John Stamos Mullet Posted February 19 Share Posted February 19 (edited) Loaded up the Debug version to see what it shows for H.E.R.O. (NTSC) and here's what it shows: so it's running just slightly slower than full speed. Played it for a good 20 minutes and barely saw the tic, maybe twice. I noticed that the speed ramped between 59.55ish and 59.96ish, Never showed 60+ FPS. Not sure if that's the game itself or something else. It's completely playable, even close to perfect as is, but sharing just for posterity. The display itself is a 2021 Samsung QLED 55" yet Curiously, another demanding game - California Games never dipped below 60.00 FPS. Edited February 19 by John Stamos Mullet 4 Quote Link to comment Share on other sites More sharing options...
Plumbob Posted February 19 Share Posted February 19 This seems very strange to me, when I first tried to play Atari Donkey Kong 2600 (red cart), the screen came up blank like this: then I tried 3 times to reload the cart and got the red message Loading Game Failed. Then on the 4th try it worked just fine: I wasn’t really expecting to get different results from repeated tries so when this happened it surprised me. 1 Quote Link to comment Share on other sites More sharing options...
Plumbob Posted February 19 Share Posted February 19 The paddles work great with Astroblast, but the joystick doesn’t work at all. Quote Link to comment Share on other sites More sharing options...
RevEng Posted February 19 Share Posted February 19 11 hours ago, Plumbob said: This seems very strange to me, when I first tried to play Atari Donkey Kong 2600 (red cart), the screen came up blank like this: then I tried 3 times to reload the cart and got the red message Loading Game Failed. Then on the 4th try it worked just fine: I wasn’t really expecting to get different results from repeated tries so when this happened it surprised me. The console is having difficulty reading the cart, and you got lucky on one dump. Cleaning the cart may or may not help 12 hours ago, John Stamos Mullet said: I noticed that the speed ramped between 59.55ish and 59.96ish, Never showed 60+ FPS. Not sure if that's the game itself or something else. [...] yet Curiously, another demanding game - California Games never dipped below 60.00 FPS. 2600 games actually vary in framerate, depending on how many scanlines they use for the display. If you run H.E.R.O in stella and hit Alt-L you'll see the game is 263 scanlines, which causes the game to run at 59.8 Hz. If you do the same with California Games, it's 262 lines and 60Hz. The occasional blip you're seeing with games that aren't 60Hz is due to HDMI not having a corresponding 59.8 Hz mode, so a frame needs to be dropped somewhere to match. (in this case, 0.3 % of frames) Leading up to the drop the FPS will be a little above the target FPS value, and after the drop it will be a little below the target FPS value. 11 Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted February 19 Share Posted February 19 1 minute ago, RevEng said: The console is having difficulty reading the cart, and you got luck on one dump. Cleaning the cart may or may not help 2600 games actually vary in framerate, depending on how many scanlines they use for the display. If you run H.E.R.O in stella and hit Alt-L you'll see the game is 263 scanlines, which causes the game to run at 59.8 Hz. If you do the same with California Games, it's 262 lines and 60Hz. The occasional blip you're seeing with games that aren't 60Hz is due to HDMI not having a corresponding 59.8 Hz mode, so a frame needs to be dropped somewhere to match. (in this case, 0.3 % of frames) Ah. Well there you go. it's not the game or the console, but an HDMI mismatch deficiency. Cool. Funny how a real 7800 through an HDMI convertor like a retrotink doesn't have the same frame drops. the Tink must be doing some internal interpolation. 3 Quote Link to comment Share on other sites More sharing options...
Plumbob Posted February 19 Share Posted February 19 14 minutes ago, RevEng said: The console is having difficulty reading the cart, and you got lucky on one dump. Cleaning the cart may or may not help 2600 games actually vary in framerate, depending on how many scanlines they use for the display. If you run H.E.R.O in stella and hit Alt-L you'll see the game is 263 scanlines, which causes the game to run at 59.8 Hz. If you do the same with California Games, it's 262 lines and 60Hz. The occasional blip you're seeing with games that aren't 60Hz is due to HDMI not having a corresponding 59.8 Hz mode, so a frame needs to be dropped somewhere to match. (in this case, 0.3 % of frames) Leading up to the drop the FPS will be a little high, and after the drop it will be a little low. Ok. That makes sense. Thanks for the explanation! What do you think might be the issue with my Hero2 cart, which consistently shows a blank screen and about 43FPS each time I try it? Quote Link to comment Share on other sites More sharing options...
