woj Posted January 21 Share Posted January 21 Does anyone have / have written a compact, no menu / no nonsense one exe file loader for Atarimax carts? Or any existing open-source development that has one? I mean something minimal I could attach my exe file to and have it loadable from the cart.(Actual reason - my game is on the border of using up the whole 1Mbit cart and I cannot afford to have a full 8K block for the Atarimax original "firmware", which otherwise worked for me as it should, essentially I need to have full control over it to squeeze everything). Thought I'd ask before diving into writing one myself. (A flashing / writing procedure for a single sector of the 1Mbit cart would be also very useful, so far I have found one for the 8Mbit cart, otherwise I know the Arcade Pacman has one, just a bit lazy to dig it out from there ;)). Finally, is it my correct understanding that the flash sector size on the 1Mbit cart is 16kbits, so 2KB, in size? That's about the largest that would work for me, if it is 64kbit that I understand the 8Mbit one has, then the whole topic can be essentially slashed, because I'd need to go the 8Mbit route anyhow... Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 21 Share Posted January 21 The AtariMax workbook software can autolaunch an entry in the list Quote Link to comment Share on other sites More sharing options...
woj Posted January 21 Author Share Posted January 21 45 minutes ago, Wrathchild said: The AtariMax workbook software can autolaunch an entry in the list I know and I tested it, not what I am after as I tried to explain, but perhaps not well enough... Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 21 Share Posted January 21 (edited) 128KB cart (AM29F010) has 8x16K sectors and the 1024KB cart (AM29F040x2) has 8x64K sectors on each chip. Edited January 21 by Wrathchild 1 Quote Link to comment Share on other sites More sharing options...
woj Posted January 21 Author Share Posted January 21 So these are sector sizes in KBytes, huh? Now that you quoted the chip ids I could check for sure. That means no go with the 128K cart, not unless I compress things to squeeze 10K out of my code, probably not doable. Alternatively, to maybe speed up loading, I can load graphics totally uncompressed and then not feel guilty about using an oversized cart 😀 In the meantime I started scribbling a loader just in case, does not seem to be too difficult. Anyhow, I think I see the path now. 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 21 Share Posted January 21 Wouldn't dismiss the compression, I know @popmilo has had good gains with his recent work and could give some advice. 1 Quote Link to comment Share on other sites More sharing options...
woj Posted January 21 Author Share Posted January 21 I clearly underestimated the potential of proper compression (I used a quickly self-hacked RL one so far), first experiments show I can save exactly 43521 bytes on the graphics alone (and I also have a 4K Pokey tunes file to do, it is "airy", I expect another 2-3K gain here). Not only it will fit nicely on the 1Mbit cart leaving one full sector free for high score saving, it will also leave another sector for the original MaxFlash firmware (I am still tempted to write my own one though), not to mention that the disk version of the game will now fit on an SD 90K disk. This is toooo good! The only thing I do not yet know is the implication on the speed of loading, this is with ZX5, but how bad can it be 1 Quote Link to comment Share on other sites More sharing options...
popmilo Posted January 21 Share Posted January 21 I tend to first try simple zipping of data on pc when I wanna check what to expect from compression. Turns out it's almost exactly what you get in the end after using some best-for-the-job packer on 6502 Recently I've used b2 packer and am very satisfied with it. Read good stuff about zx5 so sounds like a good way to go. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 21 Share Posted January 21 Careful on the flash sector sizes, the flash chip used in the AtariMax carts has changed over time -- in 2012 some additional flash chip IDs were added to the AtariMax flashing software. One of them is possibly the SST39SF040, which has a sector size of 4K instead of 64K. It's hard to tell conclusively as the software checks for the OR of the two flash ID bytes. 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 21 Share Posted January 21 25 minutes ago, phaeron said: SST39SF040 Also the SST29SF040 should work, I believe you can get away with their 020 or 010 too. I have a handful of SST29F010 but you can seem to get them for love nor money these days... great thing about them was the sector size is 128 bytes so you can effectively remap DOS operations onto it 1 Quote Link to comment Share on other sites More sharing options...
