senior_falcon Posted December 1, 2019 Share Posted December 1, 2019 On 11/28/2019 at 2:36 PM, RXB said: As you can see the code is the same in TI INTERN as my code in RXB 2015, error? (where?) XB amd TI BASIC use the scratchpad in different ways. Maybe there is a memory conflict somewhere in the scratchpad? Quote Link to comment Share on other sites More sharing options...
RXB Posted December 1, 2019 Share Posted December 1, 2019 13 hours ago, senior_falcon said: XB amd TI BASIC use the scratchpad in different ways. Maybe there is a memory conflict somewhere in the scratchpad? Hmmm the locations are exactly the same use, >8378 Random location same, >834A FAC the same, >8310 VAR5 the same so what SCRATCH PAD address is different? I guess I could change VAR5 to another address but this is the first time any problems have ever cropped up. Are you sure the problem is not your Assembly program? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 1, 2019 Share Posted December 1, 2019 (edited) 2 hours ago, RXB said: Are you sure the problem is not your Assembly program? It works with regular XB and does not work with the random number generator in RXB. (edit) An example of different locations is the "insert" flag. This is at >8363 in TI BASIC and >8364 in XB Edited December 1, 2019 by senior_falcon Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 1, 2019 Share Posted December 1, 2019 Maybe this would be helpful for you. I have attached RNDTESTXB which is an XB program that has a simple assembly routine that prints a random number on the screen. The assembly routine is called this way: CALL LINK("RANDOM",N) where N is a number from 0 to 9. The number is converted to an integer and printed on the screen at R23,C3. In TIXB you can pass a random number (RND*9) and it is printed on the screen. RXB cannot do this but gives a "subprogram not found" message. The assembly program: DEF RANDOM WKSP BSS 32 RANDOM LWPI WKSP CLR R0 LI R1,1 BLWP @NUMREF BLWP @XMLLNK DATA >12B8 CFI MOVB @FAC+1,R1 AI R1,>9000 CONVERT TO ASCII PLUS OFFSET LI R0,>02C2 BOTTOM OF SCREEN BLWP @VSBW LWPI >83E0 B @>006A And the XB program: 10 CALL INIT :: CALL LOAD(8192,255,172):: CALL LINK("X") (this is a SYSTEX like loader to put the assembly routine into low memory) 20 CALL LINK("RANDOM",RND*9) 30 PRINT 40 GOTO 20 RNDTESTXB.zip Quote Link to comment Share on other sites More sharing options...
RXB Posted December 2, 2019 Share Posted December 2, 2019 (edited) 20 hours ago, senior_falcon said: Maybe this would be helpful for you. I have attached RNDTESTXB which is an XB program that has a simple assembly routine that prints a random number on the screen. The assembly routine is called this way: CALL LINK("RANDOM",N) where N is a number from 0 to 9. The number is converted to an integer and printed on the screen at R23,C3. In TIXB you can pass a random number (RND*9) and it is printed on the screen. RXB cannot do this but gives a "subprogram not found" message. The assembly program: DEF RANDOM WKSP BSS 32 RANDOM LWPI WKSP CLR R0 LI R1,1 BLWP @NUMREF BLWP @XMLLNK DATA >12B8 CFI MOVB @FAC+1,R1 AI R1,>9000 CONVERT TO ASCII PLUS OFFSET LI R0,>02C2 BOTTOM OF SCREEN BLWP @VSBW LWPI >83E0 B @>006A And the XB program: 10 CALL INIT :: CALL LOAD(8192,255,172):: CALL LINK("X") (this is a SYSTEX like loader to put the assembly routine into low memory) 20 CALL LINK("RANDOM",RND*9) 30 PRINT 40 GOTO 20 RNDTESTXB.zip 371 B · 2 downloads XB CALL INIT has NUMREF and uses >8310 and my RND does same as TI Basic. Where is the name "RANDOM" for CALL LINK loaded as I do not see it put into low memory? I see a CALL LINK("X") but RXB has had issues with SYSTEX before as they use hard coded GPL address that only works with XB and fails with others XB's. I suspect the SYSTEX loader never put the program into memory, hence gives a "subprogram not found" message. Edited December 2, 2019 by RXB spelling error Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 2, 2019 Share Posted December 2, 2019 3 hours ago, RXB said: XB CALL INIT has NUMREF and uses >8310 and my RND does same as TI Basic. Where is the name "RANDOM" for CALL LINK loaded as I do not see it put into low memory? I see a CALL LINK("X") but RXB has had issues with SYSTEX before as they use hard coded GPL address that only works with XB and fails with others XB's. I suspect the SYSTEX loader never put the program into memory, hence gives a "subprogram not found" message. This is not systex. It is my own loader similar to systex. There are no hard coded addresses. Run the program. You'll get the error "subprogram not found" in line 20. Use Classic99's debugger to take a look into low memory. Look at >2002 and >2004. They should be >2540 and >3FF8. This shows the xb routine was loaded. Look at >3FF8 and you will see "RANDOM", also indicating that the program was loaded. If you really want to be sure the program is loaded you can open up Classic99 and select XB and open up a second Classic99 and select RXB. Compare the code from >24F4 to >2540. It should be the same. I suppose the file might have been corrupted when I made the zip file, but I doubt it. The "subprogram not found" is a red herring. At times passing a random number leads to a crash with the usual colorful graphics on the screen. Quote Link to comment Share on other sites More sharing options...
