+batari Posted July 19, 2005 Author Share Posted July 19, 2005 Just got a chance to look at your code... I think I answered the wrong question before, as the scrolling into the score was a bug in Alpha 0.1. This has been fixed in Alpha 0.2, so removing the rem in line 80 scrolls properly. The code needed to be fixed up a bit to compile in Alpha 0.2, since inline asm needs to be indented now. 894152[/snapback] Ok, thanks for looking at it. Just d/l'd the latest, greatest and yes that did fix my scrolling issue. Was going to stick in another couple of quick changes and post a new source, but I've run into another issue. I can't get score to decrement properly. score = score - 1 yields 67. Just to see if it was my program, I changed the following lines in your sample.bas 60 if joy0up then score = score + 1 80 if joy0down then score = score - 1 Hit up a couple of times, then hit down. 894414[/snapback] You're right - it's a bug in the compiler. This had been added to the todo list for Alpha 0.3. Quote Link to comment Share on other sites More sharing options...
s0c7 Posted July 19, 2005 Share Posted July 19, 2005 (edited) You're right - it's a bug in the compiler. This had been added to the todo list for Alpha 0.3. 894490[/snapback] Ok. Thanks. I replaced my posted source with a new version that is compatible with the current release (clouds scroll now ). I probably won't release another update until the next version of bB comes out. Edited July 19, 2005 by s0c7 Quote Link to comment Share on other sites More sharing options...
attendo Posted July 19, 2005 Share Posted July 19, 2005 (edited) Could you perhaps change it? also a little bit because my ide doesnt work with the files in 2600basic.zip and needs the latest version.. 2600basic.zip ( 110.9k ) Number of downloads: 173 <--- batari_basic_alpha2.zip ( 148.74k ) Number of downloads: 10 894185[/snapback] Yeah, it doesn't make much sense to continue to have Alpha 0.1 there, so I removed the file. 894487[/snapback] Thanks, lol your a very busy man now, phew. Edited July 19, 2005 by attendo Quote Link to comment Share on other sites More sharing options...
+batari Posted July 19, 2005 Author Share Posted July 19, 2005 Ok, thanks for looking at it. Just d/l'd the latest, greatest and yes that did fix my scrolling issue. Was going to stick in another couple of quick changes and post a new source, but I've run into another issue. I can't get score to decrement properly. score = score - 1 yields 67. Just to see if it was my program, I changed the following lines in your sample.bas 60 if joy0up then score = score + 1 80 if joy0down then score = score - 1 894490[/snapback] Just thinking out loud... One way to do score=score-1 is score=score+999999. This will work now and also will carry over to later versions. Quote Link to comment Share on other sites More sharing options...
kisrael Posted July 19, 2005 Share Posted July 19, 2005 Just a note, I will keep an archive of versions, just because at some point we might end up with source code that won't turn into ASM with the updated versions. batari, if you get the chance, would you be able to put up a list of "likely" and "possible" and "in a perfect world" features for future versions? Or do you think it might make people too crazy if they don't see or end up getting their favorite features? In particular, I'm wondering about aliases for the A-Z variables and being able to ditch line numbers and to label subroutines with names rather than numbers... Man, I forgot how brutal old school BASIC was...in some ways worse than DASM! There's that famous "GOTO considered harmful" where that one guy thought if a student leans BASIC first, they may be broken for life as a programmer...I know enough programming now that I can compensate (I think) by making myself follow certain patterns, putting everything in subroutines and using comments, but still (I don't mean to sound ungrateful Batari! It's no coincidence that bB is getting me to FINALLY start coding some projects I've been toying with for a long time...) Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted July 19, 2005 Share Posted July 19, 2005 Incidentally, batari, if you want me to write a kernel for you, just let me know - I'd be happy to. Just tell me what it should do and I'll code it (and actually test it, ). If you want to write 'em, cool; I just wanted to get the offer on the table. Quote Link to comment Share on other sites More sharing options...
s0c7 Posted July 19, 2005 Share Posted July 19, 2005 Just thinking out loud... One way to do score=score-1 is score=score+999999. This will work now and also will carry over to later versions. 894543[/snapback] That works as far as the display. I'm also having problems getting score to work correctly in conditional situations. This may be my fault, not sure. Make the following changes to sample.bas to see what I'm talking about. Again, up/down the joystick to increment/decrement the score. The score color doesn't change if it goes over 10. However, if you roll it backwards to 999999 it will change. 35 if score > 10 then scorecolor = 80 : goto 45 60 if joy0up then score = score + 1 80 if joy0down then score = score + 999999 Quote Link to comment Share on other sites More sharing options...
