mrvan Posted April 8 Share Posted April 8 Hopefully I'm not overdoing my welcome here, with all my questions. All the examples I have for EA5 programs use BL @main in the crt_eas5.asm file. Is it possible, to launch EA5 apps in XB (2.9) with CALL MLOAD and return to XB? Or how should I build GCC apps such that they can be run from inside the XB env and return? When I write XB programs and compile, I receive an OBJ output file that I can readily link into an EA5 or another version that XB recognizes as an XB program and can use CALL RUN. Sorry I don't know what that latter type is called. When using GCC I have an object file, but it is in ELF format. I can't help but wonder if most folks using GCC stick mostly to cartridges to take advantage of the more usable space (cartridge address space + RAM). 32KB isn't much to contain both program and data. I also read somewhere and can't find another reference about some cartridge type that could map in multiple ROMs. Can someone point me to that format? Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted April 9 Share Posted April 9 30 minutes ago, mrvan said: Hopefully I'm not overdoing my welcome here, with all my questions. All the examples I have for EA5 programs use BL @main in the crt_eas5.asm file. Is it possible, to launch EA5 apps in XB (2.9) with CALL MLOAD and return to XB? Or how should I build GCC apps such that they can be run from inside the XB env and return? When I write XB programs and compile, I receive an OBJ output file that I can readily link into an EA5 or another version that XB recognizes as an XB program and can use CALL RUN. Sorry I don't know what that latter type is called. When using GCC I have an object file, but it is in ELF format. I can't help but wonder if most folks using GCC stick mostly to cartridges to take advantage of the more usable space (cartridge address space + RAM). 32KB isn't much to contain both program and data. I also read somewhere and can't find another reference about some cartridge type that could map in multiple ROMs. Can someone point me to that format? I have examples of utilizing vast cartridge ROM and SAMS ram, but they are not beginner friendly, for accessing all the cartridge banking, and even SAMS ram bank switching. My approach changes the way you write the code... https://github.com/jedimatt42/fcmd As for using gcc to build overlays to work with the XB 2.9 environment, it's a little bit of a chocolate and peanut-butter issue... it may end up great, but those with the necessary knowledge aren't likely to bump into each other. Coercing the elf binary into an XB friendly loadable module might be do-able. But I'm guessing you'd have to spec out what CALL MLOAD does for us before we could help. Texas Instrument's CALL LOAD handles their uncompressed tag object format... It also stashes addresses into a link table so CALL LINK can find them by name. I would imagine to build some interoperability with any variant of XB, you would have to write a custom entry point ( usually what the crt variants provide ) that makes sure your code gets loaded where it needs to be, and when your C function is returned from, returns to XB correctly. I don't actually know what XB (2.9) is, but if this is XB GEM, I hear that returning correctly is a bespoke issue. I would expect, that in order to get far enough along to build interoperable components between GCC and any XB, you will have learned enough 4A assembly to just do XB and assembly, or learned enough of the 4A architecture to realize that you can do the stuff that XB makes look easy, pretty easy in C. 1 Quote Link to comment Share on other sites More sharing options...
mrvan Posted April 9 Share Posted April 9 12 hours ago, jedimatt42 said: I have examples of utilizing vast cartridge ROM and SAMS ram, but they are not beginner friendly, for accessing all the cartridge banking, and even SAMS ram bank switching. My approach changes the way you write the code... https://github.com/jedimatt42/fcmd As for using gcc to build overlays to work with the XB 2.9 environment, it's a little bit of a chocolate and peanut-butter issue... it may end up great, but those with the necessary knowledge aren't likely to bump into each other. Coercing the elf binary into an XB friendly loadable module might be do-able. But I'm guessing you'd have to spec out what CALL MLOAD does for us before we could help. Texas Instrument's CALL LOAD handles their uncompressed tag object format... It also stashes addresses into a link table so CALL LINK can find them by name. I would imagine to build some interoperability with any variant of XB, you would have to write a custom entry point ( usually what the crt variants provide ) that makes sure your code gets loaded where it needs to be, and when your C function is returned from, returns to XB correctly. I don't actually know what XB (2.9) is, but if this is XB GEM, I hear that returning correctly is a bespoke issue. I would expect, that in order to get far enough along to build interoperable components between GCC and any XB, you will have learned enough 4A assembly to just do XB and assembly, or learned enough of the 4A architecture to realize that you can do the stuff that XB makes look easy, pretty easy in C. Thanks jedimatt42. I've started reviewing your code and it does provide insight into quite a bit. I definitely have more learning to go. And yes, I imagine the experts in such details are few and far between with the small number of folks that dare to step back 40+ years into the past for these machines. Quote Link to comment Share on other sites More sharing options...
