BartOrloy Posted April 20, 2023 Share Posted April 20, 2023 (edited) hello, i am trying to compile firmware from git. if i use esp32_platform_version = 3.4.0 i end with Tool Manager: Installing espressif/toolchain-riscv32-esp @ 8.4.0+2021r1 Error: Could not find the package with 'espressif/toolchain-riscv32-esp @ 8.4.0+2021r1' requirements for your system 'linux_x86_64' i found no way ho to solve this, but i see there is no package like that on platformio registry there is only 8.4.0+2021r2-patch5. so i decided to try esp32_platform_version = 6.1.0, it started to compile, but there is another error In file included from lib/device/sio/network.h:4, from lib/device/network.h:5, from lib/media/atari/diskTypeAtx.h:8, from lib/media/media.h:7, from lib/fuji/../device/sio/disk.h:6, from lib/fuji/../device/disk.h:5, from lib/fuji/fujiDisk.h:4, from lib/fuji/fujiDisk.cpp:1: /root/.platformio/packages/framework-espidf/components/driver/deprecated/driver/timer.h:16:2: warning: #warning "legacy timer group driver is deprecated, please migrate to driver/gptimer.h" [-Wcpp] 16 | #warning "legacy timer group driver is deprecated, please migrate to driver/gptimer.h" | ^~~~~~~ lib/media/atari/diskTypeAtx.cpp: In member function 'void MediaTypeATX::_process_sector(AtxTrack&, AtxSector*, uint16_t)': lib/media/atari/diskTypeAtx.cpp:250:29: error: 'esp_random' was not declared in this scope; did you mean 'srandom'? 250 | uint32_t rand = esp_random(); | ^~~~~~~~~~ | srandom Compiling .pio/build/fujinet-v1-4mb/lib7ec/device/adamnet/disk.o Archiving .pio/build/fujinet-v1-4mb/libef6/libnetwork-protocol.a Indexing .pio/build/fujinet-v1-4mb/libef6/libnetwork-protocol.a Compiling .pio/build/fujinet-v1-4mb/lib7ec/device/adamnet/fuji.o Compiling .pio/build/fujinet-v1-4mb/lib7ec/device/adamnet/keyboard.o *** [.pio/build/fujinet-v1-4mb/lib9fa/media/atari/diskTypeAtx.o] Error 1 ================================= [FAILED] Took 137.18 seconds ================================= i use this https://hub.docker.com/r/petewall/platformio container with up to date packages thx for any advices Edited April 20, 2023 by BartOrloy Quote Link to comment Share on other sites More sharing options...
mozzwald Posted April 20, 2023 Share Posted April 20, 2023 (edited) 19 minutes ago, BartOrloy said: Tool Manager: Installing espressif/toolchain-riscv32-esp @ 8.4.0+2021r1 Error: Could not find the package with 'espressif/toolchain-riscv32-esp @ 8.4.0+2021r1' requirements for your system 'linux_x86_64' Make sure you have your platformio.ini setup correctly per the wiki instructions. https://github.com/FujiNetWIFI/fujinet-platformio/wiki/Board-Bring-Up-Software Also, when running the build, use the platformio menu and build for your specific target as shown here: If you use the status bar to build, you must pick the correct env on the status bar as well. edit: use 3.4.0 platform version. The newer one has not been tested completely yet and is likely broken Edited April 20, 2023 by mozzwald Add platform version Quote Link to comment Share on other sites More sharing options...
BartOrloy Posted April 20, 2023 Author Share Posted April 20, 2023 are you bot? Quote Link to comment Share on other sites More sharing options...
mozzwald Posted April 20, 2023 Share Posted April 20, 2023 17 minutes ago, BartOrloy said: are you bot? Lol, last time I checked I was meat and bones, not bare metal and code Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 21, 2023 Share Posted April 21, 2023 1 Quote Link to comment Share on other sites More sharing options...
BartOrloy Posted April 21, 2023 Author Share Posted April 21, 2023 (edited) ok, because your reply was in sense of i tried to turn it off and on... platformio is not equal editor btw. i was able compile this revision 2588bc14 thx for assistance Edited April 21, 2023 by BartOrloy 1 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted April 21, 2023 Share Posted April 21, 2023 5 minutes ago, BartOrloy said: ok, because your reply was in sense of i tried to turn it off and on Yes, start with the easy stuff Quite often we say the same things over. We've even added giant red boxes with "IMPORTANT" and people still manage to skip that step. 8 minutes ago, BartOrloy said: btw. i was able compile this revision 2588bc14 That's a very old commit. are you building the entire codebase from that point or you used that commit as a fix for the current master? There are some other folks having the same issue and I was also able to replicate it on a Windows 10 computer so we need to figure out a proper fix. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted April 22, 2023 Share Posted April 22, 2023 @BartOrloy PlatformIO has provided a fix that I've tested on Windows 10 and works. Until it's in our repo you can apply it manually to your platformio.ini file. https://github.com/platformio/platform-espressif32/issues/1081#issuecomment-1518601054 1 Quote Link to comment Share on other sites More sharing options...
