CALL LOCATE
orion1052003
It works great. The man wraps around on screen. Why does it work?
640 CALL SPRITE(#1,96,16,DR,DC) :: CALL MAGNIFY(4)
660 ANIM=ABS(ANIM-4) :: CALL JOYST(1,X,Y) :: DR=DR-Y*0 :: DC=DC+X*4 :: CALL LOCATE(#1,(DR AND 255)+1,(DC AND 255)+1)
What does the +1 do?
I am somewhat familiar with AND since I read The Power of AND by Craig Miller from "Night Mission". I think whatever you AND something with, the answer can't be higher than whatever number you ANDed with. The bit "mask" in assembly. I don't fully understand it, but I ANDed some numbers at work just to get familiar with it. I think 9 is 1001. 1 is 0001. 9 AND 1 would be 0001=1 then I think. Can you actually do AND 1, AND 7, etc. or was it some number AND 1, DC, DR, or some number AND 7, etc. that you meant above?
The "AND 255" gets whatever value into the range 0-255. The "+1" moves the range from 0-255 to 1-256. The latter being exactly the range CALL LOCATE will accept.
Yep, bit masking is what it is. And yes, "9 AND 1" equals 1.
Do you have any idea why my jump won't work?
810 SUB JUMP(DR,DC)
830 DR=DR-Y*4
DR was something about row (=vertical) position of the sprite ? And Y was the joystick direction (=vertical) ? Is Y then -4, 0 or 4 here, or has it been changed before getting here ?
It looks like, initially in the jump, you want the man to, more or less instantly, move up, down or not by 16 pixels based on the joystick input ?
Here's some Major Havoc jumping for reference.
http://www.youtube.com/watch?v=ULiqCxUB-Y8
The video/Major Havoc jumping.
Looks like joystick input is only left, right and fire.
When you hit the fire button, the man jumps. If you hold the fire button, he continues to elevate. Looks like he gains speed to reach maximum speed quite fast.
When leaping off a structure or releasing the fire button while jumping, it looks like gravity takes over, and downward decent then reaches a maximum speed.
Is this correct ?
Edited by sometimes99er
At first I had 8 directions and center, Diagonals and LeftRightUpDown. It took almost all the character sets and I thought to try only Left, Right, and Fire for the jump. In the game it seems he doesn't actually need to move up or down, the diagonal jump looked cool..but ya can't have everything. So, yes, left, right, orange button k=18.
My thought or wish on the Major Havoc jump would be to try and emulate this jump but then slow it down a bit. I wanted the man to run at ground level left or right and wrap around the screen.(which he now does) He would jump in a tad slow floating movement as long as the button was held down, or until he hit the "ceiling". I was inspired by Major Havoc and Lunar Lander to have a space man with super high jumps, maybe on a planetoid..
There are about 4 subroutines of enemies that keep re-appearing until the game ends, and they only partially work.
DR=Dot Row DC=Dot Column Y= Horizontal X=Vertical(whatever JOYST uses)
I think Y*4 is added to DR or subtracted. Line 660.
635 DR=130 :: DC=1
660 ANIM=ABS(ANIM-4)::CALL JOYST(1,X,Y)::DR=DR-Y*4 :: DC=DC+X*4::CALL LOCATE(#1,DR,DC)
663 IF X<>0 THEN CALL PATTERN(#1,ANIM+X*2+108)::FACE=SGN(X+4)::GOTO 660
16 pixels?
Do you have to put several CALL COINC statements in to make it catch a coincidence? Or do you generally just write one CALL COINC and loop back to it?
Do you need to CALL subrprograms in the same loop as CALL JOYST(main program)?
I suppose the CALL JOYST would be the main game loop. How do I work in the Subprograms without making the JOYST loop way too lengthy?
I was planning to have a few separate subroutines CALL enemies(Subprograms) one at a time in a loop continuously until the game ends. I think this would cause a similar effect to the recurring and annoying bouncing Spider in Centipede.
