Rybags Posted April 12, 2012 Share Posted April 12, 2012 (edited) A 2 way option for Xex load might be nice - e.g. hold Shift on the Atari and it defaults to standard. Edited April 12, 2012 by Rybags Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2500149 Share on other sites More sharing options...
atarixle Posted April 14, 2012 Share Posted April 14, 2012 Another stupid question - if already answered - ... How do I grant access to my serial device, if Linux declines it? (Ubuntu 12.04 ... in 10.10 it worked out-of-the-box) (Putting on my sysadmin hat) Check the permissions on the serial device. Your user may not belong to the group that can open it. Looks like your user may need to be in the dialout group to use it. Thank you! In german, it's the group "Modem verwenden", I activated, for those who're looking for the right group on german systems. After relogging, it worked on my newly installed debian 6.0.4 64 Bit. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2501265 Share on other sites More sharing options...
atari8warez Posted April 25, 2012 Share Posted April 25, 2012 (edited) Version 0.8.2 is now available (source and binaries) What's new in version 0.8.2 Added multi-session capability. This allows the AspeQt user to invoke multiple instances of AspeQt and use different configurations for each session. Session files were already partly implemented in AspeQt to save/restore mounted disk image groups. This modification takes it further by adding other configuration settings unique to the session. AspeQt normally saves all it's settings to Windows Registry, and restores them from there when it's first launched. With this mod, AspeQt will first examine it's command line to see if a session file was specified, and if it was, then AspeQt will load it's session specific configuration parameters from the given session file. If no session file name was found, then AspeQt will load all of it's settings from Windows Registry as usual. See AspeQt documentation for session specific settings. Updated some icons for consistency across main window menu items Fixed a problem with missing icon in About Dialog Fixed a problem with Text Printer Window menu item icon not displaying properly Fixed a problem with "last session directory" registry entry Changed code to make sure all path separators are cross platform compatible (forward slash) in registry and session files Source and binaries are available at my website and SourceForge as usual. Multi-session capability has been tested by myself to the extent of making sure session files save and load properly and the software behave accordingly, however i have not tested it using more than one Atari connected to the PC in a real life situation. So I appreciate your input on that, please test and let me know. I will also do my own tests as soon as I have another SIO2PC available. For how to use the multi session capability please refer to the documentation file. Edited April 25, 2012 by atari8warez Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2508345 Share on other sites More sharing options...
atarixle Posted April 25, 2012 Share Posted April 25, 2012 Are there some new depencies? diskimageatx.cpp: In member function ‘virtual bool DiskImageAtx::open(const QString&, FileTypes::FileType)’: diskimageatx.cpp:30: error: ‘phantomflip’ was not declared in this scope diskimageatx.cpp: In member function ‘bool DiskImageAtx::seekToSector(quint16)’: diskimageatx.cpp:161: error: ‘phantomflip’ was not declared in this scope diskimageatx.cpp:165: error: ‘phantomflip’ was not declared in this scope diskimageatx.cpp: In member function ‘virtual bool DiskImageAtx::readSector(quint16, QByteArray&)’: diskimageatx.cpp:240: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second: /usr/include/qt4/QtCore/qbytearray.h:456: note: candidate 1: bool QByteRef::operator==(char) const diskimageatx.cpp:240: note: candidate 2: operator==(int, int) <built-in> make: *** [diskimageatx.o] Fehler 1 Same error on Linux aswell as on Mac OS X. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2508643 Share on other sites More sharing options...
atari8warez Posted April 25, 2012 Share Posted April 25, 2012 (edited) None that I know of, but diskimageatx.cpp was written by Krzy so I hope he can comment on this. Code compiles and runs fine in Windows, I have no access to linux or Mac OS X. phantomflip is declared in diskimageatx.h, so I can't make sense of that error message in your post. The other (warning) message also appears in windows. Edited April 25, 2012 by atari8warez Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2508653 Share on other sites More sharing options...
atarixle Posted April 25, 2012 Share Posted April 25, 2012 (edited) May be it's commented out, when compiling somewhere else than Windows? I got to check the sources, but I'm not very good in coding C/C++ ... even if I studied this. EDIT: I don't see any declaration of phantomflip in diskimageatx.h :/ Do I have different sources? downloaded them from your site and from sourceforge Edited April 25, 2012 by atarixle Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2508679 Share on other sites More sharing options...
