+Lee Stewart Posted August 23, 2020 Share Posted August 23, 2020 From PM 1, PeteE said: The "invalid cross-bank access" is supposed to prevent the programmer from accidentally trying to directly use a symbol that is in another bank. By default, you can only access symbols in a BANK ALL or the same bank. To create a valid cross-bank access, the symbol must be prefixed by "x#". There were quite a few of those, so I elected to disable the error in the assembler instead of updating them all. There is not much point in trying to keep this compatible with asm994a, so I probably should try to change those. Most all of them (I think) are the branches from bank 0 to body code in other banks, which all use the following (except for the initial label after DATA, which, I believe, all start with ‘_’): BL @BLF2A DATA _DIGIT->6000+BANK2 and should be pretty easy to find and replace with the regex mode of notepad++. From PM, PeteE said: For non-inverted cartridges, one way would be to use the .IFDEF preprocessor directive to choose between inverted and non .... This is a touch complicated by the fact that I do some explicit switching of banks, but, fortunately, not many instances of this. I could change those to labels to make it easier to use the preprocessor. Dealing with PC99 and any emulator that requires individual ROM-bank files may be a bit more complicated but probably doable. Thanks again. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 26, 2020 Share Posted August 26, 2020 Well, I got it to assemble, but the program does not work past the title screen. Other than fix all of the errors, I did the following: AORG >6000 BANK ALL <bank header that is same in all banks> AORG >6048 BANK 0 <bank 0 code> AORG >7FFE DATA >C000 AORG >6048 BANK 1 <bank 1 code> AORG >7FFE MYBANK DATA >8000 AORG >6048 BANK 2 <bank 2 code> AORG >7FFE DATA >4000 AORG >6048 BANK 3 <bank 3 code> AORG >7FFE DATA >0000 I have not analyzed the listing any more carefully than checking the header and what is at >7FFE in each bank—everything is where it should be. When I look at the binaries, which are 8 KiB each, there is nothing at >7FFE in the first three. The last one is a wash because it is supposed to be >0000. Any ideas? ...lee Quote Link to comment Share on other sites More sharing options...
PeteE Posted August 26, 2020 Share Posted August 26, 2020 Hi @Lee Stewart, after each AORG >7FFE, a BANK command is required. I ran into that problem when doing this myself also. I would suggest writing it as: AORG >6000 BANK ALL <bank header that is same in all banks> BANK 0 <bank 0 code> BANK 1 <bank 1 code> BANK 2 <bank 2 code> BANK 3 <bank 3 code> AORG >7FFE BANK 0 MYBANK DATA >C000 BANK 1 DATA >8000 BANK 2 DATA >4000 BANK 3 DATA >0000 The assembler will reset the $ to the same address after the header at the start of each bank, and the same goes for the MYBANK symbol at >7FFE. Does that make sense? The listing file should show that it works. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 26, 2020 Author Share Posted August 26, 2020 I second PeteE's suggestion, although the other way also works. The problem here is that AORG will not keep the previous bank, but resets it to "non-banked program", which results in a wonky state for banked programs. Thus, you need a BANK after each AORG (the same could probably be said for other *ORGs). I guess it'll be OK to keep the previous bank, maybe also issue a warning. My TODO list keeps on growing ... ? 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 26, 2020 Share Posted August 26, 2020 I have an AORG after a DORG. Once I straightened that out per your instruction, all hell broke loose. I now have those hundreds of cross-bank references to deal with and they are not all so easy to deal with as I thought. I realize that unintentional cross-bank access can be a problem, but the availability of labels from any bank (not part of branches) to all other banks (part of asm994a) is almost a necessity. This might be the deal breaker. ...lee 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 26, 2020 Author Share Posted August 26, 2020 The labels you put in shared segments (BANK ALL) are accessible in all banks. And if you know what you're doing, you can do cross-bank accesses by prefixing "x#" to the symbol in question. This shows some valid use of x#: https://github.com/endlos99/xdt99/blob/master/test/asm/asshbankx.asm BTW, as all ORGs, AORG + BANK n keeps track of the last used address for that bank and AORG, so in the example, bank 0 and bank 1 have the same addresses. As a rule of thumb: AORG should be followed by BANK, a BANK does not need a previous AORG if that bank has already been written to. In not entirely sure about your use case: Why would you access a symbol of a different bank, unless that symbol has the same value in all banks? Could you perhaps give a small example? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 26, 2020 Share Posted August 26, 2020 18 minutes ago, ralphb said: I’m not entirely sure about your use case: Why would you access a symbol of a different bank, unless that symbol has the same value in all banks? Could you perhaps give a small example? fbForth 2.0’s home bank is Bank 0. The other banks are used to branch to supporting code, but always come back to Bank 0 when the inner and outer interpreters are in control. With over 500 words, there was not enough room to have the whole dictionary in Bank 0, so I put the dictionary linked list of Link fields, Name fields and Parameter field pointers in Bank2, with only the Code Fields and actual Parameter fields in Bank 0. Guess where all of the Parameter field pointers in Bank 2 point with DATA statements. You guessed it—to Bank 0. This is all handled by trampoline code located in low RAM. Here is a short snippet of the headers at the top of the dictionary in Bank 2: * Dictionary headers have been split from the code and parameter fields in * bank 0 and placed here in bank 2 along with the guts of the words that * access them. DATA >0 <--end-of-line pfa search marker ;[*** EXECUTE *** DATA >0 EXEC_N DATA 7+TERMBT*LSHFT8+'E','XE','CU','TE'+TERMBT DATA EXECUT+2 ; pfa ptr ;]* ;[*** LIT *** DATA EXEC_N LIT_N DATA 3+TERMBT*LSHFT8+'L','IT'+TERMBT DATA LIT+2 ; pfa ptr ;]* ;[*** BRANCH *** DATA LIT_N BRAN_N DATA 6+TERMBT*LSHFT8+'B','RA','NC','H '+TERMBT DATA BRANCH+2 ; pfa ptr Here is a snippet from Bank 0 related to the above: ************************************************************************* * * EQUates for marker bits in name fields, a byte shifter and replacements * for some character combinations the Asm994a assembler chokes on: * TERMBT EQU >0080 Terminator bit PRECBT EQU >0040 Precedence bit SMDGBT EQU >0020 Smudge bit LSHFT8 EQU >0100 Multiplier to get low byte shifted into high byte * ************************************************************************* * ;[*** EXECUTE *** ( cfa --- ) * DATA >0 * EXEC_N DATA 7+TERMBT*LSHFT8+'E','XE','CU','TE'+TERMBT EXECUT DATA $+2 MOV *SP+,W B @DOEXEC * ;]* ;[*** LIT *** ( --- n ) * DATA EXEC_N * LIT_N DATA 3+TERMBT*LSHFT8+'L','IT'+TERMBT LIT DATA $+2 DECT SP MOV *IP+,*SP B *NEXT * ;]* ;[*** BRANCH *** ( --- ) * DATA LIT_N * BRAN_N DATA 6+TERMBT*LSHFT8+'B','RA','NC','H '+TERMBT BRANCH DATA $+2 A *IP,IP B *NEXT ;]* Taking the word LIT as an example, the text interpreter would search Bank 2 for the name LIT and, upon finding it, see that the pfa is LIT+2, which address is in Bank 0. The text interpreter will back that up 2 bytes to record the cfa (always Bank 0) as the next execution token. So you see, cross-bank label knowledge is critical to the current design of fbForth 2.0. ...lee Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted August 26, 2020 Share Posted August 26, 2020 25 minutes ago, ralphb said: The labels you put in shared segments (BANK ALL) are accessible in all banks. And if you know what you're doing, you can do cross-bank accesses by prefixing "x#" to the symbol in question. This shows some valid use of x#: https://github.com/endlos99/xdt99/blob/master/test/asm/asshbankx.asm BTW, as all ORGs, AORG + BANK n keeps track of the last used address for that bank and AORG, so in the example, bank 0 and bank 1 have the same addresses. As a rule of thumb: AORG should be followed by BANK, a BANK does not need a previous AORG if that bank has already been written to. In not entirely sure about your use case: Why would you access a symbol of a different bank, unless that symbol has the same value in all banks? Could you perhaps give a small example? I want to understand this too! I have used this code in a 32K cart version of "Bubble Plane", but with GenProg. Each level data is 16 row by 256 column (4K) RLE compressed (about 2K), in upper banks. Sound lists and char defs are up there too. Game code is all in bank 0. BANK0 EQU >6000 BANK1 EQU >6002 BANK2 EQU >6004 BANK3 EQU >6006 VDPBUF EQU >0010 * vdpwa address of uncompressed level data, swpb PADBUF EQU >8320 * 32 byte buffer that we use for moving data from vdp to vdp * trampoline code common to all banks LEVELS EQU $ DATA BANK1,CHARA1 DATA BANK1,LEVEL1 DATA BANK1,LEVEL2 DATA BANK2,LEVEL3 DATA BANK2,LEVEL4 * etc where LEVEL labels are each under DORG >6000, but intended for specific upper banks DATA BANK3,SNDLST * move some data from bank to vdp * R0 is vdp address * R1 is # index to LEVELS LOADLV EQU $ ANDI R0,>4000 SWPB R0 MOVB R0,*R15 * vdpwa SWPB R0 MOVB R0,*R15 * vdpwa SLA R1,2 AI R1,LEVELS MOV *R1,R3 MOV *R1,R1 SETO *R3+ * change bank, but this trampoline code is the same in all of them * R1 now maps into the bank MOV *R1+,R2 * length of level data * begin RLE decompressing level data into VDP RAM LOOP EQU $ * ... CI R1,>8000 JL LOOP SETO *R3+ * Cross bank boundary LI R1,>6000 JMP LOOP * when done: SETO @BANK0 RT So I guess for xdt99 my source would be LEVELS DATA BANK1,1#LEVEL1 DATA BANK1,1#LEVEL2 DATA BANK2,2#LEVEL3 DATA BANK2,2#LEVEL4 * source file with charset data AORG >6000+BANK 1 * source file with level data continues where charset data left off AORG >6000+BANK 1 LEVEL1 DATA ... LEVEL2 DATA ... * can I get this to wrap around to >6000 if it crosses a boundary? AORG >6000+BANK 2 * because I just know LEVEL3 starts in bank 2 LEVEL3 LEVEL4 * source file with sound data continues where level data left off AORG >6000+BANK 3 SNDLST Can I get xdt99 to have the data wrap around to >6000 in the next bank? I think GENPROG loaded relocatable 24K level data into 3 8K banks, each with base address >6000, and I had to hardcode what bank each level started in. Quote Link to comment Share on other sites More sharing options...
+9640News Posted August 26, 2020 Share Posted August 26, 2020 43 minutes ago, FarmerPotato said: I want to understand this too! I have used this code in a 32K cart version of "Bubble Plane", but with GenProg. Each level data is 16 row by 256 column (4K) RLE compressed (about 2K), in upper banks. Sound lists and char defs are up there too. Game code is all in bank 0. BANK0 EQU >6000 BANK1 EQU >6002 BANK2 EQU >6004 BANK3 EQU >6006 VDPBUF EQU >0010 * vdpwa address of uncompressed level data, swpb PADBUF EQU >8320 * 32 byte buffer that we use for moving data from vdp to vdp * trampoline code common to all banks LEVELS EQU $ DATA BANK1,CHARA1 DATA BANK1,LEVEL1 DATA BANK1,LEVEL2 DATA BANK2,LEVEL3 DATA BANK2,LEVEL4 * etc where LEVEL labels are each under DORG >6000, but intended for specific upper banks DATA BANK3,SNDLST * move some data from bank to vdp * R0 is vdp address * R1 is # index to LEVELS LOADLV EQU $ ANDI R0,>4000 SWPB R0 MOVB R0,*R15 * vdpwa SWPB R0 MOVB R0,*R15 * vdpwa SLA R1,2 AI R1,LEVELS MOV *R1,R3 MOV *R1,R1 SETO *R3+ * change bank, but this trampoline code is the same in all of them * R1 now maps into the bank MOV *R1+,R2 * length of level data * begin RLE decompressing level data into VDP RAM LOOP EQU $ * ... CI R1,>8000 JL LOOP SETO *R3+ * Cross bank boundary LI R1,>6000 JMP LOOP * when done: SETO @BANK0 RT So I guess for xdt99 my source would be LEVELS DATA BANK1,1#LEVEL1 DATA BANK1,1#LEVEL2 DATA BANK2,2#LEVEL3 DATA BANK2,2#LEVEL4 * source file with charset data AORG >6000+BANK 1 * source file with level data continues where charset data left off AORG >6000+BANK 1 LEVEL1 DATA ... LEVEL2 DATA ... * can I get this to wrap around to >6000 if it crosses a boundary? AORG >6000+BANK 2 * because I just know LEVEL3 starts in bank 2 LEVEL3 LEVEL4 * source file with sound data continues where level data left off AORG >6000+BANK 3 SNDLST Can I get xdt99 to have the data wrap around to >6000 in the next bank? I think GENPROG loaded relocatable 24K level data into 3 8K banks, each with base address >6000, and I had to hardcode what bank each level started in. GenPROG using GenLINK has the ability to use the BLOCK command for where you can load code to a specific range of addresses. It could be a block of only a couple of bytes, to 64K if one so desired. You would also likely use the PAGES command to specify the 8K pages. In the case of MDOS, I believe the PAGES identify to the 8K byte page number. I think MDOS at the Command Line Interface (CLI) limits you to something with something less than 64K taking into account the first >400 bytes of memory are OS oriented, and there is some restricted memory above >F000. However, you can use the DSR Load command in MDOS to load a program image file up to the available free memory range if you have previously requested those pages from the Memory DSR. Nothing says that each 8K block could have been previously identified with a PAGE number, and that block mapped to >6000->7FFF with your page reference being an offset into your list of requested memory pages. I hope that makes sense. Basically, you could have a 1.5 MB program image file loadable from a separate file if you had the extra memory, with each 8K block having been PAGE'd and BLOCK'd to be useable at any memory address range you desired. In addition, you could also have a BLOCK range to fit any graphics VIDEO range set if you wanted to copy a block of CPU memory to VDP memory for graphics. Lots of easy options on the MDOS side of things for handling CPU and/or video memory. Beery Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 27, 2020 Share Posted August 27, 2020 11 hours ago, Lee Stewart said: I have an AORG after a DORG. Once I straightened that out per your instruction, all hell broke loose. I now have those hundreds of cross-bank references to deal with and they are not all so easy to deal with as I thought. I realize that unintentional cross-bank access can be a problem, but the availability of labels from any bank (not part of branches) to all other banks (part of asm994a) is almost a necessity. This might be the deal breaker. Patching xas99.py to allow “cross-bank access” per @PeteE’s patch, allowed assembly, but the above-quoted solution for handling DORGed code does not work. The four required binaries are, indeed, created and Bank 0 appears to be correct, but the three binaries for Banks 1, 2 and 3 are now misaligned. Bank 0 continues at the proper place after the DORGed code, but the other banks now continue from the “BANK ALL” code at the address where the last “BANK 0” appeared after the DORGed code, which now misaligns each of those three banks by 54 bytes. It is as though the second “BANK 0” were treated like a “BANK ALL”. I want to use XORG, but fear the same complication. ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 27, 2020 Share Posted August 27, 2020 6 hours ago, Lee Stewart said: Patching xas99.py to allow “cross-bank access” per @PeteE’s patch, allowed assembly, but the above-quoted solution for handling DORGed code does not work. The four required binaries are, indeed, created and Bank 0 appears to be correct, but the three binaries for Banks 1, 2 and 3 are now misaligned. Bank 0 continues at the proper place after the DORGed code, but the other banks now continue from the “BANK ALL” code at the address where the last “BANK 0” appeared after the DORGed code, which now misaligns each of those three banks by 54 bytes. It is as though the second “BANK 0” were treated like a “BANK ALL”. I want to use XORG, but fear the same complication. The following workaround successfully re-aligns Banks 1, 2 and 3 after the second “BANK 0”: _AORG_PATCH EQU $ ; workaround anticipating 2nd "BANK 0" BANK 0 ; Without AORG patch applied farther below, the length of this section of Bank 0 ; code is how much misalignment would occur in Banks 1, 2, 3. <Bank 0 code> DORG 0 <DORGed code> AORG BANK 0 ; 2nd "BANK 0" causes misalignment of remaining banks <remaining Bank 0 code> AORG _AORG_PATCH ; workaround for 2nd "BANK 0" misalignment BANK 1 . . . fbForth 2.0 now boots up properly. I need to compare the binaries with the asm994a-assembled code before continuing with my updates. The MYBANK word (2 bytes) is at >7FFE in every bank. I am a reasonably happy camper. ...lee 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 27, 2020 Share Posted August 27, 2020 1 hour ago, Lee Stewart said: The following workaround successfully re-aligns Banks 1, 2 and 3 after the second “BANK 0”: _AORG_PATCH EQU $ ; workaround anticipating 2nd "BANK 0" BANK 0 ; Without AORG patch applied farther below, the length of this section of Bank 0 ; code is how much misalignment would occur in Banks 1, 2, 3. <Bank 0 code> DORG 0 <DORGed code> AORG BANK 0 ; 2nd "BANK 0" causes misalignment of remaining banks <remaining Bank 0 code> AORG _AORG_PATCH ; workaround for 2nd "BANK 0" misalignment BANK 1 . . . fbForth 2.0 now boots up properly. I need to compare the binaries with the asm994a-assembled code before continuing with my updates. The MYBANK word (2 bytes) is at >7FFE in every bank. I am a reasonably happy camper. ...lee That's great news Lee. Now that it builds what do these new tools buy you? Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 27, 2020 Author Share Posted August 27, 2020 20 hours ago, Lee Stewart said: fbForth 2.0’s home bank is Bank 0. ... Taking the word LIT as an example, the text interpreter would search Bank 2 for the name LIT and, upon finding it, see that the pfa is LIT+2, which address is in Bank 0. The text interpreter will back that up 2 bytes to record the cfa (always Bank 0) as the next execution token. So you see, cross-bank label knowledge is critical to the current design of fbForth 2.0. ...lee I see. If that is all, you'd need to prepend all references in bank 2 to bank 0 with x# -- or disable the cross-bank check. I'll make that an option. But how do you know if an address points to bank 0, 1, 2, ..., or n? The final program doesn't contain labels, just addresses. In your example, it just seems like a convention that the linked list is in bank 2, and interpreters in bank 0. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 27, 2020 Author Share Posted August 27, 2020 2 hours ago, Lee Stewart said: The following workaround successfully re-aligns Banks 1, 2 and 3 after the second “BANK 0”: _AORG_PATCH EQU $ ; workaround anticipating 2nd "BANK 0" BANK 0 ; Without AORG patch applied farther below, the length of this section of Bank 0 ; code is how much misalignment would occur in Banks 1, 2, 3. <Bank 0 code> DORG 0 <DORGed code> AORG BANK 0 ; 2nd "BANK 0" causes misalignment of remaining banks <remaining Bank 0 code> AORG _AORG_PATCH ; workaround for 2nd "BANK 0" misalignment BANK 1 . . . fbForth 2.0 now boots up properly. I need to compare the binaries with the asm994a-assembled code before continuing with my updates. The MYBANK word (2 bytes) is at >7FFE in every bank. I am a reasonably happy camper. ...lee Congratulations! Patching the DORG should not be necessary, though (I mean, it probably is, but shouldn't). I'll have a look at the default bank handling of the ORGs -- I hope I remember everything I promised. ? 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 27, 2020 Share Posted August 27, 2020 2 hours ago, TheBF said: That's great news Lee. Now that it builds what do these new tools buy you? Well, for starters, these versatile tools are currently maintained by an accessible author (@ralphb). Not so with asm994a. That was always discouraging, especially when I ran smack dab into its undocumented preprocessor with no diagnostic help other than the fact that my code would not assemble properly until I figured out what words to avoid for my labels. There are two other important features that xas99 offers me: Though it is not a lot of code, I only need to maintain the headers in one place now, not four! I always had to remember to make the same changes to four different headers. Much as I think my device for calculating RAM EQUates, for code to be copied to RAM, was clever and simple, XORG will make my life so much easier because the assembled XORGed code will all have the correct addresses. Troubleshooting is rarely much fun, but this will make it a good deal simpler. ...lee 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 27, 2020 Share Posted August 27, 2020 1 hour ago, ralphb said: I see. If that is all, you'd need to prepend all references in bank 2 to bank 0 with x# -- or disable the cross-bank check. I'll make that an option. I actually have not counted them all, but there are somewhere near 1000 such labels—not something I want to patch manually with ‘x#’ 1000 times. I will go with disabling the cross-bank check. 1 hour ago, ralphb said: But how do you know if an address points to bank 0, 1, 2, ..., or n? The final program doesn't contain labels, just addresses. In your example, it just seems like a convention that the linked list is in bank 2, and interpreters in bank 0. Well, the 500+ pfas in Bank 2 all point to Bank 0 if not the handful that are in RAM. Every other cross-bank address is encoded with the bank ID, which the trampoline code in low RAM knows how to decode, Such a call to trampoline code follows: BL @BLF2A DATA _IDDOT->6000+BANK2 ; _IDDOT = >73EA..BANK2 = >4000..result = >53EA The BLF2A trampoline code extracts the bank code by shifting a copy of the DATA word 13 bits right and adding back >6000. This gets the address to bump to switch to the correct bank. The original has its leftmost 3 bits masked off and >6000 added back to get the routine’s address. Clear as mud, right? Anyway, it works. Lastly, when the inner (address) interpreter (located in scratchpad RAM) executes the address in an fbForth 2.0 word’s code field, Bank 0 is always mapped in because that is where every code field in ROM resides. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 27, 2020 Share Posted August 27, 2020 7 hours ago, Lee Stewart said: fbForth 2.0 now boots up properly. I need to compare the binaries with the asm994a-assembled code before continuing with my updates. The MYBANK word (2 bytes) is at >7FFE in every bank. I am a reasonably happy camper. All binaries match except for the BSS stretches. It transpires that asm994a writes >FFs there and xas99, >00s. Fortunately there were few of those to walk through. 5 hours ago, ralphb said: Congratulations! Patching the DORG should not be necessary, though (I mean, it probably is, but shouldn't). I'll have a look at the default bank handling of the ORGs -- I hope I remember everything I promised. ? Thanks! And now—on to XORGing RAM copies! ...lee Quote Link to comment Share on other sites More sharing options...
PeteE Posted August 27, 2020 Share Posted August 27, 2020 8 hours ago, ralphb said: I see. If that is all, you'd need to prepend all references in bank 2 to bank 0 with x# -- or disable the cross-bank check. I'll make that an option. I would find this option to disable cross-bank checks useful as well. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 28, 2020 Share Posted August 28, 2020 4 hours ago, Lee Stewart said: Thanks! And now—on to XORGing RAM copies! Hooboy! I am not sure XORG is going to be the boon I thought it would. I am a bit hamstrung without a column with the target addresses. I changed a lot of code with XORG, which involved about 100 labels in code destined for low RAM. It seemed pretty straightforward, but it blew up when I tried the binary in Classic99. Without a column of target addresses, it is going to be tedious to find what I did wrong. I am going to have to go back to the old code and just change a few labels at a time. Not what I was anticipating. Sorry to be such a PITA. ...lee Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 28, 2020 Author Share Posted August 28, 2020 8 hours ago, PeteE said: I would find this option to disable cross-bank checks useful as well. I must admit that my mental model of bank switching was a cartridge, with a simple switcheroo in ROM. Also, x# should help the programmer, not frustrate him or her. I'll also try to merge your patch, although I would change the command line interface slightly. ? Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 28, 2020 Author Share Posted August 28, 2020 6 hours ago, Lee Stewart said: Hooboy! I am not sure XORG is going to be the boon I thought it would. I am a bit hamstrung without a column with the target addresses. I changed a lot of code with XORG, which involved about 100 labels in code destined for low RAM. It seemed pretty straightforward, but it blew up when I tried the binary in Classic99. Without a column of target addresses, it is going to be tedious to find what I did wrong. I am going to have to go back to the old code and just change a few labels at a time. Not what I was anticipating. Sorry to be such a PITA. Without knowing your code, I can only offer some guesses here. Did you copy the XORG area to RAM? XORG just influences the address pointer, but it doesn't move the range to RAM. The pattern is li r0, <target> li r1, xorg_start li r2, xorg_end - xorg_start ! movb *r1+, *r0+ dec r2 jne -! ... xorg_start xorg <target> ... xorg_end aorg ... ; normal program continues Inside the XORG range, any addresses outside the range will remain fixed (as you'd expect). Maybe something goes wrong with your DATA statements with the expressions? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 28, 2020 Share Posted August 28, 2020 44 minutes ago, ralphb said: Did you copy the XORG area to RAM? XORG just influences the address pointer, but it doesn't move the range to RAM. I understand and that is what the code does. 44 minutes ago, ralphb said: Inside the XORG range, any addresses outside the range will remain fixed (as you'd expect). Maybe something goes wrong with your DATA statements with the expressions? I am sure something like that has happened. The problem is that, without a convenient column of target addresses in the listing, it is well nigh impossible to find the error(s)—certainly not easily. My old code, with its calculated EQUates, serves me better. Here is the XORGed code: Spoiler * __ __ __ * / / ___ _ ______/ / ___ _ _____ / / * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / * /____/\___/__,__/ /____/\__/|___/\__/_/ * ____ __ * / __/_ _____ ___ ___ ____/ /_ * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ * /___/\_,_/ .__/ .__/\___/_/ \__/ * /_/ /_/ * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * fbForth--- * * * * Low-level support routines * * * * << Including Trampoline Code, tables & variables: 2606 bytes >> * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * LLVSPT ; <--This is the source copy location for the rest of this code. $BUFF EQU >2010 * 4 I/O buffers below ($LO = >3020) * Change '4' to number of buffers needed and for which there is room. $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers XORG $LO ; calculate destination addresses * _____ ____ __ __ ___________ * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| * ;[*** Interrupt Service ======================================================= * This routine is executed for every interrupt. It processes any pending * speech and souind. It then looks to see whether a user ISR is installed in * ISR. If so, it sets up NEXT for execution of the user ISR. This will work * only if the user has installed an ISR using the following steps in the fol- * lowing order: * * (1) Write an ISR with entry point, say MYISR. * (2) Determine code field address of MYISR with this high-level Forth: * ' MYISR CFA * <<< Maybe need a word to do #3 >>> * (3) Write CFA of MYISR into user variable ISR. * * Steps (2)-(3) in high-level Forth are shown below: * ' MYISR CFA * ISR ! * * <<< Perhaps last step above should be by a word that disables interrupts >>> * * The console ISR branches to the contents of >83C4 because it is non-zero, * with the address, INT1, of the fbForth ISR entry point below (also, the * contents of INTLNK). This means that the console ISR will branch to INT1 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first * process any pending speech and sound. * * If the user's ISR is properly installed, the code that processes the user * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed * from Forth's workspace (MAINWS), the code at INT2 will process the user's * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's * inner interpreter. *** ========================================================================== * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! INT1 LI R0,BRSTK load address of top of Branch Address Stack * * Set up for pending speech * MOV @SPCSVC,*R0 save Speech service address onto Branch Stack JEQ SNDCH1 jump to sound-check if no speech INCT R0 increment Branch Stack * * Set up for pending sound table #1 (ST#1) * SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? JEQ SNDCH2 process speech and sound if needed LI R1,x#PLAYT1 load PLAYT1 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Set up for pending sound table #2 (ST#2) * SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? JEQ PRCSPS process speech and sound if needed LI R1,x#PLAYT2 load PLAYT2 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Process sound stack if both sound tables idle * PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? JNE PRSPS2 nope..skip sound stack processing LWPI SND1WS switch to ST#1 WS CI R4,SNDST0 anything on sound stack? JEQ PRSPS1 no..exit sound stack processing DECT R4 pop sound stack position MOV *R4,R2 get sound table address from sound stack INC R0 kick off sound processing of ST#1 (R0=1) PRSPS1 LWPI GPLWS switch back to GPL WS * * Check for any pending speech and sound * PRSPS2 CI R0,BRSTK any speech or sound to process? JEQ USRISR if not, jump to user ISR processing LI R1,BNKRST yup..load return address MOV R1,*R0 push return address onto Branch Stack * * Process pending speech and sound * MOV @x#MYBANK,@BANKSV save bank at interrupt CLR @>6002 switch to bank 2 for speech & sound services LI R7,BRSTK load top of Branch Stack MOV *R7+,R8 pop speech/sound ISR B *R8 service speech/sound * * Restore interrupted bank * BNKRST ; return point for speech and sound ISRs MOV @BANKSV,R0 restore bank at interrupt SRL R0,13 get the bank# to correct position AI R0,>6000 make it a real bank-switch address CLR *R0 switch to the bank at interrupt * * Process User ISR if defined * USRISR MOV @$ISR+$UVAR,R0 User ISR installed? JEQ INTEX * * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) * is executed from Forth's WS (MAINWS = >8300), which it does at the end of * every CODE word, keyboard scan and one or two other places. * LI R1,INT2 Load entry point, INT2 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) * * The following 2 instructions are copies of the remainder of the console ROM's * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) * because we're not going back there! * INTEX LWPI >83C0 Change to console's ISR WS RTWP Return to caller of console ISR * * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored * before executing user's ISR. INT3 (cleanup routine below) will be inserted * in address list to get us back here for cleanup after user's ISR has finished. * User's ISR is executed at the end of this section just before INT3. * INT2 LIMI 0 Disable interrupts MOVB @>83D4,R0 Get copy of VR01 SRL R0,8 ...to LSB ORI R0,>100 Set up for VR01 ANDI R0,>FFDF Clear VDP-interrupt-enable bit BLWP @VWTR Turn off VDP interrupt LI NEXT,$NEXT Restore NEXT SETO @INTACT Set Forth "pending interrupt" flag DECT R Set up return linkage by pushing MOV IP,*R ...IP (R13, next Forth CFA) to return stack and LI IP,INT3 ...setting IP to INT3 (below) for cleanup MOV @$ISR(U),W Do the user's Forth ISR by executing B @DOEXEC ...it through Forth's inner interpreter * * Clean up and re-enable interrupts. * INT3 DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) MOV *R+,IP Start cleanup: pop IP from before call to user's ISR CLR @INTACT Clear Forth "pending interrupt" flag MOVB @>83D4,R0 Prepare to restore VR01 by... SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and AI R0,>100 ...VR # (01) to MSB MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status BLWP @VWTR Write VR01 LIMI 2 Re-enable interrupts B *NEXT Continue normal task ;]* ;[*** BKLINK from SYSTEM calls ========================================== * BKLINK MOV @INTACT,R7 Are we in user's ISR? JNE BKLIN1 Don't enable interrupts if so. LIMI 2 BKLIN1 B *LINK ;]* * ____ __ _____ ____ * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ * /___/ * ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== * Entry point for low-level system support functions $SYS$ LIMI 0 MOV @SYSTAB(R1),R0 B *R0 ;] ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== DATA BRW CODE = -20 write block to blocks file DATA BRW CODE = -18 read block from blocks file DATA BRW CODE = -16 create blocks file DATA BRW CODE = -14 use blocks file DATA GXY CODE = -12 GOTOXY DATA QKY CODE = -10 ?KEY DATA QTM CODE = -8 ?TERMINAL DATA CLF CODE = -6 CRLF DATA EMT CODE = -4 EMIT DATA KY CODE = -2 KEY SYSTAB DATA SBW CODE = 0 VSBW DATA MBW CODE = 2 VMBW DATA SBR CODE = 4 VSBR DATA MBR CODE = 6 VMBR DATA WTR CODE = 8 VWTR DATA GPL CODE = 10 GPLLNK DATA XML CODE = 12 XMLLNK DATA DSR CODE = 14 DSRLNK DATA CLS$ CODE = 16 CLS DATA MVE CODE = 18 VMOVE DATA FILL$ CODE = 20 VFILL DATA AOX CODE = 22 VAND DATA AOX CODE = 24 VOR DATA AOX CODE = 26 VXOR ;]* ;[*== VDP single byte write. CODE = 0 ================= * SBW MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 Character to write SWPB R1 Get in left byte BLWP @VSBW B @BKLINK ;]* ;[*== VDP multi byte write. CODE = 2 ================= * MBW MOV *SP+,R2 Number of bytes to move MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 RAM address (source) BLWP @VMBW B @BKLINK ;]* ;[*== VDP single byte read. CODE = 4 ================= * SBR MOV *SP,R0 VRAM address (source) BLWP @VSBR SRL R1,8 Character to right half for Forth MOV R1,*SP Stack it B @BKLINK ;]* ;[*== VDP multi byte read. CODE = 6 ================= * MBR MOV *SP+,R2 Number of bytes to read MOV *SP+,R1 RAM address (destination) MOV *SP+,R0 VRAM address (source) BLWP @VMBR B @BKLINK ;]* ;[*== VDP-to-VDP move. CODE = 18 ================= * MVE MOV *SP+,R0 Pop cnt to R0 MOV *SP+,R2 Pop vdst to R2 MOV *SP+,R1 Pop vsrc to R1 BLWP @VMOVE B @BKLINK ;]* ;[*== VDP register write. CODE = 8 ================= * WTR MOV *SP+,R1 VDP register number MOV *SP+,R0 Data for register SWPB R1 Get register to left byte MOVB R1,R0 Place with data BLWP @VWTR B @BKLINK ;]* ;[*== GPL link utility. CODE = 10 ================= * GPL CLR R0 MOVB R0,@KYSTAT LI R0,>0420 Construct the BLWP instruction LI R1,GPLLNK to the GPLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== XML link utility. CODE = 12 ================= * XML LI R0,>0420 Construct the BLWP instruction LI R1,XMLLNK to the XMLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== DSR link utility. CODE = 14 ================= * DSR LI R0,>0420 Construct the BLWP instruction LI R1,DSRLNK to the DSRLNK utility MOV *SP+,R2 This datum selects DSR or subroutine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== Screen clearing utility. CODE = 16 ================= * CLS$ MOV @$SSTRT(U),R2 Beginning of screen in VRAM MOV @$SEND(U),R1 End of screen in VRAM S R2,R1 Screen size LI R0,>2000 Blank character MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== VDP fill routine. CODE = 20 ================= * FILL$ MOV *SP+,R0 Fill character SWPB R0 to left byte MOV *SP+,R1 Fill count MOV *SP+,R2 Address to start VRAM fill MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK *======================================================================== FILL1 ; R0=char, R1=cnt, R2=vaddr ORI R2,>4000 Set bit for VDP write SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time FLOOP MOVB R0,@VDPWD Write a byte DEC R1 JNE FLOOP Not done, fill another B *LINK ;]*====================================================================== * *==== VAND -- VDP byte AND routine. CODE = 22 ================= *==== VOR -- VDP byte OR routine. CODE = 24 ================= ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= * AOX MOV *SP+,R2 VRAM address SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time MOVB @VDPRD,R3 Read byte MOV *SP+,R0 Get data to operate with SWPB R0 to left byte *** Now do requested operation ***************** CI R1,24 JEQ DOOR JGT DOXOR INV R3 These two instructions SZC R3,R0 perform an 'AND' JMP FINAOX DOOR SOC R3,R0 perform 'OR' JMP FINAOX DOXOR XOR R3,R0 perform 'XOR' FINAOX LI R1,1 MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== KEY routine CODE = -2 ================= * KY MOV @$ALTI(U),R0 alternate input device? JEQ KEY0 jump to keyboard input if not * * R0 now points to PAB for alternate input device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to read one byte. * CLR R7 prepare to zero status byte MOVB R7,@KYSTAT zero status byte INC R0 point R0 to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB MOV R0,R1 Set up pointer... AI R1,8 ...to namelength byte of PAB MOV R1,@SUBPTR copy to DSR subroutine name-length pointer MOV R0,R3 save pointer (DSRLNK will trash it!) BLWP @DSRLNK get 1 byte from device DATA >8 MOV R3,R0 restore pointer DECT R0 point to one-byte VRAM buffer in front of PAB BLWP @VSBR read character SRL R1,8 move to LSB MOV R1,R0 copy to return register B @BKLINK return to caller * * Input is comining from the keyboard * KEY0 MOV @KEYCNT,R7 INC R7 JNE KEY1 MOV @CURPO$(U),R0 BLWP @VSBR Read character at cursor position... MOVB R1,@CURCHR ...and save it LI R1,>1E00 Place cursor character on screen BLWP @VSBW * KEY1 BLWP @KSCAN MOVB @KYSTAT,R0 COC @H2000,R0 check status JEQ KEY2 JMP if key was pressed * CI R7,100 No key pressed JNE KEY3 MOVB @CURCHR,R1 JMP KEY5 * KEY3 CI R7,200 JNE KEY4 CLR R7 LI R1,>1E00 Cursor char KEY5 MOV @CURPO$(U),R0 BLWP @VSBW KEY4 MOV R7,@KEYCNT MOV @INTACT,R7 Are we in user's ISR? JNE KEY6 Don't enable interrupts if so. LIMI 2 KEY6 DECT IP This will re-execute KEY B *NEXT KEY2 SETO @KEYCNT Key was pressed MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 B @BKLINK ;]* ;[*== EMIT routine CODE = -4 ================= * EMT MOV R2,R1 copy char to R1 for VSBW MOV @$ALTO(U),R0 alternate output device? JEQ EMIT0 jump to video display output if not * * R0 now points to PAB for alternate output device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to write one byte. * CLR R7 ALTOUT active MOVB R7,@KYSTAT zero status byte DEC R0 point to one-byte VRAM buffer in front of PAB SWPB R1 char to MSB BLWP @VSBW write char to buffer INCT R0 point to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB AI R0,8 Set up pointer to namelength byte of PAB MOV R0,@SUBPTR copy to DSR subroutine name-length pointer BLWP @DSRLNK put 1 byte to device DATA >8 B @BKLINK return to caller * * Output is going to the video display * EMIT0 CI R1,7 Is it a bell? JNE NOTBEL CLR R2 MOVB R2,@KYSTAT BLWP @GPLLNK DATA >0036 Emit error tone JMP EMEXIT * NOTBEL CI R1,8 Is it a backspace? JNE NOTBS LI R1,>2000 MOV @CURPO$(U),R0 BLWP @VSBW JGT DECCUR JMP EMEXIT DECCUR DEC @CURPO$(U) JMP EMEXIT * NOTBS CI R1,>A Is it a line feed? JNE NOTLF MOV @$SEND(U),R7 S @$SWDTH(U),R7 C @CURPO$(U),R7 JHE SCRLL A @$SWDTH(U),@CURPO$(u) JMP EMEXIT SCRLL MOV LINK,R7 BL @SCROLL MOV R7,LINK JMP EMEXIT * *** SCROLLING ROUTINE * SCROLL MOV @$SSTRT(U),R0 VRAM addr LI R1,LINBUF Line buffer MOV @$SWDTH(U),R2 Count A R2,R0 Start at line 2 SCROL1 BLWP @VMBR S R2,R0 One line back to write BLWP @VMBW A R2,R0 Two lines ahead for next read A R2,R0 C R0,@$SEND(U) End of screen? JL SCROL1 MOV R2,R1 Blank bottom row of screen LI R0,>2000 Blank S @$SEND(U),R2 NEG R2 Now contains address of start of last line MOV LINK,R6 BL @FILL1 Write the blanks B *R6 * NOTLF CI R1,>D Is it a carriage return? JNE NOTCR CLR R0 MOV @CURPO$(U),R1 MOV R1,R3 S @$SSTRT(U),R1 Adjusted for screen not at 0 MOV @$SWDTH(U),R2 DIV R2,R0 S R1,R3 MOV R3,@CURPO$(U) JMP EMEXIT * NOTCR SWPB R1 Assume it is a printable character MOV @CURPO$(U),R0 BLWP @VSBW MOV @$SEND(U),R2 DEC R2 C R0,R2 JNE NOTCR1 MOV @$SEND(U),R0 S @$SWDTH(U),R0 Was last char on screen. Scroll MOV R0,@CURPO$(U) JMP SCRLL NOTCR1 INC R0 No scroll necessary MOV R0,@CURPO$(U) * EMEXIT B @BKLINK ;]* ;[*== CRLF routine CODE = -6 ================= * CLF MOV LINK,R5 LI R2,>000D BL @EMT EMT will alter INT mask via B @BKLINK LI R2,>000A LIMI 0 Previous call to EMT altered INT mask BL @EMT MOV R5,LINK B @BKLINK ;]* ;[*== ?TERMINAL routine CODE = -8 ================= * scan for <clear>, <break>, FCTN+4 press * QTM MOV LINK,R5 save return BL @>0020 branch to console's test for <clear> STST R0 store status in R0 JNE QTM2 exit if not <clear> QTM1 BL @>0020 check for <clear> again JEQ QTM1 loop until not <clear> QTM2 MOV R5,LINK restore return ANDI R0,>2000 keep only EQU bit B @BKLINK return to caller ;]* ;[*== ?KEY routine CODE = -10 ================= * QKY BLWP @KSCAN MOVB @KYCHAR,R0 SRL R0,8 CI R0,>00FF JNE QKEY1 CLR R0 QKEY1 B @BKLINK ;]* ;[*== GOTOXY routine CODE = -12 ================= * GXY MPY @$SWDTH(U),R3 A R2,R4 Position within screen A @$SSTRT(U),R4 Add VRAM offset to screen top MOV R4,@CURPO$(U) B @BKLINK ;] * ___ __ __ ____ ______ * / _ )/ /__ ____/ /__ / _/_/_/ __ \ * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / * /____/_/\___/\__/_/\_\ /___/_/ \____/ * *== USE blocks file CODE = -14 ================= *== CREATE blocks file CODE = -16 ================= *== READ block from blocks file CODE = -18 ================= *== WRITE block to blocks file CODE = -20 ================= ;[*== Block File I/O Support ============================================ * * BPTOG utility to toggle one of 2 PABs for block file access * BPTOG MOV @$BPOFF(U),R0 PAB offset to R0 LI R1,70 Toggle amount XOR R0,R1 New offset MOV R1,@$BPOFF(U) Update offset * **xxx** entry point to insure we have correct PAB address BPSET MOV @$DKBUF(U),R0 Get DISK_BUF address A @$BPABS(U),R0 Get BPABS address * A @$BPOFF(U),R0 Add current offset MOV R0,@BFPAB Update current block file's PAB address RT * * CLOSE blocks file * BKCLOS MOV @BFPAB,R0 LI R1,$FCLS Opcode=CLOSE BLWP @VSBW AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Close the file DATA 8 RT Deal with error in caller * * storage area * SVBRET DATA 0 Storage for LINK coming into BRW BFPAB DATA 0 Storage for current blocks file PAB address... * ...will have current PAB on entry * PAB header storage * PABHD BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative * >03=OUTPUT mode + " * >01=UPDATE mode + " * BYTE 2,3: save contents of DISK_BUF here BYTE >80 Record length BYTE >80 Character count of transfer BSS 2 Record number * *** file I/O equates * $FOPN EQU >0000 $FCLS EQU >0100 $FRD EQU >0200 $FWRT EQU >0300 $FRST EQU >0400 $FINP EQU 5 $FOUT EQU 3 $FUPD EQU 1 * *** BRW -- entry point for block read/write routines * BRW MOV LINK,@SVBRET Save LINK address MOV R1,R7 Save CODE {R1 to R7} SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) BL @BPSET Insure correct PAB address in BFPAB (it may have moved) CI R7,4 USE or CREATE? JLT BRW01 No BL @BPTOG Yes...toggle BPOFF & BFPAB MOV @BFPAB,R0 Load PAB address AI R0,9 Set to name length byte CLR R2 MOV *SP+,R1 Pop bfnaddr to R1 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 INC R2 Add 1 to # bytes to copy BLWP @VMBW Copy char count & pathname to PAB * *** set up PAB for OPEN * BRW01 LI R1,$FUPD Opcode=0,mode=update CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? JOP BRW02 No LI R1,$FINP Yes...change mode=input BRW02 MOV R1,@PABHD Put in PAB header MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header CLR R0 MOV R0,@PABHD+6 Set record#=0 MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 Copy first 8 bytes of PAB header BLWP @VMBW Do the copy * *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] * AI R0,9 Address of filename's char count in PAB MOV R0,@SUBPTR Point to-----^^^^ BLWP @DSRLNK Open/create the file DATA 8 JEQ BKERR CI R7,4 READ or WRITE? JLT BRW04 Yes JGT BRWDON No; =USE; we're done * *** write blank records to newly created blocks file [CODE = -16,CREATE] * MOV *SP+,R5 No; = CREATE; pop #blocks from stack SLA R5,3 Convert #blocks to #records MOV R5,R3 Save MOV R5,R4 Set up counter LI R0,$FWRT+$FUPD Set up for WRITE MOV R0,@PABHD Copy to PAB header BRLOOP S R4,R5 Calculate next record MOV R5,@PABHD+6 Copy to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Write one record of blanks DATA 8 JEQ BKERR MOV R3,R5 Get #blocks DEC R4 Count down 1 record JNE BRLOOP Write another record if not done JMP BRWDON We're done * *** prepare for read/write block * BRW04 MOV *SP+,R5 Pop block# to write MOV *SP+,R6 Pop bufaddr DEC R5 Block#-1 SLA R5,3 Convert to starting record# LI R4,8 Load counter for 8 records LI R0,$FWRT+$FUPD Set up for WRITE LI R3,VMBW WRITE vector CI R7,2 Are we writing the block? JEQ BRW05 Yup LI R0,$FRD+$FINP Nope...set up for READ LI R3,VMBR READ vector BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header * * READ/WRITE block routine [CODE = -18/-20] * RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy MOV @$DKBUF(U),R0 VRAM buffer address to R0 MOV R6,R1 RAM buffer to R1 LI R2,128 Bytes to copy CI R7,3 READ? JEQ BRW06 Yup BLWP *R3 Nope...copy record to VRAM * * temporarily use CRU register---it should be OK * BRW06 MOV @BFPAB,CRU PAB address AI CRU,9 Address of filename's char count MOV CRU,@SUBPTR Point to filename's char count BLWP @DSRLNK Read/write one record DATA 8 JEQ BKERR CI R7,2 WRITE? JEQ BRW07 Yup...next record MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) BLWP *R3 Nope...copy record to RAM buffer BRW07 INC R5 Next record in file AI R6,128 Next record to/from block RAM buffer DEC R4 Count down 1 record JNE RWLOOP Read/write another record if not done JMP BRWDON We're done * *** error handling * BKERR MOVB R0,R0 Device error? JEQ BKERR6 Yes, exit with disk error BKERR9 LI R6,9 No, exit with file error JMP BKCLN BKERR8 LI R6,8 Block# <=0! exit with range error JMP BKCLN BKERR6 LI R6,6 BKCLN BL @BKCLOS Close current blocks file; ignore error CI R7,4 USE or CREATE? JLT BKCLN1 No BL @BPTOG Yes...toggle BPOFF & BFPAB BKCLN1 MOV R6,R0 Pass error back to caller JMP BKEXIT BRWDON CLR R6 BL @BKCLOS Close current blocks file JNE BRWDN1 Error? LI R6,9 Yes...assume it was a file error BRWDN1 CI R7,4 (no error)...CREATE? JNE BRWDN2 No...we're done BL @BPTOG Yes...revert to correct blocks file BRWDN2 MOV R6,R0 Error to R0 BKEXIT MOV @SVBRET,LINK Restore LINK B @BKLINK ;] ;[* MSGTYP <<< Support for string typing in various banks >>> * * Called with: BL @MSGTYP * * R4 and R5 are the only registers that will be preserved * ..after a call to EMIT--- * * Input: R4 = Address of length byte of packed string * * We will pass the ASCII value of character to EMIT in R2 without * insuring it is 7 bits wide. * MSGTYP DECT R Push return address MOV LINK,*R ...to Forth return stack CLR R5 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char SWPB R5 Put char count in low byte MTLOOP CLR R2 MOVB *R4+,R2 Copy next char to R2 for EMIT SWPB R2 Put char in low byte LIMI 0 We need to do this because we're calling EMIT directly BL @EMT Call EMIT directly INC @$OUT(U) Increment display line character count DEC R5 Decrement character count for this message JNE MTLOOP Are we done? MOV *R+,LINK Yes. Pop return address RT Return to caller ;] ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) R4$5 MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4,*R5 RT ;] * __ __ _ __ _ __ __ * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ * ___ ___ ____ * / _ \___ / _/__ ___ __/ / /____ * / // / -_) _/ _ `/ // / / __(_-< * /____/\__/_/ \_,_/\_,_/_/\__/___/ ;[*== User Variable defaults ============================================ * UBASE0 BSS 6 BASE OF USER VARIABLES DATA UBASE0 06 USER UCONS$ DATA SPBASE 08 USER S0 DATA RBASE 0A USER R0 { R0$ DATA $UVAR 0C USER U0 DATA SPBASE 0E USER TIB DATA 31 10 USER WIDTH DATA DPBASE 12 USER DP DATA $SYS$ 14 USER SYS$ DATA 0 16 USER CURPOS DATA INT1 18 USER INTLNK DATA 1 1A USER WARNING DATA 64 1C USER C/L$ { CL$ DATA $BUFF 1E USER FIRST$ DATA $LO 20 USER LIMIT$ DATA >0380 22 USER COLTAB Color Table address in VRAM DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM DATA >80 2A USER FPB pushes address of user screen font file PAB * ...that is this relative distance from DISK_BUF DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) DATA 40 30 USER SCRN_WIDTH DATA 0 32 USER SCRN_START DATA 960 34 USER SCRN_END DATA 0 36 USER ISR [Note: This used to be INT1] DATA 0 38 USER ALTIN DATA 0 3A USER ALTOUT DATA 1 3C USER VDPMDE permanent location for VDPMDE DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files * ...that is this relative distance from DISK_BUF DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB * ...always toggled between 0 and 70 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) * 0 = console font via GPLLNK DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. * 0 = Symmetric (default) * !0 = Floored $UVAR BSS >80 USER VARIABLE AREA ;] ;[*== A Constant ==================================================== * H2000 DATA >2000 ;]* * __ ____ _ ___ __ _ __ __ * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ * /___/ * ;[*== Utility Vectors =================================================== * * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK XMLLNK DATA UTILWS,XMLENT ; Link to ROM routines KSCAN DATA UTILWS,KSENTR ; Keyboard scan VSBW DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) VMBW DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) VSBR DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) VMBR DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) VMOVE DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) VWTR DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) ;]* ;[*== XMLENT -- Link to system XML utilities ============================ * XMLENT MOV *R14+,@GPLWS+2 Get argument LWPI GPLWS Select GPL workspace MOV R11,@UTILWS+22 Save GPL return address MOV R1,R2 Make a copy of argument CI R1,>8000 Direct address in ALC? JH XML30 We have the address SRL R1,12 SLA R1,1 SLA R2,4 SRL R2,11 A @XMLTAB(R1),R2 MOV *R2,R2 XML30 BL *R2 LWPI UTILWS Get back to right WS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * ________ __ __ _ ____ __ __ ________ * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * This routine will work with any GROM library slot since it is * * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * * This GPLLNK does NOT require a module to be plugged into the * * GROM port so it will work with the Editor/Assembler, * * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * * It saves and restores the current GROM Address in case you want * * to return back to GROM for Basic or Extended Basic CALL LINKs * * or to return to the loading module. * * * * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * * DATA >34 * * * * NOTES: Do Not REF GPLLNK when using this routine in your code. * * * * 70 Bytes - including the GPLLNK Workspace * *-----------------------------------------------------------------------* * GPLWS (>83E0) is GPL workspace G_R4 EQU GPLWS+8 GPL workspace R4 G_R6 EQU GPLWS+12 GPL workspace R6 * SUBSTK (>8373) is GPL Subroutine stack pointer LDGADR EQU >60 Load & Execute GROM address entry point XTAB27 EQU >200E Low Mem XML table location 27 * ..Will contain XMLRTN at startup GETSTK EQU >166C GPLLNK DATA GLNKWS ; R7 Set up BLWP Vectors DATA GLINK1 ; R8 * RTNADR <---don't think we need this label DATA XMLRTN ; R9 address where GPL XML returns to us... * ...this address will already be in XTAB27,... * ...>200E, so don't really need it here} GXMLAD DATA >176C ; R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) DATA >50 ; R11 Initialized to >50 where PUTSTK address resides GLNKWS EQU $->18 ; GPLLNK's workspace of which only... BSS >08 ; R12-R15 ...registers R7 through R15 are used GLINK1 MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS LWPI GPLWS Load GPL WS BL *R4 Save current GROM Address on stack MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return INCT @SUBSTK Adjust the stack pointer B @LDGADR Execute our GPL Routine XMLRTN MOV @GETSTK,R4 Get GETSTK pointer BL *R4 Restore GROM address off the stack LWPI GLNKWS Load our WS RTWP All Done - Return to Caller ;] * ___ _______ __ _ ____ __ __ ________ * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * (Uses console GROM 0's DSRLNK routine) * * (Do not REF DSRLNK or GPLLNK when using these routines) * * (This DSRLNK will also handle Subprograms and CS1, CS2) * * * * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * * DATA 8 * * * * NOTES: Must be used with a GPLLNK routine * * Returns ERRORs the same as the E/A DSRLNK * * EQ bit set on return if error * * ERROR CODE in caller's MSB of Register 0 on return * * * * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * *-----------------------------------------------------------------------* PUTSTK EQU >50 Push GROM Address to stack pointer TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK NAMLEN EQU >8356 Device name length pointer in VDP PAB VWA EQU >8C02 VDP Write Address location VRD EQU >8800 VDP Read Data byte location G_R4LB EQU >83E9 GPL Workspace R4 Lower byte GSTAT EQU >837C GPL Status byte location DSRLNK DATA DSRWS,DLINK1 Set BLWP Vectors DSRWS ; Start of DSRLNK workspace DR3LB EQU $+7 ; lower byte of DSRLNK workspace R3 DLINK1 MOV R12,R12 R0 Have we already looked up the LINK address? JNE DLINK3 R1 YES! Skip lookup routine *<<-------------------------------------------------------------------------->>* * This section of code is only executed once to find the GROM address * * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * * to indicate that the address is found and to be used as a mask for EQ & CND * *------------------------------------------------------------------------------* LWPI GPLWS R2,R3 else load GPL workspace MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack BL *R4 R6 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector ***les*** Note on above instruction: ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) JMP DLINK2 R11 Jump around R12-R15 DATA 0 R12 contains >2000 flag when set DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address MOV @GETSTK,R5 Take some time & set up GETSTK pointer MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector INCT @DSRADR Adjust it to get past GPL FETCH instruction BL *R5 Restore the GROM address off the stack LWPI DSRWS Reload DSRLNK workspace LI R12,>2000 Set flag to signify DSRLNK address is set *<<-------------------------------------------------------------------------->>* DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK MOV @NAMLEN,R3 Save VDP address of Name Length AI R3,-8 Adjust it to point to PAB Flag byte BLWP @GPLLNK Execute DSR LINK DSRADR BYTE >03 High byte of GPL DSRLNK address DSRAD1 BYTE >00 Lower byte of GPL DSRLNK address *----Error Check & Report to Caller's R0 and EQU bit------------------------- MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag MOVB R3,@VWA Set up MSB of VDP Address for Error Flag SZCB R12,R15 Clear EQ bit for Error Report MOVB @VRD,R3 Get PAB Error Flag SRL R3,5 Adjust it to 0-7 error code MOVB R3,*R13 Put it into Caller's R0 (msb) JNE SETEQ If it's not zero, set EQ bit COC @GSTAT,R12 Else, test CND bit for Link Error (00) JNE DSREND No Error, Just return SETEQ SOCB R12,R15 Error, so set Caller's EQ bit DSREND RTWP All Done - Return to Caller ;] ;[*== KSENTR -- Keyboard Scan (entry point) ============================= * KSENTR LWPI GPLWS MOV R11,@UTILWS+22 Save GPL return address BL @SCNKEY Console keyboard scan routine LWPI UTILWS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * _ _____ ___ __ ____ _ ___ __ _ * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ * ;[*== VDP utilities (entry point) ======================================= * ** VDP single byte write * VSBWEN BL @WVDPWA Write out address MOVB @2(R13),@VDPWD Write data RTWP Return to calling program * ** VDP multiple byte write * VMBWEN BL @WVDPWA Write out address VWTMOR MOVB *R1+,@VDPWD Write a byte DEC R2 Decrement byte count JNE VWTMOR More to write? RTWP Return to calling Program * ** VDP single byte read * VSBREN BL @WVDPRA Write out address MOVB @VDPRD,@2(R13) Read data RTWP Return to calling program * ** VDP multiple byte read * VMBREN BL @WVDPRA Write out address VRDMOR MOVB @VDPRD,*R1+ Read a byte DEC R2 Decrement byte count JNE VRDMOR More to read? RTWP Return to calling program * ** VDP write to register * VWTREN MOV *R13,R1 Get register number and value MOVB @1(R13),@VDPWA Write out value ORI R1,>8000 Set for register write MOVB R1,@VDPWA Write out register number RTWP Return to calling program * ** Set up to write to VDP * WVDPWA LI R1,>4000 JMP WVDPAD * ** Set up to read VDP * WVDPRA CLR R1 * ** Write VDP address * WVDPAD MOV *R13,R2 Get VDP address MOVB @U_R2LB,@VDPWA Write low byte of address SOC R1,R2 Properly adjust VDP write bit MOVB R2,@VDPWA Write high byte of address MOV @2(R13),R1 Get CPU RAM address MOV @4(R13),R2 Get byte count RT Return to calling routine * ** VDP-to-VDP move. * VMOVEN MOV *R13,R1 Get cnt to R1 MOV @2(R13),R2 Get vsrc to R2 MOV @4(R13),R3 Get vdst to R3 ORI R3,>4000 Prepare for VDP write ** copy cnt bytes from vsrc to vdst VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address MOVB R2,@VDPWA Write MSB of VDP read address INC R2 Next VDP read address MOVB @VDPRD,R0 Read VDP byte MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address MOVB R3,@VDPWA Write MSB of VDP write address INC R3 Next VDP write address MOVB R0,@VDPWD Write VDP byte DEC R1 Decrement count JNE VMVMOR Repeat if not done RTWP Return to calling program ;]* ;[*== fbForth Version Message =========================================== FBFMSG * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? * Also, printing the extra blanks overwrites the font-not-found error message. BYTE 17 TEXT 'fbForth 2.0: ' ;] * __ ___ ___ ____ __ __ _ __ __ * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ * ;[*== Modifiable words in Resident Dictionary =========================== ;[*** (ABORT) *** DATA x#VLST_N <--Last word in ROM PABR_N DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT PABORT DATA DOCOL DATA ABORT,SEMIS ;]* ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] DATA PABR_N FRTH_N DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT FORTH DATA DOVOC FORTHV DATA DPBASE+2 ; vocabulary link field FORTHP DATA >81A0 ; pseudo name field FORTHL DATA 0 ; chronological link field ;]* ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] DATA FRTH_N ASMR_N DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT ASSM DATA DOVOC ; Initially points to last word in ASSEMBLER vocabulary in the kernel ASMV DATA SASM_N ; vocabulary link field DATA >81A0 ; pseudo name field ASML DATA FORTHL ; chronological link field * ;]* ;]* * ___ __ __ * / _ | ___ ___ ___ __ _ / / / /__ ____ * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ * _ __ __ __ _ __ __ * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ * /___/ * *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary ;[*** NEXT, *** ( --- ) * 1st word in ASSEMBLER vocabulary * DATA FORTHP <--points to PNF of FORTH NXT__N DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT NEXTC DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) MOV @$DP(U),R1 HERE to R1 MOV R0,*R1+ compile "B *NEXT" MOV R1,@$DP(U) update HERE MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary B *NEXT back to inner interpreter * : NEXT, ( --- ) * *NEXT B, ; ;]* ;[*** ;ASM *** ( --- ) * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. * DATA NXT__N SASM_N BYTE 4+TERMBT <--note different name field format TEXT ';ASM' BYTE ' '+TERMBT SASM DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! JMP NXT_P finish up in NEXT, * : ;ASM ( --- ) * *NEXT B, ; ;]* ;[*== Some Variables (KEYCNT etc.) ====================================== KEYCNT DATA -1 Used in cursor flash logic INTACT DATA 0 Non-zero during user's interrupt service routine * *++ variables used by some graphics primitives * $DMODE DATA 0 ; actual location of variable contents $DCOL DATA -1 ; actual location of variable contents *=========================================================== ;]* * ______ ___ _____ __ * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ * /_/ * ;[*== Trampoline Code =================================================== * * MYBANK must be at same location in all banks with the code that appears * in the following table. The EQUates for BANK0--BANK3 may also be in the * same places in each bank for convenience, but they only need to appear once. * * Bank Select MYBANK * ---- ------ ------ * 0 >6006 >C000 * 1 >6004 >8000 * 2 >6002 >4000 * 3 >6000 >0000 * * Bank0 code will look like this * * MYBANK DATA >C000 * BANK0 EQU >C000 * BANK1 EQU >8000 * BANK2 EQU >4000 * BANK3 EQU >0000 * * Banks 1--3 will look the same, including labels, and the DATA * instruction at MYBANK's location will correspond to its bank. * * Before a bank is selected, the values above will be shifted right 13 * bits and have >6000 added. * ;[*** BLBANK ************************************************************ * * General bank branching routine (32KB ROM, i.e., 4 banks) for a * branch that is expected to return (not high-level Forth) via RTBANK--- * --put in scratchpad or low RAM * --called by * BL @BLBANK * DATA dst_addr - >6000 + bank# in left 2 bits * BLBANK DECT R ; reserve space on return stack (R14) MOV *LINK+,CRU ; copy destination bank address to R12 MOV LINK,*R ; push return address DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) MOV CRU,LINK ; copy destination bank address to R11 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTBANK ************************************************************ * * General bank return routine (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called by * B @RTBANK * RTBANK MOV *R+,CRU ; pop return bank# from return stack to R12 SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address MOV *R+,LINK ; pop return address from return stack CLR *CRU ; switch to destination bank B *LINK ; branch to return address ;]* ;[*** BLF2A ************************************************************* * * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to bank0 via RTNEXT. This will * only(?) be used for the ALC payload of Forth stubs in bank0--- * --put in scratchpad or low RAM * --called by * BL @BLF2A * DATA dst_addr - >6000 + bank# in left 2 bits * BLF2A MOV *LINK,LINK ; copy destination bank address to R11 MOV LINK,CRU ; copy it to R12 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTNEXT ************************************************************ * * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 * banks)--- * --put in scratchpad or low RAM * --called by * B @RTNEXT * RTNEXT MOV @INTACT,CRU Are we in user's ISR? JNE RTNXT1 Don't enable interrupts if so. LIMI 2 RTNXT1 CLR @>6006 ; switch to bank 0 B *NEXT ; branch to next CFA (in R15) ;]* ;[*** BLA2F ************************************************************* * * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to calling bank via RTA2F--- * --put in scratchpad or low RAM * --called by * BL @BLA2F * DATA <Forth cfa in bank0> * BLA2F DECT R ; reserve space on return stack MOV *LINK+,W ; move CFA of Forth routine to W MOV LINK,*R ; push return address of calling bank DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) DECT R ; reserve spot on return stack MOV IP,*R ; move current IP to return stack LI IP,RTA2F ; move address of return procedure to IP CLR @>6006 ; switch to bank0 B @DOEXEC ; Execute the Forth routine ;]* ;[*** RTA2F ************************************************************* * * ALC to high-level Forth bank "return" routine from Forth to calling * ALC (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called through B *NEXT at end of Forth word's execution in BLA2F * RTA2F DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) * Retrieve ALC return info and return to caller... * ...caller will execute B *NEXT when it finishes B @RTBANK ; branch to general bank return routine above ;]* ;]*********************************************************************** ;[*++ Bank-specific cell-/byte-reading code ++* ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) *++ Read cell contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKAT CLR *R0 ; switch banks MOV *R1,*SP ; get cell contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) *++ Read byte contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKCAT CLR *R0 ; switch banks CLR R2 ; clear R2 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 MOV R2,*SP ; get byte contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;]* * _______ __ _________ ___ __ * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / * /___/ * ;[*** SAMS! *** ( --- ) * This calls the SAMS initialization in the startup code in bank 1. * * DATA SMSQ_N * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT * SAMSST DATA $+2 * BL @BLF2A * DATA _SMSST->6000+BANK1 _SMSST BL @SMSINI initialize SAMS card B @RTNEXT back to inner interpreter ;]* ;[*== Required strings, tables, variables... ============================ * * * Default blocks filename * DEFNAM BYTE 12 TEXT "DSK1.FBLOCKS " * * Default colors for all VDP modes--- * MSB: Screen color (LSN); text FG (MSN), BG (LSN) * LSB: Color Table colors (FG/BG) * DEFCOL DATA >4F00 ; TEXT80 offset=0 DATA >4F00 ; TEXT offset=2 DATA >F4F4 ; GRAPHICS offset=4 DATA >11F4 ; MULTI offset=6 DATA >FE10 ; GRAPHICS2 offset=8 DATA >FEF4 ; SPLIT offset=10 DATA >FEF4 ; SPLIT2 offset=12 * * Default text mode * DEFTXT DATA >0001 * * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB * FNTFLG DATA 0 ; font flag initially 0 * * Speech variables needing initial value (more below LLVEND) * SPCSVC DATA 0 * * Sound Table #1 Workspace for sound variables. Only using R0..R4 * SND1WS SND1ST DATA 0 ; R0 (sound table status) 0=no table.. ; ..1=loading sound bytes..