cschell Posted August 16, 2005 Author Share Posted August 16, 2005 Hi everyone, I threw this together a while back on request, but don't think anything every actually got done with it. (Probably didn't help that I was very slow getting it done.) Anyway, it's a version of the 78SCLOW banking file that has the serial port active. It was requested for debugging purposes. I figure some of the developers out there may be interested. Details on the serial port are in the tech docs in the zip file. Look for the section that starts like this: Serial Port: The FPGA in OS mode emulates an RS-232 serial port. It provides a 16 byte circular RX buffer and a 1 byte TX Buffer (in addition to the shift register of data currently being transmitted). Please note that this is essentially UNTESTED. I loaded it onto the cart and Aces of Aces ran, but I didn't try the serial port at all. So if anyone is interested, enjoy. Let me know if it works for you. Chad 78scser.zip Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 19, 2005 Share Posted August 19, 2005 The CC2ROMDB is there a way to safely edit that so that "(PAL)" at the end = "P: " at the begining so that all the PAL games are in a group, likewise the non protos, (proto) = "Proto: " , Hack/Home = "Hk: " or "Hb: " and the alternate required controlers "C:(ctrl type) " ((conversly all the NTSC games could have an "N:" instead, depending on region)) (ctrl type) 2B -two button BG -booster grip KC -kids controller KB -key board PK -pokey AV -Atarivox FC -footcraz TP -touchpad Pl -paddel DC -driving controler ML- mindlink TF- Track and Feild controller with the hierarchy being Proto/pal/7800/H/controler not normal (name of game) = "Proto: P: 78: (Hk:or Hb:) C(xy): " or a total of 20 being the longest possible string if we leave in spaces... if its a proto pal 7800 hack/homebrew that uses alternate controlers... (not likely to be a released hack/homebrew that is also a proto) of coruse you could have it omit spaces that would save room also. ...just cuz I'm lazy and run the menu generator frequently. Quote Link to comment Share on other sites More sharing options...
Mot Posted August 19, 2005 Share Posted August 19, 2005 The CC2ROMDB is there a way to safely edit that so that "(PAL)" at the end = "P: " at the begining so that all the PAL games are in a group, likewise the non protos, (proto) = "Proto: " , Hack/Home = "Hk: " or "Hb: " and the alternate required controlers "C:(ctrl type) " ((conversly all the NTSC games could have an "N:" instead, depending on region)) In the DB that I created I have company as one of the attributes this takes care of "Hacks" as this is listed as Hacks as the company. I was thinking of putting a check box in my Java Menu gen program, to filter by removing all (PAL) roms but you can always just take out the PAL (or NTSC) from the input directory. (ctrl type)2B -two button BG -booster grip KC -kids controller KB -key board PK -pokey AV -Atarivox FC -footcraz TP -touchpad Pl -paddel DC -driving controler ML- mindlink TF- Track and Feild controller with the hierarchy being Proto/pal/7800/H/controler not normal (name of game) = "Proto: P: 78: (Hk:or Hb:) C(xy): " or a total of 20 being the longest possible string if we leave in spaces... if its a proto pal 7800 hack/homebrew that uses alternate controlers... (not likely to be a released hack/homebrew that is also a proto) of coruse you could have it omit spaces that would save room also. ...just cuz I'm lazy and run the menu generator frequently. 