+Al_Nafuur Posted September 15, 2023 Share Posted September 15, 2023 Here is some information how to connect the components (might change in the future): Raspberry Pi SN74LVC245AN 2600 Cartridge Port 5V +5V (pin 23) 3V3 Vcc (pin 20) GND GND, OE (pin 10,19) GND, sGND (pin 12,24) GPIO 0 - GPIO 12 A0 - A12 (pin 8-1,22,21,19,20,18) GPIO 13 - GPIO 20 A1 - A8 (pin 2-9) GPIO 21 DIR (pin 1) B1 - B8 (pin 18-11) D1 - D8 (pin 9-11,13-17) 2 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 15, 2023 Author Share Posted September 15, 2023 Setting up the Raspberry Pi development environment: Download Raspberry 32bit PiOS (here alternatively 64bit?) Install it to an SD Connect the Raspberry Pi to your breadboard (HowTo) Boot the Pi On a Pi3 I recommend resizing the 100MB swap file to at least 1GB (HowTo) Added to "/boot/cmdline.txt" as root: isolcpus=domain,managed_irq,2,3 If you like to make changes to the code, install any code editor/IDE you like (Install VS Code HowTo). Clone the Stella fork and switch to the dev branch. Open the LXTerminal and type: cd /path/to/your-git-dir/ git clone https://github.com/Al-Nafuur/stella.git cd stella git checkout feature/cartridgeportThread Install SDL2 dev. Open the LXTerminal and type: sudo apt-get update sudo apt-get install libsdl2-dev If your are using a Raspberry Pi3B+ you have to change the peripheral base address (define of PI_PERI_BASE) in "stella/src/emucore/CartPort.cxx" line 30-34 Build Stella. Open the LXTerminal and type: cd /path/to/your-git-dir/stella ./configure --host=rtstella && make -j2 all current build needs root rights to access GPIO and timer hardware directly building and linking takes about 1 hour Download this file to your ROMs dir: CartridgePort.bin Start Stella. Open the LXTerminal and type: cd /path/to/your-git-dir/stella sudo export SDL_AUDIODRIVER=alsa echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor sudo echo -1 > /proc/sys/kernel/sched_rt_runtime_us sudo ./stella -plr.timemachine 0 -dev.timemachine 0 /path/to/your-ROM-dir/CartridgePort.bin The rtstella build needs to be started without nice and timemachine disabled, also the file selector doesn't worked so you have to load the bin file at startup Before you insert or remove a cartridge from the port unplug the 5V wire from the breadboard and reattach it when the cart is plugged in. After you have plugged in the 5V you can start the cart by selecting the bin file in the Stella file selector. 2 Link to comment Share on other sites More sharing options...
JetSetIlly Posted September 16, 2023 Share Posted September 16, 2023 This is probably a very dumb question but I assume the "2600 Cartridge Port" is literally just a port cannibalized from a real 2600, or am I mistaken? Which model of 2600 is the most suitable donor / easiest to remove? Or are they all the same. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 16, 2023 Author Share Posted September 16, 2023 4 hours ago, JetSetIlly said: This is probably a very dumb question but I assume the "2600 Cartridge Port" is literally just a port cannibalized from a real 2600, or am I mistaken? Which model of 2600 is the most suitable donor / easiest to remove? Or are they all the same. You can rip the off of an 2600. But you also can buy a new one: https://letmegooglethat.com/?q=24+pin+edge+connector+buy sorry couldn't resist There is also a few threads here on AA about buying them. https://www.google.com/search?q=site%3A+fourum.atariage.com+buy+24+pin+edge+connector&sca_esv=565782341&hl=de&ei=Re4EZZetJsaHxc8PwM2o2AY&ved=0ahUKEwjX4_fl562BAxXGQ_EDHcAmCmsQ4dUDCA8&uact=5&oq=site%3A+fourum.atariage.com+buy+24+pin+edge+connector&gs_lp=Egxnd3Mtd2l6LXNlcnAiM3NpdGU6IGZvdXJ1bS5hdGFyaWFnZS5jb20gYnV5IDI0IHBpbiBlZGdlIGNvbm5lY3RvcjIFECEYoAFIiI4BUMMEWMWFAXABeAGQAQCYAZABoAG9FqoBBTE0LjE0uAEDyAEA-AEB-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&sclient=gws-wiz-serp#ip=1 Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 16, 2023 Share Posted September 16, 2023 38 minutes ago, Al_Nafuur said: You can rip the off of an 2600. But you also can buy a new one: https://letmegooglethat.com/?q=24+pin+edge+connector+buy sorry couldn't resist It took me quite a while to find out the correct name for it. Maybe @JetSetIlly didn't know too. 1 Link to comment Share on other sites More sharing options...
+5-11under Posted September 16, 2023 Share Posted September 16, 2023 The picture in the first post shows Raspberry Pi 3/4. @Al_Nafuur is using a 3B (I think). Would the code require changes for a 4, or would it work the same? Any information is appreciated. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 16, 2023 Author Share Posted September 16, 2023 1 hour ago, 5-11under said: The picture in the first post shows Raspberry Pi 3/4. @Al_Nafuur is using a 3B (I think). Would the code require changes for a 4, or would it work the same? Any information is appreciated. It looks like the 4 has some changes to the GPIO handling, so indeed the code may has to be adapted to the 4. 1 Link to comment Share on other sites More sharing options...