-1=counting SND1DS DATA SOUND ; R1 (sound-table byte destination).. ; ..initialized to sound chip SND1AD DATA 0 ; R2 (sound table address) SND1CT DATA 0 ; R3 (# of sound bytes to load or.. ; ..sound count = seconds * 60) SND1SP DATA SNDST0 ; R4 (pointer to top of sound stack).. ; ..initialized to bottom of sound stack * * Sound Table #2 Workspace for sound variables. Only using R0..R3 * SND2WS SND2ST DATA 0 ; R0 (sound table status) 0=no table.. ; ..1=loading sound bytes..-1=counting SND2DS DATA SOUND ; R1 (sound-table byte destination) init to sound chip ;]* * * This is the end of low-level support code that gets copied. * LLVEND ;[*== Un-initialized Variables and workspaces... ========================= * Start of definitions of variables and workspaces that do not need to * take up space in ROM because they need no initial values. * * Sound Table #2 Workspace for sound variables..continued. * SND2AD EQU SND2WS+4 ; R2 (sound table address) SND2CT EQU SND2WS+6 ; R3 (# of sound bytes to load or.. * ; ..sound count = seconds * 60) SDMUTE EQU SND2WS+8 ; dummy destination for sound byte * * Branch Stack for ISR processing of Speech, 2 Sound Tables and return * BRSTK EQU SDMUTE+2 * * Speech variables (more above LLVEND) * SSFLAG EQU BRSTK+8 SPCNT EQU SSFLAG+2 SPADR EQU SPCNT+2 BANKSV EQU SPADR+2 PADSV EQU BANKSV+2 * * Panel window: height, width and screen position...used by PANEL and SCROLL * PANWIN EQU PADSV+12 panel height, width and screen start *== Utility Workspace ================================================= *** General utility workspace registers UTILWS EQU PANWIN+6 U_R2LB EQU UTILWS+5 LINBUF EQU UTILWS+32 CURCHR EQU LINBUF+80 *++ variable used by the 40/80-column editor OLDCUR EQU CURCHR+2 *++ FILE I/O variables PBADR EQU OLDCUR+8 PBBF EQU PBADR+2 PBVBF EQU PBBF+2 *++ Floating Point Math Library variables FPVARS EQU PBVBF+2 *++ SAMS flag SAMSFL EQU FPVARS+22 *++ Bottom of Sound Stack *++ This location marks the top of the low-level support code. The Sound *++ Stack grows upward toward the Return Stack by moving the entire stack *++ up one cell to make room for the next new bottom entry. SNDST0 EQU SAMSFL+2 ;]* AORG BANK 1 and its listing: Spoiler **** **** > fbForth101_LowLevelSupport.a99 0001 * __ __ __ 0002 * / / ___ _ ______/ / ___ _ _____ / / 0003 * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / 0004 * /____/\___/__,__/ /____/\__/|___/\__/_/ 0005 * ____ __ 0006 * / __/_ _____ ___ ___ ____/ /_ 0007 * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ 0008 * /___/\_,_/ .__/ .__/\___/_/ \__/ 0009 * /_/ /_/ 0010 * 0011 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0012 * * 0013 * fbForth--- * 0014 * * 0015 * Low-level support routines * 0016 * * 0017 * << Including Trampoline Code, tables & variables: 2606 bytes >> * 0018 * * 0019 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0020 0021 LLVSPT ; <--This is the source copy location for the rest of this code. 0022 0023 2010 $BUFF EQU >2010 0024 0025 * 4 I/O buffers below ($LO = >3020) 0026 * Change '4' to number of buffers needed and for which there is room. 0027 0028 3020 $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers 0029 0030 XORG $LO ; calculate destination addresses 0031 0032 * _____ ____ __ __ ___________ 0033 * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ 0034 * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ 0035 * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| 0036 * 0037 ;[*** Interrupt Service ======================================================= 0038 * This routine is executed for every interrupt. It processes any pending 0039 * speech and souind. It then looks to see whether a user ISR is installed in 0040 * ISR. If so, it sets up NEXT for execution of the user ISR. This will work 0041 * only if the user has installed an ISR using the following steps in the fol- 0042 * lowing order: 0043 * 0044 * (1) Write an ISR with entry point, say MYISR. 0045 * (2) Determine code field address of MYISR with this high-level Forth: 0046 * ' MYISR CFA 0047 * <<< Maybe need a word to do #3 >>> 0048 * (3) Write CFA of MYISR into user variable ISR. 0049 * 0050 * Steps (2)-(3) in high-level Forth are shown below: 0051 * ' MYISR CFA 0052 * ISR ! 0053 * 0054 * <<< Perhaps last step above should be by a word that disables interrupts >>> 0055 * 0056 * The console ISR branches to the contents of >83C4 because it is non-zero, 0057 * with the address, INT1, of the fbForth ISR entry point below (also, the 0058 * contents of INTLNK). This means that the console ISR will branch to INT1 0059 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first 0060 * process any pending speech and sound. 0061 * 0062 * If the user's ISR is properly installed, the code that processes the user 0063 * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed 0064 * from Forth's workspace (MAINWS), the code at INT2 will process the user's 0065 * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's 0066 * inner interpreter. 0067 *** ========================================================================== 0068 0069 * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! 0070 0071 INT1 0072 6140 0200 20 LI R0,BRSTK load address of top of Branch Address Stack 6142 3A2A 0073 * 0074 * Set up for pending speech 0075 * 0076 6144 C420 46 MOV @SPCSVC,*R0 save Speech service address onto Branch Stack 6146 3A14 0077 6148 1301 14 JEQ SNDCH1 jump to sound-check if no speech 0078 614A 05C0 14 INCT R0 increment Branch Stack 0079 * 0080 * Set up for pending sound table #1 (ST#1) 0081 * 0082 614C C0A0 34 SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? 614E 3A16 0083 6150 1303 14 JEQ SNDCH2 process speech and sound if needed 0084 6152 0201 20 LI R1,x#PLAYT1 load PLAYT1 address and... 6154 7C68 0085 6156 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0086 * 0087 * Set up for pending sound table #2 (ST#2) 0088 * 0089 6158 C0E0 34 SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? 615A 3A20 0090 615C 1303 14 JEQ PRCSPS process speech and sound if needed 0091 615E 0201 20 LI R1,x#PLAYT2 load PLAYT2 address and... 6160 7C6E 0092 6162 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0093 * 0094 * Process sound stack if both sound tables idle 0095 * 0096 6164 E0C2 18 PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? 0097 6166 160A 14 JNE PRSPS2 nope..skip sound stack processing 0098 6168 02E0 18 LWPI SND1WS switch to ST#1 WS 616A 3A16 0099 616C 0284 22 CI R4,SNDST0 anything on sound stack? 616E 3AE4 0100 6170 1303 14 JEQ PRSPS1 no..exit sound stack processing 0101 6172 0644 14 DECT R4 pop sound stack position 0102 6174 C094 26 MOV *R4,R2 get sound table address from sound stack 0103 6176 0580 14 INC R0 kick off sound processing of ST#1 (R0=1) 0104 6178 02E0 18 PRSPS1 LWPI GPLWS switch back to GPL WS 617A 83E0 0105 * 0106 * Check for any pending speech and sound 0107 * 0108 617C 0280 22 PRSPS2 CI R0,BRSTK any speech or sound to process? 617E 3A2A 0109 6180 1312 14 JEQ USRISR if not, jump to user ISR processing 0110 6182 0201 20 LI R1,BNKRST yup..load return address 6184 307A 0111 6186 C401 30 MOV R1,*R0 push return address onto Branch Stack 0112 * 0113 * Process pending speech and sound 0114 * 0115 6188 C820 54 MOV @x#MYBANK,@BANKSV save bank at interrupt 618A 7FFE 618C 3A38 0116 618E 04E0 34 CLR @>6002 switch to bank 2 for speech & sound services 6190 6002 0117 6192 0207 20 LI R7,BRSTK load top of Branch Stack 6194 3A2A 0118 6196 C237 30 MOV *R7+,R8 pop speech/sound ISR 0119 6198 0458 20 B *R8 service speech/sound 0120 * 0121 * Restore interrupted bank 0122 * 0123 BNKRST ; return point for speech and sound ISRs 0124 619A C020 34 MOV @BANKSV,R0 restore bank at interrupt 619C 3A38 0125 619E 09D0 56 SRL R0,13 get the bank# to correct position 0126 61A0 0220 22 AI R0,>6000 make it a real bank-switch address 61A2 6000 0127 61A4 04D0 26 CLR *R0 switch to the bank at interrupt 0128 * 0129 * Process User ISR if defined 0130 * 0131 61A6 C020 34 USRISR MOV @$ISR+$UVAR,R0 User ISR installed? 61A8 36EA 0132 61AA 1304 14 JEQ INTEX 0133 * 0134 * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) 0135 * is executed from Forth's WS (MAINWS = >8300), which it does at the end of 0136 * every CODE word, keyboard scan and one or two other places. 0137 * 0138 61AC 0201 20 LI R1,INT2 Load entry point, INT2 61AE 309A 0139 61B0 C801 38 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) 61B2 831E 0140 * 0141 * The following 2 instructions are copies of the remainder of the console ROM's 0142 * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) 0143 * because we're not going back there! 0144 * 0145 61B4 02E0 18 INTEX LWPI >83C0 Change to console's ISR WS 61B6 83C0 0146 61B8 0380 18 RTWP Return to caller of console ISR 0147 * 0148 * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored 0149 * before executing user's ISR. INT3 (cleanup routine below) will be inserted 0150 * in address list to get us back here for cleanup after user's ISR has finished. 0151 * User's ISR is executed at the end of this section just before INT3. 0152 * 0153 61BA 0300 24 INT2 LIMI 0 Disable interrupts 61BC 0000 0154 61BE D020 34 MOVB @>83D4,R0 Get copy of VR01 61C0 83D4 0155 61C2 0980 56 SRL R0,8 ...to LSB 0156 61C4 0260 22 ORI R0,>100 Set up for VR01 61C6 0100 0157 61C8 0240 22 ANDI R0,>FFDF Clear VDP-interrupt-enable bit 61CA FFDF 0158 61CC 0420 54 BLWP @VWTR Turn off VDP interrupt 61CE 3752 0159 61D0 020F 20 LI NEXT,$NEXT Restore NEXT 61D2 833A 0160 61D4 0720 34 SETO @INTACT Set Forth "pending interrupt" flag 61D6 3956 0161 61D8 064E 14 DECT R Set up return linkage by pushing 0162 61DA C78D 30 MOV IP,*R ...IP (R13, next Forth CFA) to return stack and 0163 61DC 020D 20 LI IP,INT3 ...setting IP to INT3 (below) for cleanup 61DE 30C8 0164 61E0 C2A8 34 MOV @$ISR(U),W Do the user's Forth ISR by executing 61E2 0036 0165 61E4 0460 28 B @DOEXEC ...it through Forth's inner interpreter 61E6 833C 0166 * 0167 * Clean up and re-enable interrupts. 0168 * 0169 61E8 30CA INT3 DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) 0170 61EA 30CC DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) 0171 61EC C37E 30 MOV *R+,IP Start cleanup: pop IP from before call to user's ISR 0172 61EE 04E0 34 CLR @INTACT Clear Forth "pending interrupt" flag 61F0 3956 0173 61F2 D020 34 MOVB @>83D4,R0 Prepare to restore VR01 by... 61F4 83D4 0174 61F6 0980 56 SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and 0175 61F8 0220 22 AI R0,>100 ...VR # (01) to MSB 61FA 0100 0176 61FC D060 34 MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status 61FE 8802 0177 6200 0420 54 BLWP @VWTR Write VR01 6202 3752 0178 6204 0300 24 LIMI 2 Re-enable interrupts 6206 0002 0179 6208 045F 20 B *NEXT Continue normal task 0180 ;]* 0181 ;[*** BKLINK from SYSTEM calls ========================================== 0182 * 0183 620A C1E0 34 BKLINK MOV @INTACT,R7 Are we in user's ISR? 620C 3956 0184 620E 1602 14 JNE BKLIN1 Don't enable interrupts if so. 0185 6210 0300 24 LIMI 2 6212 0002 0186 6214 045B 20 BKLIN1 B *LINK 0187 ;]* 0188 * ____ __ _____ ____ 0189 * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ 0190 * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< 0191 * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ 0192 * /___/ 0193 * 0194 ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== 0195 0196 * Entry point for low-level system support functions 0197 0198 6216 0300 24 $SYS$ LIMI 0 6218 0000 0199 621A C021 34 MOV @SYSTAB(R1),R0 621C 3114 0200 621E 0450 20 B *R0 0201 ;] 0202 ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== 0203 0204 6220 34C6 DATA BRW CODE = -20 write block to blocks file 0205 6222 34C6 DATA BRW CODE = -18 read block from blocks file 0206 6224 34C6 DATA BRW CODE = -16 create blocks file 0207 6226 34C6 DATA BRW CODE = -14 use blocks file 0208 6228 346C DATA GXY CODE = -12 GOTOXY 0209 622A 3456 DATA QKY CODE = -10 ?KEY 0210 622C 343C DATA QTM CODE = -8 ?TERMINAL 0211 622E 3420 DATA CLF CODE = -6 CRLF 0212 6230 3312 DATA EMT CODE = -4 EMIT 0213 6232 3260 DATA KY CODE = -2 KEY 0214 6234 3130 SYSTAB DATA SBW CODE = 0 VSBW 0215 6236 313E DATA MBW CODE = 2 VMBW 0216 6238 314C DATA SBR CODE = 4 VSBR 0217 623A 315A DATA MBR CODE = 6 VMBR 0218 623C 3176 DATA WTR CODE = 8 VWTR 0219 623E 3186 DATA GPL CODE = 10 GPLLNK 0220 6240 31A6 DATA XML CODE = 12 XMLLNK 0221 6242 31C0 DATA DSR CODE = 14 DSRLNK 0222 6244 31DA DATA CLS$ CODE = 16 CLS 0223 6246 3168 DATA MVE CODE = 18 VMOVE 0224 6248 31F4 DATA FILL$ CODE = 20 VFILL 0225 624A 3224 DATA AOX CODE = 22 VAND 0226 624C 3224 DATA AOX CODE = 24 VOR 0227 624E 3224 DATA AOX CODE = 26 VXOR 0228 ;]* 0229 ;[*== VDP single byte write. CODE = 0 ================= 0230 * 0231 6250 C039 30 SBW MOV *SP+,R0 VRAM address (destination) 0232 6252 C079 30 MOV *SP+,R1 Character to write 0233 6254 06C1 14 SWPB R1 Get in left byte 0234 6256 0420 54 BLWP @VSBW 6258 373E 0235 625A 0460 28 B @BKLINK 625C 30EA 0236 ;]* 0237 ;[*== VDP multi byte write. CODE = 2 ================= 0238 * 0239 625E C0B9 30 MBW MOV *SP+,R2 Number of bytes to move 0240 6260 C039 30 MOV *SP+,R0 VRAM address (destination) 0241 6262 C079 30 MOV *SP+,R1 RAM address (source) 0242 6264 0420 54 BLWP @VMBW 6266 3742 0243 6268 0460 28 B @BKLINK 626A 30EA 0244 ;]* 0245 ;[*== VDP single byte read. CODE = 4 ================= 0246 * 0247 626C C019 26 SBR MOV *SP,R0 VRAM address (source) 0248 626E 0420 54 BLWP @VSBR 6270 3746 0249 6272 0981 56 SRL R1,8 Character to right half for Forth 0250 6274 C641 30 MOV R1,*SP Stack it 0251 6276 0460 28 B @BKLINK 6278 30EA 0252 ;]* 0253 ;[*== VDP multi byte read. CODE = 6 ================= 0254 * 0255 627A C0B9 30 MBR MOV *SP+,R2 Number of bytes to read 0256 627C C079 30 MOV *SP+,R1 RAM address (destination) 0257 627E C039 30 MOV *SP+,R0 VRAM address (source) 0258 6280 0420 54 BLWP @VMBR 6282 374A 0259 6284 0460 28 B @BKLINK 6286 30EA 0260 ;]* 0261 ;[*== VDP-to-VDP move. CODE = 18 ================= 0262 * 0263 6288 C039 30 MVE MOV *SP+,R0 Pop cnt to R0 0264 628A C0B9 30 MOV *SP+,R2 Pop vdst to R2 0265 628C C079 30 MOV *SP+,R1 Pop vsrc to R1 0266 628E 0420 54 BLWP @VMOVE 6290 374E 0267 6292 0460 28 B @BKLINK 6294 30EA 0268 ;]* 0269 ;[*== VDP register write. CODE = 8 ================= 0270 * 0271 6296 C079 30 WTR MOV *SP+,R1 VDP register number 0272 6298 C039 30 MOV *SP+,R0 Data for register 0273 629A 06C1 14 SWPB R1 Get register to left byte 0274 629C D001 18 MOVB R1,R0 Place with data 0275 629E 0420 54 BLWP @VWTR 62A0 3752 0276 62A2 0460 28 B @BKLINK 62A4 30EA 0277 ;]* 0278 ;[*== GPL link utility. CODE = 10 ================= 0279 * 0280 62A6 04C0 14 GPL CLR R0 0281 62A8 D800 38 MOVB R0,@KYSTAT 62AA 837C 0282 62AC 0200 20 LI R0,>0420 Construct the BLWP instruction 62AE 0420 0283 62B0 0201 20 LI R1,GPLLNK to the GPLLNK utility 62B2 3784 0284 62B4 C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0285 62B6 0203 20 LI R3,>045B Construct the B *LINK instruction 62B8 045B 0286 62BA C10B 18 MOV LINK,R4 Save LINK address 0287 62BC 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62BE 8300 0288 62C0 C2C4 18 MOV R4,LINK and reconstruct LINK 0289 62C2 0460 28 B @BKLINK 62C4 30EA 0290 ;]* 0291 ;[*== XML link utility. CODE = 12 ================= 0292 * 0293 62C6 0200 20 XML LI R0,>0420 Construct the BLWP instruction 62C8 0420 0294 62CA 0201 20 LI R1,XMLLNK to the XMLLNK utility 62CC 3736 0295 62CE C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0296 62D0 0203 20 LI R3,>045B Construct the B *LINK instruction 62D2 045B 0297 62D4 C10B 18 MOV LINK,R4 Save LINK address 0298 62D6 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62D8 8300 0299 62DA C2C4 18 MOV R4,LINK and reconstruct LINK 0300 62DC 0460 28 B @BKLINK 62DE 30EA 0301 ;]* 0302 ;[*== DSR link utility. CODE = 14 ================= 0303 * 0304 62E0 0200 20 DSR LI R0,>0420 Construct the BLWP instruction 62E2 0420 0305 62E4 0201 20 LI R1,DSRLNK to the DSRLNK utility 62E6 37BE 0306 62E8 C0B9 30 MOV *SP+,R2 This datum selects DSR or subroutine 0307 62EA 0203 20 LI R3,>045B Construct the B *LINK instruction 62EC 045B 0308 62EE C10B 18 MOV LINK,R4 Save LINK address 0309 62F0 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62F2 8300 0310 62F4 C2C4 18 MOV R4,LINK and reconstruct LINK 0311 62F6 0460 28 B @BKLINK 62F8 30EA 0312 ;]* 0313 ;[*== Screen clearing utility. CODE = 16 ================= 0314 * 0315 62FA C0A8 34 CLS$ MOV @$SSTRT(U),R2 Beginning of screen in VRAM 62FC 0032 0316 62FE C068 34 MOV @$SEND(U),R1 End of screen in VRAM 6300 0034 0317 6302 6042 18 S R2,R1 Screen size 0318 6304 0200 20 LI R0,>2000 Blank character 6306 2000 0319 6308 C1CB 18 MOV LINK,R7 0320 630A 06A0 32 BL @FILL1 630C 3208 0321 630E C2C7 18 MOV R7,LINK 0322 6310 0460 28 B @BKLINK 6312 30EA 0323 ;]* 0324 ;[*== VDP fill routine. CODE = 20 ================= 0325 * 0326 6314 C039 30 FILL$ MOV *SP+,R0 Fill character 0327 6316 06C0 14 SWPB R0 to left byte 0328 6318 C079 30 MOV *SP+,R1 Fill count 0329 631A C0B9 30 MOV *SP+,R2 Address to start VRAM fill 0330 631C C1CB 18 MOV LINK,R7 0331 631E 06A0 32 BL @FILL1 6320 3208 0332 6322 C2C7 18 MOV R7,LINK 0333 6324 0460 28 B @BKLINK 6326 30EA 0334 *======================================================================== 0335 FILL1 ; R0=char, R1=cnt, R2=vaddr 0336 6328 0262 22 ORI R2,>4000 Set bit for VDP write 632A 4000 0337 632C 06C2 14 SWPB R2 0338 632E D802 38 MOVB R2,@VDPWA LS byte first 6330 8C02 0339 6332 06C2 14 SWPB R2 0340 6334 D802 38 MOVB R2,@VDPWA Then MS byte 6336 8C02 0341 6338 1000 14 NOP Kill time 0342 633A D800 38 FLOOP MOVB R0,@VDPWD Write a byte 633C 8C00 0343 633E 0601 14 DEC R1 0344 6340 16FC 14 JNE FLOOP Not done, fill another 0345 6342 045B 20 B *LINK 0346 ;]*====================================================================== 0347 * 0348 *==== VAND -- VDP byte AND routine. CODE = 22 ================= 0349 *==== VOR -- VDP byte OR routine. CODE = 24 ================= 0350 ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= 0351 * 0352 6344 C0B9 30 AOX MOV *SP+,R2 VRAM address 0353 6346 06C2 14 SWPB R2 0354 6348 D802 38 MOVB R2,@VDPWA LS byte first 634A 8C02 0355 634C 06C2 14 SWPB R2 0356 634E D802 38 MOVB R2,@VDPWA Then MS byte 6350 8C02 0357 6352 1000 14 NOP Kill time 0358 6354 D0E0 34 MOVB @VDPRD,R3 Read byte 6356 8800 0359 6358 C039 30 MOV *SP+,R0 Get data to operate with 0360 635A 06C0 14 SWPB R0 to left byte 0361 *** Now do requested operation ***************** 0362 635C 0281 22 CI R1,24 635E 0018 0363 6360 1304 14 JEQ DOOR 0364 6362 1505 14 JGT DOXOR 0365 6364 0543 14 INV R3 These two instructions 0366 6366 4003 18 SZC R3,R0 perform an 'AND' 0367 6368 1003 14 JMP FINAOX 0368 636A E003 18 DOOR SOC R3,R0 perform 'OR' 0369 636C 1001 14 JMP FINAOX 0370 636E 2803 18 DOXOR XOR R3,R0 perform 'XOR' 0371 6370 0201 20 FINAOX LI R1,1 6372 0001 0372 6374 C1CB 18 MOV LINK,R7 0373 6376 06A0 32 BL @FILL1 6378 3208 0374 637A C2C7 18 MOV R7,LINK 0375 637C 0460 28 B @BKLINK 637E 30EA 0376 ;]* 0377 ;[*== KEY routine CODE = -2 ================= 0378 * 0379 6380 C028 34 KY MOV @$ALTI(U),R0 alternate input device? 6382 0038 0380 6384 131B 14 JEQ KEY0 jump to keyboard input if not 0381 * 0382 * R0 now points to PAB for alternate input device, the one-byte buffer 0383 * for which must immediately precede its PAB. PAB must have been set up 0384 * to read one byte. 0385 * 0386 6386 04C7 14 CLR R7 prepare to zero status byte 0387 6388 D807 38 MOVB R7,@KYSTAT zero status byte 638A 837C 0388 638C 0580 14 INC R0 point R0 to Flag/Status byte 0389 638E 0420 54 BLWP @VSBR read it 6390 3746 0390 6392 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6394 1F00 0391 6396 0420 54 BLWP @VSBW write it back to PAB 6398 373E 0392 639A C040 18 MOV R0,R1 Set up pointer... 0393 639C 0221 22 AI R1,8 ...to namelength byte of PAB 639E 0008 0394 63A0 C801 38 MOV R1,@SUBPTR copy to DSR subroutine name-length pointer 63A2 8356 0395 63A4 C0C0 18 MOV R0,R3 save pointer (DSRLNK will trash it!) 0396 63A6 0420 54 BLWP @DSRLNK get 1 byte from device 63A8 37BE 0397 63AA 0008 DATA >8 0398 63AC C003 18 MOV R3,R0 restore pointer 0399 63AE 0640 14 DECT R0 point to one-byte VRAM buffer in front of PAB 0400 63B0 0420 54 BLWP @VSBR read character 63B2 3746 0401 63B4 0981 56 SRL R1,8 move to LSB 0402 63B6 C001 18 MOV R1,R0 copy to return register 0403 63B8 0460 28 B @BKLINK return to caller 63BA 30EA 0404 * 0405 * Input is comining from the keyboard 0406 * 0407 63BC C1E0 34 KEY0 MOV @KEYCNT,R7 63BE 3954 0408 63C0 0587 14 INC R7 0409 63C2 160A 14 JNE KEY1 0410 63C4 C028 34 MOV @CURPO$(U),R0 63C6 0016 0411 63C8 0420 54 BLWP @VSBR Read character at cursor position... 63CA 3746 0412 63CC D801 38 MOVB R1,@CURCHR ...and save it 63CE 3ABC 0413 63D0 0201 20 LI R1,>1E00 Place cursor character on screen 63D2 1E00 0414 63D4 0420 54 BLWP @VSBW 63D6 373E 0415 * 0416 63D8 0420 54 KEY1 BLWP @KSCAN 63DA 373A 0417 63DC D020 34 MOVB @KYSTAT,R0 63DE 837C 0418 63E0 2020 38 COC @H2000,R0 check status 63E2 3734 0419 63E4 1319 14 JEQ KEY2 JMP if key was pressed 0420 * 0421 63E6 0287 22 CI R7,100 No key pressed 63E8 0064 0422 63EA 1603 14 JNE KEY3 0423 63EC D060 34 MOVB @CURCHR,R1 63EE 3ABC 0424 63F0 1006 14 JMP KEY5 0425 * 0426 63F2 0287 22 KEY3 CI R7,200 63F4 00C8 0427 63F6 1607 14 JNE KEY4 0428 63F8 04C7 14 CLR R7 0429 63FA 0201 20 LI R1,>1E00 Cursor char 63FC 1E00 0430 63FE C028 34 KEY5 MOV @CURPO$(U),R0 6400 0016 0431 6402 0420 54 BLWP @VSBW 6404 373E 0432 6406 C807 38 KEY4 MOV R7,@KEYCNT 6408 3954 0433 640A C1E0 34 MOV @INTACT,R7 Are we in user's ISR? 640C 3956 0434 640E 1602 14 JNE KEY6 Don't enable interrupts if so. 0435 6410 0300 24 LIMI 2 6412 0002 0436 6414 064D 14 KEY6 DECT IP This will re-execute KEY 0437 6416 045F 20 B *NEXT 0438 6418 0720 34 KEY2 SETO @KEYCNT Key was pressed 641A 3954 0439 641C C028 34 MOV @CURPO$(U),R0 Restore character at cursor location 641E 0016 0440 6420 D060 34 MOVB @CURCHR,R1 6422 3ABC 0441 6424 0420 54 BLWP @VSBW 6426 373E 0442 6428 D020 34 MOVB @KYCHAR,R0 Put char in... 642A 8375 0443 642C 0980 56 SRL R0,8 ...LSB of R0 0444 642E 0460 28 B @BKLINK 6430 30EA 0445 ;]* 0446 ;[*== EMIT routine CODE = -4 ================= 0447 * 0448 6432 C042 18 EMT MOV R2,R1 copy char to R1 for VSBW 0449 6434 C028 34 MOV @$ALTO(U),R0 alternate output device? 6436 003A 0450 6438 1317 14 JEQ EMIT0 jump to video display output if not 0451 * 0452 * R0 now points to PAB for alternate output device, the one-byte buffer 0453 * for which must immediately precede its PAB. PAB must have been set up 0454 * to write one byte. 0455 * 0456 643A 04C7 14 CLR R7 ALTOUT active 0457 643C D807 38 MOVB R7,@KYSTAT zero status byte 643E 837C 0458 6440 0600 14 DEC R0 point to one-byte VRAM buffer in front of PAB 0459 6442 06C1 14 SWPB R1 char to MSB 0460 6444 0420 54 BLWP @VSBW write char to buffer 6446 373E 0461 6448 05C0 14 INCT R0 point to Flag/Status byte 0462 644A 0420 54 BLWP @VSBR read it 644C 3746 0463 644E 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6450 1F00 0464 6452 0420 54 BLWP @VSBW write it back to PAB 6454 373E 0465 6456 0220 22 AI R0,8 Set up pointer to namelength byte of PAB 6458 0008 0466 645A C800 38 MOV R0,@SUBPTR copy to DSR subroutine name-length pointer 645C 8356 0467 645E 0420 54 BLWP @DSRLNK put 1 byte to device 6460 37BE 0468 6462 0008 DATA >8 0469 6464 0460 28 B @BKLINK return to caller 6466 30EA 0470 * 0471 * Output is going to the video display 0472 * 0473 6468 0281 22 EMIT0 CI R1,7 Is it a bell? 646A 0007 0474 646C 1607 14 JNE NOTBEL 0475 646E 04C2 14 CLR R2 0476 6470 D802 38 MOVB R2,@KYSTAT 6472 837C 0477 6474 0420 54 BLWP @GPLLNK 6476 3784 0478 6478 0036 DATA >0036 Emit error tone 0479 647A 1060 14 JMP EMEXIT 0480 * 0481 647C 0281 22 NOTBEL CI R1,8 Is it a backspace? 647E 0008 0482 6480 160B 14 JNE NOTBS 0483 6482 0201 20 LI R1,>2000 6484 2000 0484 6486 C028 34 MOV @CURPO$(U),R0 6488 0016 0485 648A 0420 54 BLWP @VSBW 648C 373E 0486 648E 1501 14 JGT DECCUR 0487 6490 1055 14 JMP EMEXIT 0488 6492 0628 34 DECCUR DEC @CURPO$(U) 6494 0016 0489 6496 1052 14 JMP EMEXIT 0490 * 0491 6498 0281 22 NOTBS CI R1,>A Is it a line feed? 649A 000A 0492 649C 162B 14 JNE NOTLF 0493 649E C1E8 34 MOV @$SEND(U),R7 64A0 0034 0494 64A2 61E8 34 S @$SWDTH(U),R7 64A4 0030 0495 64A6 81E8 34 C @CURPO$(U),R7 64A8 0016 0496 64AA 1404 14 JHE SCRLL 0497 64AC AA28 54 A @$SWDTH(U),@CURPO$(u) 64AE 0030 64B0 0016 0498 64B2 1044 14 JMP EMEXIT 0499 64B4 C1CB 18 SCRLL MOV LINK,R7 0500 64B6 06A0 32 BL @SCROLL 64B8 339E 0501 64BA C2C7 18 MOV R7,LINK 0502 64BC 103F 14 JMP EMEXIT 0503 * 0504 *** SCROLLING ROUTINE 0505 * 0506 64BE C028 34 SCROLL MOV @$SSTRT(U),R0 VRAM addr 64C0 0032 0507 64C2 0201 20 LI R1,LINBUF Line buffer 64C4 3A6C 0508 64C6 C0A8 34 MOV @$SWDTH(U),R2 Count 64C8 0030 0509 64CA A002 18 A R2,R0 Start at line 2 0510 64CC 0420 54 SCROL1 BLWP @VMBR 64CE 374A 0511 64D0 6002 18 S R2,R0 One line back to write 0512 64D2 0420 54 BLWP @VMBW 64D4 3742 0513 64D6 A002 18 A R2,R0 Two lines ahead for next read 0514 64D8 A002 18 A R2,R0 0515 64DA 8A00 38 C R0,@$SEND(U) End of screen? 64DC 0034 0516 64DE 1AF6 14 JL SCROL1 0517 64E0 C042 18 MOV R2,R1 Blank bottom row of screen 0518 64E2 0200 20 LI R0,>2000 Blank 64E4 2000 0519 64E6 60A8 34 S @$SEND(U),R2 64E8 0034 0520 64EA 0502 16 NEG R2 Now contains address of start of last line 0521 64EC C18B 18 MOV LINK,R6 0522 64EE 06A0 32 BL @FILL1 Write the blanks 64F0 3208 0523 64F2 0456 20 B *R6 0524 * 0525 64F4 0281 22 NOTLF CI R1,>D Is it a carriage return? 64F6 000D 0526 64F8 160D 14 JNE NOTCR 0527 64FA 04C0 14 CLR R0 0528 64FC C068 34 MOV @CURPO$(U),R1 64FE 0016 0529 6500 C0C1 18 MOV R1,R3 0530 6502 6068 34 S @$SSTRT(U),R1 Adjusted for screen not at 0 6504 0032 0531 6506 C0A8 34 MOV @$SWDTH(U),R2 6508 0030 0532 650A 3C02 128 DIV R2,R0 0533 650C 60C1 18 S R1,R3 0534 650E CA03 38 MOV R3,@CURPO$(U) 6510 0016 0535 6512 1014 14 JMP EMEXIT 0536 * 0537 6514 06C1 14 NOTCR SWPB R1 Assume it is a printable character 0538 6516 C028 34 MOV @CURPO$(U),R0 6518 0016 0539 651A 0420 54 BLWP @VSBW 651C 373E 0540 651E C0A8 34 MOV @$SEND(U),R2 6520 0034 0541 6522 0602 14 DEC R2 0542 6524 8080 18 C R0,R2 0543 6526 1607 14 JNE NOTCR1 0544 6528 C028 34 MOV @$SEND(U),R0 652A 0034 0545 652C 6028 34 S @$SWDTH(U),R0 Was last char on screen. Scroll 652E 0030 0546 6530 CA00 38 MOV R0,@CURPO$(U) 6532 0016 0547 6534 10BF 14 JMP SCRLL 0548 6536 0580 14 NOTCR1 INC R0 No scroll necessary 0549 6538 CA00 38 MOV R0,@CURPO$(U) 653A 0016 0550 * 0551 653C 0460 28 EMEXIT B @BKLINK 653E 30EA 0552 ;]* 0553 ;[*== CRLF routine CODE = -6 ================= 0554 * 0555 6540 C14B 18 CLF MOV LINK,R5 0556 6542 0202 20 LI R2,>000D 6544 000D 0557 6546 06A0 32 BL @EMT EMT will alter INT mask via B @BKLINK 6548 3312 0558 654A 0202 20 LI R2,>000A 654C 000A 0559 654E 0300 24 LIMI 0 Previous call to EMT altered INT mask 6550 0000 0560 6552 06A0 32 BL @EMT 6554 3312 0561 6556 C2C5 18 MOV R5,LINK 0562 6558 0460 28 B @BKLINK 655A 30EA 0563 ;]* 0564 ;[*== ?TERMINAL routine CODE = -8 ================= 0565 * scan for <clear>, <break>, FCTN+4 press 0566 * 0567 655C C14B 18 QTM MOV LINK,R5 save return 0568 655E 06A0 32 BL @>0020 branch to console's test for <clear> 6560 0020 0569 6562 02C0 12 STST R0 store status in R0 0570 6564 1603 14 JNE QTM2 exit if not <clear> 0571 6566 06A0 32 QTM1 BL @>0020 check for <clear> again 6568 0020 0572 656A 13FD 14 JEQ QTM1 loop until not <clear> 0573 656C C2C5 18 QTM2 MOV R5,LINK restore return 0574 656E 0240 22 ANDI R0,>2000 keep only EQU bit 6570 2000 0575 6572 0460 28 B @BKLINK return to caller 6574 30EA 0576 ;]* 0577 ;[*== ?KEY routine CODE = -10 ================= 0578 * 0579 6576 0420 54 QKY BLWP @KSCAN 6578 373A 0580 657A D020 34 MOVB @KYCHAR,R0 657C 8375 0581 657E 0980 56 SRL R0,8 0582 6580 0280 22 CI R0,>00FF 6582 00FF 0583 6584 1601 14 JNE QKEY1 0584 6586 04C0 14 CLR R0 0585 6588 0460 28 QKEY1 B @BKLINK 658A 30EA 0586 ;]* 0587 ;[*== GOTOXY routine CODE = -12 ================= 0588 * 0589 658C 38E8 72 GXY MPY @$SWDTH(U),R3 658E 0030 0590 6590 A102 18 A R2,R4 Position within screen 0591 6592 A128 34 A @$SSTRT(U),R4 Add VRAM offset to screen top 6594 0032 0592 6596 CA04 38 MOV R4,@CURPO$(U) 6598 0016 0593 659A 0460 28 B @BKLINK 659C 30EA 0594 ;] 0595 * ___ __ __ ____ ______ 0596 * / _ )/ /__ ____/ /__ / _/_/_/ __ \ 0597 * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / 0598 * /____/_/\___/\__/_/\_\ /___/_/ \____/ 0599 0600 * 0601 *== USE blocks file CODE = -14 ================= 0602 *== CREATE blocks file CODE = -16 ================= 0603 *== READ block from blocks file CODE = -18 ================= 0604 *== WRITE block to blocks file CODE = -20 ================= 0605 ;[*== Block File I/O Support ============================================ 0606 * 0607 * BPTOG utility to toggle one of 2 PABs for block file access 0608 * 0609 659E C028 34 BPTOG MOV @$BPOFF(U),R0 PAB offset to R0 65A0 0040 0610 65A2 0201 20 LI R1,70 Toggle amount 65A4 0046 0611 65A6 2840 18 XOR R0,R1 New offset 0612 65A8 CA01 38 MOV R1,@$BPOFF(U) Update offset 65AA 0040 0613 * 0614 **xxx** entry point to insure we have correct PAB address 0615 65AC C028 34 BPSET MOV @$DKBUF(U),R0 Get DISK_BUF address 65AE 002C 0616 65B0 A028 34 A @$BPABS(U),R0 Get BPABS address 65B2 003E 0617 * 0618 65B4 A028 34 A @$BPOFF(U),R0 Add current offset 65B6 0040 0619 65B8 C800 38 MOV R0,@BFPAB Update current block file's PAB address 65BA 34BC 0620 65BC 045B 20 RT 0621 * 0622 * CLOSE blocks file 0623 * 0624 65BE C020 34 BKCLOS MOV @BFPAB,R0 65C0 34BC 0625 65C2 0201 20 LI R1,$FCLS Opcode=CLOSE 65C4 0100 0626 65C6 0420 54 BLWP @VSBW 65C8 373E 0627 65CA 0220 22 AI R0,9 Address of filename's char count 65CC 0009 0628 65CE C800 38 MOV R0,@SUBPTR Point to filename's char count 65D0 8356 0629 65D2 0420 54 BLWP @DSRLNK Close the file 65D4 37BE 0630 65D6 0008 DATA 8 0631 65D8 045B 20 RT Deal with error in caller 0632 * 0633 * storage area 0634 * 0635 65DA 0000 SVBRET DATA 0 Storage for LINK coming into BRW 0636 65DC 0000 BFPAB DATA 0 Storage for current blocks file PAB address... 0637 * ...will have current PAB on entry 0638 * PAB header storage 0639 * 0640 65DE PABHD BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE 0641 * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative 0642 * >03=OUTPUT mode + " 0643 * >01=UPDATE mode + " 0644 * BYTE 2,3: save contents of DISK_BUF here 0645 65E2 80 BYTE >80 Record length 0646 65E3 80 BYTE >80 Character count of transfer 0647 65E4 BSS 2 Record number 0648 * 0649 *** file I/O equates 0650 * 0651 0000 $FOPN EQU >0000 0652 0100 $FCLS EQU >0100 0653 0200 $FRD EQU >0200 0654 0300 $FWRT EQU >0300 0655 0400 $FRST EQU >0400 0656 0005 $FINP EQU 5 0657 0003 $FOUT EQU 3 0658 0001 $FUPD EQU 1 0659 * 0660 *** BRW -- entry point for block read/write routines 0661 * 0662 65E6 C80B 38 BRW MOV LINK,@SVBRET Save LINK address 65E8 34BA 0663 65EA C1C1 18 MOV R1,R7 Save CODE {R1 to R7} 0664 65EC 0817 56 SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) 0665 65EE 0227 22 AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) 65F0 000C 0666 65F2 06A0 32 BL @BPSET Insure correct PAB address in BFPAB (it may have moved) 65F4 348C 0667 65F6 0287 22 CI R7,4 USE or CREATE? 65F8 0004 0668 65FA 110D 14 JLT BRW01 No 0669 65FC 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 65FE 347E 0670 6600 C020 34 MOV @BFPAB,R0 Load PAB address 6602 34BC 0671 6604 0220 22 AI R0,9 Set to name length byte 6606 0009 0672 6608 04C2 14 CLR R2 0673 660A C079 30 MOV *SP+,R1 Pop bfnaddr to R1 0674 660C D811 46 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 660E 8305 0675 6610 0582 14 INC R2 Add 1 to # bytes to copy 0676 6612 0420 54 BLWP @VMBW Copy char count & pathname to PAB 6614 3742 0677 * 0678 *** set up PAB for OPEN 0679 * 0680 6616 0201 20 BRW01 LI R1,$FUPD Opcode=0,mode=update 6618 0001 0681 661A 9820 54 CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? 661C 830F 661E 830F 0682 6620 1C02 14 JOP BRW02 No 0683 6622 0201 20 LI R1,$FINP Yes...change mode=input 6624 0005 0684 6626 C801 38 BRW02 MOV R1,@PABHD Put in PAB header 6628 34BE 0685 662A C828 54 MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header 662C 002C 662E 34C0 0686 6630 04C0 14 CLR R0 0687 6632 C800 38 MOV R0,@PABHD+6 Set record#=0 6634 34C4 0688 6636 C020 34 MOV @BFPAB,R0 VRAM destination 6638 34BC 0689 663A 0201 20 LI R1,PABHD RAM source 663C 34BE 0690 663E 0202 20 LI R2,8 Copy first 8 bytes of PAB header 6640 0008 0691 6642 0420 54 BLWP @VMBW Do the copy 6644 3742 0692 * 0693 *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] 0694 * 0695 6646 0220 22 AI R0,9 Address of filename's char count in PAB 6648 0009 0696 664A C800 38 MOV R0,@SUBPTR Point to-----^^^^ 664C 8356 0697 664E 0420 54 BLWP @DSRLNK Open/create the file 6650 37BE 0698 6652 0008 DATA 8 0699 6654 135F 14 JEQ BKERR 0700 6656 0287 22 CI R7,4 READ or WRITE? 6658 0004 0701 665A 1120 14 JLT BRW04 Yes 0702 665C 156E 14 JGT BRWDON No; =USE; we're done 0703 * 0704 *** write blank records to newly created blocks file [CODE = -16,CREATE] 0705 * 0706 665E C179 30 MOV *SP+,R5 No; = CREATE; pop #blocks from stack 0707 6660 0A35 56 SLA R5,3 Convert #blocks to #records 0708 6662 C0C5 18 MOV R5,R3 Save 0709 6664 C105 18 MOV R5,R4 Set up counter 0710 6666 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 6668 0301 0711 666A C800 38 MOV R0,@PABHD Copy to PAB header 666C 34BE 0712 666E 6144 18 BRLOOP S R4,R5 Calculate next record 0713 6670 C805 38 MOV R5,@PABHD+6 Copy to PAB header 6672 34C4 0714 6674 C020 34 MOV @BFPAB,R0 VRAM destination 6676 34BC 0715 6678 0201 20 LI R1,PABHD RAM source 667A 34BE 0716 667C 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 667E 0008 0717 6680 0420 54 BLWP @VMBW Do the copy 6682 3742 0718 6684 0220 22 AI R0,9 Address of filename's char count 6686 0009 0719 6688 C800 38 MOV R0,@SUBPTR Point to filename's char count 668A 8356 0720 668C 0420 54 BLWP @DSRLNK Write one record of blanks 668E 37BE 0721 6690 0008 DATA 8 0722 6692 1340 14 JEQ BKERR 0723 6694 C143 18 MOV R3,R5 Get #blocks 0724 6696 0604 14 DEC R4 Count down 1 record 0725 6698 16EA 14 JNE BRLOOP Write another record if not done 0726 669A 104F 14 JMP BRWDON We're done 0727 * 0728 *** prepare for read/write block 0729 * 0730 669C C179 30 BRW04 MOV *SP+,R5 Pop block# to write 0731 669E C1B9 30 MOV *SP+,R6 Pop bufaddr 0732 66A0 0605 14 DEC R5 Block#-1 0733 66A2 0A35 56 SLA R5,3 Convert to starting record# 0734 66A4 0204 20 LI R4,8 Load counter for 8 records 66A6 0008 0735 66A8 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 66AA 0301 0736 66AC 0203 20 LI R3,VMBW WRITE vector 66AE 3742 0737 66B0 0287 22 CI R7,2 Are we writing the block? 66B2 0002 0738 66B4 1304 14 JEQ BRW05 Yup 0739 66B6 0200 20 LI R0,$FRD+$FINP Nope...set up for READ 66B8 0205 0740 66BA 0203 20 LI R3,VMBR READ vector 66BC 374A 0741 66BE C800 38 BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header 66C0 34BE 0742 * 0743 * READ/WRITE block routine [CODE = -18/-20] 0744 * 0745 66C2 C805 38 RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header 66C4 34C4 0746 66C6 C020 34 MOV @BFPAB,R0 VRAM destination 66C8 34BC 0747 66CA 0201 20 LI R1,PABHD RAM source 66CC 34BE 0748 66CE 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 66D0 0008 0749 66D2 0420 54 BLWP @VMBW Do the copy 66D4 3742 0750 66D6 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 66D8 002C 0751 66DA C046 18 MOV R6,R1 RAM buffer to R1 0752 66DC 0202 20 LI R2,128 Bytes to copy 66DE 0080 0753 66E0 0287 22 CI R7,3 READ? 66E2 0003 0754 66E4 1301 14 JEQ BRW06 Yup 0755 66E6 0413 42 BLWP *R3 Nope...copy record to VRAM 0756 * 0757 * temporarily use CRU register---it should be OK 0758 * 0759 66E8 C320 34 BRW06 MOV @BFPAB,CRU PAB address 66EA 34BC 0760 66EC 022C 22 AI CRU,9 Address of filename's char count 66EE 0009 0761 66F0 C80C 38 MOV CRU,@SUBPTR Point to filename's char count 66F2 8356 0762 66F4 0420 54 BLWP @DSRLNK Read/write one record 66F6 37BE 0763 66F8 0008 DATA 8 0764 66FA 130C 14 JEQ BKERR 0765 66FC 0287 22 CI R7,2 WRITE? 66FE 0002 0766 6700 1303 14 JEQ BRW07 Yup...next record 0767 6702 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) 6704 002C 0768 6706 0413 42 BLWP *R3 Nope...copy record to RAM buffer 0769 6708 0585 14 BRW07 INC R5 Next record in file 0770 670A 0226 22 AI R6,128 Next record to/from block RAM buffer 670C 0080 0771 670E 0604 14 DEC R4 Count down 1 record 0772 6710 16D8 14 JNE RWLOOP Read/write another record if not done 0773 6712 1013 14 JMP BRWDON We're done 0774 * 0775 *** error handling 0776 * 0777 6714 D000 18 BKERR MOVB R0,R0 Device error? 0778 6716 1306 14 JEQ BKERR6 Yes, exit with disk error 0779 6718 0206 20 BKERR9 LI R6,9 No, exit with file error 671A 0009 0780 671C 1005 14 JMP BKCLN 0781 671E 0206 20 BKERR8 LI R6,8 Block# <=0! exit with range error 6720 0008 0782 6722 1002 14 JMP BKCLN 0783 6724 0206 20 BKERR6 LI R6,6 6726 0006 0784 6728 06A0 32 BKCLN BL @BKCLOS Close current blocks file; ignore error 672A 349E 0785 672C 0287 22 CI R7,4 USE or CREATE? 672E 0004 0786 6730 1102 14 JLT BKCLN1 No 0787 6732 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 6734 347E 0788 6736 C006 18 BKCLN1 MOV R6,R0 Pass error back to caller 0789 6738 100C 14 JMP BKEXIT 0790 673A 04C6 14 BRWDON CLR R6 0791 673C 06A0 32 BL @BKCLOS Close current blocks file 673E 349E 0792 6740 1602 14 JNE BRWDN1 Error? 0793 6742 0206 20 LI R6,9 Yes...assume it was a file error 6744 0009 0794 6746 0287 22 BRWDN1 CI R7,4 (no error)...CREATE? 6748 0004 0795 674A 1602 14 JNE BRWDN2 No...we're done 0796 674C 06A0 32 BL @BPTOG Yes...revert to correct blocks file 674E 347E 0797 6750 C006 18 BRWDN2 MOV R6,R0 Error to R0 0798 6752 C2E0 34 BKEXIT MOV @SVBRET,LINK Restore LINK 6754 34BA 0799 6756 0460 28 B @BKLINK 6758 30EA 0800 ;] 0801 ;[* MSGTYP <<< Support for string typing in various banks >>> 0802 * 0803 * Called with: BL @MSGTYP 0804 * 0805 * R4 and R5 are the only registers that will be preserved 0806 * ..after a call to EMIT--- 0807 * 0808 * Input: R4 = Address of length byte of packed string 0809 * 0810 * We will pass the ASCII value of character to EMIT in R2 without 0811 * insuring it is 7 bits wide. 0812 * 0813 675A 064E 14 MSGTYP DECT R Push return address 0814 675C C78B 30 MOV LINK,*R ...to Forth return stack 0815 675E 04C5 14 CLR R5 0816 6760 D174 28 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char 0817 6762 06C5 14 SWPB R5 Put char count in low byte 0818 6764 04C2 14 MTLOOP CLR R2 0819 6766 D0B4 28 MOVB *R4+,R2 Copy next char to R2 for EMIT 0820 6768 06C2 14 SWPB R2 Put char in low byte 0821 676A 0300 24 LIMI 0 We need to do this because we're calling EMIT directly 676C 0000 0822 676E 06A0 32 BL @EMT Call EMIT directly 6770 3312 0823 6772 05A8 34 INC @$OUT(U) Increment display line character count 6774 0052 0824 6776 0605 14 DEC R5 Decrement character count for this message 0825 6778 16F5 14 JNE MTLOOP Are we done? 0826 677A C2FE 30 MOV *R+,LINK Yes. Pop return address 0827 677C 045B 20 RT Return to caller 0828 ;] 0829 ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) 0830 677E CD74 46 R4$5 MOV *R4+,*R5+ 0831 6780 CD74 46 MOV *R4+,*R5+ 0832 6782 CD74 46 MOV *R4+,*R5+ 0833 6784 C554 38 MOV *R4,*R5 0834 6786 045B 20 RT 0835 ;] 0836 * __ __ _ __ _ __ __ 0837 * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ 0838 * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) 0839 * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ 0840 * ___ ___ ____ 0841 * / _ \___ / _/__ ___ __/ / /____ 0842 * / // / -_) _/ _ `/ // / / __(_-< 0843 * /____/\__/_/ \_,_/\_,_/_/\__/___/ 0844 0845 ;[*== User Variable defaults ============================================ 0846 * 0847 6788 UBASE0 BSS 6 BASE OF USER VARIABLES 0848 678E 3668 DATA UBASE0 06 USER UCONS$ 0849 6790 FFA0 DATA SPBASE 08 USER S0 0850 6792 3FFE DATA RBASE 0A USER R0 { R0$ 0851 6794 36B4 DATA $UVAR 0C USER U0 0852 6796 FFA0 DATA SPBASE 0E USER TIB 0853 6798 001F DATA 31 10 USER WIDTH 0854 679A A000 DATA DPBASE 12 USER DP 0855 679C 30F6 DATA $SYS$ 14 USER SYS$ 0856 679E 0000 DATA 0 16 USER CURPOS 0857 67A0 3020 DATA INT1 18 USER INTLNK 0858 67A2 0001 DATA 1 1A USER WARNING 0859 67A4 0040 DATA 64 1C USER C/L$ { CL$ 0860 67A6 2010 DATA $BUFF 1E USER FIRST$ 0861 67A8 3020 DATA $LO 20 USER LIMIT$ 0862 67AA 0380 DATA >0380 22 USER COLTAB Color Table address in VRAM 0863 67AC 0300 DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM 0864 67AE 0780 DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM 0865 67B0 0800 DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM 0866 67B2 0080 DATA >80 2A USER FPB pushes address of user screen font file PAB 0867 * ...that is this relative distance from DISK_BUF 0868 67B4 1000 DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) 0869 67B6 0460 DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) 0870 67B8 0028 DATA 40 30 USER SCRN_WIDTH 0871 67BA 0000 DATA 0 32 USER SCRN_START 0872 67BC 03C0 DATA 960 34 USER SCRN_END 0873 67BE 0000 DATA 0 36 USER ISR [Note: This used to be INT1] 0874 67C0 0000 DATA 0 38 USER ALTIN 0875 67C2 0000 DATA 0 3A USER ALTOUT 0876 67C4 0001 DATA 1 3C USER VDPMDE permanent location for VDPMDE 0877 67C6 00C6 DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files 0878 * ...that is this relative distance from DISK_BUF 0879 67C8 0000 DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB 0880 * ...always toggled between 0 and 70 0881 67CA 0800 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM 0882 67CC FFFF DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) 0883 * 0 = console font via GPLLNK 0884 67CE 0000 DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU 0885 67D0 0000 DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap 0886 67D2 0000 DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. 0887 * 0 = Symmetric (default) 0888 * !0 = Floored 0889 67D4 $UVAR BSS >80 USER VARIABLE AREA 0890 ;] 0891 ;[*== A Constant ==================================================== 0892 * 0893 6854 2000 H2000 DATA >2000 0894 ;]* 0895 * __ ____ _ ___ __ _ __ __ 0896 * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ 0897 * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< 0898 * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ 0899 * /___/ 0900 * 0901 ;[*== Utility Vectors =================================================== 0902 * 0903 * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK 0904 * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK 0905 6856 3A4C XMLLNK DATA UTILWS,XMLENT ; Link to ROM routines 6858 3756 0906 685A 3A4C KSCAN DATA UTILWS,KSENTR ; Keyboard scan 685C 3832 0907 685E 3A4C VSBW DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) 6860 3848 0908 6862 3A4C VMBW DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) 6864 3854 0909 6866 3A4C VSBR DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) 6868 3862 0910 686A 3A4C VMBR DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) 686C 386E 0911 686E 3A4C VMOVE DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) 6870 38AE 0912 6872 3A4C VWTR DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) 6874 387C 0913 ;]* 0914 ;[*== XMLENT -- Link to system XML utilities ============================ 0915 * 0916 6876 C83E 50 XMLENT MOV *R14+,@GPLWS+2 Get argument 6878 83E2 0917 687A 02E0 18 LWPI GPLWS Select GPL workspace 687C 83E0 0918 687E C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6880 3A62 0919 6882 C081 18 MOV R1,R2 Make a copy of argument 0920 6884 0281 22 CI R1,>8000 Direct address in ALC? 6886 8000 0921 6888 1B07 14 JH XML30 We have the address 0922 688A 09C1 56 SRL R1,12 0923 688C 0A11 56 SLA R1,1 0924 688E 0A42 56 SLA R2,4 0925 6890 09B2 56 SRL R2,11 0926 6892 A0A1 34 A @XMLTAB(R1),R2 6894 0CFA 0927 6896 C092 26 MOV *R2,R2 0928 6898 0692 24 XML30 BL *R2 0929 689A 02E0 18 LWPI UTILWS Get back to right WS 689C 3A4C 0930 689E C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 68A0 83F6 0931 68A2 0380 18 RTWP 0932 ;]* 0933 * ________ __ __ _ ____ __ __ ________ 0934 * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ 0935 * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / 0936 * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 0937 * 0938 *-----------------------------------------------------------------------* 0939 ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= 0940 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 0941 * * 0942 * This routine will work with any GROM library slot since it is * 0943 * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * 0944 * This GPLLNK does NOT require a module to be plugged into the * 0945 * GROM port so it will work with the Editor/Assembler, * 0946 * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * 0947 * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * 0948 * It saves and restores the current GROM Address in case you want * 0949 * to return back to GROM for Basic or Extended Basic CALL LINKs * 0950 * or to return to the loading module. * 0951 * * 0952 * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * 0953 * DATA >34 * 0954 * * 0955 * NOTES: Do Not REF GPLLNK when using this routine in your code. * 0956 * * 0957 * 70 Bytes - including the GPLLNK Workspace * 0958 *-----------------------------------------------------------------------* 0959 0960 * GPLWS (>83E0) is GPL workspace 0961 83E8 G_R4 EQU GPLWS+8 GPL workspace R4 0962 83EC G_R6 EQU GPLWS+12 GPL workspace R6 0963 * SUBSTK (>8373) is GPL Subroutine stack pointer 0964 0060 LDGADR EQU >60 Load & Execute GROM address entry point 0965 200E XTAB27 EQU >200E Low Mem XML table location 27 0966 * ..Will contain XMLRTN at startup 0967 166C GETSTK EQU >166C 0968 0969 68A4 3776 GPLLNK DATA GLNKWS ; R7 Set up BLWP Vectors 0970 68A6 3796 DATA GLINK1 ; R8 0971 * RTNADR <---don't think we need this label 0972 68A8 37B2 DATA XMLRTN ; R9 address where GPL XML returns to us... 0973 * ...this address will already be in XTAB27,... 0974 * ...>200E, so don't really need it here} 0975 68AA 176C GXMLAD DATA >176C ; R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) 0976 68AC 0050 DATA >50 ; R11 Initialized to >50 where PUTSTK address resides 0977 3776 GLNKWS EQU $->18 ; GPLLNK's workspace of which only... 0978 68AE BSS >08 ; R12-R15 ...registers R7 through R15 are used 0979 0980 68B6 C81B 46 GLINK1 MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS 68B8 83E8 0981 68BA C83E 50 MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS 68BC 83EC 0982 68BE 02E0 18 LWPI GPLWS Load GPL WS 68C0 83E0 0983 68C2 0694 24 BL *R4 Save current GROM Address on stack 0984 68C4 C920 54 MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return 68C6 378A 68C8 8302 0985 68CA 05E0 34 INCT @SUBSTK Adjust the stack pointer 68CC 8373 0986 68CE 0460 28 B @LDGADR Execute our GPL Routine 68D0 0060 0987 0988 68D2 C120 34 XMLRTN MOV @GETSTK,R4 Get GETSTK pointer 68D4 166C 0989 68D6 0694 24 BL *R4 Restore GROM address off the stack 0990 68D8 02E0 18 LWPI GLNKWS Load our WS 68DA 3776 0991 68DC 0380 18 RTWP All Done - Return to Caller 0992 ;] 0993 * ___ _______ __ _ ____ __ __ ________ 0994 * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ 0995 * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / 0996 * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 0997 * 0998 *-----------------------------------------------------------------------* 0999 ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= 1000 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 1001 * * 1002 * (Uses console GROM 0's DSRLNK routine) * 1003 * (Do not REF DSRLNK or GPLLNK when using these routines) * 1004 * (This DSRLNK will also handle Subprograms and CS1, CS2) * 1005 * * 1006 * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * 1007 * DATA 8 * 1008 * * 1009 * NOTES: Must be used with a GPLLNK routine * 1010 * Returns ERRORs the same as the E/A DSRLNK * 1011 * EQ bit set on return if error * 1012 * ERROR CODE in caller's MSB of Register 0 on return * 1013 * * 1014 * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * 1015 *-----------------------------------------------------------------------* 1016 1017 0050 PUTSTK EQU >50 Push GROM Address to stack pointer 1018 836D TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK 1019 8356 NAMLEN EQU >8356 Device name length pointer in VDP PAB 1020 8C02 VWA EQU >8C02 VDP Write Address location 1021 8800 VRD EQU >8800 VDP Read Data byte location 1022 83E9 G_R4LB EQU >83E9 GPL Workspace R4 Lower byte 1023 837C GSTAT EQU >837C GPL Status byte location 1024 1025 68DE 37C2 DSRLNK DATA DSRWS,DLINK1 Set BLWP Vectors 68E0 37C2 1026 1027 DSRWS ; Start of DSRLNK workspace 1028 37C9 DR3LB EQU $+7 ; lower byte of DSRLNK workspace R3 1029 68E2 C30C 18 DLINK1 MOV R12,R12 R0 Have we already looked up the LINK address? 1030 68E4 161C 14 JNE DLINK3 R1 YES! Skip lookup routine 1031 *<<-------------------------------------------------------------------------->>* 1032 * This section of code is only executed once to find the GROM address * 1033 * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * 1034 * to indicate that the address is found and to be used as a mask for EQ & CND * 1035 *------------------------------------------------------------------------------* 1036 68E6 02E0 18 LWPI GPLWS R2,R3 else load GPL workspace 68E8 83E0 1037 68EA C120 34 MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack 68EC 0050 1038 68EE 0694 24 BL *R4 R6 1039 68F0 0204 20 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector 68F2 0011 1040 68F4 DB44 38 MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector 68F6 0402 1041 1042 ***les*** Note on above instruction: 1043 ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) 1044 ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) 1045 1046 68F8 1004 14 JMP DLINK2 R11 Jump around R12-R15 1047 68FA 0000 DATA 0 R12 contains >2000 flag when set 1048 68FC 0000 DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP 68FE 0000 6900 0000 1049 6902 DB60 54 DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address 6904 83E9 6906 0402 1050 6908 C160 34 MOV @GETSTK,R5 Take some time & set up GETSTK pointer 690A 166C 1051 690C D81D 46 MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector 690E 3811 1052 6910 05E0 34 INCT @DSRADR Adjust it to get past GPL FETCH instruction 6912 3810 1053 6914 0695 24 BL *R5 Restore the GROM address off the stack 1054 6916 02E0 18 LWPI DSRWS Reload DSRLNK workspace 6918 37C2 1055 691A 020C 20 LI R12,>2000 Set flag to signify DSRLNK address is set 691C 2000 1056 *<<-------------------------------------------------------------------------->>* 1057 691E 058E 14 DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte 1058 6920 D83E 48 MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK 6922 836D 1059 6924 C0E0 34 MOV @NAMLEN,R3 Save VDP address of Name Length 6926 8356 1060 6928 0223 22 AI R3,-8 Adjust it to point to PAB Flag byte 692A FFF8 1061 692C 0420 54 BLWP @GPLLNK Execute DSR LINK 692E 3784 1062 6930 03 DSRADR BYTE >03 High byte of GPL DSRLNK address 1063 6931 00 DSRAD1 BYTE >00 Lower byte of GPL DSRLNK address 1064 *----Error Check & Report to Caller's R0 and EQU bit------------------------- 1065 6932 D820 54 MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag 6934 37C9 6936 8C02 1066 6938 D803 38 MOVB R3,@VWA Set up MSB of VDP Address for Error Flag 693A 8C02 1067 693C 53CC 18 SZCB R12,R15 Clear EQ bit for Error Report 1068 693E D0E0 34 MOVB @VRD,R3 Get PAB Error Flag 6940 8800 1069 6942 0953 56 SRL R3,5 Adjust it to 0-7 error code 1070 6944 D743 30 MOVB R3,*R13 Put it into Caller's R0 (msb) 1071 6946 1603 14 JNE SETEQ If it's not zero, set EQ bit 1072 6948 2320 38 COC @GSTAT,R12 Else, test CND bit for Link Error (00) 694A 837C 1073 694C 1601 14 JNE DSREND No Error, Just return 1074 694E F3CC 18 SETEQ SOCB R12,R15 Error, so set Caller's EQ bit 1075 6950 0380 18 DSREND RTWP All Done - Return to Caller 1076 ;] 1077 ;[*== KSENTR -- Keyboard Scan (entry point) ============================= 1078 * 1079 6952 02E0 18 KSENTR LWPI GPLWS 6954 83E0 1080 6956 C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6958 3A62 1081 695A 06A0 32 BL @SCNKEY Console keyboard scan routine 695C 000E 1082 695E 02E0 18 LWPI UTILWS 6960 3A4C 1083 6962 C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 6964 83F6 1084 6966 0380 18 RTWP 1085 ;]* 1086 * _ _____ ___ __ ____ _ ___ __ _ 1087 * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ 1088 * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< 1089 * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ 1090 * 1091 ;[*== VDP utilities (entry point) ======================================= 1092 * 1093 ** VDP single byte write 1094 * 1095 6968 06A0 32 VSBWEN BL @WVDPWA Write out address 696A 388E 1096 696C D82D 54 MOVB @2(R13),@VDPWD Write data 696E 0002 6970 8C00 1097 6972 0380 18 RTWP Return to calling program 1098 * 1099 ** VDP multiple byte write 1100 * 1101 6974 06A0 32 VMBWEN BL @WVDPWA Write out address 6976 388E 1102 6978 D831 48 VWTMOR MOVB *R1+,@VDPWD Write a byte 697A 8C00 1103 697C 0602 14 DEC R2 Decrement byte count 1104 697E 16FC 14 JNE VWTMOR More to write? 1105 6980 0380 18 RTWP Return to calling Program 1106 * 1107 ** VDP single byte read 1108 * 1109 6982 06A0 32 VSBREN BL @WVDPRA Write out address 6984 3894 1110 6986 DB60 54 MOVB @VDPRD,@2(R13) Read data 6988 8800 698A 0002 1111 698C 0380 18 RTWP Return to calling program 1112 * 1113 ** VDP multiple byte read 1114 * 1115 698E 06A0 32 VMBREN BL @WVDPRA Write out address 6990 3894 1116 6992 DC60 48 VRDMOR MOVB @VDPRD,*R1+ Read a byte 6994 8800 1117 6996 0602 14 DEC R2 Decrement byte count 1118 6998 16FC 14 JNE VRDMOR More to read? 1119 699A 0380 18 RTWP Return to calling program 1120 * 1121 ** VDP write to register 1122 * 1123 699C C05D 26 VWTREN MOV *R13,R1 Get register number and value 1124 699E D82D 54 MOVB @1(R13),@VDPWA Write out value 69A0 0001 69A2 8C02 1125 69A4 0261 22 ORI R1,>8000 Set for register write 69A6 8000 1126 69A8 D801 38 MOVB R1,@VDPWA Write out register number 69AA 8C02 1127 69AC 0380 18 RTWP Return to calling program 1128 * 1129 ** Set up to write to VDP 1130 * 1131 69AE 0201 20 WVDPWA LI R1,>4000 69B0 4000 1132 69B2 1001 14 JMP WVDPAD 1133 * 1134 ** Set up to read VDP 1135 * 1136 69B4 04C1 14 WVDPRA CLR R1 1137 * 1138 ** Write VDP address 1139 * 1140 69B6 C09D 26 WVDPAD MOV *R13,R2 Get VDP address 1141 69B8 D820 54 MOVB @U_R2LB,@VDPWA Write low byte of address 69BA 3A51 69BC 8C02 1142 69BE E081 18 SOC R1,R2 Properly adjust VDP write bit 1143 69C0 D802 38 MOVB R2,@VDPWA Write high byte of address 69C2 8C02 1144 69C4 C06D 34 MOV @2(R13),R1 Get CPU RAM address 69C6 0002 1145 69C8 C0AD 34 MOV @4(R13),R2 Get byte count 69CA 0004 1146 69CC 045B 20 RT Return to calling routine 1147 1148 * 1149 ** VDP-to-VDP move. 1150 * 1151 69CE C05D 26 VMOVEN MOV *R13,R1 Get cnt to R1 1152 69D0 C0AD 34 MOV @2(R13),R2 Get vsrc to R2 69D2 0002 1153 69D4 C0ED 34 MOV @4(R13),R3 Get vdst to R3 69D6 0004 1154 69D8 0263 22 ORI R3,>4000 Prepare for VDP write 69DA 4000 1155 1156 ** copy cnt bytes from vsrc to vdst 1157 1158 69DC D820 54 VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address 69DE 3A51 69E0 8C02 1159 69E2 D802 38 MOVB R2,@VDPWA Write MSB of VDP read address 69E4 8C02 1160 69E6 0582 14 INC R2 Next VDP read address 1161 69E8 D020 34 MOVB @VDPRD,R0 Read VDP byte 69EA 8800 1162 69EC D820 54 MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address 69EE 3A53 69F0 8C02 1163 69F2 D803 38 MOVB R3,@VDPWA Write MSB of VDP write address 69F4 8C02 1164 69F6 0583 14 INC R3 Next VDP write address 1165 69F8 D800 38 MOVB R0,@VDPWD Write VDP byte 69FA 8C00 1166 69FC 0601 14 DEC R1 Decrement count 1167 69FE 16EE 14 JNE VMVMOR Repeat if not done 1168 6A00 0380 18 RTWP Return to calling program 1169 ;]* 1170 ;[*== fbForth Version Message =========================================== 1171 FBFMSG 1172 * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? 