mrvan Posted April 12 Share Posted April 12 On 4/8/2023 at 5:32 PM, jedimatt42 said: I have examples of utilizing vast cartridge ROM and SAMS ram, but they are not beginner friendly, for accessing all the cartridge banking, and even SAMS ram bank switching. My approach changes the way you write the code... https://github.com/jedimatt42/fcmd As for using gcc to build overlays to work with the XB 2.9 environment, it's a little bit of a chocolate and peanut-butter issue... it may end up great, but those with the necessary knowledge aren't likely to bump into each other. Coercing the elf binary into an XB friendly loadable module might be do-able. But I'm guessing you'd have to spec out what CALL MLOAD does for us before we could help. Texas Instrument's CALL LOAD handles their uncompressed tag object format... It also stashes addresses into a link table so CALL LINK can find them by name. I would imagine to build some interoperability with any variant of XB, you would have to write a custom entry point ( usually what the crt variants provide ) that makes sure your code gets loaded where it needs to be, and when your C function is returned from, returns to XB correctly. I don't actually know what XB (2.9) is, but if this is XB GEM, I hear that returning correctly is a bespoke issue. I would expect, that in order to get far enough along to build interoperable components between GCC and any XB, you will have learned enough 4A assembly to just do XB and assembly, or learned enough of the 4A architecture to realize that you can do the stuff that XB makes look easy, pretty easy in C. I'm working my way through things... Hi jedditmatt42, I'm still on my quest to figure out full type support provided with this GCC compiler, and was looking for the source for libgcc in particular. I found your extremely simple to follow instructions for building GCC in Linux at https://github-wiki-see.page/m/jedimatt42/fcmd/wiki/tms9900gcc-Ubuntu-Installation-Guide. I can confirm they still work as of Ubuntu 22.04, and on ARM64 (a new Mac M2 Max) in Parallels Desktop, with the following updates: In build/binutils-2.19.1/config.guess, duplicate the lines 964-966, place immediately after, and change the new switch condition from x86_64 to aarch64. Same change in build/gcc-4.4.0/config.guess, duplicate the lines 980-882 and make the same change as before. I may eventually dare to attempt installation directly in MacOS, but will save that for another day. 3 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted April 15 Share Posted April 15 @mrvan I have not tried, yet to build @EtchedPixels compiler but I am pretty sure it must be possible to build it and use to compile something. At lest this is what @EtchedPixels has reported. If I remember well @EtchedPixels compiler is spread across 3 GitHub repositories. So the build process requires some extra work.@EtchedPixelscould you please write some simple instructions ? or, even better, maybe put everything into a single repository ? Quote Link to comment Share on other sites More sharing options...
mrvan Posted April 15 Share Posted April 15 4 hours ago, Fabrizio Caruso said: @mrvan I have not tried, yet to build @EtchedPixels compiler but I am pretty sure it must be possible to build it and use to compile something. At lest this is what @EtchedPixels has reported. If I remember well @EtchedPixels compiler is spread across 3 GitHub repositories. So the build process requires some extra work.@EtchedPixelscould you please write some simple instructions ? or, even better, maybe put everything into a single repository ? Thank you, Fabrizio Caruso. I'm managing to get by with GCC, with its many limitations. But it is C, and for that I am very thankful. Even in that, I'm busily adding methods that are normally part of libgcc, to support longs, floats and doubles. Quote Link to comment Share on other sites More sharing options...
