Trebor Posted October 13, 2008 Share Posted October 13, 2008 Donkey Kong needed some more love too: -Trebor Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 13, 2008 Share Posted October 13, 2008 DIG DUG: -Trebor Quote Link to comment Share on other sites More sharing options...
Artlover Posted October 13, 2008 Share Posted October 13, 2008 What's the word on this new palette? Is it the be all end all? I'm about to reissue a7800x with dual preview and movie playback support so I might as well do a palette update while I'm at it. Is there even any issues with the existing palletes in a7800x? So I've been doing an experiment. Comparing screen shots between the EMU7800, the new pallete shots by Mord, and a7800x with both old and new stella pallete's. Using Ms-Pacman and MotorPsycho titles as an example. - EMU7800 - a7800x (Old Stella pallete) - New pallete as taken by Mord - a7800x (New Stella default pallete) So what is the consensus here? How accurate is A7800X default (New Stella) pallete? Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 13, 2008 Share Posted October 13, 2008 So what is the consensus here? How accurate is A7800X default (New Stella) pallete? This is a discussion probably best handled in a separate thread as I believe this pinned one is for the explict purpose of gathering screenshots from the ProSystem emulator. That being said the New Stella palette is better than what is currently implemented in A7800X (Just look at Inky), but not as good as Mord's. The latest palette in Al's post was strickly ripped from a 7800 dumped into Photoshop and fine tuned. The Mord palette is based on the 7800. The New Stella palette is based on the 2600. If I recall correctly the New Stella palette lacks the depth and richness of what a palette from the 7800 can produce. Again, this is probably best in a new/separate thread either in this forum or even the emulation forum. -Trebor Quote Link to comment Share on other sites More sharing options...
Artlover Posted October 14, 2008 Share Posted October 14, 2008 Again, this is probably best in a new/separate thread either in this forum or even the emulation forum. Sorry. The main reason I brought it up here was because I wanted to know if I screen shots taken from a7800x would be accepted in this project. I'll assume no, given your explaination. Quote Link to comment Share on other sites More sharing options...
Shannon Posted October 14, 2008 Share Posted October 14, 2008 So what is the consensus here? How accurate is A7800X default (New Stella) pallete? This is a discussion probably best handled in a separate thread as I believe this pinned one is for the explict purpose of gathering screenshots from the ProSystem emulator. That being said the New Stella palette is better than what is currently implemented in A7800X (Just look at Inky), but not as good as Mord's. The latest palette in Al's post was strickly ripped from a 7800 dumped into Photoshop and fine tuned. The Mord palette is based on the 7800. The New Stella palette is based on the 2600. If I recall correctly the New Stella palette lacks the depth and richness of what a palette from the 7800 can produce. Again, this is probably best in a new/separate thread either in this forum or even the emulation forum. -Trebor You did look at his sample screenshots right? Inky looks fine to me in A7800X. I assume Mord is using the pallette mentioned in message #2? And the one used by Al's has been hand manipulated? Just trying to help. If I release a new a7800x with a correct pallete then people that use it could contribute to this thread. But it seems like you guys are moving at a pretty steady rate anyways. Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 14, 2008 Share Posted October 14, 2008 You did look at his sample screenshots right? Inky looks fine to me in A7800X. I assume Mord is using the pallette mentioned in message #2? And the one used by Al's has been hand manipulated? Just trying to help. If I release a new a7800x with a correct pallete then people that use it could contribute to this thread. But it seems like you guys are moving at a pretty steady rate anyways. Yes, I did look at the screenshots. They show a7800x [Old Stella Palette] which is the last implementation having Inky's color wrong. The proposal for the new a7800x [New Stella Palette] is an improvement, but as I explained, not as good as the alternative. "Al's palette" is the one from Message #2. If Message #2 = "Mord's palette" then they are one and the same. Again, this is another example of why this should be in a separate thread. -Trebor Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 14, 2008 Share Posted October 14, 2008 (edited) CHOPLIFTER! Edited October 14, 2008 by Trebor Quote Link to comment Share on other sites More sharing options...
Shannon Posted October 14, 2008 Share Posted October 14, 2008 Something went wacky with yer choplifter pics there... Quote Link to comment Share on other sites More sharing options...
Albert Posted October 14, 2008 Author Share Posted October 14, 2008 Something went wacky with yer choplifter pics there... Yep, they were there before--there was a duplicate post (which I deleted) and I bet the attachments were actually attached to that post and not the first one. When I deleted the second post (which Trebor had edited to say, "Duplicate Post"), it probably nuked all the attachments. Trebor, can you edit that post and fix the attachments? ..Al Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 14, 2008 Share Posted October 14, 2008 Trebor, can you edit that post and fix the Done Quote Link to comment Share on other sites More sharing options...
Albert Posted October 14, 2008 Author Share Posted October 14, 2008 Trebor, can you edit that post and fix the Done Thanks! ..Al Quote Link to comment Share on other sites More sharing options...
