Opry99er Posted February 26, 2011 Share Posted February 26, 2011 Suggestion (I did this with the original Honeycomb Rapture demo)--- put your key-check in a GOSUB.. not in the main game loop--- then branch to it 3 or 4 times in your game loop instead of just once... Immediate response improvement. At least for my application. . With compiled speed, it shouldn't cost you anything. Quote Link to comment Share on other sites More sharing options...
unhuman Posted February 27, 2011 Share Posted February 27, 2011 Suggestion (I did this with the original Honeycomb Rapture demo)--- put your key-check in a GOSUB.. not in the main game loop--- then branch to it 3 or 4 times in your game loop instead of just once... Immediate response improvement. At least for my application. . With compiled speed, it shouldn't cost you anything. That works for a sprite, but not for character animation... Basically, I want it responsive, but not wrong. Not quite sure how to do that... What I'm thinking is that in the delay period - monitor the joystick - and track any motion - and if there is a motion, hold that it occurred and use that retained value, even if it gets unset later in the loop - basically if someone taps joystick in a way, but then releases, we still want the motion... Maybe? I should experiment with it for sure. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 27, 2011 Share Posted February 27, 2011 Not all that clean--- I threw this together in about an hour... should have taken some more time with it, but you'll get the point. =) http://www.youtube.com/watch?v=izkGCcQb530 Quote Link to comment Share on other sites More sharing options...
unhuman Posted February 27, 2011 Share Posted February 27, 2011 (edited) Not all that clean--- I threw this together in about an hour... should have taken some more time with it, but you'll get the point. =) Is that why the video is unavailable? That's pretty dirty, as you suggest. Yeah, it was the processing - oooh, and thanks for the shout-out! Edited February 27, 2011 by unhuman Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 27, 2011 Share Posted February 27, 2011 ha!!! JUST uploaded it... might still be processing. =) Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted February 27, 2011 Share Posted February 27, 2011 Ok - I've updated BloxoTIz to be compiled. Everything seems to work... Even found a bug in the compiler! 3. Detect key state logic by myself. the "S" in the CALL KEY(1, K, S) doesn't work properly. The K is fine. I use this to prevent flipping back and forth repeatedly when your block is split. Is this related to the compiler? In my programs, I am using a simple IF S ... to detect key presses. It works when not compiled, and I have not yet moved to a stage where I am ready to run through the compiler. Quote Link to comment Share on other sites More sharing options...
unhuman Posted February 27, 2011 Share Posted February 27, 2011 updated BloxoTIz compiled to be more responsive to the joystick like I thought I should try. I like it better. So, check it out here - nobody has yet anyway. I'm watching you. BloxoTIz Quote Link to comment Share on other sites More sharing options...
unhuman Posted February 27, 2011 Share Posted February 27, 2011 Ok - I've updated BloxoTIz to be compiled. Everything seems to work... Even found a bug in the compiler! 3. Detect key state logic by myself. the "S" in the CALL KEY(1, K, S) doesn't work properly. The K is fine. I use this to prevent flipping back and forth repeatedly when your block is split. Is this related to the compiler? In my programs, I am using a simple IF S ... to detect key presses. It works when not compiled, and I have not yet moved to a stage where I am ready to run through the compiler. I think it was the compiler - worked fine in B/XB. It seems to work fine compiled with 0,K,S (which I use out-of-game), but not with 1,K,S (which I use in-game-loop) So, I just used my own flag. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted February 27, 2011 Share Posted February 27, 2011 Ok - I've updated BloxoTIz to be compiled. Everything seems to work... Even found a bug in the compiler! 3. Detect key state logic by myself. the "S" in the CALL KEY(1, K, S) doesn't work properly. The K is fine. I use this to prevent flipping back and forth repeatedly when your block is split. Is this related to the compiler? In my programs, I am using a simple IF S ... to detect key presses. It works when not compiled, and I have not yet moved to a stage where I am ready to run through the compiler. I think it was the compiler - worked fine in B/XB. It seems to work fine compiled with 0,K,S (which I use out-of-game), but not with 1,K,S (which I use in-game-loop) So, I just used my own flag. I suppose so long as K still returns -1 in the absence of a key press, I can work without S. Will require a few source changes, but obviously doable. Quote Link to comment Share on other sites More sharing options...
sharapos Posted August 15, 2011 Share Posted August 15, 2011 i can believe it Xcom was on ebay....http://newsgroups.derkeiler.com/Archive/Comp/comp.sys.ti/2007-11/msg00005.html... and no trace nowhere. SST look also very interesting, i'm trying to put it on disk, and try with real hardware... i installed omniflop, but my old 5 1/4 floppy don't work. I tryed to connect the TI99 one, it looks working ( starting under windows ), but reconize nothing. Opry99er, how did u installed a 3 1/2 in TI99 ? you remplaced some circuit in disk controller ? Hello, Can you put on the forum your version of SST compiler ? You talk about it so much BUT don't put it here. I m also interested by other compilers (except whilhelm compiler which I have) . Quote Link to comment Share on other sites More sharing options...