kisrael Posted July 19, 2005 Share Posted July 19, 2005 Incidentally, batari, if you want me to write a kernel for you, just let me know - I'd be happy to. Just tell me what it should do and I'll code it (and actually test it, ). If you want to write 'em, cool; I just wanted to get the offer on the table. Hey, are you gonna do requests? Actually there's an interesting challenge here. Batari should consider writing up a quick standards doc for kernals--ideally they should use as much of the same variables (in terms of positioning things) as is feasible, given the feature layout of the given kernal. I'd love to see that kernal that lets you read in a background from "DATA" like statements..... Quote Link to comment Share on other sites More sharing options...
+batari Posted July 19, 2005 Author Share Posted July 19, 2005 (edited) Just thinking out loud... One way to do score=score-1 is score=score+999999. This will work now and also will carry over to later versions. 894543[/snapback] That works as far as the display. I'm also having problems getting score to work correctly in conditional situations. This may be my fault, not sure. Make the following changes to sample.bas to see what I'm talking about. Again, up/down the joystick to increment/decrement the score. The score color doesn't change if it goes over 10. However, if you roll it backwards to 999999 it will change. 35 if score > 10 then scorecolor = 80 : goto 45 60 if joy0up then score = score + 1 80 if joy0down then score = score + 999999 894600[/snapback] Right now, using the score in an if-then won't work as you expect... Instead, accessing "score" really gives you the BCD value of the highest two digits. You meed to break the score into three individual BCD values by dimming variables, then doing the following checks: dim scorevalue2=score+2 dim scorevalue1=score+1 dim scorevalue0=score if scorevalue2>$10 || scorevalue1>1 then scorecolor=80:goto 45 if scorevalue0>1 then scorecolor=80:goto 45 EDIT: OOPS, error in above, left out the "then" I haven't tried this, but I think it will work. Edited July 19, 2005 by batari Quote Link to comment Share on other sites More sharing options...
+batari Posted July 19, 2005 Author Share Posted July 19, 2005 batari, if you get the chance, would you be able to put up a list of "likely" and "possible" and "in a perfect world" features for future versions? Or do you think it might make people too crazy if they don't see or end up getting their favorite features? In particular, I'm wondering about aliases for the A-Z variables and being able to ditch line numbers and to label subroutines with names rather than numbers... 894552[/snapback] You must be too busy to read the README Aliases: already in Alpha 0.2 Linenumbers: now optional in Alpha 0.2 Labels: now allowed, but also optional in Alpha 0.2 But yeah, I think such a list would be helpful. Quote Link to comment Share on other sites More sharing options...
+batari Posted July 19, 2005 Author Share Posted July 19, 2005 Incidentally, batari, if you want me to write a kernel for you, just let me know - I'd be happy to. Just tell me what it should do and I'll code it (and actually test it, ). If you want to write 'em, cool; I just wanted to get the offer on the table. 894565[/snapback] I'll PM you with particulars later tonight... I don't want to announce anything publicly until we have something workable. Quote Link to comment Share on other sites More sharing options...
yuppicide Posted July 19, 2005 Share Posted July 19, 2005 I suggested once this gets more polished we contact Retro Gamer about putting in some programs people can type in themselves like back in the old days. Anyone talked to Retro Gamer about this yet? jeff 892335[/snapback] Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 20, 2005 Share Posted July 20, 2005 Yep, Potatohead is right - the compiler currently doesn't like -1. Just replace -1 with 255, and it will compile and work how you want it to. No need to define player 1. 894483[/snapback] Yep, that did the trick. Can't imagine the logic behind this, but hey, if it works, it works! Thanks for the advice. I'll tweak this a little more and see what happens. JR Quote Link to comment Share on other sites More sharing options...
