Deteacher Posted March 11, 2011 Share Posted March 11, 2011 Big improvement: 21,490! Quote Link to comment Share on other sites More sharing options...
bennybingo Posted March 11, 2011 Share Posted March 11, 2011 A bit rusty on this one... Here is my submission for now: 8440 And my cart: Quote Link to comment Share on other sites More sharing options...
classicgamer_27330 Posted March 11, 2011 Share Posted March 11, 2011 (edited) On the bridge I go about halfway - 3/4 of the way across, then dodge. Pretty much my dying is @ the dragon. I don't know how good this tip is because I'm in 10th place Edited March 11, 2011 by classicgamer_27330 Quote Link to comment Share on other sites More sharing options...
Frostbite76 Posted March 11, 2011 Share Posted March 11, 2011 (edited) http://www5.snapfish.com/snapfish/slideshow/AlbumID=3337748027/PictureID=125685812027/a=5210909027_5210909027/[/img] Here is my score Edited March 11, 2011 by Frostbite76 Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted March 11, 2011 Share Posted March 11, 2011 (edited) TIPS, AND TACTICS... STARTING A GAME, When starting or resetting a game of Dragonfire, look at the bottom of the screen... where your total of lives are, The correct total of life's should reach the second ZERO in your score, (6 lives in reserve). Sometimes when hitting reset or the fire button, You suddenly are missing 1 life!! To avoid this, before starting a new game, just shut down the power switch and turn it back on. For some odd reason the fire button takes away one of your lives in reserve and only give you (5) back up lives and not (6). THE BRIDGE You are safe from both two flames behind the right corner of the castle! If you run out on the bridge nervous, and unsure, and two fireballs are on their way adjacent to each other, run right and jump right to safety. If there's no time to run from the top flame, DUCK the top flame,...then run right back to the castle, since you can "always" outrun the bottom flame. There's also a time where you CAN get passed two closely spit together flames, to do that... duck the top flame, then JUMP in PLACE to avoid the bottom flame. Always keep trying to press left into the Castle. Don't stall! I've gotten passed the bridge my last game, (over 15ks) every time losing ZERO lives! You actually can jump over the bottom flame (still in a tuck position), THIS helps me a lot... and stops me from running back home on the bridge. Practice jumping the lower slower flames, in a TUCK, but remember the flame has to nearly be burning your knees, before you should jump. If you jump at all soon, you will burn. It always works on those two SLOW flames. It's to tricky to stay tucked and jump the bottom flame, when you don't have to, only use this when you get advanced enough, and that top fire is close to the bottom and there's no time to run back. If you are at a beginner level, you should practice jumping on the bridge, and learn different ways to cross. Just keep doing it, before ever entering the castle/treasure room. CROSSING THE BRIDGE My best technique so far, is... I first run out almost half way, stop... duck the first flame, jump the second... then wait in a tuck, for the next flame to shoot over my head (never try to jump across here) always wait for the third flame above to cross. Then when that flame goes over your head, raise back up and jump again... INTO the castle. Sometimes another bottom flame will appear, but if you get your footing/technique right... your jump will clear it. DON'T TRY TO JUMP to the castle after ducking only one top flame, it's only 70% effective. After tucking that "second" fireball speeding past your head, come up, and jump into the castle. I recommend jumping into the last space into the castle, don't run, because of that sudden bottom flame that occurs, about 30% of the time. INSIDE THE TREASURE ROOM Don't try to snag treasures straight to the (LEFT) of your safe box, if one treasure is sooo close u can smell it (left of your starting zone), that dragon will fireball you dead before you can even reach it! Don't try that pattern over again either, same thing will happen and 3 lives or all will be lost! Also before re-entering the room "WAIT" a second after losing a life in the treasure room, you don't wanna send another man out to get burned by fire that's not even crossed to the top yet! Make sure all fire is cleared before leaving the box again, always use an angle upward! You can snag one treasure to the RIGHT side of the box, but it's probably smart to get back in your box after doing that! If you don't want to run immediately out of the safe box, after clearing the bridge, make sure you pull down/right on your joystick. Doesn't matter if you left the box for a second, the dragon has to cross the left side of the screen to get you, you are fast, you will get back in the box if you pull the joystick down/right. If you wanna get out of the box, always angle yourself up/left corner in doing that. Or you can try mostly UP. NEVER try straight across the dragon! Also a problem can be, if you don't put enough angle on