1173 * Also, printing the extra blanks overwrites the font-not-found error message. 1174 6A02 11 BYTE 17 1175 6A03 66 TEXT 'fbForth 2.0: ' 6A04 6246 6A06 6F72 6A08 7468 6A0A 2032 6A0C 2E30 6A0E 3A20 6A10 2020 6A12 2020 1176 ;] 1177 * __ ___ ___ ____ __ __ _ __ __ 1178 * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ 1179 * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< 1180 * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ 1181 * 1182 ;[*== Modifiable words in Resident Dictionary =========================== 1183 ;[*** (ABORT) *** 1184 6A14 73CC DATA x#VLST_N <--Last word in ROM 1185 6A16 8728 PABR_N DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT 6A18 4142 6A1A 4F52 6A1C 54A9 1186 1187 6A1E 8334 PABORT DATA DOCOL 1188 6A20 6ADE DATA ABORT,SEMIS 6A22 6358 1189 ;]* 1190 ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] 1191 6A24 38F6 DATA PABR_N 1192 6A26 C546 FRTH_N DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT 6A28 4F52 6A2A 54C8 1193 1194 6A2C 7218 FORTH DATA DOVOC 1195 6A2E A002 FORTHV DATA DPBASE+2 ; vocabulary link field 1196 6A30 81A0 FORTHP DATA >81A0 ; pseudo name field 1197 6A32 0000 FORTHL DATA 0 ; chronological link field 1198 ;]* 1199 ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] 1200 6A34 3906 DATA FRTH_N 1201 6A36 C941 ASMR_N DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT 6A38 5353 6A3A 454D 6A3C 424C 6A3E 45D2 1202 1203 6A40 7218 ASSM DATA DOVOC 1204 ; Initially points to last word in ASSEMBLER vocabulary in the kernel 1205 6A42 394A ASMV DATA SASM_N ; vocabulary link field 1206 6A44 81A0 DATA >81A0 ; pseudo name field 1207 6A46 3912 ASML DATA FORTHL ; chronological link field 1208 1209 * 1210 ;]* 1211 ;]* 1212 * ___ __ __ 1213 * / _ | ___ ___ ___ __ _ / / / /__ ____ 1214 * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ 1215 * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ 1216 * _ __ __ __ _ __ __ 1217 * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ 1218 * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< 1219 * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ 1220 * /___/ 1221 * 1222 *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary 1223 ;[*** NEXT, *** ( --- ) 1224 * 1st word in ASSEMBLER vocabulary 1225 * 1226 6A48 3910 DATA FORTHP <--points to PNF of FORTH 1227 6A4A 854E NXT__N DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT 6A4C 4558 6A4E 54AC 1228 1229 6A50 3932 NEXTC DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! 1230 6A52 0200 20 NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) 6A54 045F 1231 6A56 C068 34 MOV @$DP(U),R1 HERE to R1 6A58 0012 1232 6A5A CC40 34 MOV R0,*R1+ compile "B *NEXT" 1233 6A5C CA01 38 MOV R1,@$DP(U) update HERE 6A5E 0012 1234 6A60 CA28 54 MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary 6A62 0058 6A64 0056 1235 6A66 045F 20 B *NEXT back to inner interpreter 1236 1237 * : NEXT, ( --- ) 1238 * *NEXT B, ; 1239 ;]* 1240 ;[*** ;ASM *** ( --- ) 1241 * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by 1242 * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. 1243 * 1244 6A68 392A DATA NXT__N 1245 6A6A 84 SASM_N BYTE 4+TERMBT <--note different name field format 1246 6A6B 3B TEXT ';ASM' 6A6C 4153 6A6E 4D 1247 6A6F A0 BYTE ' '+TERMBT 1248 1249 6A70 3952 SASM DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! 1250 6A72 10EF 14 JMP NXT_P finish up in NEXT, 1251 1252 * : ;ASM ( --- ) 1253 * *NEXT B, ; 1254 ;]* 1255 1256 ;[*== Some Variables (KEYCNT etc.) ====================================== 1257 1258 6A74 FFFF KEYCNT DATA -1 Used in cursor flash logic 1259 6A76 0000 INTACT DATA 0 Non-zero during user's interrupt service routine 1260 * 1261 *++ variables used by some graphics primitives 1262 * 1263 6A78 0000 $DMODE DATA 0 ; actual location of variable contents 1264 6A7A FFFF $DCOL DATA -1 ; actual location of variable contents 1265 1266 *=========================================================== 1267 ;]* 1268 * ______ ___ _____ __ 1269 * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ 1270 * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) 1271 * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ 1272 * /_/ 1273 * 1274 ;[*== Trampoline Code =================================================== 1275 * 1276 * MYBANK must be at same location in all banks with the code that appears 1277 * in the following table. The EQUates for BANK0--BANK3 may also be in the 1278 * same places in each bank for convenience, but they only need to appear once. 1279 * 1280 * Bank Select MYBANK 1281 * ---- ------ ------ 1282 * 0 >6006 >C000 1283 * 1 >6004 >8000 1284 * 2 >6002 >4000 1285 * 3 >6000 >0000 1286 * 1287 * Bank0 code will look like this 1288 * 1289 * MYBANK DATA >C000 1290 * BANK0 EQU >C000 1291 * BANK1 EQU >8000 1292 * BANK2 EQU >4000 1293 * BANK3 EQU >0000 1294 * 1295 * Banks 1--3 will look the same, including labels, and the DATA 1296 * instruction at MYBANK's location will correspond to its bank. 1297 * 1298 * Before a bank is selected, the values above will be shifted right 13 1299 * bits and have >6000 added. 1300 * 1301 ;[*** BLBANK ************************************************************ 1302 * 1303 * General bank branching routine (32KB ROM, i.e., 4 banks) for a 1304 * branch that is expected to return (not high-level Forth) via RTBANK--- 1305 * --put in scratchpad or low RAM 1306 * --called by 1307 * BL @BLBANK 1308 * DATA dst_addr - >6000 + bank# in left 2 bits 1309 * 1310 6A7C 064E 14 BLBANK DECT R ; reserve space on return stack (R14) 1311 6A7E C33B 30 MOV *LINK+,CRU ; copy destination bank address to R12 1312 6A80 C78B 30 MOV LINK,*R ; push return address 1313 6A82 064E 14 DECT R ; reserve space on return stack 1314 6A84 C7A0 46 MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) 6A86 7FFE 1315 6A88 C2CC 18 MOV CRU,LINK ; copy destination bank address to R11 1316 6A8A 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6A8C 1FFF 1317 6A8E 022B 22 AI LINK,>6000 ; make it a real address 6A90 6000 1318 6A92 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1319 6A94 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6A96 6000 1320 6A98 04DC 26 CLR *CRU ; switch to destination bank 1321 6A9A 045B 20 B *LINK ; branch to destination address 1322 ;]* 1323 ;[*** RTBANK ************************************************************ 1324 * 1325 * General bank return routine (32KB ROM, i.e., 4 banks)--- 1326 * --put in scratchpad or low RAM 1327 * --called by 1328 * B @RTBANK 1329 * 1330 6A9C C33E 30 RTBANK MOV *R+,CRU ; pop return bank# from return stack to R12 1331 6A9E 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1332 6AA0 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6AA2 6000 1333 6AA4 C2FE 30 MOV *R+,LINK ; pop return address from return stack 1334 6AA6 04DC 26 CLR *CRU ; switch to destination bank 1335 6AA8 045B 20 B *LINK ; branch to return address 1336 ;]* 1337 ;[*** BLF2A ************************************************************* 1338 * 1339 * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 1340 * banks) that is expected to return to bank0 via RTNEXT. This will 1341 * only(?) be used for the ALC payload of Forth stubs in bank0--- 1342 * --put in scratchpad or low RAM 1343 * --called by 1344 * BL @BLF2A 1345 * DATA dst_addr - >6000 + bank# in left 2 bits 1346 * 1347 6AAA C2DB 26 BLF2A MOV *LINK,LINK ; copy destination bank address to R11 1348 6AAC C30B 18 MOV LINK,CRU ; copy it to R12 1349 6AAE 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6AB0 1FFF 1350 6AB2 022B 22 AI LINK,>6000 ; make it a real address 6AB4 6000 1351 6AB6 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1352 6AB8 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6ABA 6000 1353 6ABC 04DC 26 CLR *CRU ; switch to destination bank 1354 6ABE 045B 20 B *LINK ; branch to destination address 1355 ;]* 1356 ;[*** RTNEXT ************************************************************ 1357 * 1358 * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 1359 * banks)--- 1360 * --put in scratchpad or low RAM 1361 * --called by 1362 * B @RTNEXT 1363 * 1364 6AC0 C320 34 RTNEXT MOV @INTACT,CRU Are we in user's ISR? 6AC2 3956 1365 6AC4 1602 14 JNE RTNXT1 Don't enable interrupts if so. 1366 6AC6 0300 24 LIMI 2 6AC8 0002 1367 6ACA 04E0 34 RTNXT1 CLR @>6006 ; switch to bank 0 6ACC 6006 1368 6ACE 045F 20 B *NEXT ; branch to next CFA (in R15) 1369 ;]* 1370 ;[*** BLA2F ************************************************************* 1371 * 1372 * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 1373 * banks) that is expected to return to calling bank via RTA2F--- 1374 * --put in scratchpad or low RAM 1375 * --called by 1376 * BL @BLA2F 1377 * DATA <Forth cfa in bank0> 1378 * 1379 6AD0 064E 14 BLA2F DECT R ; reserve space on return stack 1380 6AD2 C2BB 30 MOV *LINK+,W ; move CFA of Forth routine to W 1381 6AD4 C78B 30 MOV LINK,*R ; push return address of calling bank 1382 6AD6 064E 14 DECT R ; reserve space on return stack 1383 6AD8 C7A0 46 MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) 6ADA 7FFE 1384 6ADC 064E 14 DECT R ; reserve spot on return stack 1385 6ADE C78D 30 MOV IP,*R ; move current IP to return stack 1386 6AE0 020D 20 LI IP,RTA2F ; move address of return procedure to IP 6AE2 39CC 1387 6AE4 04E0 34 CLR @>6006 ; switch to bank0 6AE6 6006 1388 6AE8 0460 28 B @DOEXEC ; Execute the Forth routine 6AEA 833C 1389 ;]* 1390 ;[*** RTA2F ************************************************************* 1391 * 1392 * ALC to high-level Forth bank "return" routine from Forth to calling 1393 * ALC (32KB ROM, i.e., 4 banks)--- 1394 * --put in scratchpad or low RAM 1395 * --called through B *NEXT at end of Forth word's execution in BLA2F 1396 * 1397 6AEC 39CE RTA2F DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) 1398 6AEE 39D0 DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) 1399 6AF0 C37E 30 MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) 1400 * Retrieve ALC return info and return to caller... 1401 * ...caller will execute B *NEXT when it finishes 1402 6AF2 0460 28 B @RTBANK ; branch to general bank return routine above 6AF4 397C 1403 ;]* 1404 ;]*********************************************************************** 1405 ;[*++ Bank-specific cell-/byte-reading code ++* 1406 ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) 1407 *++ Read cell contents of address in Bank bank# or RAM. 1408 *++ Register inputs: 1409 *++ R0: bank-switch address 1410 *++ R1: address in bank# to be read 1411 1412 6AF6 04D0 26 _BKAT CLR *R0 ; switch banks 1413 6AF8 C651 38 MOV *R1,*SP ; get cell contents of address to stack 1414 6AFA 0460 28 B @RTNEXT ; return to inner interpreter 6AFC 39A0 1415 ;]* 1416 ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) 1417 *++ Read byte contents of address in Bank bank# or RAM. 1418 *++ Register inputs: 1419 *++ R0: bank-switch address 1420 *++ R1: address in bank# to be read 1421 1422 6AFE 04D0 26 _BKCAT CLR *R0 ; switch banks 1423 6B00 04C2 14 CLR R2 ; clear R2 1424 6B02 D811 46 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 6B04 8305 1425 6B06 C642 30 MOV R2,*SP ; get byte contents of address to stack 1426 6B08 0460 28 B @RTNEXT ; return to inner interpreter 6B0A 39A0 1427 1428 ;]* 1429 1430 ;]* 1431 * _______ __ _________ ___ __ 1432 * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ 1433 * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / 1434 * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / 1435 * /___/ 1436 * 1437 ;[*** SAMS! *** ( --- ) 1438 * This calls the SAMS initialization in the startup code in bank 1. 1439 * 1440 * DATA SMSQ_N 1441 * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT 1442 * SAMSST DATA $+2 1443 * BL @BLF2A 1444 * DATA _SMSST->6000+BANK1 1445 1446 6B0C 06A0 32 _SMSST BL @SMSINI initialize SAMS card 6B0E 610C 1447 6B10 0460 28 B @RTNEXT back to inner interpreter 6B12 39A0 1448 ;]* 1449 ;[*== Required strings, tables, variables... ============================ 1450 * 1451 * 1452 * Default blocks filename 1453 * 1454 6B14 0C DEFNAM BYTE 12 1455 6B15 44 TEXT "DSK1.FBLOCKS " 6B16 534B 6B18 312E 6B1A 4642 6B1C 4C4F 6B1E 434B 6B20 5320 1456 * 1457 * Default colors for all VDP modes--- 1458 * MSB: Screen color (LSN); text FG (MSN), BG (LSN) 1459 * LSB: Color Table colors (FG/BG) 1460 * 1461 6B22 4F00 DEFCOL DATA >4F00 ; TEXT80 offset=0 1462 6B24 4F00 DATA >4F00 ; TEXT offset=2 1463 6B26 F4F4 DATA >F4F4 ; GRAPHICS offset=4 1464 6B28 11F4 DATA >11F4 ; MULTI offset=6 1465 6B2A FE10 DATA >FE10 ; GRAPHICS2 offset=8 1466 6B2C FEF4 DATA >FEF4 ; SPLIT offset=10 1467 6B2E FEF4 DATA >FEF4 ; SPLIT2 offset=12 1468 * 1469 * Default text mode 1470 * 1471 6B30 0001 DEFTXT DATA >0001 1472 * 1473 * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB 1474 * 1475 6B32 0000 FNTFLG DATA 0 ; font flag initially 0 1476 * 1477 * Speech variables needing initial value (more below LLVEND) 1478 * 1479 6B34 0000 SPCSVC DATA 0 1480 * 1481 * Sound Table #1 Workspace for sound variables. Only using R0..R4 1482 * 1483 SND1WS 1484 6B36 0000 SND1ST DATA 0 ; R0 (sound table status) 0=no table.. 1485 ; ..1=loading sound bytes..-1=counting 1486 6B38 8400 SND1DS DATA SOUND ; R1 (sound-table byte destination).. 1487 ; ..initialized to sound chip 1488 6B3A 0000 SND1AD DATA 0 ; R2 (sound table address) 1489 6B3C 0000 SND1CT DATA 0 ; R3 (# of sound bytes to load or.. 1490 ; ..sound count = seconds * 60) 1491 6B3E 3AE4 SND1SP DATA SNDST0 ; R4 (pointer to top of sound stack).. 1492 ; ..initialized to bottom of sound stack 1493 * 1494 * Sound Table #2 Workspace for sound variables. Only using R0..R3 1495 * 1496 SND2WS 1497 6B40 0000 SND2ST DATA 0 ; R0 (sound table status) 0=no table.. 1498 ; ..1=loading sound bytes..-1=counting 1499 6B42 8400 SND2DS DATA SOUND ; R1 (sound-table byte destination) init to sound chip 1500 ;]* 1501 * 1502 * This is the end of low-level support code that gets copied. 1503 * 1504 LLVEND 1505 1506 ;[*== Un-initialized Variables and workspaces... ========================= 1507 * Start of definitions of variables and workspaces that do not need to 1508 * take up space in ROM because they need no initial values. 1509 * 1510 * Sound Table #2 Workspace for sound variables..continued. 1511 * 1512 3A24 SND2AD EQU SND2WS+4 ; R2 (sound table address) 1513 3A26 SND2CT EQU SND2WS+6 ; R3 (# of sound bytes to load or.. 1514 * ; ..sound count = seconds * 60) 1515 3A28 SDMUTE EQU SND2WS+8 ; dummy destination for sound byte 1516 * 1517 * Branch Stack for ISR processing of Speech, 2 Sound Tables and return 1518 * 1519 3A2A BRSTK EQU SDMUTE+2 1520 * 1521 * Speech variables (more above LLVEND) 1522 * 1523 3A32 SSFLAG EQU BRSTK+8 1524 3A34 SPCNT EQU SSFLAG+2 1525 3A36 SPADR EQU SPCNT+2 1526 3A38 BANKSV EQU SPADR+2 1527 3A3A PADSV EQU BANKSV+2 1528 * 1529 * Panel window: height, width and screen position...used by PANEL and SCROLL 1530 * 1531 3A46 PANWIN EQU PADSV+12 panel height, width and screen start 1532 1533 *== Utility Workspace ================================================= 1534 *** General utility workspace registers 1535 3A4C UTILWS EQU PANWIN+6 1536 3A51 U_R2LB EQU UTILWS+5 1537 1538 3A6C LINBUF EQU UTILWS+32 1539 3ABC CURCHR EQU LINBUF+80 1540 1541 *++ variable used by the 40/80-column editor 1542 3ABE OLDCUR EQU CURCHR+2 1543 1544 *++ FILE I/O variables 1545 1546 3AC6 PBADR EQU OLDCUR+8 1547 3AC8 PBBF EQU PBADR+2 1548 3ACA PBVBF EQU PBBF+2 1549 1550 *++ Floating Point Math Library variables 1551 3ACC FPVARS EQU PBVBF+2 1552 1553 *++ SAMS flag 1554 3AE2 SAMSFL EQU FPVARS+22 1555 1556 *++ Bottom of Sound Stack 1557 *++ This location marks the top of the low-level support code. The Sound 1558 *++ Stack grows upward toward the Return Stack by moving the entire stack 1559 *++ up one cell to make room for the next new bottom entry. 1560 3AE4 SNDST0 EQU SAMSFL+2 1561 ;]* 1562 1563 AORG 1564 BANK 1 Here is the code it replaced: Spoiler * __ __ __ * / / ___ _ ______/ / ___ _ _____ / / * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / * /____/\___/__,__/ /____/\__/|___/\__/_/ * ____ __ * / __/_ _____ ___ ___ ____/ /_ * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ * /___/\_,_/ .__/ .__/\___/_/ \__/ * /_/ /_/ * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * fbForth--- * * * * Low-level support routines * * * * << Including Trampoline Code, tables & variables: 2606 bytes >> * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * LLVSPT ; <--This is the source copy location for the rest of this code. $BUFF EQU >2010 * 4 I/O buffers below ($LO = >3020) * Change '4' to number of buffers needed and for which there is room. $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers * _____ ____ __ __ ___________ * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| * ;[*** Interrupt Service ======================================================= * This routine is executed for every interrupt. It processes any pending * speech and souind. It then looks to see whether a user ISR is installed in * ISR. If so, it sets up NEXT for execution of the user ISR. This will work * only if the user has installed an ISR using the following steps in the fol- * lowing order: * * (1) Write an ISR with entry point, say MYISR. * (2) Determine code field address of MYISR with this high-level Forth: * ' MYISR CFA * <<< Maybe need a word to do #3 >>> * (3) Write CFA of MYISR into user variable ISR. * * Steps (2)-(3) in high-level Forth are shown below: * ' MYISR CFA * ISR ! * * <<< Perhaps last step above should be by a word that disables interrupts >>> * * The console ISR branches to the contents of >83C4 because it is non-zero, * with the address, INT1, of the fbForth ISR entry point below (also, the * contents of INTLNK). This means that the console ISR will branch to INT1 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first * process any pending speech and sound. * * If the user's ISR is properly installed, the code that processes the user * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed * from Forth's workspace (MAINWS), the code at INT2 will process the user's * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's * inner interpreter. *** ========================================================================== * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! INT1 EQU $LO+$-LLVSPT LI R0,BRSTK load address of top of Branch Address Stack * * Set up for pending speech * MOV @SPCSVC,*R0 save Speech service address onto Branch Stack JEQ SNDCH1 jump to sound-check if no speech INCT R0 increment Branch Stack * * Set up for pending sound table #1 (ST#1) * SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? JEQ SNDCH2 process speech and sound if needed LI R1,x#PLAYT1 load PLAYT1 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Set up for pending sound table #2 (ST#2) * SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? JEQ PRCSPS process speech and sound if needed LI R1,x#PLAYT2 load PLAYT2 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Process sound stack if both sound tables idle * PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? JNE PRSPS2 nope..skip sound stack processing LWPI SND1WS switch to ST#1 WS CI R4,SNDST0 anything on sound stack? JEQ PRSPS1 no..exit sound stack processing DECT R4 pop sound stack position MOV *R4,R2 get sound table address from sound stack INC R0 kick off sound processing of ST#1 (R0=1) PRSPS1 LWPI GPLWS switch back to GPL WS * * Check for any pending speech and sound * PRSPS2 CI R0,BRSTK any speech or sound to process? JEQ USRISR if not, jump to user ISR processing LI R1,BNKRST yup..load return address MOV R1,*R0 push return address onto Branch Stack * * Process pending speech and sound * MOV @x#MYBANK,@BANKSV save bank at interrupt CLR @>6002 switch to bank 2 for speech & sound services LI R7,BRSTK load top of Branch Stack MOV *R7+,R8 pop speech/sound ISR B *R8 service speech/sound * * Restore interrupted bank * BNKRST EQU $LO+$-LLVSPT return point for speech and sound ISRs MOV @BANKSV,R0 restore bank at interrupt SRL R0,13 get the bank# to correct position AI R0,>6000 make it a real bank-switch address CLR *R0 switch to the bank at interrupt * * Process User ISR if defined * USRISR MOV @$ISR+$UVAR,R0 User ISR installed? JEQ INTEX * * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) * is executed from Forth's WS (MAINWS = >8300), which it does at the end of * every CODE word, keyboard scan and one or two other places. * LI R1,INT2 Load entry point, INT2 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) * * The following 2 instructions are copies of the remainder of the console ROM's * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) * because we're not going back there! * INTEX LWPI >83C0 Change to console's ISR WS RTWP Return to caller of console ISR * * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored * before executing user's ISR. INT3 (cleanup routine below) will be inserted * in address list to get us back here for cleanup after user's ISR has finished. * User's ISR is executed at the end of this section just before INT3. * INT2 EQU $LO+$-LLVSPT LIMI 0 Disable interrupts MOVB @>83D4,R0 Get copy of VR01 SRL R0,8 ...to LSB ORI R0,>100 Set up for VR01 ANDI R0,>FFDF Clear VDP-interrupt-enable bit BLWP @VWTR Turn off VDP interrupt LI NEXT,$NEXT Restore NEXT SETO @INTACT Set Forth "pending interrupt" flag DECT R Set up return linkage by pushing MOV IP,*R ...IP (R13, next Forth CFA) to return stack and LI IP,INT3 ...setting IP to INT3 (below) for cleanup MOV @$ISR(U),W Do the user's Forth ISR by executing B @DOEXEC ...it through Forth's inner interpreter * * Clean up and re-enable interrupts. * INT3 EQU $LO+$-LLVSPT DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) MOV *R+,IP Start cleanup: pop IP from before call to user's ISR CLR @INTACT Clear Forth "pending interrupt" flag MOVB @>83D4,R0 Prepare to restore VR01 by... SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and AI R0,>100 ...VR # (01) to MSB MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status BLWP @VWTR Write VR01 LIMI 2 Re-enable interrupts B *NEXT Continue normal task ;]* ;[*** BKLINK from SYSTEM calls ========================================== * BKLINK EQU $LO+$-LLVSPT MOV @INTACT,R7 Are we in user's ISR? JNE BKLIN1 Don't enable interrupts if so. LIMI 2 BKLIN1 B *LINK ;]* * ____ __ _____ ____ * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ * /___/ * ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== * Entry point for low-level system support functions $SYS$ EQU $LO+$-LLVSPT LIMI 0 MOV @SYSTAB(R1),R0 B *R0 ;] ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== DATA BRW CODE = -20 write block to blocks file DATA BRW CODE = -18 read block from blocks file DATA BRW CODE = -16 create blocks file DATA BRW CODE = -14 use blocks file DATA GXY CODE = -12 GOTOXY DATA QKY CODE = -10 ?KEY DATA QTM CODE = -8 ?TERMINAL DATA CLF CODE = -6 CRLF DATA EMT CODE = -4 EMIT DATA KY CODE = -2 KEY SYSTAB EQU $LO+$-LLVSPT DATA SBW CODE = 0 VSBW DATA MBW CODE = 2 VMBW DATA SBR CODE = 4 VSBR DATA MBR CODE = 6 VMBR DATA WTR CODE = 8 VWTR DATA GPL CODE = 10 GPLLNK DATA XML CODE = 12 XMLLNK DATA DSR CODE = 14 DSRLNK DATA CLS$ CODE = 16 CLS DATA MVE CODE = 18 VMOVE DATA FILL$ CODE = 20 VFILL DATA AOX CODE = 22 VAND DATA AOX CODE = 24 VOR DATA AOX CODE = 26 VXOR ;]* ;[*== VDP single byte write. CODE = 0 ================= * SBW EQU $LO+$-LLVSPT MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 Character to write SWPB R1 Get in left byte BLWP @VSBW B @BKLINK ;]* ;[*== VDP multi byte write. CODE = 2 ================= * MBW EQU $LO+$-LLVSPT MOV *SP+,R2 Number of bytes to move MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 RAM address (source) BLWP @VMBW B @BKLINK ;]* ;[*== VDP single byte read. CODE = 4 ================= * SBR EQU $LO+$-LLVSPT MOV *SP,R0 VRAM address (source) BLWP @VSBR SRL R1,8 Character to right half for Forth MOV R1,*SP Stack it B @BKLINK ;]* ;[*== VDP multi byte read. CODE = 6 ================= * MBR EQU $LO+$-LLVSPT MOV *SP+,R2 Number of bytes to read MOV *SP+,R1 RAM address (destination) MOV *SP+,R0 VRAM address (source) BLWP @VMBR B @BKLINK ;]* ;[*== VDP-to-VDP move. CODE = 18 ================= * MVE EQU $LO+$-LLVSPT MOV *SP+,R0 Pop cnt to R0 MOV *SP+,R2 Pop vdst to R2 MOV *SP+,R1 Pop vsrc to R1 BLWP @VMOVE B @BKLINK ;]* ;[*== VDP register write. CODE = 8 ================= * WTR EQU $LO+$-LLVSPT MOV *SP+,R1 VDP register number MOV *SP+,R0 Data for register SWPB R1 Get register to left byte MOVB R1,R0 Place with data BLWP @VWTR B @BKLINK ;]* ;[*== GPL link utility. CODE = 10 ================= * GPL EQU $LO+$-LLVSPT CLR R0 MOVB R0,@KYSTAT LI R0,>0420 Construct the BLWP instruction LI R1,GPLLNK to the GPLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== XML link utility. CODE = 12 ================= * XML EQU $LO+$-LLVSPT LI R0,>0420 Construct the BLWP instruction LI R1,XMLLNK to the XMLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== DSR link utility. CODE = 14 ================= * DSR EQU $LO+$-LLVSPT LI R0,>0420 Construct the BLWP instruction LI R1,DSRLNK to the DSRLNK utility MOV *SP+,R2 This datum selects DSR or subroutine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== Screen clearing utility. CODE = 16 ================= * CLS$ EQU $LO+$-LLVSPT MOV @$SSTRT(U),R2 Beginning of screen in VRAM MOV @$SEND(U),R1 End of screen in VRAM S R2,R1 Screen size LI R0,>2000 Blank character MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== VDP fill routine. CODE = 20 ================= * FILL$ EQU $LO+$-LLVSPT MOV *SP+,R0 Fill character SWPB R0 to left byte MOV *SP+,R1 Fill count MOV *SP+,R2 Address to start VRAM fill MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK *======================================================================== FILL1 EQU $LO+$-LLVSPT R0=char, R1=cnt, R2=vaddr ORI R2,>4000 Set bit for VDP write SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time FLOOP MOVB R0,@VDPWD Write a byte DEC R1 JNE FLOOP Not done, fill another B *LINK ;]*====================================================================== * *==== VAND -- VDP byte AND routine. CODE = 22 ================= *==== VOR -- VDP byte OR routine. CODE = 24 ================= ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= * AOX EQU $LO+$-LLVSPT MOV *SP+,R2 VRAM address SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time MOVB @VDPRD,R3 Read byte MOV *SP+,R0 Get data to operate with SWPB R0 to left byte *** Now do requested operation ***************** CI R1,24 JEQ DOOR JGT DOXOR INV R3 These two instructions SZC R3,R0 perform an 'AND' JMP FINAOX DOOR SOC R3,R0 perform 'OR' JMP FINAOX DOXOR XOR R3,R0 perform 'XOR' FINAOX LI R1,1 MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== KEY routine CODE = -2 ================= * KY EQU $LO+$-LLVSPT MOV @$ALTI(U),R0 alternate input device? JEQ KEY0 jump to keyboard input if not * * R0 now points to PAB for alternate input device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to read one byte. * CLR R7 prepare to zero status byte MOVB R7,@KYSTAT zero status byte INC R0 point R0 to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB MOV R0,R1 Set up pointer... AI R1,8 ...to namelength byte of PAB MOV R1,@SUBPTR copy to DSR subroutine name-length pointer MOV R0,R3 save pointer (DSRLNK will trash it!) BLWP @DSRLNK get 1 byte from device DATA >8 MOV R3,R0 restore pointer DECT R0 point to one-byte VRAM buffer in front of PAB BLWP @VSBR read character SRL R1,8 move to LSB MOV R1,R0 copy to return register B @BKLINK return to caller * * Input is comining from the keyboard * KEY0 MOV @KEYCNT,R7 INC R7 JNE KEY1 MOV @CURPO$(U),R0 BLWP @VSBR Read character at cursor position... MOVB R1,@CURCHR ...and save it LI R1,>1E00 Place cursor character on screen BLWP @VSBW * KEY1 BLWP @KSCAN MOVB @KYSTAT,R0 COC @H2000,R0 check status JEQ KEY2 JMP if key was pressed * CI R7,100 No key pressed JNE KEY3 MOVB @CURCHR,R1 JMP KEY5 * KEY3 CI R7,200 JNE KEY4 CLR R7 LI R1,>1E00 Cursor char KEY5 MOV @CURPO$(U),R0 BLWP @VSBW KEY4 MOV R7,@KEYCNT MOV @INTACT,R7 Are we in user's ISR? JNE KEY6 Don't enable interrupts if so. LIMI 2 KEY6 DECT IP This will re-execute KEY B *NEXT KEY2 SETO @KEYCNT Key was pressed MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 B @BKLINK ;]* ;[*== EMIT routine CODE = -4 ================= * EMT EQU $LO+$-LLVSPT MOV R2,R1 copy char to R1 for VSBW MOV @$ALTO(U),R0 alternate output device? JEQ EMIT0 jump to video display output if not * * R0 now points to PAB for alternate output device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to write one byte. * CLR R7 ALTOUT active MOVB R7,@KYSTAT zero status byte DEC R0 point to one-byte VRAM buffer in front of PAB SWPB R1 char to MSB BLWP @VSBW write char to buffer INCT R0 point to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB AI R0,8 Set up pointer to namelength byte of PAB MOV R0,@SUBPTR copy to DSR subroutine name-length pointer BLWP @DSRLNK put 1 byte to device DATA >8 B @BKLINK return to caller * * Output is going to the video display * EMIT0 CI R1,7 Is it a bell? JNE NOTBEL CLR R2 MOVB R2,@KYSTAT BLWP @GPLLNK DATA >0036 Emit error tone JMP EMEXIT * NOTBEL CI R1,8 Is it a backspace? JNE NOTBS LI R1,>2000 MOV @CURPO$(U),R0 BLWP @VSBW JGT DECCUR JMP EMEXIT DECCUR DEC @CURPO$(U) JMP EMEXIT * NOTBS CI R1,>A Is it a line feed? JNE NOTLF MOV @$SEND(U),R7 S @$SWDTH(U),R7 C @CURPO$(U),R7 JHE SCRLL A @$SWDTH(U),@CURPO$(u) JMP EMEXIT SCRLL MOV LINK,R7 BL @SCROLL MOV R7,LINK JMP EMEXIT * *** SCROLLING ROUTINE * SCROLL EQU $LO+$-LLVSPT MOV @$SSTRT(U),R0 VRAM addr LI R1,LINBUF Line buffer MOV @$SWDTH(U),R2 Count A R2,R0 Start at line 2 SCROL1 BLWP @VMBR S R2,R0 One line back to write BLWP @VMBW A R2,R0 Two lines ahead for next read A R2,R0 C R0,@$SEND(U) End of screen? JL SCROL1 MOV R2,R1 Blank bottom row of screen LI R0,>2000 Blank S @$SEND(U),R2 NEG R2 Now contains address of start of last line MOV LINK,R6 BL @FILL1 Write the blanks B *R6 * NOTLF CI R1,>D Is it a carriage return? JNE NOTCR CLR R0 MOV @CURPO$(U),R1 MOV R1,R3 S @$SSTRT(U),R1 Adjusted for screen not at 0 MOV @$SWDTH(U),R2 DIV R2,R0 S R1,R3 MOV R3,@CURPO$(U) JMP EMEXIT * NOTCR SWPB R1 Assume it is a printable character MOV @CURPO$(U),R0 BLWP @VSBW MOV @$SEND(U),R2 DEC R2 C R0,R2 JNE NOTCR1 MOV @$SEND(U),R0 S @$SWDTH(U),R0 Was last char on screen. Scroll MOV R0,@CURPO$(U) JMP SCRLL NOTCR1 INC R0 No scroll necessary MOV R0,@CURPO$(U) * EMEXIT B @BKLINK ;]* ;[*== CRLF routine CODE = -6 ================= * CLF EQU $LO+$-LLVSPT MOV LINK,R5 LI R2,>000D BL @EMT EMT will alter INT mask via B @BKLINK LI R2,>000A LIMI 0 Previous call to EMT altered INT mask BL @EMT MOV R5,LINK B @BKLINK ;]* ;[*== ?TERMINAL routine CODE = -8 ================= * scan for <clear>, <break>, FCTN+4 press * QTM EQU $LO+$-LLVSPT MOV LINK,R5 save return BL @>0020 branch to console's test for <clear> STST R0 store status in R0 JNE QTM2 exit if not <clear> QTM1 BL @>0020 check for <clear> again JEQ QTM1 loop until not <clear> QTM2 MOV R5,LINK restore return ANDI R0,>2000 keep only EQU bit B @BKLINK return to caller ;]* ;[*== ?KEY routine CODE = -10 ================= * QKY EQU $LO+$-LLVSPT BLWP @KSCAN MOVB @KYCHAR,R0 SRL R0,8 CI R0,>00FF JNE QKEY1 CLR R0 QKEY1 B @BKLINK ;]* ;[*== GOTOXY routine CODE = -12 ================= * GXY EQU $LO+$-LLVSPT MPY @$SWDTH(U),R3 A R2,R4 Position within screen A @$SSTRT(U),R4 Add VRAM offset to screen top MOV R4,@CURPO$(U) B @BKLINK ;] * ___ __ __ ____ ______ * / _ )/ /__ ____/ /__ / _/_/_/ __ \ * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / * /____/_/\___/\__/_/\_\ /___/_/ \____/ * *== USE blocks file CODE = -14 ================= *== CREATE blocks file CODE = -16 ================= *== READ block from blocks file CODE = -18 ================= *== WRITE block to blocks file CODE = -20 ================= ;[*== Block File I/O Support ============================================ * * BPTOG utility to toggle one of 2 PABs for block file access * BPTOG EQU $LO+$-LLVSPT MOV @$BPOFF(U),R0 PAB offset to R0 LI R1,70 Toggle amount XOR R0,R1 New offset MOV R1,@$BPOFF(U) Update offset * **xxx** entry point to insure we have correct PAB address BPSET EQU $LO+$-LLVSPT MOV @$DKBUF(U),R0 Get DISK_BUF address A @$BPABS(U),R0 Get BPABS address * A @$BPOFF(U),R0 Add current offset MOV R0,@BFPAB Update current block file's PAB address RT * * CLOSE blocks file * BKCLOS EQU $LO+$-LLVSPT MOV @BFPAB,R0 LI R1,$FCLS Opcode=CLOSE BLWP @VSBW AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Close the file DATA 8 RT Deal with error in caller * * storage area * SVBRET EQU $LO+$-LLVSPT DATA 0 Storage for LINK coming into BRW BFPAB EQU $LO+$-LLVSPT DATA 0 Storage for current blocks file PAB address... * ...will have current PAB on entry * PAB header storage * PABHD EQU $LO+$-LLVSPT BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative * >03=OUTPUT mode + " * >01=UPDATE mode + " * BYTE 2,3: save contents of DISK_BUF here BYTE >80 Record length BYTE >80 Character count of transfer BSS 2 Record number * *** file I/O equates * $FOPN EQU >0000 $FCLS EQU >0100 $FRD EQU >0200 $FWRT EQU >0300 $FRST EQU >0400 $FINP EQU 5 $FOUT EQU 3 $FUPD EQU 1 * *** BRW -- entry point for block read/write routines * BRW EQU $LO+$-LLVSPT MOV LINK,@SVBRET Save LINK address MOV R1,R7 Save CODE {R1 to R7} SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) BL @BPSET Insure correct PAB address in BFPAB (it may have moved) CI R7,4 USE or CREATE? JLT BRW01 No BL @BPTOG Yes...toggle BPOFF & BFPAB MOV @BFPAB,R0 Load PAB address AI R0,9 Set to name length byte CLR R2 MOV *SP+,R1 Pop bfnaddr to R1 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 INC R2 Add 1 to # bytes to copy BLWP @VMBW Copy char count & pathname to PAB * *** set up PAB for OPEN * BRW01 LI R1,$FUPD Opcode=0,mode=update CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? JOP BRW02 No LI R1,$FINP Yes...change mode=input BRW02 MOV R1,@PABHD Put in PAB header MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header CLR R0 MOV R0,@PABHD+6 Set record#=0 MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 Copy first 8 bytes of PAB header BLWP @VMBW Do the copy * *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] * AI R0,9 Address of filename's char count in PAB MOV R0,@SUBPTR Point to-----^^^^ BLWP @DSRLNK Open/create the file DATA 8 JEQ BKERR CI R7,4 READ or WRITE? JLT BRW04 Yes JGT BRWDON No; =USE; we're done * *** write blank records to newly created blocks file [CODE = -16,CREATE] * MOV *SP+,R5 No; = CREATE; pop #blocks from stack SLA R5,3 Convert #blocks to #records MOV R5,R3 Save MOV R5,R4 Set up counter LI R0,$FWRT+$FUPD Set up for WRITE MOV R0,@PABHD Copy to PAB header BRLOOP S R4,R5 Calculate next record MOV R5,@PABHD+6 Copy to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Write one record of blanks DATA 8 JEQ BKERR MOV R3,R5 Get #blocks DEC R4 Count down 1 record JNE BRLOOP Write another record if not done JMP BRWDON We're done * *** prepare for read/write block * BRW04 MOV *SP+,R5 Pop block# to write MOV *SP+,R6 Pop bufaddr DEC R5 Block#-1 SLA R5,3 Convert to starting record# LI R4,8 Load counter for 8 records LI R0,$FWRT+$FUPD Set up for WRITE LI R3,VMBW WRITE vector CI R7,2 Are we writing the block? JEQ BRW05 Yup LI R0,$FRD+$FINP Nope...set up for READ LI R3,VMBR READ vector BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header * * READ/WRITE block routine [CODE = -18/-20] * RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy MOV @$DKBUF(U),R0 VRAM buffer address to R0 MOV R6,R1 RAM buffer to R1 LI R2,128 Bytes to copy CI R7,3 READ? JEQ BRW06 Yup BLWP *R3 Nope...copy record to VRAM * * temporarily use CRU register---it should be OK * BRW06 MOV @BFPAB,CRU PAB address AI CRU,9 Address of filename's char count MOV CRU,@SUBPTR Point to filename's char count BLWP @DSRLNK Read/write one record DATA 8 JEQ BKERR CI R7,2 WRITE? JEQ BRW07 Yup...next record MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) BLWP *R3 Nope...copy record to RAM buffer BRW07 INC R5 Next record in file AI R6,128 Next record to/from block RAM buffer DEC R4 Count down 1 record JNE RWLOOP Read/write another record if not done JMP BRWDON We're done * *** error handling * BKERR MOVB R0,R0 Device error? JEQ BKERR6 Yes, exit with disk error BKERR9 LI R6,9 No, exit with file error JMP BKCLN BKERR8 LI R6,8 Block# <=0! exit with range error JMP BKCLN BKERR6 LI R6,6 BKCLN BL @BKCLOS Close current blocks file; ignore error CI R7,4 USE or CREATE? JLT BKCLN1 No BL @BPTOG Yes...toggle BPOFF & BFPAB BKCLN1 MOV R6,R0 Pass error back to caller JMP BKEXIT BRWDON CLR R6 BL @BKCLOS Close current blocks file JNE BRWDN1 Error? LI R6,9 Yes...assume it was a file error BRWDN1 CI R7,4 (no error)...CREATE? JNE BRWDN2 No...we're done BL @BPTOG Yes...revert to correct blocks file BRWDN2 MOV R6,R0 Error to R0 BKEXIT MOV @SVBRET,LINK Restore LINK B @BKLINK ;] ;[* MSGTYP <<< Support for string typing in various banks >>> * * Called with: BL @MSGTYP * * R4 and R5 are the only registers that will be preserved * ..after a call to EMIT--- * * Input: R4 = Address of length byte of packed string * * We will pass the ASCII value of character to EMIT in R2 without * insuring it is 7 bits wide. * MSGTYP EQU $LO+$-LLVSPT DECT R Push return address MOV LINK,*R ...to Forth return stack CLR R5 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char SWPB R5 Put char count in low byte MTLOOP CLR R2 MOVB *R4+,R2 Copy next char to R2 for EMIT SWPB R2 Put char in low byte LIMI 0 We need to do this because we're calling EMIT directly BL @EMT Call EMIT directly INC @$OUT(U) Increment display line character count DEC R5 Decrement character count for this message JNE MTLOOP Are we done? MOV *R+,LINK Yes. Pop return address RT Return to caller ;] ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) R4$5 EQU $LO+$-LLVSPT MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4,*R5 RT ;] * __ __ _ __ _ __ __ * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ * ___ ___ ____ * / _ \___ / _/__ ___ __/ / /____ * / // / -_) _/ _ `/ // / / __(_-< * /____/\__/_/ \_,_/\_,_/_/\__/___/ ;[*== User Variable defaults ============================================ * UBASE0 EQU $LO+$-LLVSPT BSS 6 BASE OF USER VARIABLES DATA UBASE0 06 USER UCONS$ DATA SPBASE 08 USER S0 DATA RBASE 0A USER R0 { R0$ DATA $UVAR 0C USER U0 DATA SPBASE 0E USER TIB DATA 31 10 USER WIDTH DATA DPBASE 12 USER DP DATA $SYS$ 14 USER SYS$ DATA 0 16 USER CURPOS DATA INT1 18 USER INTLNK DATA 1 1A USER WARNING DATA 64 1C USER C/L$ { CL$ DATA $BUFF 1E USER FIRST$ DATA $LO 20 USER LIMIT$ DATA >0380 22 USER COLTAB Color Table address in VRAM DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM DATA >80 2A USER FPB pushes address of user screen font file PAB * ...that is this relative distance from DISK_BUF DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) DATA 40 30 USER SCRN_WIDTH DATA 0 32 USER SCRN_START DATA 960 34 USER SCRN_END DATA 0 36 USER ISR [Note: This used to be INT1] DATA 0 38 USER ALTIN DATA 0 3A USER ALTOUT DATA 1 3C USER VDPMDE permanent location for VDPMDE DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files * ...that is this relative distance from DISK_BUF DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB * ...always toggled between 0 and 70 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) * 0 = console font via GPLLNK DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. * 0 = Symmetric (default) * !0 = Floored $UVAR EQU $LO+$-LLVSPT BSS >80 USER VARIABLE AREA ;] ;[*== A Constant ==================================================== * H2000 EQU $LO+$-LLVSPT DATA >2000 ;]* * __ ____ _ ___ __ _ __ __ * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ * /___/ * ;[*== Utility Vectors =================================================== * * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK XMLLNK EQU $LO+$-LLVSPT DATA UTILWS,XMLENT ; Link to ROM routines KSCAN EQU $LO+$-LLVSPT DATA UTILWS,KSENTR ; Keyboard scan VSBW EQU $LO+$-LLVSPT DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) VMBW EQU $LO+$-LLVSPT DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) VSBR EQU $LO+$-LLVSPT DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) VMBR EQU $LO+$-LLVSPT DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) VMOVE EQU $LO+$-LLVSPT DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) VWTR EQU $LO+$-LLVSPT DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) ;]* ;[*== XMLENT -- Link to system XML utilities ============================ * XMLENT EQU $LO+$-LLVSPT MOV *R14+,@GPLWS+2 Get argument LWPI GPLWS Select GPL workspace MOV R11,@UTILWS+22 Save GPL return address MOV R1,R2 Make a copy of argument CI R1,>8000 Direct address in ALC? JH XML30 We have the address SRL R1,12 SLA R1,1 SLA R2,4 SRL R2,11 A @XMLTAB(R1),R2 MOV *R2,R2 XML30 BL *R2 LWPI UTILWS Get back to right WS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * ________ __ __ _ ____ __ __ ________ * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * This routine will work with any GROM library slot since it is * * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * * This GPLLNK does NOT require a module to be plugged into the * * GROM port so it will work with the Editor/Assembler, * * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * * It saves and restores the current GROM Address in case you want * * to return back to GROM for Basic or Extended Basic CALL LINKs * * or to return to the loading module. * * * * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * * DATA >34 * * * * NOTES: Do Not REF GPLLNK when using this routine in your code. * * * * 70 Bytes - including the GPLLNK Workspace * *-----------------------------------------------------------------------* * GPLWS (>83E0) is GPL workspace G_R4 EQU GPLWS+8 GPL workspace R4 G_R6 EQU GPLWS+12 GPL workspace R6 * SUBSTK (>8373) is GPL Subroutine stack pointer LDGADR EQU >60 Load & Execute GROM address entry point XTAB27 EQU >200E Low Mem XML table location 27 * ..Will contain XMLRTN at startup GETSTK EQU >166C GPLLNK EQU $LO+$-LLVSPT DATA GLNKWS R7 Set up BLWP Vectors DATA GLINK1 R8 * RTNADR EQU $LO+$-LLVSPT <---don't think we need this label DATA XMLRTN R9 address where GPL XML returns to us... * ...this address will already be in XTAB27,... * ...>200E, so don't really need it here} GXMLAD EQU $LO+$-LLVSPT DATA >176C R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) DATA >50 R11 Initialized to >50 where PUTSTK address resides GLNKWS EQU $LO+$-LLVSPT->18 GPLLNK's workspace of which only... BSS >08 R12-R15 ...registers R7 through R15 are used GLINK1 EQU $LO+$-LLVSPT MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS LWPI GPLWS Load GPL WS BL *R4 Save current GROM Address on stack MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return INCT @SUBSTK Adjust the stack pointer B @LDGADR Execute our GPL Routine XMLRTN EQU $LO+$-LLVSPT MOV @GETSTK,R4 Get GETSTK pointer BL *R4 Restore GROM address off the stack LWPI GLNKWS Load our WS RTWP All Done - Return to Caller ;] * ___ _______ __ _ ____ __ __ ________ * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * (Uses console GROM 0's DSRLNK routine) * * (Do not REF DSRLNK or GPLLNK when using these routines) * * (This DSRLNK will also handle Subprograms and CS1, CS2) * * * * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * * DATA 8 * * * * NOTES: Must be used with a GPLLNK routine * * Returns ERRORs the same as the E/A DSRLNK * * EQ bit set on return if error * * ERROR CODE in caller's MSB of Register 0 on return * * * * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * *-----------------------------------------------------------------------* PUTSTK EQU >50 Push GROM Address to stack pointer TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK NAMLEN EQU >8356 Device name length pointer in VDP PAB VWA EQU >8C02 VDP Write Address location VRD EQU >8800 VDP Read Data byte location G_R4LB EQU >83E9 GPL Workspace R4 Lower byte GSTAT EQU >837C GPL Status byte location DSRLNK EQU $LO+$-LLVSPT DATA DSRWS,DLINK1 Set BLWP Vectors DSRWS EQU $LO+$-LLVSPT Start of DSRLNK workspace DR3LB EQU DSRWS+7 lower byte of DSRLNK workspace R3 DLINK1 EQU $LO+$-LLVSPT MOV R12,R12 R0 Have we already looked up the LINK address? JNE DLINK3 R1 YES! Skip lookup routine *<<-------------------------------------------------------------------------->>* * This section of code is only executed once to find the GROM address * * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * * to indicate that the address is found and to be used as a mask for EQ & CND * *------------------------------------------------------------------------------* LWPI GPLWS R2,R3 else load GPL workspace MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack BL *R4 R6 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector ***les*** Note on above instruction: ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) JMP DLINK2 R11 Jump around R12-R15 DATA 0 R12 contains >2000 flag when set DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address MOV @GETSTK,R5 Take some time & set up GETSTK pointer MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector INCT @DSRADR Adjust it to get past GPL FETCH instruction BL *R5 Restore the GROM address off the stack LWPI DSRWS Reload DSRLNK workspace LI R12,>2000 Set flag to signify DSRLNK address is set *<<-------------------------------------------------------------------------->>* DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK MOV @NAMLEN,R3 Save VDP address of Name Length AI R3,-8 Adjust it to point to PAB Flag byte BLWP @GPLLNK Execute DSR LINK DSRADR EQU $LO+$-LLVSPT BYTE >03 High byte of GPL DSRLNK address DSRAD1 EQU $LO+$-LLVSPT BYTE >00 Lower byte of GPL DSRLNK address *----Error Check & Report to Caller's R0 and EQU bit------------------------- MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag MOVB R3,@VWA Set up MSB of VDP Address for Error Flag SZCB R12,R15 Clear EQ bit for Error Report MOVB @VRD,R3 Get PAB Error Flag SRL R3,5 Adjust it to 0-7 error code MOVB R3,*R13 Put it into Caller's R0 (msb) JNE SETEQ If it's not zero, set EQ bit COC @GSTAT,R12 Else, test CND bit for Link Error (00) JNE DSREND No Error, Just return SETEQ SOCB R12,R15 Error, so set Caller's EQ bit DSREND RTWP All Done - Return to Caller ;] ;[*== KSENTR -- Keyboard Scan (entry point) ============================= * KSENTR EQU $LO+$-LLVSPT LWPI GPLWS MOV R11,@UTILWS+22 Save GPL return address BL @SCNKEY Console keyboard scan routine LWPI UTILWS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * _ _____ ___ __ ____ _ ___ __ _ * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ * ;[*== VDP utilities (entry point) ======================================= * ** VDP single byte write * VSBWEN EQU $LO+$-LLVSPT BL @WVDPWA Write out address MOVB @2(R13),@VDPWD Write data RTWP Return to calling program * ** VDP multiple byte write * VMBWEN EQU $LO+$-LLVSPT BL @WVDPWA Write out address VWTMOR MOVB *R1+,@VDPWD Write a byte DEC R2 Decrement byte count JNE VWTMOR More to write? RTWP Return to calling Program * ** VDP single byte read * VSBREN EQU $LO+$-LLVSPT BL @WVDPRA Write out address MOVB @VDPRD,@2(R13) Read data RTWP Return to calling program * ** VDP multiple byte read * VMBREN EQU $LO+$-LLVSPT BL @WVDPRA Write out address VRDMOR MOVB @VDPRD,*R1+ Read a byte DEC R2 Decrement byte count JNE VRDMOR More to read? RTWP Return to calling program * ** VDP write to register * VWTREN EQU $LO+$-LLVSPT MOV *R13,R1 Get register number and value MOVB @1(R13),@VDPWA Write out value ORI R1,>8000 Set for register write MOVB R1,@VDPWA Write out register number RTWP Return to calling program * ** Set up to write to VDP * WVDPWA EQU $LO+$-LLVSPT LI R1,>4000 JMP WVDPAD * ** Set up to read VDP * WVDPRA EQU $LO+$-LLVSPT CLR R1 * ** Write VDP address * WVDPAD MOV *R13,R2 Get VDP address MOVB @U_R2LB,@VDPWA Write low byte of address SOC R1,R2 Properly adjust VDP write bit MOVB R2,@VDPWA Write high byte of address MOV @2(R13),R1 Get CPU RAM address MOV @4(R13),R2 Get byte count RT Return to calling routine * ** VDP-to-VDP move. * VMOVEN EQU $LO+$-LLVSPT MOV *R13,R1 Get cnt to R1 MOV @2(R13),R2 Get vsrc to R2 MOV @4(R13),R3 Get vdst to R3 ORI R3,>4000 Prepare for VDP write ** copy cnt bytes from vsrc to vdst VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address MOVB R2,@VDPWA Write MSB of VDP read address INC R2 Next VDP read address MOVB @VDPRD,R0 Read VDP byte MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address MOVB R3,@VDPWA Write MSB of VDP write address INC R3 Next VDP write address MOVB R0,@VDPWD Write VDP byte DEC R1 Decrement count JNE VMVMOR Repeat if not done RTWP Return to calling program ;]* ;[*== fbForth Version Message =========================================== FBFMSG EQU $LO+$-LLVSPT * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? * Also, printing the extra blanks overwrites the font-not-found error message. BYTE 17 TEXT 'fbForth 2.0: ' ;] * __ ___ ___ ____ __ __ _ __ __ * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ * ;[*== Modifiable words in Resident Dictionary =========================== ;[*** (ABORT) *** DATA x#VLST_N <--Last word in ROM PABR_N EQU $LO+$-LLVSPT DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT PABORT EQU $LO+$-LLVSPT DATA DOCOL DATA ABORT,SEMIS ;]* ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] DATA PABR_N FRTH_N EQU $LO+$-LLVSPT DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT FORTHV EQU $LO+$-LLVSPT+2 ; vocabulary link field FORTHP EQU $LO+$-LLVSPT+4 ; pseudo name field FORTHL EQU $LO+$-LLVSPT+6 ; chronological link field FORTH EQU $LO+$-LLVSPT DATA DOVOC DATA DPBASE+2,>81A0,0 ; (may need to modify) ;]* ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] DATA FRTH_N ASMR_N EQU $LO+$-LLVSPT DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT ASMV EQU $LO+$-LLVSPT+2 ; vocabulary link field ASML EQU $LO+$-LLVSPT+6 ; chronological link field ASSM EQU $LO+$-LLVSPT DATA DOVOC DATA SASM_N,>81A0,FORTHL ; <--ASMV initially points to last word in * ; ...ASSEMBLER vocabulary in the kernel ;]* ;]* * ___ __ __ * / _ | ___ ___ ___ __ _ / / / /__ ____ * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ * _ __ __ __ _ __ __ * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ * /___/ * *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary ;[*** NEXT, *** ( --- ) * 1st word in ASSEMBLER vocabulary * DATA FORTHP <--points to PNF of FORTH NXT__N EQU $LO+$-LLVSPT DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT NEXTC EQU $LO+$-LLVSPT DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) MOV @$DP(U),R1 HERE to R1 MOV R0,*R1+ compile "B *NEXT" MOV R1,@$DP(U) update HERE MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary B *NEXT back to inner interpreter * : NEXT, ( --- ) * *NEXT B, ; ;]* ;[*** ;ASM *** ( --- ) * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. * DATA NXT__N SASM_N EQU $LO+$-LLVSPT BYTE 4+TERMBT <--note different name field format TEXT ';ASM' BYTE ' '+TERMBT SASM EQU $LO+$-LLVSPT DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! JMP NXT_P finish up in NEXT, * : ;ASM ( --- ) * *NEXT B, ; ;]* ;[*== Some Variables (KEYCNT etc.) ====================================== KEYCNT EQU $LO+$-LLVSPT DATA -1 Used in cursor flash logic INTACT EQU $LO+$-LLVSPT DATA 0 Non-zero during user's interrupt service routine * *++ variables used by some graphics primitives * $DMODE EQU $LO+$-LLVSPT DATA 0 ; actual location of variable contents $DCOL EQU $LO+$-LLVSPT DATA -1 ; actual location of variable contents *=========================================================== ;]* * ______ ___ _____ __ * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ * /_/ * ;[*== Trampoline Code =================================================== * * MYBANK must be at same location in all banks with the code that appears * in the following table. The EQUates for BANK0--BANK3 may also be in the * same places in each bank for convenience, but they only need to appear once. * * Bank Select MYBANK * ---- ------ ------ * 0 >6006 >C000 * 1 >6004 >8000 * 2 >6002 >4000 * 3 >6000 >0000 * * Bank0 code will look like this * * MYBANK DATA >C000 * BANK0 EQU >C000 * BANK1 EQU >8000 * BANK2 EQU >4000 * BANK3 EQU >0000 * * Banks 1--3 will look the same, including labels, and the DATA * instruction at MYBANK's location will correspond to its bank. * * Before a bank is selected, the values above will be shifted right 13 * bits and have >6000 added. * ;[*** BLBANK ************************************************************ * * General bank branching routine (32KB ROM, i.e., 4 banks) for a * branch that is expected to return (not high-level Forth) via RTBANK--- * --put in scratchpad or low RAM * --called by * BL @BLBANK * DATA dst_addr - >6000 + bank# in left 2 bits * BLBANK EQU $LO+$-LLVSPT DECT R ; reserve space on return stack (R14) MOV *LINK+,CRU ; copy destination bank address to R12 MOV LINK,*R ; push return address DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) MOV CRU,LINK ; copy destination bank address to R11 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTBANK ************************************************************ * * General bank return routine (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called by * B @RTBANK * RTBANK EQU $LO+$-LLVSPT MOV *R+,CRU ; pop return bank# from return stack to R12 SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address MOV *R+,LINK ; pop return address from return stack CLR *CRU ; switch to destination bank B *LINK ; branch to return address ;]* ;[*** BLF2A ************************************************************* * * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to bank0 via RTNEXT. This will * only(?) be used for the ALC payload of Forth stubs in bank0--- * --put in scratchpad or low RAM * --called by * BL @BLF2A * DATA dst_addr - >6000 + bank# in left 2 bits * BLF2A EQU $LO+$-LLVSPT MOV *LINK,LINK ; copy destination bank address to R11 MOV LINK,CRU ; copy it to R12 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTNEXT ************************************************************ * * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 * banks)--- * --put in scratchpad or low RAM * --called by * B @RTNEXT * RTNEXT EQU $LO+$-LLVSPT MOV @INTACT,CRU Are we in user's ISR? JNE RTNXT1 Don't enable interrupts if so. LIMI 2 RTNXT1 CLR @>6006 ; switch to bank 0 B *NEXT ; branch to next CFA (in R15) ;]* ;[*** BLA2F ************************************************************* * * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to calling bank via RTA2F--- * --put in scratchpad or low RAM * --called by * BL @BLA2F * DATA <Forth cfa in bank0> * BLA2F EQU $LO+$-LLVSPT DECT R ; reserve space on return stack MOV *LINK+,W ; move CFA of Forth routine to W MOV LINK,*R ; push return address of calling bank DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) DECT R ; reserve spot on return stack MOV IP,*R ; move current IP to return stack LI IP,RTA2F ; move address of return procedure to IP CLR @>6006 ; switch to bank0 B @DOEXEC ; Execute the Forth routine ;]* ;[*** RTA2F ************************************************************* * * ALC to high-level Forth bank "return" routine from Forth to calling * ALC (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called through B *NEXT at end of Forth word's execution in BLA2F * RTA2F EQU $LO+$-LLVSPT DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) * Retrieve ALC return info and return to caller... * ...caller will execute B *NEXT when it finishes B @RTBANK ; branch to general bank return routine above ;]* ;]*********************************************************************** ;[*++ Bank-specific cell-/byte-reading code ++* ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) *++ Read cell contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKAT EQU $LO+$-LLVSPT CLR *R0 ; switch banks MOV *R1,*SP ; get cell contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) *++ Read byte contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKCAT EQU $LO+$-LLVSPT CLR *R0 ; switch banks CLR R2 ; clear R2 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 MOV R2,*SP ; get byte contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;]* * _______ __ _________ ___ __ * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / * /___/ * ;[*** SAMS! *** ( --- ) * This calls the SAMS initialization in the startup code in bank 1. * * DATA SMSQ_N * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT * SAMSST DATA $+2 * BL @BLF2A * DATA _SMSST->6000+BANK1 _SMSST BL @SMSINI initialize SAMS card B @RTNEXT back to inner interpreter ;]* ;[*== Required strings, tables, variables... ============================ * * * Default blocks filename * DEFNAM EQU $LO+$-LLVSPT BYTE 12 TEXT "DSK1.FBLOCKS " * * Default colors for all VDP modes--- * MSB: Screen color (LSN); text FG (MSN), BG (LSN) * LSB: Color Table colors (FG/BG) * DEFCOL EQU $LO+$-LLVSPT DATA >4F00 ; TEXT80 offset=0 DATA >4F00 ; TEXT offset=2 DATA >F4F4 ; GRAPHICS offset=4 DATA >11F4 ; MULTI offset=6 DATA >FE10 ; GRAPHICS2 offset=8 DATA >FEF4 ; SPLIT offset=10 DATA >FEF4 ; SPLIT2 offset=12 * * Default text mode * DEFTXT EQU $LO+$-LLVSPT DATA >0001 * * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB * FNTFLG EQU $LO+$-LLVSPT DATA 0 ; font flag initially 0 * * Speech variables needing initial value (more below LLVEND) * SPCSVC EQU $LO+$-LLVSPT DATA 0 * * Sound Table #1 Workspace for sound variables. Only using R0..R4 * SND1WS EQU $LO+$-LLVSPT SND1ST EQU SND1WS R0 (sound table status) 0=no table; 1=loading sound... DATA 0 ...bytes; -1=counting SND1DS EQU SND1WS+2 R1 (sound-table byte destination)... DATA SOUND ...initialized to sound chip SND1AD EQU SND1WS+4 R2 (sound table address) DATA 0 SND1CT EQU SND1WS+6 R3 (# of sound bytes to load or... DATA 0 ...sound count = seconds * 60) SND1SP EQU SND1WS+8 R4 (pointer to top of sound stack) DATA SNDST0 initialized to bottom of sound stack * * Sound Table #2 Workspace for sound variables. Only using R0..R3 * SND2WS EQU $LO+$-LLVSPT SND2ST EQU SND2WS R0 (sound table status) 0=no table ; 1=loading sound... DATA 0 ...bytes; -1=counting SND2DS EQU SND2WS+2 R1 (sound-table byte destination)... DATA SOUND ...initialized to sound chip ;]* * * This is the end of low-level support code that gets copied. * LLVEND ;[*== Un-initialized Variables and workspaces... ========================= * Start of definitions of variables and workspaces that do not need to * take up space in ROM because they need no initial values. * * Sound Table #2 Workspace for sound variables..continued. * SND2AD EQU SND2WS+4 R2 (sound table address) SND2CT EQU SND2WS+6 R3 (# of sound bytes to load or... * ...sound count = seconds * 60) SDMUTE EQU SND2WS+8 dummy destination for sound byte * * Branch Stack for ISR processing of Speech, 2 Sound Tables and return * BRSTK EQU SDMUTE+2 * * Speech variables (more above LLVEND) * SSFLAG EQU BRSTK+8 SPCNT EQU SSFLAG+2 SPADR EQU SPCNT+2 BANKSV EQU SPADR+2 PADSV EQU BANKSV+2 * * Panel window: height, width and screen position...used by PANEL and SCROLL * PANWIN EQU PADSV+12 panel height, width and screen start *== Utility Workspace ================================================= *** General utility workspace registers UTILWS EQU PANWIN+6 U_R2LB EQU UTILWS+5 LINBUF EQU UTILWS+32 CURCHR EQU LINBUF+80 *++ variable used by the 40/80-column editor OLDCUR EQU CURCHR+2 *++ FILE I/O variables PBADR EQU OLDCUR+8 PBBF EQU PBADR+2 PBVBF EQU PBBF+2 *++ Floating Point Math Library variables FPVARS EQU PBVBF+2 *++ SAMS flag SAMSFL EQU FPVARS+22 *++ Bottom of Sound Stack *++ This location marks the top of the low-level support code. The Sound *++ Stack grows upward toward the Return Stack by moving the entire stack *++ up one cell to make room for the next new bottom entry. SNDST0 EQU SAMSFL+2 ;]* and its listing: Spoiler 0105 COPY "Bank1\fbForth101_LowLevelSupport.a99" **** **** > fbForth101_LowLevelSupport.a99 0001 * __ __ __ 0002 * / / ___ _ ______/ / ___ _ _____ / / 0003 * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / 0004 * /____/\___/__,__/ /____/\__/|___/\__/_/ 0005 * ____ __ 0006 * / __/_ _____ ___ ___ ____/ /_ 0007 * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ 0008 * /___/\_,_/ .