914324[/snapback] In the CC2ROMDB.TXT that I created I put in this as one of the attributes and here are all of them: private static final String[][] CONTROLLS = { {"2", "2-Btn"}, {"K", "Keypad"}, {"P", "Paddles"}, {"D", "Drive"}, {"C", "CosmicCmd"}, {"B", "BoostrGrp"}, {"F", "FootCraz"}, {"I", "KidCtrl"}, {"V", "Joy+TPad"}, {"L", "LGun"}, {"JL", "Joy/LGun"}, {"J2L", "2BJoy/LGun"}, {"KV", "KidVid"}, {"TB", "Trackball"} }; and I wrote the Java menu gen to go with this data so it will sort the games in controler order. So I can plug my paddles in and go to the paddle part of the menu and play these at one time. Sample output menu is: ----------------Joystick---------------- 7800: Asteroids 7800: Ballblazer 7800: Centipede : ----------------Paddles----------------- Astroblast Paddles Bachelorette Party Paddles Backgammon Paddles This is the program page Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 19, 2005 Share Posted August 19, 2005 I changed some of my prefixes... that's seems to be just about what I'm looking for, so the protos and pal titles are the only things not grouped up with your current code. my fiance knows some programming... hummm... I'm thinking about asking him to see if he can get something that can do this: Game type 78 or 26/compleate or proto/Pal?/controller if 2600 I would want all of my 7800's together (allowing the exclusion of protos to that area) How did you get the breaks in your menu file? I want some of those. ...I'll play around with that one see what happens. Thanks for the lead. here's from my txt file 3D Tic-Tac-Toe 3DTIC 2K 78BIOS 7800: Ace Of Aces 2-Btn ACE78 78SC_LOW 78BIOS 7800: Alien Brigade Joy/LGun ALIEN782 78SC_BIG 78BIOS 7800: Asteroids ASTR78 HSC_16K HSC .....(all other 7800 games here) 7800: Water Ski 2-Btn WATER78 78SC_SM 78BIOS 7800: Winter Games WINTER78 78SC_R16 78BIOS 7800: Xenophobe 2-Btn XENO78 78SC_LOW 78BIOS 7800: Xevious XEV78 HSC_32K HSC 7800: PX: Gato GATO 7800_48K 78BIOS 7800: PX: GATO GATO78 7800_48K 78BIOS 7800: PX: Klax 2-Btn KLAX78 78SC_LOW 78BIOS 7800: PX: Pitfighter 2-Btn PITFIT78 78SC_SM 78BIOS 7800: PX: Rescue on Fractalus RSFRCTLS 7800_ROF 78BIOS 7800: PX: Sentinel SENT78 78SC_LOW 78BIOS .... (all other joystick 2600titles here) Word Zapper WORDZAPR 4K 78BIOS Worm War I WORMWAR1 4K 78BIOS Xenophobe XENOPHBE F6 78BIOS X-Man XMAN 4K 78BIOS Yahtzee YAHTZEE 4K 78BIOS Yars' Revenge YAREVNGE 4K 78BIOS Zaxxon ZAXXON F8 78BIOS Z-Tack ZTACK 4K 78BIOS CBg: Omega Race OMEGA FA 78BIOS CBg: Thrust (v 1.2) THRUST2 F6 78BIOS CCC: Survival Run SURVRUN 4K 78BIOS CDc: Indy 500 INDY500 2K 78BIOS CFc: Video Jogger VIDJOGGR 4K 78BIOS CFc: Video Reflex VIDRFLX 4K 78BIOS CKc: Alpha-Beam with Ernie ALPHABEM F8 78BIOS CKc: Big Bird's Egg Catch BIGBIRD F8 78BIOS CKc: Cookie Monster Munch COOKIE F8 78BIOS CKc: Oscar's Trash Race OSCAR F8 78BIOS CKp: BASIC Programming BASPROG 4K 78BIOS CKp: Brain Games BRAIN 2K 78BIOS CKp: Code Breaker CODEBRKR 2K 78BIOS CKp: Concentration CONCENT 2K 78BIOS CKp: MagiCard MAGICARD CV 78BIOS CLg: Sentinel SENTINEL F6 78BIOS CPd: Astroblast ASTRBLST 4K 78BIOS CPd: Bachelor Party BACHPRTY 4K 78BIOS CPd: Bachelorette Party BACHLTTE 4K 78BIOS CPd: Backgammon BACKGMN 4K 78BIOS CPd: Beat 'em and Eat 'em BEATEM 4K 78BIOS CPd: Blackjack BLACKJK 2K 78BIOS CPd: Breakout BREAKOUT 2K 78BIOS CPd: Bugs BUGS 4K 78BIOS CPd: Bumper Bash BUMPBASH 4K 78BIOS CPd: Canyon Bomber CANBOMB 2K 78BIOS CPd: Casino CASINO 4K 78BIOS CPd: Circus Atari CIRCUS 4K 78BIOS CPd: Demons to Diamonds DEMNSDIA 4K 78BIOS CPd: Eggomania EGGO 4K 78BIOS CPd: Encounter at L-5 ENCNTRL5 4K 78BIOS CPd: G.I. Joe: Cobra Strike GIJOE 4K 78BIOS CPd: Guardian GUARDIAN 4K 78BIOS CPd: Kaboom KABOOM 2K 78BIOS CPd: Marble Craze MARBLE F4 78BIOS CPd: Mondo Pong MONDOPNG 4K 78BIOS CPd: Music Machine MUSICMAC 4K 78BIOS CPd: Night Driver NITEDRVR 2K 78BIOS CPd: Philly Flasher PHILLY 4K 78BIOS CPd: Picnic PICNIC 4K 78BIOS CPd: Piece 'o Cake PIECECAK 4K 78BIOS CPd: SCSIcide SCSICIDE 4K 78BIOS CPd: SCSIcide2 SCSICID2 4K 78BIOS CPd: Solar Storm SOLARSTM 4K 78BIOS CPd: Star Wars: Jedi Arena SWJA 4K 78BIOS CPd: Steeple Chase (Video Gems) STPLCHSE 4K 78BIOS CPd: Steeplechase (Sears) STEEPLE 2K 78BIOS CPd: Street Racer STRTRCR 2K 78BIOS CPd: Super Breakout SBRKOUT 4K 78BIOS CPd: Tac-Scan TACSCAN 4K 78BIOS CPd: Video Olympics VIDOLY 2K 78BIOS CPd: