Cheese007 Posted April 16, 2006 Share Posted April 16, 2006 this one (check second picture) Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1052317 Share on other sites More sharing options...
TheRedEye Posted April 18, 2006 Share Posted April 18, 2006 Just out of curiousity, what was the final plan to getting this great proto dumped? I am going to be sending my modified 7800 to him, just have not gotten around to it yet. Yup. Once I get the modded 7800, I'm going to roll up to SF and try to have TheRedEye give me a hand with the dump. Keep the faith - sooner or later everyone will be able to take a hack at GLCB. Matt Kain Possible concern: I don't have a TV with RF inputs, does this modified 7800 also have composite out? Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1053250 Share on other sites More sharing options...
Tempest Posted April 18, 2006 Share Posted April 18, 2006 this one (check second picture) That one is the final version. I can tell by the date. Tempest Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1053252 Share on other sites More sharing options...
+Mitch Posted April 18, 2006 Share Posted April 18, 2006 Just out of curiousity, what was the final plan to getting this great proto dumped? I am going to be sending my modified 7800 to him, just have not gotten around to it yet. Yup. Once I get the modded 7800, I'm going to roll up to SF and try to have TheRedEye give me a hand with the dump. Keep the faith - sooner or later everyone will be able to take a hack at GLCB. Matt Kain Possible concern: I don't have a TV with RF inputs, does this modified 7800 also have composite out? Do you have a VCR? You can plug the 7800 into the RF input of the VCR and output through composite to your TV. Mitch Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1053360 Share on other sites More sharing options...
TheRedEye Posted April 18, 2006 Share Posted April 18, 2006 Do you have a VCR? You can plug the 7800 into the RF input of the VCR and output through composite to your TV. Mitch Nope. I think I have a l'il 9" somewhere with composite in the back, though. I'll figure something out! Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1053416 Share on other sites More sharing options...
A.J. Franzman Posted April 18, 2006 Share Posted April 18, 2006 (edited) Possible concern: I don't have a TV with RF inputs, does this modified 7800 also have composite out? Um, if it doesn't have an RF input, it isn't a television. Are you saying you only use video monitors in your house? An RF signal is the same as what comes from an antenna, or a cable TV or satellite receiver. Just because the jack is not compatible with the plug on the end of the cable from the Atari console, doesn't mean anything. AFAIK, no North American TV ever had an RF input that used an RCA jack which would directly accept an Atari console's RF cable. When the 2600 and 7800 were produced, most TVs had a pair of screw terminals for connecting to 300 ohm twin-lead antenna cable, and that's what comes out of the console's switch box. Nowadays a TV's RF input is via a female "F" connector that accepts 75 ohm coaxial cable. Adapters are available to connect the console's RF cable directly to this type of jack, or to connect the twin-lead output of the switch box to it. Edited March 20, 2007 by A.J. Franzman Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1053481 Share on other sites More sharing options...
A.J. Franzman Posted April 18, 2006 Share Posted April 18, 2006 If you only have a portable TV with no external antenna signal input, it should still be possible to connect the 7800's RF cable by using an alligator clip lead between the RF cable center terminal and the TV's built-in antenna. The picture won't be great, but it should be good enough for dumping. Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1053483 Share on other sites More sharing options...
TheRedEye Posted April 19, 2006 Share Posted April 19, 2006 (edited) Possible concern: I don't have a TV with RF inputs, does this modified 7800 also have composite out? Um, if it doesn't have an RF input, it isn't a television. Are you saying you only use video monitors in your house? That's exactly what I'm saying, yes. But my 9" does indeed have an RF jack in the back, so we're okay. Edited April 19, 2006 by TheRedEye Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1054030 Share on other sites More sharing options...
mattkain Posted April 21, 2006 Author Share Posted April 21, 2006 Possible concern: I don't have a TV with RF inputs, does this modified 7800 also have composite out? Um, if it doesn't have an RF input, it isn't a television. Are you saying you only use video monitors in your house? That's exactly what I'm saying, yes. But my 9" does indeed have an RF jack in the back, so we're okay. Otherwise I have a VCR which I'm fairly certain has an RF input. I still haven't received a modded 7800 though. I'll let you know when this happens. matt Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1055015 Share on other sites More sharing options...
Josh Posted May 14, 2006 Share Posted May 14, 2006 Sooooo... Whens the Rom Going to Be Distributed? Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1067317 Share on other sites More sharing options...
Tempest Posted May 14, 2006 Share Posted May 14, 2006 Sooooo...Whens the Rom Going to Be Distributed? Wheeeeeeeeen.... It has be dumped. Tempest Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1067330 Share on other sites More sharing options...
Josh Posted May 14, 2006 Share Posted May 14, 2006 oh.... ok.... i'll just wait... Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1067332 Share on other sites More sharing options...
Foxsolo2000 Posted May 14, 2006 Share Posted May 14, 2006 Got to admit that this is the most exciting development in years. Cant wait to see it Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1067433 Share on other sites More sharing options...
stop_rebel_scum Posted May 15, 2006 Share Posted May 15, 2006 Sooooo...Whens the Rom Going to Be Distributed? Good Grief.. Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1068028 Share on other sites More sharing options...
NightSprinter Posted May 15, 2006 Share Posted May 15, 2006 Sooooo...Whens the Rom Going to Be Distributed? Good Grief.. :rolling: An ironic, yet highly-suitable response there. Seriously folks, let's just wait until it's done ok? I mean yeah I remember seeing an ad for it in an Atari poster I had when I was little, but even "I" can wait for the game to be released. Let's show a little patience here, folks. Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1068063 Share on other sites More sharing options...
~llama Posted May 28, 2006 Share Posted May 28, 2006 I'd just like to point out that One Doesn't Have to Capitalize Everything. And "Good grief" was a brilliant response Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1074443 Share on other sites More sharing options...
Foxsolo2000 Posted June 10, 2006 Share Posted June 10, 2006 Sorry to sound like a cracked record but any news yet? Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1081526 Share on other sites More sharing options...
CPUWIZ Posted June 10, 2006 Share Posted June 10, 2006 Delay is purely on me, patience. Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1081589 Share on other sites More sharing options...
Tempest Posted June 10, 2006 Share Posted June 10, 2006 Delay is purely on me, patience. You suck. Tempest Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1081641 Share on other sites More sharing options...
else Posted June 12, 2006 Share Posted June 12, 2006 Darn, no news yet. Every time I see this thread get bumped, I get all excited. Not that I'm complaining or anything..... Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1082363 Share on other sites More sharing options...
Shawn Posted June 12, 2006 Share Posted June 12, 2006 Delay is purely on me, patience. Lazy Bastard Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1082444 Share on other sites More sharing options...
Godzilla Posted June 13, 2006 Share Posted June 13, 2006 is there no end to the evil this Tom Delay character can spread? Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1082915 Share on other sites More sharing options...
Gregory DG Posted June 13, 2006 Share Posted June 13, 2006 Joy... I can't wait to see this in action! Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1082919 Share on other sites More sharing options...
ntavio Posted August 18, 2006 Share Posted August 18, 2006 bump??????????????????? Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1122824 Share on other sites More sharing options...
+Wonder007 Posted August 20, 2006 Share Posted August 20, 2006 Any news on this game????? Quote Link to comment https://forums.atariage.com/topic/84557-good-luck-charlie-brown/page/4/#findComment-1124121 Share on other sites More sharing options...