THe JUMP was written by my friend who was also experimenting with PI. We wanted to make a jump using CALL LOCATE instead of the normal CALL MOTION, primarily because I heard using locate is much better for coincidence checking. Instead of the internet, most of my news and information comes from rumor and small children, so I'm not sure about that.
I couldn't get CALL COINC to work with my subprograms, but it worked here in this test on line 365.
100 !TEST PROGRAM-USE CALL LOCATE WITH JOYST
110 P1=15 :: P2=10
120 CALL CLEAR :: CALL SCREEN(6)
130 A$=RPT$("F",16) :: CALL CHAR(96,A$)
140 CALL SPRITE(#1,96,2,89,121)
143 S$=RPT$("F",16) :: CALL CHAR(104,S$)
145 CALL SPRITE(#2,104,16,57,223)
150 DR=100 :: DC=100
160 CALL HCHAR(1,16,104)!UP
170 CALL HCHAR(24,16,112)!DOWN
180 CALL HCHAR(12,3,120)!LEFT
190 CALL HCHAR(12,30,128)!RIGHT
200 CALL JOYST(1,X,Y)
210 CALL COLOR(10,P1,P1,11,P1,P1,12,P1,P1,13,P1,P1)
220 R=R-Y/4 :: C=C+X/4
230 DR=DR-Y*4 :: DC=DC+X*4
260 CALL LOCATE(#1,DR,DC)
270 CALL KEY(1,K,S)
280 DISPLAY AT(16,1):"SAME KEY=0 NEW KEY=1 NO KEY PRESS=-1"
290 DISPLAY AT(18,5):"KEY= ";K;"STATUS= ";S
300 DISPLAY AT(20,1):"X= ";X;"Y= ";Y
310 DISPLAY AT(21,1):"R= ";R;"C= ";C
320 DISPLAY AT(22,1):"DR= ";DR;"DC= ";DC
330 IF Y=4 AND X=0 THEN CALL COLOR(10,P2,P2)
340 IF Y=0 AND X=4 THEN CALL COLOR(13,P2,P2)
350 IF Y=-4 AND X=0 THEN CALL COLOR(11,P2,P2)
360 IF Y=0 AND X=-4 THEN CALL COLOR(12,P2,P2)
365 CALL COINC(#1,#2,10,C) :: IF C THEN CALL SOUND(300,-2,10)
368 DISPLAY AT(14,12):"C= ";C
370 GOTO 200
You have way to much stuff in the loop between 370 and 200. It makes the chance of getting a COINC very slow.
If you watch my Videos on RXB 2012 you will see this demo, the lower half requires RXB but the top half is XB.
My point is the more between each line and number of lines the slower XB gets.
Just a matter of distance or up hill if you are walking. More line numbers is farther and more calculations is up hill.
Reduce the number of lines in a loop and it speeds up, reduce the complications and it gets faster.
100 ! RUN FOR 1 HOUR AND	 AND PRINT X FOR XB VS RXB
110 ! NORMAL XB COINC
120 CALL CLEAR :: X=190
130 CALL SPRITE(#1,65,2,9,X,20,0,#2,66,2,9,X,30,0,#3,67,2,9,X,-20,0)
140 CALL COINC(ALL,A)
150 CALL COINC(#1,#2,12,B)
160 CALL COINC(#1,#3,12,C)
170 CALL COINC(#2,#3,12,D)
180 X=X+1 :: PRINT A;B;C;D
190 GOTO 140
200 !
210 ! RXB COINC
220 CALL CLEAR :: X=190
230 CALL SPRITE(#1,65,2,9,X,20,0,#2,66,2,9,X,30,0,#3,67,2,9,X,-20,0)
240 CALL COINC(ALL,A,#1,#2,12,B,#1,#3,12,C,#2,#3,12,D)
250 X=X+1 :: PRINT A;B;C;D
260 GOTO 240
810 SUB JUMP(DR,DC)
830 DR=DR-Y*4
16 pixels?
