Kroko Posted September 28, 2023 Share Posted September 28, 2023 23 hours ago, Al_Nafuur said: Sorry, I cleaned up the mess and the instructions. No need to rebase the rtstella branch. So after using 64Bit Pi OS did you get past the AboutDialog.o when compiling ? Because it hangs there for me, too ... 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 28, 2023 Author Share Posted September 28, 2023 2 minutes ago, Kroko said: So after using 64Bit Pi OS did you get past the AboutDialog.o when compiling ? Because it hangs there for me, too ... I rebooted a few times and tried different things like configure without host=rtstella and building the master branch or just using make and eventually it finished the build. There are a few fixes needed in the driver for the 64bit build. (hint: use long instead of int in line 99 and 124) I am currently testing @DirtyHairy's counter. Link to comment Share on other sites More sharing options...
+rbairos Posted June 1 Share Posted June 1 Hi Everybody. Just curious what the current state of this project is? Haven't seen any updates in a few months. Thanks Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted June 1 Author Share Posted June 1 2 hours ago, rbairos said: Hi Everybody. Just curious what the current state of this project is? Haven't seen any updates in a few months. Thanks I started to build a version with a MAX-II CPLD, but it didn't worked and after a few days of debugging I found out that one of the I/O pins of the MAX-II was stuck high. I have order (and already received) a new MAX-II test board, but haven't started to solder it to the test setup.. 4 Link to comment Share on other sites More sharing options...
Cardboard76 Posted June 1 Share Posted June 1 hey, uh, do you think it'd be possible to take a dead 2600 for the case and cartridge port and use it for the Unnamed 1970s Console? Link to comment Share on other sites More sharing options...