your left running... that FIRST fire ball will most likely sizzle you down! The first 4 levels of Dragons don't shoot fire at the farthest right or left! You can hide anywhere at the far left or right side if the screen! For beginners this is a great way to avoid dragons in the first 4 rounds, that are literally "hot" on your tail. However, once you reach the yellow dragon on the 5th level... you cannot use the left or right side of walls to escape, which now brings to the next tip. Your treasure box, is your only true safe place in the treasure room, after level 4 (the red dragon). So, if you struggle getting away from the fireballs, approach from the upper left corner, then zoom diagonal down/right The skating around technique, if you feel lost but don't want to go back into your treasure box, the dragon follows you, so... skating around the room, in a figure 8 fashion, (but a number "8" laying on it's side) you can weave fire, and maybe snag a few final treasures to escape. The number 8, technique, works best with the treasures nearest to the dragon, those tough ones! You gotta either weave a tight 8, 'till you reach that last 1 or 2 treasures, or you can kinda go straight up and down, snag... then fly diagonal up/right to the exit box. To exit the treasure room every time, it may be a mild risk, but when heading upper left to the exit, just before hitting the box, I always like to hit the left wall, and push right on the joystick. So I always am able to get in the exit box. I never miss it, by hitting the left wall for a half second before entering. Of course if you are barely outrunning flames, you might need to swing right and back left to exit safely. Rush, but don't rush in treasure rooms, This is vital, I'll explain... the dragons fireballs often are slower then you are! Many mistakes happen from "over steering" the joystick in a panic to clear the room of treasures. Remember there's no time limit! Patience is a key needed, in difficult patterns to snag the treasures. Sometimes (outside the box) just waiting for the fire to "near" you and then moving out into your next pattern or exit/safe box, can be helpful. I find myself running into fire, instead of knowing better. I'm working on it, but I think the real rush starts at the yellow dragon and beyond that. I rarely lose 1 life before the white dragon now. ADVANCED TIPS (WHITE DRAGON ROOM), The White dragon is one tough punk as* b*tch! One technique that works for me, is don't always try to clear every single piece of treasure and leave. Instead look at the treasure and visualize a route! Then you can snag most, or even just a few treasures, then go back into your safe box for a mental break! This will stop the dragons fireballs and reset him! You should actually (visualize) a plan a new route each time you leave your box... you also can repeat this as often as you want. Just practice getting back into your safe box in one piece, using the diagonal right/down, on the joystick... it takes practice but it works for me! All dragons go from the left screen to the right, so I like to hop out of the box immediately,(UNTILL THE WHITE DRAGON LEVEL) the White Dragon fireballs really can put you at "game over" quickly, this could prove a deadly move... I find it better now to plan where you want to run to, before leaving your safe box. When it's time to leave, don't go left out, don't even go left/diagonal, a fireball will sizzle you to ash. What I find works, is push up with a (slight) angle... you will just clear the first fire ball, then try a figure 8 route to dodge the fireballs and get some treasure, use the safety box if you need to! Memorize the Dragons fireball patterns, he shoots about 3/4 first straight then a curve or a last "middle ball", it's very tough to outrun and dodge these, swerving around left to right, and going back to your safe box is what works for me so far. You might want to practice difficulty level (4), it starts you further in the game, and you get to figure and improve your technique against the white dragons without having to do so many early levels. 16,240 - Bonus Thief! Edited March 13, 2011 by JacobZu7zu7 Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted March 11, 2011 Share Posted March 11, 2011 Oops, Deteacher is ranked twice in the standings, #3 and #6. 1# 34,620 (Frostbite76) 2# 20,080 (keilbaca) 3# 14,460 (Deteacher) 4# 13,110 (JacobZu7zu7) 5# 12,770 (Vocelli) 6# 12,720 (Deteacher) 7# 10,600 (toymailman) Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted March 11, 2011 Share Posted March 11, 2011 (edited) Ze_ro, you forgot to count 2 extra points which I got for the best tips on Round 9.01 - Millipede. The correct current standings for Season 9 after Millipede round is: 1. oyamafamily [16] (11 for winning the previous round, 3 bonus points for "Guardian Garden" challenge, and 2 extra points for best tips) 2. SeaGtGruff [14] (10 for the 2nd place, 3 points via "Guardian Garden" challenge, and 1 bonus point via "Progress") Edited March 11, 2011 by oyamafamily Quote Link to comment Share on other sites More sharing options...