woj Posted January 22 Author Share Posted January 22 20 hours ago, phaeron said: Careful on the flash sector sizes, the flash chip used in the AtariMax carts has changed over time -- in 2012 some additional flash chip IDs were added to the AtariMax flashing software. One of them is possibly the SST39SF040, which has a sector size of 4K instead of 64K. It's hard to tell conclusively as the software checks for the OR of the two flash ID bytes. I read the note on sector size differences in your hardware manual, quite aware of that But now I am getting totally confused - which AtariMax cartridge has what possible sector sizes? The one I am currently (and successfully, see below) aiming is the 128KB one, so this is the sector size I need to know, from previous conversations and various sources it should be 16KB, no? (and only?) Please explain, confirm @Wrathchild ? @phaeron ? One thing I did not find in the reference manual though is how the flashing is done Anyhow, the experimentation with compression totally exceeded my expectations, from ~124000 bytes I went down to ~64300 bytes, this is almost 60K of data saved, on a file that already used (poor, apparently) RL compression. I could still squeeze some bytes out by heavily reorganizing loading order, but I am happy with the end result, extremely happy. Putting aside two nasty mistakes I made at the beginning that stalled me for 2 hours, it all went smooth. One thing I noticed though, in emulation and with this game (lots of on the fly transfers to VBXE) it loads visibly slower from the cart, than when loading the XEX from SIDE3. Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 22 Share Posted January 22 1 hour ago, woj said: I read the note on sector size differences in your hardware manual, quite aware of that But now I am getting totally confused - which AtariMax cartridge has what possible sector sizes? The one I am currently (and successfully, see below) aiming is the 128KB one, so this is the sector size I need to know, from previous conversations and various sources it should be 16KB, no? (and only?) Please explain, confirm @Wrathchild ? @phaeron ? The problem is that there isn't necessarily a defined sector size for AtariMax cartridges. That's determined by the specific flash chip used, which in turn may be changed in different production runs -- and the AtariMax flashing software doesn't necessarily use the functionality you're trying to use. The best that you can do is try to accommodate the sector sizes and sector erase procedures for all of the flash chips that are known to have possibly been used, and hope that there isn't a future production run that uses a new chip with another incompatible change. At a minimum, it looks like you might have to accommodate 64K and 4K sectors. The flash chips I have mapped in Altirra for the 8Mbit cart are: Am29F040B ($01/$A4) BM29F040 ($AD/$40) HY29F040A ($AD/$A4) SST39SF040 ($BF/$B7) 1 hour ago, woj said: One thing I did not find in the reference manual though is how the flashing is done I haven't documented it in the hardware manual because it's not really new, being well documented in the flash chip datasheets. The hard part is figuring out what flash has been shipped in product and homebrew Atari projects don't document this or note production changes. Flash chips in Atari homebrew are almost universally NOR flash with an interface modeled after the 29F series, which involves unlocking the device by a series of writes with specific addresses and values before being able to issue commands to program or query the chip. More specifically, they're usually modeled after the protocol used by later revisions of the Am29F0x0 series, which changed the unlock protocol from testing A0-A14 to only testing A0-A10. The manufacturer/device ID is easy to query after that, but making sense of it can be tricky because of the dozens of mergers that have happened through the industry, which means you may have to track through two mergers and three rebrands to find out wtf the current name of the company is and where their datasheet is, or conversely what the original name was to find it in archives. Beyond that, the commands for query, program, and erase are pretty regular, though there are still some differences. Sector size is the most common difference; many of the older devices have 8 sectors regardless of size, some newer ones have 4K or even 128 byte sectors, and flash devices with top/bottom variants can even have irregular sector sizes. A couple of devices, though not seen in AtariMax carts, only allow programming in small blocks rather than single bytes and don't allow re-programming areas without an erase. Unlock can still differ, SSF39SF010/20/40 is one of the devices that still requires full A0-A14 unlock. Final note: Altirra doesn't emulate some flash features such as toggle bits, because program/erase operations are instant. 2 Quote Link to comment Share on other sites More sharing options...
woj Posted January 22 Author Share Posted January 22 11 minutes ago, phaeron said: At a minimum, it looks like you might have to accommodate 64K and 4K sectors. Also for the 1Mbit cart? Anyhow, thanks for the elaborate explanation, as always I developed boot mode flashers twice in my life for two different kinds of ST10 ECUs, so indeed I know that doing this properly is a bit more than 5 minute work, and these were not the most enjoyable programming jobs. I will need to look into these flash chips a bit more it seems... Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 22 Share Posted January 22 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 23 Share Posted January 23 6 hours ago, woj said: Also for the 1Mbit cart? Missed that you were only targeting the 1Mbit cart. Less well researched... the 2012 flasher only accepts two OR values, $20 and $21. Best guesses are: $21 -> AMD/Spansion Am29F010B ($20/$01); 16K sectors with A0-A10 unlock $20 -> ST Microelectronics M29F010 ($20/$20); 16K sectors with A0-A10 unlock 1 Quote Link to comment Share on other sites More sharing options...
