n24005 Posted February 19 Share Posted February 19 Asteroids Deluxe Cocktail Arcade has a loud hum. After lots of problem solving, it appears to be related to the pokey chip.. disconnecting pin 37 allows the other 2 non-pokey sounds to play correctly without the hum. I tried a second pokey and still have the hum. All related components have been verified. it seems that the pokey is only outputting 1.6vdc.. from my readings on here, it seems like the pokey should be putting out 5vdc. Is that correct? why would neither pokey be putting out full voltage?? The board has solid 5vdc. What else am I missing? Quote Link to comment Share on other sites More sharing options...
Lord Mushroom Posted February 19 Share Posted February 19 If you don´t get a reply here, I would try here: https://forums.atariage.com/forum/18-arcade-and-pinball/ Or here: https://forums.arcade-museum.com You have to jump through some hoops to join, though. Quote Link to comment Share on other sites More sharing options...
n24005 Posted Monday at 10:01 AM Author Share Posted Monday at 10:01 AM Turns out that the slam switch was stuck on! For some reason it is a hum in the cocktail cabinet as opposed to the squeal in cabaret models. 1 Quote Link to comment Share on other sites More sharing options...
82-T/A Posted Monday at 03:49 PM Share Posted Monday at 03:49 PM 5 hours ago, n24005 said: Turns out that the slam switch was stuck on! For some reason it is a hum in the cocktail cabinet as opposed to the squeal in cabaret models. HAH! Oh man... that's gotten me before too on a game. The little weight is so close to the contact... 1 Quote Link to comment Share on other sites More sharing options...