Gorfy Posted March 11, 2011 Share Posted March 11, 2011 New score: 11,940 Quote Link to comment Share on other sites More sharing options...
Vocelli Posted March 12, 2011 Share Posted March 12, 2011 Wow... An impressive score for me! Vocelli: 36250 Quote Link to comment Share on other sites More sharing options...
Scrabbler15 Posted March 12, 2011 Share Posted March 12, 2011 5560 I'm just happy to have finally gotten to the white dragon. Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted March 12, 2011 Share Posted March 12, 2011 Ze_ro, you forgot to count 2 extra points which I got for the best tips on Round 9.01 - Millipede. The correct current standings for Season 9 after Millipede round is: 1. oyamafamily [16] (11 for winning the previous round, 3 bonus points for "Guardian Garden" challenge, and 2 extra points for best tips) 2. SeaGtGruff [14] (10 for the 2nd place, 3 points via "Guardian Garden" challenge, and 1 bonus point via "Progress") Good eye. Quote Link to comment Share on other sites More sharing options...
atariUCLA24 Posted March 12, 2011 Share Posted March 12, 2011 Small improvement, but nowhere near most of the scores on here- 2800 Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted March 12, 2011 Share Posted March 12, 2011 8300 Quote Link to comment Share on other sites More sharing options...
Mister VCS Posted March 12, 2011 Share Posted March 12, 2011 (edited) first try: 8,060 10,580 my cartridge: @Z_ero: the IMAGIC-logo at the top of the lable isn't missing - the picture is just too bright... what do you think about a bonus-point for the first "International-Edition-cartridge"? Edited March 12, 2011 by Mister VCS Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted March 12, 2011 Share Posted March 12, 2011 10,560 Quote Link to comment Share on other sites More sharing options...
