PacManPlus Posted August 23, 2005 Share Posted August 23, 2005 (edited) Does Missile Command on a cartridge show the same display oddities as the built-in? 916737[/snapback] You do see the bar under the reserve like the one built-in, but the 'comb' is visible when the screen changes color. I think someone said that it was either solid or you couldn't see it at all? I haven't played the built-in Missile Command for very long yet... Bob Edited August 23, 2005 by PacManPlus Quote Link to comment Share on other sites More sharing options...
cnjmallett Posted October 8, 2005 Share Posted October 8, 2005 Should I have continuity between the black wire's original point at J40 and the new point at the top of C4? No matter which one I have the black wire hooked to, I still see the startup screen for the Flashback 2 (castle). And when I add the jumper to J3 (connecting the left and right sides), all it basically does is sort of scramble the title screen. Now, if I plug in a cartridge, I'll get a whole different kind of scramble, though that scramble will slightly change when I attach the jumper. Any ideas or thoughts on this would be appreciated. And just to double check, if you were facing a cartridge connector, already in a machine, I wired bottom left as 1, bottom right as 12, top left as 24, and top right as 13. 24-----------13 1------------12 Is this correct? I also tried: 13----------24 12-----------1 just to see, but that didn't work either. I may be in over my head with this, but I figured I'd give it a shot. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted October 8, 2005 Share Posted October 8, 2005 Should I have continuity between the black wire's original point at J40 and the new point at the top of C4? No matter which one I have the black wire hooked to, I still see the startup screen for the Flashback 2 (castle). 944697[/snapback] No. It sounds like you solder-bridged across the capacitor somehow (or bridged to something near where the wire was originally at J40). And when I add the jumper to J3 (connecting the left and right sides), all it basically does is sort of scramble the title screen. Now, if I plug in a cartridge, I'll get a whole different kind of scramble, though that scramble will slightly change when I attach the jumper. Any ideas or thoughts on this would be appreciated. 944697[/snapback] It won't work right until you get the first problem fixed. And just to double check, if you were facing a cartridge connector, already in a machine, I wired bottom left as 1, bottom right as 12, top left as 24, and top right as 13. 24-----------13 1------------12 Is this correct? I also tried: 13----------24 12-----------1 just to see, but that didn't work either. I may be in over my head with this, but I figured I'd give it a shot. 944697[/snapback] Your first version of the cart port pinout is correct, if viewing it from the side the cartridge plugs into. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted October 9, 2005 Author Share Posted October 9, 2005 You've solder bridged someplace, everything else you've done sounds correct, also the top pinout you listed is the correct one: 24_____________13 1______________12 Curt Should I have continuity between the black wire's original point at J40 and the new point at the top of C4? No matter which one I have the black wire hooked to, I still see the startup screen for the Flashback 2 (castle). And when I add the jumper to J3 (connecting the left and right sides), all it basically does is sort of scramble the title screen. Now, if I plug in a cartridge, I'll get a whole different kind of scramble, though that scramble will slightly change when I attach the jumper. Any ideas or thoughts on this would be appreciated. And just to double check, if you were facing a cartridge connector, already in a machine, I wired bottom left as 1, bottom right as 12, top left as 24, and top right as 13. 24-----------13 1------------12 Is this correct? I also tried: 13----------24 12-----------1 just to see, but that didn't work either. I may be in over my head with this, but I figured I'd give it a shot. 944697[/snapback] Quote Link to comment Share on other sites More sharing options...
cnjmallett Posted October 9, 2005 Share Posted October 9, 2005 Thanks guys, I really appreciate the help. Quote Link to comment Share on other sites More sharing options...
cnjmallett Posted October 9, 2005 Share Posted October 9, 2005 Well, I guess I hit a "bad" batch (as far as modifying them), because I bought a second one, and before I touched anything, I checked J40 and C4 and they have continuity between them on this one too. So it's really no use I go any further. Oh well, I got most of what I wanted out of this project, which was to learn. Maybe I'll try it again with the Flashback 3 if that ends up being an option on that one too. Thanks again for you help guys. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted October 9, 2005 Share Posted October 9, 2005 (edited) Well, I guess I hit a "bad" batch (as far as modifying them), because I bought a second one, and before I touched anything, I checked J40 and C4 and they have continuity between them on this one too. 945136[/snapback] Um, the black wire's original position at J40 is supposed to have continuity to one side of C4. You need to move the black wire to the other side of C4. Curt (or anyone, really), could you make a close-up board photo with the black wire disconnected, with both of its possible initial locations and the new location for using cartridges all identified? Edited October 9, 2005 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
cnjmallett Posted October 9, 2005 Share Posted October 9, 2005 I got it! That was it AJ... I just needed to move the wire to the other side of C4. Something so simple.... oh well, live and learn... which was the whole point of me trying this anyway. Again, thank you for your help. Thanks for your help too, Curt. Quote Link to comment Share on other sites More sharing options...
spikey911 Posted October 16, 2005 Share Posted October 16, 2005 Are there any other places that sell the connectors, etc ? The websites listed here are completely confusing... Is there any place that you can order from simply without e-mailing and such? Quote Link to comment Share on other sites More sharing options...
