DistantStar001 Posted August 8, 2023 Share Posted August 8, 2023 Just what the title says. I like Tetris and I have several TRS-80 Model 1s (as well as a Model III) and I'd like to enjoy the combination someday. After all, if this thing can do Zaxxon, tetris shouldn't be that hard. However, the only version I've found is for the Model 4... So not so helpful. I know it's out for the Coco and other platforms. I was able to get a version for my Apple IIs, Atari 8-bits, C64s, C128s, VIC-20s, BBC Micro, 5160, Macintosh Plus, 80 column PET (fixed 40 column version but it owrks), ZX Spectrum, and even my stock 1K ZX81!?!? But not my TRS-80. And if the ZX81 can do it on 1K of RAM, surly my TRS-80s can do it with 16K (or even just 4). Anyone know where this might be floating around? Quote Link to comment Share on other sites More sharing options...
MrDave Posted August 13, 2023 Share Posted August 13, 2023 I guess you will have to write one My first z80 program was a tetris type game.. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 31, 2023 Share Posted August 31, 2023 That's an interesting challenge @DistantStar001 Please let me know if this works in real hardware. I only have tested on emulation. BTW, this would be my first game programmed for TRS-80. WASD control. Assembled at $4a00 ttris.cmd Arrows control. Assembled at $5200 for TRS-DOS ttris2.cmd Enhanced title screen. Lowercase messages. Cleans correctly the screen for Model 1. Assembled at $5200 for TRS-DOS ttris3.cmd Solved game over bug on Model 1. ttris4.cmd 3 Quote Link to comment Share on other sites More sharing options...
George Phillips Posted September 1, 2023 Share Posted September 1, 2023 Nicely done. Change the ORG from $4A00 to $5200 so it'll run under TRS-DOS and it'll work fine on a real machine. TRS-80 users are likely to expect the arrow keys for control rather than WASD. 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 1, 2023 Share Posted September 1, 2023 4 hours ago, George Phillips said: Nicely done. Change the ORG from $4A00 to $5200 so it'll run under TRS-DOS and it'll work fine on a real machine. TRS-80 users are likely to expect the arrow keys for control rather than WASD. Oh my! Never noticed there were arrows on the keyboard, and the right address for TRS-DOS. I've attached the new CMD to my first post. Thanks a lot! 1 Quote Link to comment Share on other sites More sharing options...
George Phillips Posted September 2, 2023 Share Posted September 2, 2023 Thanks; works nicely now under TRS-DOS. You can use lower-case in messages which will work fine on the Model III and most Model I's. However, earlier Model I's did not have lower-case and need a little bit of code to handle the conversion. Their video memory only had 7 bits per byte! Here's a little code fragment that will write a character to the screen and automatically uppercase it if necessary: ; HL pointing to screen memory, A is character to display ld (hl),a cp (hl) jr z,ok res 5,(hl) ok: Of course, you could do a single test at the start of the program and uppercase all messages if the machine doesn't support lower-case. 1 Quote Link to comment Share on other sites More sharing options...
DistantStar001 Posted September 3, 2023 Author Share Posted September 3, 2023 On 8/31/2023 at 11:59 AM, nanochess said: That's an interesting challenge @DistantStar001 Please let me know if this works in real hardware. I only have tested on emulation. BTW, this would be my first game programmed for TRS-80. WASD control. Assembled at $4a00 ttris.cmd 1.49 kB · 10 downloads Arrows control. Assembled at $5200 for TRS-DOS ttris2.cmd 1.49 kB · 3 downloads Can you covert this to a .cas or .wav file (or tell me how to)? I'm having issues with the floppy controller on my expansion interface. Quote Link to comment Share on other sites More sharing options...
George Phillips Posted September 3, 2023 Share Posted September 3, 2023 Here you go. I used trld ttrs2a.cmd ttrs2a.lcas to do the conversion http://48k.ca/trld.html The name for SYSTEM is TTRIS2 but, as always, you can just give the first letter T to the ?* prompt. Running it on the Model 1 I noticed a small bug in that the screen is cleared with 0's which end up displaying as @ signs. I didn't think to try it on a Model 1. As penance I patched the code to clear with character 128 hence the ttris2a name. ttris2a.cas ttris2a.cmd 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 4, 2023 Share Posted September 4, 2023 I've enhanced the title screen, added lowercase messages, and solved the screen cleaning bug. Added as ttris3.cmd in my original post. 1 Quote Link to comment Share on other sites More sharing options...
George Phillips Posted September 4, 2023 Share Posted September 4, 2023 One tiny bug left. The "Press Space" message that appears at the end of the game is scrambled if lower case isn't available. Tested it with trs80gp -m1 -nlc ttris3.cmd 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 5, 2023 Share Posted September 5, 2023 10 hours ago, George Phillips said: One tiny bug left. The "Press Space" message that appears at the end of the game is scrambled if lower case isn't available. Tested it with trs80gp -m1 -nlc ttris3.cmd I've corrected it and attached the file ttris4.cmd to my original post. Thanks for the report! 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 20, 2023 Share Posted September 20, 2023 Now with source code available at Github https://github.com/nanochess/Ttris/ 2 Quote Link to comment Share on other sites More sharing options...
DistantStar001 Posted October 18, 2023 Author Share Posted October 18, 2023 On 9/20/2023 at 3:06 PM, nanochess said: Now with source code available at Github https://github.com/nanochess/Ttris/ I know it's been a while, and sorry about that. Life's been getting away from me. But I really wanted to say thank you for this! I can't wait until I have a chance top try it. 1 Quote Link to comment Share on other sites More sharing options...