+Mitch Posted October 14, 2008 Share Posted October 14, 2008 Great work guys. I'm going to have to stop playing Super Pac-Man and get a few more done myself. I think we are about 1/4 done now. Mitch Quote Link to comment Share on other sites More sharing options...
Underball Posted October 14, 2008 Share Posted October 14, 2008 What's the word on this new palette? Is it the be all end all? I'm about to reissue a7800x with dual preview and movie playback support so I might as well do a palette update while I'm at it. Is there even any issues with the existing palletes in a7800x? So I've been doing an experiment. Comparing screen shots between the EMU7800, the new pallete shots by Mord, and a7800x with both old and new stella pallete's. Using Ms-Pacman and MotorPsycho titles as an example. - EMU7800 - a7800x (Old Stella pallete) - New pallete as taken by Mord - a7800x (New Stella default pallete) So what is the consensus here? How accurate is A7800X default (New Stella) pallete? The attached is the latest NTSC pallet I created for Prosystem/PSP7800. It is as color-accurate to true NTSC values are going to get. I had posted this in one of my PSP7800 threads last month. NTSC_Final.zip Quote Link to comment Share on other sites More sharing options...
+Mitch Posted October 14, 2008 Share Posted October 14, 2008 The attached is the latest NTSC pallet I created for Prosystem/PSP7800. It is as color-accurate to true NTSC values are going to get. I had posted this in one of my PSP7800 threads last month. That should be the same as the one that is linked at the start of this thread. I don't have time at the moment to verify though. Mitch Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted October 14, 2008 Share Posted October 14, 2008 Great work guys. I'm going to have to stop playing Super Pac-Man and get a few more done myself. I think we are about 1/4 done now. Mitch Speaking of which, the ones for Super Pac-Man are in the first post of that thread Bob Quote Link to comment Share on other sites More sharing options...
Albert Posted October 14, 2008 Author Share Posted October 14, 2008 Great work guys. I'm going to have to stop playing Super Pac-Man and get a few more done myself. I think we are about 1/4 done now. Mitch Speaking of which, the ones for Super Pac-Man are in the first post of that thread Bob Great! Now I just need to add the game to the database! ..Al Quote Link to comment Share on other sites More sharing options...
+Mitch Posted October 14, 2008 Share Posted October 14, 2008 The attached is the latest NTSC pallet I created for Prosystem/PSP7800. It is as color-accurate to true NTSC values are going to get. I had posted this in one of my PSP7800 threads last month. That should be the same as the one that is linked at the start of this thread. I don't have time at the moment to verify though. Mitch I just compared them and they are the same. Mitch Quote Link to comment Share on other sites More sharing options...
+Mitch Posted October 14, 2008 Share Posted October 14, 2008 Great work guys. I'm going to have to stop playing Super Pac-Man and get a few more done myself. I think we are about 1/4 done now. Mitch Speaking of which, the ones for Super Pac-Man are in the first post of that thread Bob Great! Now I just need to add the game to the database! ..Al For that matter Combat 1990 can probably be added to the completed list since those were taken with the new palette. Mitch Quote Link to comment Share on other sites More sharing options...
Albert Posted October 14, 2008 Author Share Posted October 14, 2008 For that matter Combat 1990 can probably be added to the completed list since those were taken with the new palette. Done! ..Al Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 14, 2008 Share Posted October 14, 2008 CENTIPEDE: -Trebor Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 14, 2008 Share Posted October 14, 2008 DONKEY KONG JR. -Trebor Quote Link to comment Share on other sites More sharing options...
Shannon Posted October 14, 2008 Share Posted October 14, 2008 (edited) The attached is the latest NTSC pallet I created for Prosystem/PSP7800. It is as color-accurate to true NTSC values are going to get. I had posted this in one of my PSP7800 threads last month. Shhhh stay on topic!! P.S. That palette was already mentioned earlier on in the thread. Thanks Underball. I'll add that into A7800x when I release it with dual preview. Any preferred name for it? Prosystem New NTSC? Oh and keep up the great work with the screenshots guys. It's nice to see non 2600 sections get updates. Edited October 14, 2008 by Shannon Quote Link to comment Share on other sites More sharing options...
Albert Posted October 15, 2008 Author Share Posted October 15, 2008 Oh and keep up the great work with the screenshots guys. It's nice to see non 2600 sections get updates. Quote Link to comment Share on other sites More sharing options...
Mord Posted October 15, 2008 Share Posted October 15, 2008 "Al's palette" is the one from Message #2. If Message #2 = "Mord's palette" then they are one and the same. Again, this is another example of why this should be in a separate thread. They probably aren't the same when I go over things a bit more. Looks like I was using the default for ProSystem 1.2 for the majority of them, although the only difference seemed to be a brighter red to me in the motor psycho title screen. Regardless, I have time and the energy to retake shots that I've already taken if desired. Al: Let me know if you're willing to update the database with the new ones. I'll drop the ones I retake in zip attachments in a single msg to keep from respamming the thread. Quote Link to comment Share on other sites More sharing options...