mrvan Posted April 15 Share Posted April 15 Can anyone point me to how I can call the GROM methods for math from GCC? I've bothered to implement C methods for atol, atof, add for long/ulong/double, but read these may be implemented in the console GROM. There still may be an issue even if I use the GROM methods, at least for doubles, as the GCC compiler generates incorrect RADIX 100 formats for double literals (I've studied the format and printed the hex)--for instance 1.0 generates 0x3F 0x01 0x00... if I recall, rather than 0x40 0x01, 0x00... Also several violations of the mantissa values being over 99. I might be able to fix the GCC compiler, but have not gotten too deep into understanding its details, beyond learning about the GCC library, which is related but separate. This may end up on my list, unless the other C compiler proves to be superior. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted April 15 Share Posted April 15 1 hour ago, mrvan said: Can anyone point me to how I can call the GROM methods for math from GCC? I've bothered to implement C methods for atol, atof, add for long/ulong/double, but read these may be implemented in the console GROM. There still may be an issue even if I use the GROM methods, at least for doubles, as the GCC compiler generates incorrect RADIX 100 formats for double literals (I've studied the format and printed the hex)--for instance 1.0 generates 0x3F 0x01 0x00... if I recall, rather than 0x40 0x01, 0x00... Also several violations of the mantissa values being over 99. I might be able to fix the GCC compiler, but have not gotten too deep into understanding its details, beyond learning about the GCC library, which is related but separate. This may end up on my list, unless the other C compiler proves to be superior. I call one of the routines here for the builtin float to int: https://github.com/jedimatt42/fcmd/blob/a4e2ad136eb0d3b2d33b67e644d8ac3417becc94/b2_tifloat.c#L55 The input parameter was the address of the TI float data. The address of the routines can be found in the TI Intern. For the float to int, there was no benefit in using the XMLLNK overhead. I did not examine the other routines. I've had no use for actual floats. Float arithmetic is a choice, and usually sub-optimal unless you need to show a result as a float. 1 Quote Link to comment Share on other sites More sharing options...
mrvan Posted April 16 Share Posted April 16 7 hours ago, jedimatt42 said: I call one of the routines here for the builtin float to int: https://github.com/jedimatt42/fcmd/blob/a4e2ad136eb0d3b2d33b67e644d8ac3417becc94/b2_tifloat.c#L55 The input parameter was the address of the TI float data. The address of the routines can be found in the TI Intern. For the float to int, there was no benefit in using the XMLLNK overhead. I did not examine the other routines. I've had no use for actual floats. Float arithmetic is a choice, and usually sub-optimal unless you need to show a result as a float. Awesome, thank you! I found this guide at https://www.unige.ch/medecine/nouspikel/ti99/reals.htm. Your example provides just enough detail that I can find my way between this doc and your code. I'll still have to determine how to get to the GROM methods. I need to spend a bit more time looking over this link and your code. Quote Link to comment Share on other sites More sharing options...
mrvan Posted April 17 Share Posted April 17 On 4/15/2023 at 3:06 PM, jedimatt42 said: I call one of the routines here for the builtin float to int: https://github.com/jedimatt42/fcmd/blob/a4e2ad136eb0d3b2d33b67e644d8ac3417becc94/b2_tifloat.c#L55 The input parameter was the address of the TI float data. The address of the routines can be found in the TI Intern. For the float to int, there was no benefit in using the XMLLNK overhead. I did not examine the other routines. I've had no use for actual floats. Float arithmetic is a choice, and usually sub-optimal unless you need to show a result as a float. Thanks jedimatt42. I was able to modify to perform a floating point (double) add. 2 Quote Link to comment Share on other sites More sharing options...