woj Posted January 23 Author Share Posted January 23 I sort of got it to work, so far in the emulator and I have a slight graphics glitch when flashing the sector, for a reason known to me, but I might want to delay fixing it until I have the real cart in my hands, as I presume the timing of things is going to be different. So far I am still using the Maxflash tools loader, I do want to write my own though, first, I think a small speed improvement can be made with buffering, second, so far I did not manage to make it play nice with the RESET button. I noticed the Arcade Pac Man has a nice bare loader for this cart, but it just copies whole continuous 8K block at a time, rather than the XEX file blocks with the initad calls and all, which is what I really need. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 23 Share Posted January 23 Feel free to PM me. For reset handling on AtariMax, one of the best ways is to have the cart setting and INI/RUN vectors in every bank, that transfers control back to the main bank. I appreciate that can break continuing of data crossing banks but is managable. Quote Link to comment Share on other sites More sharing options...
woj Posted January 23 Author Share Posted January 23 5 minutes ago, Wrathchild said: one of the best ways is to have the cart setting and INI/RUN vectors in every bank, that transfers control back to the main bank Yes, I figured out that much and continuity is not a big problem. What I do not yet know is what to expect when none of the banks are active at the time of reset, which is what my game has. But I will figure it out once I get to loader writing. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 23 Share Posted January 23 Perhaps utilise CASINI (2) and set bit 1 of BOOT (9) Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 24 Share Posted January 24 If you have an indeterminate banking status which will be the case practically always, you'd need to ensure you don't inadvertantly have set up a run environment where the OS attempts to init or run the cart based on the flags value. So you'd need to ensure $BFFC is nonzero in each bank that doesn't provide a set of valid vectors and init code. Also, isn't there some situation where the default startup bank is different depending on the cart revision? Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 24 Share Posted January 24 Erase clears to $FF, so at least the clean sectors should default to not-a-cart. It was the 8Mbit carts that changed default power-up bank behavior at some point between production runs. Probably not anything actually guaranteed, but it was consistent enough that there were definitely cart images that depended on a specific power-up bank and broke on the new run of carts. What's not known is whether there was ever any reset logic involved or whether it was literally the state some random circuit tended to power up in. In any case, it only mattered on a cold power-up start, you couldn't depend on it for any warm start or 'lukewarm' soft cold start scenario. I never actually checked what banks the 1Mbit carts preferred. 1 Quote Link to comment Share on other sites More sharing options...
Sheddy Posted January 24 Share Posted January 24 Possibly of use, but only for the 8mbit carts. There will be equivalent for 1mbit presumably. From an Email with Steve Tucker: > At some point I'd like to try adding a high score saving function as > well, so it'd be good to know the proper way of flashing the cart > without relying on my interpretation of a disassembly (and potentially > wrecking my cart!) Hi Chris, Here is the code I used to save game states for Summer Games. The stuff at the end is game specific and probably no useful, but the other routines are general purpose calls for erasing a bank and writing from a block of memory into the erased area. If you need any help just yell. Thanks Steve -- ;; ;; XL/XE Equates ;; inter .equ $3FA ;; Shadow of cartridge interlock cartop .equ $BFFF ;; Last byte of cartridge trig3 .equ $D013 ;; Wired to cartridge on XL/XE random .equ $D20A ;; zerobank .equ $D500 ;; Zero bank ;; ;; Flash program registers ;; copysrc .equ $30 ;; Source pointer copydst .equ $32 ;; Destination pointer cursec .equ $34 ;; Current sector base curbank .equ $35 ;; Current absolute cart bank count .equ $36 ;; 16-bit count of data to read/write pollsame .equ $39 ;; Write polling scratch register ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Set bank to the base of a 64k 'sector' in flash cartridge ;; ;; Valid sectors are 8-15 for an 8mbit cartridge, passed in A ;; setsec sta cursec and #$0F clc rol A rol A rol A tax sta zerobank,x sta curbank rts ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Erase a 64k sector of an 8mbit flash cartridge ;; ;; Valid sectors are 8-15, passed in A ;; erasebk pha _ebc1 jsr cmd_unlock lda #$80 jsr wr5555 jsr cmd_unlock pla jsr setsec lda #$30 sta carbase jsr poll_write rts .export erasebk ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Increment the source pointer, dec the 16-bit byte counter, carry will be clear if it turns over ;; decctr inc copysrc ;; Increment the source pointer bne _dcdst inc copysrc+1 _dcdst inc copydst bne _dccmp inc