+batari Posted July 20, 2005 Author Share Posted July 20, 2005 Yep, Potatohead is right - the compiler currently doesn't like -1. Just replace -1 with 255, and it will compile and work how you want it to. No need to define player 1. 894483[/snapback] Yep, that did the trick. Can't imagine the logic behind this, but hey, if it works, it works! 894662[/snapback] For an explanation, read the section on negative numbers here: http://alienbill.com/2600/basic/downloads/0.2/help.html Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 20, 2005 Share Posted July 20, 2005 (edited) Look at me! I'm flyin', I'm flyin'! By the way, Player0 will not work as part of an IF/THEN statement. HOWEVER, you can use IF/THEN statements to skip over the shapes you don't wish to use, thus creating limited animation. I have an idea for a video game which may just be possible with Batari BASIC. With some clever programming and a little flicker, I may be able to draw out every onscreen character, with a minimum of those chunky blocks. JR jtest2.bin Edited July 20, 2005 by Jess Ragan Quote Link to comment Share on other sites More sharing options...
kisrael Posted July 20, 2005 Share Posted July 20, 2005 I seem to be getting a lot of bogus Max. nested gosubs exceeded in line 65 As far as I can tell I'm not nesting ANY gosubs....just a series of gosubs with each sub returning once it's done... any idea? Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 20, 2005 Share Posted July 20, 2005 I'm kickin' it into overdrive with this one! (Bonus points for anyone who can name the game that inspired this demo) JR jturbo.bin Quote Link to comment Share on other sites More sharing options...
+batari Posted July 20, 2005 Author Share Posted July 20, 2005 (edited) I seem to be getting a lot of bogus Max. nested gosubs exceeded in line 65 As far as I can tell I'm not nesting ANY gosubs....just a series of gosubs with each sub returning once it's done... any idea? 894683[/snapback] Yes, it's bogus, caused by fuzzy thinking on my calculation nested gosubs. Until I fix, a workaround would be to stick inline asm in there: gosub subroutine would become asm jsr subroutine end This should work, and bypass the incorrect checking for nested gosubs. Edited July 20, 2005 by batari Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 20, 2005 Share Posted July 20, 2005 I've got a question about the score counter. It only seems to count upwards... any attempts to initialize it or count downward with it end in failure. What I'd like to do is split the score counter into two parts; one for the actual score, then another for a countdown timer which would end the game once it reaches zero. Is there any way to do this? JR Quote Link to comment Share on other sites More sharing options...
s0c7 Posted July 20, 2005 Share Posted July 20, 2005 (edited) I know I said I'd wait until the next release..... Here is the latest version of F-4. What's new/changes: - You now start with a score of 3. For every hit, add 1. For every miss, subtract 1. If your score reaches 0, game over. - You have to use the reset button to start a game (fire won't do it anymore). - Revamped the source somewhat. Added even more comments. Big thanks to batari for getting back to me so quick on the questions I posted earlier. I kind of cheated with my solution to the If..Then score issue. Still some things I want to do, but this is getting close. ** Update 7/20 - d/l removed. See post 340 for the latest version. Edited July 20, 2005 by s0c7 Quote Link to comment Share on other sites More sharing options...
+batari Posted July 20, 2005 Author Share Posted July 20, 2005 I've got a question about the score counter. It only seems to count upwards... any attempts to initialize it or count downward with it end in failure. What I'd like to do is split the score counter into two parts; one for the actual score, then another for a countdown timer which would end the game once it reaches zero. Is there any way to do this? JR 894733[/snapback] There's not really any way to do it right now. But later I might allow two 3 digit scores which would allow you to do this. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 20, 2005 Share Posted July 20, 2005 All right, this is the last version of my demo for the day. With any luck, it will evolve into a full-fledged game in the next few days. I couldn't get the ship to properly wrap around the screen, so instead I've created boundaries to keep it in check. Now it's time to bring an enemy to this little party... JR jgame.bin Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 20, 2005 Share Posted July 20, 2005 I know I said I'd wait until the next release..... Here is the latest version of F-4. What's new/changes: - You now start with a score of 3. For every hit, add 1. For every miss, subtract 1. If your score reaches 0, game over. - You have to use the reset button to start a game (fire won't do it anymore). - Revamped the source somewhat. Added even more comments. Big thanks to batari for getting back to me so quick on the questions I posted earlier. I kind of cheated with my solution to the If..Then score issue. Still some things I want to do, but this is getting close. 894739[/snapback] Geez, this is seriously impressive. The scrolling screen totally floored me, and you came up with a pretty clever way to subtract points from the score. My only complaint is the random enemy movement... the rival jet looks like it's being flown by a coffee addict. Other than that, you've done a most excellent job! JR Quote Link to comment Share on other sites More sharing options...
