foft Posted December 31, 2023 Share Posted December 31, 2023 I noticed that my 1050 drive belt was coming apart last I checked it. I decided to have a go at 3D printing one and, so far, it works. Obviously it needs printing with something flexible, I used some TPU filament. https://www.thingiverse.com/thing:6409494 I measured the original belt size as: Length: 320mm Height: 3.3mm Thickness: 0.5mm The first one I printed was slipping, so I reduced the length to 300mm. That then worked. It might be worth making it slightly higher too to reduce the chance of it slipping slightly off the bottom. Also I wonder about making small ridges on the inside to improve grip? Anyway I posted for now the version that is working for me rather than further adjusting it. 9 1 Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted December 31, 2023 Share Posted December 31, 2023 anybody in the uk want to print me a couple off? Quote Link to comment Share on other sites More sharing options...
Jfcatari Posted December 31, 2023 Share Posted December 31, 2023 2 hours ago, nasty niff said: anybody in the uk want to print me a couple off? console 5 has belts in the US https://console5.com/store/fabric-reinforced-belt-for-atari-1050-tandon-tm100-4p-floppy-drive.html Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted December 31, 2023 Share Posted December 31, 2023 And the delivery costs more than the product Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted December 31, 2023 Share Posted December 31, 2023 Found a company to print them, cheap too Quote Link to comment Share on other sites More sharing options...
scotty Posted December 31, 2023 Share Posted December 31, 2023 (edited) Just about all the public libraries in the Cleveland, Ohio area (multiple separate systems) will print it for just the cost of the filament used. Cleveland Public charges 5c per gram of filament. The County library system is 10c per gram with a $1.00 minimum charge. Thank you for the design!! Edited December 31, 2023 by scotty Quote Link to comment Share on other sites More sharing options...
blacka013 Posted January 1 Share Posted January 1 Hi nasty niff, can you share the details of the company you've found olease? Regards 1 Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted January 1 Share Posted January 1 Surface scan, there is a minimum order, but it's cheaper than getting belts from the states.. @blacka013 1 Quote Link to comment Share on other sites More sharing options...
