José Pereira Posted May 22, 2023 Share Posted May 22, 2023 (edited) On 5/17/2023 at 4:38 PM, José Pereira said: Cybernoid I has various floors and walls types that has also different colours... On level_3 there's even another type (and started trying this one on A8 and have to say is tricky but sure will get it 😞 So here's all types and with the A8 colourings: Please notice that then new ones on CPC are green (not possível on A8) but not correct because horizontally have 3lines while vertically have 2. Sure os because of then resolution but could bem other way to solve this. On A8 they're the same only changing direction and I think that the gray & white goes well with the blue 'point'. The hardest part of I is exactly 'the coming of' new gfxs but probably now I have them all done (and seen) screen per screen. That particular screen of level_3 maked me realize that the top tower here can't have PMGs to add different colours (now I'm thinking it even looks better ) but also seen C64 version I get that platforms (where usually are the rockets) is better for A8 colourings than the CPC one. On the left the old one(s) and at the right the new (and definitive) looking(s), I'm almost sure : So that screen of level_3 looks like this on A8: Cybernoid I level_3 line_1 screen_1.xex But also only now I saw that'll have to 'replace' all ascending and descending rockets on all levels screens already done so that they'll be 1pixel to left. Not important but maybe better for 'code like' collision detection? !... Like I said, had to go to see level_3 because of the new gfxs but now returning to end level_2 in the hope that can have also _3 soon... Edited May 22, 2023 by José Pereira Forgot to add the descendining rockets and added thext... 6 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted May 24, 2023 Share Posted May 24, 2023 On 5/22/2023 at 4:00 PM, José Pereira said: So that screen of level_3 looks like this on A8: Cybernoid I level_3 line_1 screen_1a.xex The walls have many white & gray turning it 'washed out' so after many different designs by now I'm statisfied with this one: Cybernoid I level_3 line_1 screen_1b.xex 7 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted May 24, 2023 Share Posted May 24, 2023 (edited) 2 hours ago, José Pereira said: The walls have many white & gray turning it 'washed out' so after many different designs by now I'm statisfied with this one: Cybernoid I level_3 line_1 screen_1b.xex 4.82 kB · 1 download Forgot to also change the top wall: Cybernoid I level_3 line_1 screen_1b.xex Please notice that because of A8 colouring 'via' PMGs and PFs colours dli (like is this case) they're maybe, just a couple of times (not too much though ...) that can't there have the blue & cyan (or on other cases the gray), like also here: Cybernoid I level_2 line_2 screen_2 _to use M0 & M1.xex It's allmost unoticeable, I think... Edited May 24, 2023 by José Pereira 3 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted May 25, 2023 Share Posted May 25, 2023 Choose one : a.)- Cybernoid I level_3 line_1 screen_1a.xex b.)- Cybernoid I level_3 line_1 screen_1b.xex c.)- Cybernoid I level_3 line_1 screen_1c.xex d.)- Cybernoid I level_3 line_1 screen_1d.xex Cybernoid I level_3 line_1 screen_1d.xex 4 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 25, 2023 Share Posted May 25, 2023 (edited) 'A' of course but if that can't work for some unknown reason then 'B', what does the original cybernoid screen look like as another comparison point? Edited May 25, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
José Pereira Posted May 25, 2023 Share Posted May 25, 2023 1 hour ago, _The Doctor__ said: 'A' of course but if that can't work for some unknown reason then 'B', what does the original cybernoid screen look like as another comparison point? On this post: On 5/22/2023 at 4:00 PM, José Pereira said: Cybernoid I has various floors and walls types that has also different colours... On level_3 there's even another type (and started trying this one on A8 and have to say is tricky but sure will get it 😞 So here's all types and with the A8 colourings: Please notice that then new ones on CPC are green (not possível on A8) but not correct because horizontally have 3lines while vertically have 2. Sure os because of then resolution but could bem other way to solve this. On A8 they're the same only changing direction and I think that the gray & white goes well with the blue 'point'. Some little changes: a.)- Cybernoid I level_3 line_1 screen_1a.xex All them can work and every other design (have more but not much different)... 1 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted May 26, 2023 Share Posted May 26, 2023 (edited) There's the possibility to walls have cyan and blue on the outside lines so it'll follows the rule on the other more commonly used (here on the bottom): Cybernoid I level_3 line_1 screen_1a _cyan and blue.xex Edited May 26, 2023 by José Pereira 6 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted June 2, 2023 Share Posted June 2, 2023 (edited) After thousands of tries...: For sure (I think ) is this the 'choosen one': Cybernoid I level_3 line_1 screen_1a _cyan and blue _white and gray opposite _but white and gray in middle.xex Edited June 2, 2023 by José Pereira 7 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted June 2, 2023 Share Posted June 2, 2023 (edited) On 5/24/2023 at 3:27 PM, José Pereira said: Forgot to also change the top wall: Cybernoid I level_3 line_1 screen_1b.xex 4.82 kB · 1 download Please notice that because of A8 colouring 'via' PMGs and PFs colours dli (like is this case) they're maybe, just a couple of times (not too much though ...) that can't there have the blue & cyan (or on other cases the gray), like also here: Cybernoid I level_2 line_2 screen_2 _to use M0 & M1.xex 4.98 kB · 3 downloads It's allmost unoticeable, I think... And, for this particular screen, in top I can make it a bit more blueish now: Cybernoid I level_3 line_1 screen_1a _cyan and blue _white and gray opposite _but white and gray in middle.xex Edited June 2, 2023 by José Pereira 6 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 7, 2023 Share Posted August 7, 2023 Cybernoid! Cybernoid! Cybernoid! 2 1 2 Quote Link to comment Share on other sites More sharing options...
Steril707 Posted August 8, 2023 Share Posted August 8, 2023 CYBERNOID! CYBERNOID! 1 1 1 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted August 8, 2023 Share Posted August 8, 2023 Cybernoid! Logic: 3, 2, 1... GO! 1 Quote Link to comment Share on other sites More sharing options...
