Jfcatari Posted March 25 Share Posted March 25 (edited) There is a clock difference between these: Both of these appear in 600XL's and 800XL's When I see the CO16010 used, there appears to be this strange setup? Picture taken from a 600XL NTSC. When the CO61090 is used it appears in the expected place with no extra stuff. Edited March 25 by Jfcatari typo Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted March 26 Share Posted March 26 Your numbers don't seem to be correct. In the Atari Engineering Information System Item Master List, the parts are listed as: C010177 CRYSTAL: 3.579575 MHZ C016010 CRYSTAL: 3.579545 C061090 CRYSTAL,3.579545 MHX,QUARTZ and the frequencies are the same in Field Service Manuals for the various computer and console models. So there is apparently no difference in frequencies between the two. Quote Link to comment Share on other sites More sharing options...
Jfcatari Posted March 26 Author Share Posted March 26 (edited) Thanks for the information. I am focused only the C061090 and the C016010. I have an 800XL that will only work correctly with the C061090. The composite output to a tube based TV gets a rolling color and B/W picture with the C016010 installed. Do they happen to specify the load capacitance for each? Maybe they are the same frequency, but the capacitance is different. Like I mentioned above, when I see the C016010 used is appears between the two crystal locations with the additional component above it. Edited March 26 by Jfcatari 1 Quote Link to comment Share on other sites More sharing options...
Jfcatari Posted March 28 Author Share Posted March 28 Here is an 800XL with the same strange setup using the C016010. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 28 Share Posted March 28 (edited) It's not strange, they are tuning the frequency by slight. I posted a link about load tuning a crystal, and that's what this is. The frequency of the crystals are not all the same and need to be dialed in for this use. You can verify the frequencies with a scope for each part number. Do it with and without the capacitor, or a different capacitor of a slightly different value and watch it change. Edited March 28 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted March 28 Share Posted March 28 (edited) Dogpile on the rabbit! The part number description and the crystal both say they are exactly the same. Yet The One needs to be slightly tuned? I’ll but that but the description shouldn’t be the same. Something EE wise is going on here. 🤔 Edited March 28 by kheller2 Quote Link to comment Share on other sites More sharing options...
