BillC Posted October 13, 2013 Share Posted October 13, 2013 Hello AtariGeezer, So this ebay number , this hardware connect to PBI port on 600XL and 800XL only ? The ribbon cable is 40 conductor, I think that it plugs into the CPU socket Found information on Atarimax which confirms this: http://www.atarimax.com/freenet/freenet_material/5.8-BitComputersSupportArea/10.ProductReviews/showarticle.php?74 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted October 13, 2013 Share Posted October 13, 2013 The Turbo816 is a 65816 microprocessor that runs at the normal clock speedof the computer. It's meant to be installed in a XL/XE machine, and comeswith a replacement OS. The card measures about 3.5x7", roughly the sizeof two 3.5" disks end to end. On end is a 40 pin ribbon cable which plugsinto the 6502 socket on the motherboard. On the end is a 50 pin connectorfor attaching Turbo-BUS cards, like SRAM memory, PROM application cards,hardware interface cards, blah blah. Quote Link to comment Share on other sites More sharing options...
Tickled_Pink Posted October 13, 2013 Share Posted October 13, 2013 And $54 already. With Lotharek working on an 65816 upgrade, which I can see being cheaper than this item, I can only imagine that people are interested in it for its legendary status and rarity. 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 14, 2013 Share Posted October 14, 2013 David_P, If I remember correctly, the chip on the underside of the Sweet-16 is a GAL type chip, possibly a 22v10. Because of an 'oops' in board layout (that we discovered after the boards were made), that GAL is mounted UPSIDE DOWN with the PINS BENT OVER. Please observe CAUTION if you try to remove and read the GAL, you will most likely blow it if you put it in your device programmer as is. The security fuse is probably blown, but maybe not all of them got done. It was fairly simple logic in there, basically, the 'extra' logic on an old 400/800 CPU board, plus a little tweaking the timing through multiple gates to get it 'just right'. -K Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 14, 2013 Author Share Posted October 14, 2013 Here's a question for you hardware types -- in the approximate center of the board, there are two additional spots for (looks like) 20-pin narrow IC's. These have diagonal jumpers across the pins. Any idea/speculation what this might be for? Got a feeling this baby will go for big $$$. -Larry Quote Link to comment Share on other sites More sharing options...
BillC Posted October 14, 2013 Share Posted October 14, 2013 Here's a question for you hardware types -- in the approximate center of the board, there are two additional spots for (looks like) 20-pin narrow IC's. These have diagonal jumpers across the pins. Any idea/speculation what this might be for? Got a feeling this baby will go for big $$$. -Larry Probably just buffers that were found not to be needed, perhaps the propagation delay even caused problems. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 14, 2013 Share Posted October 14, 2013 Probably just buffers that were found not to be needed, perhaps the propagation delay even caused problems. I agree, from the pattern of jumpers, it looks like 74LS244 or 245. -K Quote Link to comment Share on other sites More sharing options...
