+Atari2600PAL Posted June 6 Author Share Posted June 6 6 hours ago, Ksarul said: Thanks for the pictures @Atari2600PAL--I have added them to my hardware reference folder for CorComp FDCs. One the DSRs, I have a sneaking suspicion that that DSR on your board may be an older revision specific to the Rev C boards. If @atrax27407 doesn't have it in his DSR archive, it might be a good idea to read them out and put the BIN files up here for preservation purposes. I've just dumped the DSR just in case, if @atrax27407 requires a copy I can upload here? Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted June 6 Share Posted June 6 I would appreciate it! Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 6 Author Share Posted June 6 35 minutes ago, atrax27407 said: I would appreciate it! I dumped this using Force command utility with a CRUBASE of 1100, should there be a 2nd dump please? If so, what CRUBASE should I specify (am new to this!) CC9900REVCDSRROM 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted June 6 Share Posted June 6 That dump is of the first of the two EPROMs and should be Bank 1. If you can specify a length of the dump in Force command, use 16K and you should get both banks. Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 6 Author Share Posted June 6 11 minutes ago, atrax27407 said: That dump is of the first of the two EPROMs and should be Bank 1. If you can specify a length of the dump in Force command, use 16K and you should get both banks. Don't think @jedimatt42's utility does 16kb (only 8kb/4kb), will try to find another Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 6 Author Share Posted June 6 42 minutes ago, atrax27407 said: That dump is of the first of the two EPROMs and should be Bank 1. If you can specify a length of the dump in Force command, use 16K and you should get both banks. It's let me override to 16384, don't know what's in the file though Thanks CC9900REVC16KDSRROM 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted June 6 Share Posted June 6 Unfortunately, the second 8K didn't copy correctly. Can you load F'WEB on your TI system? Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 6 Author Share Posted June 6 14 minutes ago, atrax27407 said: Unfortunately, the second 8K didn't copy correctly. Can you load F'WEB on your TI system? I’ve downloaded funnel web 40 dsk to my tipi, but currently no idea what to do next. Will take a proper look at it tomorrow sometime Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted June 6 Share Posted June 6 I'll send you a DSR dump that works only from F'web (uses some utilities from the F'web kernel). 1 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 6 Author Share Posted June 6 19 minutes ago, atrax27407 said: I'll send you a DSR dump that works only from F'web (uses some utilities from the F'web kernel). Ok, thanks Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted June 6 Share Posted June 6 Here is the DSR Dump series - they are "Load and Run" from F'web. DSRDUMP.dsk 2 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 6 Author Share Posted June 6 Thanks. Once I’ve worked out how to get f’web to load from the tipi I’ll give it a go Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 6 Share Posted June 6 29 minutes ago, Atari2600PAL said: Thanks. Once I’ve worked out how to get f’web to load from the tipi I’ll give it a go make a folder, put it in there, map DSK1. to that folder, have your TIPI at 1000 or 1100 cru.. should mostly work have to try it again now that we have sector access 1 Quote Link to comment Share on other sites More sharing options...
Fritz442 Posted June 6 Share Posted June 6 (edited) These might be the ones ya'll are looking for. These came from my 2793 card. Not sure if they work on REV-C card. CC_1984_DSDD_menu_bank1.bin CC_1984_DSDD_menu_bank2.bin Edited June 6 by Fritz442 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 7 Author Share Posted June 7 13 hours ago, arcadeshopper said: make a folder, put it in there, map DSK1. to that folder, have your TIPI at 1000 or 1100 cru.. should mostly work have to try it again now that we have sector access Thanks that worked (once I remembered I needed to launch XB) 1 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 7 Author Share Posted June 7 @atrax27407 I've managed to run f'web and then ran the 16k utility with CRU of 1100 giving me the file attached DSRDMP1 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted June 7 Share Posted June 7 I downloaded your DSRDUMP file and split it into two 8K chunks and found that there are a couple of minor variations from the files that I have. I suspect that they are to accommodate the FDC on your controller (which was an early version). There were undoubtedly some circuit changes because of it. As Shakespeare wrote "therein lies the rub". 1 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 7 Author Share Posted June 7 1 minute ago, atrax27407 said: I downloaded your DSRDUMP file and split it into two 8K chunks and found that there are a couple of minor variations from the files that I have. I suspect that they are to accommodate the FDC on your controller (which was an early version). There were undoubtedly some circuit changes because of it. As Shakespeare wrote "therein lies the rub". Ok, thanks. Will keep an eye on eBay for a newer card. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 7 Share Posted June 7 4 minutes ago, Atari2600PAL said: Ok, thanks. Will keep an eye on eBay for a newer card. I'm putting a some up on my store soon Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted June 7 Author Share Posted June 7 3 minutes ago, arcadeshopper said: I'm putting a some up on my store soon Ok, will keep an eye out thanks (or could you give me a heads up when they are available please?) Many thanks 1 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted July 2 Author Share Posted July 2 I picked up a cheap (sold as untested) PHP1240 disk controller, which I realise is single density, and was wondering if anyone can confirm whether I can at least test it, when it arrives, with my existing double density floppy drives please? A web search suggests an SD controller can use DD drives (as SD) but I'm not 100% convinced yet Any thoughts please? (I just picked it up as it seemed cheap and I'd like one in my collection. I have a replacement CC9900 on order with arcadeshopper that will be my main controller) Many thanks 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted July 2 Share Posted July 2 Any of the double-density drives also work with single-density controllers, so your drives should work fine with the TI controller as long as controller, drives, and cables are all functional. 1 Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted July 2 Author Share Posted July 2 3 minutes ago, Ksarul said: Any of the double-density drives also work with single-density controllers, so your drives should work fine with the TI controller as long as controller, drives, and cables are all functional. Many thanks, will give it a go then when it arrives Quote Link to comment Share on other sites More sharing options...
+mizapf Posted July 2 Share Posted July 2 4 hours ago, Atari2600PAL said: A web search suggests an SD controller can use DD drives (as SD) but I'm not 100% convinced yet Double density is just a different encoding of the data which reduces the flow changes of FM recording (single density), so the cell size may be half as big as the single density cell size. From the physical point of view of the drive, there is no difference. High density, however, uses a different magnetic force for recording and requires a suitable recording medium (high density floppy disks). This is the reason why high density disks don't usually work with double density drives. Quote Link to comment Share on other sites More sharing options...
+Atari2600PAL Posted July 2 Author Share Posted July 2 5 minutes ago, mizapf said: Double density is just a different encoding of the data which reduces the flow changes of FM recording (single density), so the cell size may be half as big as the single density cell size. From the physical point of view of the drive, there is no difference. High density, however, uses a different magnetic force for recording and requires a suitable recording medium (high density floppy disks). This is the reason why high density disks don't usually work with double density drives. Thanks for the info Quote Link to comment Share on other sites More sharing options...