copydst+1 _dccmp lda copydst+1 cmp #hi(cartop+1) bne _decby inc curbank lda #hi(carbase) sta copydst+1 _decby sec lda count sbc #$01 sta count lda count+1 sbc #$00 sta count+1 rts ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Program upto 64k into a sector of the flash cartridge. ;; ;; copysrc should be set to the start of data to program. ;; count should be set to the total number of bytes to write (0 based) ;; sector to write to should be passed in A ;; ;; you should call erasebk with the sector to erase before programming ;; prgsec jsr setsec _prgnw lda #lo(carbase) sta copydst lda #hi(carbase) sta copydst+1 _prg1 jsr cmd_unlock lda #$A0 jsr wr5555 ldx curbank sta zerobank,x ldy #$00 lda (copysrc),y sta (copydst),y jsr decctr bcs _prg1 _prgerr rts .export prgsec ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Program Initalization and Cleanup ;; init lda #$00 sta nmien sta wsync rts ;; ;; Cleanup routines ;; cleanup sta cartoff sta wsync lda trig3 sta inter lda #$40 sta nmien rts ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Poll for flash write operation to complete ;; poll_write lda #$00 sta pollsame _poll_again lda carbase cmp carbase bne poll_write cmp carbase bne poll_write cmp carbase bne poll_write inc pollsame bne _poll_again rts ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Send unlock sequence ;; cmd_unlock lda #$AA jsr wr5555 lda #$55 jmp wr2AAA ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Shortcut to write a few commonly used 17-bit addresses ;; wr5555 sta $d542 sta $b555 rts wr2AAA sta $d541 sta $aaaa rts ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Write @ sector 2ce from $6320, 2 sector ;; wr2ce jsr init ;; c4a -> cea9 -> pos 4da lda #$08 ;; flash sector 8 jsr erasebk ;; 02 sectors from 6320 to sector 2CE/2CF lda #$20 sta copysrc lda #$63 sta copysrc+1 lda #$FF sta count lda #$00 sta count+1 lda #$08 jsr prgsec jsr cleanup rts .export wr2ce ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Shared memory copy routine. Pass table offset in X ;; memcpy lda #$00 sta copysrc lda #$A0 sta copysrc+1 lda readtab,x sta copydst inx lda readtab,x sta copydst+1 inx lda readtab,x sta count inx lda readtab,x sta count+1 inx lda readtab,x tax sta zerobank,x _cpsec ldy #$00 lda (copysrc),y sta (copydst),y jsr decctr bcs _cpsec rts ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Flash reads ;; ;; dest pointer count (zero based) bank flash sector disk sector readtab .byte $20, $63, $FF, $00, $40 ;; 8 2CE/2CF ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Read entry points ;; rd2ce ldx #$00 ;; c09 -> cf02 -> pos 499 jsr init jsr memcpy jsr cleanup rts .export rd2ce .end -- -- FREE SHIPPING SALE: http://www.atarimax.com/freeshippingsale/ -- * * * Author of Imagic and APE - The Atari Peripheral Emulator! * * * * * * Turn your 8-bit Atari into a p owerhouse with APE! * * * * * * Ape Homepage: http://www.atarimax.com/ * * * * * ********************************************************* * * !! Request my *FOR SALE* LISTING OF CLASSIC VIDEO GAME STUFF -- 2000+ Items !! 1 Quote Link to comment Share on other sites More sharing options...
woj Posted January 24 Author Share Posted January 24 I got a basic custom loader for the cart working, this was not too much work, but I chased myself totally into a corner trying to see what I can do about RESET functionality. I will not write an essay here (too tired by now, perhaps the solution will come tomorrow after rest) of what I just went through, but just ask a direct question: Assuming the cart is not plugged in or disabled, there does not seem to be any way with the Atari OS to configure the dosini / dosvec / casini / boot flags / cold / warm start flags to prevent the OS to open the editor upon RESET, before it goes into any of those handlers, is there? I looked at the XL OS sources, and I do not see a way... (The editor opening is a huge pain for me, because it destroys part of the memory that my game occupies, while I want the RESET to essentially restart my program, and I do not have enough free RAM left to release the area that the editor opening destroys...). Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 24 Share Posted January 24 (edited) Even with a cartridge, the OS will often open E: There's only 2 ways to stop the text screen appearing (disregarding using PBI Rom override) 1. have the cartridge run as a Diagnostic mode Rom. 2. normal mode cartridge - do not return from the INIT vector call. This has indirect JSR before E: is opened. Both cases mean you don't have a fully initialised system (1 actually means you have to do everything yourself) The additional problem you'd have is that E: could open at $9C00 or $BC00 depending if the flash Rom is present or not. Could you rework the game such that workspace or screen data is at those locations? Edited January 24 by Rybags 2 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 25 Share Posted January 25 If you are only targeting XL/XE architecture and utilising the memory under the OS then you can handle the reset via the $FFFC vector. So you'd need to swap to a SOFT/OS or maybe providing your own minimal OS. 1 Quote Link to comment Share on other sites More sharing options...