sharapos Posted August 15, 2011 Share Posted August 15, 2011 ok today i decided to search in my old disk, bec i was sure to have another compiler than the SST and Wilhelm's BASIC compiler. And i found one coded by Peter Krull. Somebody already tryed it ? Can you also put on the forum this compiler by Peter Krull ? Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 15, 2011 Share Posted August 15, 2011 Can you also put on the forum this compiler by Peter Krull ? It's here ... http://www.atariage.com/forums/topic/185936-at-least-dsk-image-from-my-collection Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 15, 2011 Share Posted August 15, 2011 That's the one!!! Z80 assembler and runs Forth as it's native language, instead of BASIC. It's freaking awesome. Have you ever programmed in Forth? Barf! Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 15, 2011 Share Posted August 15, 2011 Slow-down could be as simple as 2 or 3 delay loops within the game loop. Ideally, you want to use an interrupt handler to increment a variable every vertical blank. Then the busy loop just clears the variable and waits for a certain number of vertical blanks to take place. Then your code should always run at the same speed even if someone has a 25MHz clone in an FPGA. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted August 15, 2011 Share Posted August 15, 2011 (edited) Can you also put on the forum this compiler by Peter Krull ?It's here ... http://www.atariage.com/forums/topic/185936-at-least-dsk-image-from-my-collection I can't find how to compile with this one. The options 1, 3 and 4 (BASIC, FP-LOADER and INT-LOADER) work. When I press option 2 (COMPILER), it asks me for a basic file to load, that works. Then it asks for an output filename, I type "DSK1.TEST". Then it scrambles the pattern table and lists the disk contents (I can press PROC'D to list another screen or ENTER to go back to menu). No output file is generated... Edited October 10, 2016 by lucien2 Quote Link to comment Share on other sites More sharing options...
rocky007 Posted August 16, 2011 Author Share Posted August 16, 2011 from my side, it working perfect, but only on real TI99. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted August 16, 2011 Share Posted August 16, 2011 (edited) from my side, it working perfect, but only on real TI99. I thought MESS was emulating the disks 100% correctly. Maybe a file was corrupted during transfer. There is a strange file on the disk. Did anyone tried this DSK image on a real TI? Edited October 10, 2016 by lucien2 Quote Link to comment Share on other sites More sharing options...
rocky007 Posted August 16, 2011 Author Share Posted August 16, 2011 on real TI it's working perfect. this video was made on real ti Quote Link to comment Share on other sites More sharing options...
lucien2 Posted August 16, 2011 Share Posted August 16, 2011 on real TI it's working perfect. I already saw that video, I believe you. But is it running with a floppy generated from the DSK image you posted or is it running with the original floppy? What I was guessing is that a problem occured when you created the DSK image. Do you have this strange file (awe..jf..w) on the original floppy? Quote Link to comment Share on other sites More sharing options...
rocky007 Posted August 16, 2011 Author Share Posted August 16, 2011 the DSK i posted is a image from the original floppy. the strange file is probably a defect on the original floppy due to age, but don't disturb the program itself. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted August 16, 2011 Share Posted August 16, 2011 OK, then. Let's wait if anyone else can use this compiler on the real TI. Quote Link to comment Share on other sites More sharing options...
