John Stamos Mullet Posted February 18 Share Posted February 18 3 hours ago, Gamma Ray said: Wake me when the paddle support is fixed. This is helpful. 😏 3 Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted February 18 Share Posted February 18 (edited) I can report that H.E.R.O. performance is notably better, but still has the occasional stutter/tic when there's a lot going on on screen (multiple enemies + Miner). Not nearly as frequent as before and less noticeable. But in general is definitely better. Edited February 18 by John Stamos Mullet 2 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted February 18 Share Posted February 18 Yep, paddles in the left port work with Tac Scan. 4 Quote Link to comment Share on other sites More sharing options...
chad5200 Posted February 18 Share Posted February 18 Can someone with a ticking Pitfall test their game with this update? Wondering if the performance boost fixed that. 2 Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted February 18 Share Posted February 18 Also - California Games is flawless now. 3 Quote Link to comment Share on other sites More sharing options...
AtariYMás009 Posted February 18 Share Posted February 18 (edited) I have tested all my games (PAL 50) and as far as the image is concerned everything is more than correct, I do not notice jerks in the image even with fast games like yars revenge; However @raz0red, I have noticed a problem that was also present in revision 1 of build 1.1, and that is that games that contain music at the beginning (in my case E.t., raider of the lost ark and q*bert,) do not show that music correctly, in all cases they omit the first notes. Edited February 18 by AtariYMás009 3 Quote Link to comment Share on other sites More sharing options...
raz0red Posted February 18 Author Share Posted February 18 12 minutes ago, AtariYMás009 said: I have noticed a problem that was also present in revision 1 of build 1.1, and that is that games that contain music at the beginning (in my case E.t., raider of the lost ark and q*bert,) do not show that music correctly, in all cases they omit the first notes. Just for clarification, they omit the initial notes after launch, but then play correctly after that? Thanks a lot, Chris. Quote Link to comment Share on other sites More sharing options...
Dionoid Posted February 18 Share Posted February 18 14 minutes ago, AtariYMás009 said: ...games that contain music at the beginning (in my case E.t., raider of the lost ark and q*bert,) do not show that music correctly, in all cases they omit the first notes. I think this is caused by the Stella emulator, because I get that same behavior (i.e. sometimes first music notes are missing) when running Stella on my PC. Maybe this is even correct emulation of a 2600? Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted February 18 Share Posted February 18 16 minutes ago, raz0red said: Just for clarification, they omit the initial notes after launch, but then play correctly after that? Thanks a lot, Chris. I noticed this as well with California Games. 1 Quote Link to comment Share on other sites More sharing options...
+Atari_Warlord Posted February 18 Share Posted February 18 I took 4 games off my problem list with this update (All NTSC): 1. Fall Down now works for 2 players 2. Journey Escape music plays correctly while the screen is busy 3. The Music Machine plays music correctly now 4. Time Pilot works I put in Juno First and Medieval Mayhem and they played fine also. Quote Link to comment Share on other sites More sharing options...
AtariYMás009 Posted February 18 Share Posted February 18 49 minutes ago, raz0red said: Just for clarification, they omit the initial notes after launch, but then play correctly after that? Thanks a lot, Chris. yes, the games worked correctly after that 1 Quote Link to comment Share on other sites More sharing options...
AtariYMás009 Posted February 18 Share Posted February 18 50 minutes ago, Dionoid said: I think this is caused by the Stella emulator, because I get that same behavior (i.e. sometimes first music notes are missing) when running Stella on my PC. Maybe this is even correct emulation of a 2600? I think not, because it didn't happened when the games were displayed at 60Hz Quote Link to comment Share on other sites More sharing options...
DEANJIMMY Posted February 18 Share Posted February 18 12 minutes ago, Atari_Warlord said: I took 4 games off my problem list with this update (All NTSC): 1. Fall Down now works for 2 players 2. Journey Escape music plays correctly while the screen is busy 3. The Music Machine plays music correctly now 4. Time Pilot works I put in Juno First and Medieval Mayhem and they played fine also. I can confirm Time Pilot 2600 NTSC finaly works (white cart)🤗 Fall Down PAL works now with 2 players🤙 And... Omicron works twinstick now🕹🕹 Conquest of Mars still fails to start, maybe not dumped correctly, which size should it be? And Tac Scan NTSC works with paddle in port one (left)! 20240218_192539.mp4 1 Quote Link to comment Share on other sites More sharing options...
