crash Posted May 19, 2006 Share Posted May 19, 2006 Greetings, Can anyone advise if the Falcon's Appletalk compatible LAN port (RS-422?) can be adapted to an RS-232 serial port? I've not been able to find an appropriate adapter thus far. Thanks! Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted May 19, 2006 Share Posted May 19, 2006 Isn't the modem port RS-232 or are you trying to equipe your Falcon with two RS-232 ports? Quote Link to comment Share on other sites More sharing options...
crash Posted May 19, 2006 Author Share Posted May 19, 2006 I'm trying to use a program and hardware device that only works on "the other" serial port. I've seen discussion that this LAN port is the second serial port, but I need it to communicate with an RS-232 device. The program will not use the Falcon modem port. Quote Link to comment Share on other sites More sharing options...
krupkaj Posted May 19, 2006 Share Posted May 19, 2006 I have scheme of this adapter on my website http://krupkaj.wz.cz/acm/index.php?submenu...az=cables/LAN-9 Quote Link to comment Share on other sites More sharing options...
jens Posted May 19, 2006 Share Posted May 19, 2006 I'm trying to use a program and hardware device that only works on "the other" serial port. I've seen discussion that this LAN port is the second serial port, but I need it to communicate with an RS-232 device. The program will not use the Falcon modem port. The Falcon modem port is modem2. The Lan port has the same plug as a LocalTalk port but is modem2 as well I think. One can either use one or the other at a time. Quote Link to comment Share on other sites More sharing options...
crash Posted May 19, 2006 Author Share Posted May 19, 2006 Hmmm... I think that what I need is Modem1. Isn't there any way to get a Modem1 out of the Falcon? As for the fine schematic for the adapter cable, krupkaj, do you have one of these working yourself? Thanks! Quote Link to comment Share on other sites More sharing options...
brpocock Posted May 19, 2006 Share Posted May 19, 2006 If it's RS-422 you can buy the cables for ~$15 via e.g. Belkin... I have several of the mDIN varieties as RS-422 mDIN (about 1/2" diameter) are used on SGI and OldWorld Macintoshes, and RS-422 DIN were used on e.g. Apple //c. Quote Link to comment Share on other sites More sharing options...