__/ .__/\___/_/ \__/ 0009 * /_/ /_/ 0010 * 0011 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0012 * * 0013 * fbForth--- * 0014 * * 0015 * Low-level support routines * 0016 * * 0017 * << Including Trampoline Code, tables & variables: 2606 bytes >> * 0018 * * 0019 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0020 0021 LLVSPT ; <--This is the source copy location for the rest of this code. 0022 0023 2010 $BUFF EQU >2010 0024 0025 * 4 I/O buffers below ($LO = >3020) 0026 * Change '4' to number of buffers needed and for which there is room. 0027 0028 3020 $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers 0029 * _____ ____ __ __ ___________ 0030 * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ 0031 * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ 0032 * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| 0033 * 0034 ;[*** Interrupt Service ======================================================= 0035 * This routine is executed for every interrupt. It processes any pending 0036 * speech and souind. It then looks to see whether a user ISR is installed in 0037 * ISR. If so, it sets up NEXT for execution of the user ISR. This will work 0038 * only if the user has installed an ISR using the following steps in the fol- 0039 * lowing order: 0040 * 0041 * (1) Write an ISR with entry point, say MYISR. 0042 * (2) Determine code field address of MYISR with this high-level Forth: 0043 * ' MYISR CFA 0044 * <<< Maybe need a word to do #3 >>> 0045 * (3) Write CFA of MYISR into user variable ISR. 0046 * 0047 * Steps (2)-(3) in high-level Forth are shown below: 0048 * ' MYISR CFA 0049 * ISR ! 0050 * 0051 * <<< Perhaps last step above should be by a word that disables interrupts >>> 0052 * 0053 * The console ISR branches to the contents of >83C4 because it is non-zero, 0054 * with the address, INT1, of the fbForth ISR entry point below (also, the 0055 * contents of INTLNK). This means that the console ISR will branch to INT1 0056 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first 0057 * process any pending speech and sound. 0058 * 0059 * If the user's ISR is properly installed, the code that processes the user 0060 * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed 0061 * from Forth's workspace (MAINWS), the code at INT2 will process the user's 0062 * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's 0063 * inner interpreter. 0064 *** ========================================================================== 0065 0066 * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! 0067 0068 3020 INT1 EQU $LO+$-LLVSPT 0069 6140 0200 20 LI R0,BRSTK load address of top of Branch Address Stack 6142 3A2A 0070 * 0071 * Set up for pending speech 0072 * 0073 6144 C420 46 MOV @SPCSVC,*R0 save Speech service address onto Branch Stack 6146 3A14 0074 6148 1301 14 JEQ SNDCH1 jump to sound-check if no speech 0075 614A 05C0 14 INCT R0 increment Branch Stack 0076 * 0077 * Set up for pending sound table #1 (ST#1) 0078 * 0079 614C C0A0 34 SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? 614E 3A16 0080 6150 1303 14 JEQ SNDCH2 process speech and sound if needed 0081 6152 0201 20 LI R1,x#PLAYT1 load PLAYT1 address and... 6154 7C68 0082 6156 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0083 * 0084 * Set up for pending sound table #2 (ST#2) 0085 * 0086 6158 C0E0 34 SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? 615A 3A20 0087 615C 1303 14 JEQ PRCSPS process speech and sound if needed 0088 615E 0201 20 LI R1,x#PLAYT2 load PLAYT2 address and... 6160 7C6E 0089 6162 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0090 * 0091 * Process sound stack if both sound tables idle 0092 * 0093 6164 E0C2 18 PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? 0094 6166 160A 14 JNE PRSPS2 nope..skip sound stack processing 0095 6168 02E0 18 LWPI SND1WS switch to ST#1 WS 616A 3A16 0096 616C 0284 22 CI R4,SNDST0 anything on sound stack? 616E 3AE4 0097 6170 1303 14 JEQ PRSPS1 no..exit sound stack processing 0098 6172 0644 14 DECT R4 pop sound stack position 0099 6174 C094 26 MOV *R4,R2 get sound table address from sound stack 0100 6176 0580 14 INC R0 kick off sound processing of ST#1 (R0=1) 0101 6178 02E0 18 PRSPS1 LWPI GPLWS switch back to GPL WS 617A 83E0 0102 * 0103 * Check for any pending speech and sound 0104 * 0105 617C 0280 22 PRSPS2 CI R0,BRSTK any speech or sound to process? 617E 3A2A 0106 6180 1312 14 JEQ USRISR if not, jump to user ISR processing 0107 6182 0201 20 LI R1,BNKRST yup..load return address 6184 307A 0108 6186 C401 30 MOV R1,*R0 push return address onto Branch Stack 0109 * 0110 * Process pending speech and sound 0111 * 0112 6188 C820 54 MOV @x#MYBANK,@BANKSV save bank at interrupt 618A 7FFE 618C 3A38 0113 618E 04E0 34 CLR @>6002 switch to bank 2 for speech & sound services 6190 6002 0114 6192 0207 20 LI R7,BRSTK load top of Branch Stack 6194 3A2A 0115 6196 C237 30 MOV *R7+,R8 pop speech/sound ISR 0116 6198 0458 20 B *R8 service speech/sound 0117 * 0118 * Restore interrupted bank 0119 * 0120 307A BNKRST EQU $LO+$-LLVSPT return point for speech and sound ISRs 0121 619A C020 34 MOV @BANKSV,R0 restore bank at interrupt 619C 3A38 0122 619E 09D0 56 SRL R0,13 get the bank# to correct position 0123 61A0 0220 22 AI R0,>6000 make it a real bank-switch address 61A2 6000 0124 61A4 04D0 26 CLR *R0 switch to the bank at interrupt 0125 * 0126 * Process User ISR if defined 0127 * 0128 61A6 C020 34 USRISR MOV @$ISR+$UVAR,R0 User ISR installed? 61A8 36EA 0129 61AA 1304 14 JEQ INTEX 0130 * 0131 * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) 0132 * is executed from Forth's WS (MAINWS = >8300), which it does at the end of 0133 * every CODE word, keyboard scan and one or two other places. 0134 * 0135 61AC 0201 20 LI R1,INT2 Load entry point, INT2 61AE 309A 0136 61B0 C801 38 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) 61B2 831E 0137 * 0138 * The following 2 instructions are copies of the remainder of the console ROM's 0139 * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) 0140 * because we're not going back there! 0141 * 0142 61B4 02E0 18 INTEX LWPI >83C0 Change to console's ISR WS 61B6 83C0 0143 61B8 0380 18 RTWP Return to caller of console ISR 0144 * 0145 * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored 0146 * before executing user's ISR. INT3 (cleanup routine below) will be inserted 0147 * in address list to get us back here for cleanup after user's ISR has finished. 0148 * User's ISR is executed at the end of this section just before INT3. 0149 * 0150 309A INT2 EQU $LO+$-LLVSPT 0151 61BA 0300 24 LIMI 0 Disable interrupts 61BC 0000 0152 61BE D020 34 MOVB @>83D4,R0 Get copy of VR01 61C0 83D4 0153 61C2 0980 56 SRL R0,8 ...to LSB 0154 61C4 0260 22 ORI R0,>100 Set up for VR01 61C6 0100 0155 61C8 0240 22 ANDI R0,>FFDF Clear VDP-interrupt-enable bit 61CA FFDF 0156 61CC 0420 54 BLWP @VWTR Turn off VDP interrupt 61CE 3752 0157 61D0 020F 20 LI NEXT,$NEXT Restore NEXT 61D2 833A 0158 61D4 0720 34 SETO @INTACT Set Forth "pending interrupt" flag 61D6 3956 0159 61D8 064E 14 DECT R Set up return linkage by pushing 0160 61DA C78D 30 MOV IP,*R ...IP (R13, next Forth CFA) to return stack and 0161 61DC 020D 20 LI IP,INT3 ...setting IP to INT3 (below) for cleanup 61DE 30C8 0162 61E0 C2A8 34 MOV @$ISR(U),W Do the user's Forth ISR by executing 61E2 0036 0163 61E4 0460 28 B @DOEXEC ...it through Forth's inner interpreter 61E6 833C 0164 * 0165 * Clean up and re-enable interrupts. 0166 * 0167 30C8 INT3 EQU $LO+$-LLVSPT 0168 61E8 30CA DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) 0169 61EA 30CC DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) 0170 61EC C37E 30 MOV *R+,IP Start cleanup: pop IP from before call to user's ISR 0171 61EE 04E0 34 CLR @INTACT Clear Forth "pending interrupt" flag 61F0 3956 0172 61F2 D020 34 MOVB @>83D4,R0 Prepare to restore VR01 by... 61F4 83D4 0173 61F6 0980 56 SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and 0174 61F8 0220 22 AI R0,>100 ...VR # (01) to MSB 61FA 0100 0175 61FC D060 34 MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status 61FE 8802 0176 6200 0420 54 BLWP @VWTR Write VR01 6202 3752 0177 6204 0300 24 LIMI 2 Re-enable interrupts 6206 0002 0178 6208 045F 20 B *NEXT Continue normal task 0179 ;]* 0180 ;[*** BKLINK from SYSTEM calls ========================================== 0181 * 0182 30EA BKLINK EQU $LO+$-LLVSPT 0183 620A C1E0 34 MOV @INTACT,R7 Are we in user's ISR? 620C 3956 0184 620E 1602 14 JNE BKLIN1 Don't enable interrupts if so. 0185 6210 0300 24 LIMI 2 6212 0002 0186 6214 045B 20 BKLIN1 B *LINK 0187 ;]* 0188 * ____ __ _____ ____ 0189 * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ 0190 * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< 0191 * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ 0192 * /___/ 0193 * 0194 ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== 0195 0196 * Entry point for low-level system support functions 0197 0198 30F6 $SYS$ EQU $LO+$-LLVSPT 0199 6216 0300 24 LIMI 0 6218 0000 0200 621A C021 34 MOV @SYSTAB(R1),R0 621C 3114 0201 621E 0450 20 B *R0 0202 ;] 0203 ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== 0204 0205 6220 34C6 DATA BRW CODE = -20 write block to blocks file 0206 6222 34C6 DATA BRW CODE = -18 read block from blocks file 0207 6224 34C6 DATA BRW CODE = -16 create blocks file 0208 6226 34C6 DATA BRW CODE = -14 use blocks file 0209 6228 346C DATA GXY CODE = -12 GOTOXY 0210 622A 3456 DATA QKY CODE = -10 ?KEY 0211 622C 343C DATA QTM CODE = -8 ?TERMINAL 0212 622E 3420 DATA CLF CODE = -6 CRLF 0213 6230 3312 DATA EMT CODE = -4 EMIT 0214 6232 3260 DATA KY CODE = -2 KEY 0215 3114 SYSTAB EQU $LO+$-LLVSPT 0216 6234 3130 DATA SBW CODE = 0 VSBW 0217 6236 313E DATA MBW CODE = 2 VMBW 0218 6238 314C DATA SBR CODE = 4 VSBR 0219 623A 315A DATA MBR CODE = 6 VMBR 0220 623C 3176 DATA WTR CODE = 8 VWTR 0221 623E 3186 DATA GPL CODE = 10 GPLLNK 0222 6240 31A6 DATA XML CODE = 12 XMLLNK 0223 6242 31C0 DATA DSR CODE = 14 DSRLNK 0224 6244 31DA DATA CLS$ CODE = 16 CLS 0225 6246 3168 DATA MVE CODE = 18 VMOVE 0226 6248 31F4 DATA FILL$ CODE = 20 VFILL 0227 624A 3224 DATA AOX CODE = 22 VAND 0228 624C 3224 DATA AOX CODE = 24 VOR 0229 624E 3224 DATA AOX CODE = 26 VXOR 0230 ;]* 0231 ;[*== VDP single byte write. CODE = 0 ================= 0232 * 0233 3130 SBW EQU $LO+$-LLVSPT 0234 6250 C039 30 MOV *SP+,R0 VRAM address (destination) 0235 6252 C079 30 MOV *SP+,R1 Character to write 0236 6254 06C1 14 SWPB R1 Get in left byte 0237 6256 0420 54 BLWP @VSBW 6258 373E 0238 625A 0460 28 B @BKLINK 625C 30EA 0239 ;]* 0240 ;[*== VDP multi byte write. CODE = 2 ================= 0241 * 0242 313E MBW EQU $LO+$-LLVSPT 0243 625E C0B9 30 MOV *SP+,R2 Number of bytes to move 0244 6260 C039 30 MOV *SP+,R0 VRAM address (destination) 0245 6262 C079 30 MOV *SP+,R1 RAM address (source) 0246 6264 0420 54 BLWP @VMBW 6266 3742 0247 6268 0460 28 B @BKLINK 626A 30EA 0248 ;]* 0249 ;[*== VDP single byte read. CODE = 4 ================= 0250 * 0251 314C SBR EQU $LO+$-LLVSPT 0252 626C C019 26 MOV *SP,R0 VRAM address (source) 0253 626E 0420 54 BLWP @VSBR 6270 3746 0254 6272 0981 56 SRL R1,8 Character to right half for Forth 0255 6274 C641 30 MOV R1,*SP Stack it 0256 6276 0460 28 B @BKLINK 6278 30EA 0257 ;]* 0258 ;[*== VDP multi byte read. CODE = 6 ================= 0259 * 0260 315A MBR EQU $LO+$-LLVSPT 0261 627A C0B9 30 MOV *SP+,R2 Number of bytes to read 0262 627C C079 30 MOV *SP+,R1 RAM address (destination) 0263 627E C039 30 MOV *SP+,R0 VRAM address (source) 0264 6280 0420 54 BLWP @VMBR 6282 374A 0265 6284 0460 28 B @BKLINK 6286 30EA 0266 ;]* 0267 ;[*== VDP-to-VDP move. CODE = 18 ================= 0268 * 0269 3168 MVE EQU $LO+$-LLVSPT 0270 6288 C039 30 MOV *SP+,R0 Pop cnt to R0 0271 628A C0B9 30 MOV *SP+,R2 Pop vdst to R2 0272 628C C079 30 MOV *SP+,R1 Pop vsrc to R1 0273 628E 0420 54 BLWP @VMOVE 6290 374E 0274 6292 0460 28 B @BKLINK 6294 30EA 0275 ;]* 0276 ;[*== VDP register write. CODE = 8 ================= 0277 * 0278 3176 WTR EQU $LO+$-LLVSPT 0279 6296 C079 30 MOV *SP+,R1 VDP register number 0280 6298 C039 30 MOV *SP+,R0 Data for register 0281 629A 06C1 14 SWPB R1 Get register to left byte 0282 629C D001 18 MOVB R1,R0 Place with data 0283 629E 0420 54 BLWP @VWTR 62A0 3752 0284 62A2 0460 28 B @BKLINK 62A4 30EA 0285 ;]* 0286 ;[*== GPL link utility. CODE = 10 ================= 0287 * 0288 3186 GPL EQU $LO+$-LLVSPT 0289 62A6 04C0 14 CLR R0 0290 62A8 D800 38 MOVB R0,@KYSTAT 62AA 837C 0291 62AC 0200 20 LI R0,>0420 Construct the BLWP instruction 62AE 0420 0292 62B0 0201 20 LI R1,GPLLNK to the GPLLNK utility 62B2 3784 0293 62B4 C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0294 62B6 0203 20 LI R3,>045B Construct the B *LINK instruction 62B8 045B 0295 62BA C10B 18 MOV LINK,R4 Save LINK address 0296 62BC 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62BE 8300 0297 62C0 C2C4 18 MOV R4,LINK and reconstruct LINK 0298 62C2 0460 28 B @BKLINK 62C4 30EA 0299 ;]* 0300 ;[*== XML link utility. CODE = 12 ================= 0301 * 0302 31A6 XML EQU $LO+$-LLVSPT 0303 62C6 0200 20 LI R0,>0420 Construct the BLWP instruction 62C8 0420 0304 62CA 0201 20 LI R1,XMLLNK to the XMLLNK utility 62CC 3736 0305 62CE C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0306 62D0 0203 20 LI R3,>045B Construct the B *LINK instruction 62D2 045B 0307 62D4 C10B 18 MOV LINK,R4 Save LINK address 0308 62D6 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62D8 8300 0309 62DA C2C4 18 MOV R4,LINK and reconstruct LINK 0310 62DC 0460 28 B @BKLINK 62DE 30EA 0311 ;]* 0312 ;[*== DSR link utility. CODE = 14 ================= 0313 * 0314 31C0 DSR EQU $LO+$-LLVSPT 0315 62E0 0200 20 LI R0,>0420 Construct the BLWP instruction 62E2 0420 0316 62E4 0201 20 LI R1,DSRLNK to the DSRLNK utility 62E6 37BE 0317 62E8 C0B9 30 MOV *SP+,R2 This datum selects DSR or subroutine 0318 62EA 0203 20 LI R3,>045B Construct the B *LINK instruction 62EC 045B 0319 62EE C10B 18 MOV LINK,R4 Save LINK address 0320 62F0 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62F2 8300 0321 62F4 C2C4 18 MOV R4,LINK and reconstruct LINK 0322 62F6 0460 28 B @BKLINK 62F8 30EA 0323 ;]* 0324 ;[*== Screen clearing utility. CODE = 16 ================= 0325 * 0326 31DA CLS$ EQU $LO+$-LLVSPT 0327 62FA C0A8 34 MOV @$SSTRT(U),R2 Beginning of screen in VRAM 62FC 0032 0328 62FE C068 34 MOV @$SEND(U),R1 End of screen in VRAM 6300 0034 0329 6302 6042 18 S R2,R1 Screen size 0330 6304 0200 20 LI R0,>2000 Blank character 6306 2000 0331 6308 C1CB 18 MOV LINK,R7 0332 630A 06A0 32 BL @FILL1 630C 3208 0333 630E C2C7 18 MOV R7,LINK 0334 6310 0460 28 B @BKLINK 6312 30EA 0335 ;]* 0336 ;[*== VDP fill routine. CODE = 20 ================= 0337 * 0338 31F4 FILL$ EQU $LO+$-LLVSPT 0339 6314 C039 30 MOV *SP+,R0 Fill character 0340 6316 06C0 14 SWPB R0 to left byte 0341 6318 C079 30 MOV *SP+,R1 Fill count 0342 631A C0B9 30 MOV *SP+,R2 Address to start VRAM fill 0343 631C C1CB 18 MOV LINK,R7 0344 631E 06A0 32 BL @FILL1 6320 3208 0345 6322 C2C7 18 MOV R7,LINK 0346 6324 0460 28 B @BKLINK 6326 30EA 0347 *======================================================================== 0348 3208 FILL1 EQU $LO+$-LLVSPT R0=char, R1=cnt, R2=vaddr 0349 6328 0262 22 ORI R2,>4000 Set bit for VDP write 632A 4000 0350 632C 06C2 14 SWPB R2 0351 632E D802 38 MOVB R2,@VDPWA LS byte first 6330 8C02 0352 6332 06C2 14 SWPB R2 0353 6334 D802 38 MOVB R2,@VDPWA Then MS byte 6336 8C02 0354 6338 1000 14 NOP Kill time 0355 633A D800 38 FLOOP MOVB R0,@VDPWD Write a byte 633C 8C00 0356 633E 0601 14 DEC R1 0357 6340 16FC 14 JNE FLOOP Not done, fill another 0358 6342 045B 20 B *LINK 0359 ;]*====================================================================== 0360 * 0361 *==== VAND -- VDP byte AND routine. CODE = 22 ================= 0362 *==== VOR -- VDP byte OR routine. CODE = 24 ================= 0363 ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= 0364 * 0365 3224 AOX EQU $LO+$-LLVSPT 0366 6344 C0B9 30 MOV *SP+,R2 VRAM address 0367 6346 06C2 14 SWPB R2 0368 6348 D802 38 MOVB R2,@VDPWA LS byte first 634A 8C02 0369 634C 06C2 14 SWPB R2 0370 634E D802 38 MOVB R2,@VDPWA Then MS byte 6350 8C02 0371 6352 1000 14 NOP Kill time 0372 6354 D0E0 34 MOVB @VDPRD,R3 Read byte 6356 8800 0373 6358 C039 30 MOV *SP+,R0 Get data to operate with 0374 635A 06C0 14 SWPB R0 to left byte 0375 *** Now do requested operation ***************** 0376 635C 0281 22 CI R1,24 635E 0018 0377 6360 1304 14 JEQ DOOR 0378 6362 1505 14 JGT DOXOR 0379 6364 0543 14 INV R3 These two instructions 0380 6366 4003 18 SZC R3,R0 perform an 'AND' 0381 6368 1003 14 JMP FINAOX 0382 636A E003 18 DOOR SOC R3,R0 perform 'OR' 0383 636C 1001 14 JMP FINAOX 0384 636E 2803 18 DOXOR XOR R3,R0 perform 'XOR' 0385 6370 0201 20 FINAOX LI R1,1 6372 0001 0386 6374 C1CB 18 MOV LINK,R7 0387 6376 06A0 32 BL @FILL1 6378 3208 0388 637A C2C7 18 MOV R7,LINK 0389 637C 0460 28 B @BKLINK 637E 30EA 0390 ;]* 0391 ;[*== KEY routine CODE = -2 ================= 0392 * 0393 3260 KY EQU $LO+$-LLVSPT 0394 6380 C028 34 MOV @$ALTI(U),R0 alternate input device? 6382 0038 0395 6384 131B 14 JEQ KEY0 jump to keyboard input if not 0396 * 0397 * R0 now points to PAB for alternate input device, the one-byte buffer 0398 * for which must immediately precede its PAB. PAB must have been set up 0399 * to read one byte. 0400 * 0401 6386 04C7 14 CLR R7 prepare to zero status byte 0402 6388 D807 38 MOVB R7,@KYSTAT zero status byte 638A 837C 0403 638C 0580 14 INC R0 point R0 to Flag/Status byte 0404 638E 0420 54 BLWP @VSBR read it 6390 3746 0405 6392 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6394 1F00 0406 6396 0420 54 BLWP @VSBW write it back to PAB 6398 373E 0407 639A C040 18 MOV R0,R1 Set up pointer... 0408 639C 0221 22 AI R1,8 ...to namelength byte of PAB 639E 0008 0409 63A0 C801 38 MOV R1,@SUBPTR copy to DSR subroutine name-length pointer 63A2 8356 0410 63A4 C0C0 18 MOV R0,R3 save pointer (DSRLNK will trash it!) 0411 63A6 0420 54 BLWP @DSRLNK get 1 byte from device 63A8 37BE 0412 63AA 0008 DATA >8 0413 63AC C003 18 MOV R3,R0 restore pointer 0414 63AE 0640 14 DECT R0 point to one-byte VRAM buffer in front of PAB 0415 63B0 0420 54 BLWP @VSBR read character 63B2 3746 0416 63B4 0981 56 SRL R1,8 move to LSB 0417 63B6 C001 18 MOV R1,R0 copy to return register 0418 63B8 0460 28 B @BKLINK return to caller 63BA 30EA 0419 * 0420 * Input is comining from the keyboard 0421 * 0422 63BC C1E0 34 KEY0 MOV @KEYCNT,R7 63BE 3954 0423 63C0 0587 14 INC R7 0424 63C2 160A 14 JNE KEY1 0425 63C4 C028 34 MOV @CURPO$(U),R0 63C6 0016 0426 63C8 0420 54 BLWP @VSBR Read character at cursor position... 63CA 3746 0427 63CC D801 38 MOVB R1,@CURCHR ...and save it 63CE 3ABC 0428 63D0 0201 20 LI R1,>1E00 Place cursor character on screen 63D2 1E00 0429 63D4 0420 54 BLWP @VSBW 63D6 373E 0430 * 0431 63D8 0420 54 KEY1 BLWP @KSCAN 63DA 373A 0432 63DC D020 34 MOVB @KYSTAT,R0 63DE 837C 0433 63E0 2020 38 COC @H2000,R0 check status 63E2 3734 0434 63E4 1319 14 JEQ KEY2 JMP if key was pressed 0435 * 0436 63E6 0287 22 CI R7,100 No key pressed 63E8 0064 0437 63EA 1603 14 JNE KEY3 0438 63EC D060 34 MOVB @CURCHR,R1 63EE 3ABC 0439 63F0 1006 14 JMP KEY5 0440 * 0441 63F2 0287 22 KEY3 CI R7,200 63F4 00C8 0442 63F6 1607 14 JNE KEY4 0443 63F8 04C7 14 CLR R7 0444 63FA 0201 20 LI R1,>1E00 Cursor char 63FC 1E00 0445 63FE C028 34 KEY5 MOV @CURPO$(U),R0 6400 0016 0446 6402 0420 54 BLWP @VSBW 6404 373E 0447 6406 C807 38 KEY4 MOV R7,@KEYCNT 6408 3954 0448 640A C1E0 34 MOV @INTACT,R7 Are we in user's ISR? 640C 3956 0449 640E 1602 14 JNE KEY6 Don't enable interrupts if so. 0450 6410 0300 24 LIMI 2 6412 0002 0451 6414 064D 14 KEY6 DECT IP This will re-execute KEY 0452 6416 045F 20 B *NEXT 0453 6418 0720 34 KEY2 SETO @KEYCNT Key was pressed 641A 3954 0454 641C C028 34 MOV @CURPO$(U),R0 Restore character at cursor location 641E 0016 0455 6420 D060 34 MOVB @CURCHR,R1 6422 3ABC 0456 6424 0420 54 BLWP @VSBW 6426 373E 0457 6428 D020 34 MOVB @KYCHAR,R0 Put char in... 642A 8375 0458 642C 0980 56 SRL R0,8 ...LSB of R0 0459 642E 0460 28 B @BKLINK 6430 30EA 0460 ;]* 0461 ;[*== EMIT routine CODE = -4 ================= 0462 * 0463 3312 EMT EQU $LO+$-LLVSPT 0464 6432 C042 18 MOV R2,R1 copy char to R1 for VSBW 0465 6434 C028 34 MOV @$ALTO(U),R0 alternate output device? 6436 003A 0466 6438 1317 14 JEQ EMIT0 jump to video display output if not 0467 * 0468 * R0 now points to PAB for alternate output device, the one-byte buffer 0469 * for which must immediately precede its PAB. PAB must have been set up 0470 * to write one byte. 0471 * 0472 643A 04C7 14 CLR R7 ALTOUT active 0473 643C D807 38 MOVB R7,@KYSTAT zero status byte 643E 837C 0474 6440 0600 14 DEC R0 point to one-byte VRAM buffer in front of PAB 0475 6442 06C1 14 SWPB R1 char to MSB 0476 6444 0420 54 BLWP @VSBW write char to buffer 6446 373E 0477 6448 05C0 14 INCT R0 point to Flag/Status byte 0478 644A 0420 54 BLWP @VSBR read it 644C 3746 0479 644E 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6450 1F00 0480 6452 0420 54 BLWP @VSBW write it back to PAB 6454 373E 0481 6456 0220 22 AI R0,8 Set up pointer to namelength byte of PAB 6458 0008 0482 645A C800 38 MOV R0,@SUBPTR copy to DSR subroutine name-length pointer 645C 8356 0483 645E 0420 54 BLWP @DSRLNK put 1 byte to device 6460 37BE 0484 6462 0008 DATA >8 0485 6464 0460 28 B @BKLINK return to caller 6466 30EA 0486 * 0487 * Output is going to the video display 0488 * 0489 6468 0281 22 EMIT0 CI R1,7 Is it a bell? 646A 0007 0490 646C 1607 14 JNE NOTBEL 0491 646E 04C2 14 CLR R2 0492 6470 D802 38 MOVB R2,@KYSTAT 6472 837C 0493 6474 0420 54 BLWP @GPLLNK 6476 3784 0494 6478 0036 DATA >0036 Emit error tone 0495 647A 1060 14 JMP EMEXIT 0496 * 0497 647C 0281 22 NOTBEL CI R1,8 Is it a backspace? 647E 0008 0498 6480 160B 14 JNE NOTBS 0499 6482 0201 20 LI R1,>2000 6484 2000 0500 6486 C028 34 MOV @CURPO$(U),R0 6488 0016 0501 648A 0420 54 BLWP @VSBW 648C 373E 0502 648E 1501 14 JGT DECCUR 0503 6490 1055 14 JMP EMEXIT 0504 6492 0628 34 DECCUR DEC @CURPO$(U) 6494 0016 0505 6496 1052 14 JMP EMEXIT 0506 * 0507 6498 0281 22 NOTBS CI R1,>A Is it a line feed? 649A 000A 0508 649C 162B 14 JNE NOTLF 0509 649E C1E8 34 MOV @$SEND(U),R7 64A0 0034 0510 64A2 61E8 34 S @$SWDTH(U),R7 64A4 0030 0511 64A6 81E8 34 C @CURPO$(U),R7 64A8 0016 0512 64AA 1404 14 JHE SCRLL 0513 64AC AA28 54 A @$SWDTH(U),@CURPO$(u) 64AE 0030 64B0 0016 0514 64B2 1044 14 JMP EMEXIT 0515 64B4 C1CB 18 SCRLL MOV LINK,R7 0516 64B6 06A0 32 BL @SCROLL 64B8 339E 0517 64BA C2C7 18 MOV R7,LINK 0518 64BC 103F 14 JMP EMEXIT 0519 * 0520 *** SCROLLING ROUTINE 0521 * 0522 339E SCROLL EQU $LO+$-LLVSPT 0523 64BE C028 34 MOV @$SSTRT(U),R0 VRAM addr 64C0 0032 0524 64C2 0201 20 LI R1,LINBUF Line buffer 64C4 3A6C 0525 64C6 C0A8 34 MOV @$SWDTH(U),R2 Count 64C8 0030 0526 64CA A002 18 A R2,R0 Start at line 2 0527 64CC 0420 54 SCROL1 BLWP @VMBR 64CE 374A 0528 64D0 6002 18 S R2,R0 One line back to write 0529 64D2 0420 54 BLWP @VMBW 64D4 3742 0530 64D6 A002 18 A R2,R0 Two lines ahead for next read 0531 64D8 A002 18 A R2,R0 0532 64DA 8A00 38 C R0,@$SEND(U) End of screen? 64DC 0034 0533 64DE 1AF6 14 JL SCROL1 0534 64E0 C042 18 MOV R2,R1 Blank bottom row of screen 0535 64E2 0200 20 LI R0,>2000 Blank 64E4 2000 0536 64E6 60A8 34 S @$SEND(U),R2 64E8 0034 0537 64EA 0502 16 NEG R2 Now contains address of start of last line 0538 64EC C18B 18 MOV LINK,R6 0539 64EE 06A0 32 BL @FILL1 Write the blanks 64F0 3208 0540 64F2 0456 20 B *R6 0541 * 0542 64F4 0281 22 NOTLF CI R1,>D Is it a carriage return? 64F6 000D 0543 64F8 160D 14 JNE NOTCR 0544 64FA 04C0 14 CLR R0 0545 64FC C068 34 MOV @CURPO$(U),R1 64FE 0016 0546 6500 C0C1 18 MOV R1,R3 0547 6502 6068 34 S @$SSTRT(U),R1 Adjusted for screen not at 0 6504 0032 0548 6506 C0A8 34 MOV @$SWDTH(U),R2 6508 0030 0549 650A 3C02 128 DIV R2,R0 0550 650C 60C1 18 S R1,R3 0551 650E CA03 38 MOV R3,@CURPO$(U) 6510 0016 0552 6512 1014 14 JMP EMEXIT 0553 * 0554 6514 06C1 14 NOTCR SWPB R1 Assume it is a printable character 0555 6516 C028 34 MOV @CURPO$(U),R0 6518 0016 0556 651A 0420 54 BLWP @VSBW 651C 373E 0557 651E C0A8 34 MOV @$SEND(U),R2 6520 0034 0558 6522 0602 14 DEC R2 0559 6524 8080 18 C R0,R2 0560 6526 1607 14 JNE NOTCR1 0561 6528 C028 34 MOV @$SEND(U),R0 652A 0034 0562 652C 6028 34 S @$SWDTH(U),R0 Was last char on screen. Scroll 652E 0030 0563 6530 CA00 38 MOV R0,@CURPO$(U) 6532 0016 0564 6534 10BF 14 JMP SCRLL 0565 6536 0580 14 NOTCR1 INC R0 No scroll necessary 0566 6538 CA00 38 MOV R0,@CURPO$(U) 653A 0016 0567 * 0568 653C 0460 28 EMEXIT B @BKLINK 653E 30EA 0569 ;]* 0570 ;[*== CRLF routine CODE = -6 ================= 0571 * 0572 3420 CLF EQU $LO+$-LLVSPT 0573 6540 C14B 18 MOV LINK,R5 0574 6542 0202 20 LI R2,>000D 6544 000D 0575 6546 06A0 32 BL @EMT EMT will alter INT mask via B @BKLINK 6548 3312 0576 654A 0202 20 LI R2,>000A 654C 000A 0577 654E 0300 24 LIMI 0 Previous call to EMT altered INT mask 6550 0000 0578 6552 06A0 32 BL @EMT 6554 3312 0579 6556 C2C5 18 MOV R5,LINK 0580 6558 0460 28 B @BKLINK 655A 30EA 0581 ;]* 0582 ;[*== ?TERMINAL routine CODE = -8 ================= 0583 * scan for <clear>, <break>, FCTN+4 press 0584 * 0585 343C QTM EQU $LO+$-LLVSPT 0586 655C C14B 18 MOV LINK,R5 save return 0587 655E 06A0 32 BL @>0020 branch to console's test for <clear> 6560 0020 0588 6562 02C0 12 STST R0 store status in R0 0589 6564 1603 14 JNE QTM2 exit if not <clear> 0590 6566 06A0 32 QTM1 BL @>0020 check for <clear> again 6568 0020 0591 656A 13FD 14 JEQ QTM1 loop until not <clear> 0592 656C C2C5 18 QTM2 MOV R5,LINK restore return 0593 656E 0240 22 ANDI R0,>2000 keep only EQU bit 6570 2000 0594 6572 0460 28 B @BKLINK return to caller 6574 30EA 0595 ;]* 0596 ;[*== ?KEY routine CODE = -10 ================= 0597 * 0598 3456 QKY EQU $LO+$-LLVSPT 0599 6576 0420 54 BLWP @KSCAN 6578 373A 0600 657A D020 34 MOVB @KYCHAR,R0 657C 8375 0601 657E 0980 56 SRL R0,8 0602 6580 0280 22 CI R0,>00FF 6582 00FF 0603 6584 1601 14 JNE QKEY1 0604 6586 04C0 14 CLR R0 0605 6588 0460 28 QKEY1 B @BKLINK 658A 30EA 0606 ;]* 0607 ;[*== GOTOXY routine CODE = -12 ================= 0608 * 0609 346C GXY EQU $LO+$-LLVSPT 0610 658C 38E8 72 MPY @$SWDTH(U),R3 658E 0030 0611 6590 A102 18 A R2,R4 Position within screen 0612 6592 A128 34 A @$SSTRT(U),R4 Add VRAM offset to screen top 6594 0032 0613 6596 CA04 38 MOV R4,@CURPO$(U) 6598 0016 0614 659A 0460 28 B @BKLINK 659C 30EA 0615 ;] 0616 * ___ __ __ ____ ______ 0617 * / _ )/ /__ ____/ /__ / _/_/_/ __ \ 0618 * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / 0619 * /____/_/\___/\__/_/\_\ /___/_/ \____/ 0620 0621 * 0622 *== USE blocks file CODE = -14 ================= 0623 *== CREATE blocks file CODE = -16 ================= 0624 *== READ block from blocks file CODE = -18 ================= 0625 *== WRITE block to blocks file CODE = -20 ================= 0626 ;[*== Block File I/O Support ============================================ 0627 * 0628 * BPTOG utility to toggle one of 2 PABs for block file access 0629 * 0630 347E BPTOG EQU $LO+$-LLVSPT 0631 659E C028 34 MOV @$BPOFF(U),R0 PAB offset to R0 65A0 0040 0632 65A2 0201 20 LI R1,70 Toggle amount 65A4 0046 0633 65A6 2840 18 XOR R0,R1 New offset 0634 65A8 CA01 38 MOV R1,@$BPOFF(U) Update offset 65AA 0040 0635 * 0636 **xxx** entry point to insure we have correct PAB address 0637 348C BPSET EQU $LO+$-LLVSPT 0638 65AC C028 34 MOV @$DKBUF(U),R0 Get DISK_BUF address 65AE 002C 0639 65B0 A028 34 A @$BPABS(U),R0 Get BPABS address 65B2 003E 0640 * 0641 65B4 A028 34 A @$BPOFF(U),R0 Add current offset 65B6 0040 0642 65B8 C800 38 MOV R0,@BFPAB Update current block file's PAB address 65BA 34BC 0643 65BC 045B 20 RT 0644 * 0645 * CLOSE blocks file 0646 * 0647 349E BKCLOS EQU $LO+$-LLVSPT 0648 65BE C020 34 MOV @BFPAB,R0 65C0 34BC 0649 65C2 0201 20 LI R1,$FCLS Opcode=CLOSE 65C4 0100 0650 65C6 0420 54 BLWP @VSBW 65C8 373E 0651 65CA 0220 22 AI R0,9 Address of filename's char count 65CC 0009 0652 65CE C800 38 MOV R0,@SUBPTR Point to filename's char count 65D0 8356 0653 65D2 0420 54 BLWP @DSRLNK Close the file 65D4 37BE 0654 65D6 0008 DATA 8 0655 65D8 045B 20 RT Deal with error in caller 0656 * 0657 * storage area 0658 * 0659 34BA SVBRET EQU $LO+$-LLVSPT 0660 65DA 0000 DATA 0 Storage for LINK coming into BRW 0661 34BC BFPAB EQU $LO+$-LLVSPT 0662 65DC 0000 DATA 0 Storage for current blocks file PAB address... 0663 * ...will have current PAB on entry 0664 * PAB header storage 0665 * 0666 34BE PABHD EQU $LO+$-LLVSPT 0667 65DE BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE 0668 * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative 0669 * >03=OUTPUT mode + " 0670 * >01=UPDATE mode + " 0671 * BYTE 2,3: save contents of DISK_BUF here 0672 65E2 80 BYTE >80 Record length 0673 65E3 80 BYTE >80 Character count of transfer 0674 65E4 BSS 2 Record number 0675 * 0676 *** file I/O equates 0677 * 0678 0000 $FOPN EQU >0000 0679 0100 $FCLS EQU >0100 0680 0200 $FRD EQU >0200 0681 0300 $FWRT EQU >0300 0682 0400 $FRST EQU >0400 0683 0005 $FINP EQU 5 0684 0003 $FOUT EQU 3 0685 0001 $FUPD EQU 1 0686 * 0687 *** BRW -- entry point for block read/write routines 0688 * 0689 34C6 BRW EQU $LO+$-LLVSPT 0690 65E6 C80B 38 MOV LINK,@SVBRET Save LINK address 65E8 34BA 0691 65EA C1C1 18 MOV R1,R7 Save CODE {R1 to R7} 0692 65EC 0817 56 SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) 0693 65EE 0227 22 AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) 65F0 000C 0694 65F2 06A0 32 BL @BPSET Insure correct PAB address in BFPAB (it may have moved) 65F4 348C 0695 65F6 0287 22 CI R7,4 USE or CREATE? 65F8 0004 0696 65FA 110D 14 JLT BRW01 No 0697 65FC 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 65FE 347E 0698 6600 C020 34 MOV @BFPAB,R0 Load PAB address 6602 34BC 0699 6604 0220 22 AI R0,9 Set to name length byte 6606 0009 0700 6608 04C2 14 CLR R2 0701 660A C079 30 MOV *SP+,R1 Pop bfnaddr to R1 0702 660C D811 46 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 660E 8305 0703 6610 0582 14 INC R2 Add 1 to # bytes to copy 0704 6612 0420 54 BLWP @VMBW Copy char count & pathname to PAB 6614 3742 0705 * 0706 *** set up PAB for OPEN 0707 * 0708 6616 0201 20 BRW01 LI R1,$FUPD Opcode=0,mode=update 6618 0001 0709 661A 9820 54 CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? 661C 830F 661E 830F 0710 6620 1C02 14 JOP BRW02 No 0711 6622 0201 20 LI R1,$FINP Yes...change mode=input 6624 0005 0712 6626 C801 38 BRW02 MOV R1,@PABHD Put in PAB header 6628 34BE 0713 662A C828 54 MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header 662C 002C 662E 34C0 0714 6630 04C0 14 CLR R0 0715 6632 C800 38 MOV R0,@PABHD+6 Set record#=0 6634 34C4 0716 6636 C020 34 MOV @BFPAB,R0 VRAM destination 6638 34BC 0717 663A 0201 20 LI R1,PABHD RAM source 663C 34BE 0718 663E 0202 20 LI R2,8 Copy first 8 bytes of PAB header 6640 0008 0719 6642 0420 54 BLWP @VMBW Do the copy 6644 3742 0720 * 0721 *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] 0722 * 0723 6646 0220 22 AI R0,9 Address of filename's char count in PAB 6648 0009 0724 664A C800 38 MOV R0,@SUBPTR Point to-----^^^^ 664C 8356 0725 664E 0420 54 BLWP @DSRLNK Open/create the file 6650 37BE 0726 6652 0008 DATA 8 0727 6654 135F 14 JEQ BKERR 0728 6656 0287 22 CI R7,4 READ or WRITE? 6658 0004 0729 665A 1120 14 JLT BRW04 Yes 0730 665C 156E 14 JGT BRWDON No; =USE; we're done 0731 * 0732 *** write blank records to newly created blocks file [CODE = -16,CREATE] 0733 * 0734 665E C179 30 MOV *SP+,R5 No; = CREATE; pop #blocks from stack 0735 6660 0A35 56 SLA R5,3 Convert #blocks to #records 0736 6662 C0C5 18 MOV R5,R3 Save 0737 6664 C105 18 MOV R5,R4 Set up counter 0738 6666 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 6668 0301 0739 666A C800 38 MOV R0,@PABHD Copy to PAB header 666C 34BE 0740 666E 6144 18 BRLOOP S R4,R5 Calculate next record 0741 6670 C805 38 MOV R5,@PABHD+6 Copy to PAB header 6672 34C4 0742 6674 C020 34 MOV @BFPAB,R0 VRAM destination 6676 34BC 0743 6678 0201 20 LI R1,PABHD RAM source 667A 34BE 0744 667C 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 667E 0008 0745 6680 0420 54 BLWP @VMBW Do the copy 6682 3742 0746 6684 0220 22 AI R0,9 Address of filename's char count 6686 0009 0747 6688 C800 38 MOV R0,@SUBPTR Point to filename's char count 668A 8356 0748 668C 0420 54 BLWP @DSRLNK Write one record of blanks 668E 37BE 0749 6690 0008 DATA 8 0750 6692 1340 14 JEQ BKERR 0751 6694 C143 18 MOV R3,R5 Get #blocks 0752 6696 0604 14 DEC R4 Count down 1 record 0753 6698 16EA 14 JNE BRLOOP Write another record if not done 0754 669A 104F 14 JMP BRWDON We're done 0755 * 0756 *** prepare for read/write block 0757 * 0758 669C C179 30 BRW04 MOV *SP+,R5 Pop block# to write 0759 669E C1B9 30 MOV *SP+,R6 Pop bufaddr 0760 66A0 0605 14 DEC R5 Block#-1 0761 66A2 0A35 56 SLA R5,3 Convert to starting record# 0762 66A4 0204 20 LI R4,8 Load counter for 8 records 66A6 0008 0763 66A8 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 66AA 0301 0764 66AC 0203 20 LI R3,VMBW WRITE vector 66AE 3742 0765 66B0 0287 22 CI R7,2 Are we writing the block? 66B2 0002 0766 66B4 1304 14 JEQ BRW05 Yup 0767 66B6 0200 20 LI R0,$FRD+$FINP Nope...set up for READ 66B8 0205 0768 66BA 0203 20 LI R3,VMBR READ vector 66BC 374A 0769 66BE C800 38 BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header 66C0 34BE 0770 * 0771 * READ/WRITE block routine [CODE = -18/-20] 0772 * 0773 66C2 C805 38 RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header 66C4 34C4 0774 66C6 C020 34 MOV @BFPAB,R0 VRAM destination 66C8 34BC 0775 66CA 0201 20 LI R1,PABHD RAM source 66CC 34BE 0776 66CE 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 66D0 0008 0777 66D2 0420 54 BLWP @VMBW Do the copy 66D4 3742 0778 66D6 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 66D8 002C 0779 66DA C046 18 MOV R6,R1 RAM buffer to R1 0780 66DC 0202 20 LI R2,128 Bytes to copy 66DE 0080 0781 66E0 0287 22 CI R7,3 READ? 66E2 0003 0782 66E4 1301 14 JEQ BRW06 Yup 0783 66E6 0413 42 BLWP *R3 Nope...copy record to VRAM 0784 * 0785 * temporarily use CRU register---it should be OK 0786 * 0787 66E8 C320 34 BRW06 MOV @BFPAB,CRU PAB address 66EA 34BC 0788 66EC 022C 22 AI CRU,9 Address of filename's char count 66EE 0009 0789 66F0 C80C 38 MOV CRU,@SUBPTR Point to filename's char count 66F2 8356 0790 66F4 0420 54 BLWP @DSRLNK Read/write one record 66F6 37BE 0791 66F8 0008 DATA 8 0792 66FA 130C 14 JEQ BKERR 0793 66FC 0287 22 CI R7,2 WRITE? 66FE 0002 0794 6700 1303 14 JEQ BRW07 Yup...next record 0795 6702 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) 6704 002C 0796 6706 0413 42 BLWP *R3 Nope...copy record to RAM buffer 0797 6708 0585 14 BRW07 INC R5 Next record in file 0798 670A 0226 22 AI R6,128 Next record to/from block RAM buffer 670C 0080 0799 670E 0604 14 DEC R4 Count down 1 record 0800 6710 16D8 14 JNE RWLOOP Read/write another record if not done 0801 6712 1013 14 JMP BRWDON We're done 0802 * 0803 *** error handling 0804 * 0805 6714 D000 18 BKERR MOVB R0,R0 Device error? 0806 6716 1306 14 JEQ BKERR6 Yes, exit with disk error 0807 6718 0206 20 BKERR9 LI R6,9 No, exit with file error 671A 0009 0808 671C 1005 14 JMP BKCLN 0809 671E 0206 20 BKERR8 LI R6,8 Block# <=0! exit with range error 6720 0008 0810 6722 1002 14 JMP BKCLN 0811 6724 0206 20 BKERR6 LI R6,6 6726 0006 0812 6728 06A0 32 BKCLN BL @BKCLOS Close current blocks file; ignore error 672A 349E 0813 672C 0287 22 CI R7,4 USE or CREATE? 672E 0004 0814 6730 1102 14 JLT BKCLN1 No 0815 6732 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 6734 347E 0816 6736 C006 18 BKCLN1 MOV R6,R0 Pass error back to caller 0817 6738 100C 14 JMP BKEXIT 0818 673A 04C6 14 BRWDON CLR R6 0819 673C 06A0 32 BL @BKCLOS Close current blocks file 673E 349E 0820 6740 1602 14 JNE BRWDN1 Error? 0821 6742 0206 20 LI R6,9 Yes...assume it was a file error 6744 0009 0822 6746 0287 22 BRWDN1 CI R7,4 (no error)...CREATE? 6748 0004 0823 674A 1602 14 JNE BRWDN2 No...we're done 0824 674C 06A0 32 BL @BPTOG Yes...revert to correct blocks file 674E 347E 0825 6750 C006 18 BRWDN2 MOV R6,R0 Error to R0 0826 6752 C2E0 34 BKEXIT MOV @SVBRET,LINK Restore LINK 6754 34BA 0827 6756 0460 28 B @BKLINK 6758 30EA 0828 ;] 0829 ;[* MSGTYP <<< Support for string typing in various banks >>> 0830 * 0831 * Called with: BL @MSGTYP 0832 * 0833 * R4 and R5 are the only registers that will be preserved 0834 * ..after a call to EMIT--- 0835 * 0836 * Input: R4 = Address of length byte of packed string 0837 * 0838 * We will pass the ASCII value of character to EMIT in R2 without 0839 * insuring it is 7 bits wide. 0840 * 0841 363A MSGTYP EQU $LO+$-LLVSPT 0842 675A 064E 14 DECT R Push return address 0843 675C C78B 30 MOV LINK,*R ...to Forth return stack 0844 675E 04C5 14 CLR R5 0845 6760 D174 28 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char 0846 6762 06C5 14 SWPB R5 Put char count in low byte 0847 6764 04C2 14 MTLOOP CLR R2 0848 6766 D0B4 28 MOVB *R4+,R2 Copy next char to R2 for EMIT 0849 6768 06C2 14 SWPB R2 Put char in low byte 0850 676A 0300 24 LIMI 0 We need to do this because we're calling EMIT directly 676C 0000 0851 676E 06A0 32 BL @EMT Call EMIT directly 6770 3312 0852 6772 05A8 34 INC @$OUT(U) Increment display line character count 6774 0052 0853 6776 0605 14 DEC R5 Decrement character count for this message 0854 6778 16F5 14 JNE MTLOOP Are we done? 0855 677A C2FE 30 MOV *R+,LINK Yes. Pop return address 0856 677C 045B 20 RT Return to caller 0857 ;] 0858 ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) 0859 365E R4$5 EQU $LO+$-LLVSPT 0860 677E CD74 46 MOV *R4+,*R5+ 0861 6780 CD74 46 MOV *R4+,*R5+ 0862 6782 CD74 46 MOV *R4+,*R5+ 0863 6784 C554 38 MOV *R4,*R5 0864 6786 045B 20 RT 0865 ;] 0866 * __ __ _ __ _ __ __ 0867 * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ 0868 * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) 0869 * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ 0870 * ___ ___ ____ 0871 * / _ \___ / _/__ ___ __/ / /____ 0872 * / // / -_) _/ _ `/ // / / __(_-< 0873 * /____/\__/_/ \_,_/\_,_/_/\__/___/ 0874 0875 ;[*== User Variable defaults ============================================ 0876 * 0877 3668 UBASE0 EQU $LO+$-LLVSPT 0878 6788 BSS 6 BASE OF USER VARIABLES 0879 678E 3668 DATA UBASE0 06 USER UCONS$ 0880 6790 FFA0 DATA SPBASE 08 USER S0 0881 6792 3FFE DATA RBASE 0A USER R0 { R0$ 0882 6794 36B4 DATA $UVAR 0C USER U0 0883 6796 FFA0 DATA SPBASE 0E USER TIB 0884 6798 001F DATA 31 10 USER WIDTH 0885 679A A000 DATA DPBASE 12 USER DP 0886 679C 30F6 DATA $SYS$ 14 USER SYS$ 0887 679E 0000 DATA 0 16 USER CURPOS 0888 67A0 3020 DATA INT1 18 USER INTLNK 0889 67A2 0001 DATA 1 1A USER WARNING 0890 67A4 0040 DATA 64 1C USER C/L$ { CL$ 0891 67A6 2010 DATA $BUFF 1E USER FIRST$ 0892 67A8 3020 DATA $LO 20 USER LIMIT$ 0893 67AA 0380 DATA >0380 22 USER COLTAB Color Table address in VRAM 0894 67AC 0300 DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM 0895 67AE 0780 DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM 0896 67B0 0800 DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM 0897 67B2 0080 DATA >80 2A USER FPB pushes address of user screen font file PAB 0898 * ...that is this relative distance from DISK_BUF 0899 67B4 1000 DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) 0900 67B6 0460 DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) 0901 67B8 0028 DATA 40 30 USER SCRN_WIDTH 0902 67BA 0000 DATA 0 32 USER SCRN_START 0903 67BC 03C0 DATA 960 34 USER SCRN_END 0904 67BE 0000 DATA 0 36 USER ISR [Note: This used to be INT1] 0905 67C0 0000 DATA 0 38 USER ALTIN 0906 67C2 0000 DATA 0 3A USER ALTOUT 0907 67C4 0001 DATA 1 3C USER VDPMDE permanent location for VDPMDE 0908 67C6 00C6 DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files 0909 * ...that is this relative distance from DISK_BUF 0910 67C8 0000 DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB 0911 * ...always toggled between 0 and 70 0912 67CA 0800 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM 0913 67CC FFFF DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) 0914 * 0 = console font via GPLLNK 0915 67CE 0000 DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU 0916 67D0 0000 DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap 0917 67D2 0000 DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. 0918 * 0 = Symmetric (default) 0919 * !0 = Floored 0920 36B4 $UVAR EQU $LO+$-LLVSPT 0921 67D4 BSS >80 USER VARIABLE AREA 0922 ;] 0923 ;[*== A Constant ==================================================== 0924 * 0925 3734 H2000 EQU $LO+$-LLVSPT 0926 6854 2000 DATA >2000 0927 ;]* 0928 * __ ____ _ ___ __ _ __ __ 0929 * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ 0930 * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< 0931 * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ 0932 * /___/ 0933 * 0934 ;[*== Utility Vectors =================================================== 0935 * 0936 * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK 0937 * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK 0938 3736 XMLLNK EQU $LO+$-LLVSPT 0939 6856 3A4C DATA UTILWS,XMLENT ; Link to ROM routines 6858 3756 0940 373A KSCAN EQU $LO+$-LLVSPT 0941 685A 3A4C DATA UTILWS,KSENTR ; Keyboard scan 685C 3832 0942 373E VSBW EQU $LO+$-LLVSPT 0943 685E 3A4C DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) 6860 3848 0944 3742 VMBW EQU $LO+$-LLVSPT 0945 6862 3A4C DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) 6864 3854 0946 3746 VSBR EQU $LO+$-LLVSPT 0947 6866 3A4C DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) 6868 3862 0948 374A VMBR EQU $LO+$-LLVSPT 0949 686A 3A4C DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) 686C 386E 0950 374E VMOVE EQU $LO+$-LLVSPT 0951 686E 3A4C DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) 6870 38AE 0952 3752 VWTR EQU $LO+$-LLVSPT 0953 6872 3A4C DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) 6874 387C 0954 ;]* 0955 ;[*== XMLENT -- Link to system XML utilities ============================ 0956 * 0957 3756 XMLENT EQU $LO+$-LLVSPT 0958 6876 C83E 50 MOV *R14+,@GPLWS+2 Get argument 6878 83E2 0959 687A 02E0 18 LWPI GPLWS Select GPL workspace 687C 83E0 0960 687E C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6880 3A62 0961 6882 C081 18 MOV R1,R2 Make a copy of argument 0962 6884 0281 22 CI R1,>8000 Direct address in ALC? 6886 8000 0963 6888 1B07 14 JH XML30 We have the address 0964 688A 09C1 56 SRL R1,12 0965 688C 0A11 56 SLA R1,1 0966 688E 0A42 56 SLA R2,4 0967 6890 09B2 56 SRL R2,11 0968 6892 A0A1 34 A @XMLTAB(R1),R2 6894 0CFA 0969 6896 C092 26 MOV *R2,R2 0970 6898 0692 24 XML30 BL *R2 0971 689A 02E0 18 LWPI UTILWS Get back to right WS 689C 3A4C 0972 689E C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 68A0 83F6 0973 68A2 0380 18 RTWP 0974 ;]* 0975 * ________ __ __ _ ____ __ __ ________ 0976 * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ 0977 * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / 0978 * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 0979 * 0980 *-----------------------------------------------------------------------* 0981 ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= 0982 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 0983 * * 0984 * This routine will work with any GROM library slot since it is * 0985 * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * 0986 * This GPLLNK does NOT require a module to be plugged into the * 0987 * GROM port so it will work with the Editor/Assembler, * 0988 * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * 0989 * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * 0990 * It saves and restores the current GROM Address in case you want * 0991 * to return back to GROM for Basic or Extended Basic CALL LINKs * 0992 * or to return to the loading module. * 0993 * * 0994 * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * 0995 * DATA >34 * 0996 * * 0997 * NOTES: Do Not REF GPLLNK when using this routine in your code. * 0998 * * 0999 * 70 Bytes - including the GPLLNK Workspace * 1000 *-----------------------------------------------------------------------* 1001 1002 * GPLWS (>83E0) is GPL workspace 1003 83E8 G_R4 EQU GPLWS+8 GPL workspace R4 1004 83EC G_R6 EQU GPLWS+12 GPL workspace R6 1005 * SUBSTK (>8373) is GPL Subroutine stack pointer 1006 0060 LDGADR EQU >60 Load & Execute GROM address entry point 1007 200E XTAB27 EQU >200E Low Mem XML table location 27 1008 * ..Will contain XMLRTN at startup 1009 166C GETSTK EQU >166C 1010 1011 3784 GPLLNK EQU $LO+$-LLVSPT 1012 68A4 3776 DATA GLNKWS R7 Set up BLWP Vectors 1013 68A6 3796 DATA GLINK1 R8 1014 * RTNADR EQU $LO+$-LLVSPT <---don't think we need this label 1015 68A8 37B2 DATA XMLRTN R9 address where GPL XML returns to us... 1016 * ...this address will already be in XTAB27,... 1017 * ...>200E, so don't really need it here} 1018 378A GXMLAD EQU $LO+$-LLVSPT 1019 68AA 176C DATA >176C R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) 1020 68AC 0050 DATA >50 R11 Initialized to >50 where PUTSTK address resides 1021 3776 GLNKWS EQU $LO+$-LLVSPT->18 GPLLNK's workspace of which only... 1022 68AE BSS >08 R12-R15 ...registers R7 through R15 are used 1023 1024 3796 GLINK1 EQU $LO+$-LLVSPT 1025 68B6 C81B 46 MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS 68B8 83E8 1026 68BA C83E 50 MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS 68BC 83EC 1027 68BE 02E0 18 LWPI GPLWS Load GPL WS 68C0 83E0 1028 68C2 0694 24 BL *R4 Save current GROM Address on stack 1029 68C4 C920 54 MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return 68C6 378A 68C8 8302 1030 68CA 05E0 34 INCT @SUBSTK Adjust the stack pointer 68CC 8373 1031 68CE 0460 28 B @LDGADR Execute our GPL Routine 68D0 0060 1032 1033 37B2 XMLRTN EQU $LO+$-LLVSPT 1034 68D2 C120 34 MOV @GETSTK,R4 Get GETSTK pointer 68D4 166C 1035 68D6 0694 24 BL *R4 Restore GROM address off the stack 1036 68D8 02E0 18 LWPI GLNKWS Load our WS 68DA 3776 1037 68DC 0380 18 RTWP All Done - Return to Caller 1038 ;] 1039 * ___ _______ __ _ ____ __ __ ________ 1040 * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ 1041 * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / 1042 * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 1043 * 1044 *-----------------------------------------------------------------------* 1045 ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= 1046 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 1047 * * 1048 * (Uses console GROM 0's DSRLNK routine) * 1049 * (Do not REF DSRLNK or GPLLNK when using these routines) * 1050 * (This DSRLNK will also handle Subprograms and CS1, CS2) * 1051 * * 1052 * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * 1053 * DATA 8 * 1054 * * 1055 * NOTES: Must be used with a GPLLNK routine * 1056 * Returns ERRORs the same as the E/A DSRLNK * 1057 * EQ bit set on return if error * 1058 * ERROR CODE in caller's MSB of Register 0 on return * 1059 * * 1060 * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * 1061 *-----------------------------------------------------------------------* 1062 1063 0050 PUTSTK EQU >50 Push GROM Address to stack pointer 1064 836D TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK 1065 8356 NAMLEN EQU >8356 Device name length pointer in VDP PAB 1066 8C02 VWA EQU >8C02 VDP Write Address location 1067 8800 VRD EQU >8800 VDP Read Data byte location 1068 83E9 G_R4LB EQU >83E9 GPL Workspace R4 Lower byte 1069 837C GSTAT EQU >837C GPL Status byte location 1070 1071 37BE DSRLNK EQU $LO+$-LLVSPT 1072 68DE 37C2 DATA DSRWS,DLINK1 Set BLWP Vectors 68E0 37C2 1073 1074 37C2 DSRWS EQU $LO+$-LLVSPT Start of DSRLNK workspace 1075 37C9 DR3LB EQU DSRWS+7 lower byte of DSRLNK workspace R3 1076 37C2 DLINK1 EQU $LO+$-LLVSPT 1077 68E2 C30C 18 MOV R12,R12 R0 Have we already looked up the LINK address? 1078 68E4 161C 14 JNE DLINK3 R1 YES! Skip lookup routine 1079 *<<-------------------------------------------------------------------------->>* 1080 * This section of code is only executed once to find the GROM address * 1081 * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * 1082 * to indicate that the address is found and to be used as a mask for EQ & CND * 1083 *------------------------------------------------------------------------------* 1084 68E6 02E0 18 LWPI GPLWS R2,R3 else load GPL workspace 68E8 83E0 1085 68EA C120 34 MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack 68EC 0050 1086 68EE 0694 24 BL *R4 R6 1087 68F0 0204 20 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector 68F2 0011 1088 68F4 DB44 38 MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector 68F6 0402 1089 1090 ***les*** Note on above instruction: 1091 ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) 1092 ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) 1093 1094 68F8 1004 14 JMP DLINK2 R11 Jump around R12-R15 1095 68FA 0000 DATA 0 R12 contains >2000 flag when set 1096 68FC 0000 DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP 68FE 0000 6900 0000 1097 6902 DB60 54 DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address 6904 83E9 6906 0402 1098 6908 C160 34 MOV @GETSTK,R5 Take some time & set up GETSTK pointer 690A 166C 1099 690C D81D 46 MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector 690E 3811 1100 6910 05E0 34 INCT @DSRADR Adjust it to get past GPL FETCH instruction 6912 3810 1101 6914 0695 24 BL *R5 Restore the GROM address off the stack 1102 6916 02E0 18 LWPI DSRWS Reload DSRLNK workspace 6918 37C2 1103 691A 020C 20 LI R12,>2000 Set flag to signify DSRLNK address is set 691C 2000 1104 *<<-------------------------------------------------------------------------->>* 1105 691E 058E 14 DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte 1106 6920 D83E 48 MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK 6922 836D 1107 6924 C0E0 34 MOV @NAMLEN,R3 Save VDP address of Name Length 6926 8356 1108 6928 0223 22 AI R3,-8 Adjust it to point to PAB Flag byte 692A FFF8 1109 692C 0420 54 BLWP @GPLLNK Execute DSR LINK 692E 3784 1110 3810 DSRADR EQU $LO+$-LLVSPT 1111 6930 03 BYTE >03 High byte of GPL DSRLNK address 1112 3811 DSRAD1 EQU $LO+$-LLVSPT 1113 6931 00 BYTE >00 Lower byte of GPL DSRLNK address 1114 *----Error Check & Report to Caller's R0 and EQU bit------------------------- 1115 6932 D820 54 MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag 6934 37C9 6936 8C02 1116 6938 D803 38 MOVB R3,@VWA Set up MSB of VDP Address for Error Flag 693A 8C02 1117 693C 53CC 18 SZCB R12,R15 Clear EQ bit for Error Report 1118 693E D0E0 34 MOVB @VRD,R3 Get PAB Error Flag 6940 8800 1119 6942 0953 56 SRL R3,5 Adjust it to 0-7 error code 1120 6944 D743 30 MOVB R3,*R13 Put it into Caller's R0 (msb) 1121 6946 1603 14 JNE SETEQ If it's not zero, set EQ bit 1122 6948 2320 38 COC @GSTAT,R12 Else, test CND bit for Link Error (00) 694A 837C 1123 694C 1601 14 JNE DSREND No Error, Just return 1124 694E F3CC 18 SETEQ SOCB R12,R15 Error, so set Caller's EQ bit 1125 6950 0380 18 DSREND RTWP All Done - Return to Caller 1126 ;] 1127 ;[*== KSENTR -- Keyboard Scan (entry point) ============================= 1128 * 1129 3832 KSENTR EQU $LO+$-LLVSPT 1130 6952 02E0 18 LWPI GPLWS 6954 83E0 1131 6956 C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6958 3A62 1132 695A 06A0 32 BL @SCNKEY Console keyboard scan routine 695C 000E 1133 695E 02E0 18 LWPI UTILWS 6960 3A4C 1134 6962 C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 6964 83F6 1135 6966 0380 18 RTWP 1136 ;]* 1137 * _ _____ ___ __ ____ _ ___ __ _ 1138 * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ 1139 * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< 1140 * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ 1141 * 1142 ;[*== VDP utilities (entry point) ======================================= 1143 * 1144 ** VDP single byte write 1145 * 1146 3848 VSBWEN EQU $LO+$-LLVSPT 1147 6968 06A0 32 BL @WVDPWA Write out address 696A 388E 1148 696C D82D 54 MOVB @2(R13),@VDPWD Write data 696E 0002 6970 8C00 1149 6972 0380 18 RTWP Return to calling program 1150 * 1151 ** VDP multiple byte write 1152 * 1153 3854 VMBWEN EQU $LO+$-LLVSPT 1154 6974 06A0 32 BL @WVDPWA Write out address 6976 388E 1155 6978 D831 48 VWTMOR MOVB *R1+,@VDPWD Write a byte 697A 8C00 1156 697C 0602 14 DEC R2 Decrement byte count 1157 697E 16FC 14 JNE VWTMOR More to write? 1158 6980 0380 18 RTWP Return to calling Program 1159 * 1160 ** VDP single byte read 1161 * 1162 3862 VSBREN EQU $LO+$-LLVSPT 1163 6982 06A0 32 BL @WVDPRA Write out address 6984 3894 1164 6986 DB60 54 MOVB @VDPRD,@2(R13) Read data 6988 8800 698A 0002 1165 698C 0380 18 RTWP Return to calling program 1166 * 1167 ** VDP multiple byte read 1168 * 1169 386E VMBREN EQU $LO+$-LLVSPT 1170 698E 06A0 32 BL @WVDPRA Write out address 6990 3894 1171 6992 DC60 48 VRDMOR MOVB @VDPRD,*R1+ Read a byte 6994 8800 1172 6996 0602 14 DEC R2 Decrement byte count 1173 6998 16FC 14 JNE VRDMOR More to read? 1174 699A 0380 18 RTWP Return to calling program 1175 * 1176 ** VDP write to register 1177 * 1178 387C VWTREN EQU $LO+$-LLVSPT 1179 699C C05D 26 MOV *R13,R1 Get register number and value 1180 699E D82D 54 MOVB @1(R13),@VDPWA Write out value 69A0 0001 69A2 8C02 1181 69A4 0261 22 ORI R1,>8000 Set for register write 69A6 8000 1182 69A8 D801 38 MOVB R1,@VDPWA Write out register number 69AA 8C02 1183 69AC 0380 18 RTWP Return to calling program 1184 * 1185 ** Set up to write to VDP 1186 * 1187 388E WVDPWA EQU $LO+$-LLVSPT 1188 69AE 0201 20 LI R1,>4000 69B0 4000 1189 69B2 1001 14 JMP WVDPAD 1190 * 1191 ** Set up to read VDP 1192 * 1193 3894 WVDPRA EQU $LO+$-LLVSPT 1194 69B4 04C1 14 CLR R1 1195 * 1196 ** Write VDP address 1197 * 1198 69B6 C09D 26 WVDPAD MOV *R13,R2 Get VDP address 1199 69B8 D820 54 MOVB @U_R2LB,@VDPWA Write low byte of address 69BA 3A51 69BC 8C02 1200 69BE E081 18 SOC R1,R2 Properly adjust VDP write bit 1201 69C0 D802 38 MOVB R2,@VDPWA Write high byte of address 69C2 8C02 1202 69C4 C06D 34 MOV @2(R13),R1 Get CPU RAM address 69C6 0002 1203 69C8 C0AD 34 MOV @4(R13),R2 Get byte count 69CA 0004 1204 69CC 045B 20 RT Return to calling routine 1205 1206 * 1207 ** VDP-to-VDP move. 1208 * 1209 38AE VMOVEN EQU $LO+$-LLVSPT 1210 69CE C05D 26 MOV *R13,R1 Get cnt to R1 1211 69D0 C0AD 34 MOV @2(R13),R2 Get vsrc to R2 69D2 0002 1212 69D4 C0ED 34 MOV @4(R13),R3 Get vdst to R3 69D6 0004 1213 69D8 0263 22 ORI R3,>4000 Prepare for VDP write 69DA 4000 1214 1215 ** copy cnt bytes from vsrc to vdst 1216 1217 69DC D820 54 VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address 69DE 3A51 69E0 8C02 1218 69E2 D802 38 MOVB R2,@VDPWA Write MSB of VDP read address 69E4 8C02 1219 69E6 0582 14 INC R2 Next VDP read address 1220 69E8 D020 34 MOVB @VDPRD,R0 Read VDP byte 69EA 8800 1221 69EC D820 54 MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address 69EE 3A53 69F0 8C02 1222 69F2 D803 38 MOVB R3,@VDPWA Write MSB of VDP write address 69F4 8C02 1223 69F6 0583 14 INC R3 Next VDP write address 1224 69F8 D800 38 MOVB R0,@VDPWD Write VDP byte 69FA 8C00 1225 69FC 0601 14 DEC R1 Decrement count 1226 69FE 16EE 14 JNE VMVMOR Repeat if not done 1227 6A00 0380 18 RTWP Return to calling program 1228 ;]* 1229 ;[*== fbForth Version Message =========================================== 1230 38E2 FBFMSG EQU $LO+$-LLVSPT 1231 * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? 1232 * Also, printing the extra blanks overwrites the font-not-found error message. 1233 6A02 11 BYTE 17 1234 6A03 66 TEXT 'fbForth 2.0: ' 6A04 6246 6A06 6F72 6A08 7468 6A0A 2032 6A0C 2E30 6A0E 3A20 6A10 2020 6A12 2020 1235 ;] 1236 * __ ___ ___ ____ __ __ _ __ __ 1237 * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ 1238 * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< 1239 * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ 1240 * 1241 ;[*== Modifiable words in Resident Dictionary =========================== 1242 ;[*** (ABORT) *** 1243 6A14 73CC DATA x#VLST_N <--Last word in ROM 1244 38F6 PABR_N EQU $LO+$-LLVSPT 1245 6A16 8728 DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT 6A18 4142 6A1A 4F52 6A1C 54A9 1246 1247 38FE PABORT EQU $LO+$-LLVSPT 1248 6A1E 8334 DATA DOCOL 1249 6A20 6ADE DATA ABORT,SEMIS 6A22 6358 1250 ;]* 1251 ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] 1252 6A24 38F6 DATA PABR_N 1253 3906 FRTH_N EQU $LO+$-LLVSPT 1254 6A26 C546 DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT 6A28 4F52 6A2A 54C8 1255 1256 390E FORTHV EQU $LO+$-LLVSPT+2 ; vocabulary link field 1257 3910 FORTHP EQU $LO+$-LLVSPT+4 ; pseudo name field 1258 3912 FORTHL EQU $LO+$-LLVSPT+6 ; chronological link field 1259 390C FORTH EQU $LO+$-LLVSPT 1260 6A2C 7218 DATA DOVOC 1261 6A2E A002 DATA DPBASE+2,>81A0,0 ; (may need to modify) 6A30 81A0 6A32 0000 1262 ;]* 1263 ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] 1264 6A34 3906 DATA FRTH_N 1265 3916 ASMR_N EQU $LO+$-LLVSPT 1266 6A36 C941 DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT 6A38 5353 6A3A 454D 6A3C 424C 6A3E 45D2 1267 1268 3922 ASMV EQU $LO+$-LLVSPT+2 ; vocabulary link field 1269 3926 ASML EQU $LO+$-LLVSPT+6 ; chronological link field 1270 3920 ASSM EQU $LO+$-LLVSPT 1271 6A40 7218 DATA DOVOC 1272 6A42 394A DATA SASM_N,>81A0,FORTHL ; <--ASMV initially points to last word in 6A44 81A0 6A46 3912 1273 * ; ...ASSEMBLER vocabulary in the kernel 1274 ;]* 1275 ;]* 1276 * ___ __ __ 1277 * / _ | ___ ___ ___ __ _ / / / /__ ____ 1278 * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ 1279 * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ 1280 * _ __ __ __ _ __ __ 1281 * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ 1282 * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< 1283 * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ 1284 * /___/ 1285 * 1286 *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary 1287 ;[*** NEXT, *** ( --- ) 1288 * 1st word in ASSEMBLER vocabulary 1289 * 1290 6A48 3910 DATA FORTHP <--points to PNF of FORTH 1291 392A NXT__N EQU $LO+$-LLVSPT 1292 6A4A 854E DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT 6A4C 4558 6A4E 54AC 1293 1294 3930 NEXTC EQU $LO+$-LLVSPT 1295 6A50 3932 DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! 1296 6A52 0200 20 NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) 6A54 045F 1297 6A56 C068 34 MOV @$DP(U),R1 HERE to R1 6A58 0012 1298 6A5A CC40 34 MOV R0,*R1+ compile "B *NEXT" 1299 6A5C CA01 38 MOV R1,@$DP(U) update HERE 6A5E 0012 1300 6A60 CA28 54 MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary 6A62 0058 6A64 0056 1301 6A66 045F 20 B *NEXT back to inner interpreter 1302 1303 * : NEXT, ( --- ) 1304 * *NEXT B, ; 1305 ;]* 1306 ;[*** ;ASM *** ( --- ) 1307 * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by 1308 * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. 1309 * 1310 6A68 392A DATA NXT__N 1311 394A SASM_N EQU $LO+$-LLVSPT 1312 6A6A 84 BYTE 4+TERMBT <--note different name field format 1313 6A6B 3B TEXT ';ASM' 6A6C 4153 6A6E 4D 1314 6A6F A0 BYTE ' '+TERMBT 1315 1316 3950 SASM EQU $LO+$-LLVSPT 1317 6A70 3952 DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! 1318 6A72 10EF 14 JMP NXT_P finish up in NEXT, 1319 1320 * : ;ASM ( --- ) 1321 * *NEXT B, ; 1322 ;]* 1323 1324 ;[*== Some Variables (KEYCNT etc.) ====================================== 1325 1326 3954 KEYCNT EQU $LO+$-LLVSPT 1327 6A74 FFFF DATA -1 Used in cursor flash logic 1328 3956 INTACT EQU $LO+$-LLVSPT 1329 6A76 0000 DATA 0 Non-zero during user's interrupt service routine 1330 * 1331 *++ variables used by some graphics primitives 1332 * 1333 3958 $DMODE EQU $LO+$-LLVSPT 1334 6A78 0000 DATA 0 ; actual location of variable contents 1335 395A $DCOL EQU $LO+$-LLVSPT 1336 6A7A FFFF DATA -1 ; actual location of variable contents 1337 1338 *=========================================================== 1339 ;]* 1340 * ______ ___ _____ __ 1341 * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ 1342 * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) 1343 * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ 1344 * /_/ 1345 * 1346 ;[*== Trampoline Code =================================================== 1347 * 1348 * MYBANK must be at same location in all banks with the code that appears 1349 * in the following table. The EQUates for BANK0--BANK3 may also be in the 1350 * same places in each bank for convenience, but they only need to appear once. 1351 * 1352 * Bank Select MYBANK 1353 * ---- ------ ------ 1354 * 0 >6006 >C000 1355 * 1 >6004 >8000 1356 * 2 >6002 >4000 1357 * 3 >6000 >0000 1358 * 1359 * Bank0 code will look like this 1360 * 1361 * MYBANK DATA >C000 1362 * BANK0 EQU >C000 1363 * BANK1 EQU >8000 1364 * BANK2 EQU >4000 1365 * BANK3 EQU >0000 1366 * 1367 * Banks 1--3 will look the same, including labels, and the DATA 1368 * instruction at MYBANK's location will correspond to its bank. 1369 * 1370 * Before a bank is selected, the values above will be shifted right 13 1371 * bits and have >6000 added. 