If Y can be -4, 0 or 4 then (it will always be 0 inside this SUB since Y is not passed)
Y*4
becomes
-16, 0 or 16
The line
830 DR=DR-Y*4
must then change the "Dot Row" of the sprite by 16 pixels, if you were pulling the joystick in the Y direction.
Obviously the confusion is almost complete. :party:
If you use CALL MOTION, there's always the possibility of missing a coincidence. You have to make CALL COINC often with the right amount of tolerance. Yes, CALL COINC can be in a loop, and yes, one can make several CALLs - it depends. I guess it's a bit of trial and error.
If you use one CALL LOCATE and one CALL COINC in your loop, you should be able to catch everything. Of course with the right amount of tolerance.
No.
There's no general rule to the use of subrprograms, but of course it depends on what your subrprograms are doing.
Subprograms take some overhead. Calling a subprogram, using local variables and returning takes computer time.
RXB suggested having many statements on a single line, so XB does not have to do too much searching for linenumbers, I think this is very true, when it comes to optimization and saving computer time.
You have to try it out. Using subroutines can help sort out some logic errors and enhancing readability. However - XB can not control a hole lot of action and check for coincidences with an overall nice arcade quality. Take a simple OUTLAW situation. One player shooting at a computer controlled player shooting back at you. This quickly becomes the limit of XB speed. But then again, sometimes things like INACCURATE INVADERS kinda surprises you (and then done in 29 lines with 7 data). Bottomline, you can't have a lot of stuff happening at the same time, but you can take things through different stages (levels).
I removed line 830 which removed the variable Y from the jump. It now does a jumping effect always going to the right. I would use FACE to tell the program to jump left or right. Line 850 .....IF FACE=1 THEN DC=DC+(A*PI/45)*5 :: IF FACE=0 THEN DC=DC-(A*PI/45)*5?
635 DR=130 :: DC=1
662 CALL KEY(1,K,S) :: IF K=18 THEN CALL JUMP(DR,DC)
663 IF X<>0 THEN CALL PATTERN(#1,ANIM+X*2+108) :: FACE=SGN(X+4) :: GOTO 660
665 CALL PATTERN(#1,FACE*16+96) :: GOTO 660
670 IF DC<2 THEN DC=240 ELSE IF DC>240 THEN DC=2
810 SUB JUMP(DR,DC)
815 !ALL COINC(#1,ALL,C)
820 CALL SOUND(150,-2,4)
840 SDR=DR :: A=1
845 IF DC<2 THEN DC=240 ELSE IF DC>240 THEN DC=2
850 CALL KEY(1,K,S) :: IF K=18 THEN DR=DR-4 :: DC=DC+(A*PI/45)*5 :: IF DC>240 THEN DC=1
860 !DISPLAY AT(23,1):A;" ";SIN(A*PI/45)
870 IF DR<8 THEN 890
880 CALL LOCATE(#1,DR,DC) :: IF S<0 THEN A=A+1 :: GOTO 850
890 IF DR<SDR THEN DR=DR+4 :: DC=DC+1 :: CALL LOCATE(#1,DR,DC) :: IF DC>240 THEN DC=1
900 IF DR<SDR THEN 890
910 SUBEND
Also tried changing line 850 which makes it jump straight up and to the right on the way down. Misunderstanding is complete again.
635 DR=130 :: DC=1
662 CALL KEY(1,K,S) :: IF K=18 THEN CALL JUMP(DR,DC,FACE)
810 SUB JUMP(DR,DC,FACE)
840 SDR=DR :: A=1
850 CALL KEY(1,K,S) :: IF K=18 THEN DR=DR-4 :: IF FACE=1 THEN DC=DC+(A*PI/45)*5 :: IF FACE=1 THEN DC=DC-(A*PI/45)*5 :: IF DC>240 THEN DC=1
910 SUBEND
First of all there's two "IF FACE=1" in the line above ?