Dionoid Posted February 18 Share Posted February 18 16 minutes ago, AtariYMás009 said: I think not, because it didn't happened when the games were displayed at 60Hz Ah, ok. Maybe the first notes get lost while switching from 60Hz to 50Hz? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 18 Share Posted February 18 (edited) 4 hours ago, chad5200 said: For Tac-Scan, the old manual says to use paddles in the Right port. The classic 2600 only works with paddles in the the Right port. However, this firmware build that @raz0red has shared needs the paddles to be in the Left port. Stella 6.7 even mentions Left port by default: I suppose I would prefer it if this firmware matched the old manual (or better yet if both Left and Right port worked) but I guess that is debatable. It is kind of nice to just keep the paddles plugged into the Left port if you are in a "paddle game playing mood" where you are playing a bunch of paddles games. Oh, this firmware finally uses Stella's build in properties? Great! Then the ports and paddles are swapped. BTW: Is there another thread where this firmware was/is discussed? Edited February 18 by Thomas Jentzsch Quote Link to comment Share on other sites More sharing options...
DEANJIMMY Posted February 18 Share Posted February 18 3 hours ago, John Stamos Mullet said: I can report that H.E.R.O. performance is notably better, but still has the occasional stutter/tic when there's a lot going on on screen (multiple enemies + Miner). Not nearly as frequent as before and less noticeable. But in general is definitely better. The PAL version of HERO runs with not stutter (at least the first 8 levels, didn't play far) and Galaga 7800 PAL runs with no stutter, if you move the ship left/right over full distance. 2 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 18 Share Posted February 18 37 minutes ago, DEANJIMMY said: I can confirm Time Pilot 2600 NTSC finaly works (white cart)🤗 Not for me. Even with repeated cleaning the game loads up with corrupted text at the top. When I start the game I get a solid white playfield and can hear that I'm moving the plane around, and hear my shots. But NOTHING registers as getting hit and I never seem to hit anything either. So at least for me... Time Pilot is still a no go with this release. Wait! NM... this release is newer than what I was presented with the other day. This one in the posts does work for Time Pilot without issue. Now to check the game I was initially testing on the other FW. 1 Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted February 18 Share Posted February 18 58 minutes ago, Thomas Jentzsch said: Oh, this firmware finally uses Stella's build in properties? Great! Then the ports and paddles are swapped. BTW: Is there another thread where this firmware was/is discussed? No, new thread for new build. 2 Quote Link to comment Share on other sites More sharing options...
MrChickenz Posted February 18 Share Posted February 18 15 hours ago, John Stamos Mullet said: So this is where everyone went! 2 1 Quote Link to comment Share on other sites More sharing options...
Plumbob Posted February 18 Share Posted February 18 Here is some debug info for Hero2, NTSC, with 1.1x-r1 firmware installed: My Hero 2 cartridge works just fine on my 7800: Please let me know if there is anything else I can do to help get this game working. I appreciate all the hard work and thanks for this latest update, I’ll spend the rest of the day enjoying testing/playing through all my games! 1 Quote Link to comment Share on other sites More sharing options...
shane857 Posted February 18 Share Posted February 18 Absolutely no problems for me so far testing mainly PAL games. Great to have 50hz back and correct colour palette for PAL 7800 games so far...👍 4 Quote Link to comment Share on other sites More sharing options...
TheRingBearer Posted February 18 Share Posted February 18 Medieval Mayhem NTSC Centipede Trak-Ball Series NTSC Millipede Trak-Ball Series NTSC 1 Quote Link to comment Share on other sites More sharing options...
TheRingBearer Posted February 18 Share Posted February 18 Alpha Beam with Ernie NTSC 1 Quote Link to comment Share on other sites More sharing options...
DEANJIMMY Posted February 18 Share Posted February 18 14 hours ago, KainXavier said: Here's Aardvark after it freezes: With Juno First, I had a hard time even getting it to boot, but here's a photo of the debug text when it did: As for Maze Craze, it's gone back to failing to display 9 / 10 times. I'm guessing my TV just doesn't support 720p at 50hz. I doubt it'll help but here's a photo of when it did run: Lastly, I can't get Zippy the Porcupine to display at all but that was the case even with the Rev 2 beta. I hope that helps! P.S.: Dungeon II and T:ME Salvo seemed to work just fine. (I already had them on-hand.) Edit: Just to be clear, the version of Maze Craze I'm running is the one included in the NTSC release of the 10 Games In 1 cartridge. Did your Juno First ever work on the 2600+? Mine worked only once when I moved the cart in the slot long time ago. The debug load shows that only the half of the rom is dumped as in your case. Quote Link to comment Share on other sites More sharing options...
infinite.pies Posted February 19 Share Posted February 19 I can use my iPad as a screen now. Yay! There's still some flicker with sprites (a bit more than I get when using the TV), but it's usable and the sprites aren't disappearing. The slight extra flickering is probably not due to any issue with the 2600+ itself, more to do with the way the HDMI video output is being converted to a USB-C input for the iPad, so I wouldn't expect this to be addressed in any way, it's just a great little bonus to be able to plug into my iPad for a quick gaming session occasionally. I'm very happy with this! 1 Quote Link to comment Share on other sites More sharing options...