+batari Posted October 16, 2005 Share Posted October 16, 2005 I did the soldering on my FB2 today. I noticed that the circuit board looks different from the one on the website. The solder pads are located in different places, and there is no mention of J40 and C4, instead the board says to use J9. There was a component that appeared to be a 0 Ohm resistor across J9, which I removed so I could put a switch there. But no dice - carts won't work when J3 is shorted and J9 open, but the FB2 mode still works with J3 open and J9 shorted so I don't think I screwed anything up. Does anyone else have this version of FB2, and have they successfully modded it yet? Is there anything I've missed? Quote Link to comment Share on other sites More sharing options...
Kokovec Posted October 17, 2005 Share Posted October 17, 2005 Are there any other places that sell the connectors, etc ? The websites listed here are completely confusing... Is there any place that you can order from simply without e-mailing and such? 949375[/snapback] I purchased my connectors from Best Electronics. The best thing to do is call them and tell them you need a cart connector for an FB2 unit. They only sell them in pairs so it will cost you $20.00 + S&H. The part number is CO15573A for the connector and guide. Follow this link and call the number at the bottom of the page http://www.best-electronics-ca.com/2600_Tech_Tips.htm#based Quote Link to comment Share on other sites More sharing options...
[d2f]Iggy*SJB Posted December 10, 2005 Share Posted December 10, 2005 I'll make my introduction post later.....but suffice it to say I'm a very classic gamer, with a fair(not extensive, but I can wield a soldering iron without much worry) knowledge of electronics. I just got one of these devices, which I bought because it can be modified for original carts(the main reason I didn't buy the 1st one). I have a question, and it's fairly simple. I have a DEAD Atari 2600. I had it repaired once(cost a boatload of cash, but I liked it)....but the repair didn't last. The question is this: Can I remove the cartridge slot from the dead one, for use in the FB2? Just to say it....I hope the FB3(since it IS in the works), comes with the cart port installed. If a cart doesn't run on it, the cart is probably bad. Quote Link to comment Share on other sites More sharing options...
ATARIeric Posted December 11, 2005 Share Posted December 11, 2005 Can I remove the cartridge slot from the dead one, for use in the FB2? Yes, You would need to desolder it off the main board. Maybe this link will help you learn how to desolder. Eric Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted December 11, 2005 Share Posted December 11, 2005 I have a DEAD Atari 2600. I had it repaired once(cost a boatload of cash, but I liked it)....but the repair didn't last. The question is this: Can I remove the cartridge slot from the dead one, for use in the FB2? 980244[/snapback] If you do (and if you're in the U.S.A.), could I get the rest of the dead motherboard from you? Quote Link to comment Share on other sites More sharing options...
[d2f]Iggy*SJB Posted December 11, 2005 Share Posted December 11, 2005 Thanks, I do know how(and have the tools) to de-solder it. Although, hopefully, someone might find that link usable! AJ- For a couple of bucks, sure. I honestly don't know whats wrong with it, but I figure it's worth a few dollars(no more than $5.), plus shipping. It will be intact, though. I'll even post a picture of it, if you'd like(Before you commit, of course.) Quote Link to comment Share on other sites More sharing options...
SalemFrost7800 Posted March 9, 2006 Share Posted March 9, 2006 (edited) 2 questions: 1) Does this create a better looking display on the T.V.? I have 2 Original 2600 consoles and neither has a great t.v. display even with the adapter I bought from Atariage. 2) Does anyone on here make and sell these? Thanks ,Tim Edited March 10, 2006 by usinoh Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted March 10, 2006 Share Posted March 10, 2006 (edited) 2 questions: 1) Does this create a better looking display on the T.V.? I have 2 Original 2600 consoles and neither has a great t.v. display even with the adapter I bought from Atariage. 2) Does anyone on her make and sell these? 1030824[/snapback] What are you smoking? 1) This thread is about adding a cartridge port to the Flashback 2 dedicated system. Adding a cart port to your Flashback 2 will have no effect on the picture quality of your other two 2600 consoles! 2) I doubt it. When I'm on her, thoughts of Atari never even enter my mind! Edited March 10, 2006 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
SalemFrost7800 Posted March 10, 2006 Share Posted March 10, 2006 2) I doubt it. When I'm on her, thoughts of Atari never even enter my mind! LOL oops Quote Link to comment Share on other sites More sharing options...
SalemFrost7800 Posted March 10, 2006 Share Posted March 10, 2006 2 questions: 1) Does this create a better looking display on the T.V.? I have 2 Original 2600 consoles and neither has a great t.v. display even with the adapter I bought from Atariage. 2) Does anyone on her make and sell these? 1030824[/snapback] 1) This thread is about adding a cartridge port to the Flashback 2 dedicated system. Adding a cart port to your Flashback 2 will have no effect on the picture quality of your other two 2600 consoles! I realize that, however the FB2 uses patch cords to plug into the front of your tv and the old atari systems use an RF switch, I thought using the new type plug in could create a picture that looks more clean than the old switch type. Quote Link to comment Share on other sites More sharing options...