Also, if an "IF" is met, then the rest of the line is only executed if the "IF" was true, otherwise it jumps to the next line in the program.
100 A=A+1::CALL JOYST(1,X,Y)
110 IF X=4 THEN A=A+100::PRINT A
120 GOTO 100
The above is a test. The value is only printed, when you move the joystick to the right.
It was supposed to be :
850 CALL KEY(1,K,S) :: IF K=18 THEN DR=DR-4 :: IF FACE=1 THEN DC=DC+(A*PI/45)*5 :: IF FACE=0 THEN DC=DC-(A*PI/45)*5 :: IF DC>240 THEN DC=1
I remember changing 1 line to FACE=1 and one to FACE=0 and it still didn't come out right. Wow. If this isn't murphy's law, it's definitely what happens when it gets late at night. Some days I can't do this till night and am fighting sleep.
As I tried to explain in post #39,
What comes after an "IF" is only executed, including multiple statements, if the "IF" is true/the condition is met.
Program pointer will never ever get to the things after FACE=0. Why ? It will only get to "FACE=0" if the previous condition "FACE=1" is met. Obviously FACE can't be both 1 and 0, so 0 it will never be (when and if the program pointer gets there).
One solution is to split it up, ending up with only ONE "IF" on each program line. Another a bit more dangerous path/solution is to use ELSE.
Should be:
850 CALL KEY(1,K,S) :: IF K=18 THEN DR=DR-4 :: IF FACE=1 THEN DC=DC+(A*PI/45)*5 ELSE DC=DC-(A*PI/45)*5
851 IF DC>240 OR DC<1 THEN DC=1
My friend also has a question about using call locate with joyst.
CALL LOCATE(#1,(DR AND 255)+1,(DC AND 255)+1) I am not sure that I understand what you are trying to do here. (DR AND 255) and (DC AND 255) will return -1 if DR=255 or DC=255 thus only acting if either is 255 and then it changes the statement to be CALL LOCATE(#1,-1+1,-1+1) making either parameter zero which will cause an error. Since DR never changes I would rewrite as CALL LOCATE(#1,DR,(DC AND 255)+2)
No, or that depends on what and how you extract from the original line.
"AND 255" is a bitwise operation. It takes a value, DR or DC, and only allow the least 8 bits to pass thru, effectively forcing any value into the range 0-255 (what 8 bits can represent). Here I list the value of DR, and the result after doing "DR AND 255" to try and illustrate without using bit graphics. Maybe you get the idea.
DR (DR AND 255)
0 0
1 1
17 17
255 255
256 0
257 1
-1 255
-244.4 12
30000 48
Mind you the max range of DR must be -32768.5 - 32767.4999 (floating point range accepted into the 16 bit range).
Here's a program to test what's going to happen
100 INPUT A
110 PRINT (A AND 255)
120 GOTO 100
DR, yep you could do that, as long as DR is in the 1-256 range (what CALL LOCATE likes).
"DC AND 255" forces DC into the 0-255 range. "(DC AND 255)+2" would then result in the possible range of 2-257, which is outside the range of CALL LOCATE, and could cause your program to end with an ERROR.
Hmm. Does this solve the negative non integer number, and out of range error? Or merely "patch" it? I know not what I do...
840 SDR=DR :: A=1
844 DISPLAY AT(16,12):"DC= ";DC
850 CALL KEY(1,K,S) :: IF K=18 THEN DR=DR-4 :: DC=ABS(DC)+ABS(INT(A*PI/45)*5) :: IF DC>240 THEN DC=17
855 CALL COINC(#1,#2,10,CO) :: IF CO THEN CALL SOUND(150,-2,4) :: CALL DELSPRITE(#1)
875 IF DR=126 THEN M=DC
890 IF DR<SDR THEN DR=DR+4 :: DC=DC+1 :: CALL LOCATE(#1,DR,DC) :: IF DC>240 THEN DC=17
910 SUBEND
I changed line 850 stop negative and non-integer numbers. The error I continually got under these conditions - when the man was at the rightmost corner of the screen, DR=126, and pressed the jump button- stopped after this. The error was always at line 880 If I remember right.