atari8warez Posted April 25, 2012 Share Posted April 25, 2012 (edited) Ok, seems like the source archive that I uploaded (to SF and my website) have the previous revision (51) of the diskimageatx.h (somehow I missed to update the file in my archive, so next time I am creating the archives from scratch, as this started to happen frequently). SourceForge has the latest source (rev 57) in the SVN area as Turtoise SVN committed the correct version to the repository. Anyway I updated the archives but here's where in diskimageatx.h the missing variable declaration should go if you want a quick fix: struct atx_file { quint16 version; quint32 start; atx_track_header tracks[100]; }; QFile *sourceFile; quint8 count[1040]; quint8 wd1772status; atx_file atx; int lastsector; int phantomflip; }; Edited April 25, 2012 by atari8warez Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2508721 Share on other sites More sharing options...
atari8warez Posted April 26, 2012 Share Posted April 26, 2012 Ok, in between argueing with MG, building hardware and posting pointless messages to Atariage, I was also able to test AspeQt in a multi session environment and happy to report that my preliminary tests with two AspeQt sessions active at the same time (using COM port 1 and 4), serving an Atari 800XL and a 130XE simultaneously were successful. Both AspeQt sessions were set to 3xSIO speed, each copying a disk full of stuff from one drive to another (simultaneously) were at ease with the SIO operation, no errors or timeouts. The PC is a P4 running at 2.4Ghz, the CPU usage was maxing out to 30% at times was normally around %20 during the operation. The two target disks were set to Auto-commit (writing the .atr back to PC drive in real time rather than buffering the changes for later commit). So it looks very promising so far, will do more testing for sure but I am pretty satisfied with my results.... hoping to hear from you guys too... Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2508987 Share on other sites More sharing options...
atarixle Posted April 26, 2012 Share Posted April 26, 2012 (edited) diskimageatx.cpp: In member function ‘virtual bool DiskImageAtx::readSector(quint16, QByteArray&)’: diskimageatx.cpp:240: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second: /usr/include/qt4/QtCore/qbytearray.h:456: note: candidate 1: bool QByteRef::operator==(char) const In Linux (debian, gcc Debian 4.4.5-8 4.4.5), this causes this warning. On Mac OS X (Lion, i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00)), this causes an error and the compiling stops appruptly. Can you make this more ISO-C-ish? Edited April 26, 2012 by atarixle Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509096 Share on other sites More sharing options...
Slor Posted April 26, 2012 Share Posted April 26, 2012 (edited) Hey - thanks for implementing the multisession feature. You can bet I'll be testing it ASAP (since I asked for it). Edited April 26, 2012 by Slor Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509156 Share on other sites More sharing options...
Fox-1 / mnx Posted April 26, 2012 Share Posted April 26, 2012 Did a quick test on my old Intel P2, 400MHz, 384MB, real COM1/COM2 ports, WXP. 2 Instances, mainly just reading data, no problems yet, but like I said, just a quick test. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509166 Share on other sites More sharing options...
atari8warez Posted April 26, 2012 Share Posted April 26, 2012 Hey - thanks for implementing the multisession feature. You can bet I'll be testing it ASAP (since I asked for it). You're welcome J. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509173 Share on other sites More sharing options...
atari8warez Posted April 26, 2012 Share Posted April 26, 2012 Did a quick test on my old Intel P2, 400MHz, 384MB, real COM1/COM2 ports, WXP. 2 Instances, mainly just reading data, no problems yet, but like I said, just a quick test. Sounds great, I wish someone with an older machine can try it like a 386/286. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509182 Share on other sites More sharing options...
atari8warez Posted April 26, 2012 Share Posted April 26, 2012 diskimageatx.cpp: In member function ‘virtual bool DiskImageAtx::readSector(quint16, QByteArray&)’: diskimageatx.cpp:240: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second: /usr/include/qt4/QtCore/qbytearray.h:456: note: candidate 1: bool QByteRef::operator==(char) const In Linux (debian, gcc Debian 4.4.5-8 4.4.5), this causes this warning. On Mac OS X (Lion, i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00)), this causes an error and the compiling stops appruptly. Can you make this more ISO-C-ish? Yeah this happens on Windows too, although the compliation does not stop as it's only a warning. The code isn't mine but I will check to see what I can do with it. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509202 Share on other sites More sharing options...
w1k Posted April 26, 2012 Share Posted April 26, 2012 do aspeqt support R: device? Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509256 Share on other sites More sharing options...
greblus Posted April 26, 2012 Share Posted April 26, 2012 (edited) In order to compile rev. 57 on Linux (g++ 4.7) I had to add #include <unistd.h> to serialport-unix.h, otherwise I got lots of "'::close' '::read' '::write' was not declared" errors. I don't know why it compiled cleanly before, possibly unistd.h was included somewhere else. Edited April 26, 2012 by greblus Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509314 Share on other sites More sharing options...