Gorfy Posted March 12, 2011 Share Posted March 12, 2011 16,240 - Bonus Thief! TIPS, AND TACTICS... STARTING A GAME, When starting or resetting a game of Dragonfire, look at the bottom of the screen... where your total of lives are, The correct total of life's should reach the second ZERO in your score, (6 lives in reserve). Sometimes when hitting reset or the fire button, You suddenly are missing 1 life!! To avoid this, before starting a new game, just shut down the power switch and turn it back on. For some odd reason the fire button takes away one of your lives in reserve and only give you (5) back up lives and not (6). THE BRIDGE You are safe from both two flames behind the right corner of the castle! If you run out on the bridge nervous, and unsure, and two fireballs are on their way adjacent to each other, run right and jump right to safety. If there's no time to run from the top flame, DUCK the top flame,...then run right back to the castle, since you can "always" outrun the bottom flame. There's also a time where you CAN get passed two closely spit together flames, to do that... duck the top flame, then JUMP in PLACE to avoid the bottom flame. Always keep trying to press left into the Castle. Don't stall! I've gotten passed the bridge my last game, (over 15ks) every time losing ZERO lives! You actually can jump over the bottom flame (still in a tuck position), THIS helps me a lot... and stops me from running back home on the bridge. Practice jumping the lower slower flames, in a TUCK, but remember the flame has to nearly be burning your knees, before you should jump. If you jump at all soon, you will burn. It always works on those two SLOW flames. It's to tricky to stay tucked and jump the bottom flame, when you don't have to, only use this when you get advanced enough, and that top fire is close to the bottom and there's no time to run back. If you are at a beginner level, you should practice jumping on the bridge, and learn different ways to cross. Just keep doing it, before ever entering the castle/treasure room. CROSSING THE BRIDGE My best technique so far, is... I first run out almost half way, stop... duck the first flame, jump the second... then wait in a tuck, for the next flame to shoot over my head (never try to jump across here) always wait for the third flame above to cross. Then when that flame goes over your head, raise back up and jump again... INTO the castle. Sometimes another bottom flame will appear, but if you get your footing/technique right... your jump will clear it. DON'T TRY TO JUMP to the castle after ducking only one top flame, it's only 70% effective. After tucking that "second" fireball speeding past your head, come up, and jump into the castle. I recommend jumping into the last space into the castle, don't run, because of that sudden bottom flame that occurs, about 30% of the time. INSIDE THE TREASURE ROOM Don't try to snag treasures straight to the (LEFT) of your safe box, if one treasure is sooo close u can smell it (left of your starting zone), that dragon will fireball you dead before you can even reach it! Don't try that pattern over again either, same thing will happen and 3 lives or all will be lost! Also before re-entering the room "WAIT" a second after losing a life in the treasure room, you don't wanna send another man out to get burned by fire that's not even crossed to the top yet! Make sure all fire is cleared before leaving the box again, always use an angle upward! You can snag one treasure to the RIGHT side of the box, but it's probably smart to get back in your box after doing that! If you don't want to run immediately out of the safe box, after clearing the bridge, make sure you pull down/right on your joystick. Doesn't matter if you left the box for a second, the dragon has to cross the left side of the screen to get you, you are fast, you will get back in the box if you pull the joystick down/right. If you wanna get out of the box, always angle yourself up/left corner in doing that. Or you can try mostly UP. NEVER try straight across the dragon! Also a problem can be, if you don't put enough angle on your left running... that FIRST fire ball will most likely sizzle you down! The first 4 levels of Dragons don't shoot fire at the farthest right or left! You can hide anywhere at the far left or right side if the screen! For beginners this is a great way to avoid dragons in the first 4 rounds, that are literally "hot" on your tail. However, once you reach the yellow dragon on the 5th level... you cannot use the left or right side of walls to escape, which now brings to the next tip. Your treasure box, is your only true safe place in the treasure room, after level 4 (the red dragon). So, if you struggle getting away from the fireballs, approach from the upper left corner, then zoom diagonal down/right The skating around technique, if you feel lost but don't want to go back into your treasure box, the dragon follows you, so... skating around the room, in a figure 8 fashion, (but a number "8" laying on it's side) you can weave fire, and maybe snag a few final treasures to escape. The number 8, technique, works best with the treasures nearest to the dragon, those tough ones! You gotta either weave a tight 8, 'till you reach that last 1 or 2 treasures, or you can kinda go straight up and down, snag... then