Warlords WARLORDS 4K 78BIOS CPd: Warplock WARPLOCK 4K 78BIOS O: Atari Salt 2.6 diagnostic ATARSALT 4K 78BIOS O: Colourbar Generator COLORBAR 4K 78BIOS O: Diagnostic Test Cartridge DIAGTEST 2K 78BIOS PX: Aquaventure AQUAVEN F8 78BIOS PX: A-Team ATEAM1 F8 78BIOS PX: Bugs Bunny BUGSBUNY F8 78BIOS PX: CatTrax CATTRAX 4K 78BIOS PX: Combat II COMBAT2 F8 78BIOS PX: Computer Chess COMCHESS 4K 78BIOS PX: Donald Duck's Speedboat DONALDUK F8 78BIOS PX: Dumbo's Flying Circus DUMBO F8 78BIOS PX: Elevator Action ELEVATOR F8SC F8BANK1 PX: Frog Pond FROGPOND F8 78BIOS PX: Garfield GARFIELD F6 78BIOS PX: Kabobber KABOBER 4K 78BIOS PX: Lord of the Rings LORDRING E0 78BIOS PX: Millipede MILPROTO F6SC 78BIOS PX: Miss Piggy's Wedding MISSPIG F8 78BIOS PX: Off your Rocker OFFROCK 4K 78BIOS PX: P: Realsports Basketball RSBSKBLP F8 78BIOS PX: P: Star Wars: Ewok SWEWOKP E0 78BIOS PX: Pengo PENGO1 F8 78BIOS PX: Planet of the Apes PLANAPES 4K 78BIOS PX: Polo POLO 2K 78BIOS PX: Pompeii POMPEII 4K 78BIOS PX: Rabbit Transit RABBIT F8 78BIOS PX: Realsports Basketball RSBSKBAL F8 78BIOS PX: Saboteur SABOTUER F8 78BIOS PX: Sinistar SINISTAR F8 78BIOS PX: Sky Patrol SKYPTRL2 F8 F8BANK1 PX: Squoosh SQUOOSH 4K 78BIOS PX: Star Wars: Ewok SWEWOK E0 78BIOS PX: Surf's Up SURFSUP F8 78BIOS PX: Telepathy TELPATHY F8 78BIOS PX: Tempest TEMPEST F8 78BIOS PX: Thwocker THWOKER FE 78BIOS PX: Wizard WIZARD2 4K 78BIOS PX: Xevious XEVIOUS F8 78BIOS PX: CKc: Grover's Music Maker GROVER F8 78BIOS PX: CKc: Holy Moley HOLYMOLY F8 78BIOS PX: CKc: Monstercise MNSTRCSE F8 78BIOS PX: CKc: Peek-A-Boo PEEKBOO 4K 78BIOS PX: CLg: Shooting Arcade SHOOTARC F6SC 78BIOS PX: CPd: Dukes of Hazzard DUKES F6 78BIOS PX: CPd: Dukes of Hazzard2 DUKES2 2K 78BIOS PX: CPd: Secret Agent SECRETAG 4K 78BIOS PX: CPd: Super Stunt Cycle STNTCYCL 2K 78BIOS P: Acid Drop ACIDDROP F8 78BIOS P: Adventures on GX-12 ADONGXP 4K 78BIOS P: Aliens Return ALIENRTP 4K 78BIOS P: Angriff der Luftflotten ANGRIFFP 4K 78BIOS P: Base Attack (Z-Tack) BASEATTK 4K 78BIOS P: BI! BI! BIBIP 4K 78BIOS P: Bobby is Going Home BOBBYHMP 4K 78BIOS P: Challenge CHALENGP 4K 78BIOS P: Clown Down Town CLOWNDWN 4K 78BIOS P: Col 'N' COL_N 4K 78BIOS P: Dancing Plate DANCEPLP 4K 78BIOS P: Double Dragon DBLDRGNP F6 78BIOS P: Dragon Defender DRGDFND2 4K 78BIOS P: Duck Shot DUCKSHOT 4K 78BIOS P: Farmyard Fun FARMYARD 4K 78BIOS P: Fatal Run FATALRNP F4SC 78BIOS P: Fighter Pilot FIGHTERP F6 78BIOS P: Fire Birds FIREBDSP 4K 78BIOS P: Forest FOREST 4K 78BIOS P: General Retreat GENRLRET 4K 78BIOS P: Ghostbusters II GHOST2P F6 78BIOS P: Gunfight GUNPAL 4K 26QUICK P: Ikari Warriors IKARIP F6 78BIOS P: Inca Gold INCAGOLD 4K 78BIOS P: KLAX KLAXP F6SC 78BIOS P: Laser Base LASRBSEP 4K 78BIOS P: Marineflieger MARINEFP 4K 78BIOS P: Meteor Defense METEORDP 4K 78BIOS P: Miner 2049'er Volume 2 MINER2 3F 78BIOS P: Missile Control MSCNTRLP 4K 78BIOS P: Mission 3000 AD MIS3000 4K 78BIOS P: Mission Survive MISURVIP 4K 78BIOS P: Motocross MOTOCRSS 4K 78BIOS P: Motorodeo MOTORODE F6 78BIOS P: Mr. Postman MRPOST 4K 78BIOS P: Night Stalker NITSTLKP 4K 78BIOS P: Open Sesame OPENSMEP 4K 78BIOS P: Parachute PARACHUT 4K 78BIOS P: Pele's Soccer PELESCRP 4K 78BIOS P: Phantom Tank PHTMTNKP 4K 78BIOS P: Pick 'N' Pile PICKPILE F6 78BIOS P: Polaris POLARISP 3F 26QUICK P: Pyramid War PYRMDWAR 4K 78BIOS P: Save Our Ship SOS 4K 78BIOS P: Schnecke und Eichhoernchen SCHNECKP 4K 78BIOS P: Sea Hawk SEAHAWKP 4K 78BIOS P: Sea Monster SEAMON2 4K 78BIOS P: Ski Hunt SKIHUNT 4K 78BIOS P: Space Canyon SPCAECAN 4K 78BIOS P: Space Tunnel SPCTUNLP 4K 78BIOS P: Spider Kong SPIDKNGP 4K 78BIOS P: Surfer's Paradise SURFPARD 4K 78BIOS P: Time Warp TIMEWARP 4K 78BIOS P: Treasure Below TRESRBLP 4K 78BIOS P: Tuby Bird TUBYBRDP 4K 78BIOS P: Westward Ho WESTHO 4K 78BIOS P: Wing War WINGWAR F8 78BIOS P: Zoo Fun ZOOFUN 4K 78BIOS P: CPd: Steeple Chase STPLCHSP 4K 78BIOS Quote Link to comment Share on other sites More sharing options...
