Spudster Posted April 12 Author Share Posted April 12 Recently got my hands on a bog-standard A8Pico cart and ran some XEX file tests. This cart also fails the same way as the BBPro - Boots to the menu then goes bonkers after selecting a file. Doesn't matter which Incognito mode I select (Colleen to XL/XE). Also like BBPro, cart works great in my U1MB 1200XL and lightly modded 130XE. FujiNet has no issues launching the same files on this machine. At least one person has mentioned getting the A8Pico running on their Incognito-equipped 800, so I'm suspecting there's a deeper issue with my machine that's rendering it incompatible with these carts. Maybe some day when I'm feeling frisky I'll revert the machine back to stock and see if that makes a difference. Outside that, I'm at a loss as to what else to do. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 12 Share Posted April 12 Many of these carts do not take signal timing length into consideration for data transfer. The 800 cart port is slightly different spec due to ras cas rather than phi on cart port ultimate cart gets it correct others can do the same if coded like ult and another that get it right. else you have to modify cart slot signal with wire or upgrade needs to do this for you which some do. Some might have fixed this with a jed update or or cart boot file on SD etc Quote Link to comment Share on other sites More sharing options...
SenorRossie Posted April 12 Share Posted April 12 (edited) I have an A8PicoCart working with my incognito equipped 800. All I have to do is press reset to get to the purple menu. IIRC it works both in colleen as well as in xl mode. I have the 800 back in storage, but will be able to test some more at the end of next week. Edited April 12 by SenorRossie 1 Quote Link to comment Share on other sites More sharing options...
Spudster Posted April 12 Author Share Posted April 12 36 minutes ago, SenorRossie said: I have an A8PicoCart working with my incognito equipped 800. All I have to do is press reset to get to the purple menu. IIRC it works both in colleen as well as in xl mode. I have the 800 back in storage, but will be able to test some more at the end of next week. I have never had a problem getting to the menu (I initially did with the BBPro, but eventually fixed that). The current problem with both carts is neither will successfully launch a file. One item I have noticed but did not mention here is that apps that use mostly text will get further than those which are all graphics. Both end up with screen corruption and a locked up 800. Quote Link to comment Share on other sites More sharing options...
Spudster Posted April 12 Author Share Posted April 12 3 hours ago, _The Doctor__ said: Many of these carts do not take signal timing length into consideration for data transfer. The 800 cart port is slightly different spec due to ras cas rather than phi on cart port ultimate cart gets it correct others can do the same if coded like ult and another that get it right. else you have to modify cart slot signal with wire or upgrade needs to do this for you which some do. Some might have fixed this with a jed update or or cart boot file on SD etc Yeah, I ran across a few mentions of this, though most were in reference to not being able to get to the menu, which is not an issue I have. I’ll look into it anyway in case it may help the actual loading/running of the app, which is where all my troubles currently lie. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 12 Share Posted April 12 Can you attach a single example of a failing xex? 6 hours ago, Spudster said: ran some XEX file tests Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 12 Share Posted April 12 (edited) Make sure all .jeds, all firmware, and all plugins are up to date. those that report all works for them please list your running revision number of all those that report all do not work please list your running revision number of all plus example attachments of files that failed to launch remember not everything likes basic, pbi, high sio, SDX, or all memory extension choices. Edited April 12 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Spudster Posted April 14 Author Share Posted April 14 On 4/12/2024 at 1:56 PM, _The Doctor__ said: Make sure all .jeds, all firmware, and all plugins are up to date. those that report all works for them please list your running revision number of all those that report all do not work please list your running revision number of all plus example attachments of files that failed to launch remember not everything likes basic, pbi, high sio, SDX, or all memory extension choices. Using 4.20 Incognito firmware (no plugins) on a basic “Colleen” profile with all fancy stuff disabled set to OS A. Attached is the XEX I’m testing with: 3-D Tic-Tac-Toe (1979)(Atari)(US).xex Here is the screenshot of the app failing with the A8Pico: ….and with the