RXB Posted December 3, 2019 Share Posted December 3, 2019 On 12/1/2019 at 11:32 AM, senior_falcon said: It works with regular XB and does not work with the random number generator in RXB. (edit) An example of different locations is the "insert" flag. This is at >8363 in TI BASIC and >8364 in XB Hmmm that is not a PERMANENT FLAG, it is a temporary flag. [1806] 6C3A 8E,64 VALIZ9 CZ @ARG8 INSERT mode? [1807] 6C3C 6C,91 BS G6C91 [1808] * INSERT - is COMPLICATED!!!!! Because of those edge charac [1809] * Shift up all things. . . . continue as a standard insert [1810] * VARA <= ARG2 [1811] 6C3E D5,2A,5E DCEQ @ARG2,@VARA If end of screen [1812] 6C41 6C,68 BS READZ4 [1813] *---------------------------------------------------------- [1814] * Fix Editing a line that has been retrived by the REDO key [1815] * and may garble the last few characters bug, 5/28/81 [1816] 6C43 D6,B0,2A CEQ EDGECH,V*VARA If at end of line 6C46 7F [1817] 6C47 4C,68 BR READZ4 [1818] 6C49 D7,2A,02 DCEQ >02FE,@VARA If also at end of screen 6C4C FE [1819] 6C4D 4C,64 BR G6C64 [1820] 6C4F 0F,83 XML SCROLL Scroll the screen [1821] 6C51 A7,20,00 DSUB 32,@VARW Back up line start address 6C54 20 [1822] 6C55 A7,2A,00 DSUB 28,@VARA Back up to current start line 6C58 1C [1823] 6C59 A7,5E,00 DSUB 32,@ARG2 Absolute high limit backs up 6C5C 20 [1824] 6C5D A7,61,00 DSUB 32,@ARG5 Current cursor position too 6C60 20 [1825] 6C61 05,6C,68 B READZ4 [1826] 6C64 A3,2A,00 G6C64 DADD 4,@VARA Skip to next line 6C67 04 [1827] *---------------------------------------------------------- [1828] 6C68 BD,5C,2A READZ4 DST @VARA,@ARG Use ARG as temp for insert [1829] 6C6B C5,5C,61 G6C6B DCH @ARG5,@ARG Move everything up to current [1830] * line [1831] 6C6E 4C,8A BR G6C8A [1832] 6C70 93,5C DDEC @ARG Copy lower location to higher [1833] 6C72 BC,E0,01 ST V*ARG,V@1(@ARG) Going from high to low 6C75 5C,B0,5C [1834] 6C78 D6,B0,5C CEQ EDGECH,V*ARG Bumped into wall again 6C7B 7F [1835] 6C7C 4C,88 BR G6C88 [1836] 6C7E A7,5C,00 DSUB 4,@ARG Skip the wall 6C81 04 [1837] 6C82 BC,E0,05 ST V*ARG,V@5(@ARG) And move character over 6C85 5C,B0,5C [1838] 6C88 4C,6B G6C88 BR G6C6B 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0035 EDIT-359 [1839] 6C8A C9,2A,5E G6C8A DCHE @ARG2,@VARA Only update VARA if upper [1840] 6C8D 6C,91 BS G6C91 [1841] 6C8F 91,2A DINC @VARA hasn't been reached yet [1842] 6C91 A2,75,60 G6C91 ADD OFFSET,@RKEY Create displayable character [1843] 6C94 BC,B0,61 ST @RKEY,V*ARG5 Display at current character 6C97 75 [1844] * position [1845] 6C98 86,60 CLR @ARG4 Indicate change in line [1846] 6C9A D5,61,5E READ05 DCEQ @ARG2,@ARG5 Hit right margin [1847] 6C9D 4C,AD BR G6CAD [1848] 6C9F 8E,A3,74 CZ V@NOTONE If not the first time [1849] 6CA2 6C,A7 BS G6CA7 [1850] 6CA4 06,00,34 CALL TONE1 ---BEEP--- [1851] 6CA7 BE,A3,74 G6CA7 ST >FF,V@NOTONE Set the flag 6CAA FF [1852] 6CAB 4A,A8 BR READZ1 Stay in current mode !!!! [1853] 6CAD 91,61 G6CAD DINC @ARG5 Update current address [1854] 6CAF D6,B0,61 CEQ EDGECH,V*ARG5 Correct for next line 6CB2 7F [1855] 6CB3 4C,B9 BR G6CB9 [1856] 6CB5 A3,61,00 DADD 4,@ARG5 By skipping border 6CB8 04 [1857] 6CB9 C5,61,2A G6CB9 DCH @VARA,@ARG5 Check for last new high limit [1858] 6CBC 4C,C1 BR G6CC1 [1859] 6CBE BD,2A,61 DST @ARG5,@VARA Update new high limit [1860] 6CC1 CB,2A,02 G6CC1 DCHE >02FE,@VARA Still some space to go 6CC4 FE [1861] 6CC5 4A,A8 BR READZ1 [1862] 6CC7 0F,83 XML SCROLL Scroll the screen!!! [1863] 6CC9 A7,2A,00 DSUB 28,@VARA Back to current start of line 6CCC 1C [1864] 6CCD 8E,64 CZ @ARG8 If not insert mode then [1865] 6CCF 6C,D5 BS G6CD5 [1866] 6CD1 A7,2A,00 DSUB 4,@VARA Off by 4 more-correct it 6CD4 04 [1867] 6CD5 A7,20,00 G6CD5 DSUB 32,@VARW Backup line start address 6CD8 20 [1868] 6CD9 A7,5E,00 DSUB 32,@ARG2 Absolute high limit backs up 6CDC 20 [1869] 6CDD A7,61,00 DSUB 32,@ARG5 Current cursor position too 6CE0 20 [1870] 6CE1 4A,A8 BR READZ1 Start with something else [1871] * Using it like a permanent flag is just wrong, ARG