Mot Posted August 19, 2005 Share Posted August 19, 2005 I guess a script to add the stuff you want could be done using the CC2ROMDB.TXT that I wrote. The hard part of what you want is sorting the game name while ignoring the prefix. I think only a few people seem to want to sort their CC2 menu in different ways other than just game name around here. ? One thing I would like to have a 2 level menu on the cc2 so the top level would be: GAME NAME COMPANY NAME CONTROLLER TYPE Once you select one of these choices, the sub menu would appear with a list of the games in that order. That would be realy spiffy dude! Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 19, 2005 Share Posted August 19, 2005 @mot: That would be awesome! BTW I just ran the java applet just like I would the menu generator, with a copy of all of my roms in a folder with the cc2romdb that you provided. I selected all three methods of ordering the roms... ran the program and got the memu.txt, menu.cc2 and GAMES folder as expected nice little progress list, but no format change when running in the cc2...the alternate controler games were still all mixed in there was no grouping by company or anything, did I do something wrong? Quote Link to comment Share on other sites More sharing options...
Mot Posted August 19, 2005 Share Posted August 19, 2005 @mot: That would be awesome! BTW I just ran the java applet just like I would the menu generator, with a copy of all of my roms in a folder with the cc2romdb that you provided. I selected all three methods of ordering the roms... ran the program and got the memu.txt, menu.cc2 and GAMES folder as expected nice little progress list, but no format change when running in the cc2...the alternate controler games were still all mixed in there was no grouping by company or anything, did I do something wrong? 914690[/snapback] If you selected all three check boxes, then you will have to go past all the usual entries sorted by game name to the part that has them sorted by company name then then to the part where it is sorted by controller type. or go backwards to see the controller type section. Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 19, 2005 Share Posted August 19, 2005 (edited) It didn't have it... I copied and pasted to word the menu file txt generated and there is only entries for names. no companies no controllers. just renamed my other cc2 file and games GAMESold and Menu.old and put the new generated file in but it only had the names, when I ran it without names checked I got nothing but the GAMES folder, nothing in the txt file... (nothing in the cc2 file either!) Edited August 19, 2005 by FireTiger Quote Link to comment Share on other sites More sharing options...
Mot Posted August 19, 2005 Share Posted August 19, 2005 It didn't have it... I copied and pasted to word the menu file txt generated and there is only entries for names. no companies no controllers. just renamed my other cc2 file and games GAESold and Menu.old and put the new generated file in but it only had the names, when I ran it without names checked I got nothing but the GAMES folder, nothing in the txt file... (nothing in the cc2 file either!) 914715[/snapback] OK, I'll look into it and get back to you. Quote Link to comment Share on other sites More sharing options...
Mot Posted August 19, 2005 Share Posted August 19, 2005 OK there is something wrong with the new CCROMDB.TXT and this program when it comes to company order. The program will gen with controller order and/or game name order. The program is getting an error in the Company order part and will not go on to the controller order section after this error. I will need to fix and replace the program, maybe this weekend. Soory Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 19, 2005 Share Posted August 19, 2005 (edited) ok so I can do it for controler type just not company name... its ok don't mind helping debug. 883 roms found, seems to work. Program missed one of the two versions of SCSIcide: ((see edit)) "SCSIcide Paddles" is still under joystick, but SCSIcide (paddles) appers also in the normal Paddles area??? If you already set up to allow filtering for or aginst pal, could you implament that? ---edit--- If you don't its ok as I just copied and pasted the grouping menu That I did to the end of this java generated one and then when back and manualy reomved the protos and pal titles. THe accaepted ROM afwer cc2 has it is SCICIDE = paddles but the program didn't pick it up, it picked up SCICID2 for paddles. attached is my current played around with java and hand edited menu txt file. MENUjava.TXT Edited August 19, 2005 by FireTiger Quote Link to comment Share on other sites More sharing options...