MikeM_ Posted February 19 Share Posted February 19 (edited) Got it installed on my 2600+ that had the clicking in Pitfall! and tested all the games that don’t yet work for me. Aside from Time Pilot, no improvement in the other games I have that don't work. Pitfall! Still has the clicking sound, but the pattern is different. Also, it didn’t start clicking right away. IMG_3957.mov TimePilot works 👍🏼 Zaxxon Black screen, no change Smurf: Rescue noise on screen. No change James Bond 007 Black screen, no change Edited February 19 by MikeM_ 4 Quote Link to comment Share on other sites More sharing options...
RevEng Posted February 19 Share Posted February 19 21 minutes ago, Plumbob said: Ok. That makes sense. Thanks for the explanation! What do you think might be the issue with my Hero2 cart, which consistently shows a blank screen and about 43FPS each time I try it? You're welcome. I'm not 100% sure what's going wrong with Hero2, because I don't know what format the game is actually in, since there wasn't a public rom release. Quote Link to comment Share on other sites More sharing options...
KainXavier Posted February 19 Share Posted February 19 @raz0red I've got some good news and some bad news. The good news is that Maze Craze is now displaying 100% of the time for me. The bad news is that Aardvark is still freezing upon entering gameplay. Here's a new screenshot just in case it contains any useful data: Also, I'm sure I'm running your new build because "1.1x-r2" displays in the bottom right when loading games. Regarding Zippy, my guess is that it's doing something similar to Maze Craze. It enters a display mode my TV is not capable of supporting so I'm honestly not sure if it works or not. I know the cart works on my 7800 with RF, and the colors look right so I don't think it's a PAL cart. Quote Link to comment Share on other sites More sharing options...
raz0red Posted February 19 Author Share Posted February 19 5 minutes ago, KainXavier said: @raz0red I've got some good news and some bad news. The good news is that Maze Craze is now displaying 100% of the time for me. The bad news is that Aardvark is still freezing upon entering gameplay. Here's a new screenshot just in case it contains any useful data: Also, I'm sure I'm running your new build because "1.1x-r2" displays in the bottom right when loading games. Regarding Zippy, my guess is that it's doing something similar to Maze Craze. It enters a display mode my TV is not capable of supporting so I'm honestly not sure if it works or not. I know the cart works on my 7800 with RF, and the colors look right so I don't think it's a PAL cart. Ok, good news on Maze Craze. I will send you another build in a bit to test with Aardvark. Thanks, Chris. 1 Quote Link to comment Share on other sites More sharing options...
KainXavier Posted February 19 Share Posted February 19 (edited) 7 hours ago, DEANJIMMY said: Did your Juno First ever work on the 2600+? Mine worked only once when I moved the cart in the slot long time ago. The debug load shows that only the half of the rom is dumped as in your case. It worked for me on the launch firmware and the first v1.1 beta. It stopped working with Rev 2, but that's also when I updated the dumper firmware to v1.1.0.9. Does anyone know if downgrading the dumper is possible? I'm happy to try if it won't bork my machine. 16 minutes ago, raz0red said: I will send you another build in a bit to test with Aardvark. Okay, sounds good! If I've fallen asleep at that point, I'll try to check back in with you around this time tomorrow. Edited February 19 by KainXavier Quote Link to comment Share on other sites More sharing options...
KainXavier Posted February 19 Share Posted February 19 Sorry for the double-post but this is in regards to the new hotfix build sent to me... IT WORKS!! Aardvark_r1_hotfix_2.MOV 1 Quote Link to comment Share on other sites More sharing options...
raz0red Posted February 19 Author Share Posted February 19 9 minutes ago, KainXavier said: Sorry for the double-post but this is in regards to the new hotfix build sent to me... IT WORKS!! Great to hear! @RevEng added SC-RAM detection for games delivered via the dumper (which fixed Aardvark, and hopefully others). It will be part of the next experimental update. Chris. 8 Quote Link to comment Share on other sites More sharing options...
raz0red Posted February 19 Author Share Posted February 19 4 hours ago, MikeM_ said: Zaxxon Black screen, no change Smurf: Rescue noise on screen. No change James Bond 007 Black screen, no change Those are all 8k games that are dumping as 4k. Chris. 1 Quote Link to comment Share on other sites More sharing options...
lroby74 Posted February 19 Share Posted February 19 (edited) Hello everybody, i am using 2600+ on a 21" CRT via HDMI>Svideo converter, would like to test FPS on my screen so i am asking you how i can have the informations row that i can see on your posted pictures, thanks a lot in advance. EDIT: I've found now that exists a debug firmware version, i believe that i need to use that instead of standard version. Edited February 19 by lroby74 Quote Link to comment Share on other sites More sharing options...
