youngolddude Posted December 31, 2023 Share Posted December 31, 2023 Hi, English isnt my native language, I have an 2600 vader promotional, it doesnt work, i conect it to the tv and no signal, on chanel 2 or 3, no sounds, no life, the AC adapter is working sending 10v~11v i imagine to supply 9V i remmeber about 10 years ago it worked, but i just junked it on my closet, where can I start? im SW engineer, I have some tools to soldier here and there but not an expert, also in components change, the greatest thing i done is just changed capacitors to an ATX PC power supply Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted December 31, 2023 Share Posted December 31, 2023 There are many existing post and replies on this topic, I suggest you use the forum search to try locate theem and the answer you need is probably already on the forum somewhere. Quote Link to comment Share on other sites More sharing options...
CapitanClassic Posted December 31, 2023 Share Posted December 31, 2023 You might want to follow the flowcharts in the Atari 2600 Field Manual to help diagnose what the issue could be. 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted December 31, 2023 Share Posted December 31, 2023 11 hours ago, youngolddude said: Hi, English isnt my native language, I have an 2600 vader promotional, it doesnt work, i conect it to the tv and no signal, on chanel 2 or 3, no sounds, no life, the AC adapter is working sending 10v~11v i imagine to supply 9V i remmeber about 10 years ago it worked, but i just junked it on my closet, where can I start? im SW engineer, I have some tools to soldier here and there but not an expert, also in components change, the greatest thing i done is just changed capacitors to an ATX PC power supply This has been covered in lots of posts in these forums over the years. But I will give you one place you need to start with. You stated that the power supply is good yes? Then the next step is to verify if the voltage regulator on the system itself is working. As from the left pin to ground it should show that input voltage from your power supply although might be a bit less given the extra load from the 2600 when plugged in. And from the right side pin to ground you should see around +5v. If you aren't, then you know where you need to start. Again, the first rule in stuff like this is.. to ASAP. Always Start At Power 1 Quote Link to comment Share on other sites More sharing options...
