pirx Posted October 11, 2023 Share Posted October 11, 2023 @electrotrains devised a very cheap and surprisingly good cartridge emulator based on super cheap (we are speaking under $2) clones of PiPico like https://www.aliexpress.us/item/3256804090698520.html?gatewayAdapt=glo2usa4itemAdapt I have such a device and it works like a charm. I asked the author if it would be possible to modify the project to work for 5200 and it seems to be doable - there are more address lines required, but there are some signals missing in 5200 like Phi2, R/W, CCTL (?), so it should be OK. I know nothing (practically) about electronics and designing PCBs, but I know a bit about programming on 5200, so maybe someone could make a PCB, I'd modify/write the A8 firmware to run 5200 carts and we'd have a beautiful and super inexpensive cart emulator. This is a call for the hardware specialist to look at this small but mighty project. 2 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted October 11, 2023 Share Posted October 11, 2023 This will be like a cart for running rooms like the atarimax sd? Quote Link to comment Share on other sites More sharing options...
pirx Posted October 12, 2023 Author Share Posted October 12, 2023 this is the basic idea - you upload cart files to the cart (pipico) via USB (PCs see it as an external disk) and then run them from a small menu on 5200. pipico has 16MiB "disk", so a bunch of carts will fit. the cart is then loaded to pipico RAM and served to 5200 from there. RAM is not large (<256KiB), so really big cartridges will not work, but I am not sure if there are many (any?) of such huge games for 5200. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 17, 2023 Share Posted October 17, 2023 The absence of the cart bus and r/w lines means you have to 'fake' communication between the 5200 and the ARM when compared to how the existing UNO/Pico carts work (this had come up before). And this really only applies to the initial menu selection stage, e.g. entering text for a title search, conveying menu selections. At its simplest I would think using a page in the ROM area to simulate a 128 byte range and then treating access to them as a 'Send Character'. e.g. access a command byte to instigate a 'Send Text' mode and then repeat 'Send Character' until they are done, either the address&0x7F of the value after the 'Send Text' gives the length or just use an 'End Text' command byte. Quote Link to comment Share on other sites More sharing options...
pirx Posted October 19, 2023 Author Share Posted October 19, 2023 (edited) I see, I did not know about this difference. I think even something simpler would work - it would suffice to poll a single byte in the cart area, maybe the copyright date as it is read only once. or the start vector. I suppose text search is not that necessary, just some numeric selection and/or cursor moves. As far as I understand this can be done entirely in software, so no additional hardware in the cart is needed, just pipico hooked up to the 5200 cart. As a first step, the pipico software could start just a single cart (e.g.: file with a certain extension). It would be a useful cart already. Edited October 19, 2023 by pirx Quote Link to comment Share on other sites More sharing options...
coachbrj Posted October 23, 2023 Share Posted October 23, 2023 I am not a tech guy, so if this question is too dumb to answer please ignore it. But could what you are asking/doing lead to this... Quote Link to comment Share on other sites More sharing options...
pirx Posted October 23, 2023 Author Share Posted October 23, 2023 no, this is a much simpler idea, not a console replacement, but a programmable cartridge replacement using super cheap parts. like poor's man atarimax cart. 2 Quote Link to comment Share on other sites More sharing options...