DEANJIMMY Posted February 19 Share Posted February 19 3 hours ago, KainXavier said: It worked for me on the launch firmware and the first v1.1 beta. It stopped working with Rev 2, but that's also when I updated the dumper firmware to v1.1.0.9. Does anyone know if downgrading the dumper is possible? I'm happy to try if it won't bork my machine. Okay, sounds good! If I've fallen asleep at that point, I'll try to check back in with you around this time tomorrow. Downgrade of the dumper is possible, I did it without touching the SW to marrow down issues. 2 Quote Link to comment Share on other sites More sharing options...
+Atari_Warlord Posted February 19 Share Posted February 19 Debug info for Brik and Looping. Brik does not recognize the Joystick button being pushed to start. Quote Link to comment Share on other sites More sharing options...
shane857 Posted February 19 Share Posted February 19 This is the first time for me playing Atari 7800 games. Are these sounds normal in crossbow? 🤔 And also 7800 games look really pixelated and ugly...lol. Maybe a decent/optional scanline filter could be added in a future update? It doesn't really matter with 2600 games. MOV_0008.mp4 1 Quote Link to comment Share on other sites More sharing options...
Laladien Posted February 19 Share Posted February 19 35 minutes ago, shane857 said: This is the first time for me playing Atari 7800 games. Are these sounds normal in crossbow? 🤔 And also 7800 games look really pixelated and ugly...lol. Maybe a decent/optional scanline filter could be added in a future update? It doesn't really matter with 2600 games. MOV_0008.mp4 Ouch! No, some of those sounds are right - some sound like they're some whack extended cut... LOL But no, no it shouldn't sound like that. LOL 1 Quote Link to comment Share on other sites More sharing options...
shane857 Posted February 19 Share Posted February 19 28 minutes ago, Laladien said: Ouch! No, some of those sounds are right - some sound like they're some whack extended cut... LOL But no, no it shouldn't sound like that. LOL Yeh. The long beeping sounds to the menu maybe. 😂 Quote Link to comment Share on other sites More sharing options...
shane857 Posted February 19 Share Posted February 19 1 hour ago, shane857 said: This is the first time for me playing Atari 7800 games. Are these sounds normal in crossbow? 🤔 And also 7800 games look really pixelated and ugly...lol. Maybe a decent/optional scanline filter could be added in a future update? It doesn't really matter with 2600 games. MOV_0008.mp4 This is the PAL version. Quote Link to comment Share on other sites More sharing options...
Laladien Posted February 19 Share Posted February 19 31 minutes ago, shane857 said: Yeh. The long beeping sounds to the menu maybe. 😂 It was like they were overlapping and slow version of the sound effects! Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted February 19 Share Posted February 19 14 hours ago, lroby74 said: Hello everybody, i am using 2600+ on a 21" CRT via HDMI>Svideo converter, 2 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted February 19 Share Posted February 19 3 hours ago, shane857 said: This is the first time for me playing Atari 7800 games. Are these sounds normal in crossbow? 🤔 And also 7800 games look really pixelated and ugly...lol. Maybe a decent/optional scanline filter could be added in a future update? It doesn't really matter with 2600 games. Hur hur hur There's a known issue with dumping 7800 Crossbow with certain carts, where 16k of data isn't able to dump. This is what that Crossbow screen normally looks like... 4 1 Quote Link to comment Share on other sites More sharing options...
pseudografx Posted February 20 Share Posted February 20 4 hours ago, shane857 said: This is the first time for me playing Atari 7800 games. Are these sounds normal in crossbow? 🤔 And also 7800 games look really pixelated and ugly...lol. Maybe a decent/optional scanline filter could be added in a future update? It doesn't really matter with 2600 games. Not only are the colours wrong, but the game seems to be stretched to fullscreen on a widescreen TV. Therefore graphics looks blockier than it should. 2 1 Quote Link to comment Share on other sites More sharing options...
