Bandolito Posted July 20, 2023 Share Posted July 20, 2023 OK, I just recently got a FujiNet and I love it. After playing with it some now I want to create the following setup but have so far been unsuccessful: I want to boot my Atari from my physical 810 drive set as D1, but have the FujiNet still provide a new, empty ATR I created and loaded into slot 2 in the FujiNet. My goal is to be able to copy my physical disks in my 810 drive to the ATR image in the FujiNet D2 and just save files to D2 if I wanted to. What are the steps needed to achieve this? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 20, 2023 Share Posted July 20, 2023 Plan A. Try changing Enable SIO Status wait routine to YES (this got changed to No by default for some reason). Failing that, Set CONFIG boot disk to No, and use the web UI to mount stuff. It looks like I will need to do some more work to improve the status wait (so that FujiNet's config disk will get out of the way, if another device answers the status.) -Thom Quote Link to comment Share on other sites More sharing options...
Bandolito Posted July 20, 2023 Author Share Posted July 20, 2023 Thom, I did as you suggested and it worked! Thank you! Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 21, 2023 Share Posted July 21, 2023 8 hours ago, Bandolito said: Thom, I did as you suggested and it worked! Thank you! curious, which one? -Thom Quote Link to comment Share on other sites More sharing options...
Bandolito Posted July 24, 2023 Author Share Posted July 24, 2023 Set the CONFIG boot to disk to NO. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 24, 2023 Share Posted July 24, 2023 Ok. Thanks. -Thom Quote Link to comment Share on other sites More sharing options...