has many uses so making the claim this is a permanent flag is just incorrect. [0183] * ARG EQU >835C Floating-point ARGument [0184] 835D ARG1 EQU ARG+1 [0185] 835E ARG2 EQU ARG+2 [0186] 835F ARG3 EQU ARG+3 [0187] 8360 ARG4 EQU ARG+4 [0188] 8361 ARG5 EQU ARG+5 [0189] 8362 ARG6 EQU ARG+6 [0190] 8363 ARG7 EQU ARG+7 [0191] 8364 ARG8 EQU ARG+8 [0192] 8364 XSTLN EQU >8364 GKXB variable [0193] 8366 XENLN EQU >8366 GKXB variable 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0004 EQUATES EDIT-359 [0194] 8367 ARG11 EQU ARG+11 [0195] 8368 XCURLI EQU >8368 GKXB variable [0196] 836A XCURIN EQU >836A GKXB variable [0197] 836B ARG15 EQU ARG+15 [0198] 836C ARG16 EQU ARG+16 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 3, 2019 Share Posted December 3, 2019 (edited) 20 hours ago, senior_falcon said: This is not systex. It is my own loader similar to systex. There are no hard coded addresses. Run the program. You'll get the error "subprogram not found" in line 20. Use Classic99's debugger to take a look into low memory. Look at >2002 and >2004. They should be >2540 and >3FF8. This shows the xb routine was loaded. Look at >3FF8 and you will see "RANDOM", also indicating that the program was loaded. If you really want to be sure the program is loaded you can open up Classic99 and select XB and open up a second Classic99 and select RXB. Compare the code from >24F4 to >2540. It should be the same. I suppose the file might have been corrupted when I made the zip file, but I doubt it. The "subprogram not found" is a red herring. At times passing a random number leads to a crash with the usual colorful graphics on the screen. Hmm I may have the answer.... See original XB and other others all load way to many bytes into Lower 8K thus was a chunk of memory as they later reduced the CALL INIT routines for more space later. But they never changed the GPL code for loading that Assembly into lower 8K for support. which includes a lot of junk. When I saw this in the notes off to side of GPL code loader for CALL INIT I decided to fix this overlooked error. (They never fixed it in time for version 110 but noted error.) Now I had to return the same values to >2002 and >2004 even though loading junk bytes from GPL to that area does not take place in since RXB 2000 (People complained about that area was not the same, even though XB uses a FIXED LOAD ADDRESS not a RELOCATABLE that seems a odd complaint to me.) So instead I zeroed out >24EA to >3FFF in RXB instead of loading all that junk from GPL that was never used, after all it was being written over by loading. If you fire up Classic99 and check RXB after CALL INIT vs XB after CALL INIT you will see that difference. I try to fix what I can but baked in stupid is hard to fix, very hard for me to say broken, so just gotta love it. Just wondering what is going on as when RXB uses CALL INIT it zeros out lower 8K, which would make more sense then leaving all the junk there? (I mean INIT means INITIALIZE not just load this stuff.) in·i·tial·ize /iˈniSHəˌlīz/ Learn to pronounce verb COMPUTING 1. set to the value or put in the condition appropriate to the start of an operation. "the counter is initialized to one" 2. format (a computer disk). Edited December 3, 2019 by RXB Added Text. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 3, 2019 Share Posted December 3, 2019 55 minutes ago, RXB said: Hmm I may have the answer.... What was the question? Quote Link to comment Share on other sites More sharing options...
+9640News Posted December 3, 2019 Share Posted December 3, 2019 5 minutes ago, senior_falcon said: What was the question? Which came first, the chicken or the egg? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 3, 2019 Share Posted December 3, 2019 Try to run RNDTESTXB but replace 'RND*9' in line 20 with just '9'. It works fine. Then put 'RND*9' back in and you get "SubProgram not found in 20". 2 Quote Link to comment Share on other sites More sharing options...
