Marius Posted July 21, 2014 Share Posted July 21, 2014 In private conversation I already asked you to swap power supply and on march 6th you responded you did that with no luck (same issue) What makes you think that it will cure your problem this time? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 21, 2014 Share Posted July 21, 2014 Because his stuff works without issue on a 2 amp PSU. Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted July 21, 2014 Author Share Posted July 21, 2014 (edited) In private conversation I already asked you to swap power supply and on march 6th you responded you did that with no luck (same issue) What makes you think that it will cure your problem this time? You are right. We excluded this possibility, because I already swapped the PS. That is, why I sent flashjazzcat everything BUT the PS. No doubt, the flashing of the Ultimate went wrong. Maybe because a faulty power supply. Although I changed it - maybe changed it with one with the same problem? I don't know. I just have no other idea. Well, flashjazzcat made it running again by (re)flashing the Ultimate. I will build a "new" PS with a meanwell switched-mode power supply. Double checking it with a Ozziscope. Let's see what happens then. Whatever, I'd like to say thank you and flashjazzcat for the help and endurance. Maybe this story is " to be continued" ... but I'll let you know ! Stefan Edited July 21, 2014 by Stefan Both Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted August 19, 2014 Author Share Posted August 19, 2014 Hello again, just to keep you up to date I got a Power Supply normally used for a USB 3.0 Hub. 5.0 Volts, 2.5 Amps. Changed the plug - last check - plugged it in... It works !!! Played the Numen Demo, started AtariWriter from a partition of the MyIde II, played games from the Sio2SD or from the image menu of the MyIde II. Flashjazzcat: The MyDosBios is the "older one" ? The last (lowest) entry (Sidexxxthing) is red. But I can bypass it, by "starting the cartridge" and enter the FatLoader. No problem at all - just wondering. You did a great job!!! Thank you !!! (I'll test the whole process, if I'm with the atari boys on the classic-computing'14 just to be able to catch at a straw - in the worst case) Greetings Stefan Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 19, 2014 Share Posted August 19, 2014 Flashjazzcat: The MyDosBios is the "older one" ? The last (lowest) entry (Sidexxxthing) is red. But I can bypass it, by "starting the cartridge" and enter the FatLoader. No problem at all - just wondering. I think I used the MYBIOS that ProWizard recommended to us for the job. The rest I have no idea about: when I set up your machine, it was the first (and probably last) time I used MYBIOS. Anyway - glad things are working for you Stefan. Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted September 23, 2014 Author Share Posted September 23, 2014 Dear prowizzard, Today I followed your step by step Manual. After playing around with different Beta versions, it was neccesary to switch back. Everything was fine. Did it without any probs. It probably was the powersupply that made things going wrong first time. Maybe the very first flash made the problems, occured much later? Whatever... Is it possible to set a "conclusion" at the beginning of the thread and close it? It was a bit confusing today to crawl through... just in case, somebody is interested / has the same problems Stefan Quote Link to comment Share on other sites More sharing options...
