timmah1979 Posted January 25 Share Posted January 25 So I have an issue. Not sure if anyone else has had same issue or not. But I recently got Kung Fu Master for the Atari 2600+ (it passed on compatibility list) The issue is this. It starts right up (great) Then the problems begin Either the guy freezes up The guy disappears Or the game resets All these issues happen right at beginning OR half way through the stage Is anyone else having this issue? Would the firmware update to 1.1 fix this? (I'm still on 1.0) Thanks! Quote Link to comment Share on other sites More sharing options...
Ampersound Posted January 25 Share Posted January 25 I got Kung-Fu Master earlier this week (PAL) and I was already on firmware 1.1 at the time. It worked perfect for me and I got to the 2nd Level Boss. Hopefully the update might sort that for you. Quote Link to comment Share on other sites More sharing options...
MarcinJ Posted January 26 Share Posted January 26 I have two cartridges with Kung-Fu Master for Atari 2600 and both work on 2600+. Quote Link to comment Share on other sites More sharing options...
Glorkbot Posted January 26 Share Posted January 26 I would clean it again. I think you said in another thread that it was cleaned and tested before it got to you? but it could be clean enough to run on an original 2600 but not clean enough to run on the 2600+. 1 Quote Link to comment Share on other sites More sharing options...
+LS650 Posted January 26 Share Posted January 26 Clean, clean, clean. And then clean it again. Quote Link to comment Share on other sites More sharing options...