1372 * 1373 ;[*** BLBANK ************************************************************ 1374 * 1375 * General bank branching routine (32KB ROM, i.e., 4 banks) for a 1376 * branch that is expected to return (not high-level Forth) via RTBANK--- 1377 * --put in scratchpad or low RAM 1378 * --called by 1379 * BL @BLBANK 1380 * DATA dst_addr - >6000 + bank# in left 2 bits 1381 * 1382 395C BLBANK EQU $LO+$-LLVSPT 1383 6A7C 064E 14 DECT R ; reserve space on return stack (R14) 1384 6A7E C33B 30 MOV *LINK+,CRU ; copy destination bank address to R12 1385 6A80 C78B 30 MOV LINK,*R ; push return address 1386 6A82 064E 14 DECT R ; reserve space on return stack 1387 6A84 C7A0 46 MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) 6A86 7FFE 1388 6A88 C2CC 18 MOV CRU,LINK ; copy destination bank address to R11 1389 6A8A 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6A8C 1FFF 1390 6A8E 022B 22 AI LINK,>6000 ; make it a real address 6A90 6000 1391 6A92 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1392 6A94 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6A96 6000 1393 6A98 04DC 26 CLR *CRU ; switch to destination bank 1394 6A9A 045B 20 B *LINK ; branch to destination address 1395 ;]* 1396 ;[*** RTBANK ************************************************************ 1397 * 1398 * General bank return routine (32KB ROM, i.e., 4 banks)--- 1399 * --put in scratchpad or low RAM 1400 * --called by 1401 * B @RTBANK 1402 * 1403 397C RTBANK EQU $LO+$-LLVSPT 1404 6A9C C33E 30 MOV *R+,CRU ; pop return bank# from return stack to R12 1405 6A9E 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1406 6AA0 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6AA2 6000 1407 6AA4 C2FE 30 MOV *R+,LINK ; pop return address from return stack 1408 6AA6 04DC 26 CLR *CRU ; switch to destination bank 1409 6AA8 045B 20 B *LINK ; branch to return address 1410 ;]* 1411 ;[*** BLF2A ************************************************************* 1412 * 1413 * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 1414 * banks) that is expected to return to bank0 via RTNEXT. This will 1415 * only(?) be used for the ALC payload of Forth stubs in bank0--- 1416 * --put in scratchpad or low RAM 1417 * --called by 1418 * BL @BLF2A 1419 * DATA dst_addr - >6000 + bank# in left 2 bits 1420 * 1421 398A BLF2A EQU $LO+$-LLVSPT 1422 6AAA C2DB 26 MOV *LINK,LINK ; copy destination bank address to R11 1423 6AAC C30B 18 MOV LINK,CRU ; copy it to R12 1424 6AAE 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6AB0 1FFF 1425 6AB2 022B 22 AI LINK,>6000 ; make it a real address 6AB4 6000 1426 6AB6 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1427 6AB8 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6ABA 6000 1428 6ABC 04DC 26 CLR *CRU ; switch to destination bank 1429 6ABE 045B 20 B *LINK ; branch to destination address 1430 ;]* 1431 ;[*** RTNEXT ************************************************************ 1432 * 1433 * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 1434 * banks)--- 1435 * --put in scratchpad or low RAM 1436 * --called by 1437 * B @RTNEXT 1438 * 1439 39A0 RTNEXT EQU $LO+$-LLVSPT 1440 6AC0 C320 34 MOV @INTACT,CRU Are we in user's ISR? 6AC2 3956 1441 6AC4 1602 14 JNE RTNXT1 Don't enable interrupts if so. 1442 6AC6 0300 24 LIMI 2 6AC8 0002 1443 6ACA 04E0 34 RTNXT1 CLR @>6006 ; switch to bank 0 6ACC 6006 1444 6ACE 045F 20 B *NEXT ; branch to next CFA (in R15) 1445 ;]* 1446 ;[*** BLA2F ************************************************************* 1447 * 1448 * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 1449 * banks) that is expected to return to calling bank via RTA2F--- 1450 * --put in scratchpad or low RAM 1451 * --called by 1452 * BL @BLA2F 1453 * DATA <Forth cfa in bank0> 1454 * 1455 39B0 BLA2F EQU $LO+$-LLVSPT 1456 6AD0 064E 14 DECT R ; reserve space on return stack 1457 6AD2 C2BB 30 MOV *LINK+,W ; move CFA of Forth routine to W 1458 6AD4 C78B 30 MOV LINK,*R ; push return address of calling bank 1459 6AD6 064E 14 DECT R ; reserve space on return stack 1460 6AD8 C7A0 46 MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) 6ADA 7FFE 1461 6ADC 064E 14 DECT R ; reserve spot on return stack 1462 6ADE C78D 30 MOV IP,*R ; move current IP to return stack 1463 6AE0 020D 20 LI IP,RTA2F ; move address of return procedure to IP 6AE2 39CC 1464 6AE4 04E0 34 CLR @>6006 ; switch to bank0 6AE6 6006 1465 6AE8 0460 28 B @DOEXEC ; Execute the Forth routine 6AEA 833C 1466 ;]* 1467 ;[*** RTA2F ************************************************************* 1468 * 1469 * ALC to high-level Forth bank "return" routine from Forth to calling 1470 * ALC (32KB ROM, i.e., 4 banks)--- 1471 * --put in scratchpad or low RAM 1472 * --called through B *NEXT at end of Forth word's execution in BLA2F 1473 * 1474 39CC RTA2F EQU $LO+$-LLVSPT 1475 6AEC 39CE DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) 1476 6AEE 39D0 DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) 1477 6AF0 C37E 30 MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) 1478 * Retrieve ALC return info and return to caller... 1479 * ...caller will execute B *NEXT when it finishes 1480 6AF2 0460 28 B @RTBANK ; branch to general bank return routine above 6AF4 397C 1481 ;]* 1482 ;]*********************************************************************** 1483 ;[*++ Bank-specific cell-/byte-reading code ++* 1484 ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) 1485 *++ Read cell contents of address in Bank bank# or RAM. 1486 *++ Register inputs: 1487 *++ R0: bank-switch address 1488 *++ R1: address in bank# to be read 1489 1490 39D6 _BKAT EQU $LO+$-LLVSPT 1491 6AF6 04D0 26 CLR *R0 ; switch banks 1492 6AF8 C651 38 MOV *R1,*SP ; get cell contents of address to stack 1493 6AFA 0460 28 B @RTNEXT ; return to inner interpreter 6AFC 39A0 1494 ;]* 1495 ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) 1496 *++ Read byte contents of address in Bank bank# or RAM. 1497 *++ Register inputs: 1498 *++ R0: bank-switch address 1499 *++ R1: address in bank# to be read 1500 1501 39DE _BKCAT EQU $LO+$-LLVSPT 1502 6AFE 04D0 26 CLR *R0 ; switch banks 1503 6B00 04C2 14 CLR R2 ; clear R2 1504 6B02 D811 46 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 6B04 8305 1505 6B06 C642 30 MOV R2,*SP ; get byte contents of address to stack 1506 6B08 0460 28 B @RTNEXT ; return to inner interpreter 6B0A 39A0 1507 1508 ;]* 1509 1510 ;]* 1511 * _______ __ _________ ___ __ 1512 * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ 1513 * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / 1514 * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / 1515 * /___/ 1516 * 1517 ;[*** SAMS! *** ( --- ) 1518 * This calls the SAMS initialization in the startup code in bank 1. 1519 * 1520 * DATA SMSQ_N 1521 * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT 1522 * SAMSST DATA $+2 1523 * BL @BLF2A 1524 * DATA _SMSST->6000+BANK1 1525 1526 6B0C 06A0 32 _SMSST BL @SMSINI initialize SAMS card 6B0E 610C 1527 6B10 0460 28 B @RTNEXT back to inner interpreter 6B12 39A0 1528 ;]* 1529 ;[*== Required strings, tables, variables... ============================ 1530 * 1531 * 1532 * Default blocks filename 1533 * 1534 39F4 DEFNAM EQU $LO+$-LLVSPT 1535 6B14 0C BYTE 12 1536 6B15 44 TEXT "DSK1.FBLOCKS " 6B16 534B 6B18 312E 6B1A 4642 6B1C 4C4F 6B1E 434B 6B20 5320 1537 * 1538 * Default colors for all VDP modes--- 1539 * MSB: Screen color (LSN); text FG (MSN), BG (LSN) 1540 * LSB: Color Table colors (FG/BG) 1541 * 1542 3A02 DEFCOL EQU $LO+$-LLVSPT 1543 6B22 4F00 DATA >4F00 ; TEXT80 offset=0 1544 6B24 4F00 DATA >4F00 ; TEXT offset=2 1545 6B26 F4F4 DATA >F4F4 ; GRAPHICS offset=4 1546 6B28 11F4 DATA >11F4 ; MULTI offset=6 1547 6B2A FE10 DATA >FE10 ; GRAPHICS2 offset=8 1548 6B2C FEF4 DATA >FEF4 ; SPLIT offset=10 1549 6B2E FEF4 DATA >FEF4 ; SPLIT2 offset=12 1550 * 1551 * Default text mode 1552 * 1553 3A10 DEFTXT EQU $LO+$-LLVSPT 1554 6B30 0001 DATA >0001 1555 * 1556 * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB 1557 * 1558 3A12 FNTFLG EQU $LO+$-LLVSPT 1559 6B32 0000 DATA 0 ; font flag initially 0 1560 * 1561 * Speech variables needing initial value (more below LLVEND) 1562 * 1563 3A14 SPCSVC EQU $LO+$-LLVSPT 1564 6B34 0000 DATA 0 1565 * 1566 * Sound Table #1 Workspace for sound variables. Only using R0..R4 1567 * 1568 3A16 SND1WS EQU $LO+$-LLVSPT 1569 3A16 SND1ST EQU SND1WS R0 (sound table status) 0=no table; 1=loading sound... 1570 6B36 0000 DATA 0 ...bytes; -1=counting 1571 3A18 SND1DS EQU SND1WS+2 R1 (sound-table byte destination)... 1572 6B38 8400 DATA SOUND ...initialized to sound chip 1573 3A1A SND1AD EQU SND1WS+4 R2 (sound table address) 1574 6B3A 0000 DATA 0 1575 3A1C SND1CT EQU SND1WS+6 R3 (# of sound bytes to load or... 1576 6B3C 0000 DATA 0 ...sound count = seconds * 60) 1577 3A1E SND1SP EQU SND1WS+8 R4 (pointer to top of sound stack) 1578 6B3E 3AE4 DATA SNDST0 initialized to bottom of sound stack 1579 * 1580 * Sound Table #2 Workspace for sound variables. Only using R0..R3 1581 * 1582 3A20 SND2WS EQU $LO+$-LLVSPT 1583 3A20 SND2ST EQU SND2WS R0 (sound table status) 0=no table ; 1=loading sound... 1584 6B40 0000 DATA 0 ...bytes; -1=counting 1585 3A22 SND2DS EQU SND2WS+2 R1 (sound-table byte destination)... 1586 6B42 8400 DATA SOUND ...initialized to sound chip 1587 ;]* 1588 * 1589 * This is the end of low-level support code that gets copied. 1590 * 1591 LLVEND 1592 1593 ;[*== Un-initialized Variables and workspaces... ========================= 1594 * Start of definitions of variables and workspaces that do not need to 1595 * take up space in ROM because they need no initial values. 1596 * 1597 * Sound Table #2 Workspace for sound variables..continued. 1598 * 1599 3A24 SND2AD EQU SND2WS+4 R2 (sound table address) 1600 3A26 SND2CT EQU SND2WS+6 R3 (# of sound bytes to load or... 1601 * ...sound count = seconds * 60) 1602 3A28 SDMUTE EQU SND2WS+8 dummy destination for sound byte 1603 * 1604 * Branch Stack for ISR processing of Speech, 2 Sound Tables and return 1605 * 1606 3A2A BRSTK EQU SDMUTE+2 1607 * 1608 * Speech variables (more above LLVEND) 1609 * 1610 3A32 SSFLAG EQU BRSTK+8 1611 3A34 SPCNT EQU SSFLAG+2 1612 3A36 SPADR EQU SPCNT+2 1613 3A38 BANKSV EQU SPADR+2 1614 3A3A PADSV EQU BANKSV+2 1615 * 1616 * Panel window: height, width and screen position...used by PANEL and SCROLL 1617 * 1618 3A46 PANWIN EQU PADSV+12 panel height, width and screen start 1619 1620 *== Utility Workspace ================================================= 1621 *** General utility workspace registers 1622 3A4C UTILWS EQU PANWIN+6 1623 3A51 U_R2LB EQU UTILWS+5 1624 1625 3A6C LINBUF EQU UTILWS+32 1626 3ABC CURCHR EQU LINBUF+80 1627 1628 *++ variable used by the 40/80-column editor 1629 3ABE OLDCUR EQU CURCHR+2 1630 1631 *++ FILE I/O variables 1632 1633 3AC6 PBADR EQU OLDCUR+8 1634 3AC8 PBBF EQU PBADR+2 1635 3ACA PBVBF EQU PBBF+2 1636 1637 *++ Floating Point Math Library variables 1638 3ACC FPVARS EQU PBVBF+2 1639 1640 *++ SAMS flag 1641 3AE2 SAMSFL EQU FPVARS+22 1642 1643 *++ Bottom of Sound Stack 1644 *++ This location marks the top of the low-level support code. The Sound 1645 *++ Stack grows upward toward the Return Stack by moving the entire stack 1646 *++ up one cell to make room for the next new bottom entry. 1647 3AE4 SNDST0 EQU SAMSFL+2 1648 ;]* ...lee Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 28, 2020 Author Share Posted August 28, 2020 It's only a guess, but I think the AORG followed immediately by BANK could be confusing the move. I assume you didn't include to code to copy the XORG range? Also, how do you know where the end of the XORG range is? I'd attach labels to XORG and AORG, and use those labels as boundaries for the code to copy. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 28, 2020 Share Posted August 28, 2020 (edited) 5 hours ago, ralphb said: It's only a guess, but I think the AORG followed immediately by BANK could be confusing the move. I assume you didn't include to code to copy the XORG range? If I do not follow AORG with BANK, the same thing that happened to DORG is the result. The copy code is in the file that precedes this one and it uses the labels described below. 5 hours ago, ralphb said: Also, how do you know where the end of the XORG range is? I'd attach labels to XORG and AORG, and use those labels as boundaries for the code to copy. The XORG range is bracketed with labels LLVSPT above it and LLVEND below it. Those labels are, in fact, attached to the XORG and AORG directives, respectively (just not visually), because there is no machine code generated between label and directive. Those labels also have proper ROM addresses: LLVSPT = >6140 and LLVEND = >6B44. [EDIT: Actually, I was wrong! LLVSPT was >6140, a proper ROM address, but the symbol list showed LLVEND to have >3A24! More info in a later post.] ...lee Edited August 28, 2020 by Lee Stewart Correction Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 28, 2020 Share Posted August 28, 2020 6 hours ago, Lee Stewart said: Here is the XORGed code: Reveal hidden contents * __ __ __ * / / ___ _ ______/ / ___ _ _____ / / * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / * /____/\___/__,__/ /____/\__/|___/\__/_/ * ____ __ * / __/_ _____ ___ ___ ____/ /_ * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ * /___/\_,_/ .__/ .__/\___/_/ \__/ * /_/ /_/ * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * fbForth--- * * * * Low-level support routines * * * * << Including Trampoline Code, tables & variables: 2606 bytes >> * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * LLVSPT ; <--This is the source copy location for the rest of this code. $BUFF EQU >2010 * 4 I/O buffers below ($LO = >3020) * Change '4' to number of buffers needed and for which there is room. $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers XORG $LO ; calculate destination addresses * _____ ____ __ __ ___________ * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| * ;[*** Interrupt Service ======================================================= * This routine is executed for every interrupt. It processes any pending * speech and souind. It then looks to see whether a user ISR is installed in * ISR. If so, it sets up NEXT for execution of the user ISR. This will work * only if the user has installed an ISR using the following steps in the fol- * lowing order: * * (1) Write an ISR with entry point, say MYISR. * (2) Determine code field address of MYISR with this high-level Forth: * ' MYISR CFA * <<< Maybe need a word to do #3 >>> * (3) Write CFA of MYISR into user variable ISR. * * Steps (2)-(3) in high-level Forth are shown below: * ' MYISR CFA * ISR ! * * <<< Perhaps last step above should be by a word that disables interrupts >>> * * The console ISR branches to the contents of >83C4 because it is non-zero, * with the address, INT1, of the fbForth ISR entry point below (also, the * contents of INTLNK). This means that the console ISR will branch to INT1 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first * process any pending speech and sound. * * If the user's ISR is properly installed, the code that processes the user * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed * from Forth's workspace (MAINWS), the code at INT2 will process the user's * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's * inner interpreter. *** ========================================================================== * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! INT1 LI R0,BRSTK load address of top of Branch Address Stack * * Set up for pending speech * MOV @SPCSVC,*R0 save Speech service address onto Branch Stack JEQ SNDCH1 jump to sound-check if no speech INCT R0 increment Branch Stack * * Set up for pending sound table #1 (ST#1) * SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? JEQ SNDCH2 process speech and sound if needed LI R1,x#PLAYT1 load PLAYT1 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Set up for pending sound table #2 (ST#2) * SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? JEQ PRCSPS process speech and sound if needed LI R1,x#PLAYT2 load PLAYT2 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Process sound stack if both sound tables idle * PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? JNE PRSPS2 nope..skip sound stack processing LWPI SND1WS switch to ST#1 WS CI R4,SNDST0 anything on sound stack? JEQ PRSPS1 no..exit sound stack processing DECT R4 pop sound stack position MOV *R4,R2 get sound table address from sound stack INC R0 kick off sound processing of ST#1 (R0=1) PRSPS1 LWPI GPLWS switch back to GPL WS * * Check for any pending speech and sound * PRSPS2 CI R0,BRSTK any speech or sound to process? JEQ USRISR if not, jump to user ISR processing LI R1,BNKRST yup..load return address MOV R1,*R0 push return address onto Branch Stack * * Process pending speech and sound * MOV @x#MYBANK,@BANKSV save bank at interrupt CLR @>6002 switch to bank 2 for speech & sound services LI R7,BRSTK load top of Branch Stack MOV *R7+,R8 pop speech/sound ISR B *R8 service speech/sound * * Restore interrupted bank * BNKRST ; return point for speech and sound ISRs MOV @BANKSV,R0 restore bank at interrupt SRL R0,13 get the bank# to correct position AI R0,>6000 make it a real bank-switch address CLR *R0 switch to the bank at interrupt * * Process User ISR if defined * USRISR MOV @$ISR+$UVAR,R0 User ISR installed? JEQ INTEX * * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) * is executed from Forth's WS (MAINWS = >8300), which it does at the end of * every CODE word, keyboard scan and one or two other places. * LI R1,INT2 Load entry point, INT2 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) * * The following 2 instructions are copies of the remainder of the console ROM's * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) * because we're not going back there! * INTEX LWPI >83C0 Change to console's ISR WS RTWP Return to caller of console ISR * * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored * before executing user's ISR. INT3 (cleanup routine below) will be inserted * in address list to get us back here for cleanup after user's ISR has finished. * User's ISR is executed at the end of this section just before INT3. * INT2 LIMI 0 Disable interrupts MOVB @>83D4,R0 Get copy of VR01 SRL R0,8 ...to LSB ORI R0,>100 Set up for VR01 ANDI R0,>FFDF Clear VDP-interrupt-enable bit BLWP @VWTR Turn off VDP interrupt LI NEXT,$NEXT Restore NEXT SETO @INTACT Set Forth "pending interrupt" flag DECT R Set up return linkage by pushing MOV IP,*R ...IP (R13, next Forth CFA) to return stack and LI IP,INT3 ...setting IP to INT3 (below) for cleanup MOV @$ISR(U),W Do the user's Forth ISR by executing B @DOEXEC ...it through Forth's inner interpreter * * Clean up and re-enable interrupts. * INT3 DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) MOV *R+,IP Start cleanup: pop IP from before call to user's ISR CLR @INTACT Clear Forth "pending interrupt" flag MOVB @>83D4,R0 Prepare to restore VR01 by... SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and AI R0,>100 ...VR # (01) to MSB MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status BLWP @VWTR Write VR01 LIMI 2 Re-enable interrupts B *NEXT Continue normal task ;]* ;[*** BKLINK from SYSTEM calls ========================================== * BKLINK MOV @INTACT,R7 Are we in user's ISR? JNE BKLIN1 Don't enable interrupts if so. LIMI 2 BKLIN1 B *LINK ;]* * ____ __ _____ ____ * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ * /___/ * ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== * Entry point for low-level system support functions $SYS$ LIMI 0 MOV @SYSTAB(R1),R0 B *R0 ;] ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== DATA BRW CODE = -20 write block to blocks file DATA BRW CODE = -18 read block from blocks file DATA BRW CODE = -16 create blocks file DATA BRW CODE = -14 use blocks file DATA GXY CODE = -12 GOTOXY DATA QKY CODE = -10 ?KEY DATA QTM CODE = -8 ?TERMINAL DATA CLF CODE = -6 CRLF DATA EMT CODE = -4 EMIT DATA KY CODE = -2 KEY SYSTAB DATA SBW CODE = 0 VSBW DATA MBW CODE = 2 VMBW DATA SBR CODE = 4 VSBR DATA MBR CODE = 6 VMBR DATA WTR CODE = 8 VWTR DATA GPL CODE = 10 GPLLNK DATA XML CODE = 12 XMLLNK DATA DSR CODE = 14 DSRLNK DATA CLS$ CODE = 16 CLS DATA MVE CODE = 18 VMOVE DATA FILL$ CODE = 20 VFILL DATA AOX CODE = 22 VAND DATA AOX CODE = 24 VOR DATA AOX CODE = 26 VXOR ;]* ;[*== VDP single byte write. CODE = 0 ================= * SBW MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 Character to write SWPB R1 Get in left byte BLWP @VSBW B @BKLINK ;]* ;[*== VDP multi byte write. CODE = 2 ================= * MBW MOV *SP+,R2 Number of bytes to move MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 RAM address (source) BLWP @VMBW B @BKLINK ;]* ;[*== VDP single byte read. CODE = 4 ================= * SBR MOV *SP,R0 VRAM address (source) BLWP @VSBR SRL R1,8 Character to right half for Forth MOV R1,*SP Stack it B @BKLINK ;]* ;[*== VDP multi byte read. CODE = 6 ================= * MBR MOV *SP+,R2 Number of bytes to read MOV *SP+,R1 RAM address (destination) MOV *SP+,R0 VRAM address (source) BLWP @VMBR B @BKLINK ;]* ;[*== VDP-to-VDP move. CODE = 18 ================= * MVE MOV *SP+,R0 Pop cnt to R0 MOV *SP+,R2 Pop vdst to R2 MOV *SP+,R1 Pop vsrc to R1 BLWP @VMOVE B @BKLINK ;]* ;[*== VDP register write. CODE = 8 ================= * WTR MOV *SP+,R1 VDP register number MOV *SP+,R0 Data for register SWPB R1 Get register to left byte MOVB R1,R0 Place with data BLWP @VWTR B @BKLINK ;]* ;[*== GPL link utility. CODE = 10 ================= * GPL CLR R0 MOVB R0,@KYSTAT LI R0,>0420 Construct the BLWP instruction LI R1,GPLLNK to the GPLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== XML link utility. CODE = 12 ================= * XML LI R0,>0420 Construct the BLWP instruction LI R1,XMLLNK to the XMLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== DSR link utility. CODE = 14 ================= * DSR LI R0,>0420 Construct the BLWP instruction LI R1,DSRLNK to the DSRLNK utility MOV *SP+,R2 This datum selects DSR or subroutine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== Screen clearing utility. CODE = 16 ================= * CLS$ MOV @$SSTRT(U),R2 Beginning of screen in VRAM MOV @$SEND(U),R1 End of screen in VRAM S R2,R1 Screen size LI R0,>2000 Blank character MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== VDP fill routine. CODE = 20 ================= * FILL$ MOV *SP+,R0 Fill character SWPB R0 to left byte MOV *SP+,R1 Fill count MOV *SP+,R2 Address to start VRAM fill MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK *======================================================================== FILL1 ; R0=char, R1=cnt, R2=vaddr ORI R2,>4000 Set bit for VDP write SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time FLOOP MOVB R0,@VDPWD Write a byte DEC R1 JNE FLOOP Not done, fill another B *LINK ;]*====================================================================== * *==== VAND -- VDP byte AND routine. CODE = 22 ================= *==== VOR -- VDP byte OR routine. CODE = 24 ================= ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= * AOX MOV *SP+,R2 VRAM address SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time MOVB @VDPRD,R3 Read byte MOV *SP+,R0 Get data to operate with SWPB R0 to left byte *** Now do requested operation ***************** CI R1,24 JEQ DOOR JGT DOXOR INV R3 These two instructions SZC R3,R0 perform an 'AND' JMP FINAOX DOOR SOC R3,R0 perform 'OR' JMP FINAOX DOXOR XOR R3,R0 perform 'XOR' FINAOX LI R1,1 MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== KEY routine CODE = -2 ================= * KY MOV @$ALTI(U),R0 alternate input device? JEQ KEY0 jump to keyboard input if not * * R0 now points to PAB for alternate input device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to read one byte. * CLR R7 prepare to zero status byte MOVB R7,@KYSTAT zero status byte INC R0 point R0 to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB MOV R0,R1 Set up pointer... AI R1,8 ...to namelength byte of PAB MOV R1,@SUBPTR copy to DSR subroutine name-length pointer MOV R0,R3 save pointer (DSRLNK will trash it!) BLWP @DSRLNK get 1 byte from device DATA >8 MOV R3,R0 restore pointer DECT R0 point to one-byte VRAM buffer in front of PAB BLWP @VSBR read character SRL R1,8 move to LSB MOV R1,R0 copy to return register B @BKLINK return to caller * * Input is comining from the keyboard * KEY0 MOV @KEYCNT,R7 INC R7 JNE KEY1 MOV @CURPO$(U),R0 BLWP @VSBR Read character at cursor position... MOVB R1,@CURCHR ...and save it LI R1,>1E00 Place cursor character on screen BLWP @VSBW * KEY1 BLWP @KSCAN MOVB @KYSTAT,R0 COC @H2000,R0 check status JEQ KEY2 JMP if key was pressed * CI R7,100 No key pressed JNE KEY3 MOVB @CURCHR,R1 JMP KEY5 * KEY3 CI R7,200 JNE KEY4 CLR R7 LI R1,>1E00 Cursor char KEY5 MOV @CURPO$(U),R0 BLWP @VSBW KEY4 MOV R7,@KEYCNT MOV @INTACT,R7 Are we in user's ISR? JNE KEY6 Don't enable interrupts if so. LIMI 2 KEY6 DECT IP This will re-execute KEY B *NEXT KEY2 SETO @KEYCNT Key was pressed MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 B @BKLINK ;]* ;[*== EMIT routine CODE = -4 ================= * EMT MOV R2,R1 copy char to R1 for VSBW MOV @$ALTO(U),R0 alternate output device? JEQ EMIT0 jump to video display output if not * * R0 now points to PAB for alternate output device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to write one byte. * CLR R7 ALTOUT active MOVB R7,@KYSTAT zero status byte DEC R0 point to one-byte VRAM buffer in front of PAB SWPB R1 char to MSB BLWP @VSBW write char to buffer INCT R0 point to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB AI R0,8 Set up pointer to namelength byte of PAB MOV R0,@SUBPTR copy to DSR subroutine name-length pointer BLWP @DSRLNK put 1 byte to device DATA >8 B @BKLINK return to caller * * Output is going to the video display * EMIT0 CI R1,7 Is it a bell? JNE NOTBEL CLR R2 MOVB R2,@KYSTAT BLWP @GPLLNK DATA >0036 Emit error tone JMP EMEXIT * NOTBEL CI R1,8 Is it a backspace? JNE NOTBS LI R1,>2000 MOV @CURPO$(U),R0 BLWP @VSBW JGT DECCUR JMP EMEXIT DECCUR DEC @CURPO$(U) JMP EMEXIT * NOTBS CI R1,>A Is it a line feed? JNE NOTLF MOV @$SEND(U),R7 S @$SWDTH(U),R7 C @CURPO$(U),R7 JHE SCRLL A @$SWDTH(U),@CURPO$(u) JMP EMEXIT SCRLL MOV LINK,R7 BL @SCROLL MOV R7,LINK JMP EMEXIT * *** SCROLLING ROUTINE * SCROLL MOV @$SSTRT(U),R0 VRAM addr LI R1,LINBUF Line buffer MOV @$SWDTH(U),R2 Count A R2,R0 Start at line 2 SCROL1 BLWP @VMBR S R2,R0 One line back to write BLWP @VMBW A R2,R0 Two lines ahead for next read A R2,R0 C R0,@$SEND(U) End of screen? JL SCROL1 MOV R2,R1 Blank bottom row of screen LI R0,>2000 Blank S @$SEND(U),R2 NEG R2 Now contains address of start of last line MOV LINK,R6 BL @FILL1 Write the blanks B *R6 * NOTLF CI R1,>D Is it a carriage return? JNE NOTCR CLR R0 MOV @CURPO$(U),R1 MOV R1,R3 S @$SSTRT(U),R1 Adjusted for screen not at 0 MOV @$SWDTH(U),R2 DIV R2,R0 S R1,R3 MOV R3,@CURPO$(U) JMP EMEXIT * NOTCR SWPB R1 Assume it is a printable character MOV @CURPO$(U),R0 BLWP @VSBW MOV @$SEND(U),R2 DEC R2 C R0,R2 JNE NOTCR1 MOV @$SEND(U),R0 S @$SWDTH(U),R0 Was last char on screen. Scroll MOV R0,@CURPO$(U) JMP SCRLL NOTCR1 INC R0 No scroll necessary MOV R0,@CURPO$(U) * EMEXIT B @BKLINK ;]* ;[*== CRLF routine CODE = -6 ================= * CLF MOV LINK,R5 LI R2,>000D BL @EMT EMT will alter INT mask via B @BKLINK LI R2,>000A LIMI 0 Previous call to EMT altered INT mask BL @EMT MOV R5,LINK B @BKLINK ;]* ;[*== ?TERMINAL routine CODE = -8 ================= * scan for <clear>, <break>, FCTN+4 press * QTM MOV LINK,R5 save return BL @>0020 branch to console's test for <clear> STST R0 store status in R0 JNE QTM2 exit if not <clear> QTM1 BL @>0020 check for <clear> again JEQ QTM1 loop until not <clear> QTM2 MOV R5,LINK restore return ANDI R0,>2000 keep only EQU bit B @BKLINK return to caller ;]* ;[*== ?KEY routine CODE = -10 ================= * QKY BLWP @KSCAN MOVB @KYCHAR,R0 SRL R0,8 CI R0,>00FF JNE QKEY1 CLR R0 QKEY1 B @BKLINK ;]* ;[*== GOTOXY routine CODE = -12 ================= * GXY MPY @$SWDTH(U),R3 A R2,R4 Position within screen A @$SSTRT(U),R4 Add VRAM offset to screen top MOV R4,@CURPO$(U) B @BKLINK ;] * ___ __ __ ____ ______ * / _ )/ /__ ____/ /__ / _/_/_/ __ \ * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / * /____/_/\___/\__/_/\_\ /___/_/ \____/ * *== USE blocks file CODE = -14 ================= *== CREATE blocks file CODE = -16 ================= *== READ block from blocks file CODE = -18 ================= *== WRITE block to blocks file CODE = -20 ================= ;[*== Block File I/O Support ============================================ * * BPTOG utility to toggle one of 2 PABs for block file access * BPTOG MOV @$BPOFF(U),R0 PAB offset to R0 LI R1,70 Toggle amount XOR R0,R1 New offset MOV R1,@$BPOFF(U) Update offset * **xxx** entry point to insure we have correct PAB address BPSET MOV @$DKBUF(U),R0 Get DISK_BUF address A @$BPABS(U),R0 Get BPABS address * A @$BPOFF(U),R0 Add current offset MOV R0,@BFPAB Update current block file's PAB address RT * * CLOSE blocks file * BKCLOS MOV @BFPAB,R0 LI R1,$FCLS Opcode=CLOSE BLWP @VSBW AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Close the file DATA 8 RT Deal with error in caller * * storage area * SVBRET DATA 0 Storage for LINK coming into BRW BFPAB DATA 0 Storage for current blocks file PAB address... * ...will have current PAB on entry * PAB header storage * PABHD BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative * >03=OUTPUT mode + " * >01=UPDATE mode + " * BYTE 2,3: save contents of DISK_BUF here BYTE >80 Record length BYTE >80 Character count of transfer BSS 2 Record number * *** file I/O equates * $FOPN EQU >0000 $FCLS EQU >0100 $FRD EQU >0200 $FWRT EQU >0300 $FRST EQU >0400 $FINP EQU 5 $FOUT EQU 3 $FUPD EQU 1 * *** BRW -- entry point for block read/write routines * BRW MOV LINK,@SVBRET Save LINK address MOV R1,R7 Save CODE {R1 to R7} SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) BL @BPSET Insure correct PAB address in BFPAB (it may have moved) CI R7,4 USE or CREATE? JLT BRW01 No BL @BPTOG Yes...toggle BPOFF & BFPAB MOV @BFPAB,R0 Load PAB address AI R0,9 Set to name length byte CLR R2 MOV *SP+,R1 Pop bfnaddr to R1 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 INC R2 Add 1 to # bytes to copy BLWP @VMBW Copy char count & pathname to PAB * *** set up PAB for OPEN * BRW01 LI R1,$FUPD Opcode=0,mode=update CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? JOP BRW02 No LI R1,$FINP Yes...change mode=input BRW02 MOV R1,@PABHD Put in PAB header MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header CLR R0 MOV R0,@PABHD+6 Set record#=0 MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 Copy first 8 bytes of PAB header BLWP @VMBW Do the copy * *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] * AI R0,9 Address of filename's char count in PAB MOV R0,@SUBPTR Point to-----^^^^ BLWP @DSRLNK Open/create the file DATA 8 JEQ BKERR CI R7,4 READ or WRITE? JLT BRW04 Yes JGT BRWDON No; =USE; we're done * *** write blank records to newly created blocks file [CODE = -16,CREATE] * MOV *SP+,R5 No; = CREATE; pop #blocks from stack SLA R5,3 Convert #blocks to #records MOV R5,R3 Save MOV R5,R4 Set up counter LI R0,$FWRT+$FUPD Set up for WRITE MOV R0,@PABHD Copy to PAB header BRLOOP S R4,R5 Calculate next record MOV R5,@PABHD+6 Copy to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Write one record of blanks DATA 8 JEQ BKERR MOV R3,R5 Get #blocks DEC R4 Count down 1 record JNE BRLOOP Write another record if not done JMP BRWDON We're done * *** prepare for read/write block * BRW04 MOV *SP+,R5 Pop block# to write MOV *SP+,R6 Pop bufaddr DEC R5 Block#-1 SLA R5,3 Convert to starting record# LI R4,8 Load counter for 8 records LI R0,$FWRT+$FUPD Set up for WRITE LI R3,VMBW WRITE vector CI R7,2 Are we writing the block? JEQ BRW05 Yup LI R0,$FRD+$FINP Nope...set up for READ LI R3,VMBR READ vector BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header * * READ/WRITE block routine [CODE = -18/-20] * RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy MOV @$DKBUF(U),R0 VRAM buffer address to R0 MOV R6,R1 RAM buffer to R1 LI R2,128 Bytes to copy CI R7,3 READ? JEQ BRW06 Yup BLWP *R3 Nope...copy record to VRAM * * temporarily use CRU register---it should be OK * BRW06 MOV @BFPAB,CRU PAB address AI CRU,9 Address of filename's char count MOV CRU,@SUBPTR Point to filename's char count BLWP @DSRLNK Read/write one record DATA 8 JEQ BKERR CI R7,2 WRITE? JEQ BRW07 Yup...next record MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) BLWP *R3 Nope...copy record to RAM buffer BRW07 INC R5 Next record in file AI R6,128 Next record to/from block RAM buffer DEC R4 Count down 1 record JNE RWLOOP Read/write another record if not done JMP BRWDON We're done * *** error handling * BKERR MOVB R0,R0 Device error? JEQ BKERR6 Yes, exit with disk error BKERR9 LI R6,9 No, exit with file error JMP BKCLN BKERR8 LI R6,8 Block# <=0! exit with range error JMP BKCLN BKERR6 LI R6,6 BKCLN BL @BKCLOS Close current blocks file; ignore error CI R7,4 USE or CREATE? JLT BKCLN1 No BL @BPTOG Yes...toggle BPOFF & BFPAB BKCLN1 MOV R6,R0 Pass error back to caller JMP BKEXIT BRWDON CLR R6 BL @BKCLOS Close current blocks file JNE BRWDN1 Error? LI R6,9 Yes...assume it was a file error BRWDN1 CI R7,4 (no error)...CREATE? JNE BRWDN2 No...we're done BL @BPTOG Yes...revert to correct blocks file BRWDN2 MOV R6,R0 Error to R0 BKEXIT MOV @SVBRET,LINK Restore LINK B @BKLINK ;] ;[* MSGTYP <<< Support for string typing in various banks >>> * * Called with: BL @MSGTYP * * R4 and R5 are the only registers that will be preserved * ..after a call to EMIT--- * * Input: R4 = Address of length byte of packed string * * We will pass the ASCII value of character to EMIT in R2 without * insuring it is 7 bits wide. * MSGTYP DECT R Push return address MOV LINK,*R ...to Forth return stack CLR R5 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char SWPB R5 Put char count in low byte MTLOOP CLR R2 MOVB *R4+,R2 Copy next char to R2 for EMIT SWPB R2 Put char in low byte LIMI 0 We need to do this because we're calling EMIT directly BL @EMT Call EMIT directly INC @$OUT(U) Increment display line character count DEC R5 Decrement character count for this message JNE MTLOOP Are we done? MOV *R+,LINK Yes. Pop return address RT Return to caller ;] ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) R4$5 MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4,*R5 RT ;] * __ __ _ __ _ __ __ * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ * ___ ___ ____ * / _ \___ / _/__ ___ __/ / /____ * / // / -_) _/ _ `/ // / / __(_-< * /____/\__/_/ \_,_/\_,_/_/\__/___/ ;[*== User Variable defaults ============================================ * UBASE0 BSS 6 BASE OF USER VARIABLES DATA UBASE0 06 USER UCONS$ DATA SPBASE 08 USER S0 DATA RBASE 0A USER R0 { R0$ DATA $UVAR 0C USER U0 DATA SPBASE 0E USER TIB DATA 31 10 USER WIDTH DATA DPBASE 12 USER DP DATA $SYS$ 14 USER SYS$ DATA 0 16 USER CURPOS DATA INT1 18 USER INTLNK DATA 1 1A USER WARNING DATA 64 1C USER C/L$ { CL$ DATA $BUFF 1E USER FIRST$ DATA $LO 20 USER LIMIT$ DATA >0380 22 USER COLTAB Color Table address in VRAM DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM DATA >80 2A USER FPB pushes address of user screen font file PAB * ...that is this relative distance from DISK_BUF DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) DATA 40 30 USER SCRN_WIDTH DATA 0 32 USER SCRN_START DATA 960 34 USER SCRN_END DATA 0 36 USER ISR [Note: This used to be INT1] DATA 0 38 USER ALTIN DATA 0 3A USER ALTOUT DATA 1 3C USER VDPMDE permanent location for VDPMDE DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files * ...that is this relative distance from DISK_BUF DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB * ...always toggled between 0 and 70 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) * 0 = console font via GPLLNK DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. * 0 = Symmetric (default) * !0 = Floored $UVAR BSS >80 USER VARIABLE AREA ;] ;[*== A Constant ==================================================== * H2000 DATA >2000 ;]* * __ ____ _ ___ __ _ __ __ * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ * /___/ * ;[*== Utility Vectors =================================================== * * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK XMLLNK DATA UTILWS,XMLENT ; Link to ROM routines KSCAN DATA UTILWS,KSENTR ; Keyboard scan VSBW DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) VMBW DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) VSBR DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) VMBR DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) VMOVE DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) VWTR DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) ;]* ;[*== XMLENT -- Link to system XML utilities ============================ * XMLENT MOV *R14+,@GPLWS+2 Get argument LWPI GPLWS Select GPL workspace MOV R11,@UTILWS+22 Save GPL return address MOV R1,R2 Make a copy of argument CI R1,>8000 Direct address in ALC? JH XML30 We have the address SRL R1,12 SLA R1,1 SLA R2,4 SRL R2,11 A @XMLTAB(R1),R2 MOV *R2,R2 XML30 BL *R2 LWPI UTILWS Get back to right WS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * ________ __ __ _ ____ __ __ ________ * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * This routine will work with any GROM library slot since it is * * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * * This GPLLNK does NOT require a module to be plugged into the * * GROM port so it will work with the Editor/Assembler, * * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * * It saves and restores the current GROM Address in case you want * * to return back to GROM for Basic or Extended Basic CALL LINKs * * or to return to the loading module. * * * * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * * DATA >34 * * * * NOTES: Do Not REF GPLLNK when using this routine in your code. * * * * 70 Bytes - including the GPLLNK Workspace * *-----------------------------------------------------------------------* * GPLWS (>83E0) is GPL workspace G_R4 EQU GPLWS+8 GPL workspace R4 G_R6 EQU GPLWS+12 GPL workspace R6 * SUBSTK (>8373) is GPL Subroutine stack pointer LDGADR EQU >60 Load & Execute GROM address entry point XTAB27 EQU >200E Low Mem XML table location 27 * ..Will contain XMLRTN at startup GETSTK EQU >166C GPLLNK DATA GLNKWS ; R7 Set up BLWP Vectors DATA GLINK1 ; R8 * RTNADR <---don't think we need this label DATA XMLRTN ; R9 address where GPL XML returns to us... * ...this address will already be in XTAB27,... * ...>200E, so don't really need it here} GXMLAD DATA >176C ; R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) DATA >50 ; R11 Initialized to >50 where PUTSTK address resides GLNKWS EQU $->18 ; GPLLNK's workspace of which only... BSS >08 ; R12-R15 ...registers R7 through R15 are used GLINK1 MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS LWPI GPLWS Load GPL WS BL *R4 Save current GROM Address on stack MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return INCT @SUBSTK Adjust the stack pointer B @LDGADR Execute our GPL Routine XMLRTN MOV @GETSTK,R4 Get GETSTK pointer BL *R4 Restore GROM address off the stack LWPI GLNKWS Load our WS RTWP All Done - Return to Caller ;] * ___ _______ __ _ ____ __ __ ________ * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * (Uses console GROM 0's DSRLNK routine) * * (Do not REF DSRLNK or GPLLNK when using these routines) * * (This DSRLNK will also handle Subprograms and CS1, CS2) * * * * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * * DATA 8 * * * * NOTES: Must be used with a GPLLNK routine * * Returns ERRORs the same as the E/A DSRLNK * * EQ bit set on return if error * * ERROR CODE in caller's MSB of Register 0 on return * * * * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * *-----------------------------------------------------------------------* PUTSTK EQU >50 Push GROM Address to stack pointer TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK NAMLEN EQU >8356 Device name length pointer in VDP PAB VWA EQU >8C02 VDP Write Address location VRD EQU >8800 VDP Read Data byte location G_R4LB EQU >83E9 GPL Workspace R4 Lower byte GSTAT EQU >837C GPL Status byte location DSRLNK DATA DSRWS,DLINK1 Set BLWP Vectors DSRWS ; Start of DSRLNK workspace DR3LB EQU $+7 ; lower byte of DSRLNK workspace R3 DLINK1 MOV R12,R12 R0 Have we already looked up the LINK address? JNE DLINK3 R1 YES! Skip lookup routine *<<-------------------------------------------------------------------------->>* * This section of code is only executed once to find the GROM address * * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * * to indicate that the address is found and to be used as a mask for EQ & CND * *------------------------------------------------------------------------------* LWPI GPLWS R2,R3 else load GPL workspace MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack BL *R4 R6 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector ***les*** Note on above instruction: ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) JMP DLINK2 R11 Jump around R12-R15 DATA 0 R12 contains >2000 flag when set DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address MOV @GETSTK,R5 Take some time & set up GETSTK pointer MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector INCT @DSRADR Adjust it to get past GPL FETCH instruction BL *R5 Restore the GROM address off the stack LWPI DSRWS Reload DSRLNK workspace LI R12,>2000 Set flag to signify DSRLNK address is set *<<-------------------------------------------------------------------------->>* DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK MOV @NAMLEN,R3 Save VDP address of Name Length AI R3,-8 Adjust it to point to PAB Flag byte BLWP @GPLLNK Execute DSR LINK DSRADR BYTE >03 High byte of GPL DSRLNK address DSRAD1 BYTE >00 Lower byte of GPL DSRLNK address *----Error Check & Report to Caller's R0 and EQU bit------------------------- MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag MOVB R3,@VWA Set up MSB of VDP Address for Error Flag SZCB R12,R15 Clear EQ bit for Error Report MOVB @VRD,R3 Get PAB Error Flag SRL R3,5 Adjust it to 0-7 error code MOVB R3,*R13 Put it into Caller's R0 (msb) JNE SETEQ If it's not zero, set EQ bit COC @GSTAT,R12 Else, test CND bit for Link Error (00) JNE DSREND No Error, Just return SETEQ SOCB R12,R15 Error, so set Caller's EQ bit DSREND RTWP All Done - Return to Caller ;] ;[*== KSENTR -- Keyboard Scan (entry point) ============================= * KSENTR LWPI GPLWS MOV R11,@UTILWS+22 Save GPL return address BL @SCNKEY Console keyboard scan routine LWPI UTILWS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * _ _____ ___ __ ____ _ ___ __ _ * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ * ;[*== VDP utilities (entry point) ======================================= * ** VDP single byte write * VSBWEN BL @WVDPWA Write out address MOVB @2(R13),@VDPWD Write data RTWP Return to calling program * ** VDP multiple byte write * VMBWEN BL @WVDPWA Write out address VWTMOR MOVB *R1+,@VDPWD Write a byte DEC R2 Decrement byte count JNE VWTMOR More to write? RTWP Return to calling Program * ** VDP single byte read * VSBREN BL @WVDPRA Write out address MOVB @VDPRD,@2(R13) Read data RTWP Return to calling program * ** VDP multiple byte read * VMBREN BL @WVDPRA Write out address VRDMOR MOVB @VDPRD,*R1+ Read a byte DEC R2 Decrement byte count JNE VRDMOR More to read? RTWP Return to calling program * ** VDP write to register * VWTREN MOV *R13,R1 Get register number and value MOVB @1(R13),@VDPWA Write out value ORI R1,>8000 Set for register write MOVB R1,@VDPWA Write out register number RTWP Return to calling program * ** Set up to write to VDP * WVDPWA LI R1,>4000 JMP WVDPAD * ** Set up to read VDP * WVDPRA CLR R1 * ** Write VDP address * WVDPAD MOV *R13,R2 Get VDP address MOVB @U_R2LB,@VDPWA Write low byte of address SOC R1,R2 Properly adjust VDP write bit MOVB R2,@VDPWA Write high byte of address MOV @2(R13),R1 Get CPU RAM address MOV @4(R13),R2 Get byte count RT Return to calling routine * ** VDP-to-VDP move. * VMOVEN MOV *R13,R1 Get cnt to R1 MOV @2(R13),R2 Get vsrc to R2 MOV @4(R13),R3 Get vdst to R3 ORI R3,>4000 Prepare for VDP write ** copy cnt bytes from vsrc to vdst VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address MOVB R2,@VDPWA Write MSB of VDP read address INC R2 Next VDP read address MOVB @VDPRD,R0 Read VDP byte MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address MOVB R3,@VDPWA Write MSB of VDP write address INC R3 Next VDP write address MOVB R0,@VDPWD Write VDP byte DEC R1 Decrement count JNE VMVMOR Repeat if not done RTWP Return to calling program ;]* ;[*== fbForth Version Message =========================================== FBFMSG * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? * Also, printing the extra blanks overwrites the font-not-found error message. BYTE 17 TEXT 'fbForth 2.0: ' ;] * __ ___ ___ ____ __ __ _ __ __ * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ * ;[*== Modifiable words in Resident Dictionary =========================== ;[*** (ABORT) *** DATA x#VLST_N <--Last word in ROM PABR_N DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT PABORT DATA DOCOL DATA ABORT,SEMIS ;]* ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] DATA PABR_N FRTH_N DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT FORTH DATA DOVOC FORTHV DATA DPBASE+2 ; vocabulary link field FORTHP DATA >81A0 ; pseudo name field FORTHL DATA 0 ; chronological link field ;]* ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] DATA FRTH_N ASMR_N DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT ASSM DATA DOVOC ; Initially points to last word in ASSEMBLER vocabulary in the kernel ASMV DATA SASM_N ; vocabulary link field DATA >81A0 ; pseudo name field ASML DATA FORTHL ; chronological link field * ;]* ;]* * ___ __ __ * / _ | ___ ___ ___ __ _ / / / /__ ____ * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ * _ __ __ __ _ __ __ * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ * /___/ * *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary ;[*** NEXT, *** ( --- ) * 1st word in ASSEMBLER vocabulary * DATA FORTHP <--points to PNF of FORTH NXT__N DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT NEXTC DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) MOV @$DP(U),R1 HERE to R1 MOV R0,*R1+ compile "B *NEXT" MOV R1,@$DP(U) update HERE MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary B *NEXT back to inner interpreter * : NEXT, ( --- ) * *NEXT B, ; ;]* ;[*** ;ASM *** ( --- ) * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. * DATA NXT__N SASM_N BYTE 4+TERMBT <--note different name field format TEXT ';ASM' BYTE ' '+TERMBT SASM DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! JMP NXT_P finish up in NEXT, * : ;ASM ( --- ) * *NEXT B, ; ;]* ;[*== Some Variables (KEYCNT etc.) ====================================== KEYCNT DATA -1 Used in cursor flash logic INTACT DATA 0 Non-zero during user's interrupt service routine * *++ variables used by some graphics primitives * $DMODE DATA 0 ; actual location of variable contents $DCOL DATA -1 ; actual location of variable contents *=========================================================== ;]* * ______ ___ _____ __ * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ * /_/ * ;[*== Trampoline Code =================================================== * * MYBANK must be at same location in all banks with the code that appears * in the following table. The EQUates for BANK0--BANK3 may also be in the * same places in each bank for convenience, but they only need to appear once. * * Bank Select MYBANK * ---- ------ ------ * 0 >6006 >C000 * 1 >6004 >8000 * 2 >6002 >4000 * 3 >6000 >0000 * * Bank0 code will look like this * * MYBANK DATA >C000 * BANK0 EQU >C000 * BANK1 EQU >8000 * BANK2 EQU >4000 * BANK3 EQU >0000 * * Banks 1--3 will look the same, including labels, and the DATA * instruction at MYBANK's location will correspond to its bank. * * Before a bank is selected, the values above will be shifted right 13 * bits and have >6000 added. * ;[*** BLBANK ************************************************************ * * General bank branching routine (32KB ROM, i.e., 4 banks) for a * branch that is expected to return (not high-level Forth) via RTBANK--- * --put in scratchpad or low RAM * --called by * BL @BLBANK * DATA dst_addr - >6000 + bank# in left 2 bits * BLBANK DECT R ; reserve space on return stack (R14) MOV *LINK+,CRU ; copy destination bank address to R12 MOV LINK,*R ; push return address DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) MOV CRU,LINK ; copy destination bank address to R11 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTBANK ************************************************************ * * General bank return routine (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called by * B @RTBANK * RTBANK MOV *R+,CRU ; pop return bank# from return stack to R12 SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address MOV *R+,LINK ; pop return address from return stack CLR *CRU ; switch to destination bank B *LINK ; branch to return address ;]* ;[*** BLF2A ************************************************************* * * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to bank0 via RTNEXT. This will * only(?) be used for the ALC payload of Forth stubs in bank0--- * --put in scratchpad or low RAM * --called by * BL @BLF2A * DATA dst_addr - >6000 + bank# in left 2 bits * BLF2A MOV *LINK,LINK ; copy destination bank address to R11 MOV LINK,CRU ; copy it to R12 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTNEXT ************************************************************ * * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 * banks)--- * --put in scratchpad or low RAM * --called by * B @RTNEXT * RTNEXT MOV @INTACT,CRU Are we in user's ISR? JNE RTNXT1 Don't enable interrupts if so. LIMI 2 RTNXT1 CLR @>6006 ; switch to bank 0 B *NEXT ; branch to next CFA (in R15) ;]* ;[*** BLA2F ************************************************************* * * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to calling bank via RTA2F--- * --put in scratchpad or low RAM * --called by * BL @BLA2F * DATA <Forth cfa in bank0> * BLA2F DECT R ; reserve space on return stack MOV *LINK+,W ; move CFA of Forth routine to W MOV LINK,*R ; push return address of calling bank DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) DECT R ; reserve spot on return stack MOV IP,*R ; move current IP to return stack LI IP,RTA2F ; move address of return procedure to IP CLR @>6006 ; switch to bank0 B @DOEXEC ; Execute the Forth routine ;]* ;[*** RTA2F ************************************************************* * * ALC to high-level Forth bank "return" routine from Forth to calling * ALC (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called through B *NEXT at end of Forth word's execution in BLA2F * RTA2F DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) * Retrieve ALC return info and return to caller... * ...caller will execute B *NEXT when it finishes B @RTBANK ; branch to general bank return routine above ;]* ;]*********************************************************************** ;[*++ Bank-specific cell-/byte-reading code ++* ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) *++ Read cell contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKAT CLR *R0 ; switch banks MOV *R1,*SP ; get cell contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) *++ Read byte contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKCAT CLR *R0 ; switch banks CLR R2 ; clear R2 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 MOV R2,*SP ; get byte contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;]* * _______ __ _________ ___ __ * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / * /___/ * ;[*** SAMS! *** ( --- ) * This calls the SAMS initialization in the startup code in bank 1. * * DATA SMSQ_N * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT * SAMSST DATA $+2 * BL @BLF2A * DATA _SMSST->6000+BANK1 _SMSST BL @SMSINI initialize SAMS card B @RTNEXT back to inner interpreter ;]* ;[*== Required strings, tables, variables... ============================ * * * Default blocks filename * DEFNAM BYTE 12 TEXT "DSK1.FBLOCKS " * * Default colors for all VDP modes--- * MSB: Screen color (LSN); text FG (MSN), BG (LSN) * LSB: Color Table colors (FG/BG) * DEFCOL DATA >4F00 ; TEXT80 offset=0 DATA >4F00 ; TEXT offset=2 DATA >F4F4 ; GRAPHICS offset=4 DATA >11F4 ; MULTI offset=6 DATA >FE10 ; GRAPHICS2 offset=8 DATA >FEF4 ; SPLIT offset=10 DATA >FEF4 ; SPLIT2 offset=12 * * Default text mode * DEFTXT DATA >0001 * * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB * FNTFLG DATA 0 ; font flag initially 0 * * Speech variables needing initial value (more below LLVEND) * SPCSVC DATA 0 * * Sound Table #1 Workspace for sound variables. Only using R0..R4 * SND1WS SND1ST DATA 0 ; R0 (sound table status) 0=no table.. ; ..1=loading sound bytes..-1=counting SND1DS DATA SOUND ; R1 (sound-table byte destination).. ; ..initialized to sound chip SND1AD DATA 0 ; R2 (sound table address) SND1CT DATA 0 ; R3 (# of sound bytes to load or.. ; ..sound count = seconds * 60) SND1SP DATA SNDST0 ; R4 (pointer to top of sound stack).. ; ..initialized to bottom of sound stack * * Sound Table #2 Workspace for sound variables. Only using R0..R3 * SND2WS SND2ST DATA 0 ; R0 (sound table status) 0=no table.. ; ..1=loading sound bytes..-1=counting SND2DS DATA SOUND ; R1 (sound-table byte destination) init to sound chip ;]* * * This is the end of low-level support code that gets copied. * LLVEND ;[*== Un-initialized Variables and workspaces... ========================= * Start of definitions of variables and workspaces that do not need to * take up space in ROM because they need no initial values. * * Sound Table #2 Workspace for sound variables..continued. * SND2AD EQU SND2WS+4 ; R2 (sound table address) SND2CT EQU SND2WS+6 ; R3 (# of sound bytes to load or.. * ; ..sound count = seconds * 60) SDMUTE EQU SND2WS+8 ; dummy destination for sound byte * * Branch Stack for ISR processing of Speech, 2 Sound Tables and return * BRSTK EQU SDMUTE+2 * * Speech variables (more above LLVEND) * SSFLAG EQU BRSTK+8 SPCNT EQU SSFLAG+2 SPADR EQU SPCNT+2 BANKSV EQU SPADR+2 PADSV EQU BANKSV+2 * * Panel window: height, width and screen position...used by PANEL and SCROLL * PANWIN EQU PADSV+12 panel height, width and screen start *== Utility Workspace ================================================= *** General utility workspace registers UTILWS EQU PANWIN+6 U_R2LB EQU UTILWS+5 LINBUF EQU UTILWS+32 CURCHR EQU LINBUF+80 *++ variable used by the 40/80-column editor OLDCUR EQU CURCHR+2 *++ FILE I/O variables PBADR EQU OLDCUR+8 PBBF EQU PBADR+2 PBVBF EQU PBBF+2 *++ Floating Point Math Library variables FPVARS EQU PBVBF+2 *++ SAMS flag SAMSFL EQU FPVARS+22 *++ Bottom of Sound Stack *++ This location marks the top of the low-level support code. The Sound *++ Stack grows upward toward the Return Stack by moving the entire stack *++ up one cell to make room for the next new bottom entry. SNDST0 EQU SAMSFL+2 ;]* AORG BANK 1 and its listing: Reveal hidden contents **** **** > fbForth101_LowLevelSupport.a99 0001 * __ __ __ 0002 * / / ___ _ ______/ / ___ _ _____ / / 0003 * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / 0004 * /____/\___/__,__/ /____/\__/|___/\__/_/ 0005 * ____ __ 0006 * / __/_ _____ ___ ___ ____/ /_ 0007 * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ 0008 * /___/\_,_/ .__/ .__/\___/_/ \__/ 0009 * /_/ /_/ 0010 * 0011 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0012 * * 0013 * fbForth--- * 0014 * * 0015 * Low-level support routines * 0016 * * 0017 * << Including Trampoline Code, tables & variables: 2606 bytes >> * 0018 * * 0019 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0020 0021 LLVSPT ; <--This is the source copy location for the rest of this code. 0022 0023 2010 $BUFF EQU >2010 0024 0025 * 4 I/O buffers below ($LO = >3020) 0026 * Change '4' to number of buffers needed and for which there is room. 0027 0028 3020 $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers 0029 0030 XORG $LO ; calculate destination addresses 0031 0032 * _____ ____ __ __ ___________ 0033 * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ 0034 * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ 0035 * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| 0036 * 0037 ;[*** Interrupt Service ======================================================= 0038 * This routine is executed for every interrupt. It processes any pending 0039 * speech and souind. It then looks to see whether a user ISR is installed in 0040 * ISR. If so, it sets up NEXT for execution of the user ISR. This will work 0041 * only if the user has installed an ISR using the following steps in the fol- 0042 * lowing order: 0043 * 0044 * (1) Write an ISR with entry point, say MYISR. 0045 * (2) Determine code field address of MYISR with this high-level Forth: 0046 * ' MYISR CFA 0047 * <<< Maybe need a word to do #3 >>> 0048 * (3) Write CFA of MYISR into user variable ISR. 0049 * 0050 * Steps (2)-(3) in high-level Forth are shown below: 0051 * ' MYISR CFA 0052 * ISR ! 0053 * 0054 * <<< Perhaps last step above should be by a word that disables interrupts >>> 0055 * 0056 * The console ISR branches to the contents of >83C4 because it is non-zero, 0057 * with the address, INT1, of the fbForth ISR entry point below (also, the 0058 * contents of INTLNK). This means that the console ISR will branch to INT1 0059 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first 0060 * process any pending speech and sound. 0061 * 0062 * If the user's ISR is properly installed, the code that processes the user 0063 * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed 0064 * from Forth's workspace (MAINWS), the code at INT2 will process the user's 0065 * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's 0066 * inner interpreter. 0067 *** ========================================================================== 0068 0069 * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! 0070 0071 INT1 0072 6140 0200 20 LI R0,BRSTK load address of top of Branch Address Stack 6142 3A2A 0073 * 0074 * Set up for pending speech 0075 * 0076 6144 C420 46 MOV @SPCSVC,*R0 save Speech service address onto Branch Stack 6146 3A14 0077 6148 1301 14 JEQ SNDCH1 jump to sound-check if no speech 0078 614A 05C0 14 INCT R0 increment Branch Stack 0079 * 0080 * Set up for pending sound table #1 (ST#1) 0081 * 0082 614C C0A0 34 SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? 614E 3A16 0083 6150 1303 14 JEQ SNDCH2 process speech and sound if needed 0084 6152 0201 20 LI R1,x#PLAYT1 load PLAYT1 address and... 6154 7C68 0085 6156 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0086 * 0087 * Set up for pending sound table #2 (ST#2) 0088 * 0089 6158 C0E0 34 SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? 615A 3A20 0090 615C 1303 14 JEQ PRCSPS process speech and sound if needed 0091 615E 0201 20 LI R1,x#PLAYT2 load PLAYT2 address and... 6160 7C6E 0092 6162 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0093 * 0094 * Process sound stack if both sound tables idle 0095 * 0096 6164 E0C2 18 PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? 0097 6166 160A 14 JNE PRSPS2 nope..skip sound stack processing 0098 6168 02E0 18 LWPI SND1WS switch to ST#1 WS 616A 3A16 0099 616C 0284 22 CI R4,SNDST0 anything on sound stack? 616E 3AE4 0100 6170 1303 14 JEQ PRSPS1 no..exit sound stack processing 0101 6172 0644 14 DECT R4 pop sound stack position 0102 6174 C094 26 MOV *R4,R2 get sound table address from sound stack 0103 6176 0580 14 INC R0 kick off sound processing of ST#1 (R0=1) 0104 6178 02E0 18 PRSPS1 LWPI GPLWS switch back to GPL WS 617A 83E0 0105 * 0106 * Check for any pending speech and sound 0107 * 0108 617C 0280 22 PRSPS2 CI R0,BRSTK any speech or sound to process? 