craftsman1234 Posted November 10, 2023 Share Posted November 10, 2023 On 11/8/2023 at 3:19 PM, nanochess said: I found the source code of the SGM test utility. Fortunately, I had a backup because my laptop hard drive crashed in 2014. I made it to jump to the sound test code even if only a 1K Colecovision is found, also enabled the code for a walking piggy on the screen (I didn't enable it at the time because I was going to use it for a game, but never went to it) When the music finishes it allows you to press the keys 1 to 6 in order to test each of the SN76489 channels, and the AY-3-8910 channels. cc @mytek Also when the music finishes, you can move the pig using the stick. sgm_test_v2.rom 8 kB · 6 downloads Thanks for doing this I was finally able to test this on my ColecoVision and Adam. It does bring up and interesting thing for me on the ColecoVision. I am using a F18a (Clone using a Tang Nano) In both. Different topic altogether I know. I've always thought that the Tang was making or something in the Coleco system run faster which leads to crashes in games like Donky Kong. When playing the music it seems to be twice as fast in the Coleco then the Adam. So strange but with this test I can clearly hear it. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 11, 2023 Share Posted November 11, 2023 17 hours ago, craftsman1234 said: Thanks for doing this I was finally able to test this on my ColecoVision and Adam. It does bring up and interesting thing for me on the ColecoVision. I am using a F18a (Clone using a Tang Nano) In both. Different topic altogether I know. I've always thought that the Tang was making or something in the Coleco system run faster which leads to crashes in games like Donky Kong. When playing the music it seems to be twice as fast in the Coleco then the Adam. So strange but with this test I can clearly hear it. Maybe it is refreshing the screen at double rate, or it needs a pull-up on the Interrupt pin. Quote Link to comment Share on other sites More sharing options...
craftsman1234 Posted November 11, 2023 Share Posted November 11, 2023 34 minutes ago, nanochess said: Maybe it is refreshing the screen at double rate, or it needs a pull-up on the Interrupt pin. Interesting may give that a try. Quote Link to comment Share on other sites More sharing options...
craftsman1234 Posted November 11, 2023 Share Posted November 11, 2023 1 hour ago, nanochess said: Maybe it is refreshing the screen at double rate, or it needs a pull-up on the Interrupt pin. Just to clarify. I'd putt something like a 4.7k resister between pins 12 and 16? +----+--+----+ RAS* |1 o 40| XTAL2 CAS* |2 39| XTAL1 AD7 |3 T 38| CPUCLK R-Y on TMS9928A/TMS9929A AD6 |4 M 37| GROMCLK AD5 |5 S 36| COMVID Y on TMS9928A/TMS9929A AD4 |6 35| EXTVDP B-Y on TMS9928A/TMS9929A AD3 |7 9 34| RESET*/SYNC AD2 |8 9 33| Vcc AD1 |9 1 32| RD0 AD0 |10 8 31| RD1 R/W* |11 A 30| RD2 Vss |12 29| RD3 MODE |13 28| RD4 CSW* |14 27| RD5 CSR* |15 26| RD6 INT* |16 25| RD7 CD7 |17 24| CD0 CD6 |18 23| CD1 CD5 |19 22| CD2 CD4 |20 21| CD3 +------------+ Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 11, 2023 Share Posted November 11, 2023 6 minutes ago, craftsman1234 said: Just to clarify. I'd putt something like a 4.7k resister between pins 12 and 16? +----+--+----+ RAS* |1 o 40| XTAL2 CAS* |2 39| XTAL1 AD7 |3 T 38| CPUCLK R-Y on TMS9928A/TMS9929A AD6 |4 M 37| GROMCLK AD5 |5 S 36| COMVID Y on TMS9928A/TMS9929A AD4 |6 35| EXTVDP B-Y on TMS9928A/TMS9929A AD3 |7 9 34| RESET*/SYNC AD2 |8 9 33| Vcc AD1 |9 1 32| RD0 AD0 |10 8 31| RD1 R/W* |11 A 30| RD2 Vss |12 29| RD3 MODE |13 28| RD4 CSW* |14 27| RD5 CSR* |15 26| RD6 INT* |16 25| RD7 CD7 |17 24| CD0 CD6 |18 23| CD1 CD5 |19 22| CD2 CD4 |20 21| CD3 +------------+ It would be 33 and 16. Quote Link to comment Share on other sites More sharing options...
craftsman1234 Posted November 11, 2023 Share Posted November 11, 2023 6 minutes ago, nanochess said: It would be 33 and 16. gotcha. thanks 1 Quote Link to comment Share on other sites More sharing options...
