+MrFish Posted April 7, 2014 Share Posted April 7, 2014 (edited) 44 I only counted the first pic. The second pic is using some kind of filtering (bilinear, bicubic, etc.), which will end up giving the color count some ridiculously high number. But I do see you have the enemy sprite multiplexer in it. So I'm sure the actual color count is quite a bit higher than the first one. Edited April 7, 2014 by MrFish Quote Link to comment Share on other sites More sharing options...
8Bitjunkie Posted April 7, 2014 Share Posted April 7, 2014 I have to beat the amiga version which has something between 32 and 64 colors (32 colors + half bright shadow).. :-) 1 Quote Link to comment Share on other sites More sharing options...
Sikor Posted April 7, 2014 Share Posted April 7, 2014 Hmm, Sexy Six plus 3 data disks for it Orto Puzzle Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted April 8, 2014 Share Posted April 8, 2014 Two to add to the list: Cygnus X3 (I think that's the name) and Winter Games, both of which use the APAC 256 color mode. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 8, 2014 Share Posted April 8, 2014 (edited) Here's some more: Bomb Jack (25) Break It (28) Calisto (45, Thanks to Sodding Rainbow© Technology) Capture The Flag (24) Cavernia (17) Choplifter (22) Clowns & Balloons (17) Crack-Up (29) Crownland (22) Dyna Blaster (19) ECKN (19) G.A.C.C.R.R. (22) Galaxian (44) Getris (29, Blended) Gunpowder Charlie (43) IK+ (27) Inside (17) Jet Boot Jack (17) Jetboy (21) Joe Blade (17) Joe Blade II (17) Koffi - Yellow Copter (21) Labyrinths (18) Loco (18) M.A.S.H. (23) Mahjong XE (17) Marbled (29) Mashed Turtles (33) Master Of The Lamps (17) Miner 2049'er (18) Mr. Robot & His Robot Factory (19) Murder on the Zinderneuf (19) Nightmares (18) Pacific Coast Highway (19) Plastron (23) Pogotron (57) Preppie (23) Revenge of the Mutant Camels (20) River Raid (27) Rocks (24) Seaquest (23) Snowball (31) Star Rider (73) Star Trek (17) Stargate Courier (17) Stealth (25) Timeslip (47) Track & Field (18) Tree Surgeon (17) Trivial Pursuit (17) Unicorn Horn (23) Wall War (25) Wizard (17) Yie Ar Kung-Fu (24) Edited April 8, 2014 by MrFish 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 8, 2014 Share Posted April 8, 2014 I came up with these just from cartridge games (except WKC, which was just a special cartridge image). There should be plenty more on disk and binary files: Atlantis (39) Bounty Bob Strikes Back (22) Crossbow (19) Demon Attack (17) Frogger (25) Frogger II (24) HERO (20) Popeye (17) Pole Position (22) World Karate Championship / IK (19) Zenji (24) Correction, HERO is 25 or more. It should also be noted that others could potentially have higher counts depending on what is on the screen at a given time. These, and the other lists I posted, are all counted from the particular screenshots that I took. 1 Quote Link to comment Share on other sites More sharing options...
Reaperman Posted April 9, 2014 Share Posted April 9, 2014 Since we're on the subject of color count, could somebody maybe give me a very basic explanation of how all these pretty colors wind up in games? Not too many details, just the 10,000ft view of it or a good recommendation for further reading on the subject. To give an idea of my low skill level on the subject, the most I've ever worked with is 4. Quote Link to comment Share on other sites More sharing options...