cschell Posted August 21, 2005 Author Share Posted August 21, 2005 (edited) Hi everyone, I've put together CC2 OS Ver 2.00 today. (You can think of it as a treat for all of those who didn't make it to one of the gaming conventions this weekend. ) It rolls in the improved speed performance of the earlier beta that I think 2 people actually used. But the big change is that it now allow multiple menus. Here's the blurb I wrote to describe it. Update notes for Version 2.00 of Cuttle Cart 2 OS. Minor Update: Slight speed improvement for MMC access over version 1.01. Major Update: Multiple Menus! The CC2 Menu system now supports multiple menu files, as opposed to the single flat menu of the previous system. Now all menus can contain other menus. Details: All menus follow the same format as the original MENU.TXT/MENU.CC2 files. They must be placed in the root directory of the MMC. They must have the file extension ".CC2". Otherwise they can be named whatever you want, but MENU.CC2 is reserved as the default menu. (BOOTROM.CC2 and EMGBOOT.CC2 also have special meanings and should not be used for menus.) After creating a new "submenu", to load it create an entry in your current menu whose BANKING file is "MENU " (four spaces at the end.) This tells the CC2 that this entry isn't a game, but another menu. When you select the "submenu" and press the button or reset, the "submenu" will be loaded and replace the current menu. Why is "submenu" in quotes you ask? Because they aren't really submenus, but rather alternate menus. There is no structure to how the menus connect to one another. All menus must contain menu entries for any menu you want to go to. Confused? Here's any example: You start the CC2 and it loads the default "MENU.CC2" file. MENU.CC2 contains the entry (shown here in MENU.TXT format) New Menu NEWMENU MENU IGNORE Parsing that out, the entries are: Display Name: "New Menu" File Name: "NEWMENU" Banking: "MENU" Startup: Any non-blank value <= 8 characters in length Just like a game entry. When "New Menu" is selected, the CC2 sees that the banking entry is "MENU ", and attempts to load the file "NEWMENU.CC2" from the root directory of the MMC. If it finds it, the new menu becomes the active menu, and the old menu is forgotten. If it doesn't find it, the old menu remains in place and an error message is printed on the screen. Now if you want to be able to go back to MENU.CC2 from NEWMENU.CC2, you have to have the following entry somewhere in NEWMENU.CC2 Root Menu MENU MENU IGNORE Selecting this line would tell the CC2 to reload MENU.CC2 in place of NEWMENU.CC2. (By the way, you don't have to make the display entry Root Menu, you can call it whatever you want as long as it's legal for a standard menu entry.) If you forget to add a line like the one above, you will not be able to get back to the original MENU.CC2 file. (At least not through the menu system.) Menus can link to as many other menus as you want. (Subject to the limit of 512 (? or 256, I forget) files allowed in a root directory on a FAT file system.) Menus can even link to themselves. (When a new menu is loaded, it always starts at the top of the menu. A menu entry linking a menu to itself could be used as a shortcut to automatically jump back to the top of menu. Cool eh?) Some more Details: If you have "Remember Last Menu Position" set to yes in the utilities screen, the CC2 will attempt to load the last opened menu, and move to the last game in that menu that was loaded or manual that was read. If nothing was loaded from the last menu, it will go to the start of that menu. If it can't find the last menu loaded, it will fall back to loading the default MENU.CC2 file. This is one way to get back to it if you forget to make an entry. (The other way is to edit the active menu to include the link, you can add entries to any menu just like adding them to MENU.CC2.) If you have "Remember Last Menu Position" set to no, the CC2 will always start at the top of MENU.CC2 regardless of what other menu was last active. The new multiple menus option has no effect on anything else. All games are still stored in the GAMES directory, and all manuals in the MANUALS directory. You can have as many entries point to a game as you want. You still need only one copy of that game and manual. I've had requests for something along these lines for a while now, so I hope people enjoy it. It was quite the overhaul to make this work. But my testing shows everything to be ok. Of course bugs might crop up when more people start to use it. (At worst case the emergency boot is alway there to let you