617E 3A2A 0109 6180 1312 14 JEQ USRISR if not, jump to user ISR processing 0110 6182 0201 20 LI R1,BNKRST yup..load return address 6184 307A 0111 6186 C401 30 MOV R1,*R0 push return address onto Branch Stack 0112 * 0113 * Process pending speech and sound 0114 * 0115 6188 C820 54 MOV @x#MYBANK,@BANKSV save bank at interrupt 618A 7FFE 618C 3A38 0116 618E 04E0 34 CLR @>6002 switch to bank 2 for speech & sound services 6190 6002 0117 6192 0207 20 LI R7,BRSTK load top of Branch Stack 6194 3A2A 0118 6196 C237 30 MOV *R7+,R8 pop speech/sound ISR 0119 6198 0458 20 B *R8 service speech/sound 0120 * 0121 * Restore interrupted bank 0122 * 0123 BNKRST ; return point for speech and sound ISRs 0124 619A C020 34 MOV @BANKSV,R0 restore bank at interrupt 619C 3A38 0125 619E 09D0 56 SRL R0,13 get the bank# to correct position 0126 61A0 0220 22 AI R0,>6000 make it a real bank-switch address 61A2 6000 0127 61A4 04D0 26 CLR *R0 switch to the bank at interrupt 0128 * 0129 * Process User ISR if defined 0130 * 0131 61A6 C020 34 USRISR MOV @$ISR+$UVAR,R0 User ISR installed? 61A8 36EA 0132 61AA 1304 14 JEQ INTEX 0133 * 0134 * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) 0135 * is executed from Forth's WS (MAINWS = >8300), which it does at the end of 0136 * every CODE word, keyboard scan and one or two other places. 0137 * 0138 61AC 0201 20 LI R1,INT2 Load entry point, INT2 61AE 309A 0139 61B0 C801 38 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) 61B2 831E 0140 * 0141 * The following 2 instructions are copies of the remainder of the console ROM's 0142 * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) 0143 * because we're not going back there! 0144 * 0145 61B4 02E0 18 INTEX LWPI >83C0 Change to console's ISR WS 61B6 83C0 0146 61B8 0380 18 RTWP Return to caller of console ISR 0147 * 0148 * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored 0149 * before executing user's ISR. INT3 (cleanup routine below) will be inserted 0150 * in address list to get us back here for cleanup after user's ISR has finished. 0151 * User's ISR is executed at the end of this section just before INT3. 0152 * 0153 61BA 0300 24 INT2 LIMI 0 Disable interrupts 61BC 0000 0154 61BE D020 34 MOVB @>83D4,R0 Get copy of VR01 61C0 83D4 0155 61C2 0980 56 SRL R0,8 ...to LSB 0156 61C4 0260 22 ORI R0,>100 Set up for VR01 61C6 0100 0157 61C8 0240 22 ANDI R0,>FFDF Clear VDP-interrupt-enable bit 61CA FFDF 0158 61CC 0420 54 BLWP @VWTR Turn off VDP interrupt 61CE 3752 0159 61D0 020F 20 LI NEXT,$NEXT Restore NEXT 61D2 833A 0160 61D4 0720 34 SETO @INTACT Set Forth "pending interrupt" flag 61D6 3956 0161 61D8 064E 14 DECT R Set up return linkage by pushing 0162 61DA C78D 30 MOV IP,*R ...IP (R13, next Forth CFA) to return stack and 0163 61DC 020D 20 LI IP,INT3 ...setting IP to INT3 (below) for cleanup 61DE 30C8 0164 61E0 C2A8 34 MOV @$ISR(U),W Do the user's Forth ISR by executing 61E2 0036 0165 61E4 0460 28 B @DOEXEC ...it through Forth's inner interpreter 61E6 833C 0166 * 0167 * Clean up and re-enable interrupts. 0168 * 0169 61E8 30CA INT3 DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) 0170 61EA 30CC DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) 0171 61EC C37E 30 MOV *R+,IP Start cleanup: pop IP from before call to user's ISR 0172 61EE 04E0 34 CLR @INTACT Clear Forth "pending interrupt" flag 61F0 3956 0173 61F2 D020 34 MOVB @>83D4,R0 Prepare to restore VR01 by... 61F4 83D4 0174 61F6 0980 56 SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and 0175 61F8 0220 22 AI R0,>100 ...VR # (01) to MSB 61FA 0100 0176 61FC D060 34 MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status 61FE 8802 0177 6200 0420 54 BLWP @VWTR Write VR01 6202 3752 0178 6204 0300 24 LIMI 2 Re-enable interrupts 6206 0002 0179 6208 045F 20 B *NEXT Continue normal task 0180 ;]* 0181 ;[*** BKLINK from SYSTEM calls ========================================== 0182 * 0183 620A C1E0 34 BKLINK MOV @INTACT,R7 Are we in user's ISR? 620C 3956 0184 620E 1602 14 JNE BKLIN1 Don't enable interrupts if so. 0185 6210 0300 24 LIMI 2 6212 0002 0186 6214 045B 20 BKLIN1 B *LINK 0187 ;]* 0188 * ____ __ _____ ____ 0189 * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ 0190 * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< 0191 * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ 0192 * /___/ 0193 * 0194 ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== 0195 0196 * Entry point for low-level system support functions 0197 0198 6216 0300 24 $SYS$ LIMI 0 6218 0000 0199 621A C021 34 MOV @SYSTAB(R1),R0 621C 3114 0200 621E 0450 20 B *R0 0201 ;] 0202 ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== 0203 0204 6220 34C6 DATA BRW CODE = -20 write block to blocks file 0205 6222 34C6 DATA BRW CODE = -18 read block from blocks file 0206 6224 34C6 DATA BRW CODE = -16 create blocks file 0207 6226 34C6 DATA BRW CODE = -14 use blocks file 0208 6228 346C DATA GXY CODE = -12 GOTOXY 0209 622A 3456 DATA QKY CODE = -10 ?KEY 0210 622C 343C DATA QTM CODE = -8 ?TERMINAL 0211 622E 3420 DATA CLF CODE = -6 CRLF 0212 6230 3312 DATA EMT CODE = -4 EMIT 0213 6232 3260 DATA KY CODE = -2 KEY 0214 6234 3130 SYSTAB DATA SBW CODE = 0 VSBW 0215 6236 313E DATA MBW CODE = 2 VMBW 0216 6238 314C DATA SBR CODE = 4 VSBR 0217 623A 315A DATA MBR CODE = 6 VMBR 0218 623C 3176 DATA WTR CODE = 8 VWTR 0219 623E 3186 DATA GPL CODE = 10 GPLLNK 0220 6240 31A6 DATA XML CODE = 12 XMLLNK 0221 6242 31C0 DATA DSR CODE = 14 DSRLNK 0222 6244 31DA DATA CLS$ CODE = 16 CLS 0223 6246 3168 DATA MVE CODE = 18 VMOVE 0224 6248 31F4 DATA FILL$ CODE = 20 VFILL 0225 624A 3224 DATA AOX CODE = 22 VAND 0226 624C 3224 DATA AOX CODE = 24 VOR 0227 624E 3224 DATA AOX CODE = 26 VXOR 0228 ;]* 0229 ;[*== VDP single byte write. CODE = 0 ================= 0230 * 0231 6250 C039 30 SBW MOV *SP+,R0 VRAM address (destination) 0232 6252 C079 30 MOV *SP+,R1 Character to write 0233 6254 06C1 14 SWPB R1 Get in left byte 0234 6256 0420 54 BLWP @VSBW 6258 373E 0235 625A 0460 28 B @BKLINK 625C 30EA 0236 ;]* 0237 ;[*== VDP multi byte write. CODE = 2 ================= 0238 * 0239 625E C0B9 30 MBW MOV *SP+,R2 Number of bytes to move 0240 6260 C039 30 MOV *SP+,R0 VRAM address (destination) 0241 6262 C079 30 MOV *SP+,R1 RAM address (source) 0242 6264 0420 54 BLWP @VMBW 6266 3742 0243 6268 0460 28 B @BKLINK 626A 30EA 0244 ;]* 0245 ;[*== VDP single byte read. CODE = 4 ================= 0246 * 0247 626C C019 26 SBR MOV *SP,R0 VRAM address (source) 0248 626E 0420 54 BLWP @VSBR 6270 3746 0249 6272 0981 56 SRL R1,8 Character to right half for Forth 0250 6274 C641 30 MOV R1,*SP Stack it 0251 6276 0460 28 B @BKLINK 6278 30EA 0252 ;]* 0253 ;[*== VDP multi byte read. CODE = 6 ================= 0254 * 0255 627A C0B9 30 MBR MOV *SP+,R2 Number of bytes to read 0256 627C C079 30 MOV *SP+,R1 RAM address (destination) 0257 627E C039 30 MOV *SP+,R0 VRAM address (source) 0258 6280 0420 54 BLWP @VMBR 6282 374A 0259 6284 0460 28 B @BKLINK 6286 30EA 0260 ;]* 0261 ;[*== VDP-to-VDP move. CODE = 18 ================= 0262 * 0263 6288 C039 30 MVE MOV *SP+,R0 Pop cnt to R0 0264 628A C0B9 30 MOV *SP+,R2 Pop vdst to R2 0265 628C C079 30 MOV *SP+,R1 Pop vsrc to R1 0266 628E 0420 54 BLWP @VMOVE 6290 374E 0267 6292 0460 28 B @BKLINK 6294 30EA 0268 ;]* 0269 ;[*== VDP register write. CODE = 8 ================= 0270 * 0271 6296 C079 30 WTR MOV *SP+,R1 VDP register number 0272 6298 C039 30 MOV *SP+,R0 Data for register 0273 629A 06C1 14 SWPB R1 Get register to left byte 0274 629C D001 18 MOVB R1,R0 Place with data 0275 629E 0420 54 BLWP @VWTR 62A0 3752 0276 62A2 0460 28 B @BKLINK 62A4 30EA 0277 ;]* 0278 ;[*== GPL link utility. CODE = 10 ================= 0279 * 0280 62A6 04C0 14 GPL CLR R0 0281 62A8 D800 38 MOVB R0,@KYSTAT 62AA 837C 0282 62AC 0200 20 LI R0,>0420 Construct the BLWP instruction 62AE 0420 0283 62B0 0201 20 LI R1,GPLLNK to the GPLLNK utility 62B2 3784 0284 62B4 C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0285 62B6 0203 20 LI R3,>045B Construct the B *LINK instruction 62B8 045B 0286 62BA C10B 18 MOV LINK,R4 Save LINK address 0287 62BC 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62BE 8300 0288 62C0 C2C4 18 MOV R4,LINK and reconstruct LINK 0289 62C2 0460 28 B @BKLINK 62C4 30EA 0290 ;]* 0291 ;[*== XML link utility. CODE = 12 ================= 0292 * 0293 62C6 0200 20 XML LI R0,>0420 Construct the BLWP instruction 62C8 0420 0294 62CA 0201 20 LI R1,XMLLNK to the XMLLNK utility 62CC 3736 0295 62CE C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0296 62D0 0203 20 LI R3,>045B Construct the B *LINK instruction 62D2 045B 0297 62D4 C10B 18 MOV LINK,R4 Save LINK address 0298 62D6 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62D8 8300 0299 62DA C2C4 18 MOV R4,LINK and reconstruct LINK 0300 62DC 0460 28 B @BKLINK 62DE 30EA 0301 ;]* 0302 ;[*== DSR link utility. CODE = 14 ================= 0303 * 0304 62E0 0200 20 DSR LI R0,>0420 Construct the BLWP instruction 62E2 0420 0305 62E4 0201 20 LI R1,DSRLNK to the DSRLNK utility 62E6 37BE 0306 62E8 C0B9 30 MOV *SP+,R2 This datum selects DSR or subroutine 0307 62EA 0203 20 LI R3,>045B Construct the B *LINK instruction 62EC 045B 0308 62EE C10B 18 MOV LINK,R4 Save LINK address 0309 62F0 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62F2 8300 0310 62F4 C2C4 18 MOV R4,LINK and reconstruct LINK 0311 62F6 0460 28 B @BKLINK 62F8 30EA 0312 ;]* 0313 ;[*== Screen clearing utility. CODE = 16 ================= 0314 * 0315 62FA C0A8 34 CLS$ MOV @$SSTRT(U),R2 Beginning of screen in VRAM 62FC 0032 0316 62FE C068 34 MOV @$SEND(U),R1 End of screen in VRAM 6300 0034 0317 6302 6042 18 S R2,R1 Screen size 0318 6304 0200 20 LI R0,>2000 Blank character 6306 2000 0319 6308 C1CB 18 MOV LINK,R7 0320 630A 06A0 32 BL @FILL1 630C 3208 0321 630E C2C7 18 MOV R7,LINK 0322 6310 0460 28 B @BKLINK 6312 30EA 0323 ;]* 0324 ;[*== VDP fill routine. CODE = 20 ================= 0325 * 0326 6314 C039 30 FILL$ MOV *SP+,R0 Fill character 0327 6316 06C0 14 SWPB R0 to left byte 0328 6318 C079 30 MOV *SP+,R1 Fill count 0329 631A C0B9 30 MOV *SP+,R2 Address to start VRAM fill 0330 631C C1CB 18 MOV LINK,R7 0331 631E 06A0 32 BL @FILL1 6320 3208 0332 6322 C2C7 18 MOV R7,LINK 0333 6324 0460 28 B @BKLINK 6326 30EA 0334 *======================================================================== 0335 FILL1 ; R0=char, R1=cnt, R2=vaddr 0336 6328 0262 22 ORI R2,>4000 Set bit for VDP write 632A 4000 0337 632C 06C2 14 SWPB R2 0338 632E D802 38 MOVB R2,@VDPWA LS byte first 6330 8C02 0339 6332 06C2 14 SWPB R2 0340 6334 D802 38 MOVB R2,@VDPWA Then MS byte 6336 8C02 0341 6338 1000 14 NOP Kill time 0342 633A D800 38 FLOOP MOVB R0,@VDPWD Write a byte 633C 8C00 0343 633E 0601 14 DEC R1 0344 6340 16FC 14 JNE FLOOP Not done, fill another 0345 6342 045B 20 B *LINK 0346 ;]*====================================================================== 0347 * 0348 *==== VAND -- VDP byte AND routine. CODE = 22 ================= 0349 *==== VOR -- VDP byte OR routine. CODE = 24 ================= 0350 ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= 0351 * 0352 6344 C0B9 30 AOX MOV *SP+,R2 VRAM address 0353 6346 06C2 14 SWPB R2 0354 6348 D802 38 MOVB R2,@VDPWA LS byte first 634A 8C02 0355 634C 06C2 14 SWPB R2 0356 634E D802 38 MOVB R2,@VDPWA Then MS byte 6350 8C02 0357 6352 1000 14 NOP Kill time 0358 6354 D0E0 34 MOVB @VDPRD,R3 Read byte 6356 8800 0359 6358 C039 30 MOV *SP+,R0 Get data to operate with 0360 635A 06C0 14 SWPB R0 to left byte 0361 *** Now do requested operation ***************** 0362 635C 0281 22 CI R1,24 635E 0018 0363 6360 1304 14 JEQ DOOR 0364 6362 1505 14 JGT DOXOR 0365 6364 0543 14 INV R3 These two instructions 0366 6366 4003 18 SZC R3,R0 perform an 'AND' 0367 6368 1003 14 JMP FINAOX 0368 636A E003 18 DOOR SOC R3,R0 perform 'OR' 0369 636C 1001 14 JMP FINAOX 0370 636E 2803 18 DOXOR XOR R3,R0 perform 'XOR' 0371 6370 0201 20 FINAOX LI R1,1 6372 0001 0372 6374 C1CB 18 MOV LINK,R7 0373 6376 06A0 32 BL @FILL1 6378 3208 0374 637A C2C7 18 MOV R7,LINK 0375 637C 0460 28 B @BKLINK 637E 30EA 0376 ;]* 0377 ;[*== KEY routine CODE = -2 ================= 0378 * 0379 6380 C028 34 KY MOV @$ALTI(U),R0 alternate input device? 6382 0038 0380 6384 131B 14 JEQ KEY0 jump to keyboard input if not 0381 * 0382 * R0 now points to PAB for alternate input device, the one-byte buffer 0383 * for which must immediately precede its PAB. PAB must have been set up 0384 * to read one byte. 0385 * 0386 6386 04C7 14 CLR R7 prepare to zero status byte 0387 6388 D807 38 MOVB R7,@KYSTAT zero status byte 638A 837C 0388 638C 0580 14 INC R0 point R0 to Flag/Status byte 0389 638E 0420 54 BLWP @VSBR read it 6390 3746 0390 6392 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6394 1F00 0391 6396 0420 54 BLWP @VSBW write it back to PAB 6398 373E 0392 639A C040 18 MOV R0,R1 Set up pointer... 0393 639C 0221 22 AI R1,8 ...to namelength byte of PAB 639E 0008 0394 63A0 C801 38 MOV R1,@SUBPTR copy to DSR subroutine name-length pointer 63A2 8356 0395 63A4 C0C0 18 MOV R0,R3 save pointer (DSRLNK will trash it!) 0396 63A6 0420 54 BLWP @DSRLNK get 1 byte from device 63A8 37BE 0397 63AA 0008 DATA >8 0398 63AC C003 18 MOV R3,R0 restore pointer 0399 63AE 0640 14 DECT R0 point to one-byte VRAM buffer in front of PAB 0400 63B0 0420 54 BLWP @VSBR read character 63B2 3746 0401 63B4 0981 56 SRL R1,8 move to LSB 0402 63B6 C001 18 MOV R1,R0 copy to return register 0403 63B8 0460 28 B @BKLINK return to caller 63BA 30EA 0404 * 0405 * Input is comining from the keyboard 0406 * 0407 63BC C1E0 34 KEY0 MOV @KEYCNT,R7 63BE 3954 0408 63C0 0587 14 INC R7 0409 63C2 160A 14 JNE KEY1 0410 63C4 C028 34 MOV @CURPO$(U),R0 63C6 0016 0411 63C8 0420 54 BLWP @VSBR Read character at cursor position... 63CA 3746 0412 63CC D801 38 MOVB R1,@CURCHR ...and save it 63CE 3ABC 0413 63D0 0201 20 LI R1,>1E00 Place cursor character on screen 63D2 1E00 0414 63D4 0420 54 BLWP @VSBW 63D6 373E 0415 * 0416 63D8 0420 54 KEY1 BLWP @KSCAN 63DA 373A 0417 63DC D020 34 MOVB @KYSTAT,R0 63DE 837C 0418 63E0 2020 38 COC @H2000,R0 check status 63E2 3734 0419 63E4 1319 14 JEQ KEY2 JMP if key was pressed 0420 * 0421 63E6 0287 22 CI R7,100 No key pressed 63E8 0064 0422 63EA 1603 14 JNE KEY3 0423 63EC D060 34 MOVB @CURCHR,R1 63EE 3ABC 0424 63F0 1006 14 JMP KEY5 0425 * 0426 63F2 0287 22 KEY3 CI R7,200 63F4 00C8 0427 63F6 1607 14 JNE KEY4 0428 63F8 04C7 14 CLR R7 0429 63FA 0201 20 LI R1,>1E00 Cursor char 63FC 1E00 0430 63FE C028 34 KEY5 MOV @CURPO$(U),R0 6400 0016 0431 6402 0420 54 BLWP @VSBW 6404 373E 0432 6406 C807 38 KEY4 MOV R7,@KEYCNT 6408 3954 0433 640A C1E0 34 MOV @INTACT,R7 Are we in user's ISR? 640C 3956 0434 640E 1602 14 JNE KEY6 Don't enable interrupts if so. 0435 6410 0300 24 LIMI 2 6412 0002 0436 6414 064D 14 KEY6 DECT IP This will re-execute KEY 0437 6416 045F 20 B *NEXT 0438 6418 0720 34 KEY2 SETO @KEYCNT Key was pressed 641A 3954 0439 641C C028 34 MOV @CURPO$(U),R0 Restore character at cursor location 641E 0016 0440 6420 D060 34 MOVB @CURCHR,R1 6422 3ABC 0441 6424 0420 54 BLWP @VSBW 6426 373E 0442 6428 D020 34 MOVB @KYCHAR,R0 Put char in... 642A 8375 0443 642C 0980 56 SRL R0,8 ...LSB of R0 0444 642E 0460 28 B @BKLINK 6430 30EA 0445 ;]* 0446 ;[*== EMIT routine CODE = -4 ================= 0447 * 0448 6432 C042 18 EMT MOV R2,R1 copy char to R1 for VSBW 0449 6434 C028 34 MOV @$ALTO(U),R0 alternate output device? 6436 003A 0450 6438 1317 14 JEQ EMIT0 jump to video display output if not 0451 * 0452 * R0 now points to PAB for alternate output device, the one-byte buffer 0453 * for which must immediately precede its PAB. PAB must have been set up 0454 * to write one byte. 0455 * 0456 643A 04C7 14 CLR R7 ALTOUT active 0457 643C D807 38 MOVB R7,@KYSTAT zero status byte 643E 837C 0458 6440 0600 14 DEC R0 point to one-byte VRAM buffer in front of PAB 0459 6442 06C1 14 SWPB R1 char to MSB 0460 6444 0420 54 BLWP @VSBW write char to buffer 6446 373E 0461 6448 05C0 14 INCT R0 point to Flag/Status byte 0462 644A 0420 54 BLWP @VSBR read it 644C 3746 0463 644E 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6450 1F00 0464 6452 0420 54 BLWP @VSBW write it back to PAB 6454 373E 0465 6456 0220 22 AI R0,8 Set up pointer to namelength byte of PAB 6458 0008 0466 645A C800 38 MOV R0,@SUBPTR copy to DSR subroutine name-length pointer 645C 8356 0467 645E 0420 54 BLWP @DSRLNK put 1 byte to device 6460 37BE 0468 6462 0008 DATA >8 0469 6464 0460 28 B @BKLINK return to caller 6466 30EA 0470 * 0471 * Output is going to the video display 0472 * 0473 6468 0281 22 EMIT0 CI R1,7 Is it a bell? 646A 0007 0474 646C 1607 14 JNE NOTBEL 0475 646E 04C2 14 CLR R2 0476 6470 D802 38 MOVB R2,@KYSTAT 6472 837C 0477 6474 0420 54 BLWP @GPLLNK 6476 3784 0478 6478 0036 DATA >0036 Emit error tone 0479 647A 1060 14 JMP EMEXIT 0480 * 0481 647C 0281 22 NOTBEL CI R1,8 Is it a backspace? 647E 0008 0482 6480 160B 14 JNE NOTBS 0483 6482 0201 20 LI R1,>2000 6484 2000 0484 6486 C028 34 MOV @CURPO$(U),R0 6488 0016 0485 648A 0420 54 BLWP @VSBW 648C 373E 0486 648E 1501 14 JGT DECCUR 0487 6490 1055 14 JMP EMEXIT 0488 6492 0628 34 DECCUR DEC @CURPO$(U) 6494 0016 0489 6496 1052 14 JMP EMEXIT 0490 * 0491 6498 0281 22 NOTBS CI R1,>A Is it a line feed? 649A 000A 0492 649C 162B 14 JNE NOTLF 0493 649E C1E8 34 MOV @$SEND(U),R7 64A0 0034 0494 64A2 61E8 34 S @$SWDTH(U),R7 64A4 0030 0495 64A6 81E8 34 C @CURPO$(U),R7 64A8 0016 0496 64AA 1404 14 JHE SCRLL 0497 64AC AA28 54 A @$SWDTH(U),@CURPO$(u) 64AE 0030 64B0 0016 0498 64B2 1044 14 JMP EMEXIT 0499 64B4 C1CB 18 SCRLL MOV LINK,R7 0500 64B6 06A0 32 BL @SCROLL 64B8 339E 0501 64BA C2C7 18 MOV R7,LINK 0502 64BC 103F 14 JMP EMEXIT 0503 * 0504 *** SCROLLING ROUTINE 0505 * 0506 64BE C028 34 SCROLL MOV @$SSTRT(U),R0 VRAM addr 64C0 0032 0507 64C2 0201 20 LI R1,LINBUF Line buffer 64C4 3A6C 0508 64C6 C0A8 34 MOV @$SWDTH(U),R2 Count 64C8 0030 0509 64CA A002 18 A R2,R0 Start at line 2 0510 64CC 0420 54 SCROL1 BLWP @VMBR 64CE 374A 0511 64D0 6002 18 S R2,R0 One line back to write 0512 64D2 0420 54 BLWP @VMBW 64D4 3742 0513 64D6 A002 18 A R2,R0 Two lines ahead for next read 0514 64D8 A002 18 A R2,R0 0515 64DA 8A00 38 C R0,@$SEND(U) End of screen? 64DC 0034 0516 64DE 1AF6 14 JL SCROL1 0517 64E0 C042 18 MOV R2,R1 Blank bottom row of screen 0518 64E2 0200 20 LI R0,>2000 Blank 64E4 2000 0519 64E6 60A8 34 S @$SEND(U),R2 64E8 0034 0520 64EA 0502 16 NEG R2 Now contains address of start of last line 0521 64EC C18B 18 MOV LINK,R6 0522 64EE 06A0 32 BL @FILL1 Write the blanks 64F0 3208 0523 64F2 0456 20 B *R6 0524 * 0525 64F4 0281 22 NOTLF CI R1,>D Is it a carriage return? 64F6 000D 0526 64F8 160D 14 JNE NOTCR 0527 64FA 04C0 14 CLR R0 0528 64FC C068 34 MOV @CURPO$(U),R1 64FE 0016 0529 6500 C0C1 18 MOV R1,R3 0530 6502 6068 34 S @$SSTRT(U),R1 Adjusted for screen not at 0 6504 0032 0531 6506 C0A8 34 MOV @$SWDTH(U),R2 6508 0030 0532 650A 3C02 128 DIV R2,R0 0533 650C 60C1 18 S R1,R3 0534 650E CA03 38 MOV R3,@CURPO$(U) 6510 0016 0535 6512 1014 14 JMP EMEXIT 0536 * 0537 6514 06C1 14 NOTCR SWPB R1 Assume it is a printable character 0538 6516 C028 34 MOV @CURPO$(U),R0 6518 0016 0539 651A 0420 54 BLWP @VSBW 651C 373E 0540 651E C0A8 34 MOV @$SEND(U),R2 6520 0034 0541 6522 0602 14 DEC R2 0542 6524 8080 18 C R0,R2 0543 6526 1607 14 JNE NOTCR1 0544 6528 C028 34 MOV @$SEND(U),R0 652A 0034 0545 652C 6028 34 S @$SWDTH(U),R0 Was last char on screen. Scroll 652E 0030 0546 6530 CA00 38 MOV R0,@CURPO$(U) 6532 0016 0547 6534 10BF 14 JMP SCRLL 0548 6536 0580 14 NOTCR1 INC R0 No scroll necessary 0549 6538 CA00 38 MOV R0,@CURPO$(U) 653A 0016 0550 * 0551 653C 0460 28 EMEXIT B @BKLINK 653E 30EA 0552 ;]* 0553 ;[*== CRLF routine CODE = -6 ================= 0554 * 0555 6540 C14B 18 CLF MOV LINK,R5 0556 6542 0202 20 LI R2,>000D 6544 000D 0557 6546 06A0 32 BL @EMT EMT will alter INT mask via B @BKLINK 6548 3312 0558 654A 0202 20 LI R2,>000A 654C 000A 0559 654E 0300 24 LIMI 0 Previous call to EMT altered INT mask 6550 0000 0560 6552 06A0 32 BL @EMT 6554 3312 0561 6556 C2C5 18 MOV R5,LINK 0562 6558 0460 28 B @BKLINK 655A 30EA 0563 ;]* 0564 ;[*== ?TERMINAL routine CODE = -8 ================= 0565 * scan for <clear>, <break>, FCTN+4 press 0566 * 0567 655C C14B 18 QTM MOV LINK,R5 save return 0568 655E 06A0 32 BL @>0020 branch to console's test for <clear> 6560 0020 0569 6562 02C0 12 STST R0 store status in R0 0570 6564 1603 14 JNE QTM2 exit if not <clear> 0571 6566 06A0 32 QTM1 BL @>0020 check for <clear> again 6568 0020 0572 656A 13FD 14 JEQ QTM1 loop until not <clear> 0573 656C C2C5 18 QTM2 MOV R5,LINK restore return 0574 656E 0240 22 ANDI R0,>2000 keep only EQU bit 6570 2000 0575 6572 0460 28 B @BKLINK return to caller 6574 30EA 0576 ;]* 0577 ;[*== ?KEY routine CODE = -10 ================= 0578 * 0579 6576 0420 54 QKY BLWP @KSCAN 6578 373A 0580 657A D020 34 MOVB @KYCHAR,R0 657C 8375 0581 657E 0980 56 SRL R0,8 0582 6580 0280 22 CI R0,>00FF 6582 00FF 0583 6584 1601 14 JNE QKEY1 0584 6586 04C0 14 CLR R0 0585 6588 0460 28 QKEY1 B @BKLINK 658A 30EA 0586 ;]* 0587 ;[*== GOTOXY routine CODE = -12 ================= 0588 * 0589 658C 38E8 72 GXY MPY @$SWDTH(U),R3 658E 0030 0590 6590 A102 18 A R2,R4 Position within screen 0591 6592 A128 34 A @$SSTRT(U),R4 Add VRAM offset to screen top 6594 0032 0592 6596 CA04 38 MOV R4,@CURPO$(U) 6598 0016 0593 659A 0460 28 B @BKLINK 659C 30EA 0594 ;] 0595 * ___ __ __ ____ ______ 0596 * / _ )/ /__ ____/ /__ / _/_/_/ __ \ 0597 * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / 0598 * /____/_/\___/\__/_/\_\ /___/_/ \____/ 0599 0600 * 0601 *== USE blocks file CODE = -14 ================= 0602 *== CREATE blocks file CODE = -16 ================= 0603 *== READ block from blocks file CODE = -18 ================= 0604 *== WRITE block to blocks file CODE = -20 ================= 0605 ;[*== Block File I/O Support ============================================ 0606 * 0607 * BPTOG utility to toggle one of 2 PABs for block file access 0608 * 0609 659E C028 34 BPTOG MOV @$BPOFF(U),R0 PAB offset to R0 65A0 0040 0610 65A2 0201 20 LI R1,70 Toggle amount 65A4 0046 0611 65A6 2840 18 XOR R0,R1 New offset 0612 65A8 CA01 38 MOV R1,@$BPOFF(U) Update offset 65AA 0040 0613 * 0614 **xxx** entry point to insure we have correct PAB address 0615 65AC C028 34 BPSET MOV @$DKBUF(U),R0 Get DISK_BUF address 65AE 002C 0616 65B0 A028 34 A @$BPABS(U),R0 Get BPABS address 65B2 003E 0617 * 0618 65B4 A028 34 A @$BPOFF(U),R0 Add current offset 65B6 0040 0619 65B8 C800 38 MOV R0,@BFPAB Update current block file's PAB address 65BA 34BC 0620 65BC 045B 20 RT 0621 * 0622 * CLOSE blocks file 0623 * 0624 65BE C020 34 BKCLOS MOV @BFPAB,R0 65C0 34BC 0625 65C2 0201 20 LI R1,$FCLS Opcode=CLOSE 65C4 0100 0626 65C6 0420 54 BLWP @VSBW 65C8 373E 0627 65CA 0220 22 AI R0,9 Address of filename's char count 65CC 0009 0628 65CE C800 38 MOV R0,@SUBPTR Point to filename's char count 65D0 8356 0629 65D2 0420 54 BLWP @DSRLNK Close the file 65D4 37BE 0630 65D6 0008 DATA 8 0631 65D8 045B 20 RT Deal with error in caller 0632 * 0633 * storage area 0634 * 0635 65DA 0000 SVBRET DATA 0 Storage for LINK coming into BRW 0636 65DC 0000 BFPAB DATA 0 Storage for current blocks file PAB address... 0637 * ...will have current PAB on entry 0638 * PAB header storage 0639 * 0640 65DE PABHD BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE 0641 * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative 0642 * >03=OUTPUT mode + " 0643 * >01=UPDATE mode + " 0644 * BYTE 2,3: save contents of DISK_BUF here 0645 65E2 80 BYTE >80 Record length 0646 65E3 80 BYTE >80 Character count of transfer 0647 65E4 BSS 2 Record number 0648 * 0649 *** file I/O equates 0650 * 0651 0000 $FOPN EQU >0000 0652 0100 $FCLS EQU >0100 0653 0200 $FRD EQU >0200 0654 0300 $FWRT EQU >0300 0655 0400 $FRST EQU >0400 0656 0005 $FINP EQU 5 0657 0003 $FOUT EQU 3 0658 0001 $FUPD EQU 1 0659 * 0660 *** BRW -- entry point for block read/write routines 0661 * 0662 65E6 C80B 38 BRW MOV LINK,@SVBRET Save LINK address 65E8 34BA 0663 65EA C1C1 18 MOV R1,R7 Save CODE {R1 to R7} 0664 65EC 0817 56 SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) 0665 65EE 0227 22 AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) 65F0 000C 0666 65F2 06A0 32 BL @BPSET Insure correct PAB address in BFPAB (it may have moved) 65F4 348C 0667 65F6 0287 22 CI R7,4 USE or CREATE? 65F8 0004 0668 65FA 110D 14 JLT BRW01 No 0669 65FC 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 65FE 347E 0670 6600 C020 34 MOV @BFPAB,R0 Load PAB address 6602 34BC 0671 6604 0220 22 AI R0,9 Set to name length byte 6606 0009 0672 6608 04C2 14 CLR R2 0673 660A C079 30 MOV *SP+,R1 Pop bfnaddr to R1 0674 660C D811 46 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 660E 8305 0675 6610 0582 14 INC R2 Add 1 to # bytes to copy 0676 6612 0420 54 BLWP @VMBW Copy char count & pathname to PAB 6614 3742 0677 * 0678 *** set up PAB for OPEN 0679 * 0680 6616 0201 20 BRW01 LI R1,$FUPD Opcode=0,mode=update 6618 0001 0681 661A 9820 54 CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? 661C 830F 661E 830F 0682 6620 1C02 14 JOP BRW02 No 0683 6622 0201 20 LI R1,$FINP Yes...change mode=input 6624 0005 0684 6626 C801 38 BRW02 MOV R1,@PABHD Put in PAB header 6628 34BE 0685 662A C828 54 MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header 662C 002C 662E 34C0 0686 6630 04C0 14 CLR R0 0687 6632 C800 38 MOV R0,@PABHD+6 Set record#=0 6634 34C4 0688 6636 C020 34 MOV @BFPAB,R0 VRAM destination 6638 34BC 0689 663A 0201 20 LI R1,PABHD RAM source 663C 34BE 0690 663E 0202 20 LI R2,8 Copy first 8 bytes of PAB header 6640 0008 0691 6642 0420 54 BLWP @VMBW Do the copy 6644 3742 0692 * 0693 *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] 0694 * 0695 6646 0220 22 AI R0,9 Address of filename's char count in PAB 6648 0009 0696 664A C800 38 MOV R0,@SUBPTR Point to-----^^^^ 664C 8356 0697 664E 0420 54 BLWP @DSRLNK Open/create the file 6650 37BE 0698 6652 0008 DATA 8 0699 6654 135F 14 JEQ BKERR 0700 6656 0287 22 CI R7,4 READ or WRITE? 6658 0004 0701 665A 1120 14 JLT BRW04 Yes 0702 665C 156E 14 JGT BRWDON No; =USE; we're done 0703 * 0704 *** write blank records to newly created blocks file [CODE = -16,CREATE] 0705 * 0706 665E C179 30 MOV *SP+,R5 No; = CREATE; pop #blocks from stack 0707 6660 0A35 56 SLA R5,3 Convert #blocks to #records 0708 6662 C0C5 18 MOV R5,R3 Save 0709 6664 C105 18 MOV R5,R4 Set up counter 0710 6666 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 6668 0301 0711 666A C800 38 MOV R0,@PABHD Copy to PAB header 666C 34BE 0712 666E 6144 18 BRLOOP S R4,R5 Calculate next record 0713 6670 C805 38 MOV R5,@PABHD+6 Copy to PAB header 6672 34C4 0714 6674 C020 34 MOV @BFPAB,R0 VRAM destination 6676 34BC 0715 6678 0201 20 LI R1,PABHD RAM source 667A 34BE 0716 667C 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 667E 0008 0717 6680 0420 54 BLWP @VMBW Do the copy 6682 3742 0718 6684 0220 22 AI R0,9 Address of filename's char count 6686 0009 0719 6688 C800 38 MOV R0,@SUBPTR Point to filename's char count 668A 8356 0720 668C 0420 54 BLWP @DSRLNK Write one record of blanks 668E 37BE 0721 6690 0008 DATA 8 0722 6692 1340 14 JEQ BKERR 0723 6694 C143 18 MOV R3,R5 Get #blocks 0724 6696 0604 14 DEC R4 Count down 1 record 0725 6698 16EA 14 JNE BRLOOP Write another record if not done 0726 669A 104F 14 JMP BRWDON We're done 0727 * 0728 *** prepare for read/write block 0729 * 0730 669C C179 30 BRW04 MOV *SP+,R5 Pop block# to write 0731 669E C1B9 30 MOV *SP+,R6 Pop bufaddr 0732 66A0 0605 14 DEC R5 Block#-1 0733 66A2 0A35 56 SLA R5,3 Convert to starting record# 0734 66A4 0204 20 LI R4,8 Load counter for 8 records 66A6 0008 0735 66A8 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 66AA 0301 0736 66AC 0203 20 LI R3,VMBW WRITE vector 66AE 3742 0737 66B0 0287 22 CI R7,2 Are we writing the block? 66B2 0002 0738 66B4 1304 14 JEQ BRW05 Yup 0739 66B6 0200 20 LI R0,$FRD+$FINP Nope...set up for READ 66B8 0205 0740 66BA 0203 20 LI R3,VMBR READ vector 66BC 374A 0741 66BE C800 38 BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header 66C0 34BE 0742 * 0743 * READ/WRITE block routine [CODE = -18/-20] 0744 * 0745 66C2 C805 38 RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header 66C4 34C4 0746 66C6 C020 34 MOV @BFPAB,R0 VRAM destination 66C8 34BC 0747 66CA 0201 20 LI R1,PABHD RAM source 66CC 34BE 0748 66CE 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 66D0 0008 0749 66D2 0420 54 BLWP @VMBW Do the copy 66D4 3742 0750 66D6 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 66D8 002C 0751 66DA C046 18 MOV R6,R1 RAM buffer to R1 0752 66DC 0202 20 LI R2,128 Bytes to copy 66DE 0080 0753 66E0 0287 22 CI R7,3 READ? 66E2 0003 0754 66E4 1301 14 JEQ BRW06 Yup 0755 66E6 0413 42 BLWP *R3 Nope...copy record to VRAM 0756 * 0757 * temporarily use CRU register---it should be OK 0758 * 0759 66E8 C320 34 BRW06 MOV @BFPAB,CRU PAB address 66EA 34BC 0760 66EC 022C 22 AI CRU,9 Address of filename's char count 66EE 0009 0761 66F0 C80C 38 MOV CRU,@SUBPTR Point to filename's char count 66F2 8356 0762 66F4 0420 54 BLWP @DSRLNK Read/write one record 66F6 37BE 0763 66F8 0008 DATA 8 0764 66FA 130C 14 JEQ BKERR 0765 66FC 0287 22 CI R7,2 WRITE? 66FE 0002 0766 6700 1303 14 JEQ BRW07 Yup...next record 0767 6702 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) 6704 002C 0768 6706 0413 42 BLWP *R3 Nope...copy record to RAM buffer 0769 6708 0585 14 BRW07 INC R5 Next record in file 0770 670A 0226 22 AI R6,128 Next record to/from block RAM buffer 670C 0080 0771 670E 0604 14 DEC R4 Count down 1 record 0772 6710 16D8 14 JNE RWLOOP Read/write another record if not done 0773 6712 1013 14 JMP BRWDON We're done 0774 * 0775 *** error handling 0776 * 0777 6714 D000 18 BKERR MOVB R0,R0 Device error? 0778 6716 1306 14 JEQ BKERR6 Yes, exit with disk error 0779 6718 0206 20 BKERR9 LI R6,9 No, exit with file error 671A 0009 0780 671C 1005 14 JMP BKCLN 0781 671E 0206 20 BKERR8 LI R6,8 Block# <=0! exit with range error 6720 0008 0782 6722 1002 14 JMP BKCLN 0783 6724 0206 20 BKERR6 LI R6,6 6726 0006 0784 6728 06A0 32 BKCLN BL @BKCLOS Close current blocks file; ignore error 672A 349E 0785 672C 0287 22 CI R7,4 USE or CREATE? 672E 0004 0786 6730 1102 14 JLT BKCLN1 No 0787 6732 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 6734 347E 0788 6736 C006 18 BKCLN1 MOV R6,R0 Pass error back to caller 0789 6738 100C 14 JMP BKEXIT 0790 673A 04C6 14 BRWDON CLR R6 0791 673C 06A0 32 BL @BKCLOS Close current blocks file 673E 349E 0792 6740 1602 14 JNE BRWDN1 Error? 0793 6742 0206 20 LI R6,9 Yes...assume it was a file error 6744 0009 0794 6746 0287 22 BRWDN1 CI R7,4 (no error)...CREATE? 6748 0004 0795 674A 1602 14 JNE BRWDN2 No...we're done 0796 674C 06A0 32 BL @BPTOG Yes...revert to correct blocks file 674E 347E 0797 6750 C006 18 BRWDN2 MOV R6,R0 Error to R0 0798 6752 C2E0 34 BKEXIT MOV @SVBRET,LINK Restore LINK 6754 34BA 0799 6756 0460 28 B @BKLINK 6758 30EA 0800 ;] 0801 ;[* MSGTYP <<< Support for string typing in various banks >>> 0802 * 0803 * Called with: BL @MSGTYP 0804 * 0805 * R4 and R5 are the only registers that will be preserved 0806 * ..after a call to EMIT--- 0807 * 0808 * Input: R4 = Address of length byte of packed string 0809 * 0810 * We will pass the ASCII value of character to EMIT in R2 without 0811 * insuring it is 7 bits wide. 0812 * 0813 675A 064E 14 MSGTYP DECT R Push return address 0814 675C C78B 30 MOV LINK,*R ...to Forth return stack 0815 675E 04C5 14 CLR R5 0816 6760 D174 28 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char 0817 6762 06C5 14 SWPB R5 Put char count in low byte 0818 6764 04C2 14 MTLOOP CLR R2 0819 6766 D0B4 28 MOVB *R4+,R2 Copy next char to R2 for EMIT 0820 6768 06C2 14 SWPB R2 Put char in low byte 0821 676A 0300 24 LIMI 0 We need to do this because we're calling EMIT directly 676C 0000 0822 676E 06A0 32 BL @EMT Call EMIT directly 6770 3312 0823 6772 05A8 34 INC @$OUT(U) Increment display line character count 6774 0052 0824 6776 0605 14 DEC R5 Decrement character count for this message 0825 6778 16F5 14 JNE MTLOOP Are we done? 0826 677A C2FE 30 MOV *R+,LINK Yes. Pop return address 0827 677C 045B 20 RT Return to caller 0828 ;] 0829 ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) 0830 677E CD74 46 R4$5 MOV *R4+,*R5+ 0831 6780 CD74 46 MOV *R4+,*R5+ 0832 6782 CD74 46 MOV *R4+,*R5+ 0833 6784 C554 38 MOV *R4,*R5 0834 6786 045B 20 RT 0835 ;] 0836 * __ __ _ __ _ __ __ 0837 * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ 0838 * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) 0839 * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ 0840 * ___ ___ ____ 0841 * / _ \___ / _/__ ___ __/ / /____ 0842 * / // / -_) _/ _ `/ // / / __(_-< 0843 * /____/\__/_/ \_,_/\_,_/_/\__/___/ 0844 0845 ;[*== User Variable defaults ============================================ 0846 * 0847 6788 UBASE0 BSS 6 BASE OF USER VARIABLES 0848 678E 3668 DATA UBASE0 06 USER UCONS$ 0849 6790 FFA0 DATA SPBASE 08 USER S0 0850 6792 3FFE DATA RBASE 0A USER R0 { R0$ 0851 6794 36B4 DATA $UVAR 0C USER U0 0852 6796 FFA0 DATA SPBASE 0E USER TIB 0853 6798 001F DATA 31 10 USER WIDTH 0854 679A A000 DATA DPBASE 12 USER DP 0855 679C 30F6 DATA $SYS$ 14 USER SYS$ 0856 679E 0000 DATA 0 16 USER CURPOS 0857 67A0 3020 DATA INT1 18 USER INTLNK 0858 67A2 0001 DATA 1 1A USER WARNING 0859 67A4 0040 DATA 64 1C USER C/L$ { CL$ 0860 67A6 2010 DATA $BUFF 1E USER FIRST$ 0861 67A8 3020 DATA $LO 20 USER LIMIT$ 0862 67AA 0380 DATA >0380 22 USER COLTAB Color Table address in VRAM 0863 67AC 0300 DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM 0864 67AE 0780 DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM 0865 67B0 0800 DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM 0866 67B2 0080 DATA >80 2A USER FPB pushes address of user screen font file PAB 0867 * ...that is this relative distance from DISK_BUF 0868 67B4 1000 DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) 0869 67B6 0460 DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) 0870 67B8 0028 DATA 40 30 USER SCRN_WIDTH 0871 67BA 0000 DATA 0 32 USER SCRN_START 0872 67BC 03C0 DATA 960 34 USER SCRN_END 0873 67BE 0000 DATA 0 36 USER ISR [Note: This used to be INT1] 0874 67C0 0000 DATA 0 38 USER ALTIN 0875 67C2 0000 DATA 0 3A USER ALTOUT 0876 67C4 0001 DATA 1 3C USER VDPMDE permanent location for VDPMDE 0877 67C6 00C6 DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files 0878 * ...that is this relative distance from DISK_BUF 0879 67C8 0000 DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB 0880 * ...always toggled between 0 and 70 0881 67CA 0800 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM 0882 67CC FFFF DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) 0883 * 0 = console font via GPLLNK 0884 67CE 0000 DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU 0885 67D0 0000 DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap 0886 67D2 0000 DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. 0887 * 0 = Symmetric (default) 0888 * !0 = Floored 0889 67D4 $UVAR BSS >80 USER VARIABLE AREA 0890 ;] 0891 ;[*== A Constant ==================================================== 0892 * 0893 6854 2000 H2000 DATA >2000 0894 ;]* 0895 * __ ____ _ ___ __ _ __ __ 0896 * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ 0897 * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< 0898 * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ 0899 * /___/ 0900 * 0901 ;[*== Utility Vectors =================================================== 0902 * 0903 * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK 0904 * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK 0905 6856 3A4C XMLLNK DATA UTILWS,XMLENT ; Link to ROM routines 6858 3756 0906 685A 3A4C KSCAN DATA UTILWS,KSENTR ; Keyboard scan 685C 3832 0907 685E 3A4C VSBW DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) 6860 3848 0908 6862 3A4C VMBW DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) 6864 3854 0909 6866 3A4C VSBR DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) 6868 3862 0910 686A 3A4C VMBR DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) 686C 386E 0911 686E 3A4C VMOVE DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) 6870 38AE 0912 6872 3A4C VWTR DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) 6874 387C 0913 ;]* 0914 ;[*== XMLENT -- Link to system XML utilities ============================ 0915 * 0916 6876 C83E 50 XMLENT MOV *R14+,@GPLWS+2 Get argument 6878 83E2 0917 687A 02E0 18 LWPI GPLWS Select GPL workspace 687C 83E0 0918 687E C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6880 3A62 0919 6882 C081 18 MOV R1,R2 Make a copy of argument 0920 6884 0281 22 CI R1,>8000 Direct address in ALC? 6886 8000 0921 6888 1B07 14 JH XML30 We have the address 0922 688A 09C1 56 SRL R1,12 0923 688C 0A11 56 SLA R1,1 0924 688E 0A42 56 SLA R2,4 0925 6890 09B2 56 SRL R2,11 0926 6892 A0A1 34 A @XMLTAB(R1),R2 6894 0CFA 0927 6896 C092 26 MOV *R2,R2 0928 6898 0692 24 XML30 BL *R2 0929 689A 02E0 18 LWPI UTILWS Get back to right WS 689C 3A4C 0930 689E C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 68A0 83F6 0931 68A2 0380 18 RTWP 0932 ;]* 0933 * ________ __ __ _ ____ __ __ ________ 0934 * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ 0935 * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / 0936 * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 0937 * 0938 *-----------------------------------------------------------------------* 0939 ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= 0940 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 0941 * * 0942 * This routine will work with any GROM library slot since it is * 0943 * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * 0944 * This GPLLNK does NOT require a module to be plugged into the * 0945 * GROM port so it will work with the Editor/Assembler, * 0946 * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * 0947 * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * 0948 * It saves and restores the current GROM Address in case you want * 0949 * to return back to GROM for Basic or Extended Basic CALL LINKs * 0950 * or to return to the loading module. * 0951 * * 0952 * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * 0953 * DATA >34 * 0954 * * 0955 * NOTES: Do Not REF GPLLNK when using this routine in your code. * 0956 * * 0957 * 70 Bytes - including the GPLLNK Workspace * 0958 *-----------------------------------------------------------------------* 0959 0960 * GPLWS (>83E0) is GPL workspace 0961 83E8 G_R4 EQU GPLWS+8 GPL workspace R4 0962 83EC G_R6 EQU GPLWS+12 GPL workspace R6 0963 * SUBSTK (>8373) is GPL Subroutine stack pointer 0964 0060 LDGADR EQU >60 Load & Execute GROM address entry point 0965 200E XTAB27 EQU >200E Low Mem XML table location 27 0966 * ..Will contain XMLRTN at startup 0967 166C GETSTK EQU >166C 0968 0969 68A4 3776 GPLLNK DATA GLNKWS ; R7 Set up BLWP Vectors 0970 68A6 3796 DATA GLINK1 ; R8 0971 * RTNADR <---don't think we need this label 0972 68A8 37B2 DATA XMLRTN ; R9 address where GPL XML returns to us... 0973 * ...this address will already be in XTAB27,... 0974 * ...>200E, so don't really need it here} 0975 68AA 176C GXMLAD DATA >176C ; R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) 0976 68AC 0050 DATA >50 ; R11 Initialized to >50 where PUTSTK address resides 0977 3776 GLNKWS EQU $->18 ; GPLLNK's workspace of which only... 0978 68AE BSS >08 ; R12-R15 ...registers R7 through R15 are used 0979 0980 68B6 C81B 46 GLINK1 MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS 68B8 83E8 0981 68BA C83E 50 MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS 68BC 83EC 0982 68BE 02E0 18 LWPI GPLWS Load GPL WS 68C0 83E0 0983 68C2 0694 24 BL *R4 Save current GROM Address on stack 0984 68C4 C920 54 MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return 68C6 378A 68C8 8302 0985 68CA 05E0 34 INCT @SUBSTK Adjust the stack pointer 68CC 8373 0986 68CE 0460 28 B @LDGADR Execute our GPL Routine 68D0 0060 0987 0988 68D2 C120 34 XMLRTN MOV @GETSTK,R4 Get GETSTK pointer 68D4 166C 0989 68D6 0694 24 BL *R4 Restore GROM address off the stack 0990 68D8 02E0 18 LWPI GLNKWS Load our WS 68DA 3776 0991 68DC 0380 18 RTWP All Done - Return to Caller 0992 ;] 0993 * ___ _______ __ _ ____ __ __ ________ 0994 * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ 0995 * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / 0996 * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 0997 * 0998 *-----------------------------------------------------------------------* 0999 ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= 1000 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 1001 * * 1002 * (Uses console GROM 0's DSRLNK routine) * 1003 * (Do not REF DSRLNK or GPLLNK when using these routines) * 1004 * (This DSRLNK will also handle Subprograms and CS1, CS2) * 1005 * * 1006 * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * 1007 * DATA 8 * 1008 * * 1009 * NOTES: Must be used with a GPLLNK routine * 1010 * Returns ERRORs the same as the E/A DSRLNK * 1011 * EQ bit set on return if error * 1012 * ERROR CODE in caller's MSB of Register 0 on return * 1013 * * 1014 * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * 1015 *-----------------------------------------------------------------------* 1016 1017 0050 PUTSTK EQU >50 Push GROM Address to stack pointer 1018 836D TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK 1019 8356 NAMLEN EQU >8356 Device name length pointer in VDP PAB 1020 8C02 VWA EQU >8C02 VDP Write Address location 1021 8800 VRD EQU >8800 VDP Read Data byte location 1022 83E9 G_R4LB EQU >83E9 GPL Workspace R4 Lower byte 1023 837C GSTAT EQU >837C GPL Status byte location 1024 1025 68DE 37C2 DSRLNK DATA DSRWS,DLINK1 Set BLWP Vectors 68E0 37C2 1026 1027 DSRWS ; Start of DSRLNK workspace 1028 37C9 DR3LB EQU $+7 ; lower byte of DSRLNK workspace R3 1029 68E2 C30C 18 DLINK1 MOV R12,R12 R0 Have we already looked up the LINK address? 1030 68E4 161C 14 JNE DLINK3 R1 YES! Skip lookup routine 1031 *<<-------------------------------------------------------------------------->>* 1032 * This section of code is only executed once to find the GROM address * 1033 * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * 1034 * to indicate that the address is found and to be used as a mask for EQ & CND * 1035 *------------------------------------------------------------------------------* 1036 68E6 02E0 18 LWPI GPLWS R2,R3 else load GPL workspace 68E8 83E0 1037 68EA C120 34 MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack 68EC 0050 1038 68EE 0694 24 BL *R4 R6 1039 68F0 0204 20 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector 68F2 0011 1040 68F4 DB44 38 MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector 68F6 0402 1041 1042 ***les*** Note on above instruction: 1043 ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) 1044 ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) 1045 1046 68F8 1004 14 JMP DLINK2 R11 Jump around R12-R15 1047 68FA 0000 DATA 0 R12 contains >2000 flag when set 1048 68FC 0000 DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP 68FE 0000 6900 0000 1049 6902 DB60 54 DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address 6904 83E9 6906 0402 1050 6908 C160 34 MOV @GETSTK,R5 Take some time & set up GETSTK pointer 690A 166C 1051 690C D81D 46 MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector 690E 3811 1052 6910 05E0 34 INCT @DSRADR Adjust it to get past GPL FETCH instruction 6912 3810 1053 6914 0695 24 BL *R5 Restore the GROM address off the stack 1054 6916 02E0 18 LWPI DSRWS Reload DSRLNK workspace 6918 37C2 1055 691A 020C 20 LI R12,>2000 Set flag to signify DSRLNK address is set 691C 2000 1056 *<<-------------------------------------------------------------------------->>* 1057 691E 058E 14 DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte 1058 6920 D83E 48 MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK 6922 836D 1059 6924 C0E0 34 MOV @NAMLEN,R3 Save VDP address of Name Length 6926 8356 1060 6928 0223 22 AI R3,-8 Adjust it to point to PAB Flag byte 692A FFF8 1061 692C 0420 54 BLWP @GPLLNK Execute DSR LINK 692E 3784 1062 6930 03 DSRADR BYTE >03 High byte of GPL DSRLNK address 1063 6931 00 DSRAD1 BYTE >00 Lower byte of GPL DSRLNK address 1064 *----Error Check & Report to Caller's R0 and EQU bit------------------------- 1065 6932 D820 54 MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag 6934 37C9 6936 8C02 1066 6938 D803 38 MOVB R3,@VWA Set up MSB of VDP Address for Error Flag 693A 8C02 1067 693C 53CC 18 SZCB R12,R15 Clear EQ bit for Error Report 1068 693E D0E0 34 MOVB @VRD,R3 Get PAB Error Flag 6940 8800 1069 6942 0953 56 SRL R3,5 Adjust it to 0-7 error code 1070 6944 D743 30 MOVB R3,*R13 Put it into Caller's R0 (msb) 1071 6946 1603 14 JNE SETEQ If it's not zero, set EQ bit 1072 6948 2320 38 COC @GSTAT,R12 Else, test CND bit for Link Error (00) 694A 837C 1073 694C 1601 14 JNE DSREND No Error, Just return 1074 694E F3CC 18 SETEQ SOCB R12,R15 Error, so set Caller's EQ bit 1075 6950 0380 18 DSREND RTWP All Done - Return to Caller 1076 ;] 1077 ;[*== KSENTR -- Keyboard Scan (entry point) ============================= 1078 * 1079 6952 02E0 18 KSENTR LWPI GPLWS 6954 83E0 1080 6956 C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6958 3A62 1081 695A 06A0 32 BL @SCNKEY Console keyboard scan routine 695C 000E 1082 695E 02E0 18 LWPI UTILWS 6960 3A4C 1083 6962 C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 6964 83F6 1084 6966 0380 18 RTWP 1085 ;]* 1086 * _ _____ ___ __ ____ _ ___ __ _ 1087 * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ 1088 * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< 1089 * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ 1090 * 1091 ;[*== VDP utilities (entry point) ======================================= 1092 * 1093 ** VDP single byte write 1094 * 1095 6968 06A0 32 VSBWEN BL @WVDPWA Write out address 696A 388E 1096 696C D82D 54 MOVB @2(R13),@VDPWD Write data 696E 0002 6970 8C00 1097 6972 0380 18 RTWP Return to calling program 1098 * 1099 ** VDP multiple byte write 1100 * 1101 6974 06A0 32 VMBWEN BL @WVDPWA Write out address 6976 388E 1102 6978 D831 48 VWTMOR MOVB *R1+,@VDPWD Write a byte 697A 8C00 1103 697C 0602 14 DEC R2 Decrement byte count 1104 697E 16FC 14 JNE VWTMOR More to write? 1105 6980 0380 18 RTWP Return to calling Program 1106 * 1107 ** VDP single byte read 1108 * 1109 6982 06A0 32 VSBREN BL @WVDPRA Write out address 6984 3894 1110 6986 DB60 54 MOVB @VDPRD,@2(R13) Read data 6988 8800 698A 0002 1111 698C 0380 18 RTWP Return to calling program 1112 * 1113 ** VDP multiple byte read 1114 * 1115 698E 06A0 32 VMBREN BL @WVDPRA Write out address 6990 3894 1116 6992 DC60 48 VRDMOR MOVB @VDPRD,*R1+ Read a byte 6994 8800 1117 6996 0602 14 DEC R2 Decrement byte count 1118 6998 16FC 14 JNE VRDMOR More to read? 1119 699A 0380 18 RTWP Return to calling program 1120 * 1121 ** VDP write to register 1122 * 1123 699C C05D 26 VWTREN MOV *R13,R1 Get register number and value 1124 699E D82D 54 MOVB @1(R13),@VDPWA Write out value 69A0 0001 69A2 8C02 1125 69A4 0261 22 ORI R1,>8000 Set for register write 69A6 8000 1126 69A8 D801 38 MOVB R1,@VDPWA Write out register number 69AA 8C02 1127 69AC 0380 18 RTWP Return to calling program 1128 * 1129 ** Set up to write to VDP 1130 * 1131 69AE 0201 20 WVDPWA LI R1,>4000 69B0 4000 1132 69B2 1001 14 JMP WVDPAD 1133 * 1134 ** Set up to read VDP 1135 * 1136 69B4 04C1 14 WVDPRA CLR R1 1137 * 1138 ** Write VDP address 1139 * 1140 69B6 C09D 26 WVDPAD MOV *R13,R2 Get VDP address 1141 69B8 D820 54 MOVB @U_R2LB,@VDPWA Write low byte of address 69BA 3A51 69BC 8C02 1142 69BE E081 18 SOC R1,R2 Properly adjust VDP write bit 1143 69C0 D802 38 MOVB R2,@VDPWA Write high byte of address 69C2 8C02 1144 69C4 C06D 34 MOV @2(R13),R1 Get CPU RAM address 69C6 0002 1145 69C8 C0AD 34 MOV @4(R13),R2 Get byte count 69CA 0004 1146 69CC 045B 20 RT Return to calling routine 1147 1148 * 1149 ** VDP-to-VDP move. 1150 * 1151 69CE C05D 26 VMOVEN MOV *R13,R1 Get cnt to R1 1152 69D0 C0AD 34 MOV @2(R13),R2 Get vsrc to R2 69D2 0002 1153 69D4 C0ED 34 MOV @4(R13),R3 Get vdst to R3 69D6 0004 1154 69D8 0263 22 ORI R3,>4000 Prepare for VDP write 69DA 4000 1155 1156 ** copy cnt bytes from vsrc to vdst 1157 1158 69DC D820 54 VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address 69DE 3A51 69E0 8C02 1159 69E2 D802 38 MOVB R2,@VDPWA Write MSB of VDP read address 69E4 8C02 1160 69E6 0582 14 INC R2 Next VDP read address 1161 69E8 D020 34 MOVB @VDPRD,R0 Read VDP byte 69EA 8800 1162 69EC D820 54 MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address 69EE 3A53 69F0 8C02 1163 69F2 D803 38 MOVB R3,@VDPWA Write MSB of VDP write address 69F4 8C02 1164 69F6 0583 14 INC R3 Next VDP write address 1165 69F8 D800 38 MOVB R0,@VDPWD Write VDP byte 69FA 8C00 1166 69FC 0601 14 DEC R1 Decrement count 1167 69FE 16EE 14 JNE VMVMOR Repeat if not done 1168 6A00 0380 18 RTWP Return to calling program 1169 ;]* 1170 ;[*== fbForth Version Message =========================================== 1171 FBFMSG 1172 * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? 1173 * Also, printing the extra blanks overwrites the font-not-found error message. 1174 6A02 11 BYTE 17 1175 6A03 66 TEXT 'fbForth 2.0: ' 6A04 6246 6A06 6F72 6A08 7468 6A0A 2032 6A0C 2E30 6A0E 3A20 6A10 2020 6A12 2020 1176 ;] 1177 * __ ___ ___ ____ __ __ _ __ __ 1178 * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ 1179 * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< 1180 * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ 1181 * 1182 ;[*== Modifiable words in Resident Dictionary =========================== 1183 ;[*** (ABORT) *** 1184 6A14 73CC DATA x#VLST_N <--Last word in ROM 1185 6A16 8728 PABR_N DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT 6A18 4142 6A1A 4F52 6A1C 54A9 1186 1187 6A1E 8334 PABORT DATA DOCOL 1188 6A20 6ADE DATA ABORT,SEMIS 6A22 6358 1189 ;]* 1190 ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] 1191 6A24 38F6 DATA PABR_N 1192 6A26 C546 FRTH_N DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT 6A28 4F52 6A2A 54C8 1193 1194 6A2C 7218 FORTH DATA DOVOC 1195 6A2E A002 FORTHV DATA DPBASE+2 ; vocabulary link field 1196 6A30 81A0 FORTHP DATA >81A0 ; pseudo name field 1197 6A32 0000 FORTHL DATA 0 ; chronological link field 1198 ;]* 1199 ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] 1200 6A34 3906 DATA FRTH_N 1201 6A36 C941 ASMR_N DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT 6A38 5353 6A3A 454D 6A3C 424C 6A3E 45D2 1202 1203 6A40 7218 ASSM DATA DOVOC 1204 ; Initially points to last word in ASSEMBLER vocabulary in the kernel 1205 6A42 394A ASMV DATA SASM_N ; vocabulary link field 1206 6A44 81A0 DATA >81A0 ; pseudo name field 1207 6A46 3912 ASML DATA FORTHL ; chronological link field 1208 1209 * 1210 ;]* 1211 ;]* 1212 * ___ __ __ 1213 * / _ | ___ ___ ___ __ _ / / / /__ ____ 1214 * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ 1215 * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ 1216 * _ __ __ __ _ __ __ 1217 * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ 1218 * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< 1219 * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ 1220 * /___/ 1221 * 1222 *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary 1223 ;[*** NEXT, *** ( --- ) 1224 * 1st word in ASSEMBLER vocabulary 1225 * 1226 6A48 3910 DATA FORTHP <--points to PNF of FORTH 1227 6A4A 854E NXT__N DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT 6A4C 4558 6A4E 54AC 1228 1229 6A50 3932 NEXTC DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! 1230 6A52 0200 20 NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) 6A54 045F 1231 6A56 C068 34 MOV @$DP(U),R1 HERE to R1 6A58 0012 1232 6A5A CC40 34 MOV R0,*R1+ compile "B *NEXT" 1233 6A5C CA01 38 MOV R1,@$DP(U) update HERE 6A5E 0012 1234 6A60 CA28 54 MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary 6A62 0058 6A64 0056 1235 6A66 045F 20 B *NEXT back to inner interpreter 1236 1237 * : NEXT, ( --- ) 1238 * *NEXT B, ; 1239 ;]* 1240 ;[*** ;ASM *** ( --- ) 1241 * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by 1242 * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. 1243 * 1244 6A68 392A DATA NXT__N 1245 6A6A 84 SASM_N BYTE 4+TERMBT <--note different name field format 1246 6A6B 3B TEXT ';ASM' 6A6C 4153 6A6E 4D 1247 6A6F A0 BYTE ' '+TERMBT 1248 1249 6A70 3952 SASM DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! 1250 6A72 10EF 14 JMP NXT_P finish up in NEXT, 1251 1252 * : ;ASM ( --- ) 1253 * *NEXT B, ; 1254 ;]* 1255 1256 ;[*== Some Variables (KEYCNT etc.) ====================================== 1257 1258 6A74 FFFF KEYCNT DATA -1 Used in cursor flash logic 1259 6A76 0000 INTACT DATA 0 Non-zero during user's interrupt service routine 1260 * 1261 *++ variables used by some graphics primitives 1262 * 1263 6A78 0000 $DMODE DATA 0 ; actual location of variable contents 1264 6A7A FFFF $DCOL DATA -1 ; actual location of variable contents 1265 1266 *=========================================================== 1267 ;]* 1268 * ______ ___ _____ __ 1269 * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ 1270 * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) 1271 * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ 1272 * /_/ 1273 * 1274 ;[*== Trampoline Code =================================================== 1275 * 1276 * MYBANK must be at same location in all banks with the code that appears 1277 * in the following table. The EQUates for BANK0--BANK3 may also be in the 1278 * same places in each bank for convenience, but they only need to appear once. 1279 * 1280 * Bank Select MYBANK 1281 * ---- ------ ------ 1282 * 0 >6006 >C000 1283 * 1 >6004 >8000 1284 * 2 >6002 >4000 1285 * 3 >6000 >0000 1286 * 1287 * Bank0 code will look like this 1288 * 1289 * MYBANK DATA >C000 1290 * BANK0 EQU >C000 1291 * BANK1 EQU >8000 1292 * BANK2 EQU >4000 1293 * BANK3 EQU >0000 1294 * 1295 * Banks 1--3 will look the same, including labels, and the DATA 1296 * instruction at MYBANK's location will correspond to its bank. 1297 * 1298 * Before a bank is selected, the values above will be shifted right 13 1299 * bits and have >6000 added. 1300 * 1301 ;[*** BLBANK ************************************************************ 1302 * 1303 * General bank branching routine (32KB ROM, i.e., 4 banks) for a 1304 * branch that is expected to return (not high-level Forth) via RTBANK--- 1305 * --put in scratchpad or low RAM 1306 * --called by 1307 * BL @BLBANK 1308 * DATA dst_addr - >6000 + bank# in left 2 bits 1309 * 1310 6A7C 064E 14 BLBANK DECT R ; reserve space on return stack (R14) 1311 6A7E C33B 30 MOV *LINK+,CRU ; copy destination bank address to R12 1312 6A80 C78B 30 MOV LINK,*R ; push return address 1313 6A82 064E 14 DECT R ; reserve space on return stack 1314 6A84 C7A0 46 MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) 6A86 7FFE 1315 6A88 C2CC 18 MOV CRU,LINK ; copy destination bank address to R11 1316 6A8A 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6A8C 1FFF 1317 6A8E 022B 22 AI LINK,>6000 ; make it a real address 6A90 6000 1318 6A92 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1319 6A94 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6A96 6000 1320 6A98 04DC 26 CLR *CRU ; switch to destination bank 1321 6A9A 045B 20 B *LINK ; branch to destination address 1322 ;]* 1323 ;[*** RTBANK ************************************************************ 1324 * 1325 * General bank return routine (32KB ROM, i.e., 4 banks)--- 1326 * --put in scratchpad or low RAM 1327 * --called by 1328 * B @RTBANK 1329 * 1330 6A9C C33E 30 RTBANK MOV *R+,CRU ; pop return bank# from return stack to R12 1331 6A9E 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1332 6AA0 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6AA2 6000 1333 6AA4 C2FE 30 MOV *R+,LINK ; pop return address from return stack 1334 6AA6 04DC 26 CLR *CRU ; switch to destination bank 1335 6AA8 045B 20 B *LINK ; branch to return address 1336 ;]* 1337 ;[*** BLF2A ************************************************************* 1338 * 1339 * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 1340 * banks) that is expected to return to bank0 via RTNEXT. This will 1341 * only(?) be used for the ALC payload of Forth stubs in bank0--- 1342 * --put in scratchpad or low RAM 1343 * --called by 1344 * BL @BLF2A 1345 * DATA dst_addr - >6000 + bank# in left 2 bits 1346 * 1347 6AAA C2DB 26 BLF2A MOV *LINK,LINK ; copy destination bank address to R11 1348 6AAC C30B 18 MOV LINK,CRU ; copy it to R12 1349 6AAE 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6AB0 1FFF 1350 6AB2 022B 22 AI LINK,>6000 ; make it a real address 6AB4 6000 1351 6AB6 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1352 6AB8 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6ABA 6000 1353 6ABC 04DC 26 CLR *CRU ; switch to destination bank 1354 6ABE 045B 20 B *LINK ; branch to destination address 1355 ;]* 1356 ;[*** RTNEXT ************************************************************ 1357 * 1358 * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 1359 * banks)--- 1360 * --put in scratchpad or low RAM 1361 * --called by 1362 * B @RTNEXT 1363 * 1364 6AC0 C320 34 RTNEXT MOV @INTACT,CRU Are we in user's ISR? 6AC2 3956 1365 6AC4 1602 14 JNE RTNXT1 Don't enable interrupts if so. 1366 6AC6 0300 24 LIMI 2 6AC8 0002 1367 6ACA 04E0 34 RTNXT1 CLR @>6006 ; switch to bank 0 6ACC 6006 1368 6ACE 045F 20 B *NEXT ; branch to next CFA (in R15) 1369 ;]* 1370 ;[*** BLA2F ************************************************************* 1371 * 1372 * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 1373 * banks) that is expected to return to calling bank via RTA2F--- 1374 * --put in scratchpad or low RAM 1375 * --called by 1376 * BL @BLA2F 1377 * DATA <Forth cfa in bank0> 1378 * 1379 6AD0 064E 14 BLA2F DECT R ; reserve space on return stack 1380 6AD2 C2BB 30 MOV *LINK+,W ; move CFA of Forth routine to W 1381 6AD4 C78B 30 MOV LINK,*R ; push return address of calling bank 1382 6AD6 064E 14 DECT R ; reserve space on return stack 1383 6AD8 C7A0 46 MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) 6ADA 7FFE 1384 6ADC 064E 14 DECT R ; reserve spot on return stack 1385 6ADE C78D 30 MOV IP,*R ; move current IP to return stack 1386 6AE0 020D 20 LI IP,RTA2F ; move address of return procedure to IP 6AE2 39CC 1387 6AE4 04E0 34 CLR @>6006 ; switch to bank0 6AE6 6006 1388 6AE8 0460 28 B @DOEXEC ; Execute the Forth routine 6AEA 833C 1389 ;]* 1390 ;[*** RTA2F ************************************************************* 1391 * 1392 * ALC to high-level Forth bank "return" routine from Forth to calling 1393 * ALC (32KB ROM, i.e., 4 banks)--- 1394 * --put in scratchpad or low RAM 1395 * --called through B *NEXT at end of Forth word's execution in BLA2F 1396 * 1397 6AEC 39CE RTA2F DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) 1398 6AEE 39D0 DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) 1399 6AF0 C37E 30 MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) 1400 * Retrieve ALC return info and return to caller... 1401 * ...caller will execute B *NEXT when it finishes 1402 6AF2 0460 28 B @RTBANK ; branch to general bank return routine above 6AF4 397C 1403 ;]* 1404 ;]*********************************************************************** 1405 ;[*++ Bank-specific cell-/byte-reading code ++* 1406 ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) 1407 *++ Read cell contents of address in Bank bank# or RAM. 1408 *++ Register inputs: 1409 *++ R0: bank-switch address 1410 *++ R1: address in bank# to be read 1411 1412 6AF6 04D0 26 _BKAT CLR *R0 ; switch banks 1413 6AF8 C651 38 MOV *R1,*SP ; get cell contents of address to stack 1414 6AFA 0460 28 B @RTNEXT ; return to inner interpreter 6AFC 39A0 1415 ;]* 1416 ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) 1417 *++ Read byte contents of address in Bank bank# or RAM. 1418 *++ Register inputs: 1419 *++ R0: bank-switch address 1420 *++ R1: address in bank# to be read 1421 1422 6AFE 04D0 26 _BKCAT CLR *R0 ; switch banks 1423 6B00 04C2 14 CLR R2 ; clear R2 1424 6B02 D811 46 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 6B04 8305 1425 6B06 C642 30 MOV R2,*SP ; get byte contents of address to stack 1426 6B08 0460 28 B @RTNEXT ; return to inner interpreter 6B0A 39A0 1427 1428 ;]* 1429 1430 ;]* 1431 * _______ __ _________ ___ __ 1432 * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ 1433 * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / 1434 * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / 1435 * /___/ 1436 * 1437 ;[*** SAMS! *** ( --- ) 1438 * This calls the SAMS initialization in the startup code in bank 1. 1439 * 1440 * DATA SMSQ_N 1441 * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT 1442 * SAMSST DATA $+2 1443 * BL @BLF2A 1444 * DATA _SMSST->6000+BANK1 1445 1446 6B0C 06A0 32 _SMSST BL @SMSINI initialize SAMS card 6B0E 610C 1447 6B10 0460 28 B @RTNEXT back to inner interpreter 6B12 39A0 1448 ;]* 1449 ;[*== Required strings, tables, variables... ============================ 1450 * 1451 * 1452 * Default blocks filename 1453 * 1454 6B14 0C DEFNAM BYTE 12 1455 6B15 44 TEXT "DSK1.FBLOCKS " 6B16 534B 6B18 312E 6B1A 4642 6B1C 4C4F 6B1E 434B 6B20 5320 1456 * 1457 * Default colors for all VDP modes--- 1458 * MSB: Screen color (LSN); text FG (MSN), BG (LSN) 1459 * LSB: Color Table colors (FG/BG) 1460 * 1461 6B22 4F00 DEFCOL DATA >4F00 ; TEXT80 offset=0 1462 6B24 4F00 DATA >4F00 ; TEXT offset=2 1463 6B26 F4F4 DATA >F4F4 ; GRAPHICS offset=4 1464 6B28 11F4 DATA >11F4 ; MULTI offset=6 1465 6B2A FE10 DATA >FE10 ; GRAPHICS2 offset=8 1466 6B2C FEF4 DATA >FEF4 ; SPLIT offset=10 1467 6B2E FEF4 DATA >FEF4 ; SPLIT2 offset=12 1468 * 1469 * Default text mode 1470 * 1471 6B30 0001 DEFTXT DATA >0001 1472 * 1473 * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB 1474 * 1475 6B32 0000 FNTFLG DATA 0 ; font flag initially 0 1476 * 1477 * Speech variables needing initial value (more below LLVEND) 1478 * 1479 6B34 0000 SPCSVC DATA 0 1480 * 1481 * Sound Table #1 Workspace for sound variables. Only using R0..R4 1482 * 1483 SND1WS 1484 6B36 0000 SND1ST DATA 0 ; R0 (sound table status) 0=no table.. 