TEXAS_JOE Posted September 1, 2011 Share Posted September 1, 2011 Hello everyone, I was wandering if any of you could spare the time to help me out. I have recently got hold of Harry Wilhelm's compiler, and I watched Opry99er's excellent video tutorial on how to compile from BASIC. Indeed, I followed Opry99er's instructions to the letter and now have no problem at all in compiling with Wilhelms. The problem I'm having is this; I make a BASIC game, and it IS simple, it has hardly any multiple statement lines, kept simple etc ... BUT ... when it runs, the compiled version often crashes .... Let me show you an example; For example, I did this; 10 CALL CLEAR 20 CALL SCREEN(2) 30 FOR L=1 TO 14 40 CALL COLOR(L,16,2) 50 NEXT L 60 CALL CHAR(35,"18997E3C3CBDFF5A")::! FROG 70 CALL CHAR(36,"66FFDBDBDBDBFF66")::! CAR 80 X=24 90 DIM C(4) 100 C(1)=1 110 C(2)=4 120 C(3)=8 130 C(4)=12 150 CALL HCHAR(X,12,35) 155 CALL KEY(0,K,S) 160 CALL HCHAR(12,1,32,32):: CALL HCHAR(12,C(1),36)::CALL HCHAR(X,12,35) 161 CALL GCHAR(12,C(1),W)::IF W=35 THEN 1000 170 CALL HCHAR(14,1,32,32):: CALL HCHAR(14,C(2),36)::CALL HCHAR(X,12,35) 175 CALL GCHAR(14,C(2),W)::IF W=35 THEN 1000 180 CALL HCHAR(16,1,32,32):: CALL HCHAR(16,C(3),36)::CALL HCHAR(X,12,35) 185 CALL GCHAR(16,C(3),W)::IF W=35 THEN 1000 190 CALL HCHAR(18,1,32,32):: CALL HCHAR(18,C(4),36)::CALL HCHAR(X,12,35) 191 CALL GCHAR(18,C(4),W)::IF W=35 THEN 1000 192 C(1)=C(1)+1::IF C(1)=31 THEN C(1)=1 193 C(2)=C(2)+1::IF C(2)=31 THEN C(2)=1 194 C(3)=C(3)+1::IF C(3)=31 THEN C(3)=1 195 C(4)=C(4)+1::IF C(4)=31 THEN C(4)=1 200 CALL GCHAR(X,12,Q)::IF Q=36 THEN 1000 205 IF S=0 THEN 155 210 IF K=69 THEN 500 220 IF K=88 THEN 600 230 GOTO 155 500 CALL HCHAR(X,12,32) 505 X=X-1::IF X=1 THEN 2000 510 CALL GCHAR(X,12,Q)::IF Q=36 THEN 1000 520 GOTO 150 600 CALL HCHAR(X,12,32) 605 X=X+1::IF X=25 THEN X=24 610 GOTO 510 1000 FOR L=660 TO 110 STEP -50 1010 CALL SOUND(1,L,1) 1020 NEXT L 1030 CALL CLEAR 1040 X=24 1050 GOTO 100 2000 FOR L=110 TO 660 STEP 50 2010 CALL SOUND(1,L,1) 2020 NEXT L 2030 CALL CLEAR 2040 X=24 2050 GOTO 100 This program works without error or bugs on XB, and the 'frog' gets caught by the 'cars' each time one hits it. However; with the compiled version, as soon as C(1)=31, it does'nt go back to 1 like it should. This is the same for all assigned C(x) variables. Instead, the game locks up and crashes!!! I've had this problem with a few tests I've made, I don't know if it's my syntax (which is ALWAYS questionable) or whatever else. Basically it's when a variable hits the end of the line, column no.31, i want it to go back to column no.1 , and it just locks up. 192 C(1)=C(1)+1::IF C(1)=31 THEN C(1)=1 193 C(2)=C(2)+1::IF C(2)=31 THEN C(2)=1 194 C(3)=C(3)+1::IF C(3)=31 THEN C(3)=1 195 C(4)=C(4)+1::IF C(4)=31 THEN C(4)=1 The game allows all movement to take place, encounters every collision, but only lasts until the cars get from column 1 to column 32, which in assembly makes my game very very quick to end and lock. Any help would be MASSIVELY appreciated. Thankyou for you're time. Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 1, 2011 Share Posted September 1, 2011 Maybe its a bug in the compiler. Try this as an experiment: 192 A=C(1):: IF A=31 THEN A=1:: C(1)=A Repeat this for c(2) to c(5) Let us know what happens. Quote Link to comment Share on other sites More sharing options...
+RXB Posted September 1, 2011 Share Posted September 1, 2011 Not all that clean--- I threw this together in about an hour... should have taken some more time with it, but you'll get the point. =) http://www.youtube.com/watch?v=izkGCcQb530 Nice, but you really need to turn up your mic volume is is way low. Quote Link to comment Share on other sites More sharing options...
rocky007 Posted September 1, 2011 Author Share Posted September 1, 2011 (edited) if i remember well, the compiler don't accept this : 192 C(1)=C(1)+1::IF C(1)=31 THEN C(1)=1 193 C(2)=C(2)+1::IF C(2)=31 THEN C(2)=1 194 C(3)=C(3)+1::IF C(3)=31 THEN C(3)=1 195 C(4)=C(4)+1::IF C(4)=31 THEN C(4)=1 You need to write like this : 192 C(1)=C(1)+1::IF C(1)=31 THEN 1000 193 C(2)=C(2)+1::IF C(2)=31 THEN 1010 194 C(3)=C(3)+1::IF C(3)=31 THEN 1020 195 C(4)=C(4)+1::IF C(4)=31 THEN 1030 1000 C(1)=1 :: GOTO 193 1010 C(2)=1 :: GOTO 194 1020 C(3)=1 :: GOTO 195 1030 C(4)=1 :: GOTO 196 Why not trying Peter Kull compiler ? It accept as-it XB program. Edited September 1, 2011 by rocky007 Quote Link to comment Share on other sites More sharing options...
