MikeV Posted November 22, 2020 Share Posted November 22, 2020 On 10/10/2020 at 5:43 PM, RXB said: RXB 2020 DOCUMENTS ARE DONE, HERE IS PREVIEW: RXBDOCS.pdf 6.23 MB · 28 downloads Hi Rich, Thank you for the manual. Am I correct in presuming that BLOAD/ BSAVE will be incompatible with RXB 2020 and replaced by PLOAD/ PSAVE? 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 22, 2020 Share Posted November 22, 2020 (edited) 2 hours ago, MikeV said: Hi Rich, Thank you for the manual. Am I correct in presuming that BLOAD/ BSAVE will be incompatible with RXB 2020 and replaced by PLOAD/ PSAVE? Yea sorry that is sadly true. As the new PLOAD/PSAVE can load into any memory area of 32K and the old BLOAD/BSAVE would only work with the LOWER 8K Assembly area. Additionally the new PLOAD/PSAVE uses 4K pages while the old BLOAD/BSAVE was using 8K pages. SAMS switches memory in 4K pages so it just made more sense to use one 4K page vs one 8K page that would require 2 SAMS 4K pages. Edited November 22, 2020 by RXB 1 Quote Link to comment Share on other sites More sharing options...
MikeV Posted November 23, 2020 Share Posted November 23, 2020 17 hours ago, RXB said: Yea sorry that is sadly true. As the new PLOAD/PSAVE can load into any memory area of 32K and the old BLOAD/BSAVE would only work with the LOWER 8K Assembly area. Additionally the new PLOAD/PSAVE uses 4K pages while the old BLOAD/BSAVE was using 8K pages. SAMS switches memory in 4K pages so it just made more sense to use one 4K page vs one 8K page that would require 2 SAMS 4K pages. OK, got it. Will adapt to the new version when available. Thanks for the clarification. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 30, 2020 Share Posted November 30, 2020 Making a new game Strictly for RXB 2020 also updated RXB 2015 game IN THE DARK. Currently new RXB game has 16000 4K pages loaded into SAMS in Classic99. (62.5 Meg game) Of course will have to make a smaller 1Meg version for game, but wanted to make a full on max version too. This game is not IN THE DARK, it is a new one. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 30, 2020 Share Posted November 30, 2020 Wow! 4 hours ago, RXB said: Making a new game Strictly for RXB 2020 also updated RXB 2015 game IN THE DARK. Currently new RXB game has 16000 4K pages loaded into SAMS in Classic99. (62.5 Meg game) Of course will have to make a smaller 1Meg version for game, but wanted to make a full on max version too. This game is not IN THE DARK, it is a new one. I bet that takes a while to load up. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 1, 2020 Share Posted December 1, 2020 1 hour ago, TheBF said: Wow! I bet that takes a while to load up. Working on a better loader, then again only works on Classic99. The 1Meg version should be about 2 minutes to load from SCSI drives or less in RAMDISK. 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 1, 2020 Share Posted December 1, 2020 (edited) Ok made a RXB program to make a map into 8000 pages of SAMS and put it on disk for Classic99 To load all 8000 pages took 1 hour 28 minutes, so much better then I had originally thought it would take to work. That is after all using Overdrive in Classic99 and loading 8000 4K pages into SAMS from Disk. Spoiler 100 OPEN #1:"CLOCK" 110 INPUT #1:A$,B$,C$ 120 PRINT A$:B$:C$ 130 FOR P=1 TO 8000 140 CALL SAMS(2,P+16) 150 CALL PLOAD(2,"DSK6.PAGE"&STR$(P)) 160 NEXT P 170 INPUT #1:A$,B$,C$ 180 PRINT A$:B$:C$ Just so you know that is about 32 Meg of files. Edited December 1, 2020 by RXB 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 2, 2020 Share Posted December 2, 2020 If you do some math each 4K page has 5 screens with 768 characters per screen. So 5x768=3840 characters per 4K so 8192 Pages of 4K would be 31457280 characters total for entire map. So the entire map is 15728640 x 15728640 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 2, 2020 Share Posted December 2, 2020 17 hours ago, RXB said: Ok made a RXB program to make a map into 8000 pages of SAMS and put it on disk for Classic99 To load all 8000 pages took 1 hour 28 minutes, so much better then I had originally thought it would take to work. That is after all using Overdrive in Classic99 and loading 8000 4K pages into SAMS from Disk. Reveal hidden contents 100 OPEN #1:"CLOCK" 110 INPUT #1:A$,B$,C$ 120 PRINT A$:B$:C$ 130 FOR P=1 TO 8000 140 CALL SAMS(2,P+16) 150 CALL PLOAD(2,"DSK6.PAGE"&STR$(P)) 160 NEXT P 170 INPUT #1:A$,B$,C$ 180 PRINT A$:B$:C$ Just so you know that is about 32 Meg of files. This kind of thing was where I realized there are some practical limitations to giving our favourite computer virtually un-limited memory. It is not the speediest little beast in the forest and just running through all that memory to load it up or heaven forbid erase it, takes a long time. It's still pretty cool that you actually can do a 32MB load in RXB. ?? 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 2, 2020 Share Posted December 2, 2020 (edited) 2 hours ago, TheBF said: This kind of thing was where I realized there are some practical limitations to giving our favorite computer virtually un-limited memory. It is not the speediest little beast in the forest and just running through all that memory to load it up or heaven forbid erase it, takes a long time. It's still pretty cool that you actually can do a 32MB load in RXB. ?? Well YEA! Right now I have 8 Classic99 running at same time all on OVERDRIVE making 8192 maps to same drive. Each instance of Classic99 is making 1000 files with 5 maps per file, you know 0 to 1000, 1000 to 2000, 2000 to 3000 and so on. I wanted to be first person to make the biggest game or app for TI99/4A ever. If Tursi made a SAMS file to installer for Classic99 we would see more uses of this cool feature, of course with real TI it would take days. (Better never turn it off or lose all installed SAMS! LOL!) P.S. Good reason to make a battery backed SAMS! Edited December 2, 2020 by RXB 1 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 3, 2020 Share Posted December 3, 2020 2020 12 02 RXB running 12 screens in Classic99 all at OVERDRIVE! - YouTube 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 16, 2020 Share Posted December 16, 2020 RELEASE OF RXB 2020 TO PUBLIC: RXB 2020.zip 10 5 Quote Link to comment Share on other sites More sharing options...