1485 ; ..1=loading sound bytes..-1=counting 1486 6B38 8400 SND1DS DATA SOUND ; R1 (sound-table byte destination).. 1487 ; ..initialized to sound chip 1488 6B3A 0000 SND1AD DATA 0 ; R2 (sound table address) 1489 6B3C 0000 SND1CT DATA 0 ; R3 (# of sound bytes to load or.. 1490 ; ..sound count = seconds * 60) 1491 6B3E 3AE4 SND1SP DATA SNDST0 ; R4 (pointer to top of sound stack).. 1492 ; ..initialized to bottom of sound stack 1493 * 1494 * Sound Table #2 Workspace for sound variables. Only using R0..R3 1495 * 1496 SND2WS 1497 6B40 0000 SND2ST DATA 0 ; R0 (sound table status) 0=no table.. 1498 ; ..1=loading sound bytes..-1=counting 1499 6B42 8400 SND2DS DATA SOUND ; R1 (sound-table byte destination) init to sound chip 1500 ;]* 1501 * 1502 * This is the end of low-level support code that gets copied. 1503 * 1504 LLVEND 1505 1506 ;[*== Un-initialized Variables and workspaces... ========================= 1507 * Start of definitions of variables and workspaces that do not need to 1508 * take up space in ROM because they need no initial values. 1509 * 1510 * Sound Table #2 Workspace for sound variables..continued. 1511 * 1512 3A24 SND2AD EQU SND2WS+4 ; R2 (sound table address) 1513 3A26 SND2CT EQU SND2WS+6 ; R3 (# of sound bytes to load or.. 1514 * ; ..sound count = seconds * 60) 1515 3A28 SDMUTE EQU SND2WS+8 ; dummy destination for sound byte 1516 * 1517 * Branch Stack for ISR processing of Speech, 2 Sound Tables and return 1518 * 1519 3A2A BRSTK EQU SDMUTE+2 1520 * 1521 * Speech variables (more above LLVEND) 1522 * 1523 3A32 SSFLAG EQU BRSTK+8 1524 3A34 SPCNT EQU SSFLAG+2 1525 3A36 SPADR EQU SPCNT+2 1526 3A38 BANKSV EQU SPADR+2 1527 3A3A PADSV EQU BANKSV+2 1528 * 1529 * Panel window: height, width and screen position...used by PANEL and SCROLL 1530 * 1531 3A46 PANWIN EQU PADSV+12 panel height, width and screen start 1532 1533 *== Utility Workspace ================================================= 1534 *** General utility workspace registers 1535 3A4C UTILWS EQU PANWIN+6 1536 3A51 U_R2LB EQU UTILWS+5 1537 1538 3A6C LINBUF EQU UTILWS+32 1539 3ABC CURCHR EQU LINBUF+80 1540 1541 *++ variable used by the 40/80-column editor 1542 3ABE OLDCUR EQU CURCHR+2 1543 1544 *++ FILE I/O variables 1545 1546 3AC6 PBADR EQU OLDCUR+8 1547 3AC8 PBBF EQU PBADR+2 1548 3ACA PBVBF EQU PBBF+2 1549 1550 *++ Floating Point Math Library variables 1551 3ACC FPVARS EQU PBVBF+2 1552 1553 *++ SAMS flag 1554 3AE2 SAMSFL EQU FPVARS+22 1555 1556 *++ Bottom of Sound Stack 1557 *++ This location marks the top of the low-level support code. The Sound 1558 *++ Stack grows upward toward the Return Stack by moving the entire stack 1559 *++ up one cell to make room for the next new bottom entry. 1560 3AE4 SNDST0 EQU SAMSFL+2 1561 ;]* 1562 1563 AORG 1564 BANK 1 Here is the code it replaced: Reveal hidden contents * __ __ __ * / / ___ _ ______/ / ___ _ _____ / / * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / * /____/\___/__,__/ /____/\__/|___/\__/_/ * ____ __ * / __/_ _____ ___ ___ ____/ /_ * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ * /___/\_,_/ .__/ .__/\___/_/ \__/ * /_/ /_/ * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * fbForth--- * * * * Low-level support routines * * * * << Including Trampoline Code, tables & variables: 2606 bytes >> * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * LLVSPT ; <--This is the source copy location for the rest of this code. $BUFF EQU >2010 * 4 I/O buffers below ($LO = >3020) * Change '4' to number of buffers needed and for which there is room. $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers * _____ ____ __ __ ___________ * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| * ;[*** Interrupt Service ======================================================= * This routine is executed for every interrupt. It processes any pending * speech and souind. It then looks to see whether a user ISR is installed in * ISR. If so, it sets up NEXT for execution of the user ISR. This will work * only if the user has installed an ISR using the following steps in the fol- * lowing order: * * (1) Write an ISR with entry point, say MYISR. * (2) Determine code field address of MYISR with this high-level Forth: * ' MYISR CFA * <<< Maybe need a word to do #3 >>> * (3) Write CFA of MYISR into user variable ISR. * * Steps (2)-(3) in high-level Forth are shown below: * ' MYISR CFA * ISR ! * * <<< Perhaps last step above should be by a word that disables interrupts >>> * * The console ISR branches to the contents of >83C4 because it is non-zero, * with the address, INT1, of the fbForth ISR entry point below (also, the * contents of INTLNK). This means that the console ISR will branch to INT1 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first * process any pending speech and sound. * * If the user's ISR is properly installed, the code that processes the user * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed * from Forth's workspace (MAINWS), the code at INT2 will process the user's * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's * inner interpreter. *** ========================================================================== * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! INT1 EQU $LO+$-LLVSPT LI R0,BRSTK load address of top of Branch Address Stack * * Set up for pending speech * MOV @SPCSVC,*R0 save Speech service address onto Branch Stack JEQ SNDCH1 jump to sound-check if no speech INCT R0 increment Branch Stack * * Set up for pending sound table #1 (ST#1) * SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? JEQ SNDCH2 process speech and sound if needed LI R1,x#PLAYT1 load PLAYT1 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Set up for pending sound table #2 (ST#2) * SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? JEQ PRCSPS process speech and sound if needed LI R1,x#PLAYT2 load PLAYT2 address and... MOV R1,*R0+ ...push it onto Branch Stack * * Process sound stack if both sound tables idle * PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? JNE PRSPS2 nope..skip sound stack processing LWPI SND1WS switch to ST#1 WS CI R4,SNDST0 anything on sound stack? JEQ PRSPS1 no..exit sound stack processing DECT R4 pop sound stack position MOV *R4,R2 get sound table address from sound stack INC R0 kick off sound processing of ST#1 (R0=1) PRSPS1 LWPI GPLWS switch back to GPL WS * * Check for any pending speech and sound * PRSPS2 CI R0,BRSTK any speech or sound to process? JEQ USRISR if not, jump to user ISR processing LI R1,BNKRST yup..load return address MOV R1,*R0 push return address onto Branch Stack * * Process pending speech and sound * MOV @x#MYBANK,@BANKSV save bank at interrupt CLR @>6002 switch to bank 2 for speech & sound services LI R7,BRSTK load top of Branch Stack MOV *R7+,R8 pop speech/sound ISR B *R8 service speech/sound * * Restore interrupted bank * BNKRST EQU $LO+$-LLVSPT return point for speech and sound ISRs MOV @BANKSV,R0 restore bank at interrupt SRL R0,13 get the bank# to correct position AI R0,>6000 make it a real bank-switch address CLR *R0 switch to the bank at interrupt * * Process User ISR if defined * USRISR MOV @$ISR+$UVAR,R0 User ISR installed? JEQ INTEX * * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) * is executed from Forth's WS (MAINWS = >8300), which it does at the end of * every CODE word, keyboard scan and one or two other places. * LI R1,INT2 Load entry point, INT2 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) * * The following 2 instructions are copies of the remainder of the console ROM's * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) * because we're not going back there! * INTEX LWPI >83C0 Change to console's ISR WS RTWP Return to caller of console ISR * * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored * before executing user's ISR. INT3 (cleanup routine below) will be inserted * in address list to get us back here for cleanup after user's ISR has finished. * User's ISR is executed at the end of this section just before INT3. * INT2 EQU $LO+$-LLVSPT LIMI 0 Disable interrupts MOVB @>83D4,R0 Get copy of VR01 SRL R0,8 ...to LSB ORI R0,>100 Set up for VR01 ANDI R0,>FFDF Clear VDP-interrupt-enable bit BLWP @VWTR Turn off VDP interrupt LI NEXT,$NEXT Restore NEXT SETO @INTACT Set Forth "pending interrupt" flag DECT R Set up return linkage by pushing MOV IP,*R ...IP (R13, next Forth CFA) to return stack and LI IP,INT3 ...setting IP to INT3 (below) for cleanup MOV @$ISR(U),W Do the user's Forth ISR by executing B @DOEXEC ...it through Forth's inner interpreter * * Clean up and re-enable interrupts. * INT3 EQU $LO+$-LLVSPT DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) MOV *R+,IP Start cleanup: pop IP from before call to user's ISR CLR @INTACT Clear Forth "pending interrupt" flag MOVB @>83D4,R0 Prepare to restore VR01 by... SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and AI R0,>100 ...VR # (01) to MSB MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status BLWP @VWTR Write VR01 LIMI 2 Re-enable interrupts B *NEXT Continue normal task ;]* ;[*** BKLINK from SYSTEM calls ========================================== * BKLINK EQU $LO+$-LLVSPT MOV @INTACT,R7 Are we in user's ISR? JNE BKLIN1 Don't enable interrupts if so. LIMI 2 BKLIN1 B *LINK ;]* * ____ __ _____ ____ * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ * /___/ * ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== * Entry point for low-level system support functions $SYS$ EQU $LO+$-LLVSPT LIMI 0 MOV @SYSTAB(R1),R0 B *R0 ;] ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== DATA BRW CODE = -20 write block to blocks file DATA BRW CODE = -18 read block from blocks file DATA BRW CODE = -16 create blocks file DATA BRW CODE = -14 use blocks file DATA GXY CODE = -12 GOTOXY DATA QKY CODE = -10 ?KEY DATA QTM CODE = -8 ?TERMINAL DATA CLF CODE = -6 CRLF DATA EMT CODE = -4 EMIT DATA KY CODE = -2 KEY SYSTAB EQU $LO+$-LLVSPT DATA SBW CODE = 0 VSBW DATA MBW CODE = 2 VMBW DATA SBR CODE = 4 VSBR DATA MBR CODE = 6 VMBR DATA WTR CODE = 8 VWTR DATA GPL CODE = 10 GPLLNK DATA XML CODE = 12 XMLLNK DATA DSR CODE = 14 DSRLNK DATA CLS$ CODE = 16 CLS DATA MVE CODE = 18 VMOVE DATA FILL$ CODE = 20 VFILL DATA AOX CODE = 22 VAND DATA AOX CODE = 24 VOR DATA AOX CODE = 26 VXOR ;]* ;[*== VDP single byte write. CODE = 0 ================= * SBW EQU $LO+$-LLVSPT MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 Character to write SWPB R1 Get in left byte BLWP @VSBW B @BKLINK ;]* ;[*== VDP multi byte write. CODE = 2 ================= * MBW EQU $LO+$-LLVSPT MOV *SP+,R2 Number of bytes to move MOV *SP+,R0 VRAM address (destination) MOV *SP+,R1 RAM address (source) BLWP @VMBW B @BKLINK ;]* ;[*== VDP single byte read. CODE = 4 ================= * SBR EQU $LO+$-LLVSPT MOV *SP,R0 VRAM address (source) BLWP @VSBR SRL R1,8 Character to right half for Forth MOV R1,*SP Stack it B @BKLINK ;]* ;[*== VDP multi byte read. CODE = 6 ================= * MBR EQU $LO+$-LLVSPT MOV *SP+,R2 Number of bytes to read MOV *SP+,R1 RAM address (destination) MOV *SP+,R0 VRAM address (source) BLWP @VMBR B @BKLINK ;]* ;[*== VDP-to-VDP move. CODE = 18 ================= * MVE EQU $LO+$-LLVSPT MOV *SP+,R0 Pop cnt to R0 MOV *SP+,R2 Pop vdst to R2 MOV *SP+,R1 Pop vsrc to R1 BLWP @VMOVE B @BKLINK ;]* ;[*== VDP register write. CODE = 8 ================= * WTR EQU $LO+$-LLVSPT MOV *SP+,R1 VDP register number MOV *SP+,R0 Data for register SWPB R1 Get register to left byte MOVB R1,R0 Place with data BLWP @VWTR B @BKLINK ;]* ;[*== GPL link utility. CODE = 10 ================= * GPL EQU $LO+$-LLVSPT CLR R0 MOVB R0,@KYSTAT LI R0,>0420 Construct the BLWP instruction LI R1,GPLLNK to the GPLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== XML link utility. CODE = 12 ================= * XML EQU $LO+$-LLVSPT LI R0,>0420 Construct the BLWP instruction LI R1,XMLLNK to the XMLLNK utility MOV *SP+,R2 with this datum identifying the routine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== DSR link utility. CODE = 14 ================= * DSR EQU $LO+$-LLVSPT LI R0,>0420 Construct the BLWP instruction LI R1,DSRLNK to the DSRLNK utility MOV *SP+,R2 This datum selects DSR or subroutine LI R3,>045B Construct the B *LINK instruction MOV LINK,R4 Save LINK address BL @2*R0+MAINWS Execute the above instructions MOV R4,LINK and reconstruct LINK B @BKLINK ;]* ;[*== Screen clearing utility. CODE = 16 ================= * CLS$ EQU $LO+$-LLVSPT MOV @$SSTRT(U),R2 Beginning of screen in VRAM MOV @$SEND(U),R1 End of screen in VRAM S R2,R1 Screen size LI R0,>2000 Blank character MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== VDP fill routine. CODE = 20 ================= * FILL$ EQU $LO+$-LLVSPT MOV *SP+,R0 Fill character SWPB R0 to left byte MOV *SP+,R1 Fill count MOV *SP+,R2 Address to start VRAM fill MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK *======================================================================== FILL1 EQU $LO+$-LLVSPT R0=char, R1=cnt, R2=vaddr ORI R2,>4000 Set bit for VDP write SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time FLOOP MOVB R0,@VDPWD Write a byte DEC R1 JNE FLOOP Not done, fill another B *LINK ;]*====================================================================== * *==== VAND -- VDP byte AND routine. CODE = 22 ================= *==== VOR -- VDP byte OR routine. CODE = 24 ================= ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= * AOX EQU $LO+$-LLVSPT MOV *SP+,R2 VRAM address SWPB R2 MOVB R2,@VDPWA LS byte first SWPB R2 MOVB R2,@VDPWA Then MS byte NOP Kill time MOVB @VDPRD,R3 Read byte MOV *SP+,R0 Get data to operate with SWPB R0 to left byte *** Now do requested operation ***************** CI R1,24 JEQ DOOR JGT DOXOR INV R3 These two instructions SZC R3,R0 perform an 'AND' JMP FINAOX DOOR SOC R3,R0 perform 'OR' JMP FINAOX DOXOR XOR R3,R0 perform 'XOR' FINAOX LI R1,1 MOV LINK,R7 BL @FILL1 MOV R7,LINK B @BKLINK ;]* ;[*== KEY routine CODE = -2 ================= * KY EQU $LO+$-LLVSPT MOV @$ALTI(U),R0 alternate input device? JEQ KEY0 jump to keyboard input if not * * R0 now points to PAB for alternate input device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to read one byte. * CLR R7 prepare to zero status byte MOVB R7,@KYSTAT zero status byte INC R0 point R0 to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB MOV R0,R1 Set up pointer... AI R1,8 ...to namelength byte of PAB MOV R1,@SUBPTR copy to DSR subroutine name-length pointer MOV R0,R3 save pointer (DSRLNK will trash it!) BLWP @DSRLNK get 1 byte from device DATA >8 MOV R3,R0 restore pointer DECT R0 point to one-byte VRAM buffer in front of PAB BLWP @VSBR read character SRL R1,8 move to LSB MOV R1,R0 copy to return register B @BKLINK return to caller * * Input is comining from the keyboard * KEY0 MOV @KEYCNT,R7 INC R7 JNE KEY1 MOV @CURPO$(U),R0 BLWP @VSBR Read character at cursor position... MOVB R1,@CURCHR ...and save it LI R1,>1E00 Place cursor character on screen BLWP @VSBW * KEY1 BLWP @KSCAN MOVB @KYSTAT,R0 COC @H2000,R0 check status JEQ KEY2 JMP if key was pressed * CI R7,100 No key pressed JNE KEY3 MOVB @CURCHR,R1 JMP KEY5 * KEY3 CI R7,200 JNE KEY4 CLR R7 LI R1,>1E00 Cursor char KEY5 MOV @CURPO$(U),R0 BLWP @VSBW KEY4 MOV R7,@KEYCNT MOV @INTACT,R7 Are we in user's ISR? JNE KEY6 Don't enable interrupts if so. LIMI 2 KEY6 DECT IP This will re-execute KEY B *NEXT KEY2 SETO @KEYCNT Key was pressed MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 B @BKLINK ;]* ;[*== EMIT routine CODE = -4 ================= * EMT EQU $LO+$-LLVSPT MOV R2,R1 copy char to R1 for VSBW MOV @$ALTO(U),R0 alternate output device? JEQ EMIT0 jump to video display output if not * * R0 now points to PAB for alternate output device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to write one byte. * CLR R7 ALTOUT active MOVB R7,@KYSTAT zero status byte DEC R0 point to one-byte VRAM buffer in front of PAB SWPB R1 char to MSB BLWP @VSBW write char to buffer INCT R0 point to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB AI R0,8 Set up pointer to namelength byte of PAB MOV R0,@SUBPTR copy to DSR subroutine name-length pointer BLWP @DSRLNK put 1 byte to device DATA >8 B @BKLINK return to caller * * Output is going to the video display * EMIT0 CI R1,7 Is it a bell? JNE NOTBEL CLR R2 MOVB R2,@KYSTAT BLWP @GPLLNK DATA >0036 Emit error tone JMP EMEXIT * NOTBEL CI R1,8 Is it a backspace? JNE NOTBS LI R1,>2000 MOV @CURPO$(U),R0 BLWP @VSBW JGT DECCUR JMP EMEXIT DECCUR DEC @CURPO$(U) JMP EMEXIT * NOTBS CI R1,>A Is it a line feed? JNE NOTLF MOV @$SEND(U),R7 S @$SWDTH(U),R7 C @CURPO$(U),R7 JHE SCRLL A @$SWDTH(U),@CURPO$(u) JMP EMEXIT SCRLL MOV LINK,R7 BL @SCROLL MOV R7,LINK JMP EMEXIT * *** SCROLLING ROUTINE * SCROLL EQU $LO+$-LLVSPT MOV @$SSTRT(U),R0 VRAM addr LI R1,LINBUF Line buffer MOV @$SWDTH(U),R2 Count A R2,R0 Start at line 2 SCROL1 BLWP @VMBR S R2,R0 One line back to write BLWP @VMBW A R2,R0 Two lines ahead for next read A R2,R0 C R0,@$SEND(U) End of screen? JL SCROL1 MOV R2,R1 Blank bottom row of screen LI R0,>2000 Blank S @$SEND(U),R2 NEG R2 Now contains address of start of last line MOV LINK,R6 BL @FILL1 Write the blanks B *R6 * NOTLF CI R1,>D Is it a carriage return? JNE NOTCR CLR R0 MOV @CURPO$(U),R1 MOV R1,R3 S @$SSTRT(U),R1 Adjusted for screen not at 0 MOV @$SWDTH(U),R2 DIV R2,R0 S R1,R3 MOV R3,@CURPO$(U) JMP EMEXIT * NOTCR SWPB R1 Assume it is a printable character MOV @CURPO$(U),R0 BLWP @VSBW MOV @$SEND(U),R2 DEC R2 C R0,R2 JNE NOTCR1 MOV @$SEND(U),R0 S @$SWDTH(U),R0 Was last char on screen. Scroll MOV R0,@CURPO$(U) JMP SCRLL NOTCR1 INC R0 No scroll necessary MOV R0,@CURPO$(U) * EMEXIT B @BKLINK ;]* ;[*== CRLF routine CODE = -6 ================= * CLF EQU $LO+$-LLVSPT MOV LINK,R5 LI R2,>000D BL @EMT EMT will alter INT mask via B @BKLINK LI R2,>000A LIMI 0 Previous call to EMT altered INT mask BL @EMT MOV R5,LINK B @BKLINK ;]* ;[*== ?TERMINAL routine CODE = -8 ================= * scan for <clear>, <break>, FCTN+4 press * QTM EQU $LO+$-LLVSPT MOV LINK,R5 save return BL @>0020 branch to console's test for <clear> STST R0 store status in R0 JNE QTM2 exit if not <clear> QTM1 BL @>0020 check for <clear> again JEQ QTM1 loop until not <clear> QTM2 MOV R5,LINK restore return ANDI R0,>2000 keep only EQU bit B @BKLINK return to caller ;]* ;[*== ?KEY routine CODE = -10 ================= * QKY EQU $LO+$-LLVSPT BLWP @KSCAN MOVB @KYCHAR,R0 SRL R0,8 CI R0,>00FF JNE QKEY1 CLR R0 QKEY1 B @BKLINK ;]* ;[*== GOTOXY routine CODE = -12 ================= * GXY EQU $LO+$-LLVSPT MPY @$SWDTH(U),R3 A R2,R4 Position within screen A @$SSTRT(U),R4 Add VRAM offset to screen top MOV R4,@CURPO$(U) B @BKLINK ;] * ___ __ __ ____ ______ * / _ )/ /__ ____/ /__ / _/_/_/ __ \ * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / * /____/_/\___/\__/_/\_\ /___/_/ \____/ * *== USE blocks file CODE = -14 ================= *== CREATE blocks file CODE = -16 ================= *== READ block from blocks file CODE = -18 ================= *== WRITE block to blocks file CODE = -20 ================= ;[*== Block File I/O Support ============================================ * * BPTOG utility to toggle one of 2 PABs for block file access * BPTOG EQU $LO+$-LLVSPT MOV @$BPOFF(U),R0 PAB offset to R0 LI R1,70 Toggle amount XOR R0,R1 New offset MOV R1,@$BPOFF(U) Update offset * **xxx** entry point to insure we have correct PAB address BPSET EQU $LO+$-LLVSPT MOV @$DKBUF(U),R0 Get DISK_BUF address A @$BPABS(U),R0 Get BPABS address * A @$BPOFF(U),R0 Add current offset MOV R0,@BFPAB Update current block file's PAB address RT * * CLOSE blocks file * BKCLOS EQU $LO+$-LLVSPT MOV @BFPAB,R0 LI R1,$FCLS Opcode=CLOSE BLWP @VSBW AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Close the file DATA 8 RT Deal with error in caller * * storage area * SVBRET EQU $LO+$-LLVSPT DATA 0 Storage for LINK coming into BRW BFPAB EQU $LO+$-LLVSPT DATA 0 Storage for current blocks file PAB address... * ...will have current PAB on entry * PAB header storage * PABHD EQU $LO+$-LLVSPT BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative * >03=OUTPUT mode + " * >01=UPDATE mode + " * BYTE 2,3: save contents of DISK_BUF here BYTE >80 Record length BYTE >80 Character count of transfer BSS 2 Record number * *** file I/O equates * $FOPN EQU >0000 $FCLS EQU >0100 $FRD EQU >0200 $FWRT EQU >0300 $FRST EQU >0400 $FINP EQU 5 $FOUT EQU 3 $FUPD EQU 1 * *** BRW -- entry point for block read/write routines * BRW EQU $LO+$-LLVSPT MOV LINK,@SVBRET Save LINK address MOV R1,R7 Save CODE {R1 to R7} SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) BL @BPSET Insure correct PAB address in BFPAB (it may have moved) CI R7,4 USE or CREATE? JLT BRW01 No BL @BPTOG Yes...toggle BPOFF & BFPAB MOV @BFPAB,R0 Load PAB address AI R0,9 Set to name length byte CLR R2 MOV *SP+,R1 Pop bfnaddr to R1 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 INC R2 Add 1 to # bytes to copy BLWP @VMBW Copy char count & pathname to PAB * *** set up PAB for OPEN * BRW01 LI R1,$FUPD Opcode=0,mode=update CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? JOP BRW02 No LI R1,$FINP Yes...change mode=input BRW02 MOV R1,@PABHD Put in PAB header MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header CLR R0 MOV R0,@PABHD+6 Set record#=0 MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 Copy first 8 bytes of PAB header BLWP @VMBW Do the copy * *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] * AI R0,9 Address of filename's char count in PAB MOV R0,@SUBPTR Point to-----^^^^ BLWP @DSRLNK Open/create the file DATA 8 JEQ BKERR CI R7,4 READ or WRITE? JLT BRW04 Yes JGT BRWDON No; =USE; we're done * *** write blank records to newly created blocks file [CODE = -16,CREATE] * MOV *SP+,R5 No; = CREATE; pop #blocks from stack SLA R5,3 Convert #blocks to #records MOV R5,R3 Save MOV R5,R4 Set up counter LI R0,$FWRT+$FUPD Set up for WRITE MOV R0,@PABHD Copy to PAB header BRLOOP S R4,R5 Calculate next record MOV R5,@PABHD+6 Copy to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy AI R0,9 Address of filename's char count MOV R0,@SUBPTR Point to filename's char count BLWP @DSRLNK Write one record of blanks DATA 8 JEQ BKERR MOV R3,R5 Get #blocks DEC R4 Count down 1 record JNE BRLOOP Write another record if not done JMP BRWDON We're done * *** prepare for read/write block * BRW04 MOV *SP+,R5 Pop block# to write MOV *SP+,R6 Pop bufaddr DEC R5 Block#-1 SLA R5,3 Convert to starting record# LI R4,8 Load counter for 8 records LI R0,$FWRT+$FUPD Set up for WRITE LI R3,VMBW WRITE vector CI R7,2 Are we writing the block? JEQ BRW05 Yup LI R0,$FRD+$FINP Nope...set up for READ LI R3,VMBR READ vector BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header * * READ/WRITE block routine [CODE = -18/-20] * RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header MOV @BFPAB,R0 VRAM destination LI R1,PABHD RAM source LI R2,8 #Bytes of PAB header to copy to PAB BLWP @VMBW Do the copy MOV @$DKBUF(U),R0 VRAM buffer address to R0 MOV R6,R1 RAM buffer to R1 LI R2,128 Bytes to copy CI R7,3 READ? JEQ BRW06 Yup BLWP *R3 Nope...copy record to VRAM * * temporarily use CRU register---it should be OK * BRW06 MOV @BFPAB,CRU PAB address AI CRU,9 Address of filename's char count MOV CRU,@SUBPTR Point to filename's char count BLWP @DSRLNK Read/write one record DATA 8 JEQ BKERR CI R7,2 WRITE? JEQ BRW07 Yup...next record MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) BLWP *R3 Nope...copy record to RAM buffer BRW07 INC R5 Next record in file AI R6,128 Next record to/from block RAM buffer DEC R4 Count down 1 record JNE RWLOOP Read/write another record if not done JMP BRWDON We're done * *** error handling * BKERR MOVB R0,R0 Device error? JEQ BKERR6 Yes, exit with disk error BKERR9 LI R6,9 No, exit with file error JMP BKCLN BKERR8 LI R6,8 Block# <=0! exit with range error JMP BKCLN BKERR6 LI R6,6 BKCLN BL @BKCLOS Close current blocks file; ignore error CI R7,4 USE or CREATE? JLT BKCLN1 No BL @BPTOG Yes...toggle BPOFF & BFPAB BKCLN1 MOV R6,R0 Pass error back to caller JMP BKEXIT BRWDON CLR R6 BL @BKCLOS Close current blocks file JNE BRWDN1 Error? LI R6,9 Yes...assume it was a file error BRWDN1 CI R7,4 (no error)...CREATE? JNE BRWDN2 No...we're done BL @BPTOG Yes...revert to correct blocks file BRWDN2 MOV R6,R0 Error to R0 BKEXIT MOV @SVBRET,LINK Restore LINK B @BKLINK ;] ;[* MSGTYP <<< Support for string typing in various banks >>> * * Called with: BL @MSGTYP * * R4 and R5 are the only registers that will be preserved * ..after a call to EMIT--- * * Input: R4 = Address of length byte of packed string * * We will pass the ASCII value of character to EMIT in R2 without * insuring it is 7 bits wide. * MSGTYP EQU $LO+$-LLVSPT DECT R Push return address MOV LINK,*R ...to Forth return stack CLR R5 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char SWPB R5 Put char count in low byte MTLOOP CLR R2 MOVB *R4+,R2 Copy next char to R2 for EMIT SWPB R2 Put char in low byte LIMI 0 We need to do this because we're calling EMIT directly BL @EMT Call EMIT directly INC @$OUT(U) Increment display line character count DEC R5 Decrement character count for this message JNE MTLOOP Are we done? MOV *R+,LINK Yes. Pop return address RT Return to caller ;] ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) R4$5 EQU $LO+$-LLVSPT MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4+,*R5+ MOV *R4,*R5 RT ;] * __ __ _ __ _ __ __ * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ * ___ ___ ____ * / _ \___ / _/__ ___ __/ / /____ * / // / -_) _/ _ `/ // / / __(_-< * /____/\__/_/ \_,_/\_,_/_/\__/___/ ;[*== User Variable defaults ============================================ * UBASE0 EQU $LO+$-LLVSPT BSS 6 BASE OF USER VARIABLES DATA UBASE0 06 USER UCONS$ DATA SPBASE 08 USER S0 DATA RBASE 0A USER R0 { R0$ DATA $UVAR 0C USER U0 DATA SPBASE 0E USER TIB DATA 31 10 USER WIDTH DATA DPBASE 12 USER DP DATA $SYS$ 14 USER SYS$ DATA 0 16 USER CURPOS DATA INT1 18 USER INTLNK DATA 1 1A USER WARNING DATA 64 1C USER C/L$ { CL$ DATA $BUFF 1E USER FIRST$ DATA $LO 20 USER LIMIT$ DATA >0380 22 USER COLTAB Color Table address in VRAM DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM DATA >80 2A USER FPB pushes address of user screen font file PAB * ...that is this relative distance from DISK_BUF DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) DATA 40 30 USER SCRN_WIDTH DATA 0 32 USER SCRN_START DATA 960 34 USER SCRN_END DATA 0 36 USER ISR [Note: This used to be INT1] DATA 0 38 USER ALTIN DATA 0 3A USER ALTOUT DATA 1 3C USER VDPMDE permanent location for VDPMDE DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files * ...that is this relative distance from DISK_BUF DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB * ...always toggled between 0 and 70 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) * 0 = console font via GPLLNK DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. * 0 = Symmetric (default) * !0 = Floored $UVAR EQU $LO+$-LLVSPT BSS >80 USER VARIABLE AREA ;] ;[*== A Constant ==================================================== * H2000 EQU $LO+$-LLVSPT DATA >2000 ;]* * __ ____ _ ___ __ _ __ __ * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ * /___/ * ;[*== Utility Vectors =================================================== * * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK XMLLNK EQU $LO+$-LLVSPT DATA UTILWS,XMLENT ; Link to ROM routines KSCAN EQU $LO+$-LLVSPT DATA UTILWS,KSENTR ; Keyboard scan VSBW EQU $LO+$-LLVSPT DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) VMBW EQU $LO+$-LLVSPT DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) VSBR EQU $LO+$-LLVSPT DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) VMBR EQU $LO+$-LLVSPT DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) VMOVE EQU $LO+$-LLVSPT DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) VWTR EQU $LO+$-LLVSPT DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) ;]* ;[*== XMLENT -- Link to system XML utilities ============================ * XMLENT EQU $LO+$-LLVSPT MOV *R14+,@GPLWS+2 Get argument LWPI GPLWS Select GPL workspace MOV R11,@UTILWS+22 Save GPL return address MOV R1,R2 Make a copy of argument CI R1,>8000 Direct address in ALC? JH XML30 We have the address SRL R1,12 SLA R1,1 SLA R2,4 SRL R2,11 A @XMLTAB(R1),R2 MOV *R2,R2 XML30 BL *R2 LWPI UTILWS Get back to right WS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * ________ __ __ _ ____ __ __ ________ * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * This routine will work with any GROM library slot since it is * * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * * This GPLLNK does NOT require a module to be plugged into the * * GROM port so it will work with the Editor/Assembler, * * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * * It saves and restores the current GROM Address in case you want * * to return back to GROM for Basic or Extended Basic CALL LINKs * * or to return to the loading module. * * * * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * * DATA >34 * * * * NOTES: Do Not REF GPLLNK when using this routine in your code. * * * * 70 Bytes - including the GPLLNK Workspace * *-----------------------------------------------------------------------* * GPLWS (>83E0) is GPL workspace G_R4 EQU GPLWS+8 GPL workspace R4 G_R6 EQU GPLWS+12 GPL workspace R6 * SUBSTK (>8373) is GPL Subroutine stack pointer LDGADR EQU >60 Load & Execute GROM address entry point XTAB27 EQU >200E Low Mem XML table location 27 * ..Will contain XMLRTN at startup GETSTK EQU >166C GPLLNK EQU $LO+$-LLVSPT DATA GLNKWS R7 Set up BLWP Vectors DATA GLINK1 R8 * RTNADR EQU $LO+$-LLVSPT <---don't think we need this label DATA XMLRTN R9 address where GPL XML returns to us... * ...this address will already be in XTAB27,... * ...>200E, so don't really need it here} GXMLAD EQU $LO+$-LLVSPT DATA >176C R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) DATA >50 R11 Initialized to >50 where PUTSTK address resides GLNKWS EQU $LO+$-LLVSPT->18 GPLLNK's workspace of which only... BSS >08 R12-R15 ...registers R7 through R15 are used GLINK1 EQU $LO+$-LLVSPT MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS LWPI GPLWS Load GPL WS BL *R4 Save current GROM Address on stack MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return INCT @SUBSTK Adjust the stack pointer B @LDGADR Execute our GPL Routine XMLRTN EQU $LO+$-LLVSPT MOV @GETSTK,R4 Get GETSTK pointer BL *R4 Restore GROM address off the stack LWPI GLNKWS Load our WS RTWP All Done - Return to Caller ;] * ___ _______ __ _ ____ __ __ ________ * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ * *-----------------------------------------------------------------------* ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= * {LES NOTE: Some labels have been modified for fbForth compatibility.} * * * * (Uses console GROM 0's DSRLNK routine) * * (Do not REF DSRLNK or GPLLNK when using these routines) * * (This DSRLNK will also handle Subprograms and CS1, CS2) * * * * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * * DATA 8 * * * * NOTES: Must be used with a GPLLNK routine * * Returns ERRORs the same as the E/A DSRLNK * * EQ bit set on return if error * * ERROR CODE in caller's MSB of Register 0 on return * * * * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * *-----------------------------------------------------------------------* PUTSTK EQU >50 Push GROM Address to stack pointer TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK NAMLEN EQU >8356 Device name length pointer in VDP PAB VWA EQU >8C02 VDP Write Address location VRD EQU >8800 VDP Read Data byte location G_R4LB EQU >83E9 GPL Workspace R4 Lower byte GSTAT EQU >837C GPL Status byte location DSRLNK EQU $LO+$-LLVSPT DATA DSRWS,DLINK1 Set BLWP Vectors DSRWS EQU $LO+$-LLVSPT Start of DSRLNK workspace DR3LB EQU DSRWS+7 lower byte of DSRLNK workspace R3 DLINK1 EQU $LO+$-LLVSPT MOV R12,R12 R0 Have we already looked up the LINK address? JNE DLINK3 R1 YES! Skip lookup routine *<<-------------------------------------------------------------------------->>* * This section of code is only executed once to find the GROM address * * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * * to indicate that the address is found and to be used as a mask for EQ & CND * *------------------------------------------------------------------------------* LWPI GPLWS R2,R3 else load GPL workspace MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack BL *R4 R6 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector ***les*** Note on above instruction: ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) JMP DLINK2 R11 Jump around R12-R15 DATA 0 R12 contains >2000 flag when set DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address MOV @GETSTK,R5 Take some time & set up GETSTK pointer MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector INCT @DSRADR Adjust it to get past GPL FETCH instruction BL *R5 Restore the GROM address off the stack LWPI DSRWS Reload DSRLNK workspace LI R12,>2000 Set flag to signify DSRLNK address is set *<<-------------------------------------------------------------------------->>* DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK MOV @NAMLEN,R3 Save VDP address of Name Length AI R3,-8 Adjust it to point to PAB Flag byte BLWP @GPLLNK Execute DSR LINK DSRADR EQU $LO+$-LLVSPT BYTE >03 High byte of GPL DSRLNK address DSRAD1 EQU $LO+$-LLVSPT BYTE >00 Lower byte of GPL DSRLNK address *----Error Check & Report to Caller's R0 and EQU bit------------------------- MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag MOVB R3,@VWA Set up MSB of VDP Address for Error Flag SZCB R12,R15 Clear EQ bit for Error Report MOVB @VRD,R3 Get PAB Error Flag SRL R3,5 Adjust it to 0-7 error code MOVB R3,*R13 Put it into Caller's R0 (msb) JNE SETEQ If it's not zero, set EQ bit COC @GSTAT,R12 Else, test CND bit for Link Error (00) JNE DSREND No Error, Just return SETEQ SOCB R12,R15 Error, so set Caller's EQ bit DSREND RTWP All Done - Return to Caller ;] ;[*== KSENTR -- Keyboard Scan (entry point) ============================= * KSENTR EQU $LO+$-LLVSPT LWPI GPLWS MOV R11,@UTILWS+22 Save GPL return address BL @SCNKEY Console keyboard scan routine LWPI UTILWS MOV R11,@GPLWS+22 Restore GPL return address RTWP ;]* * _ _____ ___ __ ____ _ ___ __ _ * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ * ;[*== VDP utilities (entry point) ======================================= * ** VDP single byte write * VSBWEN EQU $LO+$-LLVSPT BL @WVDPWA Write out address MOVB @2(R13),@VDPWD Write data RTWP Return to calling program * ** VDP multiple byte write * VMBWEN EQU $LO+$-LLVSPT BL @WVDPWA Write out address VWTMOR MOVB *R1+,@VDPWD Write a byte DEC R2 Decrement byte count JNE VWTMOR More to write? RTWP Return to calling Program * ** VDP single byte read * VSBREN EQU $LO+$-LLVSPT BL @WVDPRA Write out address MOVB @VDPRD,@2(R13) Read data RTWP Return to calling program * ** VDP multiple byte read * VMBREN EQU $LO+$-LLVSPT BL @WVDPRA Write out address VRDMOR MOVB @VDPRD,*R1+ Read a byte DEC R2 Decrement byte count JNE VRDMOR More to read? RTWP Return to calling program * ** VDP write to register * VWTREN EQU $LO+$-LLVSPT MOV *R13,R1 Get register number and value MOVB @1(R13),@VDPWA Write out value ORI R1,>8000 Set for register write MOVB R1,@VDPWA Write out register number RTWP Return to calling program * ** Set up to write to VDP * WVDPWA EQU $LO+$-LLVSPT LI R1,>4000 JMP WVDPAD * ** Set up to read VDP * WVDPRA EQU $LO+$-LLVSPT CLR R1 * ** Write VDP address * WVDPAD MOV *R13,R2 Get VDP address MOVB @U_R2LB,@VDPWA Write low byte of address SOC R1,R2 Properly adjust VDP write bit MOVB R2,@VDPWA Write high byte of address MOV @2(R13),R1 Get CPU RAM address MOV @4(R13),R2 Get byte count RT Return to calling routine * ** VDP-to-VDP move. * VMOVEN EQU $LO+$-LLVSPT MOV *R13,R1 Get cnt to R1 MOV @2(R13),R2 Get vsrc to R2 MOV @4(R13),R3 Get vdst to R3 ORI R3,>4000 Prepare for VDP write ** copy cnt bytes from vsrc to vdst VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address MOVB R2,@VDPWA Write MSB of VDP read address INC R2 Next VDP read address MOVB @VDPRD,R0 Read VDP byte MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address MOVB R3,@VDPWA Write MSB of VDP write address INC R3 Next VDP write address MOVB R0,@VDPWD Write VDP byte DEC R1 Decrement count JNE VMVMOR Repeat if not done RTWP Return to calling program ;]* ;[*== fbForth Version Message =========================================== FBFMSG EQU $LO+$-LLVSPT * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? * Also, printing the extra blanks overwrites the font-not-found error message. BYTE 17 TEXT 'fbForth 2.0: ' ;] * __ ___ ___ ____ __ __ _ __ __ * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ * ;[*== Modifiable words in Resident Dictionary =========================== ;[*** (ABORT) *** DATA x#VLST_N <--Last word in ROM PABR_N EQU $LO+$-LLVSPT DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT PABORT EQU $LO+$-LLVSPT DATA DOCOL DATA ABORT,SEMIS ;]* ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] DATA PABR_N FRTH_N EQU $LO+$-LLVSPT DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT FORTHV EQU $LO+$-LLVSPT+2 ; vocabulary link field FORTHP EQU $LO+$-LLVSPT+4 ; pseudo name field FORTHL EQU $LO+$-LLVSPT+6 ; chronological link field FORTH EQU $LO+$-LLVSPT DATA DOVOC DATA DPBASE+2,>81A0,0 ; (may need to modify) ;]* ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] DATA FRTH_N ASMR_N EQU $LO+$-LLVSPT DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT ASMV EQU $LO+$-LLVSPT+2 ; vocabulary link field ASML EQU $LO+$-LLVSPT+6 ; chronological link field ASSM EQU $LO+$-LLVSPT DATA DOVOC DATA SASM_N,>81A0,FORTHL ; <--ASMV initially points to last word in * ; ...ASSEMBLER vocabulary in the kernel ;]* ;]* * ___ __ __ * / _ | ___ ___ ___ __ _ / / / /__ ____ * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ * _ __ __ __ _ __ __ * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ * /___/ * *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary ;[*** NEXT, *** ( --- ) * 1st word in ASSEMBLER vocabulary * DATA FORTHP <--points to PNF of FORTH NXT__N EQU $LO+$-LLVSPT DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT NEXTC EQU $LO+$-LLVSPT DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) MOV @$DP(U),R1 HERE to R1 MOV R0,*R1+ compile "B *NEXT" MOV R1,@$DP(U) update HERE MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary B *NEXT back to inner interpreter * : NEXT, ( --- ) * *NEXT B, ; ;]* ;[*** ;ASM *** ( --- ) * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. * DATA NXT__N SASM_N EQU $LO+$-LLVSPT BYTE 4+TERMBT <--note different name field format TEXT ';ASM' BYTE ' '+TERMBT SASM EQU $LO+$-LLVSPT DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! JMP NXT_P finish up in NEXT, * : ;ASM ( --- ) * *NEXT B, ; ;]* ;[*== Some Variables (KEYCNT etc.) ====================================== KEYCNT EQU $LO+$-LLVSPT DATA -1 Used in cursor flash logic INTACT EQU $LO+$-LLVSPT DATA 0 Non-zero during user's interrupt service routine * *++ variables used by some graphics primitives * $DMODE EQU $LO+$-LLVSPT DATA 0 ; actual location of variable contents $DCOL EQU $LO+$-LLVSPT DATA -1 ; actual location of variable contents *=========================================================== ;]* * ______ ___ _____ __ * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ * /_/ * ;[*== Trampoline Code =================================================== * * MYBANK must be at same location in all banks with the code that appears * in the following table. The EQUates for BANK0--BANK3 may also be in the * same places in each bank for convenience, but they only need to appear once. * * Bank Select MYBANK * ---- ------ ------ * 0 >6006 >C000 * 1 >6004 >8000 * 2 >6002 >4000 * 3 >6000 >0000 * * Bank0 code will look like this * * MYBANK DATA >C000 * BANK0 EQU >C000 * BANK1 EQU >8000 * BANK2 EQU >4000 * BANK3 EQU >0000 * * Banks 1--3 will look the same, including labels, and the DATA * instruction at MYBANK's location will correspond to its bank. * * Before a bank is selected, the values above will be shifted right 13 * bits and have >6000 added. * ;[*** BLBANK ************************************************************ * * General bank branching routine (32KB ROM, i.e., 4 banks) for a * branch that is expected to return (not high-level Forth) via RTBANK--- * --put in scratchpad or low RAM * --called by * BL @BLBANK * DATA dst_addr - >6000 + bank# in left 2 bits * BLBANK EQU $LO+$-LLVSPT DECT R ; reserve space on return stack (R14) MOV *LINK+,CRU ; copy destination bank address to R12 MOV LINK,*R ; push return address DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) MOV CRU,LINK ; copy destination bank address to R11 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTBANK ************************************************************ * * General bank return routine (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called by * B @RTBANK * RTBANK EQU $LO+$-LLVSPT MOV *R+,CRU ; pop return bank# from return stack to R12 SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address MOV *R+,LINK ; pop return address from return stack CLR *CRU ; switch to destination bank B *LINK ; branch to return address ;]* ;[*** BLF2A ************************************************************* * * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to bank0 via RTNEXT. This will * only(?) be used for the ALC payload of Forth stubs in bank0--- * --put in scratchpad or low RAM * --called by * BL @BLF2A * DATA dst_addr - >6000 + bank# in left 2 bits * BLF2A EQU $LO+$-LLVSPT MOV *LINK,LINK ; copy destination bank address to R11 MOV LINK,CRU ; copy it to R12 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 AI LINK,>6000 ; make it a real address SRL CRU,13 ; shift bank# into bits 1-2 of R12 AI CRU,>6000 ; make it a real bank-switch address CLR *CRU ; switch to destination bank B *LINK ; branch to destination address ;]* ;[*** RTNEXT ************************************************************ * * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 * banks)--- * --put in scratchpad or low RAM * --called by * B @RTNEXT * RTNEXT EQU $LO+$-LLVSPT MOV @INTACT,CRU Are we in user's ISR? JNE RTNXT1 Don't enable interrupts if so. LIMI 2 RTNXT1 CLR @>6006 ; switch to bank 0 B *NEXT ; branch to next CFA (in R15) ;]* ;[*** BLA2F ************************************************************* * * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 * banks) that is expected to return to calling bank via RTA2F--- * --put in scratchpad or low RAM * --called by * BL @BLA2F * DATA <Forth cfa in bank0> * BLA2F EQU $LO+$-LLVSPT DECT R ; reserve space on return stack MOV *LINK+,W ; move CFA of Forth routine to W MOV LINK,*R ; push return address of calling bank DECT R ; reserve space on return stack MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) DECT R ; reserve spot on return stack MOV IP,*R ; move current IP to return stack LI IP,RTA2F ; move address of return procedure to IP CLR @>6006 ; switch to bank0 B @DOEXEC ; Execute the Forth routine ;]* ;[*** RTA2F ************************************************************* * * ALC to high-level Forth bank "return" routine from Forth to calling * ALC (32KB ROM, i.e., 4 banks)--- * --put in scratchpad or low RAM * --called through B *NEXT at end of Forth word's execution in BLA2F * RTA2F EQU $LO+$-LLVSPT DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) * Retrieve ALC return info and return to caller... * ...caller will execute B *NEXT when it finishes B @RTBANK ; branch to general bank return routine above ;]* ;]*********************************************************************** ;[*++ Bank-specific cell-/byte-reading code ++* ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) *++ Read cell contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKAT EQU $LO+$-LLVSPT CLR *R0 ; switch banks MOV *R1,*SP ; get cell contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) *++ Read byte contents of address in Bank bank# or RAM. *++ Register inputs: *++ R0: bank-switch address *++ R1: address in bank# to be read _BKCAT EQU $LO+$-LLVSPT CLR *R0 ; switch banks CLR R2 ; clear R2 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 MOV R2,*SP ; get byte contents of address to stack B @RTNEXT ; return to inner interpreter ;]* ;]* * _______ __ _________ ___ __ * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / * /___/ * ;[*** SAMS! *** ( --- ) * This calls the SAMS initialization in the startup code in bank 1. * * DATA SMSQ_N * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT * SAMSST DATA $+2 * BL @BLF2A * DATA _SMSST->6000+BANK1 _SMSST BL @SMSINI initialize SAMS card B @RTNEXT back to inner interpreter ;]* ;[*== Required strings, tables, variables... ============================ * * * Default blocks filename * DEFNAM EQU $LO+$-LLVSPT BYTE 12 TEXT "DSK1.FBLOCKS " * * Default colors for all VDP modes--- * MSB: Screen color (LSN); text FG (MSN), BG (LSN) * LSB: Color Table colors (FG/BG) * DEFCOL EQU $LO+$-LLVSPT DATA >4F00 ; TEXT80 offset=0 DATA >4F00 ; TEXT offset=2 DATA >F4F4 ; GRAPHICS offset=4 DATA >11F4 ; MULTI offset=6 DATA >FE10 ; GRAPHICS2 offset=8 DATA >FEF4 ; SPLIT offset=10 DATA >FEF4 ; SPLIT2 offset=12 * * Default text mode * DEFTXT EQU $LO+$-LLVSPT DATA >0001 * * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB * FNTFLG EQU $LO+$-LLVSPT DATA 0 ; font flag initially 0 * * Speech variables needing initial value (more below LLVEND) * SPCSVC EQU $LO+$-LLVSPT DATA 0 * * Sound Table #1 Workspace for sound variables. Only using R0..R4 * SND1WS EQU $LO+$-LLVSPT SND1ST EQU SND1WS R0 (sound table status) 0=no table; 1=loading sound... DATA 0 ...bytes; -1=counting SND1DS EQU SND1WS+2 R1 (sound-table byte destination)... DATA SOUND ...initialized to sound chip SND1AD EQU SND1WS+4 R2 (sound table address) DATA 0 SND1CT EQU SND1WS+6 R3 (# of sound bytes to load or... DATA 0 ...sound count = seconds * 60) SND1SP EQU SND1WS+8 R4 (pointer to top of sound stack) DATA SNDST0 initialized to bottom of sound stack * * Sound Table #2 Workspace for sound variables. Only using R0..R3 * SND2WS EQU $LO+$-LLVSPT SND2ST EQU SND2WS R0 (sound table status) 0=no table ; 1=loading sound... DATA 0 ...bytes; -1=counting SND2DS EQU SND2WS+2 R1 (sound-table byte destination)... DATA SOUND ...initialized to sound chip ;]* * * This is the end of low-level support code that gets copied. * LLVEND ;[*== Un-initialized Variables and workspaces... ========================= * Start of definitions of variables and workspaces that do not need to * take up space in ROM because they need no initial values. * * Sound Table #2 Workspace for sound variables..continued. * SND2AD EQU SND2WS+4 R2 (sound table address) SND2CT EQU SND2WS+6 R3 (# of sound bytes to load or... * ...sound count = seconds * 60) SDMUTE EQU SND2WS+8 dummy destination for sound byte * * Branch Stack for ISR processing of Speech, 2 Sound Tables and return * BRSTK EQU SDMUTE+2 * * Speech variables (more above LLVEND) * SSFLAG EQU BRSTK+8 SPCNT EQU SSFLAG+2 SPADR EQU SPCNT+2 BANKSV EQU SPADR+2 PADSV EQU BANKSV+2 * * Panel window: height, width and screen position...used by PANEL and SCROLL * PANWIN EQU PADSV+12 panel height, width and screen start *== Utility Workspace ================================================= *** General utility workspace registers UTILWS EQU PANWIN+6 U_R2LB EQU UTILWS+5 LINBUF EQU UTILWS+32 CURCHR EQU LINBUF+80 *++ variable used by the 40/80-column editor OLDCUR EQU CURCHR+2 *++ FILE I/O variables PBADR EQU OLDCUR+8 PBBF EQU PBADR+2 PBVBF EQU PBBF+2 *++ Floating Point Math Library variables FPVARS EQU PBVBF+2 *++ SAMS flag SAMSFL EQU FPVARS+22 *++ Bottom of Sound Stack *++ This location marks the top of the low-level support code. The Sound *++ Stack grows upward toward the Return Stack by moving the entire stack *++ up one cell to make room for the next new bottom entry. SNDST0 EQU SAMSFL+2 ;]* and its listing: Reveal hidden contents 0105 COPY "Bank1\fbForth101_LowLevelSupport.a99" **** **** > fbForth101_LowLevelSupport.a99 0001 * __ __ __ 0002 * / / ___ _ ______/ / ___ _ _____ / / 0003 * / /__/ _ \ |/|/ /___/ /__/ -_) |/ / -_) / 0004 * /____/\___/__,__/ /____/\__/|___/\__/_/ 0005 * ____ __ 0006 * / __/_ _____ ___ ___ ____/ /_ 0007 * _\ \/ // / _ \/ _ \/ _ \/ __/ __/ 0008 * /___/\_,_/ .__/ .__/\___/_/ \__/ 0009 * /_/ /_/ 0010 * 0011 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0012 * * 0013 * fbForth--- * 0014 * * 0015 * Low-level support routines * 0016 * * 0017 * << Including Trampoline Code, tables & variables: 2606 bytes >> * 0018 * * 0019 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 0020 0021 LLVSPT ; <--This is the source copy location for the rest of this code. 0022 0023 2010 $BUFF EQU >2010 0024 0025 * 4 I/O buffers below ($LO = >3020) 0026 * Change '4' to number of buffers needed and for which there is room. 0027 0028 3020 $LO EQU 4*>404+$BUFF start of low-level routines after I/O buffers 0029 * _____ ____ __ __ ___________ 0030 * / _/ / / __/__ ____/ /_/ / / _/ __/ _ \ 0031 * / _/ _ \/ _// _ \/ __/ __/ _ \ _/ /_\ \/ , _/ 0032 * /_//_.__/_/ \___/_/ \__/_//_/ /___/___/_/|_| 0033 * 0034 ;[*** Interrupt Service ======================================================= 0035 * This routine is executed for every interrupt. It processes any pending 0036 * speech and souind. It then looks to see whether a user ISR is installed in 0037 * ISR. If so, it sets up NEXT for execution of the user ISR. This will work 0038 * only if the user has installed an ISR using the following steps in the fol- 0039 * lowing order: 0040 * 0041 * (1) Write an ISR with entry point, say MYISR. 0042 * (2) Determine code field address of MYISR with this high-level Forth: 0043 * ' MYISR CFA 0044 * <<< Maybe need a word to do #3 >>> 0045 * (3) Write CFA of MYISR into user variable ISR. 0046 * 0047 * Steps (2)-(3) in high-level Forth are shown below: 0048 * ' MYISR CFA 0049 * ISR ! 0050 * 0051 * <<< Perhaps last step above should be by a word that disables interrupts >>> 0052 * 0053 * The console ISR branches to the contents of >83C4 because it is non-zero, 0054 * with the address, INT1, of the fbForth ISR entry point below (also, the 0055 * contents of INTLNK). This means that the console ISR will branch to INT1 0056 * with BL *R12 from WP = GPLWS (>83E0), R12 containing INT1 below to first 0057 * process any pending speech and sound. 0058 * 0059 * If the user's ISR is properly installed, the code that processes the user 0060 * ISR modifies NEXT so that the very next time B *NEXT or B *R15 is executed 0061 * from Forth's workspace (MAINWS), the code at INT2 will process the user's 0062 * ISR just before branching to the normal NEXT entry ($NEXT) in fbForth's 0063 * inner interpreter. 0064 *** ========================================================================== 0065 0066 * ¡¡¡ MUST REMEMBER THAT WE ARE IN GPL WORKSPACE UPON ENTRY. !!! 0067 0068 3020 INT1 EQU $LO+$-LLVSPT 0069 6140 0200 20 LI R0,BRSTK load address of top of Branch Address Stack 6142 3A2A 0070 * 0071 * Set up for pending speech 0072 * 0073 6144 C420 46 MOV @SPCSVC,*R0 save Speech service address onto Branch Stack 6146 3A14 0074 6148 1301 14 JEQ SNDCH1 jump to sound-check if no speech 0075 614A 05C0 14 INCT R0 increment Branch Stack 0076 * 0077 * Set up for pending sound table #1 (ST#1) 0078 * 0079 614C C0A0 34 SNDCH1 MOV @SND1ST,R2 sound table ST#1 to service? 614E 3A16 0080 6150 1303 14 JEQ SNDCH2 process speech and sound if needed 0081 6152 0201 20 LI R1,x#PLAYT1 load PLAYT1 address and... 6154 7C68 0082 6156 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0083 * 0084 * Set up for pending sound table #2 (ST#2) 0085 * 0086 6158 C0E0 34 SNDCH2 MOV @SND2ST,R3 sound table ST#2 to service? 615A 3A20 0087 615C 1303 14 JEQ PRCSPS process speech and sound if needed 0088 615E 0201 20 LI R1,x#PLAYT2 load PLAYT2 address and... 6160 7C6E 0089 6162 CC01 34 MOV R1,*R0+ ...push it onto Branch Stack 0090 * 0091 * Process sound stack if both sound tables idle 0092 * 0093 6164 E0C2 18 PRCSPS SOC R2,R3 OR R2 and R3..both sound tables idle? 0094 6166 160A 14 JNE PRSPS2 nope..skip sound stack processing 0095 6168 02E0 18 LWPI SND1WS switch to ST#1 WS 616A 3A16 0096 616C 0284 22 CI R4,SNDST0 anything on sound stack? 616E 3AE4 0097 6170 1303 14 JEQ PRSPS1 no..exit sound stack processing 0098 6172 0644 14 DECT R4 pop sound stack position 0099 6174 C094 26 MOV *R4,R2 get sound table address from sound stack 0100 6176 0580 14 INC R0 kick off sound processing of ST#1 (R0=1) 0101 6178 02E0 18 PRSPS1 LWPI GPLWS switch back to GPL WS 617A 83E0 0102 * 0103 * Check for any pending speech and sound 0104 * 0105 617C 0280 22 PRSPS2 CI R0,BRSTK any speech or sound to process? 617E 3A2A 0106 6180 1312 14 JEQ USRISR if not, jump to user ISR processing 0107 6182 0201 20 LI R1,BNKRST yup..load return address 6184 307A 0108 6186 C401 30 MOV R1,*R0 push return address onto Branch Stack 0109 * 0110 * Process pending speech and sound 0111 * 0112 6188 C820 54 MOV @x#MYBANK,@BANKSV save bank at interrupt 618A 7FFE 618C 3A38 0113 618E 04E0 34 CLR @>6002 switch to bank 2 for speech & sound services 6190 6002 0114 6192 0207 20 LI R7,BRSTK load top of Branch Stack 6194 3A2A 0115 6196 C237 30 MOV *R7+,R8 pop speech/sound ISR 0116 6198 0458 20 B *R8 service speech/sound 0117 * 0118 * Restore interrupted bank 0119 * 0120 307A BNKRST EQU $LO+$-LLVSPT return point for speech and sound ISRs 0121 619A C020 34 MOV @BANKSV,R0 restore bank at interrupt 619C 3A38 0122 619E 09D0 56 SRL R0,13 get the bank# to correct position 0123 61A0 0220 22 AI R0,>6000 make it a real bank-switch address 61A2 6000 0124 61A4 04D0 26 CLR *R0 switch to the bank at interrupt 0125 * 0126 * Process User ISR if defined 0127 * 0128 61A6 C020 34 USRISR MOV @$ISR+$UVAR,R0 User ISR installed? 61A8 36EA 0129 61AA 1304 14 JEQ INTEX 0130 * 0131 * Fix NEXT so that the user's ISR is processed the next time B *NEXT (B *R15) 0132 * is executed from Forth's WS (MAINWS = >8300), which it does at the end of 0133 * every CODE word, keyboard scan and one or two other places. 0134 * 0135 61AC 0201 20 LI R1,INT2 Load entry point, INT2 61AE 309A 0136 61B0 C801 38 MOV R1,@2*NEXT+MAINWS Copy it to Forth's NEXT (R15) 61B2 831E 0137 * 0138 * The following 2 instructions are copies of the remainder of the console ROM's 0139 * ISR (except that 'CLR R8' was removed because it is only needed by TI Basic) 0140 * because we're not going back there! 0141 * 0142 61B4 02E0 18 INTEX LWPI >83C0 Change to console's ISR WS 61B6 83C0 0143 61B8 0380 18 RTWP Return to caller of console ISR 0144 * 0145 * Branch through above-modified NEXT (R15) gets us here. NEXT will be restored 0146 * before executing user's ISR. INT3 (cleanup routine below) will be inserted 0147 * in address list to get us back here for cleanup after user's ISR has finished. 0148 * User's ISR is executed at the end of this section just before INT3. 0149 * 0150 309A INT2 EQU $LO+$-LLVSPT 0151 61BA 0300 24 LIMI 0 Disable interrupts 61BC 0000 0152 61BE D020 34 MOVB @>83D4,R0 Get copy of VR01 61C0 83D4 0153 61C2 0980 56 SRL R0,8 ...to LSB 0154 61C4 0260 22 ORI R0,>100 Set up for VR01 61C6 0100 0155 61C8 0240 22 ANDI R0,>FFDF Clear VDP-interrupt-enable bit 61CA FFDF 0156 61CC 0420 54 BLWP @VWTR Turn off VDP interrupt 61CE 3752 0157 61D0 020F 20 LI NEXT,$NEXT Restore NEXT 61D2 833A 0158 61D4 0720 34 SETO @INTACT Set Forth "pending interrupt" flag 61D6 3956 0159 61D8 064E 14 DECT R Set up return linkage by pushing 0160 61DA C78D 30 MOV IP,*R ...IP (R13, next Forth CFA) to return stack and 0161 61DC 020D 20 LI IP,INT3 ...setting IP to INT3 (below) for cleanup 61DE 30C8 0162 61E0 C2A8 34 MOV @$ISR(U),W Do the user's Forth ISR by executing 61E2 0036 0163 61E4 0460 28 B @DOEXEC ...it through Forth's inner interpreter 61E6 833C 0164 * 0165 * Clean up and re-enable interrupts. 