BBPro: Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 14 Share Posted April 14 Does it fail if loaded from, say, an SIO2SD device rather than the A8PicoCart? The Pico would be responsible for loading the game but once control is passed to it, the Pico isn't involved. The game itself is doing some fun stuff with the scroll registers via the Display List interrupts: - NMI interrupt (DLI) 7016: 69: 99 | A=05 X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016: 79:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:104: 99 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:114: 99 | A=05 X=F4 Y=FF ( I C) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:124:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:149: 99 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:159: 99 | A=05 X=F4 Y=FF ( I C) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:169:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:194: 99 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:204: 99 | A=05 X=F4 Y=FF ( I C) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7016:214:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (VBI) 7016:248: 81 | A=05 X=F4 Y=FF ( V I ) | 41CD: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017: 69:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017: 79:101 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:104: 99 | A=05 X=F4 Y=FF ( I C) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:114:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:124:101 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:149: 99 | A=05 X=F4 Y=FF ( I C) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:159:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:169:101 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:194: 99 | A=05 X=F4 Y=FF ( I C) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:204:100 | A=0A X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL - NMI interrupt (DLI) 7017:214:101 | A=0F X=F4 Y=FF ( I ) | 41A2: 8D 04 D4 STA HSCROL And the actual Display List is a little unconventional: 4068: x3 blank 8 406B: mode 2 @ 0780 406E: mode 2 406F: blank.i 1 4070: mode C @ 4CF5 4073: mode 4 @ 2004 4076: mode C @ 4D01 4079: mode C 407A: mode.h 4 @ 2020 407D: mode C @ 4D1C 4080: mode.i C 4081: mode.h 4 @ 2040 4084: mode C @ 4D37 4087: mode.i C 4088: mode.h 4 @ 2060 408B: mode C @ 4D51 408E: mode C 408F: blank 4 4090: mode C @ 4CF5 4093: mode 4 @ 2084 4096: mode C @ 4D01 4099: mode.i C 409A: mode.h 4 @ 20A0 409D: mode C @ 4D1C 40A0: mode.i C 40A1: mode.h 4 @ 20C0 40A4: mode C @ 4D37 40A7: mode.i C 40A8: mode.h 4 @ 20E0 40AB: mode C @ 4D51 40AE: mode C 40AF: blank 4 40B0: mode C @ 4CF5 40B3: mode 4 @ 2104 40B6: mode C @ 4D01 40B9: mode.i C 40BA: mode.h 4 @ 2120 40BD: mode C @ 4D1C 40C0: mode.i C 40C1: mode.h 4 @ 2140 40C4: mode C @ 4D37 40C7: mode.i C 40C8: mode.h 4 @ 2160 40CB: mode C @ 4D51 40CE: mode C 40CF: blank 4 40D0: mode C @ 4CF5 40D3: mode 4 @ 2184 40D6: mode C @ 4D01 40D9: mode.i C 40DA: mode.h 4 @ 21A0 40DD: mode C @ 4D1C 40E0: mode.i C 40E1: mode.h 4 @ 21C0 40E4: mode C @ 4D37 40E7: mode.i C 40E8: mode.h 4 @ 21E0 40EB: mode C @ 4D51 40EE: mode C 40EF: waitvbl 4068 So I would think timing is pretty critical here and potentially there is a slight glitch when the game starts before the correct display is rendered. This can be seen in Altirra by setting a breakpoint at the launch address (3FD3) and then using 'gv' to step a frame at a time. I see this, or variants of, or sometimes no problem (due to using Altirra's "Randomize program load timing" setting): These generally pass quickly and the user barely notices them, however I was looking at the launching of the Kangeroo prototype recently on Incognito and experienced different results in different profiles, so wonder if something locks up instead. I don't know (or think he doesn't) if @phaeron has an 800 with Incognito or any idea what might be happening here? Or if anyone else with one is able to better diagnose things, e.g. with a scope. 1 Quote Link to comment Share on other sites More sharing options...
Spudster Posted April 15 Author Share Posted April 15 13 hours ago, Wrathchild said: Does it fail if loaded from, say, an SIO2SD device rather than the A8PicoCart? The Pico would be responsible for loading the game but once control is passed to it, the Pico isn't involved. No problems with either a FujiNet or via Incognito storage using the Side loader. This is only happening with an A8Pico and the BackBit Pro. 13 hours ago, Wrathchild said: I don't know (or think he doesn't) if @phaeron has an 800 with Incognito or any idea what might be happening here? Or if anyone else with one is able to better diagnose things, e.g. with a scope. I do have a scope, but my skills with using it are decades old and my circuit knowledge of Atari hardware is non-existent. I’m good at following directions though. 🙂 Quote Link to comment Share on other sites More sharing options...