Tork110 Posted July 20, 2005 Share Posted July 20, 2005 Thanks for your help from the other day. I'm getting closer to completing the game I'm working on. My game is basically running around trying to avoid getting hit by falling pf pixels and a bouncing missile. Because I feel that that may not be great by itself, I've been trying to add everything I could think of including animations for when you reach a certain score, music, and hopefully a title screen. The music is giving me the most trouble right now. I guess I should write a quick program to find out what the TIA can do. Quote Link to comment Share on other sites More sharing options...
kisrael Posted July 20, 2005 Share Posted July 20, 2005 So I've finally got of my butt and MADE something with this great tool. Not a game, more of a toy...plus, I made a Playfield Graphic Editor that some of you may find useful. The toy name is "NECG DRUMMA v0.1". Screenshot and binary attached I hope. I made extensive use of pfpixel to write the title of the game in the background. It's New England Classic Gamers' own "PacPilgrim" for a simple drum machine: left is bass, right is snare, button is high hat. The quick and dirty tool I made for that is here: the bBpf Editor. You can use the keyboard to enter Xs and.s to draw the pixels, and it translates them to individual pfpixel calls, with a few formatting option. It's not super-well tested, doesn't warn you if you do something that exceeds what bB can do, but it worked pretty well for me! I'm including the text of the game here becuase I think it uses some good practices available with the 0.2 Alpha that I haven't heard much talk about: it shuns line numbers, uses descriptive labels for both goto-locations and variable names. dim pacMouthTime=a dim voice0vol=b dim voice1vol=c dim okToReadStick=d COLUPF = 90 player0x = 128 : player0y = 35 player1x = 127 : player1y = 40 okToReadStick = 1 setHatGraphic player0: %11111111 %00110100 %00111100 %00111100 %00111100 end pfpixel 0 0 on : pfpixel 3 0 on : pfpixel 5 0 on : pfpixel 6 0 on pfpixel 7 0 on : pfpixel 10 0 on : pfpixel 11 0 on : pfpixel 14 0 on pfpixel 15 0 on : pfpixel 0 1 on : pfpixel 1 1 on : pfpixel 3 1 on pfpixel 5 1 on : pfpixel 9 1 on : pfpixel 13 1 on : pfpixel 20 1 on pfpixel 22 1 on : pfpixel 26 1 on : pfpixel 27 1 on : pfpixel 28 1 on pfpixel 30 1 on : pfpixel 0 2 on : pfpixel 2 2 on : pfpixel 3 2 on pfpixel 5 2 on : pfpixel 6 2 on : pfpixel 9 2 on : pfpixel 13 2 on pfpixel 15 2 on : pfpixel 16 2 on : pfpixel 20 2 on : pfpixel 22 2 on pfpixel 26 2 on : pfpixel 28 2 on : pfpixel 30 2 on : pfpixel 0 3 on pfpixel 3 3 on : pfpixel 5 3 on : pfpixel 9 3 on : pfpixel 13 3 on pfpixel 16 3 on : pfpixel 21 3 on : pfpixel 24 3 on : pfpixel 26 3 on pfpixel 27 3 on : pfpixel 28 3 on : pfpixel 30 3 on : pfpixel 0 4 on pfpixel 3 4 on : pfpixel 5 4 on : pfpixel 6 4 on : pfpixel 7 4 on pfpixel 10 4 on : pfpixel 11 4 on : pfpixel 14 4 on : pfpixel 15 4 on pfpixel 4 6 on : pfpixel 5 6 on : pfpixel 8 6 on : pfpixel 9 6 on pfpixel 12 6 on : pfpixel 14 6 on : pfpixel 16 6 on : pfpixel 20 6 on pfpixel 22 6 on : pfpixel 26 6 on : pfpixel 29 6 on : pfpixel 4 7 on pfpixel 6 7 on : pfpixel 8 7 on : pfpixel 10 7 on : pfpixel 12 7 on pfpixel 14 7 on : pfpixel 16 7 on : pfpixel 17 7 on : pfpixel 19 7 on pfpixel 20 7 on : pfpixel 22 7 on : pfpixel 23 7 on : pfpixel 25 7 on pfpixel 26 7 on : pfpixel 28 7 on : pfpixel 30 7 on : pfpixel 4 8 on pfpixel 6 8 on : pfpixel 8 8 on : pfpixel 9 8 on : pfpixel 12 8 on pfpixel 14 8 on : pfpixel 16 8 on : pfpixel 18 8 on : pfpixel 20 8 on pfpixel 22 8 on : pfpixel 24 8 on : pfpixel 26 8 on : pfpixel 28 8 on pfpixel 29 8 on : pfpixel 30 8 on : pfpixel 4 9 on : pfpixel 6 9 on pfpixel 8 9 on : pfpixel 10 9 on : pfpixel 12 9 on : pfpixel 14 9 on pfpixel 16 9 on : pfpixel 20 9 on : pfpixel 22 9 on : pfpixel 26 9 on pfpixel 28 9 on : pfpixel 30 9 on : pfpixel 4 10 on : pfpixel 5 10 on pfpixel 8 10 on : pfpixel 10 10 on : pfpixel 12 10 on : pfpixel 13 10 on pfpixel 14 10 on : pfpixel 16 10 on : pfpixel 20 10 on : pfpixel 22 10 on pfpixel 26 10 on : pfpixel 28 10 on : pfpixel 30 10 on startLoop rem player1x = 127 player1y = 47 if okToReadStick = 0 then goto doneStick if joy0left then player1x = 117 : voice0vol = 12 : AUDF0 = 30 : AUDC0 = 15 : okToReadStick = 0 : goto doneStick if joy0right then player1x = 137 : voice0vol = 8 : AUDF0 = 8 : AUDC0 = 8 : okToReadStick = 0 : goto doneStick rem if joy0up then player1y = 20 rem if joy0down then player1y = 60 doneStick if joy0left then goto stickAintClear if joy0right then goto stickAintClear okToReadStick = 1; stickAintClear if joy0fire then player1y = 37 : voice1vol = 8 : AUDF1 = 0 : AUDC1 = 8 if voice0vol = 0 then goto doneLowerVoice0 voice0vol = voice0vol - 1 doneLowerVoice0 if voice1vol = 0 then goto doneLowerVoice1 voice1vol = voice1vol - 1 doneLowerVoice1 AUDV0 = voice0vol AUDV1 = voice1vol if player1x < 127 then player1x = player1x + 1: REFP1 = 8 : REFP0 = 8 if player1x > 127 then player1x = player1x - 1: REFP1 = 0 : REFP0 = 0 if player1y < 47 then player1y = player1y + 1 if player1y > 47 then player1y = player1y - 1 player0y = player0y + 5 player0x = player0x - 1 if player0x < player1x then player0x = player0x + 1 if player0x > player1x then player0x = player0x - 1 if player0y < player1y then player0y = player0y + 1 if player0y > player1y then player0y = player0y - 1 player0y = player0y - 5 player0x = player0x + 1 goto doPacGraphic returnFromPacGraphic COLUP0 = $04 : COLUP1 = $1C drawscreen goto startLoop doPacGraphic pacMouthTime = pacMouthTime + 1 if pacMouthTime > 20 then pacMouthTime = 1 if pacMouthTime > 10 then goto setPacGraphic2 setPacGraphic1 player1: %00011000 %00111100 %01110000 %01100000 %01110000 %00111100 %00011000 end goto doneSettingPacGraphic setPacGraphic2 player1: %00011000 %00111100 %01111110 %01100000 %01111110 %00111100 %00011000 end doneSettingPacGraphic goto returnFromPacGraphic rem X..X.XXX..XX..XX................ rem XX.X.X...X...X......X.X...XXX.X. rem X.XX.XX..X...X.XX...X.X...X.X.X. rem X..X.X...X. .X..X....X..X.XXX.X. rem X..X.XXX..XX..XX................ rem ................................ rem ....XX..XX..X.X.X...X.X...X..X.. rem ....X.X.X.X.X.X.XX.XX.XX.XX.X.X. rem ....X.X.XX..X.X.X.X.X.X.X.X.XXX. rem ....X.X.X.X.X.X.X...X.X...X.X.X. rem ....XX..X.X.XXX.X...X.X...X.X.X. necgdrumma.bin Quote Link to comment Share on other sites More sharing options...
