Smiley Posted August 18, 2005 Share Posted August 18, 2005 Yar's Revenge, Demon Attack, Mario Bros, Chopper Command, AstroBlast, are all games that I have been playing off and on as of late. I don't worry about high scores, I play for fun. Quote Link to comment Share on other sites More sharing options...
***astro_boy*** Posted August 18, 2005 Share Posted August 18, 2005 currently playing motorodeo Quote Link to comment Share on other sites More sharing options...
keilbaca Posted August 18, 2005 Share Posted August 18, 2005 (edited) I wish I *could* play my Atari but the A/C plug cord is damaged and I can't find a suitable replacement anywhere. My 40+ games are just sitting on a shelf as a display until I get one. 910070[/snapback] If you're REALLY desperate, you can slice the brock off the cable and wrap the wires to the terminals on a 9volt battery. ... It'll get expensive if you do it much, though. If I recall, you can expect about an hour of game time per battery. 910074[/snapback] Wrong. A 9-volt lasts 4 hours. If you go to radio shack and get a 8 AA holder, or even a 6 AA holder, that'll last for a long, long time. Like, my batteries never died and I played it for a month on batteries only long time. Now, here is something very important. When you are done playing, unplug the battery. The switch is at the 5v line, not the 9v line. Which means, even when the atari is off, it is still sucking power. The FB2 has this problem as well and when I get the one, I am going to wire the power to the 9V line, and make it run off of 6 AA's. The Atari ran off of 250some mha, and the FB2, running at like 75mha (milliamps per hour). So 6 AA's is going to last one hell of a long time. As for the game? Alien, then hopefully today, my CC2 will arive =D Edited August 18, 2005 by keilbaca Quote Link to comment Share on other sites More sharing options...
arlo Posted August 18, 2005 Share Posted August 18, 2005 I've been playing Kaboom, Pressure Cooker, and Street Racer the most. My fiance and I get into some fierce competitions while playing those. The only problem is, I just started a 2600 collection, and there are still dozens of games for us to try out because we spend so much time with those 3 games plus a few others. Guess I need either more time or more discipline... Quote Link to comment Share on other sites More sharing options...
uosipa llamxew Posted August 18, 2005 Share Posted August 18, 2005 (edited) I've got my Krokocart plugged in with Man Goes Down (and an Atarivox plugged into the other controller slot). My SC playing SWOOPS! I read something about "Swoops" in the Stella Mailing List (I think)... Is this all new, or is it something like Crash 'n Dive renamed? /curious [edit] Crash 'n' Dive, not Crash 'n' Burn. [double-edit] Ah, somehow I missed the news about the new multi-cart. Excellence & Congrats! http://www.atariage.com/features/shows/vgd...view/demos.html Edited August 18, 2005 by mojofltr Quote Link to comment Share on other sites More sharing options...
Lord Thag Posted August 18, 2005 Share Posted August 18, 2005 Jr Pac, planet patrol, frostbite and Crystal castles this week. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted August 18, 2005 Share Posted August 18, 2005 My KC playing Ixion very, very soon Quote Link to comment Share on other sites More sharing options...
galaxy warrior Posted August 18, 2005 Share Posted August 18, 2005 warlords and crystal castles. Quote Link to comment Share on other sites More sharing options...
Elvis8Atari Posted August 23, 2005 Share Posted August 23, 2005 Qberts Qubes Quote Link to comment Share on other sites More sharing options...
Sayton Posted December 9, 2005 Author Share Posted December 9, 2005 Wow! Found this old topic. Anyways, the games I have out now are: Coconuts Phoenix Donkey Kong Fast Food Galaxian I did have Space Invaders out but put it on the shelf when checking my collection. Galaxian has been seeing the most play so far. That game got so great I was curling my toes (the game intensity was getting that good). Quote Link to comment Share on other sites More sharing options...
Christophero Sly Posted December 9, 2005 Share Posted December 9, 2005 I'm alternating between Dragster and trying to develop a pattern to get 34 on Freeway. Quote Link to comment Share on other sites More sharing options...
Recycled Posted December 9, 2005 Share Posted December 9, 2005 Interchanged within the last few days: Centipede Joust Solar Fox Entombed Mario Bros. Yars Revenge Tunnel Runner Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted December 9, 2005 Share Posted December 9, 2005 (edited) The Atari ran off of 250some mha, and the FB2, running at like 75mha (milliamps per hour). 913729[/snapback] Current draw for these items would be in milliamperes a.k.a. milliamps (mA), not "milliamps per hour", which is nonsense. Draw of an original Atari console varies from one unit to the next (and different cartridges use different amounts too), so it would typically be between 250 and 350 mA. Battery capacity is typically measured in milliamp-hours (mAh). If a battery holds 1250 mAh and you put a 250 mA load on it, simple division of capacity by load gives the approximate runtime in hours (5 hours in this example). Note that when putting cells in series, the mAh numbers are not added, so if your 6 x AA cell battery pack had 6 of 2500 mAh rechargeables in it with the same 250 mA load, you could expect about 10 hours of runtime. These calculated runtimes will be a bit more than what you really get for 2 reasons: most items can't keep running until the battery reaches zero volts, and battery mAh figures are given for very slow discharge rates (20 hours constant current until empty) - draining at faster rates wastes more power as heat inside the cells, so you get lower than calculated runtime. So, in the first example above, if using a 1250 mAh battery with a 250 mA load, you should expect to get somewhat less than 5 hours runtime, possibly just a little over 4 hours (wild guess). Edited December 9, 2005 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
atari_wizard Posted December 9, 2005 Share Posted December 9, 2005 Pitfall II-Lost Caverns in my system nearly 365 days a year. Keystone Kapers Quote Link to comment Share on other sites More sharing options...
128bytes Posted December 9, 2005 Share Posted December 9, 2005 My 7800's video output recently died, so my Cuttle Cart II is taking a rest and I've hooked up my 2600 again. In the past 24 hours I've played Frogs and Flies, Return of Mario Bros., and Keystone Kapers. Quote Link to comment Share on other sites More sharing options...
n8littlefield Posted December 9, 2005 Share Posted December 9, 2005 Right now my collection is pretty small (approx 10 carts) but I've been playing an unhealthy amount of Chopper Command. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted December 9, 2005 Share Posted December 9, 2005 I usually cycle between a few games and the high score club game. I usually swap between Adventures of TRON, Quadrun and Boing!, and Pengo is in the atari right now. Quote Link to comment Share on other sites More sharing options...
elviticus Posted December 9, 2005 Share Posted December 9, 2005 Alligator People and Holiday QB. Fun games, both! Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted December 9, 2005 Share Posted December 9, 2005 Lately: Hack-Em Adventure II Sinistar Quote Link to comment Share on other sites More sharing options...
shadow460 Posted December 10, 2005 Share Posted December 10, 2005 Latest Atari game is 7800 Meltdown. Latest other games are Worldwide Soccer Victory Goal Edition (Saturn) and Enemy Zero (also Saturn). Quote Link to comment Share on other sites More sharing options...