fly diagonal up/right to the exit box. To exit the treasure room every time, it may be a mild risk, but when heading upper left to the exit, just before hitting the box, I always like to hit the left wall, and push right on the joystick. So I always am able to get in the exit box. I never miss it, by hitting the left wall for a half second before entering. Of course if you are barely outrunning flames, you might need to swing right and back left to exit safely. Rush, but don't rush in treasure rooms, This is vital, I'll explain... the dragons fireballs often are slower then you are! Many mistakes happen from "over steering" the joystick in a panic to clear the room of treasures. Remember there's no time limit! Patience is a key needed, in difficult patterns to snag the treasures. Sometimes (outside the box) just waiting for the fire to "near" you and then moving out into your next pattern or exit/safe box, can be helpful. I find myself running into fire, instead of knowing better. I'm working on it, but I think the real rush starts at the yellow dragon and beyond that. I rarely lose 1 life before the white dragon now. ADVANCED TIPS (WHITE DRAGON ROOM), The White dragon is one tough punk as* b*tch! One technique that works for me, is don't always try to clear every single piece of treasure and leave. Instead look at the treasure and visualize a route! Then you can snag most, or even just a few treasures, then go back into your safe box for a mental break! This will stop the dragons fireballs and reset him! You should actually (visualize) a plan a new route each time you leave your box... you also can repeat this as often as you want. Just practice getting back into your safe box in one piece, using the diagonal right/down, on the joystick... it takes practice but it works for me! All dragons go from the left screen to the right, so I like to hop out of the box immediately,(UNTILL THE WHITE DRAGON LEVEL) the White Dragon fireballs really can put you at "game over" quickly, this could prove a deadly move... I find it better now to plan where you want to run to, before leaving your safe box. When it's time to leave, don't go left out, don't even go left/diagonal, a fireball will sizzle you to ash. What I find works, is push up with a (slight) angle... you will just clear the first fire ball, then try a figure 8 route to dodge the fireballs and get some treasure, use the safety box if you need to! Memorize the Dragons fireball patterns, he shoots about 3/4 first straight then a curve or a last "middle ball", it's very tough to outrun and dodge these, swerving around left to right, and going back to your safe box is what works for me so far. You might want to practice difficulty level (4), it starts you further in the game, and you get to figure and improve your technique against the white dragons without having to do so many early levels. Thanks for the tips, Jacob :!: Quote Link to comment Share on other sites More sharing options...
Hydro Thunder Posted March 12, 2011 Share Posted March 12, 2011 Improvement, 6710 Finally got to see this mythical White Dragon that's been talked of in hushed tones at the local tavern... He killed me and got the double kill _twice_ (four lives total!) as by the time I knew I was dead I was running a second guy out of the box and right into the fire. Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted March 12, 2011 Share Posted March 12, 2011 11,460 Quote Link to comment Share on other sites More sharing options...
Scrabbler15 Posted March 12, 2011 Share Posted March 12, 2011 Slowly I improve, step by step, inch by inch... 6150 Quote Link to comment Share on other sites More sharing options...
Frostbite76 Posted March 12, 2011 Share Posted March 12, 2011 He killed me and got the double kill _twice_ (four lives total!) as by the time I knew I was dead I was running a second guy out of the box and right into the fire. I seem to lose half my lives this way. The game should of done a better job preventing this from happening. It's the only flaw in a great game. 1 Quote Link to comment Share on other sites More sharing options...
Frostbite76 Posted March 12, 2011 Share Posted March 12, 2011 also it is very difficult to get a treasure that's located on the bottom center of the screen or one that's located right behind the hideout box. Any tips for those tricky spots? Quote Link to comment Share on other sites More sharing options...
Frostbite76 Posted March 12, 2011 Share Posted March 12, 2011 improvement 38,950 Quote Link to comment Share on other sites More sharing options...
Gorfy Posted March 12, 2011 Share Posted March 12, 2011 improvement 38,950 that's a mind-boggling score Keep it up and you'll be competing with the Twin Galaxies high scores.... Quote Link to comment Share on other sites More sharing options...
phaxda Posted March 13, 2011 Share Posted March 13, 2011 I JUST threw out a nasty, nasty Dragonfire cartridge... a shame I had not seen this earlier. Still, only second game of the season and I am feeling competitive this year. Scores to come! Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted March 13, 2011 Share Posted March 13, 2011 15,740!!! WOO HOOO!! I finally broke 15K mark to get Bonus Points for "Master Thief" challenge!! Quote Link to comment Share on other sites More sharing options...
