the image from Asimov boots fine on my enhanced IIe using my Floppy Emu with the drive controller in slot 6. Edited March 31, 2023 by nick3092 Quote Link to comment Share on other sites More sharing options...
+KayBee Posted March 31, 2023 Author Share Posted March 31, 2023 Interesting, thank you both. Nick, thanks especially for trying it now I know it works on your enhanced it should work on mine. EDIT: it works, the SD floppy emulator had been in slot 7 on the machine. (I bought it this way) I moved to slot 6 and the game now works. Thanks again. Quote Link to comment Share on other sites More sharing options...