1980gamer Posted December 4, 2019 Share Posted December 4, 2019 8 hours ago, BeeryMiller said: Which came first, the chicken or the egg? The Rooster 1 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 4, 2019 Share Posted December 4, 2019 18 hours ago, Asmusr said: Try to run RNDTESTXB but replace 'RND*9' in line 20 with just '9'. It works fine. Then put 'RND*9' back in and you get "SubProgram not found in 20". The main difference between original RND in XB and RXB is the stupid number of Floating Point instructions and assembly used to just make a random number. Also why it is insanely slow for that very reason, this is why XB RND is crazy slow. This is from RXB 2001 GPL source and is exactly the same as XB. <0215> * Initialize random number generator <0216> A28D 31,00,0A INTRND MOVE 10,G@X2SEED,V@RNDX2 A290 A3,A0,A2 A293 95 <0217> A294 00 RTN <0218> A295 42,03,23 X2SEED BYTE >42,>03,>23,>15,>00 * = 33521, X2 INITIAL VAL A298 15,00 <0219> A29A 43,02,3E X1SEED BYTE >43,>02,>3E,>2A,>17 * = 2624223, X1 INITIAL VAL A29D 2A,17 <0220> *********************************************************** <0221> * PSEUDO-RANDOM NUMBER GENERATOR <0222> * X(N+1) = (A*X(N)+C) MOD M; RND = X/M 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0016 EQUATES EXEC-359 <0223> * WHERE: X = X2 * 1E7 + X1 <0224> * A = A2 * 1E7 + A1 <0225> * C = C2 * 1E7 + C1 <0226> * M = 1E14 <0227> * ASSUMPTIONS: <0228> * (1) All numbers are integers; fractional parts are <0229> * truncated <0230> * (2) If the variables listed below start in the ranges <0231> * specified. They will also end in the ranges specified <0232> * <0233> * CONSTANTS: 0 <= A2 < 5E6 ; 0 <= C2 < 1E7 <0234> * 0 <= A1 < 5E6 ; 0 <= C1 < 1E7 <0235> * VARIABLES: 0 <= X2 < 1E7 ; 0 <= T1 <= 1E14 ; 0 <= T2 < 1E <0236> * 0 <= X1 < 1E7 ; 0 <= T3 <= 1E14 ; 0 <= T4 < 1E <0237> * <0238> * STACK USAGE: <0239> * CONSTANT REFS CONTANT REFS CONTANT REF <0240> * +---------+ IN/OUT IN/OUT IN/OUT <0241> * | STACK+4 | X2*A1(F)(H) -- ---- -- ---- <0242> * +---------+ <0243> * | STACK+3 | T2 (C)(J) -- ---- -- ---- <0244> * +---------+ <0245> * | STACK+2 | T1 (B)(D) new X1 (E)(N) -- ---- <0246> * +---------+ <0247> * | STACK+1 |old X1(A)(G) T3 (K)(L) new X2 (M)(P) <0248> * +---------+ <0249> *********************************************************** <0250> * COMPUTE NEW VALUE FOR X1, SAVE IT IN V@RNDX1 <0251> * STACK <0252> * SREFS FAC CONTENTS <0253> A29F 35,00,05 NRND MOVE 5,V@RNDX1,@FAC FAC = X1 A2A2 4A,A3,A5 <0254> A2A5 86,4F CLR @FAC5 FAC = CLR <0255> A2A7 87,50 DCLR @FAC6 FAC = CLR <0256> A2A9 0F,77 XML VPUSH (A) FAC = X1 <0257> A2AB 31,00,08 MOVE 8,G@RNDA1,@ARG ARG = A1 A2AE 5C,A3,57 <0258> A2B1 0F,08 XML FMUL FAC = X1*A1 <0259> A2B3 31,00,08 MOVE 8,G@RNDC1,@ARG ARG = C1 A2B6 5C,A3,67 <0260> A2B9 0F,06 XML FADD T1=FAC = X1*A1+C1 <0261> A2BB 0F,77 XML VPUSH (B) FAC = T1 <0262> A2BD 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A2C0 5C,A3,77 <0263> A2C3 0F,08 XML FMUL FAC = T1/1E7 <0264> A2C5 06,00,22 CALL GRINT T2=FAC = INT(T1/1E7) <0265> A2C8 0F,77 XML VPUSH (C) FAC = T2 <0266> A2CA 31,00,08 MOVE 8,G@RNDEP,@ARG ARG = 1E7 A2CD 5C,A3,6F <0267> A2D0 0F,08 XML FMUL FAC = T2*1E7 <0268> A2D2 A7,6E,00 DSUB 8,@VSPTR A2D5 08 <0269> A2D6 0F,0C XML SSUB (D) X1=FAC = T1-T2*1E7 <0270> A2D8 35,00,05 MOVE 5,@FAC,V@RNDX1 FAC = X1 (new) A2DB A3,A5,4A <0271> A2DE 0F,77 XML VPUSH (E) FAC = X1 <0272> * COMPUTE NEW VALUE FOR X2, SAVE IT IN V@RNDX2 <0273> A2E0 35,00,05 MOVE 5,V@RNDX2,@FAC FAC = X2 A2E3 4A,A3,A0 <0274> A2E6 86,4F CLR @FAC5 FAC = CLR <0275> A2E8 87,50 DCLR @FAC6 FAC = CLR <0276> A2EA 31,00,08 MOVE 8,G@RNDA1,@ARG ARG = A1 A2ED 5C,A3,57 <0277> A2F0 0F,08 XML FMUL FAC = X2*A1 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0017 EQUATES EXEC-359 <0278> A2F2 A3,6E,00 DADD 8,@VSPTR A2F5 08 <0279> A2F6 0F,77 XML VPUSH (F) FAC = X2*A1 <0280> A2F8 A7,6E,00 DSUB 24,@VSPTR A2FB 18 <0281> A2FC 0F,78 XML VPOP (G) FAC = X1 <0282> A2FE A3,6E,00 DADD 32,@VSPTR A301 20 <0283> A302 31,00,08 MOVE 8,G@RNDA2,@ARG ARG = A2 A305 5C,A3,4F <0284> A308 0F,08 XML FMUL FAC = X1*A2 <0285> A30A 0F,0B XML SADD (H) FAC = X2*A1+X1*A2 <0286> A30C 31,00,08 MOVE 8,G@RNDC2,@ARG ARG = C2 A30F 5C,A3,5F <0287> A312 0F,06 XML FADD FAC = X2*A1+X1*A2 <0288> A314 0F,0B XML SADD (J) T3=FAC = X2*A1+X1*A2 <0289> A316 A7,6E,00 DSUB 16,@VSPTR A319 10 <0290> A31A 0F,77 XML VPUSH (K) FAC = T3 <0291> A31C 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A31F 5C,A3,77 <0292> A322 0F,08 XML FMUL FAC = T3/1E7 <0293> A324 06,00,22 CALL GRINT T4=FAC = INT(T3/1E7) <0294> A327 31,00,08 MOVE 8,G@RNDEP,@ARG ARG = 1E7 A32A 5C,A3,6F <0295> A32D 0F,08 XML FMUL FAC = T4*1E7 <0296> A32F 0F,0C XML SSUB (L) X2=FAC = T3-T4*1E7 <0297> A331 35,00,05 MOVE 5,@FAC,V@RNDX2 FAC = X2 (new) A334 A3,A0,4A <0298> * COMPUTE NEW VALUE FOR RND, LEAVE IT IN FAC <0299> A337 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A33A 5C,A3,77 <0300> A33D 0F,08 XML FMUL FAC = X2/1E7 <0301> A33F 0F,77 XML VPUSH (M) FAC = X2/1E7 <0302> A341 A3,6E,00 DADD 8,@VSPTR A344 08 <0303> A345 0F,78 XML VPOP (N) FAC = X1 <0304> A347 0F,08 XML FMUL FAC = X1/1E7 <0305> A349 0F,08 XML FMUL FAC = X1/1E14 <0306> A34B 0F,0B XML SADD (P)RND=FAC = (X2/1E7)+(X1/1E14) <0307> A34D 0F,75 XML CONT [0008] *********************************************************** Starting to wonder if VSPTR (Value Stack Pointer needs to be reset as it is looking like CALL LINK is expecting something different on STACK hence why "subprogram not found" as a value can not be found on stack as what ever on stack is not in proper place. As RXB 2015 does not mess with stack at all this would point to the problem in CALL LINK has the issue. Will have to look over CALL LINK to see what is going on in stack. Quote Link to comment Share on other sites More sharing options...
RXB Posted December 4, 2019 Share Posted December 4, 2019 (edited) So here is CALL LINK from XB and RXB 2015 that are exactly the same: <0001> *********************************************************** <0002> * LINK INSTRUCTION : SE Sep 1980 <0003> *********************************************************** <0004> * FORMAT: <0005> * CALL LINK("file-name",parameter1,parameter2,...) <0006> * <0007> * LINK ROUTINE READS THE FILE NAME SPECIFIED BY THE USER A <0008> * SAVE THE ADDRESS OF THE NAME FOR LATER USE. THE FILE WIL <0009> * BE SEARCHED IN UTILITY CODE LATER ON. <0010> * <0011> * PARAMETERS ARE PASSED EITHER BY REFERENCE OR BY VALUE. <0012> * NUMERIC OR STRING VARIABLES AND NUMERIC OR STRING ARRAYS <0013> * ARE PASSED BY REFERENCE AND ALL OTHERS INCLUDING A USER <0014> * DEFINED FUNCTION ARE PASSED BY VALUE. <0015> * <0016> * PARAMETER INFORMATION IS STORED IN CPU >8300 THROUGH >83 <0017> * THAT GIVES A PARAMETER TYPE CODE OF EACH PARAMETER. <0018> * CODE 0 ... Numeric expression <0019> * CODE 1 ... String experession <0020> * CODE 2 ... Numeric variable <0021> * CODE 3 ... String variable <0022> * CODE 4 ... Numeric array <0023> * CODE 5 ... String array <0024> * <0025> * IF A PARAMETER IS PASSED AS A NUMERIC EXPRESSION ITSL <0026> * ACTUAL VALUE GETS PUSHED INTO THE VALUE STACK. IN CASE O <0027> * A STRING EXPRESSION , ITS VALUE STACK CONTAINS AN ID(>65 <0028> * POINTER TO THE VALUE SPACE AND ITS LENGTH. IF A PARAMETE <0029> * GETS PASSED AS A REFERENCE THE PRODUCT OF XML SYM AND XM <0030> * SMB IN THE @FAC AREA GETS PUSHED INTO STACK. <0031> * <0032> * AFTER AN ASSEMBLY LANGUAGE SUBPROGRAM IS EXECUTED LINK <0033> * ROUTINE WILL POP THE STACK TO GET RID OF PARAMETER <0034> * INFORMATION. CONTROL WILL BE TRANSFERED TO THE XB MAIN <0035> * PROGRAM AFTERWARDS. <0036> * <0037> *********************************************************** <0038> * CALL LINK program <0039> *********************************************************** <0040> C325 06,C1,EB LINKIT CALL CHKIN Check if INIT has been called <0041> C328 BD,10,6E DST @VSPTR,@OLDS Save VSPTR for later use <0042> C32B D6,42,B7 CEQ LPARZ,@CHAT Check for "(" <0043> C32E 45,33 BR ERRSYN <0044> C330 0F,79 XML PGMCHR Advance program pointer <0045> C332 0F,74 XML PARSE Get the routine name. <0046> C334 B6 BYTE RPARZ * Read up to ")" <0047> C335 D6,4C,65 CEQ >65,@FAC2 Should be a string <0048> C338 45,9A BR ERRBA 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0021 EQUATES ALCS-359 <0049> C33A 8F,50 DCZ @FAC6 Don't accept null string <0050> C33C 65,9A BS ERRBA <0051> C33E C6,51,06 CH 6,@FAC7 Should be less then 6 char <0052> C341 65,9A BS ERRBA <0053> C343 0F,77 XML VPUSH Push to make it semi-permanen <0054> C345 86,12 CLR @COUNT Initialize parameter counter <0055> *********************************************************** <0056> * PARAMETERS get evaluated here <0057> *********************************************************** <0058> C347 D6,42,B6 PAR01 CEQ RPARZ,@CHAT No arg. So execute it <0059> C34A 64,05 BS EXE01 <0060> C34C D6,42,B3 CEQ COMMAZ,@CHAT Should have a comma <0061> C34F 45,33 BR ERRSYN <0062> C351 BD,22,2C DST @PGMPTR,@ERRCOD Save text pointer <0063> C354 0F,79 XML PGMCHR Get the character <0064> C356 CA,42,80 CHE >80,@CHAT Must be an expression <0065> C359 63,C7 BS VAL01 <0066> * If CHAT = LPARZ then pass by expression <0067> C35B 06,C4,2C CALL CLRFAC Clear FAC entry for SYM <0068> C35E 0F,7A XML SYM Read in the symbol table info <0069> * After XML SYM @FAC area contains a pointer to symbo table <0070> * Below statement checks if it is a UDF. <0071> C360 DA,B0,4A CLOG >40,V*FAC Pass by value C363 40 <0072> C364 43,C7 BR VAL01 <0073> C366 D6,42,B3 CEQ COMMAZ,@CHAT Pass by reference <0074> C369 63,E5 BS REF01 <0075> C36B D6,42,B6 CEQ RPARZ,@CHAT Pass by reference <0076> C36E 63,E5 BS REF01 <0077> C370 D6,42,B7 CEQ LPARZ,@CHAT An array <0078> C373 63,7C BS ARRAY <0079> C375 CA,42,80 CHE >80,@CHAT Pass by value <0080> C378 63,C7 BS VAL01 <0081> C37A 45,33 BR ERRSYN <0082> *********************************************************** <0083> * ARRAY case gets checked here <0084> *********************************************************** <0085> * Should look like A(,,) etc. <0086> * Stack entry for an array will look like <0087> * +--------------+-------+---+-------------+--------------- <0088> * | Pointer to | >00 | | Pointer to | <0089> * | symbol table | or | | dim info in | <0090> * | entry | >65 | | real v.s. | <0091> * +- FAC --------+ FAC2 -+---+- FAC4 ------+- FAC6 -------- <0092> * <0093> C37C 0F,79 ARRAY XML PGMCHR Get the next character <0094> C37E D6,42,B6 CEQ RPARZ,@CHAT Pass by reference <0095> C381 63,8F BS ARRAY2 <0096> C383 D6,42,B3 CEQ COMMAZ,@CHAT More array information <0097> C386 63,7C BS ARRAY <0098> C388 93,2C DDEC @PGMPTR Adjust the pointer <0099> C38A BE,42,B7 ST LPARZ,@CHAT <0100> C38D 43,E5 BR REF01 Pass by reference <0101> * In array cases the symbol table address gets stored at FA <0102> * area, and the pointer to the value space (dimension info) <0103> * goes into FAC4 <0104> C38F 0F,79 ARRAY2 XML PGMCHR Advance the program pointer <0105> C391 DA,B0,4A CLOG >80,V*FAC Test string bit C394 80 <0106> C395 43,9D BR GC39D <0107> C397 BE,90,12 ST 4,*COUNT Numeric array C39A 04 <0108> C39B 43,A1 BR GC3A1 <0109> C39D BE,90,12 GC39D ST 5,*COUNT String array case 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0022 EQUATES ALCS-359 C3A0 05 <0110> * Check if array is being shared. If it is then go back <0111> * through the linkage to get the actuals symbol table <0112> * pointer. Put the pointer to the value space (dimension in <0113> * into FAC4. <0114> C3A1 DA,B0,4A GC3A1 CLOG >20,V*FAC Shared array? C3A4 20 <0115> C3A5 63,BE BS GC3BE <0116> C3A7 35,00,02 MOVE 2,V@6(@FAC),@FAC4 If so, get pointer C3AA 4E,E0,06 C3AD 4A <0117> C3AE DA,EF,FF CLOG >20,V@-6(@FAC4) Shared also? C3B1 FA,4E,20 <0118> C3B4 63,BC BS GC3BC <0119> C3B6 35,00,02 MOVE 2,V*FAC4,@FAC4 Array is not shared C3B9 4E,B0,4E <0120> C3BC 43,C5 GC3BC BR GC3C5 <0121> C3BE BD,4E,4A GC3BE DST @FAC,@FAC4 Array is not shared <0122> C3C1 A3,4E,00 DADD 6,@FAC4 Point to value space C3C4 06 <0123> C3C5 43,FA GC3C5 BR PUSH <0124> *********************************************************** <0125> * VALUE <0126> * Passing the parameter by value <0127> *********************************************************** <0128> C3C7 BD,2C,22 VAL01 DST @ERRCOD,@PGMPTR Restore program pointer <0129> C3CA 0F,79 XML PGMCHR Skip the first character <0130> C3CC BD,16,0C DST @BYTES,@TEMP In case of passing a string <0131> C3CF 0F,74 XML PARSE Parsing up to comma <0132> C3D1 B6 BYTE RPARZ <0133> C3D2 BD,0C,16 DST @TEMP,@BYTES Restore the value in >0C area <0134> * After parsing @FAC area contains its actual numeric value <0135> * in a numeric case, and the following information in a <0136> * string case. <0137> * +----------------+-----+--+------------+----------------- <0138> * | >001C or | >65 | | Pointer to | Length of string <0139> * | value pointer | | | string | string <0140> * | address | | | | <0141> * +- FAC ----------+-FAC2+--+-FAC4 ------+- FAC6 ---------- <0142> * <0143> C3D5 CE,4C,63 CGT >63,@FAC2 If more then 99 then <0144> C3D8 43,E0 BR GC3E0 <0145> C3DA BE,90,12 ST 1,*COUNT