ryoder Posted December 30, 2015 Share Posted December 30, 2015 (edited) Here is a closeup of Civilization. You can see jail bars on the bottom. I'll get better pics. Edited December 30, 2015 by ryoder Quote Link to comment Share on other sites More sharing options...
calimero Posted December 30, 2015 Share Posted December 30, 2015 I really did not notice them until you mention jailbars... I am not at home right now but from photos I would say that they are present! These are images that I took while Amiga 500 was connected to NEC 1970NX... Quote Link to comment Share on other sites More sharing options...
ryoder Posted December 31, 2015 Share Posted December 31, 2015 The jail bars look worse in person than in my pics. It's almost unusable. Quote Link to comment Share on other sites More sharing options...
calimero Posted December 31, 2015 Share Posted December 31, 2015 The jail bars look worse in person than in my pics. It's almost unusable. hm... that is not case with my Nec1970. But maybe it will be visible in games... I just run demos on Nec so far, not games. I must try Civilization .... Quote Link to comment Share on other sites More sharing options...
shazzner Posted January 11, 2016 Share Posted January 11, 2016 Has anyone had luck connecting an 8bit (including c64) to these? Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted January 11, 2016 Share Posted January 11, 2016 You cannot connect a C64 as it doesn't have RGB - just composite and S-Video. You might have some luck with the Spectrum as that outputs RGB. I just use a GBS-8220 for my Amiga and ST. Quote Link to comment Share on other sites More sharing options...
bluemonday Posted January 11, 2016 Share Posted January 11, 2016 I tried cables with several different wiring combinations but never managed to get my Jaguar working with it via VGA. Likewise I did some investigations about connecting my Spectrum +3 but was told it wasn't possible. Quote Link to comment Share on other sites More sharing options...
galax Posted January 15, 2016 Author Share Posted January 15, 2016 (edited) hm... that is not case with my Nec1970. But maybe it will be visible in games... I just run demos on Nec so far, not games. I must try Civilization .... I have two 1970VX monitors and haven't seen any jail bars on either of them, lots of photos on page 1 of this thread. One of my STs gives a few strange other video artifacts though, with the same cable and monitor that works perfectly with other STs. My thought was that some of the video generating components are probably aging. Edited January 15, 2016 by galax Quote Link to comment Share on other sites More sharing options...
ryoder Posted January 22, 2016 Share Posted January 22, 2016 I am now playing with Genesis over scart to hdmi on a LCD tv. I have extremely minor jail bars there and I think it's fixable by going to a different type of sync or disabling the composite signal because sync is on composite. Is this possible on a ST? Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 22, 2016 Share Posted January 22, 2016 Hello guys, I've just got myself a VGA cable / BenQ BL702A which is listed on the Atari Wiki page as compatible. http://www.atari-wiki.com/index.php/Multisync_flatscreens Well, all is fine and it works lovely in ST High on my Mega STe. So all good. Now I'm wondering just how do I make it work in ST Low (not bothered about Medium res). I've read the techie comments above but I'm not very technically minded with hardware, wiring, soldering, etc. Well, I'm more like zero on this subject so I'm a bit confused to say the least... Just what exactly do I need in order to make it work in ST Low? Go easy - plain English replies please! Thanks, Steve. Quote Link to comment Share on other sites More sharing options...
calimero Posted January 23, 2016 Share Posted January 23, 2016 It is quite easy to make DIN13 (Atari STe video port) to VGA cable. http://info-coach.fr/atari/hardware/interfaces.php#vga_color_cable Do you know how to use iron solder? Or you can buy new cable at http://www.ebay.com/itm/ATARI-ST-VGA-MONITOR-ADAPTER-WITH-SOUND-LEAD-CABLE-/320526274539 Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 23, 2016 Share Posted January 23, 2016 Well, umm quite easy but not for me hehe. I've got the VGA cable already and it's all working in ST High res fine. A good friend tells me to simply disconnect the wire inside the cable which is for mono. So I'm thinking of going down that route! This is the cable I bought : http://www.ebay.co.uk/itm/390236060251?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Of course, I have a VGA extension cable from that into the monitor... It's only an extension cable so I'm thinking of cutting that open. If I break it (which I probably will!!) then I'll grab another I have spare. But I don't really understand the pin layouts, so I'll take a longer look at the link there above. Gotta get my BenQ BL702A running in ST Low ... Thanks :-) Quote Link to comment Share on other sites More sharing options...
calimero Posted January 23, 2016 Share Posted January 23, 2016 at link http://info-coach.fr/atari/hardware/interfaces.php#vga_color_cableyou have two section: VGA Monochrome Cable VGA Color Cable key difference is if pin number 4 (called "Monochrome Detect" on DIN13 connector) is grounded or not (this will decide if ST will but in Mono 640x400 or Color 320x200 resolution). Grounded means if pin is connected to "ground" GND pin (in this case it is pin 13). It would be best to put switch between pin 4 and 13 so if it has contact ST will boot in mono and if it has no contact it will boot in color. Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 23, 2016 Share Posted January 23, 2016 Ah, so somehow get that pin 4 connected to the GND and the STE boots up in colour mode rather than mono? Okay, I understand that. So just cutting the wire wouldn't work then? Why can't us ST users simply buy a cable like this? Yep, a cowardly move on my part but I've no idea how to alter pins or solder stuff like this. I'd end up burning myself or the house down lol. Sorry, unlike your good self this is like star trek to me mate :S Time to google and see if there's any being made/sold... Quote Link to comment Share on other sites More sharing options...
