santoscork Posted September 15 Share Posted September 15 (edited) Hello I tried to find this topic but haven't been able to. I received my Harmony Encore a few days ago. To make a long story short, I have one issue, I connected the Harmony to my mac and it's not detected by the system, nor via cable. The cables are my own and I have tried two. I reset the PRAM and SMC on the mac but the Harmony remains unseen by the system. I tried with and without an SDCard in the cart but it doesn't change anything. The Mac is running Mac OS High Sierra 10.13.6 Are there any known work arounds? It doesn't appear to be detected by my Atari 2600 Vader. The 2600 (PAL version) has a new power adapter. I don't have another cartridge to test the 2600 with and it too was recently acquired. Unless I am using the Harmony incorrectly. The SDCard is a 128GB, in FAT32, maybe it's too large? I downloaded software from here: Latest Harmony Cart software - Harmony Cartridge - AtariAge Forums Edited September 15 by santoscork added system configuration. Quote Link to comment Share on other sites More sharing options...
santoscork Posted September 17 Author Share Posted September 17 Anyone? If not I will contact the seller which was Harmony itself. If you know please chime back. Thanks Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted September 17 Share Posted September 17 Quote Connect an SD card to your computer. This will normally require an SD card reader or adapter. Only SD (and SDHC) cards up to 32GB are supported. Older MMC cards and micro-SD cards (with an SD adapter) may not work reliably. A 1GB SD card is sufficient to hold every Atari 2600 title ever produced harmony_manual_v2_online.pdf (atariage.com) Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 17 Share Posted September 17 On 9/15/2023 at 4:28 PM, santoscork said: the Harmony remains unseen by the system. Need to install the FTDI driver. I believe you'll need version 2.4.2. I recently bought a Mac Studio and am not having luck getting my Harmony detected in it. I tried installing the Beta 1.5.0 driver, but no luck. Not totally surprised as Ventura is macOS 13, not 11 or 12. Quote Link to comment Share on other sites More sharing options...
santoscork Posted September 25 Author Share Posted September 25 I was asked by @batari to try the following after I couldn't get it to work. Quote Sorry for the delay. Yes, Apple does make it a bit difficult! Here is a page about how to get the CH341 driver working on a Mac. https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all#mac-osx I have not personally tried it myself but others have reported success to me. The installation went without a hitch but the harmony cart remains undetected by System Profiler on the Mac. I tried two working USB cables. Question: 1) Do I need to have the SD Card inserted into the Harmony? The cart is not detected with or without an SD Card inserted. 2) According to the manual, as reinforced by @bent_pin I should be using a 32GB SD Card and not a minroSD card. The site for Harmony Encore does state the MicroSD Cards work on the encore. That said I have a 128GB microSD card connected. I will order a 32GB SD Card, not a microSD and report back but so far with what I have. My configuration: Harmony Encore Mac OS X 10.13.6 microSD card 128GB size Other: See attachments When the Harmony is not connected and I enter "ls /dev/cu" in the terminal, "/dev/cu.Bluetooth-Incoming-Port" is output When the Harmony is connected and I enter "ls /dev/cu" in the terminal "/dev/cu.Bluetooth-Incoming-Port /dev/cu.wchusbserialfd130" is output These outputs don't depend on whether an SDCard is attached to the cart or not. Any further ideas? Extensions » ls /dev/cu* /Library/Extensions /dev/cu.Bluetooth-Incoming-Port Extensions » ls /dev/cu* /Library/Extensions /dev/cu.Bluetooth-Incoming-Port /dev/cu.wchusbserialfd130 Quote Link to comment Share on other sites More sharing options...
santoscork Posted September 25 Author Share Posted September 25 I will try 2.4.2 as suggested by @SpiceWare. I will report back after a restart (for good measure) as it just installed. Quote Link to comment Share on other sites More sharing options...
santoscork Posted September 25 Author Share Posted September 25 On 9/17/2023 at 11:55 PM, SpiceWare said: Need to install the FTDI driver. I believe you'll need version 2.4.2. Issue persists after the 2.4.2 install. Any other ideas? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 25 Share Posted September 25 Sorry, no other ideas. My Studio does see both of my Harmony carts. When nothing is plugged in: darrellspice@Mac-Studio /dev % ls cu* cu.Bluetooth-Incoming-Port cu.IHP System Information (in Applications/Utilities): Original Harmony plugged in: darrellspice@Mac-Studio /dev % ls cu* cu.Bluetooth-Incoming-Port cu.usbserial-3 cu.IHP cu.usbserial-410 System Information: Harmony Encore plugged in: darrellspice@Mac-Studio /dev % ls cu* cu.Bluetooth-Incoming-Port cu.usbserial-3 cu.IHP cu.usbserial-510 System Information: the Harmony Cart software does not detect the Harmony nor the Encore: so I'm currently using my Linux/Windows laptop while I work on Frantic. I've been testing it flashed direct to the Harmony and via the menu on the Encore. When I flash the Harmony I do not have an SD card in it. I'm using an 8 GB micro SD card with an SD card adapter. Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted September 25 Share Posted September 25 On 9/15/2023 at 5:28 PM, santoscork said: The cables are my own and I have tried two. 3 hours ago, santoscork said: I tried two working USB cables. Have you verified the data functionality of these cables using other devices? I lost count of how many times I had users change out their cables on uC forums and it fixed the problem. Quote Link to comment Share on other sites More sharing options...
+batari Posted September 26 Share Posted September 26 21 hours ago, santoscork said: I will try 2.4.2 as suggested by @SpiceWare. I will report back after a restart (for good measure) as it just installed. I want to make it clear that the FTDI chip was used on cartridges until around April 2020. Since April 2020, the WCH CH340 chip has been used in all devices. Quote Link to comment Share on other sites More sharing options...
+batari Posted September 26 Share Posted September 26 21 hours ago, santoscork said: When the Harmony is not connected and I enter "ls /dev/cu" in the terminal, "/dev/cu.Bluetooth-Incoming-Port" is output When the Harmony is connected and I enter "ls /dev/cu" in the terminal "/dev/cu.Bluetooth-Incoming-Port /dev/cu.wchusbserialfd130" is output These outputs don't depend on whether an SDCard is attached to the cart or not. Any further ideas? Extensions » ls /dev/cu* /Library/Extensions /dev/cu.Bluetooth-Incoming-Port Extensions » ls /dev/cu* /Library/Extensions /dev/cu.Bluetooth-Incoming-Port /dev/cu.wchusbserialfd130 From the above, it appears that the driver installation was successful. If you are seeing a "usbserial" device appear after plugging in your Harmony, the driver is working properly. However, I find the name "wchusbserial" to be concerning, so I wonder if that is the problem. First, try: ls /dev/tty.* Do you see a device called /dev/tty.wchusbserialfd130? If so, that could be the problem. The software searches for /dev/tty.usb* but if the driver is using /dev/tty.wchusb* then the cart will not be found. If this is the case, create a symlink: sudo ln -sf /dev/tty.wchusb* /dev/tty.usbHarmony Hopefully with the symlink, the software can find the device. Quote Link to comment Share on other sites More sharing options...