kenjennings Posted April 9, 2014 Share Posted April 9, 2014 4 color registers for the playfield. 4 color registers for the players/missiles 1 more color register shared between the playfield and player/missiles. at any vertical row of the screen a display list interrupt can change any/all the register values, and this can be done multiple times per screen. (down to each scan line if you're determined.) also, different priority settings let two players' color mix to create three colors. and priority settings can cause the players/missiles' colors to mix with the playfield, creating new colors... (the total possible colors from priority/playfield/player-missile mixing is 23 colors including the background.) Then there is page flipping -- swapping between two different graphics patterns/palettes every frame averages the colors together, and can produce even more apparent colors..... Then there's mixing different GTIA modes, and PAL blending, etc, etc, etc. 3 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 9, 2014 Share Posted April 9, 2014 4 color registers for the playfield. 4 color registers for the players/missiles 1 more color register shared between the playfield and player/missiles. at any vertical row of the screen a display list interrupt can change any/all the register values, and this can be done multiple times per screen. (down to each scan line if you're determined.) also, different priority settings let two players' color mix to create three colors. and priority settings can cause those players' colors to mix with the playfield, creating new colors... (the total possible colors from priority/playfield/player-missile mixing is 23 colors including the background.) Then there is page flipping -- swapping between two graphics patterns/palettes every frame averages the colors together, and can produce even more apparent colors..... Then there's mixing different GTIA modes, and PAL blending, etc, etc, etc. You beat me to it... Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 9, 2014 Share Posted April 9, 2014 (edited) To give an idea of my low skill level on the subject, the most I've ever worked with is 4. If you've worked with 4 color mode before, then the easiest way to add more colors before learning about player/missile graphics and display list interrupts is to use one of the 3 GTIA special modes. They work similarly to any basic bit-mapped playfield mode on the Atari using BASIC. One mode offers 9 indirected colors, one gives 16 luminances of any single color, and the last one gives you all 16 base colors with the same luminance. The only catch is that the pixels are almost 4 times as wide as they are tall for these modes. But the added colors make them advantageous for certain applications. One of the best uses is for digitized photos. You can see a couple examples I did here using the mode with 16 luminances of any single color: GTIA Photo Examples Edited April 9, 2014 by MrFish 1 Quote Link to comment Share on other sites More sharing options...
Creature XL Posted April 9, 2014 Share Posted April 9, 2014 I want to add mine too HAR'em (18) yeah the player sprite has 6 Heli (20+) in the game over screen Else should be 13 max depending on sprites on screen. 1 Quote Link to comment Share on other sites More sharing options...
TMR Posted April 9, 2014 Share Posted April 9, 2014 i think Battle Eagle can clear the 40 colour mark on occasions...? 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 12, 2014 Share Posted April 12, 2014 Here's a couple more: Laser Gates (81) Scooter (21) I guess these all get "honorable mention": Ballblazer (16) Black Lamp (15) Contagion (15) Crimebuster (15) Eastern Front (16) Flip & Flop (15) h3x0r Deluxe (15) Jungle Hunt (15) Kik-Start (15) L.A. Swat (16) Mind Blast (15) Ninja (15) Pad (15) Rampage (16) Reaxion (16) Spy's Demise (15) Squish 'Em (15) Up Up And Away (15) Wloczykij (16) 2 Quote Link to comment Share on other sites More sharing options...
snicklin Posted April 12, 2014 Share Posted April 12, 2014 I think that with this topic that we need to remember that some games will use 4 colours on the screen and then stick a rainbow at the bottom which doesn't really fit the ethic of this topic. Some games were very clever in how they used their colour. I'd include Black Lamp and Henry's House in these. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted April 12, 2014 Author Share Posted April 12, 2014 Thetris (26) 2 Quote Link to comment Share on other sites More sharing options...
TMR Posted April 12, 2014 Share Posted April 12, 2014 Reaxion (16) i only remember it having fourteen or fifteen...? Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 13, 2014 Share Posted April 13, 2014 i only remember it having fourteen or fifteen...? I thought so too at first. But then when I noticed the blinking lights at the top and bottom and snapped a pic when they were lit, I was able to get 16. Quote Link to comment Share on other sites More sharing options...
