ApolloBoy Posted November 4, 2003 Share Posted November 4, 2003 After losing an auction for Planet Smashers and Midnight Mutants, you can imagine how disappointed I was, so now I want to get the easier-to-find PAL versions (those Europeans have it easy!) and convert them to NTSC format so I can play them on my NTSC 7800. What do I need to do, and where can I get the proper materials? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 4, 2003 Share Posted November 4, 2003 If you are buying the PAL version of the game then usually all you need in addition is to buy an EPROM of the correct size and type. A few PAL games are larger than the NTSC version, these can be made to work with a little work. If you do end up making some of these please mark them, at least internally, as repros. I can just see people a few years from now thinking that they're either protos or real NTSC carts. Mitch Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 4, 2003 Author Share Posted November 4, 2003 If you are buying the PAL version of the game then usually all you need in addition is to buy an EPROM of the correct size and type. A few PAL games are larger than the NTSC version, these can be made to work with a little work. If you do end up making some of these please mark them, at least internally, as repros. I can just see people a few years from now thinking that they're either protos or real NTSC carts. Mitch Alright, what EPROMs do I need for these games... Alien Brigade Planet Smashers Mean 18 Fatal Run Motor Psycho Ikari Warriors Basketbrawl Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 4, 2003 Share Posted November 4, 2003 27C100 EPROM, though the more common 27C010 will work with a bit more work. You will also need a second EPROM for Alien Brigade, a 27C128. Mitch Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 4, 2003 Author Share Posted November 4, 2003 27C100 EPROM, though the more common 27C010 will work with a bit more work. You will also need a second EPROM for Alien Brigade, a 27C128. Mitch Why? Quote Link to comment Share on other sites More sharing options...
vb_master Posted November 4, 2003 Share Posted November 4, 2003 RAM? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 4, 2003 Share Posted November 4, 2003 27C100 EPROM, though the more common 27C010 will work with a bit more work. You will also need a second EPROM for Alien Brigade, a 27C128. Mitch Why? Because Alien Brigade is 144k in size and they don't make 144k EPROMS. So, they use a 128k and a 16k. Mitch Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 4, 2003 Author Share Posted November 4, 2003 27C100 EPROM, though the more common 27C010 will work with a bit more work. You will also need a second EPROM for Alien Brigade, a 27C128. Mitch Why? Because Alien Brigade is 144k in size and they don't make 144k EPROMS. So, they use a 128k and a 16k. Mitch OK, so I how do I break up Alien Brigade into two ROMs? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 4, 2003 Share Posted November 4, 2003 OK, so I how do I break up Alien Brigade into two ROMs? You need a hex editor. Mitch Quote Link to comment Share on other sites More sharing options...
Ian Primus Posted November 4, 2003 Share Posted November 4, 2003 But, aren't we missing something here? Just copying the cart onto an EPROM cart won't magically convert it to NTSC. There is also a lot of code modification that needs to be done... Ian Primus ian_primus@yahoo.com Quote Link to comment Share on other sites More sharing options...
Spirantho Posted November 4, 2003 Share Posted November 4, 2003 Not if you can download the NTSC versions off the net.... Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 4, 2003 Author Share Posted November 4, 2003 Not if you can download the NTSC versions off the net.... Which I already have. Quote Link to comment Share on other sites More sharing options...
Ian Primus Posted November 5, 2003 Share Posted November 5, 2003 Not if you can download the NTSC versions off the net.... OK, I was thinking you were talking about converting a game from PAL to NTSC that was only released in PAL... Ian Primus ian_primus@yahoo.com Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 5, 2003 Share Posted November 5, 2003 OK, I was thinking you were talking about converting a game from PAL to NTSC that was only released in PAL... Ian Primus ian_primus@yahoo.com Eh, there aren't any. Sentinel would be the only one and a completed NTSC proto exists for that one. Mitch Quote Link to comment Share on other sites More sharing options...
Ian Primus Posted November 5, 2003 Share Posted November 5, 2003 Eh, there aren't any. Sentinel would be the only one and a completed NTSC proto exists for that one. Hmm, I didn't know that. I guess since the 7800 wasn't as widespread and didn't last as long as the 2600, and therefore there weren't nearly as many games, they managed to get ganes released in both formats. The fact that nearly all of them were made by Atari helps too. You learn something new every day... *slinks back to the 2600 forum* Ian Primus ian_primus@yahoo.com Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 5, 2003 Share Posted November 5, 2003 There are several 7800 games that are NTSC only, no PAL version available. So you were partly correct, just in reverse. Mitch Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 6, 2003 Author Share Posted November 6, 2003 OK, so I how do I break up Alien Brigade into two ROMs? You need a hex editor. Mitch Damn... Do you have the seperated ROM file I need? I don't know how to use a hex editor and I don't want to know how at the moment. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 6, 2003 Share Posted November 6, 2003 Do you have the seperated ROM file I need? I don't know how to use a hex editor and I don't want to know how at the moment. Let me know when you have the games and I'll work on it. Mitch Quote Link to comment Share on other sites More sharing options...
bloodreptile Posted November 6, 2003 Share Posted November 6, 2003 After losing an auction for Planet Smashers and Midnight Mutants, you can imagine how disappointed I was, so now I want to get the easier-to-find PAL versions (those Europeans have it easy!) and convert them to NTSC format so I can play them on my NTSC 7800. What do I need to do, and where can I get the proper materials? we do sometimes, Ihave not got a pal version if robotron bot i do have all the games you have listed on PaL. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 6, 2003 Share Posted November 6, 2003 we do sometimes, Ihave not got a pal version if robotron bot i do have all the games you have listed on PaL. Unfortunately for you and other PAL users, there is no PAL 7800 Robotron. Mitch Quote Link to comment Share on other sites More sharing options...
Tizoc Posted November 21, 2003 Share Posted November 21, 2003 Just a note, if you are not interested in the labels and are more interested in playing the games on your console, you don't have to buy their PAL counterparts. There are other more common games you can use to just get the board then solder on the EPROMs. Most of those games on your list use the same board anyway. O'sheas might still have some of the games with the board you need. BTW, if you plan on burning the EPROMs yourself you will have to deal with HEX. HEX is your friend. :-) Good luck! Quote Link to comment Share on other sites More sharing options...