Kroko Posted September 17, 2023 Share Posted September 17, 2023 On 9/15/2023 at 1:11 PM, Al_Nafuur said: (Install VS Code HowTo). This is a 404 ... do you have a working link ? 1 Link to comment Share on other sites More sharing options...
radventure Posted September 19, 2023 Share Posted September 19, 2023 Would a Pi 3b+ be the path-of-least-resistance for mirroring the *something*Stella*something*'s (public) progress? I'm trying to source a new one, but they're a little scarce and less cost effective currently. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 19, 2023 Author Share Posted September 19, 2023 On 9/17/2023 at 1:35 PM, Kroko said: This is a 404 ... do you have a working link ? Thanks, the fixed link is: https://code.visualstudio.com/docs/setup/raspberry-pi Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 19, 2023 Author Share Posted September 19, 2023 19 hours ago, radventure said: Would a Pi 3b+ be the path-of-least-resistance for mirroring the *something*Stella*something*'s (public) progress? I'm trying to source a new one, but they're a little scarce and less cost effective currently. Yes a 3B+ would be best at the moment. But there are a few people starting to test on Pi 4 soon.. 1 Link to comment Share on other sites More sharing options...
radventure Posted September 20, 2023 Share Posted September 20, 2023 I have a new Pi 3b+ on order, along with a couple of Sullins EBC12DCWN cart connectors.... hope they're the ones! A pair of SN74LVC245AN .... and I'm *partially* blaming @Thomas Jentzsch for me now also ordering PCBs and the items in the BOM, needed for a pair of Stelladaptors. Those enclosures are cheap enough, but the shipping isn't! Might be heat-shrink wrapped by the looks of it. I'll have to sort a breadboard and jumperwire next 1 Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 20, 2023 Share Posted September 20, 2023 3 hours ago, radventure said: .. and I'm *partially* blaming @Thomas Jentzsch Why me? Link to comment Share on other sites More sharing options...
radventure Posted September 20, 2023 Share Posted September 20, 2023 Apologies Thomas, I incorrectly recalled who mentioned it. I should be holding @Al_Nafuur partially responsible for me ordering more stuff (all good of course 🙂, exciting stuff). The Stelladaptor was mentioned some posts back and my brain tends to associate the phrase "Stella" with you automatically. 1 Link to comment Share on other sites More sharing options...
Kroko Posted September 21, 2023 Share Posted September 21, 2023 The Pi 3B+ and the 345 arrived 3 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 22, 2023 Author Share Posted September 22, 2023 11 hours ago, Kroko said: The Pi 3B+ and the 345 arrived Nice Setup!👍 I'm almost a little envious of the 34 channel logic analyzer. Something like that can be quite useful when debugging. Does it have 100Mhz resolution on all channels simultaneously? Can you send some screenshots oft the analyzer captures? Link to comment Share on other sites More sharing options...
Kroko Posted September 22, 2023 Share Posted September 22, 2023 (edited) 2 hours ago, Al_Nafuur said: Can you send some screenshots oft the analyzer captures? Yes, that was the plan. I just need to configure it to the current setup. But then we should be able to see what goes wrong timing wise, in case we suspect it has to do with bus timing. This is the specification of this thing: (I feel its good enough for all we need to see) Edited September 22, 2023 by Kroko 1 Link to comment Share on other sites More sharing options...
Kroko Posted September 22, 2023 Share Posted September 22, 2023 So I think its setup now. Here is the first measurement: Is there anything specific you want to see at this point ? 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 22, 2023 Author Share Posted September 22, 2023 44 minutes ago, Kroko said: So I think its setup now. Here is the first measurement: Is there anything specific you want to see at this point ? Yes, I am very interested in writes to the Zeropage and SC-RAM. From a real cartridge with SC-RAM would be cool, also writes to multicarts like the Harmony or the UnoCart/PlusCart would be nice to see. Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 22, 2023 Share Posted September 22, 2023 @Al_Nafuur How about the other extra RAM types? Link to comment Share on other sites More sharing options...
Kroko Posted September 26, 2023 Share Posted September 26, 2023 I am getting merge conflicts when I try to rebase. Any chance you could provide some branch or commit that just contains all I need to build rtstella ? Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 27, 2023 Author Share Posted September 27, 2023 12 hours ago, Kroko said: I am getting merge conflicts when I try to rebase. merge conflicts? Do you have any local changes made? You might start a clean download/build in a new folder. 12 hours ago, Kroko said: Any chance you could provide some branch or commit that just contains all I need to build rtstella ? I think it makes no sense to merge the two branches yet. @DirtyHairy Link to comment Share on other sites More sharing options...
Kroko Posted September 27, 2023 Share Posted September 27, 2023 7 hours ago, Al_Nafuur said: merge conflicts? Do you have any local changes made? no changes. Fresh folder and then applied your instructions. 7 hours ago, Al_Nafuur said: You might start a clean download/build in a new folder. Thats what I did. Maybe you could try your instructions in a new folder and see if it works ? I tried it 2 times with fresh folders ... 1 Link to comment Share on other sites More sharing options...
DirtyHairy Posted September 27, 2023 Share Posted September 27, 2023 8 hours ago, Al_Nafuur said: I think it makes no sense to merge the two branches yet. @DirtyHairy I think a merge would be fine. The rtstella scheduling code seems to be stable and work as it should, and you have an ifdef in your timing code that checks for rtstella, so people can try both variants. Anyway, rtstella is the way forward, the normal scheduler will never work at full speed with a real cart.. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 27, 2023 Author Share Posted September 27, 2023 6 hours ago, Kroko said: no changes. Fresh folder and then applied your instructions. Thats what I did. Maybe you could try your instructions in a new folder and see if it works ? I tried it 2 times with fresh folders ... Sorry, I cleaned up the mess and the instructions. No need to rebase the rtstella branch. 1 Link to comment Share on other sites More sharing options...