flash back to an older version.) I do not intend to provide new PC menu tools to make taking advantage of this easy. That's just not my strong suit. Fortunately it looks like Mot's program is pretty close, and there's always editing of .txt files and passing them through the menu converter. It requires updates to the HSC, SC, and 3E3F512K startup files. Those are included in the zip. The new versions work only with OS Ver 2.00. If you don't know how to upgrade the OS on the CC2, please read the manual. I've done my best to explain it there. (It's really easy.) Edit: See lower post for version 2.01 which fixes the clear screen bug. Enjoy, Chad Edited August 21, 2005 by cschell Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 21, 2005 Share Posted August 21, 2005 ok, now I need something that will maintain the file name.... MENUPD.txt -> MENUPD.CC2 instead of MENUPD.txt->MENU.CC2 I guess it would be called Menunewcc2.exe ??? input filename *.txt -> *.CC@ in 8 character capital letter format, error iforiginal file nem too long. I have now 12 folders with 12 copies of the cc2menu.exe (just cuz I'm being lazy) and have to keep each newly created CC2 menu in its own folder till I rename them. ...still not sure it works yet, had to update the boot twice, the first time I got a "corrupted NVRAM" error... Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 21, 2005 Share Posted August 21, 2005 (edited) (dblpost bad me!) um... it kept the stuff I brought up when I returned the MEUN.cc2... example: Menu All MEUNJAVA MENU IGNORE Menu 2600 MENU2600 MENU IGNORE Menu 7800 MENU7800 MENU IGNORE Menu Ctrl NEWCTRL MENU IGNORE Menu Favorites MENUFAV MENU IGNORE Menu Pal MENUPAL MENU IGNORE Menu Proto MENUPROT MENU IGNORE Root Menu MENU MENU IGNORE then I choose 7800... it displayed the cc2 format of this: Root Menu MENU MENU IGNORE 7800: Ace Of Aces 2-Btn ACE78 78SC_LOW 78BIOS 7800: Alien Brigade Joy/LGun ALIEN782 78SC_BIG 78BIOS 7800: Asteroids ASTR78 HSC_16K HSC 7800: Ballblazer (uses Pokey) BALLBLZR 78POKEY 78BIOS 7800: Barnyard Blaster LGun BARNYD 78SC_LOW 78BIOS 7800: Basketbrawl 2-Btn BSKTBRWL 78SC_LOW 78BIOS 7800: Centipede CENT78 HSC_16K HSC 7800: Choplifter! 2-Btn CHOPLFTR 7800_32K 78BIOS 7800: Color (Demo) COLOR78 7800_8K 78BIOS 7800: Commando (uses Pokey) 2-Btn COMM78 78SC_POK 78BIOS 7800: Cracked 2-Btn CRACK78 78SC_LOW 78BIOS 7800: Crossbow Joy/LGun CRSBW782 78SC_BIG 78BIOS 7800: Dark Chambers DRKCH78 78SC_LOW 78BIOS 7800: Desert Falcon DESRT78 7800_48K 78BIOS 7800: Dig Dug DIGDUG78 HSC_16K HSC 7800: Donkey Kong Junior DKJR78 7800_48K 78BIOS 7800: Donkey Kong DK78 7800_48K 78BIOS 7800: Double Dragon 2-Btn DOUBLE78 ACT78 78BIOS 7800: F-18 Hornet 2-Btn F18_78 ABS78 78BIOS 7800: Fatal Run 2-Btn FATAL78 78SC_LOW 78BIOS 7800: Fight Night FIGHT78 78SC_LOW 78BIOS 7800: Food Fight FOOD78 HSC_32K HSC 7800: Galaga GALAGA78 HSC_32K HSC 7800: Hat Trick 2-Btn HAT78 7800_48K 78BIOS 7800: Ikari Warriors 2-Btn IKARI78 78SC_LOW 78BIOS 7800: Impossible Mission John Harvey fix POSSMS78 78SC_R8K 78BIOS 7800: Impossible Mission IMPOSS78 78SC_R8K 78BIOS 7800: Jinks 2-Btn JINKS78 78SC_R8K 78BIOS 7800: Joust JOUST78 HSC_32K HSC 7800: Karateka 2-Btn KARTKA78 7800_48K 78BIOS 7800: Kung-Fu Master KUNGFU78 7800_32K 78BIOS 7800: Mario Brothers MARIO78 7800_48K 78BIOS 7800: Mat Mania 2-Btn MATMAN78 78SC_LOW 78BIOS 7800: Mean 18 Ultimate Golf 2-Btn MEAN18 78SC_LOW 78BIOS 7800: Meltdown LGun MELTDN78 78SC_LOW 78BIOS 7800: Midnight Mutants 2-Btn MIDMUT78 78SC_LOW 78BIOS 7800: Motor Psycho 2-Btn MOTOR78 78SC_LOW 78BIOS 7800: Ms. Pac-Man MSPAC78 HSC_16K HSC 7800: Ninja Golf 2-Btn NINJA78 78SC_LOW 78BIOS 7800: One-on-One 2-Btn ONE78 7800_48K 78BIOS 7800: Pete Rose Baseball PETE78 7800_32K 78BIOS 7800: Planet Smashers 2-Btn PLANET78 78SC_LOW 78BIOS 7800: Pole Position II POLE278 7800_32K 78BIOS 7800: Rampage 2-Btn RAM78 ACT78 78BIOS 7800: RealSports Baseball 2-Btn RSB78 78SC_SM 78BIOS 7800: Robotron: 2084 ROBO78 HSC_32K HSC 7800: Scrapyard Dog 2-Btn SCRAP78 78SC_LOW 78BIOS 7800: Summer Games SUMMR78 78SC_R16 78BIOS 7800: Super Huey 2-Btn HUEY78 7800_48K 78BIOS 7800: Super Skateboardin' SKATE78 7800_32K 78BIOS 7800: Tank Command 2-Btn TANK78 78SC_SM 78BIOS 7800: Test Cart TEST78 7800_32K 78BIOS 7800: TitleMatch Pro Wrestling WRESTL78 7800_32K 78BIOS 7800: Tomcat: F14 2-Btn F14_78 7800_32K 78BIOS 7800: Touchdown Football TDFOOT78 78SC_LOW 78BIOS 7800: Tower Toppler TOWER78 78SCR8SM 78BIOS 7800: Water Ski 2-Btn WATER78 78SC_SM 78BIOS 7800: Winter Games WINTER78 78SC_R16 78BIOS 7800: Xenophobe 2-Btn XENO78 78SC_LOW 78BIOS 7800: Xevious XEV78 HSC_32K HSC 7800: PX: Gato GATO 7800_48K 78BIOS 7800: PX: GATO GATO78 7800_48K 78BIOS 7800: PX: Klax 2-Btn KLAX78 78SC_LOW 78BIOS 7800: PX: Pitfighter 2-Btn PITFIT78 78SC_SM 78BIOS 7800: PX: Rescue on Fractalus RSFRCTLS 7800_ROF 78BIOS 7800: PX: Sentinel SENT78 78SC_LOW 78BIOS which is exactly what I expected, howver when I choose Root Menu I expected: Menu All MEUNJAVA MENU IGNORE Menu 2600 MENU2600 MENU IGNORE Menu 7800 MENU7800 MENU IGNORE Menu Ctrl NEWCTRL MENU IGNORE Menu Favorites MENUFAV MENU IGNORE Menu Pal MENUPAL MENU IGNORE Menu Proto MENUPROT MENU IGNORE Root Menu MENU MENU IGNORE I had displayed the cc2 format of this: Menu All MEUNJAVA MENU IGNORE Menu 2600 MENU2600 MENU IGNORE Menu 7800 MENU7800 MENU IGNORE Menu Ctrl NEWCTRL MENU IGNORE Menu Favorites MENUFAV MENU IGNORE Menu Pal MENUPAL MENU IGNORE Menu Proto MENUPROT MENU IGNORE Root Menu MENU MENU IGNORE 7800: Ace Of Aces 2-Btn ACE78 78SC_LOW 78BIOS 7800: Alien Brigade Joy/LGun ALIEN782 78SC_BIG 78BIOS 7800: Asteroids ASTR78 HSC_16K HSC 7800: Ballblazer (uses Pokey) BALLBLZR 78POKEY 78BIOS 7800: Barnyard Blaster LGun BARNYD 78SC_LOW 78BIOS 7800: Basketbrawl 2-Btn BSKTBRWL 78SC_LOW 78BIOS 7800: Centipede CENT78 HSC_16K HSC 7800: Choplifter! 2-Btn CHOPLFTR 7800_32K 78BIOS 7800: Color (Demo) COLOR78 7800_8K 78BIOS 7800: Commando (uses Pokey) 2-Btn COMM78 78SC_POK 78BIOS 7800: Cracked 2-Btn CRACK78 78SC_LOW 78BIOS 7800: Crossbow Joy/LGun CRSBW782 78SC_BIG 78BIOS you however could NOT select the 7800 menu items still displyed, its just that they were not, "cleaned" out? However the error code worked perfectly AND cleaned out the leftover stuff. (had a error menu on purpose) "NEWCTRL" -> MENUCTRL "MEUNJAVA" ->MEUNJAVA Other then that it works just fine, although as said in my previous post kinda annoying to keep track of which cc2 menu is which one to be named what. Can't wait till someone codes that lovely thing. I didn't choose to have the menus multilink, they can all go back to the root menu. Its beautiful! Simply beautiful...thanks sooo much now for anyone that wants to make an easy PC submenucc2 Print: Input the directery of the file to be converted <input> *.txt file Print: Enter name in capital letters, 8 standard character or less *.(newname) <check lenghth, force caiptal letters, check to make sure not names bootrom/embootrom ect> Print: Please select directery to output CC2 file <fetch name of file>, no input will put the file in this folder. <browse> [button create file] <out put error / succesful> Edited August 21, 2005 by FireTiger Quote Link to comment Share on other sites More sharing options...
cschell Posted August 21, 2005 Author Share Posted August 21, 2005 Hi, thanks for reminding me about the NVRAM issues. Here's an important note I forgot: When upgrading to OS Ver 2.00, the NVRAM format has changed. Therefore the first time you start after upgrading it will post the NVRAM warning and reset everything to the default values. Don't worry about it, just ignore it. However, if you have custom colors you may want to write them down before you upgrade as the colors will get reset to the defaults. Very sorry I forgot to put that in the notes. As for the garbage, I didn't try a menu smalller than one screen. I'm guessing it's as simple as needing to clear the menu before I redraw it. Looks like it's time for 2.01. Chad Quote Link to comment Share on other sites More sharing options...
cschell Posted August 21, 2005 Author Share Posted August 21, 2005 (edited) Ok, Here's version 2.01. It clears the menu when loading a new one, so smaller ones will no longer leave garbage lying around. Also changed it so that the menu bar will wrap from top to bottom / bottom to top when scrolling through a menu smaller than one screen. Chad CC2OSV201.zip Edited August 21, 2005 by cschell Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 21, 2005 Share Posted August 21, 2005 Perfect!! Quote Link to comment Share on other sites More sharing options...
cschell Posted August 22, 2005 Author Share Posted August 22, 2005 I have updated the W32 Menu Converter to simply take XXXXXXXX.TXT and create XXXXXXXX.CC2 in the same directory as the original file. It's up to the user to ensure that the original name is less than 8 characters. New utility is available on the CC2 updates page at schells.com Chad Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 22, 2005 Share Posted August 22, 2005 dblperfect, just right into the directory too. now I just need to find all of the working roms. BTW how do SC roms need to be named to work? Quote Link to comment Share on other sites More sharing options...
