damosan Posted January 29 Share Posted January 29 I've been working on getting Mini-Scheme to compile using CC65 - it is a traditional not-8bit program in that is leverages a rather complex union and many getter/setter/istrue/isfalse/etc. macros. On any 16bit processor this wouldn't be a problem. On the 6502 on the other hand... A few CC65 observations when trying to cram code into the Atari - they are, of course, variations on previous themes. The difference in this case is an leveraging existing code vs. building something from scratch. Replace getter/setter/pseudo-function macros with traditional functions where possible. Focus on the getter/setting/pseudo-function macros that are used throughout the code base first. In one case I shaved ~2k from the binary by replacing a widely used macro with a function. Average savings was ~200 bytes for each macro. Replace *s++ = *c; with *s = *c; ++s; - requires less assembly to do the work. It's not idiomatic C by any stretch but when you're trying to shave bytes from the binary... Don't forget to move critical globals to Page 0 - for performance. Doing so will shave a byte each time the variable is accessed and increase performance. Disable select features. In the case of Mini-Scheme it was was neat to see basic threading with call/cc work on an 8bit it was so slow that removal was the real answer. Quote Link to comment Share on other sites More sharing options...
sanny Posted January 29 Share Posted January 29 So, does it fit now? If not, by how much? Quote Link to comment Share on other sites More sharing options...
tebe Posted January 29 Share Posted January 29 or https://github.com/drmortalwombat/oscar64 Supported target machines c64 : Commodore C64, (0x0800..0xa000) c128 : Commodore C128, memory range (0x1c00..0xfc00) c128b : Commodore C128, first 16KB only (0x1c00..0x4000) plus4 : Commodore PLUS4, (0x1000..0xfc00) vic20: Commodore VIC20, no extra memory (0x1000..0x1e00) vic20+3 : Commodore VIC20, 3K RAM expansion (0x0400..0x1e00) vic20+8 : Commodore VIC20, 8K RAM expansion (0x1200..0x4000) vic20+16 : Commodore VIC20, 16K RAM expansion (0x1200..0x6000) vic20+24 : Commodore VIC20, 24K RAM expansion (0x1200..0x8000) pet: Commodore PET, 8K RAM (0x0400..0x2000) pet16 : Commodore PET, 16K RAM (0x0400..0x4000) pet32 : Commodore PET, 32K RAM (0x0400..0x8000) nes : Nintendo entertainment system, NROM 32 K ROM, no mirror nes_nrom_h : Nintendo entertainment system, NROM 32 K ROM, h mirror nes_nrom_v : Nintendo entertainment system, NROM 32 K ROM, v mirror nes_mmc1 : Nintendo entertainment system, MMC1, 256K PROM, 128K CROM nes_mmc3 : Nintendo entertainment system, MMC3, 512K PROM, 256K CROM atari : Atari 8bit systems, (0x2000..0xbc00) x16 : Commander X16, (0x0800..0x9f00) 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 29 Share Posted January 29 what optimisation parameters are you passing? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 29 Share Posted January 29 (edited) Try not passing parameters to functions, make as many variables global, even return values, I just tried a simple call and saved 30 bytes by not passing a variable and not returning a value. Use char instead of int where possible. Edited January 29 by TGB1718 Quote Link to comment Share on other sites More sharing options...
damosan Posted January 29 Author Share Posted January 29 5 hours ago, sanny said: So, does it fit now? If not, by how much? Yes! Quote Link to comment Share on other sites More sharing options...
damosan Posted January 29 Author Share Posted January 29 2 hours ago, Wrathchild said: what optimisation parameters are you passing? Just -O Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 29 Share Posted January 29 45 minutes ago, damosan said: Just -O do try the 'i', 's', 'r' options (and combinations off) -O, -Oi, -Or, -Os Enable an optimizer run over the produced code. Using -Oi, the code generator will inline some code where otherwise a runtime functions would have been called, even if the generated code is larger. This will not only remove the overhead for a function call, but will make the code visible for the optimizer. -Oi is an alias for -O --codesize 200. -Or will make the compiler honor the register keyword. Local variables may be placed in registers (which are actually zero page locations). See also the --register-vars command line option, and the discussion of register variables below. Using -Os will allow the compiler to inline some standard functions from the C library like strlen. This will not only remove the overhead for a function call, but will make the code visible for the optimizer. See also the --inline-stdfuncs command line option. It is possible to concatenate the modifiers for -O. For example, to enable register variables and inlining of standard functions, you may use -Ors. Quote Link to comment Share on other sites More sharing options...
damosan Posted January 30 Author Share Posted January 30 14 hours ago, Wrathchild said: do try the 'i', 's', 'r' options (and combinations off) -O, -Oi, -Or, -Os Enable an optimizer run over the produced code. Using -Oi, the code generator will inline some code where otherwise a runtime functions would have been called, even if the generated code is larger. This will not only remove the overhead for a function call, but will make the code visible for the optimizer. -Oi is an alias for -O --codesize 200. -Or will make the compiler honor the register keyword. Local variables may be placed in registers (which are actually zero page locations). See also the --register-vars command line option, and the discussion of register variables below. Using -Os will allow the compiler to inline some standard functions from the C library like strlen. This will not only remove the overhead for a function call, but will make the code visible for the optimizer. See also the --inline-stdfuncs command line option. It is possible to concatenate the modifiers for -O. For example, to enable register variables and inlining of standard functions, you may use -Ors. I believe -O optimizes for space while the other options are for speed via inlining. Quote Link to comment Share on other sites More sharing options...
damosan Posted January 30 Author Share Posted January 30 16 hours ago, TGB1718 said: Try not passing parameters to functions, make as many variables global, even return values, I just tried a simple call and saved 30 bytes by not passing a variable and not returning a value. Use char instead of int where possible. Unsigned chars to be specific - same applies to words (or unsigned ints). Sign extension is spendy from a time/space perspective. Quote Link to comment Share on other sites More sharing options...
baktra Posted January 30 Share Posted January 30 Some standard library functions can be surprisingly "bulky" too, e.g. printf(). Quote Link to comment Share on other sites More sharing options...
