Vexed - puzzle game
solaris104
7 hours ago, tmp said:
atari 800 version xex is broken, try changing "ff bf" to "8e 87" at offset 4
I tried doing this, but I assumed this was on the first line of the file. When I changed it to 8e 87, I just received a bunch of garbage errors when attempting to run the XEX in an emulator. Since the XEX loads on my Fujinet but not on my Ultimate Cart, I thought it would be worth a try to see if this change could make the game work on my Ultimate Cart.
I can leave a comment on the itch.io page, but I am assuming that I am not doing the hex edit correctly.
Bob C
2 hours ago, tmp said:
if you're testing it in altirra, disable memory randomization if you have that on in debug options
Didn't have that selected, but got it going by booting SDX3.2 from a floppy and running that way
Doesn't seem to like SDX/U1M and I did try running with the 'X' command too.
  • 1 month later...
ZeroPage Homebrew is playing Vexed on tomorrow's ZPH stream LIVE on Twitch! Hope you can join us!
Games:
  • Cyborg Warriors (2024 Final | A8) by Krzysztof "Vega" Góra / Krzysztof Ziembik @Kaz atarionline.pl (Graphics) / MichaÅ‚ Szpilowski @miker (Music & Sound Effects)
  • Dude Story (2024 Exclusive Update | A8) by Mariusz Ejchsztet @Mq. (Code, Graphics, Music)
  • Lady Tut (2023 Final | A8) by Ati @Ati / SquareWave (Music)
  • Vexed (2023 Final | A8) by Under4MHz
  • Confused 1
Now the author has Vexed V1.14 on his webpage with a note: "fixed A800 version".
Is this the same version as the fixed one above (by tmp) or is it a different/newer version ?
(Alas, no version number on the Vexed titlescreen.)
EDIT: Looking at the data segments, there is a difference of a few bytes:
Vexed-fix: $4000-878E
Vexed 1.14: $4000-8731
both are missing the run adress (most likely $4000). So the question remains, is Vexed 1.14 newer than the Vexed-fix above and what are the (only a few bytes) differences ?
