Panther Posted May 10 Share Posted May 10 I came across this project today that looks like something a lot of retro computing people can use: https://github.com/rasteri/HIDman It's a converter to use USB keyboards and mice to connect to systems with PS/2 ports. It's currently under development, but the author says it's quite functional. I also found this project doing similar using a Raspberry Pi Pico, but I think I'll try out HIDman. https://github.com/No0ne/ps2pico 3 1 Quote Link to comment Share on other sites More sharing options...
foft Posted May 10 Share Posted May 10 (edited) Nice little microcontroller. It has spi too. I guess you need a TKII, AKI or Pokeymax 3/4 to provide the PS2. Perhaps it has enough Gpio to directly talk to pokey k0-5 and kr1/2 lines? Have to check the datasheet… (edit: seems to have plenty and 5v tolerant) Edited May 10 by foft 2 Quote Link to comment Share on other sites More sharing options...
Panther Posted May 11 Author Share Posted May 11 I used to program 8051 MCUs in the 90s. Siemens 80515 chips to be precise, in assembly. These WCH chips are so much fancier, and faster. 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted May 11 Share Posted May 11 I used one of it's cousins (CH554) to add a mouse as a rollerball controller to THIS. There are links to the original source code and hex file. It was an adaption of a USB to Atari quadrature mouse device. In fact since it was intended for the Atari originally, it could still serve that purpose if someone wishes to make a board or two (gerbers are on the author's Github page). 2 Quote Link to comment Share on other sites More sharing options...