DavidC Posted December 16, 2020 Share Posted December 16, 2020 AWESOME!!! 1 Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted December 16, 2020 Share Posted December 16, 2020 1 hour ago, RXB said: RELEASE OF RXB 2020 TO PUBLIC: RXB 2020.zip 14.43 MB · 9 downloads Really been looking forward to this. Thank you for all your hard work on it! 1 2 Quote Link to comment Share on other sites More sharing options...
Astharot Posted December 16, 2020 Share Posted December 16, 2020 Like if one create a rxb2020 suite similar at xb2.7 suite for ubergrom... 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 16, 2020 Share Posted December 16, 2020 2 minutes ago, Astharot said: Like if one create a rxb2020 suite similar at xb2.7 suite for ubergrom... Yea that is a goal I have this next year. 3 Quote Link to comment Share on other sites More sharing options...
oddemann Posted December 16, 2020 Share Posted December 16, 2020 Could you do a demo of RXB2020... on Youtube? - What is new. - What is different from Basic and Ex Basic - Demonstrate different programs. From small to big ones. - Converting Basic/EX Basic to RXA. - Speed difference if any. - What are smart use of RXB compared to "normal" programming. - And what other tings is it that others are wondering about??? I think that if you do a broad (short and to the point) presentation of RXB, you will get more people to use your program. I have seen a YT where you did a lot of explaining of ram and a lot around that, for me it is over my head. I want to know WHY I should use RXB and what is great about it, from a programming stand point that dos not know that much. And you showing of you great RXB. Maybe that is what people want to know... But I think it would be good with a "low tech" show off of RXB Now you have to sell RXB2020 :p So that I want to transition from EX B to RXB hehehe Back in the day I learned Basic and Ex Basic... and I need "motivation" to change into something new. Hmmm, maybe I am getting old :p hehehe Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 16, 2020 Share Posted December 16, 2020 The MAME rpk of RXB 2020. rxb_2020.rpk 6 1 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted December 16, 2020 Share Posted December 16, 2020 4 hours ago, RXB said: RELEASE OF RXB 2020 TO PUBLIC: RXB 2020.zip 14.43 MB · 16 downloads 1 1 Quote Link to comment Share on other sites More sharing options...
DavidC Posted December 17, 2020 Share Posted December 17, 2020 3 hours ago, mizapf said: The MAME rpk of RXB 2020. rxb_2020.rpk 39.15 kB · 9 downloads Thank you @RXB and Thank you @mizapf 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 17, 2020 Share Posted December 17, 2020 On 12/16/2020 at 2:10 PM, oddemann said: Could you do a demo of RXB2020... on Youtube? - What is new. - What is different from Basic and Ex Basic - Demonstrate different programs. From small to big ones. - Converting Basic/EX Basic to RXA. - Speed difference if any. - What are smart use of RXB compared to "normal" programming. - And what other tings is it that others are wondering about??? I think that if you do a broad (short and to the point) presentation of RXB, you will get more people to use your program. I have seen a YT where you did a lot of explaining of ram and a lot around that, for me it is over my head. I want to know WHY I should use RXB and what is great about it, from a programming stand point that dos not know that much. And you showing of you great RXB. Maybe that is what people want to know... But I think it would be good with a "low tech" show off of RXB Now you have to sell RXB2020 ? So that I want to transition from EX B to RXB hehehe Back in the day I learned Basic and Ex Basic... and I need "motivation" to change into something new. Hmmm, maybe I am getting old ? hehehe Ok first of more Video on RXB 2020: 2 Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted December 18, 2020 Share Posted December 18, 2020 Thanks for doing the video Rich! I like the part with the size command. Also watched your other video with the pload / SAMS stuff. ? 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 18, 2020 Share Posted December 18, 2020 53 minutes ago, retroclouds said: Thanks for doing the video Rich! I like the part with the size command. Also watched your other video with the pload / SAMS stuff. ? LOL yea I spaced out and was looking at RAM not VDP changes in video. Quote Link to comment Share on other sites More sharing options...
MikeV Posted December 18, 2020 Share Posted December 18, 2020 On 12/16/2020 at 2:41 PM, RXB said: RELEASE OF RXB 2020 TO PUBLIC: Thank you for this! 1 Quote Link to comment Share on other sites More sharing options...
MikeV Posted December 18, 2020 Share Posted December 18, 2020 21 hours ago, RXB said: Ok first of more Video on RXB 2020: Good video. That CALL IO has been a bit of a puzzle to me; the example (chimes) helped. Hope to see some more in the future. 1 Quote Link to comment Share on other sites More sharing options...
