markmiller Posted December 19, 2023 Share Posted December 19, 2023 @dmsc I'm looking at the sources in dmsc's MADS disassembly of Turbo Basic (https://github.com/dmsc/turbo-dis/tree/master). I'm trying to port the math package to Fig-Forth, using its assembler, as an exercise in learning the TB math package. I'm also interested in seeing how Forth performs with it, instead of using the Atari math pack. I've started with the random number generator, since I have a use for it. I know there's a standard algorithm for generating random numbers in Forth, but it generates integers. I'm trying to get an apples-to-apples comparison with Basic's RND() function. I basically get the scheme Ostrowski used for generating random numbers, but there's something he did that's mystifying me. His algorithm gets a random number for each nibble in the 2nd through 6th BCD slots in the float he's generating, but he seems to be deliberately defeating the BCD scheme. He throws out any number less than 10 ($A). So, each nibble is only $A-$F. When I try to print out the random number, I get garbage. Here are some samples: 0.:>?=?;1:>: 0.<==>;;>?=< What was he driving at by making these digits A-F? I guess I foolishly thought this would be relatively straightforward! I've taken a cursory look at TB's other math operations, and nothing is jumping out at me, in terms of revealing a special numbering system Ostrowski used. Also, what's the dispatch mechanism in TB? I've located the syntax table stuff, but every time I try to look up where a label like X_RND is being called (a JSR), I get nothing. So, I'm guessing there's an index table being generated during assembly that sets up the dispatch, and this is why calls like this are not showing up in the source code. Quote Link to comment Share on other sites More sharing options...
phaeron Posted December 19, 2023 Share Posted December 19, 2023 It's actually the opposite -- the code throws out invalid A-F BCD digits. It just keeps polling RANDOM until it gets valid 0-9 digit. 1 1 Quote Link to comment Share on other sites More sharing options...
markmiller Posted December 19, 2023 Author Share Posted December 19, 2023 @phaeron - Alright. My assembly skills are rusty. I thought the Carry flag would be set if the result (from CMP) was negative. It's only set if it's positive (includes 0). Thanks. Quote Link to comment Share on other sites More sharing options...