calimero Posted January 24, 2016 Share Posted January 24, 2016 (edited) if you want I will make video: "how to add mono/color switch to cable" tonight? btw when pin 4 for is open (not connected to GND) ST will boot in color (it will gave color image on TV modulator output and on DIN13). Cable that you have is for mono so internaly he connect pin4 to GND and ST boot in mono mode (if you want, you could simple cut pin4 wire in that cable and ST will boot in color; if you add switch on cuted wire than you could switch between color and mono). Edited January 24, 2016 by calimero Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 24, 2016 Share Posted January 24, 2016 PM sent Quote Link to comment Share on other sites More sharing options...
calimero Posted January 24, 2016 Share Posted January 24, 2016 I EDIT MY POST IN MEANTIME !!! when pin 4 for is open (not connected to GND) ST will boot in color (it will gave color image on TV modulator output and on DIN13).Cable that you have is for mono so internaly he connect pin4 to GND and ST boot in mono mode (if you want, you could simple cut pin4 wire in that cable and ST will boot in color; if you add switch on cuted wire than you could switch between color and mono). Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 24, 2016 Share Posted January 24, 2016 Ummm right... So, the VGA adapted cable I bought of eBay http://www.ebay.co.uk/itm/390236060251?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT THAT's the pin 4 that needs taking out? Thanks mate, I'll pass this info on. Really appreciate your help Quote Link to comment Share on other sites More sharing options...
HuskyTE Posted January 24, 2016 Share Posted January 24, 2016 Hi! Be aware that on most Atari to Mono VGA cables, all the R, G, B, pins are soldered to pin 11 in the Atari side.So it's no so easy as disconnecting pin 4. Monochrome Atari VGA Audio Out 1 Opt. Audio connector Monochrome Detect 4+13 Connect to pin 13 H-Sync 9 13 Monochrome 11 1+2+3 (That's R,G,B.) V-Sync 12 14 GND 13 6+7+8+10 Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 24, 2016 Share Posted January 24, 2016 Thanks very much :-) Quote Link to comment Share on other sites More sharing options...
calimero Posted January 25, 2016 Share Posted January 25, 2016 (edited) Here is a closeup of Civilization. You can see jail bars on the bottom. I'll get better pics. I made test picture. Load this on Atari and than adjust H.SIZE on Nec so every vertical line is displayed same. btw HuskyTE I did not know that on mono cable all thre RGB wire are connected to same pin... thanx! Edited January 25, 2016 by calimero Quote Link to comment Share on other sites More sharing options...
Osgeld Posted January 25, 2016 Share Posted January 25, 2016 well they are unless you want red pixels Quote Link to comment Share on other sites More sharing options...
galax Posted January 25, 2016 Author Share Posted January 25, 2016 (edited) THAT's the pin 4 that needs taking out? If you go back to page 1 of this thread, you'll see that the ST has 4 video signal output pins: R, G, B, and Mono. When the Mono detect pin is grounded, the ST boots in high res and video is output on the Mono pin. When mono detect is not grounded, ST boots in low/med and video is output on R, G, and B. So cutting the mono pin on your ST mono cable will boot your ST in low res by default, but will cause no video to be output by your mono cable. Best Electronics sells a colour/mono switchable cable for US$55: http://www.best-electronics-ca.com/monadapt.htm I could build a cable like this, but not for much less than Best sells it for (although shipping might be cheaper as they use a courier service). For really cheap shipping, I'm going to be in Manchester at the end of March Edited January 25, 2016 by galax Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted January 25, 2016 Share Posted January 25, 2016 galax - thank you I'm passing on the info to my friend. He's already started to make the cable, I've seen a WIP pic of it. I think he's using some sort of magic, all this techno lark blows my mind anyhow!! Thank you for your kind off, appreciated. I'll let ppl know here the moment it's done and tested Quote Link to comment Share on other sites More sharing options...
galax Posted January 25, 2016 Author Share Posted January 25, 2016 (edited) galax - thank you I'm passing on the info to my friend. He's already started to make the cable, I've seen a WIP pic of it. I think he's using some sort of magic, all this techno lark blows my mind anyhow!! Thank you for your kind off, appreciated. I'll let ppl know here the moment it's done and tested Nice, I'm tempted to make some ST->Colour VGA cables up and put them on eBay. It's a lot easier to do put all the components inside the connector if you leave out the switch, and ST->Mono VGA cables are more common. After I do the external floppy connector cables I promised though, hopefully next month. Edited January 25, 2016 by galax 1 Quote Link to comment Share on other sites More sharing options...