atari8warez Posted April 27, 2012 Share Posted April 27, 2012 do aspeqt support R: device? Not yet. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509427 Share on other sites More sharing options...
atari8warez Posted April 27, 2012 Share Posted April 27, 2012 In order to compile rev. 57 on Linux (g++ 4.7) I had to add #include <unistd.h> to serialport-unix.h, otherwise I got lots of "'::close' '::read' '::write' was not declared" errors. I don't know why it compiled cleanly before, possibly unistd.h was included somewhere else. Hmm, good question, I'll add that. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2509432 Share on other sites More sharing options...
a8isa1 Posted May 23, 2012 Share Posted May 23, 2012 (edited) I'd like to make some requests (hopefully not previously mentioned). - Make XEX boot persistent for the session - Command line switches with any options provided overriding the stored settings. Perhaps have the overrides default to temporary (i.e. for the session only) with the choice to make them permanent One more request is more of a novelty. -XEP80 simulation. Obviously this cannot be an emulation as XEP80 is connected via game ports. XEP80 control sequences would be sent via SIO instead. Edited May 23, 2012 by a8isa1 Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2527865 Share on other sites More sharing options...
+JAC! Posted May 23, 2012 Share Posted May 23, 2012 Make XEX boot persistent for the session Good occasion to renew my previous suggestion for this: Please just have a single "Insert into Drive" button which let's you browser and select Images, Folders and XEX files just the same way. Sample applies to Drag & Drop of couse. Just "Insert" whatever is dropped and keep it. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2527879 Share on other sites More sharing options...
Rybags Posted May 23, 2012 Share Posted May 23, 2012 Persistent Xex boot mightn't be totally feasible - it's a "concocted" type of operation where Aspeqt depends on guaranteed behaviour from the loader, ie if the Atari asked for unexpected sector #s it'd probably confuse the whole thing. Maybe a "repeat previous boot" type of operation would work well. e.g. once the operation completes, put a dialog with "OK" and "Repeat" buttons on it. Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2527981 Share on other sites More sharing options...
atari8warez Posted May 23, 2012 Share Posted May 23, 2012 (edited) Guys I wish I had the time to tackle all of these requests, currently I am improving upon the remote module (AspeCl) of AspeQt. Adding some more remote commands. In fact I will be releasing some of the development effort tonight. For the requests, I am not ignoring them, just need some more time in between software/hardware projects and now construction work in my home I have to complete ASAP. What could I have done if I had a full-time daytime job Edited May 23, 2012 by atari8warez Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2527989 Share on other sites More sharing options...
atari8warez Posted May 23, 2012 Share Posted May 23, 2012 (edited) Make XEX boot persistent for the session Good occasion to renew my previous suggestion for this: Please just have a single "Insert into Drive" button which let's you browser and select Images, Folders and XEX files just the same way. Sample applies to Drag & Drop of couse. Just "Insert" whatever is dropped and keep it. Could you please expand on this a bit more. Where do you exactly want to see that button, how is it different from the existing Disk/Mount menu option or the Mount button that is already there (well other than being a button of course). Drag and drop feature was never fully implemented, it is one of my objectives to get to it too, but I will need to learn more about AspeQt, QT, and various Atari disk formats in general to dive into that deep pool :-) Edited May 23, 2012 by atari8warez Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2527994 Share on other sites More sharing options...
atari8warez Posted May 23, 2012 Share Posted May 23, 2012 (edited) I'd like to make some requests (hopefully not previously mentioned). - Make XEX boot persistent for the session - Command line switches with any options provided overriding the stored settings. Perhaps have the overrides default to temporary (i.e. for the session only) with the choice to make them permanent One more request is more of a novelty. -XEP80 simulation. Obviously this cannot be an emulation as XEP80 is connected via game ports. XEP80 control sequences would be sent via SIO instead. Have to check XEX boot request to see what's involved and/or whether it's feasible. (Rybag's suggestion might be easy to implement) Currently the only command line option available is for specifying a session file name. Session files can be duplicated and edited manually (Notepad) as they are straight text files. This would be a quick and dirty temporary solution until other command line switches are implemented. XEP80 simulation/emulation is currently way over my head timewise and XEP80 knowledgewise Edited May 23, 2012 by atari8warez Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2527997 Share on other sites More sharing options...
+Stephen Posted May 23, 2012 Share Posted May 23, 2012 How would XEP80 stuff even work? Nothing expects it over SIO - what could possibly use it? Quote Link to comment https://forums.atariage.com/topic/154949-aspeqt-yet-another-sio2pcape-clone/page/14/#findComment-2528002 Share on other sites More sharing options...