TMR Posted April 13, 2014 Share Posted April 13, 2014 I thought so too at first. But then when I noticed the blinking lights at the top and bottom and snapped a pic when they were lit, I was able to get 16. Just goes to show how long ago it was that i wrote the thing... it'll be ten next year! Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 13, 2014 Share Posted April 13, 2014 Just goes to show how long ago it was that i wrote the thing... it'll be ten next year! Hard to believe. I remember when I was looking forward to the release back then. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted April 13, 2014 Author Share Posted April 13, 2014 Paul, your memory is outstanding! Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted April 14, 2014 Share Posted April 14, 2014 I just played Jet Boot Jack and thought it was colorful. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 14, 2014 Share Posted April 14, 2014 (edited) Paul, your memory is outstanding! My girlfriend doesn't seem to think so. If only she'd learn to talk about Ataris with me, then I'd at least be able to remember part of what she says. Edited April 14, 2014 by MrFish 2 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted April 14, 2014 Share Posted April 14, 2014 My girlfriend doesn't seem to think so. If only she'd learn to talk about Ataris with me, then I'd at least be able to remember part of what she says. Girls and Atari doesn't match. When I had my 800XL working the only game that my ex ever tried to play was Bang Bank but only a couple of times because she wasn't all that great.I don't know how was there on your countries but here on 80s and 90s computers&games were mainly for boys. I don't remember any girl at school talking about or having a computer. Psst, Moderators please don't read this: I think that the girls prefer other sort of joysticks... LOL!... Quote Link to comment Share on other sites More sharing options...
+Adam+ Posted April 27, 2014 Share Posted April 27, 2014 Some other games: those which use graphics mode 9: Colony 7 (22 colours), Disc Hopper (sometimes more than 60), Space Lobsters (23) simple "Atari rainbow" effect all over the screen: Saracen (22) more sophisticated use of colours: Technoid (31) 5 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted August 22, 2014 Author Share Posted August 22, 2014 Here's the list of good games with more than 16 colors, thank you very much for your help! GAME COLORS Alley Cat 22 Alternate Reality - The City 38 Alternate Reality - The Dungeon 38 Assembloids XE 29 Atari Blast! XX WIP Atlantis 39 Battle Eagle 33 Bomb Jack 25 Bounty Bob Strikes Back 22 Break It 28 Callisto 45 Capture The Flag 24 Cavernia 17 Choplifter 22 Clowns & Ballons 17 Crack-Up! 29 Crossbow 19 Crownland 22 Cygnus X1 31 Decathlon 39 Demon Attack 17 Dimo's Quest WIP 44 Disc Hopper 60+ Dropzone 18 Dyna Blaster 19 Eckn+ 19 Flower Mania 32 Frogger 25 Frogger II 24 Galaxian 47 Getris 29 Great American Cross - Country Road Race 22 H.E.R.O. 25 Henry's House 21 International Karate 19 IK+ WIP 27 Inside 17 Jet Boot Jack 17 Jetboy 21 Joe Blade 17 Joe Blade II 17 Koronis Rift 30 Laser Gates 81 Marbled 29 Mashed Turtles 33 Master of the Lamps 17 Mahjong XE 17 Miner 2049er 18 Murder on the Zinderneuf 19 Nightmares 18 Ocean Detox 24 Pitfall II 20 Plastron 23 Pogotron 57 Pole Position 22 Popeye 17 Preppie 23 Rainbow Walker 34 Revenge of the Mutant Camels 20 Ridiculous Reality 28 River Raid 27 Rocks 24 Rolltris 25 Saracen 22 Scooter 21 Seaquest 23 Space Lobsters 23 Star Raiders II 22 Star Rider 73 Star Trek 17 Stealth 25 Technoid 31 Timeslip 47 Track & Field 18 Tree Surgeon 17 Trivial Pursuit 17 Unicorn Horn 23 Wall, The 64 Wall War 25 Wizard 17 X:8 25 Yar's Strike 28 Yie Ar Kung-Fu WIP (24) Zenji 24 Quote Link to comment Share on other sites More sharing options...