0166 * 0167 30C8 INT3 EQU $LO+$-LLVSPT 0168 61E8 30CA DATA INT3+2 $NEXT (or $SEMIS) puts INT3+2 in W (R10) 0169 61EA 30CC DATA INT3+4 DOEXEC (or $SEMIS) will branch to *W = INT3+4 (next instr) 0170 61EC C37E 30 MOV *R+,IP Start cleanup: pop IP from before call to user's ISR 0171 61EE 04E0 34 CLR @INTACT Clear Forth "pending interrupt" flag 61F0 3956 0172 61F2 D020 34 MOVB @>83D4,R0 Prepare to restore VR01 by... 61F4 83D4 0173 61F6 0980 56 SRL R0,8 ...moving payload to LSB (enabling VDP interrupt) and 0174 61F8 0220 22 AI R0,>100 ...VR # (01) to MSB 61FA 0100 0175 61FC D060 34 MOVB @VDPSTA,R1 Remove pending VDP interrupt by reading VDP status 61FE 8802 0176 6200 0420 54 BLWP @VWTR Write VR01 6202 3752 0177 6204 0300 24 LIMI 2 Re-enable interrupts 6206 0002 0178 6208 045F 20 B *NEXT Continue normal task 0179 ;]* 0180 ;[*** BKLINK from SYSTEM calls ========================================== 0181 * 0182 30EA BKLINK EQU $LO+$-LLVSPT 0183 620A C1E0 34 MOV @INTACT,R7 Are we in user's ISR? 620C 3956 0184 620E 1602 14 JNE BKLIN1 Don't enable interrupts if so. 0185 6210 0300 24 LIMI 2 6212 0002 0186 6214 045B 20 BKLIN1 B *LINK 0187 ;]* 0188 * ____ __ _____ ____ 0189 * / __/_ ______/ /____ __ _ / ___/__ _/ / /__ 0190 * _\ \/ // (_-</ __/ -_) ' \ / /__/ _ `/ / (_-< 0191 * /___/\_, /___/\__/\__/_/_/_/ \___/\_,_/_/_/___/ 0192 * /___/ 0193 * 0194 ;[*** $SYS$ -- Called by fbForth's SYSTEM =============================== 0195 0196 * Entry point for low-level system support functions 0197 0198 30F6 $SYS$ EQU $LO+$-LLVSPT 0199 6216 0300 24 LIMI 0 6218 0000 0200 621A C021 34 MOV @SYSTAB(R1),R0 621C 3114 0201 621E 0450 20 B *R0 0202 ;] 0203 ;[*** SYSTAB -- Vector table for SYSTEM calls =========================== 0204 0205 6220 34C6 DATA BRW CODE = -20 write block to blocks file 0206 6222 34C6 DATA BRW CODE = -18 read block from blocks file 0207 6224 34C6 DATA BRW CODE = -16 create blocks file 0208 6226 34C6 DATA BRW CODE = -14 use blocks file 0209 6228 346C DATA GXY CODE = -12 GOTOXY 0210 622A 3456 DATA QKY CODE = -10 ?KEY 0211 622C 343C DATA QTM CODE = -8 ?TERMINAL 0212 622E 3420 DATA CLF CODE = -6 CRLF 0213 6230 3312 DATA EMT CODE = -4 EMIT 0214 6232 3260 DATA KY CODE = -2 KEY 0215 3114 SYSTAB EQU $LO+$-LLVSPT 0216 6234 3130 DATA SBW CODE = 0 VSBW 0217 6236 313E DATA MBW CODE = 2 VMBW 0218 6238 314C DATA SBR CODE = 4 VSBR 0219 623A 315A DATA MBR CODE = 6 VMBR 0220 623C 3176 DATA WTR CODE = 8 VWTR 0221 623E 3186 DATA GPL CODE = 10 GPLLNK 0222 6240 31A6 DATA XML CODE = 12 XMLLNK 0223 6242 31C0 DATA DSR CODE = 14 DSRLNK 0224 6244 31DA DATA CLS$ CODE = 16 CLS 0225 6246 3168 DATA MVE CODE = 18 VMOVE 0226 6248 31F4 DATA FILL$ CODE = 20 VFILL 0227 624A 3224 DATA AOX CODE = 22 VAND 0228 624C 3224 DATA AOX CODE = 24 VOR 0229 624E 3224 DATA AOX CODE = 26 VXOR 0230 ;]* 0231 ;[*== VDP single byte write. CODE = 0 ================= 0232 * 0233 3130 SBW EQU $LO+$-LLVSPT 0234 6250 C039 30 MOV *SP+,R0 VRAM address (destination) 0235 6252 C079 30 MOV *SP+,R1 Character to write 0236 6254 06C1 14 SWPB R1 Get in left byte 0237 6256 0420 54 BLWP @VSBW 6258 373E 0238 625A 0460 28 B @BKLINK 625C 30EA 0239 ;]* 0240 ;[*== VDP multi byte write. CODE = 2 ================= 0241 * 0242 313E MBW EQU $LO+$-LLVSPT 0243 625E C0B9 30 MOV *SP+,R2 Number of bytes to move 0244 6260 C039 30 MOV *SP+,R0 VRAM address (destination) 0245 6262 C079 30 MOV *SP+,R1 RAM address (source) 0246 6264 0420 54 BLWP @VMBW 6266 3742 0247 6268 0460 28 B @BKLINK 626A 30EA 0248 ;]* 0249 ;[*== VDP single byte read. CODE = 4 ================= 0250 * 0251 314C SBR EQU $LO+$-LLVSPT 0252 626C C019 26 MOV *SP,R0 VRAM address (source) 0253 626E 0420 54 BLWP @VSBR 6270 3746 0254 6272 0981 56 SRL R1,8 Character to right half for Forth 0255 6274 C641 30 MOV R1,*SP Stack it 0256 6276 0460 28 B @BKLINK 6278 30EA 0257 ;]* 0258 ;[*== VDP multi byte read. CODE = 6 ================= 0259 * 0260 315A MBR EQU $LO+$-LLVSPT 0261 627A C0B9 30 MOV *SP+,R2 Number of bytes to read 0262 627C C079 30 MOV *SP+,R1 RAM address (destination) 0263 627E C039 30 MOV *SP+,R0 VRAM address (source) 0264 6280 0420 54 BLWP @VMBR 6282 374A 0265 6284 0460 28 B @BKLINK 6286 30EA 0266 ;]* 0267 ;[*== VDP-to-VDP move. CODE = 18 ================= 0268 * 0269 3168 MVE EQU $LO+$-LLVSPT 0270 6288 C039 30 MOV *SP+,R0 Pop cnt to R0 0271 628A C0B9 30 MOV *SP+,R2 Pop vdst to R2 0272 628C C079 30 MOV *SP+,R1 Pop vsrc to R1 0273 628E 0420 54 BLWP @VMOVE 6290 374E 0274 6292 0460 28 B @BKLINK 6294 30EA 0275 ;]* 0276 ;[*== VDP register write. CODE = 8 ================= 0277 * 0278 3176 WTR EQU $LO+$-LLVSPT 0279 6296 C079 30 MOV *SP+,R1 VDP register number 0280 6298 C039 30 MOV *SP+,R0 Data for register 0281 629A 06C1 14 SWPB R1 Get register to left byte 0282 629C D001 18 MOVB R1,R0 Place with data 0283 629E 0420 54 BLWP @VWTR 62A0 3752 0284 62A2 0460 28 B @BKLINK 62A4 30EA 0285 ;]* 0286 ;[*== GPL link utility. CODE = 10 ================= 0287 * 0288 3186 GPL EQU $LO+$-LLVSPT 0289 62A6 04C0 14 CLR R0 0290 62A8 D800 38 MOVB R0,@KYSTAT 62AA 837C 0291 62AC 0200 20 LI R0,>0420 Construct the BLWP instruction 62AE 0420 0292 62B0 0201 20 LI R1,GPLLNK to the GPLLNK utility 62B2 3784 0293 62B4 C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0294 62B6 0203 20 LI R3,>045B Construct the B *LINK instruction 62B8 045B 0295 62BA C10B 18 MOV LINK,R4 Save LINK address 0296 62BC 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62BE 8300 0297 62C0 C2C4 18 MOV R4,LINK and reconstruct LINK 0298 62C2 0460 28 B @BKLINK 62C4 30EA 0299 ;]* 0300 ;[*== XML link utility. CODE = 12 ================= 0301 * 0302 31A6 XML EQU $LO+$-LLVSPT 0303 62C6 0200 20 LI R0,>0420 Construct the BLWP instruction 62C8 0420 0304 62CA 0201 20 LI R1,XMLLNK to the XMLLNK utility 62CC 3736 0305 62CE C0B9 30 MOV *SP+,R2 with this datum identifying the routine 0306 62D0 0203 20 LI R3,>045B Construct the B *LINK instruction 62D2 045B 0307 62D4 C10B 18 MOV LINK,R4 Save LINK address 0308 62D6 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62D8 8300 0309 62DA C2C4 18 MOV R4,LINK and reconstruct LINK 0310 62DC 0460 28 B @BKLINK 62DE 30EA 0311 ;]* 0312 ;[*== DSR link utility. CODE = 14 ================= 0313 * 0314 31C0 DSR EQU $LO+$-LLVSPT 0315 62E0 0200 20 LI R0,>0420 Construct the BLWP instruction 62E2 0420 0316 62E4 0201 20 LI R1,DSRLNK to the DSRLNK utility 62E6 37BE 0317 62E8 C0B9 30 MOV *SP+,R2 This datum selects DSR or subroutine 0318 62EA 0203 20 LI R3,>045B Construct the B *LINK instruction 62EC 045B 0319 62EE C10B 18 MOV LINK,R4 Save LINK address 0320 62F0 06A0 32 BL @2*R0+MAINWS Execute the above instructions 62F2 8300 0321 62F4 C2C4 18 MOV R4,LINK and reconstruct LINK 0322 62F6 0460 28 B @BKLINK 62F8 30EA 0323 ;]* 0324 ;[*== Screen clearing utility. CODE = 16 ================= 0325 * 0326 31DA CLS$ EQU $LO+$-LLVSPT 0327 62FA C0A8 34 MOV @$SSTRT(U),R2 Beginning of screen in VRAM 62FC 0032 0328 62FE C068 34 MOV @$SEND(U),R1 End of screen in VRAM 6300 0034 0329 6302 6042 18 S R2,R1 Screen size 0330 6304 0200 20 LI R0,>2000 Blank character 6306 2000 0331 6308 C1CB 18 MOV LINK,R7 0332 630A 06A0 32 BL @FILL1 630C 3208 0333 630E C2C7 18 MOV R7,LINK 0334 6310 0460 28 B @BKLINK 6312 30EA 0335 ;]* 0336 ;[*== VDP fill routine. CODE = 20 ================= 0337 * 0338 31F4 FILL$ EQU $LO+$-LLVSPT 0339 6314 C039 30 MOV *SP+,R0 Fill character 0340 6316 06C0 14 SWPB R0 to left byte 0341 6318 C079 30 MOV *SP+,R1 Fill count 0342 631A C0B9 30 MOV *SP+,R2 Address to start VRAM fill 0343 631C C1CB 18 MOV LINK,R7 0344 631E 06A0 32 BL @FILL1 6320 3208 0345 6322 C2C7 18 MOV R7,LINK 0346 6324 0460 28 B @BKLINK 6326 30EA 0347 *======================================================================== 0348 3208 FILL1 EQU $LO+$-LLVSPT R0=char, R1=cnt, R2=vaddr 0349 6328 0262 22 ORI R2,>4000 Set bit for VDP write 632A 4000 0350 632C 06C2 14 SWPB R2 0351 632E D802 38 MOVB R2,@VDPWA LS byte first 6330 8C02 0352 6332 06C2 14 SWPB R2 0353 6334 D802 38 MOVB R2,@VDPWA Then MS byte 6336 8C02 0354 6338 1000 14 NOP Kill time 0355 633A D800 38 FLOOP MOVB R0,@VDPWD Write a byte 633C 8C00 0356 633E 0601 14 DEC R1 0357 6340 16FC 14 JNE FLOOP Not done, fill another 0358 6342 045B 20 B *LINK 0359 ;]*====================================================================== 0360 * 0361 *==== VAND -- VDP byte AND routine. CODE = 22 ================= 0362 *==== VOR -- VDP byte OR routine. CODE = 24 ================= 0363 ;[*== VXOR -- VDP byte XOR routine. CODE = 26 ================= 0364 * 0365 3224 AOX EQU $LO+$-LLVSPT 0366 6344 C0B9 30 MOV *SP+,R2 VRAM address 0367 6346 06C2 14 SWPB R2 0368 6348 D802 38 MOVB R2,@VDPWA LS byte first 634A 8C02 0369 634C 06C2 14 SWPB R2 0370 634E D802 38 MOVB R2,@VDPWA Then MS byte 6350 8C02 0371 6352 1000 14 NOP Kill time 0372 6354 D0E0 34 MOVB @VDPRD,R3 Read byte 6356 8800 0373 6358 C039 30 MOV *SP+,R0 Get data to operate with 0374 635A 06C0 14 SWPB R0 to left byte 0375 *** Now do requested operation ***************** 0376 635C 0281 22 CI R1,24 635E 0018 0377 6360 1304 14 JEQ DOOR 0378 6362 1505 14 JGT DOXOR 0379 6364 0543 14 INV R3 These two instructions 0380 6366 4003 18 SZC R3,R0 perform an 'AND' 0381 6368 1003 14 JMP FINAOX 0382 636A E003 18 DOOR SOC R3,R0 perform 'OR' 0383 636C 1001 14 JMP FINAOX 0384 636E 2803 18 DOXOR XOR R3,R0 perform 'XOR' 0385 6370 0201 20 FINAOX LI R1,1 6372 0001 0386 6374 C1CB 18 MOV LINK,R7 0387 6376 06A0 32 BL @FILL1 6378 3208 0388 637A C2C7 18 MOV R7,LINK 0389 637C 0460 28 B @BKLINK 637E 30EA 0390 ;]* 0391 ;[*== KEY routine CODE = -2 ================= 0392 * 0393 3260 KY EQU $LO+$-LLVSPT 0394 6380 C028 34 MOV @$ALTI(U),R0 alternate input device? 6382 0038 0395 6384 131B 14 JEQ KEY0 jump to keyboard input if not 0396 * 0397 * R0 now points to PAB for alternate input device, the one-byte buffer 0398 * for which must immediately precede its PAB. PAB must have been set up 0399 * to read one byte. 0400 * 0401 6386 04C7 14 CLR R7 prepare to zero status byte 0402 6388 D807 38 MOVB R7,@KYSTAT zero status byte 638A 837C 0403 638C 0580 14 INC R0 point R0 to Flag/Status byte 0404 638E 0420 54 BLWP @VSBR read it 6390 3746 0405 6392 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6394 1F00 0406 6396 0420 54 BLWP @VSBW write it back to PAB 6398 373E 0407 639A C040 18 MOV R0,R1 Set up pointer... 0408 639C 0221 22 AI R1,8 ...to namelength byte of PAB 639E 0008 0409 63A0 C801 38 MOV R1,@SUBPTR copy to DSR subroutine name-length pointer 63A2 8356 0410 63A4 C0C0 18 MOV R0,R3 save pointer (DSRLNK will trash it!) 0411 63A6 0420 54 BLWP @DSRLNK get 1 byte from device 63A8 37BE 0412 63AA 0008 DATA >8 0413 63AC C003 18 MOV R3,R0 restore pointer 0414 63AE 0640 14 DECT R0 point to one-byte VRAM buffer in front of PAB 0415 63B0 0420 54 BLWP @VSBR read character 63B2 3746 0416 63B4 0981 56 SRL R1,8 move to LSB 0417 63B6 C001 18 MOV R1,R0 copy to return register 0418 63B8 0460 28 B @BKLINK return to caller 63BA 30EA 0419 * 0420 * Input is comining from the keyboard 0421 * 0422 63BC C1E0 34 KEY0 MOV @KEYCNT,R7 63BE 3954 0423 63C0 0587 14 INC R7 0424 63C2 160A 14 JNE KEY1 0425 63C4 C028 34 MOV @CURPO$(U),R0 63C6 0016 0426 63C8 0420 54 BLWP @VSBR Read character at cursor position... 63CA 3746 0427 63CC D801 38 MOVB R1,@CURCHR ...and save it 63CE 3ABC 0428 63D0 0201 20 LI R1,>1E00 Place cursor character on screen 63D2 1E00 0429 63D4 0420 54 BLWP @VSBW 63D6 373E 0430 * 0431 63D8 0420 54 KEY1 BLWP @KSCAN 63DA 373A 0432 63DC D020 34 MOVB @KYSTAT,R0 63DE 837C 0433 63E0 2020 38 COC @H2000,R0 check status 63E2 3734 0434 63E4 1319 14 JEQ KEY2 JMP if key was pressed 0435 * 0436 63E6 0287 22 CI R7,100 No key pressed 63E8 0064 0437 63EA 1603 14 JNE KEY3 0438 63EC D060 34 MOVB @CURCHR,R1 63EE 3ABC 0439 63F0 1006 14 JMP KEY5 0440 * 0441 63F2 0287 22 KEY3 CI R7,200 63F4 00C8 0442 63F6 1607 14 JNE KEY4 0443 63F8 04C7 14 CLR R7 0444 63FA 0201 20 LI R1,>1E00 Cursor char 63FC 1E00 0445 63FE C028 34 KEY5 MOV @CURPO$(U),R0 6400 0016 0446 6402 0420 54 BLWP @VSBW 6404 373E 0447 6406 C807 38 KEY4 MOV R7,@KEYCNT 6408 3954 0448 640A C1E0 34 MOV @INTACT,R7 Are we in user's ISR? 640C 3956 0449 640E 1602 14 JNE KEY6 Don't enable interrupts if so. 0450 6410 0300 24 LIMI 2 6412 0002 0451 6414 064D 14 KEY6 DECT IP This will re-execute KEY 0452 6416 045F 20 B *NEXT 0453 6418 0720 34 KEY2 SETO @KEYCNT Key was pressed 641A 3954 0454 641C C028 34 MOV @CURPO$(U),R0 Restore character at cursor location 641E 0016 0455 6420 D060 34 MOVB @CURCHR,R1 6422 3ABC 0456 6424 0420 54 BLWP @VSBW 6426 373E 0457 6428 D020 34 MOVB @KYCHAR,R0 Put char in... 642A 8375 0458 642C 0980 56 SRL R0,8 ...LSB of R0 0459 642E 0460 28 B @BKLINK 6430 30EA 0460 ;]* 0461 ;[*== EMIT routine CODE = -4 ================= 0462 * 0463 3312 EMT EQU $LO+$-LLVSPT 0464 6432 C042 18 MOV R2,R1 copy char to R1 for VSBW 0465 6434 C028 34 MOV @$ALTO(U),R0 alternate output device? 6436 003A 0466 6438 1317 14 JEQ EMIT0 jump to video display output if not 0467 * 0468 * R0 now points to PAB for alternate output device, the one-byte buffer 0469 * for which must immediately precede its PAB. PAB must have been set up 0470 * to write one byte. 0471 * 0472 643A 04C7 14 CLR R7 ALTOUT active 0473 643C D807 38 MOVB R7,@KYSTAT zero status byte 643E 837C 0474 6440 0600 14 DEC R0 point to one-byte VRAM buffer in front of PAB 0475 6442 06C1 14 SWPB R1 char to MSB 0476 6444 0420 54 BLWP @VSBW write char to buffer 6446 373E 0477 6448 05C0 14 INCT R0 point to Flag/Status byte 0478 644A 0420 54 BLWP @VSBR read it 644C 3746 0479 644E 0241 22 ANDI R1,>1F00 clear error bits without disturbing flag bits 6450 1F00 0480 6452 0420 54 BLWP @VSBW write it back to PAB 6454 373E 0481 6456 0220 22 AI R0,8 Set up pointer to namelength byte of PAB 6458 0008 0482 645A C800 38 MOV R0,@SUBPTR copy to DSR subroutine name-length pointer 645C 8356 0483 645E 0420 54 BLWP @DSRLNK put 1 byte to device 6460 37BE 0484 6462 0008 DATA >8 0485 6464 0460 28 B @BKLINK return to caller 6466 30EA 0486 * 0487 * Output is going to the video display 0488 * 0489 6468 0281 22 EMIT0 CI R1,7 Is it a bell? 646A 0007 0490 646C 1607 14 JNE NOTBEL 0491 646E 04C2 14 CLR R2 0492 6470 D802 38 MOVB R2,@KYSTAT 6472 837C 0493 6474 0420 54 BLWP @GPLLNK 6476 3784 0494 6478 0036 DATA >0036 Emit error tone 0495 647A 1060 14 JMP EMEXIT 0496 * 0497 647C 0281 22 NOTBEL CI R1,8 Is it a backspace? 647E 0008 0498 6480 160B 14 JNE NOTBS 0499 6482 0201 20 LI R1,>2000 6484 2000 0500 6486 C028 34 MOV @CURPO$(U),R0 6488 0016 0501 648A 0420 54 BLWP @VSBW 648C 373E 0502 648E 1501 14 JGT DECCUR 0503 6490 1055 14 JMP EMEXIT 0504 6492 0628 34 DECCUR DEC @CURPO$(U) 6494 0016 0505 6496 1052 14 JMP EMEXIT 0506 * 0507 6498 0281 22 NOTBS CI R1,>A Is it a line feed? 649A 000A 0508 649C 162B 14 JNE NOTLF 0509 649E C1E8 34 MOV @$SEND(U),R7 64A0 0034 0510 64A2 61E8 34 S @$SWDTH(U),R7 64A4 0030 0511 64A6 81E8 34 C @CURPO$(U),R7 64A8 0016 0512 64AA 1404 14 JHE SCRLL 0513 64AC AA28 54 A @$SWDTH(U),@CURPO$(u) 64AE 0030 64B0 0016 0514 64B2 1044 14 JMP EMEXIT 0515 64B4 C1CB 18 SCRLL MOV LINK,R7 0516 64B6 06A0 32 BL @SCROLL 64B8 339E 0517 64BA C2C7 18 MOV R7,LINK 0518 64BC 103F 14 JMP EMEXIT 0519 * 0520 *** SCROLLING ROUTINE 0521 * 0522 339E SCROLL EQU $LO+$-LLVSPT 0523 64BE C028 34 MOV @$SSTRT(U),R0 VRAM addr 64C0 0032 0524 64C2 0201 20 LI R1,LINBUF Line buffer 64C4 3A6C 0525 64C6 C0A8 34 MOV @$SWDTH(U),R2 Count 64C8 0030 0526 64CA A002 18 A R2,R0 Start at line 2 0527 64CC 0420 54 SCROL1 BLWP @VMBR 64CE 374A 0528 64D0 6002 18 S R2,R0 One line back to write 0529 64D2 0420 54 BLWP @VMBW 64D4 3742 0530 64D6 A002 18 A R2,R0 Two lines ahead for next read 0531 64D8 A002 18 A R2,R0 0532 64DA 8A00 38 C R0,@$SEND(U) End of screen? 64DC 0034 0533 64DE 1AF6 14 JL SCROL1 0534 64E0 C042 18 MOV R2,R1 Blank bottom row of screen 0535 64E2 0200 20 LI R0,>2000 Blank 64E4 2000 0536 64E6 60A8 34 S @$SEND(U),R2 64E8 0034 0537 64EA 0502 16 NEG R2 Now contains address of start of last line 0538 64EC C18B 18 MOV LINK,R6 0539 64EE 06A0 32 BL @FILL1 Write the blanks 64F0 3208 0540 64F2 0456 20 B *R6 0541 * 0542 64F4 0281 22 NOTLF CI R1,>D Is it a carriage return? 64F6 000D 0543 64F8 160D 14 JNE NOTCR 0544 64FA 04C0 14 CLR R0 0545 64FC C068 34 MOV @CURPO$(U),R1 64FE 0016 0546 6500 C0C1 18 MOV R1,R3 0547 6502 6068 34 S @$SSTRT(U),R1 Adjusted for screen not at 0 6504 0032 0548 6506 C0A8 34 MOV @$SWDTH(U),R2 6508 0030 0549 650A 3C02 128 DIV R2,R0 0550 650C 60C1 18 S R1,R3 0551 650E CA03 38 MOV R3,@CURPO$(U) 6510 0016 0552 6512 1014 14 JMP EMEXIT 0553 * 0554 6514 06C1 14 NOTCR SWPB R1 Assume it is a printable character 0555 6516 C028 34 MOV @CURPO$(U),R0 6518 0016 0556 651A 0420 54 BLWP @VSBW 651C 373E 0557 651E C0A8 34 MOV @$SEND(U),R2 6520 0034 0558 6522 0602 14 DEC R2 0559 6524 8080 18 C R0,R2 0560 6526 1607 14 JNE NOTCR1 0561 6528 C028 34 MOV @$SEND(U),R0 652A 0034 0562 652C 6028 34 S @$SWDTH(U),R0 Was last char on screen. Scroll 652E 0030 0563 6530 CA00 38 MOV R0,@CURPO$(U) 6532 0016 0564 6534 10BF 14 JMP SCRLL 0565 6536 0580 14 NOTCR1 INC R0 No scroll necessary 0566 6538 CA00 38 MOV R0,@CURPO$(U) 653A 0016 0567 * 0568 653C 0460 28 EMEXIT B @BKLINK 653E 30EA 0569 ;]* 0570 ;[*== CRLF routine CODE = -6 ================= 0571 * 0572 3420 CLF EQU $LO+$-LLVSPT 0573 6540 C14B 18 MOV LINK,R5 0574 6542 0202 20 LI R2,>000D 6544 000D 0575 6546 06A0 32 BL @EMT EMT will alter INT mask via B @BKLINK 6548 3312 0576 654A 0202 20 LI R2,>000A 654C 000A 0577 654E 0300 24 LIMI 0 Previous call to EMT altered INT mask 6550 0000 0578 6552 06A0 32 BL @EMT 6554 3312 0579 6556 C2C5 18 MOV R5,LINK 0580 6558 0460 28 B @BKLINK 655A 30EA 0581 ;]* 0582 ;[*== ?TERMINAL routine CODE = -8 ================= 0583 * scan for <clear>, <break>, FCTN+4 press 0584 * 0585 343C QTM EQU $LO+$-LLVSPT 0586 655C C14B 18 MOV LINK,R5 save return 0587 655E 06A0 32 BL @>0020 branch to console's test for <clear> 6560 0020 0588 6562 02C0 12 STST R0 store status in R0 0589 6564 1603 14 JNE QTM2 exit if not <clear> 0590 6566 06A0 32 QTM1 BL @>0020 check for <clear> again 6568 0020 0591 656A 13FD 14 JEQ QTM1 loop until not <clear> 0592 656C C2C5 18 QTM2 MOV R5,LINK restore return 0593 656E 0240 22 ANDI R0,>2000 keep only EQU bit 6570 2000 0594 6572 0460 28 B @BKLINK return to caller 6574 30EA 0595 ;]* 0596 ;[*== ?KEY routine CODE = -10 ================= 0597 * 0598 3456 QKY EQU $LO+$-LLVSPT 0599 6576 0420 54 BLWP @KSCAN 6578 373A 0600 657A D020 34 MOVB @KYCHAR,R0 657C 8375 0601 657E 0980 56 SRL R0,8 0602 6580 0280 22 CI R0,>00FF 6582 00FF 0603 6584 1601 14 JNE QKEY1 0604 6586 04C0 14 CLR R0 0605 6588 0460 28 QKEY1 B @BKLINK 658A 30EA 0606 ;]* 0607 ;[*== GOTOXY routine CODE = -12 ================= 0608 * 0609 346C GXY EQU $LO+$-LLVSPT 0610 658C 38E8 72 MPY @$SWDTH(U),R3 658E 0030 0611 6590 A102 18 A R2,R4 Position within screen 0612 6592 A128 34 A @$SSTRT(U),R4 Add VRAM offset to screen top 6594 0032 0613 6596 CA04 38 MOV R4,@CURPO$(U) 6598 0016 0614 659A 0460 28 B @BKLINK 659C 30EA 0615 ;] 0616 * ___ __ __ ____ ______ 0617 * / _ )/ /__ ____/ /__ / _/_/_/ __ \ 0618 * / _ / / _ \/ __/ '_/ _/ /_/_// /_/ / 0619 * /____/_/\___/\__/_/\_\ /___/_/ \____/ 0620 0621 * 0622 *== USE blocks file CODE = -14 ================= 0623 *== CREATE blocks file CODE = -16 ================= 0624 *== READ block from blocks file CODE = -18 ================= 0625 *== WRITE block to blocks file CODE = -20 ================= 0626 ;[*== Block File I/O Support ============================================ 0627 * 0628 * BPTOG utility to toggle one of 2 PABs for block file access 0629 * 0630 347E BPTOG EQU $LO+$-LLVSPT 0631 659E C028 34 MOV @$BPOFF(U),R0 PAB offset to R0 65A0 0040 0632 65A2 0201 20 LI R1,70 Toggle amount 65A4 0046 0633 65A6 2840 18 XOR R0,R1 New offset 0634 65A8 CA01 38 MOV R1,@$BPOFF(U) Update offset 65AA 0040 0635 * 0636 **xxx** entry point to insure we have correct PAB address 0637 348C BPSET EQU $LO+$-LLVSPT 0638 65AC C028 34 MOV @$DKBUF(U),R0 Get DISK_BUF address 65AE 002C 0639 65B0 A028 34 A @$BPABS(U),R0 Get BPABS address 65B2 003E 0640 * 0641 65B4 A028 34 A @$BPOFF(U),R0 Add current offset 65B6 0040 0642 65B8 C800 38 MOV R0,@BFPAB Update current block file's PAB address 65BA 34BC 0643 65BC 045B 20 RT 0644 * 0645 * CLOSE blocks file 0646 * 0647 349E BKCLOS EQU $LO+$-LLVSPT 0648 65BE C020 34 MOV @BFPAB,R0 65C0 34BC 0649 65C2 0201 20 LI R1,$FCLS Opcode=CLOSE 65C4 0100 0650 65C6 0420 54 BLWP @VSBW 65C8 373E 0651 65CA 0220 22 AI R0,9 Address of filename's char count 65CC 0009 0652 65CE C800 38 MOV R0,@SUBPTR Point to filename's char count 65D0 8356 0653 65D2 0420 54 BLWP @DSRLNK Close the file 65D4 37BE 0654 65D6 0008 DATA 8 0655 65D8 045B 20 RT Deal with error in caller 0656 * 0657 * storage area 0658 * 0659 34BA SVBRET EQU $LO+$-LLVSPT 0660 65DA 0000 DATA 0 Storage for LINK coming into BRW 0661 34BC BFPAB EQU $LO+$-LLVSPT 0662 65DC 0000 DATA 0 Storage for current blocks file PAB address... 0663 * ...will have current PAB on entry 0664 * PAB header storage 0665 * 0666 34BE PABHD EQU $LO+$-LLVSPT 0667 65DE BSS 4 BYTE 0: opcode 0=OPEN,1=CLOSE,2=READ,3=WRITE,4=RESTORE 0668 * BYTE 1: >05=INPUT mode + clear error,fixed,display,relative 0669 * >03=OUTPUT mode + " 0670 * >01=UPDATE mode + " 0671 * BYTE 2,3: save contents of DISK_BUF here 0672 65E2 80 BYTE >80 Record length 0673 65E3 80 BYTE >80 Character count of transfer 0674 65E4 BSS 2 Record number 0675 * 0676 *** file I/O equates 0677 * 0678 0000 $FOPN EQU >0000 0679 0100 $FCLS EQU >0100 0680 0200 $FRD EQU >0200 0681 0300 $FWRT EQU >0300 0682 0400 $FRST EQU >0400 0683 0005 $FINP EQU 5 0684 0003 $FOUT EQU 3 0685 0001 $FUPD EQU 1 0686 * 0687 *** BRW -- entry point for block read/write routines 0688 * 0689 34C6 BRW EQU $LO+$-LLVSPT 0690 65E6 C80B 38 MOV LINK,@SVBRET Save LINK address 65E8 34BA 0691 65EA C1C1 18 MOV R1,R7 Save CODE {R1 to R7} 0692 65EC 0817 56 SRA R7,1 Divide CODE by 2 (now -7,-8,-9,-10) 0693 65EE 0227 22 AI R7,12 CODE + 12 (now 5,4,3,2, with OP for output, but not input) 65F0 000C 0694 65F2 06A0 32 BL @BPSET Insure correct PAB address in BFPAB (it may have moved) 65F4 348C 0695 65F6 0287 22 CI R7,4 USE or CREATE? 65F8 0004 0696 65FA 110D 14 JLT BRW01 No 0697 65FC 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 65FE 347E 0698 6600 C020 34 MOV @BFPAB,R0 Load PAB address 6602 34BC 0699 6604 0220 22 AI R0,9 Set to name length byte 6606 0009 0700 6608 04C2 14 CLR R2 0701 660A C079 30 MOV *SP+,R1 Pop bfnaddr to R1 0702 660C D811 46 MOVB *R1,@MAINWS+5 Copy length byte to low byte of R2 660E 8305 0703 6610 0582 14 INC R2 Add 1 to # bytes to copy 0704 6612 0420 54 BLWP @VMBW Copy char count & pathname to PAB 6614 3742 0705 * 0706 *** set up PAB for OPEN 0707 * 0708 6616 0201 20 BRW01 LI R1,$FUPD Opcode=0,mode=update 6618 0001 0709 661A 9820 54 CB @MAINWS+15,@MAINWS+15 Set mode=input (OP)? 661C 830F 661E 830F 0710 6620 1C02 14 JOP BRW02 No 0711 6622 0201 20 LI R1,$FINP Yes...change mode=input 6624 0005 0712 6626 C801 38 BRW02 MOV R1,@PABHD Put in PAB header 6628 34BE 0713 662A C828 54 MOV @$DKBUF(U),@PABHD+2 VRAM buffer location to PAB header 662C 002C 662E 34C0 0714 6630 04C0 14 CLR R0 0715 6632 C800 38 MOV R0,@PABHD+6 Set record#=0 6634 34C4 0716 6636 C020 34 MOV @BFPAB,R0 VRAM destination 6638 34BC 0717 663A 0201 20 LI R1,PABHD RAM source 663C 34BE 0718 663E 0202 20 LI R2,8 Copy first 8 bytes of PAB header 6640 0008 0719 6642 0420 54 BLWP @VMBW Do the copy 6644 3742 0720 * 0721 *** open new blocks file [CODE = -14, USE; CODE = -16,CREATE] 0722 * 0723 6646 0220 22 AI R0,9 Address of filename's char count in PAB 6648 0009 0724 664A C800 38 MOV R0,@SUBPTR Point to-----^^^^ 664C 8356 0725 664E 0420 54 BLWP @DSRLNK Open/create the file 6650 37BE 0726 6652 0008 DATA 8 0727 6654 135F 14 JEQ BKERR 0728 6656 0287 22 CI R7,4 READ or WRITE? 6658 0004 0729 665A 1120 14 JLT BRW04 Yes 0730 665C 156E 14 JGT BRWDON No; =USE; we're done 0731 * 0732 *** write blank records to newly created blocks file [CODE = -16,CREATE] 0733 * 0734 665E C179 30 MOV *SP+,R5 No; = CREATE; pop #blocks from stack 0735 6660 0A35 56 SLA R5,3 Convert #blocks to #records 0736 6662 C0C5 18 MOV R5,R3 Save 0737 6664 C105 18 MOV R5,R4 Set up counter 0738 6666 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 6668 0301 0739 666A C800 38 MOV R0,@PABHD Copy to PAB header 666C 34BE 0740 666E 6144 18 BRLOOP S R4,R5 Calculate next record 0741 6670 C805 38 MOV R5,@PABHD+6 Copy to PAB header 6672 34C4 0742 6674 C020 34 MOV @BFPAB,R0 VRAM destination 6676 34BC 0743 6678 0201 20 LI R1,PABHD RAM source 667A 34BE 0744 667C 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 667E 0008 0745 6680 0420 54 BLWP @VMBW Do the copy 6682 3742 0746 6684 0220 22 AI R0,9 Address of filename's char count 6686 0009 0747 6688 C800 38 MOV R0,@SUBPTR Point to filename's char count 668A 8356 0748 668C 0420 54 BLWP @DSRLNK Write one record of blanks 668E 37BE 0749 6690 0008 DATA 8 0750 6692 1340 14 JEQ BKERR 0751 6694 C143 18 MOV R3,R5 Get #blocks 0752 6696 0604 14 DEC R4 Count down 1 record 0753 6698 16EA 14 JNE BRLOOP Write another record if not done 0754 669A 104F 14 JMP BRWDON We're done 0755 * 0756 *** prepare for read/write block 0757 * 0758 669C C179 30 BRW04 MOV *SP+,R5 Pop block# to write 0759 669E C1B9 30 MOV *SP+,R6 Pop bufaddr 0760 66A0 0605 14 DEC R5 Block#-1 0761 66A2 0A35 56 SLA R5,3 Convert to starting record# 0762 66A4 0204 20 LI R4,8 Load counter for 8 records 66A6 0008 0763 66A8 0200 20 LI R0,$FWRT+$FUPD Set up for WRITE 66AA 0301 0764 66AC 0203 20 LI R3,VMBW WRITE vector 66AE 3742 0765 66B0 0287 22 CI R7,2 Are we writing the block? 66B2 0002 0766 66B4 1304 14 JEQ BRW05 Yup 0767 66B6 0200 20 LI R0,$FRD+$FINP Nope...set up for READ 66B8 0205 0768 66BA 0203 20 LI R3,VMBR READ vector 66BC 374A 0769 66BE C800 38 BRW05 MOV R0,@PABHD Copy opcode&mode to PAB header 66C0 34BE 0770 * 0771 * READ/WRITE block routine [CODE = -18/-20] 0772 * 0773 66C2 C805 38 RWLOOP MOV R5,@PABHD+6 Copy record# to PAB header 66C4 34C4 0774 66C6 C020 34 MOV @BFPAB,R0 VRAM destination 66C8 34BC 0775 66CA 0201 20 LI R1,PABHD RAM source 66CC 34BE 0776 66CE 0202 20 LI R2,8 #Bytes of PAB header to copy to PAB 66D0 0008 0777 66D2 0420 54 BLWP @VMBW Do the copy 66D4 3742 0778 66D6 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 66D8 002C 0779 66DA C046 18 MOV R6,R1 RAM buffer to R1 0780 66DC 0202 20 LI R2,128 Bytes to copy 66DE 0080 0781 66E0 0287 22 CI R7,3 READ? 66E2 0003 0782 66E4 1301 14 JEQ BRW06 Yup 0783 66E6 0413 42 BLWP *R3 Nope...copy record to VRAM 0784 * 0785 * temporarily use CRU register---it should be OK 0786 * 0787 66E8 C320 34 BRW06 MOV @BFPAB,CRU PAB address 66EA 34BC 0788 66EC 022C 22 AI CRU,9 Address of filename's char count 66EE 0009 0789 66F0 C80C 38 MOV CRU,@SUBPTR Point to filename's char count 66F2 8356 0790 66F4 0420 54 BLWP @DSRLNK Read/write one record 66F6 37BE 0791 66F8 0008 DATA 8 0792 66FA 130C 14 JEQ BKERR 0793 66FC 0287 22 CI R7,2 WRITE? 66FE 0002 0794 6700 1303 14 JEQ BRW07 Yup...next record 0795 6702 C028 34 MOV @$DKBUF(U),R0 VRAM buffer address to R0 (DSRLNK trashed it!) 6704 002C 0796 6706 0413 42 BLWP *R3 Nope...copy record to RAM buffer 0797 6708 0585 14 BRW07 INC R5 Next record in file 0798 670A 0226 22 AI R6,128 Next record to/from block RAM buffer 670C 0080 0799 670E 0604 14 DEC R4 Count down 1 record 0800 6710 16D8 14 JNE RWLOOP Read/write another record if not done 0801 6712 1013 14 JMP BRWDON We're done 0802 * 0803 *** error handling 0804 * 0805 6714 D000 18 BKERR MOVB R0,R0 Device error? 0806 6716 1306 14 JEQ BKERR6 Yes, exit with disk error 0807 6718 0206 20 BKERR9 LI R6,9 No, exit with file error 671A 0009 0808 671C 1005 14 JMP BKCLN 0809 671E 0206 20 BKERR8 LI R6,8 Block# <=0! exit with range error 6720 0008 0810 6722 1002 14 JMP BKCLN 0811 6724 0206 20 BKERR6 LI R6,6 6726 0006 0812 6728 06A0 32 BKCLN BL @BKCLOS Close current blocks file; ignore error 672A 349E 0813 672C 0287 22 CI R7,4 USE or CREATE? 672E 0004 0814 6730 1102 14 JLT BKCLN1 No 0815 6732 06A0 32 BL @BPTOG Yes...toggle BPOFF & BFPAB 6734 347E 0816 6736 C006 18 BKCLN1 MOV R6,R0 Pass error back to caller 0817 6738 100C 14 JMP BKEXIT 0818 673A 04C6 14 BRWDON CLR R6 0819 673C 06A0 32 BL @BKCLOS Close current blocks file 673E 349E 0820 6740 1602 14 JNE BRWDN1 Error? 0821 6742 0206 20 LI R6,9 Yes...assume it was a file error 6744 0009 0822 6746 0287 22 BRWDN1 CI R7,4 (no error)...CREATE? 6748 0004 0823 674A 1602 14 JNE BRWDN2 No...we're done 0824 674C 06A0 32 BL @BPTOG Yes...revert to correct blocks file 674E 347E 0825 6750 C006 18 BRWDN2 MOV R6,R0 Error to R0 0826 6752 C2E0 34 BKEXIT MOV @SVBRET,LINK Restore LINK 6754 34BA 0827 6756 0460 28 B @BKLINK 6758 30EA 0828 ;] 0829 ;[* MSGTYP <<< Support for string typing in various banks >>> 0830 * 0831 * Called with: BL @MSGTYP 0832 * 0833 * R4 and R5 are the only registers that will be preserved 0834 * ..after a call to EMIT--- 0835 * 0836 * Input: R4 = Address of length byte of packed string 0837 * 0838 * We will pass the ASCII value of character to EMIT in R2 without 0839 * insuring it is 7 bits wide. 0840 * 0841 363A MSGTYP EQU $LO+$-LLVSPT 0842 675A 064E 14 DECT R Push return address 0843 675C C78B 30 MOV LINK,*R ...to Forth return stack 0844 675E 04C5 14 CLR R5 0845 6760 D174 28 MOVB *R4+,R5 Put string length in R5 and point R4 to 1st char 0846 6762 06C5 14 SWPB R5 Put char count in low byte 0847 6764 04C2 14 MTLOOP CLR R2 0848 6766 D0B4 28 MOVB *R4+,R2 Copy next char to R2 for EMIT 0849 6768 06C2 14 SWPB R2 Put char in low byte 0850 676A 0300 24 LIMI 0 We need to do this because we're calling EMIT directly 676C 0000 0851 676E 06A0 32 BL @EMT Call EMIT directly 6770 3312 0852 6772 05A8 34 INC @$OUT(U) Increment display line character count 6774 0052 0853 6776 0605 14 DEC R5 Decrement character count for this message 0854 6778 16F5 14 JNE MTLOOP Are we done? 0855 677A C2FE 30 MOV *R+,LINK Yes. Pop return address 0856 677C 045B 20 RT Return to caller 0857 ;] 0858 ;[*-- R4$5 --* Space-saving routine to copy FP nums (Now in low RAM) 0859 365E R4$5 EQU $LO+$-LLVSPT 0860 677E CD74 46 MOV *R4+,*R5+ 0861 6780 CD74 46 MOV *R4+,*R5+ 0862 6782 CD74 46 MOV *R4+,*R5+ 0863 6784 C554 38 MOV *R4,*R5 0864 6786 045B 20 RT 0865 ;] 0866 * __ __ _ __ _ __ __ 0867 * / / / /__ ___ ____ | | / /__ _____(_)__ _/ / / /__ 0868 * / /_/ (_-</ -_) __/ | |/ / _ `/ __/ / _ `/ _ \/ / -_) 0869 * \____/___/\__/_/ |___/\_,_/_/ /_/\_,_/_.__/_/\__/ 0870 * ___ ___ ____ 0871 * / _ \___ / _/__ ___ __/ / /____ 0872 * / // / -_) _/ _ `/ // / / __(_-< 0873 * /____/\__/_/ \_,_/\_,_/_/\__/___/ 0874 0875 ;[*== User Variable defaults ============================================ 0876 * 0877 3668 UBASE0 EQU $LO+$-LLVSPT 0878 6788 BSS 6 BASE OF USER VARIABLES 0879 678E 3668 DATA UBASE0 06 USER UCONS$ 0880 6790 FFA0 DATA SPBASE 08 USER S0 0881 6792 3FFE DATA RBASE 0A USER R0 { R0$ 0882 6794 36B4 DATA $UVAR 0C USER U0 0883 6796 FFA0 DATA SPBASE 0E USER TIB 0884 6798 001F DATA 31 10 USER WIDTH 0885 679A A000 DATA DPBASE 12 USER DP 0886 679C 30F6 DATA $SYS$ 14 USER SYS$ 0887 679E 0000 DATA 0 16 USER CURPOS 0888 67A0 3020 DATA INT1 18 USER INTLNK 0889 67A2 0001 DATA 1 1A USER WARNING 0890 67A4 0040 DATA 64 1C USER C/L$ { CL$ 0891 67A6 2010 DATA $BUFF 1E USER FIRST$ 0892 67A8 3020 DATA $LO 20 USER LIMIT$ 0893 67AA 0380 DATA >0380 22 USER COLTAB Color Table address in VRAM 0894 67AC 0300 DATA >0300 24 USER SATR Sprite Attribute Table address in VRAM 0895 67AE 0780 DATA >0780 26 USER SMTN Sprite Motion Table address in VRAM 0896 67B0 0800 DATA >0800 28 USER PDT Character Pattern Descriptor Table address in VRAM 0897 67B2 0080 DATA >80 2A USER FPB pushes address of user screen font file PAB 0898 * ...that is this relative distance from DISK_BUF 0899 67B4 1000 DATA >1000 >1B80 2C USER DISK_BUF (buffer loc in VRAM, size = 128 bytes) 0900 67B6 0460 DATA >460 >1152 >1CD2 2E USER PABS (area for PABs etc.) 0901 67B8 0028 DATA 40 30 USER SCRN_WIDTH 0902 67BA 0000 DATA 0 32 USER SCRN_START 0903 67BC 03C0 DATA 960 34 USER SCRN_END 0904 67BE 0000 DATA 0 36 USER ISR [Note: This used to be INT1] 0905 67C0 0000 DATA 0 38 USER ALTIN 0906 67C2 0000 DATA 0 3A USER ALTOUT 0907 67C4 0001 DATA 1 3C USER VDPMDE permanent location for VDPMDE 0908 67C6 00C6 DATA >80+>46 3E USER BPB pushes address of PAB area for blocks files 0909 * ...that is this relative distance from DISK_BUF 0910 67C8 0000 DATA 0 40 USER BPOFF offset into BPABS for current blocks file's PAB 0911 * ...always toggled between 0 and 70 0912 67CA 0800 DATA >0800 42 USER SPDTAB Sprite Descriptor Table address in VRAM 0913 67CC FFFF DATA -1 44 USER SCRFNT !0 = default = font file (DSKx.FBFONT or user file) 0914 * 0 = console font via GPLLNK 0915 67CE 0000 DATA 0 46 USER JMODE 0 = TI Forth, ~0 = CRU 0916 67D0 0000 DATA 0 48 USER WRAP for fbForth SCROLL word, 0 = no wrap, ~0 = wrap 0917 67D2 0000 DATA 0 4A USER S|F Flag for Symmetric or Floored Integer Division.. 0918 * 0 = Symmetric (default) 0919 * !0 = Floored 0920 36B4 $UVAR EQU $LO+$-LLVSPT 0921 67D4 BSS >80 USER VARIABLE AREA 0922 ;] 0923 ;[*== A Constant ==================================================== 0924 * 0925 3734 H2000 EQU $LO+$-LLVSPT 0926 6854 2000 DATA >2000 0927 ;]* 0928 * __ ____ _ ___ __ _ __ __ 0929 * / / / / /_(_) (_) /___ __ | | / /__ ____/ /____ _______ 0930 * / /_/ / __/ / / / __/ // / | |/ / -_) __/ __/ _ \/ __(_-< 0931 * \____/\__/_/_/_/\__/\_, / |___/\__/\__/\__/\___/_/ /___/ 0932 * /___/ 0933 * 0934 ;[*== Utility Vectors =================================================== 0935 * 0936 * GPLLNK DATA GLNKWS,GLINK1 <--located with its routine at GPLLNK 0937 * DSRLNK DATA DSRWS,DLINK1 <--located with its routine at DSRLNK 0938 3736 XMLLNK EQU $LO+$-LLVSPT 0939 6856 3A4C DATA UTILWS,XMLENT ; Link to ROM routines 6858 3756 0940 373A KSCAN EQU $LO+$-LLVSPT 0941 685A 3A4C DATA UTILWS,KSENTR ; Keyboard scan 685C 3832 0942 373E VSBW EQU $LO+$-LLVSPT 0943 685E 3A4C DATA UTILWS,VSBWEN ; VDP single byte write (R0=vaddr, R1[MSB]=value) 6860 3848 0944 3742 VMBW EQU $LO+$-LLVSPT 0945 6862 3A4C DATA UTILWS,VMBWEN ; VDP multiple byte write (R0=vaddr, R1=addr, R2=cnt) 6864 3854 0946 3746 VSBR EQU $LO+$-LLVSPT 0947 6866 3A4C DATA UTILWS,VSBREN ; VDP single byte read (R0=vaddr, R1[MSB]=value read) 6868 3862 0948 374A VMBR EQU $LO+$-LLVSPT 0949 686A 3A4C DATA UTILWS,VMBREN ; VDP multiple byte read (R0=vaddr, R1=addr, R2=cnt) 686C 386E 0950 374E VMOVE EQU $LO+$-LLVSPT 0951 686E 3A4C DATA UTILWS,VMOVEN ; VDP-to-VDP move (R0=cnt, R1=vsrc,R2=vdst) 6870 38AE 0952 3752 VWTR EQU $LO+$-LLVSPT 0953 6872 3A4C DATA UTILWS,VWTREN ; VDP write to register (R0[MSB]=VR#, R0[LSB]=value) 6874 387C 0954 ;]* 0955 ;[*== XMLENT -- Link to system XML utilities ============================ 0956 * 0957 3756 XMLENT EQU $LO+$-LLVSPT 0958 6876 C83E 50 MOV *R14+,@GPLWS+2 Get argument 6878 83E2 0959 687A 02E0 18 LWPI GPLWS Select GPL workspace 687C 83E0 0960 687E C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6880 3A62 0961 6882 C081 18 MOV R1,R2 Make a copy of argument 0962 6884 0281 22 CI R1,>8000 Direct address in ALC? 6886 8000 0963 6888 1B07 14 JH XML30 We have the address 0964 688A 09C1 56 SRL R1,12 0965 688C 0A11 56 SLA R1,1 0966 688E 0A42 56 SLA R2,4 0967 6890 09B2 56 SRL R2,11 0968 6892 A0A1 34 A @XMLTAB(R1),R2 6894 0CFA 0969 6896 C092 26 MOV *R2,R2 0970 6898 0692 24 XML30 BL *R2 0971 689A 02E0 18 LWPI UTILWS Get back to right WS 689C 3A4C 0972 689E C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 68A0 83F6 0973 68A2 0380 18 RTWP 0974 ;]* 0975 * ________ __ __ _ ____ __ __ ________ 0976 * / ___/ _ \/ / / / / |/ / //_/ / |/ / ___/ 0977 * / (_ / ___/ /__/ /__/ / ,< _ _ _ / /|_/ / (_ / 0978 * \___/_/ /____/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 0979 * 0980 *-----------------------------------------------------------------------* 0981 ;[*== GPLLNK- A universal GPLLNK - 6/21/85 - MG ========================= 0982 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 0983 * * 0984 * This routine will work with any GROM library slot since it is * 0985 * indexed off of R13 in the GPLWS. (It does require Mem Expansion) * 0986 * This GPLLNK does NOT require a module to be plugged into the * 0987 * GROM port so it will work with the Editor/Assembler, * 0988 * Mini Memory (with Mem Expansion), Extended Basic, the Myarc * 0989 * CALL LR("DSKx.xxx") or the CorComp Disk Manager Loaders. * 0990 * It saves and restores the current GROM Address in case you want * 0991 * to return back to GROM for Basic or Extended Basic CALL LINKs * 0992 * or to return to the loading module. * 0993 * * 0994 * ENTER: The same way as the E/A GPLLNK, i.e., BLWP @GPLLNK * 0995 * DATA >34 * 0996 * * 0997 * NOTES: Do Not REF GPLLNK when using this routine in your code. * 0998 * * 0999 * 70 Bytes - including the GPLLNK Workspace * 1000 *-----------------------------------------------------------------------* 1001 1002 * GPLWS (>83E0) is GPL workspace 1003 83E8 G_R4 EQU GPLWS+8 GPL workspace R4 1004 83EC G_R6 EQU GPLWS+12 GPL workspace R6 1005 * SUBSTK (>8373) is GPL Subroutine stack pointer 1006 0060 LDGADR EQU >60 Load & Execute GROM address entry point 1007 200E XTAB27 EQU >200E Low Mem XML table location 27 1008 * ..Will contain XMLRTN at startup 1009 166C GETSTK EQU >166C 1010 1011 3784 GPLLNK EQU $LO+$-LLVSPT 1012 68A4 3776 DATA GLNKWS R7 Set up BLWP Vectors 1013 68A6 3796 DATA GLINK1 R8 1014 * RTNADR EQU $LO+$-LLVSPT <---don't think we need this label 1015 68A8 37B2 DATA XMLRTN R9 address where GPL XML returns to us... 1016 * ...this address will already be in XTAB27,... 1017 * ...>200E, so don't really need it here} 1018 378A GXMLAD EQU $LO+$-LLVSPT 1019 68AA 176C DATA >176C R10 GROM Address for GPL 'XML >27' (>0F27 Opcode) 1020 68AC 0050 DATA >50 R11 Initialized to >50 where PUTSTK address resides 1021 3776 GLNKWS EQU $LO+$-LLVSPT->18 GPLLNK's workspace of which only... 1022 68AE BSS >08 R12-R15 ...registers R7 through R15 are used 1023 1024 3796 GLINK1 EQU $LO+$-LLVSPT 1025 68B6 C81B 46 MOV *R11,@G_R4 Put PUTSTK Address into R4 of GPL WS 68B8 83E8 1026 68BA C83E 50 MOV *R14+,@G_R6 Put GPL Routine Address in R6 of GPL WS 68BC 83EC 1027 68BE 02E0 18 LWPI GPLWS Load GPL WS 68C0 83E0 1028 68C2 0694 24 BL *R4 Save current GROM Address on stack 1029 68C4 C920 54 MOV @GXMLAD,@>8302(R4) Push GPL XML Address on stack for GPL Return 68C6 378A 68C8 8302 1030 68CA 05E0 34 INCT @SUBSTK Adjust the stack pointer 68CC 8373 1031 68CE 0460 28 B @LDGADR Execute our GPL Routine 68D0 0060 1032 1033 37B2 XMLRTN EQU $LO+$-LLVSPT 1034 68D2 C120 34 MOV @GETSTK,R4 Get GETSTK pointer 68D4 166C 1035 68D6 0694 24 BL *R4 Restore GROM address off the stack 1036 68D8 02E0 18 LWPI GLNKWS Load our WS 68DA 3776 1037 68DC 0380 18 RTWP All Done - Return to Caller 1038 ;] 1039 * ___ _______ __ _ ____ __ __ ________ 1040 * / _ \/ __/ _ \/ / / |/ / //_/ / |/ / ___/ 1041 * / // /\ \/ , _/ /__/ / ,< _ _ _ / /|_/ / (_ / 1042 * /____/___/_/|_/____/_/|_/_/|_| (_|_|_)_/ /_/\___/ 1043 * 1044 *-----------------------------------------------------------------------* 1045 ;[*== DSRLNK - A Universal Device Service Routine Link - MG ============= 1046 * {LES NOTE: Some labels have been modified for fbForth compatibility.} * 1047 * * 1048 * (Uses console GROM 0's DSRLNK routine) * 1049 * (Do not REF DSRLNK or GPLLNK when using these routines) * 1050 * (This DSRLNK will also handle Subprograms and CS1, CS2) * 1051 * * 1052 * ENTER: The same way as the E/A DSRLNK, i.e., BLWP @DSRLNK * 1053 * DATA 8 * 1054 * * 1055 * NOTES: Must be used with a GPLLNK routine * 1056 * Returns ERRORs the same as the E/A DSRLNK * 1057 * EQ bit set on return if error * 1058 * ERROR CODE in caller's MSB of Register 0 on return * 1059 * * 1060 * 186 Bytes total - including GPLLNK, DSRLNK and both Workspaces * 1061 *-----------------------------------------------------------------------* 1062 1063 0050 PUTSTK EQU >50 Push GROM Address to stack pointer 1064 836D TYPE$ EQU >836D DSRLNK Type byte for GPL DSRLNK 1065 8356 NAMLEN EQU >8356 Device name length pointer in VDP PAB 1066 8C02 VWA EQU >8C02 VDP Write Address location 1067 8800 VRD EQU >8800 VDP Read Data byte location 1068 83E9 G_R4LB EQU >83E9 GPL Workspace R4 Lower byte 1069 837C GSTAT EQU >837C GPL Status byte location 1070 1071 37BE DSRLNK EQU $LO+$-LLVSPT 1072 68DE 37C2 DATA DSRWS,DLINK1 Set BLWP Vectors 68E0 37C2 1073 1074 37C2 DSRWS EQU $LO+$-LLVSPT Start of DSRLNK workspace 1075 37C9 DR3LB EQU DSRWS+7 lower byte of DSRLNK workspace R3 1076 37C2 DLINK1 EQU $LO+$-LLVSPT 1077 68E2 C30C 18 MOV R12,R12 R0 Have we already looked up the LINK address? 1078 68E4 161C 14 JNE DLINK3 R1 YES! Skip lookup routine 1079 *<<-------------------------------------------------------------------------->>* 1080 * This section of code is only executed once to find the GROM address * 1081 * for the GPL DSRLNK - which is placed at DSRADR and R12 is set to >2000 * 1082 * to indicate that the address is found and to be used as a mask for EQ & CND * 1083 *------------------------------------------------------------------------------* 1084 68E6 02E0 18 LWPI GPLWS R2,R3 else load GPL workspace 68E8 83E0 1085 68EA C120 34 MOV @PUTSTK,R4 R4,R5 Store current GROM address on the stack 68EC 0050 1086 68EE 0694 24 BL *R4 R6 1087 68F0 0204 20 LI R4,>11 R7,R8 Load R4 with address of LINK routine vector 68F2 0011 1088 68F4 DB44 38 MOVB R4,@>402(R13) R9,R10 Set up GROM with address for vector 68F6 0402 1089 1090 ***les*** Note on above instruction: 1091 ***les*** 1. R13 of GPLWS has >9800=GRMRD (GROM Read Data) 1092 ***les*** 2. >402 added to GRMRD yields >9C02=GRMWA (GROM Write Address) 1093 1094 68F8 1004 14 JMP DLINK2 R11 Jump around R12-R15 1095 68FA 0000 DATA 0 R12 contains >2000 flag when set 1096 68FC 0000 DATA 0,0,0 R13-R15 contains WS, PC & ST for RTWP 68FE 0000 6900 0000 1097 6902 DB60 54 DLINK2 MOVB @G_R4LB,@>402(R13) Finish setting up GROM address 6904 83E9 6906 0402 1098 6908 C160 34 MOV @GETSTK,R5 Take some time & set up GETSTK pointer 690A 166C 1099 690C D81D 46 MOVB *R13,@DSRAD1 Get the GPL DSR LINK vector 690E 3811 1100 6910 05E0 34 INCT @DSRADR Adjust it to get past GPL FETCH instruction 6912 3810 1101 6914 0695 24 BL *R5 Restore the GROM address off the stack 1102 6916 02E0 18 LWPI DSRWS Reload DSRLNK workspace 6918 37C2 1103 691A 020C 20 LI R12,>2000 Set flag to signify DSRLNK address is set 691C 2000 1104 *<<-------------------------------------------------------------------------->>* 1105 691E 058E 14 DLINK3 INC R14 Adjust R14 to point to caller's DSR Type byte 1106 6920 D83E 48 MOVB *R14+,@TYPE$ Move it into >836D for GPL DSRLNK 6922 836D 1107 6924 C0E0 34 MOV @NAMLEN,R3 Save VDP address of Name Length 6926 8356 1108 6928 0223 22 AI R3,-8 Adjust it to point to PAB Flag byte 692A FFF8 1109 692C 0420 54 BLWP @GPLLNK Execute DSR LINK 692E 3784 1110 3810 DSRADR EQU $LO+$-LLVSPT 1111 6930 03 BYTE >03 High byte of GPL DSRLNK address 1112 3811 DSRAD1 EQU $LO+$-LLVSPT 1113 6931 00 BYTE >00 Lower byte of GPL DSRLNK address 1114 *----Error Check & Report to Caller's R0 and EQU bit------------------------- 1115 6932 D820 54 MOVB @DR3LB,@VWA Set up LSB of VDP Address for Error Flag 6934 37C9 6936 8C02 1116 6938 D803 38 MOVB R3,@VWA Set up MSB of VDP Address for Error Flag 693A 8C02 1117 693C 53CC 18 SZCB R12,R15 Clear EQ bit for Error Report 1118 693E D0E0 34 MOVB @VRD,R3 Get PAB Error Flag 6940 8800 1119 6942 0953 56 SRL R3,5 Adjust it to 0-7 error code 1120 6944 D743 30 MOVB R3,*R13 Put it into Caller's R0 (msb) 1121 6946 1603 14 JNE SETEQ If it's not zero, set EQ bit 1122 6948 2320 38 COC @GSTAT,R12 Else, test CND bit for Link Error (00) 694A 837C 1123 694C 1601 14 JNE DSREND No Error, Just return 1124 694E F3CC 18 SETEQ SOCB R12,R15 Error, so set Caller's EQ bit 1125 6950 0380 18 DSREND RTWP All Done - Return to Caller 1126 ;] 1127 ;[*== KSENTR -- Keyboard Scan (entry point) ============================= 1128 * 1129 3832 KSENTR EQU $LO+$-LLVSPT 1130 6952 02E0 18 LWPI GPLWS 6954 83E0 1131 6956 C80B 38 MOV R11,@UTILWS+22 Save GPL return address 6958 3A62 1132 695A 06A0 32 BL @SCNKEY Console keyboard scan routine 695C 000E 1133 695E 02E0 18 LWPI UTILWS 6960 3A4C 1134 6962 C80B 38 MOV R11,@GPLWS+22 Restore GPL return address 6964 83F6 1135 6966 0380 18 RTWP 1136 ;]* 1137 * _ _____ ___ __ ____ _ ___ __ _ 1138 * | | / / _ \/ _ \ / / / / /_(_) (_) /_(_)__ ___ 1139 * | |/ / // / ___/ / /_/ / __/ / / / __/ / -_|_-< 1140 * |___/____/_/ \____/\__/_/_/_/\__/_/\__/___/ 1141 * 1142 ;[*== VDP utilities (entry point) ======================================= 1143 * 1144 ** VDP single byte write 1145 * 1146 3848 VSBWEN EQU $LO+$-LLVSPT 1147 6968 06A0 32 BL @WVDPWA Write out address 696A 388E 1148 696C D82D 54 MOVB @2(R13),@VDPWD Write data 696E 0002 6970 8C00 1149 6972 0380 18 RTWP Return to calling program 1150 * 1151 ** VDP multiple byte write 1152 * 1153 3854 VMBWEN EQU $LO+$-LLVSPT 1154 6974 06A0 32 BL @WVDPWA Write out address 6976 388E 1155 6978 D831 48 VWTMOR MOVB *R1+,@VDPWD Write a byte 697A 8C00 1156 697C 0602 14 DEC R2 Decrement byte count 1157 697E 16FC 14 JNE VWTMOR More to write? 1158 6980 0380 18 RTWP Return to calling Program 1159 * 1160 ** VDP single byte read 1161 * 1162 3862 VSBREN EQU $LO+$-LLVSPT 1163 6982 06A0 32 BL @WVDPRA Write out address 6984 3894 1164 6986 DB60 54 MOVB @VDPRD,@2(R13) Read data 6988 8800 698A 0002 1165 698C 0380 18 RTWP Return to calling program 1166 * 1167 ** VDP multiple byte read 1168 * 1169 386E VMBREN EQU $LO+$-LLVSPT 1170 698E 06A0 32 BL @WVDPRA Write out address 6990 3894 1171 6992 DC60 48 VRDMOR MOVB @VDPRD,*R1+ Read a byte 6994 8800 1172 6996 0602 14 DEC R2 Decrement byte count 1173 6998 16FC 14 JNE VRDMOR More to read? 1174 699A 0380 18 RTWP Return to calling program 1175 * 1176 ** VDP write to register 1177 * 1178 387C VWTREN EQU $LO+$-LLVSPT 1179 699C C05D 26 MOV *R13,R1 Get register number and value 1180 699E D82D 54 MOVB @1(R13),@VDPWA Write out value 69A0 0001 69A2 8C02 1181 69A4 0261 22 ORI R1,>8000 Set for register write 69A6 8000 1182 69A8 D801 38 MOVB R1,@VDPWA Write out register number 69AA 8C02 1183 69AC 0380 18 RTWP Return to calling program 1184 * 1185 ** Set up to write to VDP 1186 * 1187 388E WVDPWA EQU $LO+$-LLVSPT 1188 69AE 0201 20 LI R1,>4000 69B0 4000 1189 69B2 1001 14 JMP WVDPAD 1190 * 1191 ** Set up to read VDP 1192 * 1193 3894 WVDPRA EQU $LO+$-LLVSPT 1194 69B4 04C1 14 CLR R1 1195 * 1196 ** Write VDP address 1197 * 1198 69B6 C09D 26 WVDPAD MOV *R13,R2 Get VDP address 1199 69B8 D820 54 MOVB @U_R2LB,@VDPWA Write low byte of address 69BA 3A51 69BC 8C02 1200 69BE E081 18 SOC R1,R2 Properly adjust VDP write bit 1201 69C0 D802 38 MOVB R2,@VDPWA Write high byte of address 69C2 8C02 1202 69C4 C06D 34 MOV @2(R13),R1 Get CPU RAM address 69C6 0002 1203 69C8 C0AD 34 MOV @4(R13),R2 Get byte count 69CA 0004 1204 69CC 045B 20 RT Return to calling routine 1205 1206 * 1207 ** VDP-to-VDP move. 1208 * 1209 38AE VMOVEN EQU $LO+$-LLVSPT 1210 69CE C05D 26 MOV *R13,R1 Get cnt to R1 1211 69D0 C0AD 34 MOV @2(R13),R2 Get vsrc to R2 69D2 0002 1212 69D4 C0ED 34 MOV @4(R13),R3 Get vdst to R3 69D6 0004 1213 69D8 0263 22 ORI R3,>4000 Prepare for VDP write 69DA 4000 1214 1215 ** copy cnt bytes from vsrc to vdst 1216 1217 69DC D820 54 VMVMOR MOVB @UTILWS+5,@VDPWA Write LSB of VDP read address 69DE 3A51 69E0 8C02 1218 69E2 D802 38 MOVB R2,@VDPWA Write MSB of VDP read address 69E4 8C02 1219 69E6 0582 14 INC R2 Next VDP read address 1220 69E8 D020 34 MOVB @VDPRD,R0 Read VDP byte 69EA 8800 1221 69EC D820 54 MOVB @UTILWS+7,@VDPWA Write LSB of VDP write address 69EE 3A53 69F0 8C02 1222 69F2 D803 38 MOVB R3,@VDPWA Write MSB of VDP write address 69F4 8C02 1223 69F6 0583 14 INC R3 Next VDP write address 1224 69F8 D800 38 MOVB R0,@VDPWD Write VDP byte 69FA 8C00 1225 69FC 0601 14 DEC R1 Decrement count 1226 69FE 16EE 14 JNE VMVMOR Repeat if not done 1227 6A00 0380 18 RTWP Return to calling program 1228 ;]* 1229 ;[*== fbForth Version Message =========================================== 1230 38E2 FBFMSG EQU $LO+$-LLVSPT 1231 * This is 18 bytes to maintain program offset. ?? DON'T REMEMBER WHY ?? 1232 * Also, printing the extra blanks overwrites the font-not-found error message. 1233 6A02 11 BYTE 17 1234 6A03 66 TEXT 'fbForth 2.0: ' 6A04 6246 6A06 6F72 6A08 7468 6A0A 2032 6A0C 2E30 6A0E 3A20 6A10 2020 6A12 2020 1235 ;] 1236 * __ ___ ___ ____ __ __ _ __ __ 1237 * / |/ /__ ___/ (_) _(_)__ _/ / / /__ | | /| / /__ _______/ /__ 1238 * / /|_/ / _ \/ _ / / _/ / _ `/ _ \/ / -_) | |/ |/ / _ \/ __/ _ (_-< 1239 * /_/ /_/\___/\_,_/_/_//_/\_,_/_.__/_/\__/ |__/|__/\___/_/ \_,_/___/ 1240 * 1241 ;[*== Modifiable words in Resident Dictionary =========================== 1242 ;[*** (ABORT) *** 1243 6A14 73CC DATA x#VLST_N <--Last word in ROM 1244 38F6 PABR_N EQU $LO+$-LLVSPT 1245 6A16 8728 DATA 7+TERMBT*LSHFT8+'(','AB','OR','T)'+TERMBT 6A18 4142 6A1A 4F52 6A1C 54A9 1246 1247 38FE PABORT EQU $LO+$-LLVSPT 1248 6A1E 8334 DATA DOCOL 1249 6A20 6ADE DATA ABORT,SEMIS 6A22 6358 1250 ;]* 1251 ;[*** FORTH *** ( --- ) [ IMMEDIATE word ] 1252 6A24 38F6 DATA PABR_N 1253 3906 FRTH_N EQU $LO+$-LLVSPT 1254 6A26 C546 DATA 5+TERMBT+PRECBT*LSHFT8+'F','OR','TH'+TERMBT 6A28 4F52 6A2A 54C8 1255 1256 390E FORTHV EQU $LO+$-LLVSPT+2 ; vocabulary link field 1257 3910 FORTHP EQU $LO+$-LLVSPT+4 ; pseudo name field 1258 3912 FORTHL EQU $LO+$-LLVSPT+6 ; chronological link field 1259 390C FORTH EQU $LO+$-LLVSPT 1260 6A2C 7218 DATA DOVOC 1261 6A2E A002 DATA DPBASE+2,>81A0,0 ; (may need to modify) 6A30 81A0 6A32 0000 1262 ;]* 1263 ;[*** ASSEMBLER *** ( --- ) [ IMMEDIATE word ] 1264 6A34 3906 DATA FRTH_N 1265 3916 ASMR_N EQU $LO+$-LLVSPT 1266 6A36 C941 DATA 9+TERMBT+PRECBT*LSHFT8+'A','SS','EM','BL','ER'+TERMBT 6A38 5353 6A3A 454D 6A3C 424C 6A3E 45D2 1267 1268 3922 ASMV EQU $LO+$-LLVSPT+2 ; vocabulary link field 1269 3926 ASML EQU $LO+$-LLVSPT+6 ; chronological link field 1270 3920 ASSM EQU $LO+$-LLVSPT 1271 6A40 7218 DATA DOVOC 1272 6A42 394A DATA SASM_N,>81A0,FORTHL ; <--ASMV initially points to last word in 6A44 81A0 6A46 3912 1273 * ; ...ASSEMBLER vocabulary in the kernel 1274 ;]* 1275 ;]* 1276 * ___ __ __ 1277 * / _ | ___ ___ ___ __ _ / / / /__ ____ 1278 * / __ |(_-<(_-</ -_) ' \/ _ \/ / -_) __/ 1279 * /_/ |_/___/___/\__/_/_/_/_.__/_/\__/_/ 1280 * _ __ __ __ _ __ __ 1281 * | | / /__ _______ _/ / __ __/ /__ _______ __ | | /| / /__ _______/ /__ 1282 * | |/ / _ \/ __/ _ `/ _ \/ // / / _ `/ __/ // / | |/ |/ / _ \/ __/ _ (_-< 1283 * |___/\___/\__/\_,_/_.__/\_,_/_/\_,_/_/ \_, / |__/|__/\___/_/ \_,_/___/ 1284 * /___/ 1285 * 1286 *== These are the only 2 words in the kernel in the ASSEMBLER vocabulary 1287 ;[*** NEXT, *** ( --- ) 1288 * 1st word in ASSEMBLER vocabulary 1289 * 1290 6A48 3910 DATA FORTHP <--points to PNF of FORTH 1291 392A NXT__N EQU $LO+$-LLVSPT 1292 6A4A 854E DATA 5+TERMBT*LSHFT8+'N','EX','T,'+TERMBT 6A4C 4558 6A4E 54AC 1293 1294 3930 NEXTC EQU $LO+$-LLVSPT 1295 6A50 3932 DATA NEXTC+2 <--Can't use '$' in DATA directive that gets moved! 1296 6A52 0200 20 NXT_P LI R0,>045F load "B *NEXT" in R0 (NEXT=R15) 6A54 045F 1297 6A56 C068 34 MOV @$DP(U),R1 HERE to R1 6A58 0012 1298 6A5A CC40 34 MOV R0,*R1+ compile "B *NEXT" 1299 6A5C CA01 38 MOV R1,@$DP(U) update HERE 6A5E 0012 1300 6A60 CA28 54 MOV @$CURNT(U),@$CNTXT(U) set CONTEXT vocabulary to CURRENT vocabulary 6A62 0058 6A64 0056 1301 6A66 045F 20 B *NEXT back to inner interpreter 1302 1303 * : NEXT, ( --- ) 1304 * *NEXT B, ; 1305 ;]* 1306 ;[*** ;ASM *** ( --- ) 1307 * 2nd and last word in ASSEMBLER vocabulary; points to NEXT, pointed to by 1308 * ASSEMBLER as the last word defined in the ASSEMBLER vocabulary in the kernel. 1309 * 1310 6A68 392A DATA NXT__N 1311 394A SASM_N EQU $LO+$-LLVSPT 1312 6A6A 84 BYTE 4+TERMBT <--note different name field format 1313 6A6B 3B TEXT ';ASM' 6A6C 4153 6A6E 4D 1314 6A6F A0 BYTE ' '+TERMBT 1315 1316 3950 SASM EQU $LO+$-LLVSPT 1317 6A70 3952 DATA SASM+2 <--Can't use '$' in DATA directive that gets moved! 1318 6A72 10EF 14 JMP NXT_P finish up in NEXT, 1319 1320 * : ;ASM ( --- ) 1321 * *NEXT B, ; 1322 ;]* 1323 1324 ;[*== Some Variables (KEYCNT etc.) ====================================== 1325 1326 3954 KEYCNT EQU $LO+$-LLVSPT 1327 6A74 FFFF DATA -1 Used in cursor flash logic 1328 3956 INTACT EQU $LO+$-LLVSPT 1329 6A76 0000 DATA 0 Non-zero during user's interrupt service routine 1330 * 1331 *++ variables used by some graphics primitives 1332 * 1333 3958 $DMODE EQU $LO+$-LLVSPT 1334 6A78 0000 DATA 0 ; actual location of variable contents 1335 395A $DCOL EQU $LO+$-LLVSPT 1336 6A7A FFFF DATA -1 ; actual location of variable contents 1337 1338 *=========================================================== 1339 ;]* 1340 * ______ ___ _____ __ 1341 * /_ __/______ ___ _ ___ ___ / (_)__ ___ / ___/__ ___/ /__ 1342 * / / / __/ _ `/ ' \/ _ \/ _ \/ / / _ \/ -_) / /__/ _ \/ _ / -_) 1343 * /_/ /_/ \_,_/_/_/_/ .__/\___/_/_/_//_/\__/ \___/\___/\_,_/\__/ 1344 * /_/ 1345 * 1346 ;[*== Trampoline Code =================================================== 1347 * 1348 * MYBANK must be at same location in all banks with the code that appears 1349 * in the following table. The EQUates for BANK0--BANK3 may also be in the 1350 * same places in each bank for convenience, but they only need to appear once. 1351 * 1352 * Bank Select MYBANK 1353 * ---- ------ ------ 1354 * 0 >6006 >C000 1355 * 1 >6004 >8000 1356 * 2 >6002 >4000 1357 * 3 >6000 >0000 1358 * 1359 * Bank0 code will look like this 1360 * 1361 * MYBANK DATA >C000 1362 * BANK0 EQU >C000 1363 * BANK1 EQU >8000 1364 * BANK2 EQU >4000 1365 * BANK3 EQU >0000 1366 * 1367 * Banks 1--3 will look the same, including labels, and the DATA 1368 * instruction at MYBANK's location will correspond to its bank. 1369 * 1370 * Before a bank is selected, the values above will be shifted right 13 1371 * bits and have >6000 added. 1372 * 1373 ;[*** BLBANK ************************************************************ 1374 * 1375 * General bank branching routine (32KB ROM, i.e., 4 banks) for a 1376 * branch that is expected to return (not high-level Forth) via RTBANK--- 1377 * --put in scratchpad or low RAM 1378 * --called by 1379 * BL @BLBANK 1380 * DATA dst_addr - >6000 + bank# in left 2 bits 1381 * 1382 395C BLBANK EQU $LO+$-LLVSPT 1383 6A7C 064E 14 DECT R ; reserve space on return stack (R14) 1384 6A7E C33B 30 MOV *LINK+,CRU ; copy destination bank address to R12 1385 6A80 C78B 30 MOV LINK,*R ; push return address 1386 6A82 064E 14 DECT R ; reserve space on return stack 1387 6A84 C7A0 46 MOV @x#MYBANK,*R ; push return bank (leftmost 2 bits) 6A86 7FFE 1388 6A88 C2CC 18 MOV CRU,LINK ; copy destination bank address to R11 1389 6A8A 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6A8C 1FFF 1390 6A8E 022B 22 AI LINK,>6000 ; make it a real address 6A90 6000 1391 6A92 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1392 6A94 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6A96 6000 1393 6A98 04DC 26 CLR *CRU ; switch to destination bank 1394 6A9A 045B 20 B *LINK ; branch to destination address 1395 ;]* 1396 ;[*** RTBANK ************************************************************ 1397 * 1398 * General bank return routine (32KB ROM, i.e., 4 banks)--- 1399 * --put in scratchpad or low RAM 1400 * --called by 1401 * B @RTBANK 1402 * 1403 397C RTBANK EQU $LO+$-LLVSPT 1404 6A9C C33E 30 MOV *R+,CRU ; pop return bank# from return stack to R12 1405 6A9E 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1406 6AA0 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6AA2 6000 1407 6AA4 C2FE 30 MOV *R+,LINK ; pop return address from return stack 1408 6AA6 04DC 26 CLR *CRU ; switch to destination bank 1409 6AA8 045B 20 B *LINK ; branch to return address 1410 ;]* 1411 ;[*** BLF2A ************************************************************* 1412 * 1413 * High-level Forth to ALC bank branching routine (32KB ROM, i.e., 4 1414 * banks) that is expected to return to bank0 via RTNEXT. This will 1415 * only(?) be used for the ALC payload of Forth stubs in bank0--- 1416 * --put in scratchpad or low RAM 1417 * --called by 1418 * BL @BLF2A 1419 * DATA dst_addr - >6000 + bank# in left 2 bits 1420 * 1421 398A BLF2A EQU $LO+$-LLVSPT 1422 6AAA C2DB 26 MOV *LINK,LINK ; copy destination bank address to R11 1423 6AAC C30B 18 MOV LINK,CRU ; copy it to R12 1424 6AAE 024B 22 ANDI LINK,>1FFF ; mask off leftmost 3 bits to reveal address - >6000 6AB0 1FFF 1425 6AB2 022B 22 AI LINK,>6000 ; make it a real address 6AB4 6000 1426 6AB6 09DC 56 SRL CRU,13 ; shift bank# into bits 1-2 of R12 1427 6AB8 022C 22 AI CRU,>6000 ; make it a real bank-switch address 6ABA 6000 1428 6ABC 04DC 26 CLR *CRU ; switch to destination bank 1429 6ABE 045B 20 B *LINK ; branch to destination address 1430 ;]* 1431 ;[*** RTNEXT ************************************************************ 1432 * 1433 * High-level Forth bank "return" routine from ALC (32KB ROM, i.e., 4 1434 * banks)--- 1435 * --put in scratchpad or low RAM 1436 * --called by 1437 * B @RTNEXT 1438 * 1439 39A0 RTNEXT EQU $LO+$-LLVSPT 1440 6AC0 C320 34 MOV @INTACT,CRU Are we in user's ISR? 6AC2 3956 1441 6AC4 1602 14 JNE RTNXT1 Don't enable interrupts if so. 1442 6AC6 0300 24 LIMI 2 6AC8 0002 1443 6ACA 04E0 34 RTNXT1 CLR @>6006 ; switch to bank 0 6ACC 6006 1444 6ACE 045F 20 B *NEXT ; branch to next CFA (in R15) 1445 ;]* 1446 ;[*** BLA2F ************************************************************* 1447 * 1448 * ALC to high-level Forth bank branching routine (32KB ROM, i.e., 4 1449 * banks) that is expected to return to calling bank via RTA2F--- 1450 * --put in scratchpad or low RAM 1451 * --called by 1452 * BL @BLA2F 1453 * DATA <Forth cfa in bank0> 1454 * 1455 39B0 BLA2F EQU $LO+$-LLVSPT 1456 6AD0 064E 14 DECT R ; reserve space on return stack 1457 6AD2 C2BB 30 MOV *LINK+,W ; move CFA of Forth routine to W 1458 6AD4 C78B 30 MOV LINK,*R ; push return address of calling bank 1459 6AD6 064E 14 DECT R ; reserve space on return stack 1460 6AD8 C7A0 46 MOV @x#MYBANK,*R ; push return bank# (leftmost 2 bits) 6ADA 7FFE 1461 6ADC 064E 14 DECT R ; reserve spot on return stack 1462 6ADE C78D 30 MOV IP,*R ; move current IP to return stack 1463 6AE0 020D 20 LI IP,RTA2F ; move address of return procedure to IP 6AE2 39CC 1464 6AE4 04E0 34 CLR @>6006 ; switch to bank0 6AE6 6006 1465 6AE8 0460 28 B @DOEXEC ; Execute the Forth routine 6AEA 833C 1466 ;]* 1467 ;[*** RTA2F ************************************************************* 1468 * 1469 * ALC to high-level Forth bank "return" routine from Forth to calling 1470 * ALC (32KB ROM, i.e., 4 banks)--- 1471 * --put in scratchpad or low RAM 1472 * --called through B *NEXT at end of Forth word's execution in BLA2F 1473 * 1474 39CC RTA2F EQU $LO+$-LLVSPT 1475 6AEC 39CE DATA RTA2F+2 ; stored in IP by BLA2F (points to W, next instruction) 1476 6AEE 39D0 DATA RTA2F+4 ; stored in W by NEXT (points to "code field", next instruction) 1477 6AF0 C37E 30 MOV *R+,IP ; restore previous IP ("code field" executed by NEXT) 1478 * Retrieve ALC return info and return to caller... 1479 * ...caller will execute B *NEXT when it finishes 1480 6AF2 0460 28 B @RTBANK ; branch to general bank return routine above 6AF4 397C 1481 ;]* 1482 ;]*********************************************************************** 1483 ;[*++ Bank-specific cell-/byte-reading code ++* 1484 ;[*** BANK@ *** ( bankAddr bank# --- cell_contents ) 1485 *++ Read cell contents of address in Bank bank# or RAM. 1486 *++ Register inputs: 1487 *++ R0: bank-switch address 1488 *++ R1: address in bank# to be read 1489 1490 39D6 _BKAT EQU $LO+$-LLVSPT 1491 6AF6 04D0 26 CLR *R0 ; switch banks 1492 6AF8 C651 38 MOV *R1,*SP ; get cell contents of address to stack 1493 6AFA 0460 28 B @RTNEXT ; return to inner interpreter 6AFC 39A0 1494 ;]* 1495 ;[*** BANKC@ *** ( bankAddr bank# --- byte_contents ) 1496 *++ Read byte contents of address in Bank bank# or RAM. 1497 *++ Register inputs: 1498 *++ R0: bank-switch address 1499 *++ R1: address in bank# to be read 1500 1501 39DE _BKCAT EQU $LO+$-LLVSPT 1502 6AFE 04D0 26 CLR *R0 ; switch banks 1503 6B00 04C2 14 CLR R2 ; clear R2 1504 6B02 D811 46 MOVB *R1,@F_R2LB ; get byte contents of address to low byte of R2 6B04 8305 1505 6B06 C642 30 MOV R2,*SP ; get byte contents of address to stack 1506 6B08 0460 28 B @RTNEXT ; return to inner interpreter 6B0A 39A0 1507 1508 ;]* 1509 1510 ;]* 1511 * _______ __ _________ ___ __ 1512 * / __/ _ | / |/ / __/ / / _ )___ ___/ /_ __ 1513 * _\ \/ __ |/ /|_/ /\ \/_/ / _ / _ \/ _ / // / 1514 * /___/_/ |_/_/ /_/___(_) /____/\___/\_,_/\_, / 1515 * /___/ 1516 * 1517 ;[*** SAMS! *** ( --- ) 1518 * This calls the SAMS initialization in the startup code in bank 1. 1519 * 1520 * DATA SMSQ_N 1521 * SMST_N DATA 5+TERMBT*LSHFT8+'S','AM','S!'+TERMBT 1522 * SAMSST DATA $+2 1523 * BL @BLF2A 1524 * DATA _SMSST->6000+BANK1 1525 1526 6B0C 06A0 32 _SMSST BL @SMSINI initialize SAMS card 6B0E 610C 1527 6B10 0460 28 B @RTNEXT back to inner interpreter 6B12 39A0 1528 ;]* 1529 ;[*== Required strings, tables, variables... ============================ 1530 * 1531 * 1532 * Default blocks filename 1533 * 1534 39F4 DEFNAM EQU $LO+$-LLVSPT 1535 6B14 0C BYTE 12 1536 6B15 44 TEXT "DSK1.FBLOCKS " 6B16 534B 6B18 312E 6B1A 4642 6B1C 4C4F 6B1E 434B 6B20 5320 1537 * 1538 * Default colors for all VDP modes--- 1539 * MSB: Screen color (LSN); text FG (MSN), BG (LSN) 1540 * LSB: Color Table colors (FG/BG) 1541 * 1542 3A02 DEFCOL EQU $LO+$-LLVSPT 1543 6B22 4F00 DATA >4F00 ; TEXT80 offset=0 1544 6B24 4F00 DATA >4F00 ; TEXT offset=2 1545 6B26 F4F4 DATA >F4F4 ; GRAPHICS offset=4 1546 6B28 11F4 DATA >11F4 ; MULTI offset=6 1547 6B2A FE10 DATA >FE10 ; GRAPHICS2 offset=8 1548 6B2C FEF4 DATA >FEF4 ; SPLIT offset=10 1549 6B2E FEF4 DATA >FEF4 ; SPLIT2 offset=12 1550 * 1551 * Default text mode 1552 * 1553 3A10 DEFTXT EQU $LO+$-LLVSPT 1554 6B30 0001 DATA >0001 1555 * 1556 * Font flag is checked by FNT to see whether to copy DSKx.FBFONT to font PAB 1557 * 1558 3A12 FNTFLG EQU $LO+$-LLVSPT 1559 6B32 0000 DATA 0 ; font flag initially 0 1560 * 1561 * Speech variables needing initial value (more below LLVEND) 1562 * 1563 3A14 SPCSVC EQU $LO+$-LLVSPT 1564 6B34 0000 DATA 0 1565 * 1566 * Sound Table #1 Workspace for sound variables. Only using R0..R4 1567 * 1568 3A16 SND1WS EQU $LO+$-LLVSPT 1569 3A16 SND1ST EQU SND1WS R0 (sound table status) 0=no table; 1=loading sound... 1570 6B36 0000 DATA 0 ...bytes; -1=counting 1571 3A18 SND1DS EQU SND1WS+2 R1 (sound-table byte destination)... 1572 6B38 8400 DATA SOUND ...initialized to sound chip 1573 3A1A SND1AD EQU SND1WS+4 R2 (sound table address) 1574 6B3A 0000 DATA 0 1575 3A1C SND1CT EQU SND1WS+6 R3 (# of sound bytes to load or... 1576 6B3C 0000 DATA 0 ...sound count = seconds * 60) 1577 3A1E SND1SP EQU SND1WS+8 R4 (pointer to top of sound stack) 1578 6B3E 3AE4 DATA SNDST0 initialized to bottom of sound stack 1579 * 1580 * Sound Table #2 Workspace for sound variables. Only using R0..R3 1581 * 1582 3A20 SND2WS EQU $LO+$-LLVSPT 1583 3A20 SND2ST EQU SND2WS R0 (sound table status) 0=no table ; 1=loading sound... 1584 6B40 0000 DATA 0 ...bytes; -1=counting 1585 3A22 SND2DS EQU SND2WS+2 R1 (sound-table byte destination)... 1586 6B42 8400 DATA SOUND ...initialized to sound chip 1587 ;]* 1588 * 1589 * This is the end of low-level support code that gets copied. 1590 * 1591 LLVEND 1592 1593 ;[*== Un-initialized Variables and workspaces... ========================= 1594 * Start of definitions of variables and workspaces that do not need to 1595 * take up space in ROM because they need no initial values. 1596 * 1597 * Sound Table #2 Workspace for sound variables..continued. 1598 * 1599 3A24 SND2AD EQU SND2WS+4 R2 (sound table address) 1600 3A26 SND2CT EQU SND2WS+6 R3 (# of sound bytes to load or... 1601 * ...sound count = seconds * 60) 1602 3A28 SDMUTE EQU SND2WS+8 dummy destination for sound byte 1603 * 1604 * Branch Stack for ISR processing of Speech, 2 Sound Tables and return 1605 * 1606 3A2A BRSTK EQU SDMUTE+2 1607 * 1608 * Speech variables (more above LLVEND) 1609 * 1610 3A32 SSFLAG EQU BRSTK+8 1611 3A34 SPCNT EQU SSFLAG+2 1612 3A36 SPADR EQU SPCNT+2 1613 3A38 BANKSV EQU SPADR+2 1614 3A3A PADSV EQU BANKSV+2 1615 * 1616 * Panel window: height, width and screen position...used by PANEL and SCROLL 1617 * 1618 3A46 PANWIN EQU PADSV+12 panel height, width and screen start 1619 1620 *== Utility Workspace ================================================= 1621 *** General utility workspace registers 1622 3A4C UTILWS EQU PANWIN+6 1623 3A51 U_R2LB EQU UTILWS+5 1624 1625 3A6C LINBUF EQU UTILWS+32 1626 3ABC CURCHR EQU LINBUF+80 1627 1628 *++ variable used by the 40/80-column editor 1629 3ABE OLDCUR EQU CURCHR+2 1630 1631 *++ FILE I/O variables 1632 1633 3AC6 PBADR EQU OLDCUR+8 1634 3AC8 PBBF EQU PBADR+2 1635 3ACA PBVBF EQU PBBF+2 1636 1637 *++ Floating Point Math Library variables 1638 3ACC FPVARS EQU PBVBF+2 1639 1640 *++ SAMS flag 1641 3AE2 SAMSFL EQU FPVARS+22 1642 1643 *++ Bottom of Sound Stack 1644 *++ This location marks the top of the low-level support code. The Sound 1645 *++ Stack grows upward toward the Return Stack by moving the entire stack 1646 *++ up one cell to make room for the next new bottom entry. 1647 3AE4 SNDST0 EQU SAMSFL+2 1648 ;]* ...lee Mmm, yummi, yummi, code!?️ Note to self: Return later? ...to pick the flesh off the bones of this code!? ? P.S. Thanks Lee! 2 Quote Link to comment Share on other sites More sharing options...