Mot Posted August 22, 2005 Share Posted August 22, 2005 Ok, Here's version 2.01. It clears the menu when loading a new one, so smaller ones will no longer leave garbage lying around. Also changed it so that the menu bar will wrap from top to bottom / bottom to top when scrolling through a menu smaller than one screen. Chad 915837[/snapback] Chad, One minor thing: When you come back to the menu after powering off and back on, it is no longer in the menu but at the top menu, with –select- highlighted. Did you want that to happen, because with the old menus, it didn’t do that? Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 22, 2005 Share Posted August 22, 2005 Really? I have in utlities "save last menu position" = no, "Start in Select mode" = no So mine always boots to "Menu" allowing anthing at the top to be selected. Quote Link to comment Share on other sites More sharing options...
Laner Posted August 22, 2005 Share Posted August 22, 2005 Very cool... can't wait to try this tonight Quote Link to comment Share on other sites More sharing options...
Mot Posted August 23, 2005 Share Posted August 23, 2005 Really? I have in utlities "save last menu position" = no, "Start in Select mode" = no So mine always boots to "Menu" allowing anthing at the top to be selected. 916304[/snapback] Sorry, didn't see that option. This must have changed while up-grading? OK, I put in sub-menu into that program of mine: Java CC2Menu Gen version 02 It does put in a sub menu for each company and each controller, so this will go 3 levels deep and make a lot of files to put on your MMC card. This still is/maybe buggy, so be warned. I can try to fix everything. (maybe I should start a new thread for bugs and enhancements.) Here is what it looks like now: Have fun Quote Link to comment Share on other sites More sharing options...
cschell Posted August 23, 2005 Author Share Posted August 23, 2005 "Start in Select mode" = no Sorry, didn't see that option. This must have changed while up-grading? It got reset to the default of "No" when the NVRAM was reset after upgrading to OS ver 2. Chad Quote Link to comment Share on other sites More sharing options...
Mot Posted September 15, 2005 Share Posted September 15, 2005 OK, I put in sub-menu into that program of mine:Java CC2Menu Gen version 02 It does put in a sub menu for each company and each controller, so this will go 3 levels deep and make a lot of files to put on your MMC card. This still is/maybe buggy, so be warned. I can try to fix everything. (maybe I should start a new thread for bugs and enhancements.) Here is what it looks like now: Have fun Now it will sub menu at different levels. So if a company has more then 20 items: it will put in a entry like this in the COMPANY.CC2: ----20th Century Fox (Menu 22 itms)----- and will create a sub-menu like this: Alien Alligator People (Proto) Bank Heist Beany Bopper Crash Dive Crypts of Chaos Deadly Duck Earth Dies Screaming Entity (Proto) Fantastic Voyage Fast Eddie Flash Gordon M*A*S*H Mega Force Pick Up (Proto) Planet of the Apes (Proto) Porky's Revenge of the BS Tomatoes Save The Whales Spacemaster X-7 Turmoil Worm War I Return to COMPANY <<<<<<<<<<<<<<<<<<<<<< Here is my controller menu: ----------2-Btn (Menu 29 itms)---------- ---------------BoostrGrp---------------- Omega Race BoostrGrp ---------------CosmicCmd---------------- Survival Run CosmicCmd -----------------Drive------------------ Indy 500 Drive Stell-a-Sketch Drive ----------------FootCraz---------------- Video Jogger FootCraz Video Reflex FootCraz ----------------Joy+TPad---------------- Star Raiders Joy+TPad --------Joystick (Menu 641 itms)-------- -----------------Keypad----------------- BASIC Programming Keypad Brain Games Keypad Code Breaker Keypad Concentration Keypad MagiCard Keypad SynthCart (Paul Slocum) Keypad ----------------KidCtrl----------------- Alpha-Beam with Ernie KidCtrl Big Bird's Egg Catch KidCtrl Cookie Monster Munch KidCtrl Grover's Music Maker (Proto) KidCtrl Holy Moley (Proto) KidCtrl Monstercise (Proto) KidCtrl Oscar's Trash Race KidCtrl Peek-A-Boo (Proto) KidCtrl -----------------KidVid----------------- Berenstein Bears Smurfs Save the Day ------------------LGun------------------ 7800: Barnyard Blaster LGun 7800: Meltdown LGun Sentinel LGun Shooting Arcade (Proto) LGun ---------Paddles (Menu 45 itms)--------- Return to ROOT MENU <<<<<<<<<<<<<<<<<<<< In here there are sub-menu's for: 2-Btn, Joystick, and Paddles If you can think of a better way to put these sub-menus items in please let me know. Happy CC2-ing. Quote Link to comment Share on other sites More sharing options...