880error.tiff
ERROR_880.tiff
ERRORDC.tiff
Sometimes, what is your private e-mail?
At 23 seconds in this video, there is a dot chasing routine. I have a subprogram to place a random dot on screen. Like the car, the man would touch the dot, and it would disappear only to present itself again somewhere else on screen. The Man would have to touch the dot a certain number of times, say 25. How could this subprogram be called, and simultaneously have another subprogram of an "enemy" running at the same time? I thought the pesky enemies would make it harder for the man to get the dot.
Well, I don't know. Give me a complete working example, and maybe I can tell you how to fix it. It's too easy for me to add confusion, if I have to set up my own test environment. Simply to ensure we're talking about the same thing.
If you want, can you mail me privately here at AtariAge (using their system). But I'd rather communicate publicly, giving people a chance to come with ideas, learn and/or try and do better. My time is also limited, so ...
I think you're very much answering it yourself concerning the dot. Pseudo code would maybe be something like below. Pseudo code is excellent for getting what you have in your head down on paper. It will actually help. I guess moving the enemy is going to be the challenge, if it's not just going to stand there and move like, one right, one left, one right, one up, one left, one down - simple erratic behaviour.
Setup things
Loop start
Move enemy
Move man
Check collision between man and enemy
Check collision between man and dot
Loop end
Sub Move enemy
Subend
Sub Move man
Subend
Man and enemy collided
Do whatever
Go somewhere
Man and dot collided
All 25 dots taken ? Go do something special
Set new dot location
Go back to loop
Well, my thought for my first game was to finish it completely, then dish out a free game to the community as a surprise. I figure it putting it all on here would blow the surprise, even though the game is probably no big deal. It does make it easier to learn with the public forum, with trial and error and different input instead of trying to finish it in private. I put most of the code on the CALL COINC thread. Not sure how to do 3 things at once. It seems like the program can CALL JOYST, CALL DOT, and CALL enemies one at a time in a sequence, but it needs to be done simultaneously. When you have to wait for all the enemies to go by before you can move the joystick again, it's not working right.
It seems to be like this
CALL JOYST
CALL DOT
CALL ENEMIES
REPEAT
instead of CALL JOYST- CALL DOT - CALL ENEMIES , where you can move around, touch the dot, jump out of the way of an enemy all in "real time". When I call the subprograms, it seems to be just a stack of tasks that are completed in order, so I have to do all of them before I can start over, preventing the program from doing several things at once. I don't know if the structure is call all subprograms in the game loop and make the game loop too long and slow, or make a short fast game loop and not be able to call the subprograms. Catch-22.
Edited by orion1052003
The game loop allows you to "do multiple things" at one moment in "game time". If the game is running fast enough, then game time is very close to "real time". In BASIC or XB, you are going to have a hard time keeping the game running anywhere close to real time.
In your game loop, you typically need to perform several tasks:
while game is running
 get player input
 update location player according to input
 update "bad guy" locations according to game AI
 update other objects (animation frames, explosions, backgrounds, etc.)
 resolve collisions
 update score and game status
 draw objects (new player location, bad guys, other objects, etc.)
wend
Notice where "resolve collisions" is placed, i.e. after the player AND AI have had a chance to move. The player moves, the AI moves, then you check if anything collided. If you are using sprite "auto motion" in XB then you will probably end up having a hard time with resolving collisions if the sprites are moving too fast. Everything in the game gets a chance to change every time through the game loop, which is how you create the illusion that multiple things are happening at the same time.
Also notice that "updating" the player and "bad guy" locations is separate from "drawing" them. If in the current "tick" of game time the player was hit by a bad guy (or a bullet, or whatever), you would probably start an explosion animation at the player's location instead of drawing the player.
Edited by matthew180