Store flag for string express C3DD 01 <0146> C3DE 43,E3 BR GC3E3 <0147> C3E0 86,90,12 GC3E0 CLR *COUNT Otherwise it is a numeric exp <0148> C3E3 43,FA GC3E3 BR PUSH Push into stack <0149> *********************************************************** <0150> * REFERENCE <0151> * Passing the parameter by reference <0152> *********************************************************** <0153> * Variables, array element and whole array passing. <0154> * <0155> * After SMB @FAC entry shold look like; <0156> * +--------------+------+-----+-------------+-------------- <0157> * | Pointer to | >00 | | Pointer to | <0158> * | symbol table | | | value space | <0159> * | entry | | | | <0160> * +-- FAC -------+ FAC2 +-----+- FAC4 ------+- FAC6 ------- <0161> * for numeric case, and <0162> * +--------------+------+-----+-------------+-------------- <0163> * | Pointer to | >65 | | Pointer to | String <0164> * | value space | | | string | length <0165> * | entry | | | | 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0023 EQUATES ALCS-359 <0166> * +- FAC --------+ FAC2 +-----+- FAC4 ------+- FAC6 ------- <0167> * for a string case. <0168> C3E5 0F,7B REF01 XML SMB Get the location <0169> C3E7 CA,42,B8 CHE >B8,@CHAT Pass array expression <0170> C3EA 63,C7 BS VAL01 <0171> C3EC 8E,4C CZ @FAC2 <0172> C3EE 43,F6 BR GC3F6 <0173> C3F0 BE,90,12 ST 2,*COUNT Must be a numeric variable C3F3 02 <0174> C3F4 43,FA BR PUSH <0175> C3F6 BE,90,12 GC3F6 ST 3,*COUNT Must be a string variable C3F9 03 <0176> *********************************************************** <0177> * PUSH routine <0178> * Pushes @FAC entry into a value stack. <0179> *********************************************************** <0180> C3FA 90,12 PUSH INC @COUNT <0181> C3FC CE,12,10 CGT 16,@COUNT Too many parameters <0182> C3FF 65,9A BS ERRBA <0183> C401 0F,77 XML VPUSH <0184> C403 43,47 BR PAR01 Get the next argument. <0185> *********************************************************** <0186> * EXECUTE routine <0187> * Restore file name info transfer control over to ALC <0188> *********************************************************** <0189> C405 BE,4A,20 EXE01 ST >20,@FAC Store blank in the FAC area. <0190> C408 35,00,05 MOVE 5,@FAC,@FAC1 C40B 4B,4A <0191> C40D 35,00,04 MOVE 4,V@12(@OLDS),@STORE Get the file name info C410 14,E0,0C C413 10 <0192> C414 34,16,4A MOVE @STORE+2,V*STORE,@FAC Move to FAC C417 B0,14 <0193> C419 87,22 DCLR @ERRCOD Clear program pointer for <0194> * error code <0195> C41B 0F,20 XML ALSUP Go to CPU at >2000 to execute <0196> C41D 64,C9 BS ERROR Error found <0197> * If no error, start checking s <0198> *********************************************************** <0199> * RETURN to the XB main program. <0200> *********************************************************** <0201> C41F C5,6E,10 NOERR DCH @OLDS,@VSPTR Pop the stack <0202> C422 44,29 BR GC429 <0203> C424 0F,78 XML VPOP Pop the stack <0204> C426 05,C4,1F B NOERR <0205> C429 05,A0,1C GC429 B LNKRTN Check ")" and end of statemen <0206> *********************************************************** <0207> * SUBROUTINES used in this file. <0208> *********************************************************** <0209> C42C 86,4A CLRFAC CLR @FAC <0210> C42E 35,00,07 MOVE 7,@FAC,@FAC1 C431 4B,4A <0211> C433 00 RTN <0212> *********************************************************** So it appears RXB 2015 RND subprogram stack value is not set up for CALL LINK as it is expecting a reset Value Stack and Subprogram Stack. Looking at NOERR you can see this where we end up with "no subprogram found" as previously XML SYM crashed as the stack value is not set. It also appears that old XB RND leaves a Floating Point Number in FAC so this is going to delay RXB 2020 by some time digging into why. Currently RND in RXB 2015 also leaves a Floating Point Number in FAC but what symbol being pushed on stack is in question. Edited December 4, 2019 by RXB Added Text. 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 9, 2019 Share Posted December 9, 2019 (edited) I can't help but think this is caused by some difference in how TI BASIC uses the scratchpad and how XB uses it. Maybe the RND routine uses a memory location that is safe for BASIC but not safe when running in XB? Edited December 9, 2019 by senior_falcon Quote Link to comment Share on other sites More sharing options...