mrvan Posted May 18 Share Posted May 18 Hi all, I've continued my trek with GCC, and am having a very nice time. I found some of insomnia's floating point work and a decent amount of standard C and asm library methods which I presume he also wrote. Some is incomplete but easily recognized and excludable--I sure wish he'd return. I want a relatively full featured C99 environment. So I've written stdio's fopen, fputs, fgets and fclose, wrapping the DSR calls with a thin veneer. I'll work all the others later as they are variations, and these are sufficient for my immediate needs. I expected it to be more difficult as the DSR routines are somewhat cryptic but found enough hints in jeddimatt42's repository. My next somewhat obvious step, is to add stdin, stdout, and stderr and then that leads to special files. I don't and won't have /dev/* as in *nix, so have thought to just define reasonable names for pio, rs232, etc., as TI did in XB. stdout is easily mapped calling conio*(), and similar for stdin. Next is the parallel port...that's where I'm getting stuck. I have a const char *s as input to a method and then have: p = (char *) s; while (*p) { rs232_writePIO (RS232_ALT_CARD, *p); p++; } No write to the parallel port. I've also tried RS232_CARD as well, no go. Any thoughts as to what the issue may be, or perhaps you might know of an example that works? If it matters, I'm using MAME and have the parallel port mapped to output to a file. I've used PIO in XB successfully so know it works in my configuration. My program is an EA5 that I start in XB with call mload(). Thank you in advance, mrvan Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 18 Share Posted May 18 I am probably missing something but if you have fopen, fputs, fgets and fclose working with files via the DSR now, then you should be able to fopen "PIO" and use fputs to send data to it shouldn't you? If you want to write your own driver then you need CRU functions to enable the card. Assembler is probably best for that. Sample programs are here: www.unige.ch/medecine/nouspikel/ti99/rs232c.htm 1 Quote Link to comment Share on other sites More sharing options...
mrvan Posted May 18 Share Posted May 18 3 hours ago, TheBF said: I am probably missing something but if you have fopen, fputs, fgets and fclose working with files via the DSR now, then you should be able to fopen "PIO" and use fputs to send data to it shouldn't you? If you want to write your own driver then you need CRU functions to enable the card. Assembler is probably best for that. Sample programs are here: www.unige.ch/medecine/nouspikel/ti99/ Hi TheBF, yes, I thought the DSR routine should have worked as well...Those for the disks work for all regular files, including those in directories and on a hard drive. From all I read, the DSR should respond for the filename PIO. As I've dug through this more, there are claims that some parallel cards out there may not respond except by using the DSR, so that seems to be the right way. I'm in MAME so perhaps doesn't matter right now, but I do intend to get back to a real TI-99 if my wife doesn't catch me and block my purchase--I have more than my fair share of hobby space already. So I went back to opening "PIO" via DSR and received a return of 0xE0 which is DSR_ERR_FILEERROR. I reconfirmed that I can indeed write to "PIO" in XB, to make sure I wasn't chasing a rabbit. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 19 Share Posted May 19 For what it's worth, I just tried opening RS232 and PIO on my Forth system on real iron and I get an error as well. I never intended to use the DSR for either since they give no benefit to a Forth system versus my own code, but I don't know why my DSRLINK does not let me open them. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted May 20 Share Posted May 20 The flags in the PAB might be important. I would expect it (PIO) must be sequential, and I would try starting with output mode. 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 25 Share Posted May 25 In the "that's interesting C" department: If you don't like GCC for TI maybe you would like to create the absolute opposite end of the spectrum. Sector C (512 bytes) xorvoid 2 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted May 25 Share Posted May 25 17 hours ago, TheBF said: In the "that's interesting C" department: If you don't like GCC for TI maybe you would like to create the absolute opposite end of the spectrum. Sector C (512 bytes) xorvoid OMFG That is the most badass programming I have seen... ever. Maybe it's because I've spent the last couple weeks writing lexers and parsers. I've got thousands of lines of code and not even touched codegen! Barely C is getting all this done in 512 bytes??!! I gotta tell my colleagues who think little of Forth. Maybe because I've regarded compilers as an out-of-reach dark art since childhood, when I saw Clint Pulley's C99 really compiling. Didn't comprehend most compiler science. (aside: my lexer-parser now does a big chunk of C... I'm calling it "SwanC".) Maybe because gcc and llvm are such giant hundred-handed monsters. 512 bytes??!! OMFG. 2 2 Quote Link to comment Share on other sites More sharing options...
