Explosive Diarrhea
I added a score to TNT Teddy. So now it's a race to see how many people you can guide across the minefield to the outhouse. Someone forgot to check about the clams. Turns out they weren't good after all. So you have 60 seconds. After you guide one guy, the pattern changes and you have to now quickly navigate through the secret minefield. I had to do a little modifications to the default files to get it all in 2k, but I did, even the little victory tune, the tiny move changing sound, all the stuff from previous versions are still in tact. Here is a picture of the starting screen.
Press fire to start a new game. In previous versions, you could hold down right and keep moving. It's now you have to keep pressing right for each mine spot you want to pass through (every 8 pixels). And if you manage to get to the end of the level and are on the top or bottom of the screen, the guy will move to the center while the tune plays and the timer will stop as it does this (it's only fair. Actually, it did this before I thought it was fair so I kept it in.)