RXB Posted December 9, 2019 Share Posted December 9, 2019 11 hours ago, senior_falcon said: I can't help but think this is caused by some difference in how TI BASIC uses the scratchpad and how XB uses it. Maybe the RND routine uses a memory location that is safe for BASIC but not safe when running in XB? Both TI Basic and XB used exactly the same exact scratchpad locations. The only real difference is original XB used a butt load of Assembly to do what TI Basic does faster using GPL instead. I suspect the issue remains PARSE that looks at the command for statements within the CALL LINK routine i,e. CALL LINK("name",RND*9) I am curious if X=RND :: CALL LINK("name",X*9) does not crash this would prove 100% that this is the problem. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 9, 2019 Share Posted December 9, 2019 (edited) 43 minutes ago, RXB said: I am curious if X=RND :: CALL LINK("name",X*9) does not crash this would prove 100% that this is the problem. I am quite sure this will behave correctly. There only seems to be a problem when there is an RND in the argument list. Edited December 9, 2019 by senior_falcon 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 12, 2019 Share Posted December 12, 2019 On 12/9/2019 at 8:26 AM, senior_falcon said: I am quite sure this will behave correctly. There only seems to be a problem when there is an RND in the argument list. Yea I need to research why TI Basic is not doing something the XB requires, it has to be the VDP STACK or PARSE as nothing else makes sense. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 27, 2019 Share Posted December 27, 2019 One of the things that has kept me from using RXB is that I am not very fond of the lower case font that is used, and I really don't like the cursor. When I see that cursor I can't wait to exit RXB. I don't know why this is so, but it is. Anyway, I have been playing around with making a few modifications to standard XB. I have become fairly comfortable with the process, although it is still a bit of a struggle. With my new knowledge, I decided to try modifying the font and cursor used in RXB to ones that I like better. Attached are the results. There are two versions of RXB, both modified from RXB 2015 that is part of Classic99. RXBF1 uses the font from XB2.7. Gazoo felt this was the perfect font for XB, and it does have a lot going for it. RXBF2 uses a font I like even better. But some don't like this because a lowercase letter can touch a capital letter that is below it. (By the way, this font saves about 370 bytes of GROM, and I am sure Rich could find a good use for this extra memory.) Now you have a choice. Give these a try and pick your favorite from the original or the two new ones. RXB2FONTS.zip 6 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 28, 2019 Share Posted December 28, 2019 Yea I just hate fonts that overlap and interfere with lower lines of text it just looks terrible. I also totally hate the TI cursor of a single solid block as it just looks lazy and like 1950's Computer tech. Gazoo tried to get me to using his Font but my above reasons above were not negotiable. (I never told him what to do, so why boss me around?) If the font and Cursor you can change this with a simple GPL modification using a HEX EDITOR on the Classic99 file or use the GPL Source I include and you can change it. Or load your own from a XB program. I'll look at your Fonts. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 28, 2019 Share Posted December 28, 2019 That's why cars come in so many different colors! 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 29, 2019 Share Posted December 29, 2019 CALL FONT? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 29, 2019 Share Posted December 29, 2019 Or maybe: CALL LOADFONT() and CALL SAVEFONT(). (Made sense in Forth) Quote Link to comment Share on other sites More sharing options...
RXB Posted December 29, 2019 Share Posted December 29, 2019 (edited) 15 hours ago, Tursi said: CALL FONT? I do not have much space left in RXB to load other fonts, they take up a insane amount of GPL space. A single XB program can do the same thing or like I previously posted you can use RXB source to load your own set of fonts. Or you can just edit the area where fonts are and make your own up and install them for yourself. Edited December 29, 2019 by RXB Added Text. Quote Link to comment Share on other sites More sharing options...
MikeV Posted January 2, 2020 Share Posted January 2, 2020 Is this the RXB users Forum? Quote Link to comment Share on other sites More sharing options...
