MikeV Posted April 8 Share Posted April 8 This is the first of 6 planned RXB/ SAMS text adventures. During the covid months I adapted 20 or so adventures from other basics for use on the TI. These literal adaptations repeatedly left a lot to be desired, as they tended to highlight the 99/4a's weaknesses. Long story short, these are the same programs but better suited to the TI with SAMS support. The immediate goal is to reduce the time spent waiting for the TI to respond, or scroll... In addition, the use of SAMS permitted some added features. However, this is still an XB environment. Disk #1; Program: The Ancient Chateau by Tim Hartnell (1984), mixed IF and D&D elements GWBasic original: 24,653 bytes, about 26k to run The TI Version requires a DSSD drive, or something better, RXB and SAMS. Startup time: reasonable Performance: good There are two small pdf manuals included. The first can be viewed as a typical pdf. The second is for anyone who may wish to print it out in booklet form: 1) landscape format 2) print one page at a time (use 'current view') 3) place the first page back in you paper feed, print down with the same orientation as it came out 4) print page 2, etc. Your printer may be different and/ or smart enough to figure it out! There will be 3 double-sided pages. Hopefully there are no bugs... Ancient Chateau.zip 11 5 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted April 9 Share Posted April 9 Awesome. Glad to see the SAMS memory and RXB start to be utilized more! 1 Quote Link to comment Share on other sites More sharing options...
MikeV Posted April 11 Author Share Posted April 11 On 4/9/2024 at 2:08 PM, jrhodes said: Awesome. Glad to see the SAMS memory and RXB start to be utilized more! The SAMS is unfortunately one of the most under utilized pieces of hardware in the 99/4a world. It has such potential! 3 Quote Link to comment Share on other sites More sharing options...
MikeV Posted May 13 Author Share Posted May 13 Here are the SAMS aware Text Adventures 2 & 3. I am releasing then together as they were written by the same author, David Meny. The first is Escape from SSADB and the second Pirate Island. They were both written in 1985 using GWBASIC. I had the early adaptation 3-4 years ago and the "SAMS Format" should have been done a couple of weeks ago. However, found some deficiencies in the original and had to remediate... Hopefully all done! Again the docs have two formats for onscreen and printing a small booklet (they are for both programs.) The ZIP File is the docs. These programs require RXB (the only XB that supports SAMS) and a SAMS card. The next offering will require a "Clock Card". I am attempting to be inclusive in that regard. If you find any deficits, please let me know. Thanks! Pirate Island.zip ESSADB.dsk PIRATE.dsk 9 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted May 14 Share Posted May 14 OMG it is about time someone used the SAMS and RXB to make games. The only previous game was IN THE DARK using up to 917K for that version of the game. Standard issue IN THE DARK was much smaller as 1Meg SAMS takes some time to load, but if other games exist that problem goes into the background. Again thanks for this! It has been over 23 years of waiting as RXB SAMS support has been around since year 2000 Rich 3 Quote Link to comment Share on other sites More sharing options...
MikeV Posted May 15 Author Share Posted May 15 16 hours ago, RXB said: OMG it is about time someone used the SAMS and RXB to make games. The only previous game was IN THE DARK using up to 917K for that version of the game. Standard issue IN THE DARK was much smaller as 1Meg SAMS takes some time to load, but if other games exist that problem goes into the background. Again thanks for this! It has been over 23 years of waiting as RXB SAMS support has been around since year 2000 Rich There will be a few more (though none at 917K !!!) It is nice to see a TI/ XB/ SAMS combo perform so well "as is". 1 1 Quote Link to comment Share on other sites More sharing options...
