EricDeLee Posted May 16, 2006 Share Posted May 16, 2006 Anyone know where I can get pictures of the inside of a Vectrex controller? I was told to just use an Atari joystick spring to fix the joystick controller... but after looking in my controller it is a vague description on how to repair that sucker. I have one controller that is not self centering. That's a pain in the rear to play games on it. So if anyone can help me out on fixing that puppy... It would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
warmachine Posted May 16, 2006 Share Posted May 16, 2006 Anyone know where I can get pictures of the inside of a Vectrex controller? I was told to just use an Atari joystick spring to fix the joystick controller... but after looking in my controller it is a vague description on how to repair that sucker. I have one controller that is not self centering. That's a pain in the rear to play games on it. So if anyone can help me out on fixing that puppy... It would be greatly appreciated. this might help. http://www.playvectrex.com/shoptalk/vecjoy...joyrepair_f.htm Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted May 16, 2006 Author Share Posted May 16, 2006 Anyone know where I can get pictures of the inside of a Vectrex controller? I was told to just use an Atari joystick spring to fix the joystick controller... but after looking in my controller it is a vague description on how to repair that sucker. I have one controller that is not self centering. That's a pain in the rear to play games on it. So if anyone can help me out on fixing that puppy... It would be greatly appreciated. this might help. http://www.playvectrex.com/shoptalk/vecjoy...joyrepair_f.htm That was helpful. The only thing is... I don't know where to put the spring. I realized a can't sell my extra very rare combat cart with no labels for $300 on ebay... so I am just going to rip open that sucker and steal that spring... Just got to figure out where to put that thing. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 17, 2006 Share Posted May 17, 2006 Just got to figure out where to put that thing. When you carefully take apart the pot with the broken spring .. it will be obvious what to do. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
Crazy Climber Posted May 17, 2006 Share Posted May 17, 2006 As long as were talking about broken Vectrex contollers, I have one that when I plug it in to play Minestorm the ship just keeps spining in a circle with out even touching the controller. Any Ideas? Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted May 17, 2006 Author Share Posted May 17, 2006 Well... That's the thing... whoever had it before took it apart. There is not a spring in there. I hear that you can use the spring from a combat cart (the weird looking one that well.... looks weird). Then I heard that you use the spring in an Atari Joystick. But that is a different spring. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 18, 2006 Share Posted May 18, 2006 (edited) Well... That's the thing... whoever had it before took it apart. There is not a spring in there. There should be two springs .. one inside the vertical pot and one inside the horizontal pot. * You must take the pot apart to access where the spring goes. Gently bend the tabs out to take the pot apart. * Take a spring out of an early 2600 cart (like Combat) and trim it to fit. You must bend back two "ears" where you clip it to fit. Good Luck! (Other: Spinning Minestorm ship .. that is typically a problem with the Analog to Digital circuit inside the Vectrex.) Rob Mitchell, Atlanta, GA (do note who wrote the disassembly on www.playvectrex.com) Edited May 18, 2006 by Rob Mitchell Quote Link to comment Share on other sites More sharing options...
JB Posted May 18, 2006 Share Posted May 18, 2006 (Other: Spinning Minestorm ship .. that is typically a problem with the Analog to Digital circuit inside the Vectrex.) But if it's genuinely only when a specific controller is hooked up, it would seem to imply a short somewhere in the controller. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 18, 2006 Share Posted May 18, 2006 But if it's genuinely only when a specific controller is hooked up, it would seem to imply a short somewhere in the controller. Oh .. Ok .. Well there are small adjustment pots on the circuit board inside the controller. Maybe the horizontal one could be tweaked while the controller is plugged in? That's where I would start. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
+moycon Posted May 18, 2006 Share Posted May 18, 2006 Anyone know a resource for the joystick? I see Rob mentioned a Radio Shack one worked...is there somewhere online that sells old parts or joysticks like that? Quote Link to comment Share on other sites More sharing options...
Crazy Climber Posted May 18, 2006 Share Posted May 18, 2006 But if it's genuinely only when a specific controller is hooked up, it would seem to imply a short somewhere in the controller. Oh .. Ok .. Well there are small adjustment pots on the circuit board inside the controller. Maybe the horizontal one could be tweaked while the controller is plugged in? That's where I would start. Rob Mitchell, Atlanta, GA Thanks for the tip I will give it a shot. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted May 28, 2006 Share Posted May 28, 2006 Anyone know a resource for the joystick? I see Rob mentioned a Radio Shack one worked...is there somewhere online that sells old parts or joysticks like that? Not that I know of .. The Radio Shack one has pots that do not self-center .. so only the two plastic levers are useful from it. I have one .. so I have two spare levers. What exactly do you need? Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
jasonbar Posted September 16, 2009 Share Posted September 16, 2009 Resurrecting a post from the dead! :] This thread came up in a search I just did when reassembling my Vectrex controller. I had a Vectrex with the vertical spring broken. Rather than harvest one from an Atari cart, I simply got some .020" diameter spring wire from a hobby shop, wrapped it around a screwdriver of the correct size, & trimmed the legs, & installed. Simple! I opened up the working pot & removed the intact torsion spring to use as a reference to be sure that my custom spring was of the correct size & wrap. Hooray! -Jason Quote Link to comment Share on other sites More sharing options...
