Gunstar Posted July 9 Share Posted July 9 Wizard's Watch. 41 colors. GS_WizardsWatch.xex 12 Quote Link to comment Share on other sites More sharing options...
Gunstar Posted July 9 Share Posted July 9 Cleric's Guard. 80 color's. GS_ClericsGuard.xex 8 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 9 Share Posted July 9 Traveler colors: 29 plus src Atari8man_Traveler.xex 10 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 9 Share Posted July 9 City Train colors: grayscale plus src Atari8man_City_Train.xex 16 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 Ancient Assyrian Colors: 40 plus src Atari8man_Ancient_Assyrian.xex 17 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 Moon Final Colors: 22 plus src * This is a fix version of the Moon I posted about 6 months ago - Really happy with it now * Atari8man_Moon_Final.xex 11 Quote Link to comment Share on other sites More sharing options...
ClausB Posted July 10 Share Posted July 10 15 hours ago, Atari8man2004 said: Traveler colors: 29 plus src Atari8man_Traveler.xex 22.18 kB · 6 downloads Why stretched? Planets are round. Quote Link to comment Share on other sites More sharing options...
ClausB Posted July 10 Share Posted July 10 4 hours ago, Atari8man2004 said: Moon Final Colors: 22 plus src * This is a fix version of the Moon I posted about 6 months ago - Really happy with it now * Atari8man_Moon_Final.xex 19.83 kB · 3 downloads Nice and round! 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 10 Share Posted July 10 15 minutes ago, ClausB said: Why stretched? Planets are round. are you viewing this PAL RC XEX on an NTSC as that would account for it appearing stretched presumably? When I view the above moon image on Altirra (Pal) it is perfectly round. Quote Link to comment Share on other sites More sharing options...
José Pereira Posted July 10 Share Posted July 10 (edited) 17 minutes ago, Beeblebrox said: are you viewing this PAL RC XEX on an NTSC as that would account for it appearing stretched presumably? When I view the above moon image on Altirra (Pal) it is perfectly round. He's refering to image is a bit oval and should be more circle: The oval form is indeed more pronounced at the left side: Edited July 10 by José Pereira 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 10 Share Posted July 10 PAL pixels are closer to square where NTSC are tall/skinny - so that image would be closer to round if switched to NTSC. The likely cause assuming the original was round would be aspect ratio error when converting to a resolution suitable for RC. Quote Link to comment Share on other sites More sharing options...
José Pereira Posted July 10 Share Posted July 10 (edited) 6 minutes ago, Rybags said: PAL pixels are closer to square where NTSC are tall/skinny - so that image would be closer to round if switched to NTSC. The likely cause assuming the original was round would be aspect ratio error when converting to a resolution suitable for RC. yes, if you have the image 1:1 ratio (160x) pixels seems maybe @Atari8man2004 streched it 2x? This way seems now a bit oval also but vertically... Edited July 10 by José Pereira Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 4 hours ago, José Pereira said: yes, if you have the image 1:1 ratio (160x) pixels seems maybe @Atari8man2004 streched it 2x? This way seems now a bit oval also but vertically... The image is surreal making it fit on a 320x240 requires chopping so the choice was to cut the astronaut in half or get everthing in the picture with a little strech I went with the later. It's a work in Progress and I posted the source. 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 4 hours ago, ClausB said: Nice and round! I converted this image 5 or 6 times there was lots of problem with color bleeding and horizontal line with the first post. Getting it to where it is now there still a little color bleeding but it's close enough and the ratio is good " little chopping was done " so it's final I can now move to one of my other post that can use a bit more work. Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 3 hours ago, Rybags said: PAL pixels are closer to square where NTSC are tall/skinny - so that image would be closer to round if switched to NTSC. The likely cause assuming the original was round would be aspect ratio error when converting to a resolution suitable for RC. Fitting this image in a 4:3 crt ratio would req adding space to the horizontal this may make the bottom of the image to small to render the "astronaut" with rasta pixel size but I'm not sure it must be tested. The other is cropping the image cutting most of the astronaut away maybe only the head would remain but I'm also not sure and would need to be tested. Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 Traveler final It will work with little loss I'll post it when it's done cooking.. 2 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 10 Share Posted July 10 Traveler final Colors: 27 plus src Atari8man_Travler_Final.xex 9 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 11 Share Posted July 11 20 hours ago, José Pereira said: He's refering to image is a bit oval and should be more circle: The oval form is indeed more pronounced at the left side: It's fine, I thought Claus was referring to the moon image, not the traveller image. That will teach me to look at forums on a small mobile screen whilst commuting. Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 11 Share Posted July 11 9 hours ago, Beeblebrox said: It's fine, I thought Claus was referring to the moon image, not the traveller image. That will teach me to look at forums on a small mobile screen whilst commuting. We're all good here I also get confused with messages and quotes. The rescaling worked with little loss I was worried that rescaling would render the astronaut unrecognizable due to Raster pixel size but it worked. The other image of the moon that I posted 5 or 6 months ago I was never happy with that image I went back into it like 5 times there were many issues with color bleeding and horizontal line but now i'm happy with it and it looks very good. Gunstar posted some images of Wizards at the top of the page I have not done any wizards or mages and my do some in the near future. 5 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted July 17 Share Posted July 17 Not one of my best conversions, but it reminded me of the Louis Wain cat series. Majoras' Mask, 84 colours. Stephen_MajorasMask.xex 4 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 23 Share Posted July 23 (edited) Mage colors: 44 plus src I have not ran this on my 8bit yet hope its ok. Atari8man_Mage.xex Edited July 23 by Atari8man2004 16 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted July 23 Share Posted July 23 (edited) 31 minutes ago, Atari8man2004 said: Mage colors: 44 plus src I have not ran this on my 8bit yet hope its ok. Atari8man_Mage.xex 22.18 kB · 0 downloads Some way to have better defined 3 or 4pixels wide red/punk face to see noose, top and around the to black eyes. Still looking amazing as is but right now the noose is just 2pixels wide with all around black... And the beard also would win ir Grays possível instead of blues but probably not possível due to the already maximum in-line number of colours? Edited July 23 by José Pereira 1 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 23 Share Posted July 23 Orwell 2024 Colors: Monochrome plus src Atari8man_Orwell.xex 8 4 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 23 Share Posted July 23 Mage II colors: 75 plus src Atari8man_Mage_II.xex 11 Quote Link to comment Share on other sites More sharing options...
Atari8man2004 Posted July 24 Share Posted July 24 Jester Stories Colors: 54 plus src Atari8man_Jester_Stories.xex 11 1 Quote Link to comment Share on other sites More sharing options...
